Is it normal that this function takes 7kB of code size?
Hello, I am programming nRF51 on Keil. My app uses BLE with softdevice S130, PWM, and I2C communication with two sensors. Also RTT for debugging.
I have already reached the limit code size of Keil with free license, 32kB. I am using Optimization level 0 because when I put 1 or higher mmy app doesn't work anymore, but that is another question I haven't had time to debug yet.
My question: is it normal that putting just one call in main loop to this function, using optimization level 0, code size increases from 28kB to 35kB (7kB difference!)?? Or I am doing something wrong?
Thank you very much for your time,
Luis Rodenas
This is the function (actually splitted in 2 functions):
uint32_t MS5611Read2(uint8_t CMD, uint8_t OSR)  // temperature data read
    uint8_t data[3] = {0,0,0  };
	uint32_t err_code;
	err_code = twi_write_single2((CMD | OSR), 1);
  switch (OSR)
  case ADC_256:
		nrf_delay_ms(1);
    break;  // delay for conversion to complete
  case ADC_512:
		nrf_delay_ms(3);
  case ADC_1024:
		nrf_delay_ms(4);
  case ADC_2048:
		nrf_delay_ms(6);
  case ADC_4096:
		nrf_delay_ms(10);
	twi_read_burst2(0x00, data, 3);
  return (uint32_t) (((uint32_t) data[0] << 16) | (uint32_t) data[1] << 8 | data[2]); // construct PROM data for return to main program
void ms5611_read2(){
   uint32_t D1 = 0, D2 = 0;  // raw MS5611 pressure and temperature data
   double dT, OFFSET, SENS, T2, OFFSET2, SENS2;  // First order and second order corrections for raw S5637 temperature and pressure data
	double Temperature, Pressure; // stores MS5611 pressures sensor pressure and temperature
    D1 = MS5611Read2(ADC_D1, OSR);  // get raw pressure value
    D2 = MS5611Read2(ADC_D2, OSR);  // get raw temperature value
    dT = D2 - Pcal[5]*pow(2,8);    // calculate temperature difference from reference
    OFFSET = Pcal[2]*pow(2, 16) + dT*Pcal[4]/pow(2,7);
    SENS = Pcal[1]*pow(2,15) + dT*Pcal[3]/pow(2,8);
    Temperature = (2000 + (dT*Pcal[6])/pow(2, 23))/100;           // First-order Temperature in degrees Centigrade
    // Second order corrections
    if(Temperature > 20)
      T2 = 0; // correction for high temperatures
      OFFSET2 = 0;
      SENS2 = 0;
    if(Temperature < 20)                   // correction for low temperature
      T2      = dT*dT/pow(2, 31);
      OFFSET2 = 5*(100*Temperature - 2000)*(100*Temperature - 2000)/2;
      SENS2   = 5*(100*Temperature - 2000)*(100*Temperature - 2000)/4;
    if(Temperature < -15)                      // correction for very low temperature
      OFFSET2 = OFFSET2 + 7*(100*Temperature + 1500)*(100*Temperature + 1500);
      SENS2 = SENS2 + 11*(100*Temperature + 1500)*(100*Temperature + 1500)/2;
    // End of second order corrections
    Temperature = Temperature - T2/100;
    OFFSET = OFFSET - OFFSET2;
    SENS = SENS - SENS2;
    Pressure = (((D1*SENS)/pow(2, 21) - OFFSET)/pow(2, 15))/100;  // Pressure in mbar or Pa/100
      float altitude = 145366.45*(1. - pow((Pressure/1013.25), 0.190284));
	char buffer [50];
	sprintf(buffer, "%f", altitude);
		SEGGER_RTT_WriteString(0, buffer);
  • Answering myself from info on comments: Yes, it is normal that this code, without optimization, takes almost 7Kb of code space. Many other files were linked due to using floats, pow(), etc.
    If you face something similar do what endnode suggests: "To the code size analysis: the usual (and probably the only "right" way) is to compile project twice, once with this new code and second time without. Then compare MAP files (or some equivalent produced by Keil) and you will clearly see where your magic 7kB come from."
    What I did to compile my larger code was to install Eclipse+GCC and now I use that as my development environment. Very happy so far. Followed this tutorial: devzone.nordicsemi.com/.../
  • Glad to hear that! I'm using the latest ARM EABI GCC toolchain (4.9 2015q3) without problems and it works even with -Os optimizations which is giving very good results in terms of code size. One more fro me then: using any float or non 2^ arithemtic in embedded app usually signs bad design and lack of understanding of such constrained system. All transformations should be one on the other side (unless you design extremely cost sensitive solution and ARM Cortex-M0 is your more powerful side;).
    Cheers Jan
