Anomalous RTC2_IRQn generated after DFU
EDIT: the IRQ is always generated by the RTC2, the Radio is not involved
we are facing a strange issue with the FW development on nRF52832.
Suddendly after a FW update OTA via BLE (using a slighly changed version of Secure BLE DFU Bootloader) the MCU starts consuming a lot (about 3.3mA) but keeps working as expected for the remaining functionalities.
Here is the conditions generating the issue:
HW: nRF52832
FW: SDK 16, sd132 6.1.1
BLE Role: Single connection as Peripheral
  1. Update only the Main App using OTA update via BLE, bootloader is the one present in ..\examples\dfu\secure_bootloader\pca10040_s132_ble with minor changes into the user init of dfu;
  2. At restart, clear the whitelist deleting the previous peer if present;
  3. Bond with the Central, bonding procedure is started by the Central with pm_conn_secure(...);
  4. Disconnection and reconnection of the Central randomly generated;
As a consequence of the above steps the MCU after a short time (seconds to minutes) starts consuming around 3.3mA.
Not sure that step 4 is affecting the phenomenon since it occurs both during the connected and disconnected status.
Debugging we managed to retrieve the cause of the anomalous consumption by printing in the nrf_pwr_mgmt_run the wake up source from idle.
The RTC2_IRQn  is continuosly generated (I suppose from the Softdevice since there is no use of RTC2 in the code) with a frequency of about 7350 Hz, therefore continusly waking up the MCU from the sd_app_evt_wait().
The MCU continues working but with a usage percentage around 75% (all due to the interrupts) and therefore an high power consumption.
This strange behaviour occurs only after a FW update via OTA, I couldn't reproduce it differently.
As a workaround at the moment we are counting the number of interrupts per second in the nrf_pwr_mgmt_run , in case it exceeds a reasonable threshold (2k events) we reset the MCU, therefore we avoid the anomalous consumption from draining the battery. However this is not a solution but just a workaround.
Suggestion on the reasons behind these strange triggers and how to avoid them?
In case you need more details or info please let me know.
I will share what we possibily could share.
  • Hi Sigurd,
    attached is the debug window with RTC2 registers after the DFU.
    Unfortunately the issue doesn't occur with the debugger connected, therefore I am not sure that such a test is representative of the real problem occurring only when there is no debugger or RTT viewer session ongoing.
    EDIT: I tried to enter debug mode without reset and code loading after that the issue occurs.
    As you can see in the picture below, there actually is the timer COMPARE0 enabled and the counter is running as if the bootloader initialized the RTC2 without resetting.
    Hoping it is not an artifact due to the debug mode I setup, there actually is the RTC2 set with the EVENTS_COMPARE[0] triggered.
    I also halted the MCU in the normal reset conditions (without passing through DFU update) and as you can see the RTC2 is not even enabled in this case.
    On the other hand, halting the MCU after a DFU but before the issue you can see that the RTC is still enabled but there is no EVENT_COMPARE[0] generated
    Therefore my guess is:
    the DFU initialize the RTC2 to use timers during DFU, however after the RESET the RTC2 registers are not reset properly. On the other hand, with Hardware Reset the registers from RTC2 are cleared and therefore there is no event generated at the compare of the RTC2 counter.
    Since there is no handling of the RTC2 events, the MainApp doesn't handle the RTC event and therefore it keeps triggering without clearing the flag.
    Now, the question is:
    1) Why is the RTC2 not uninitialized by the bootloader before jumping to the app?
    2) How is it possible to reset "like" hardware reset after DFU?
    You can also read and print the register values with nrf_log/printk.
    After a DFU is completed, the device will do a system/hardware reset. When it boot up again, It will enter the bootloader, and determine if it should either enter DFU mode, or boot the app. Only when it enters DFU mode, RTC 2 started. If it's booting the app, the RTC2 is not started, and there is no reason to uninitialize it. Most likely you are somehow starting RTC2 in your app.
    Maybe you can print the RTC2 values early in your app main()
  • Most likely you are somehow starting RTC2 in your app.
    RTC2 is not initialized by the main app, since there is no RTC2 define enabled in the sdk_config.h, neither direct access to the registers. Indeed when the app is starting without DFU the RTC2 registers are all disabled, as shown here.
    Maybe the bootloader is doing some strange things once the app is starting just after the DFU, but I loaded the bootloader "as is" in the SDK and the issue is still there.
    The issue does not occur when J-link is connected in debug or logging with rtt-viewer, therefore it would be useless. Only approach I could find useful is halting the code with debugger and check the registers.
  • So, the issue is generated by the activation of DFU which leaves enabled the RTC2 with a compare event.
    Since the main app doesn't use the RTC2, these triggers continuously wake up the MCU because there is no clearing of the event.
    The workaround that seems to solve the issue is to uninit the RTC2 at startup in the main app.
    Why the RTC2 is active after a reset in the DFU remains a mistery up to now.
    Here is the code added just at the beginning of the main app "main()":
    // Function used to fix the anomalous power consumption once the device exits from DFU
    static void workaround_rtc2_after_dfu(void)
        // WORKAROUND TO DISABLE ANOMALOUS POWER CONSUMPTION, SHUT DOWN THE RTC2
        NRF_RTC2->INTENCLR = 0x000F0003;
        NRF_RTC2->EVTENCLR = 0x000F0003;
        NRF_RTC2->CC[0]    = 0;
        NRF_RTC2->CC[1]    = 0;
        NRF_RTC2->CC[2]    = 0;
        NRF_RTC2->CC[3]    = 0;
    int main ( void )
        uint16_t ret_code;
        // First of all call the workaround, this will solve the issue after OTA DFU
        workaround_rtc2_after_dfu();
        // .... Remaining code
