Why is MCUboot scratch algorithm disabled on Thingy:91?
The original firmware for Thingy:91 in version 2019-11-29_d3130d77 and earlier, included MCUboot configured to use the scratch partition for swapping the firmware images.
Since version 2020-04-29_bc7ade8b, the default MCUboot version no longer does this, instead using the generic "move" algorithm - even though a 120KiB scratch partition is still reserved in the static partition layout.
Is it by design, or is this a bug? When distributing e.g. open source projects intended to run on the Thingy:91, it creates a problem - the published application shouldn't require an external debug probe to work, and if FOTA functionality is desired, then one would need to make sure that the application doesn't fill up the entire partition, so that the "move" algorithm can work. And in either case, without modifying the partition layout (which I believe is discouraged for the Thingy), the 120 KiB of the flash memory just go to waste and are not used for either MCUboot, the app image, or storage space.
Of course I can build my own version of MCUboot that uses the scratch algorithm, but that won't be usable by people who don't have access to an external debug probe.
Is there something that I'm missing? Could you comment on this issue?
  • The move algorithm has less flash wear than the skratch algorithm.
    See https://www.youtube.com/watch?v=KFgK3TRDNR4
    Sigurd Hellesvik
  • OK then. I can't say that I'm particularly happy that the 120 KiB originally reserved for a scratch partition are now basically unusable without repartitioning the device, but if that's intentional, then I guess it is what it is.
    Just to confirm: commercially available Thingy:91 units are generally expected to be flashed with the latest firmware available at the time of manufacturing, is that right? So I cannot assume that MCUboot on any unit straight from the factory will use either the "move" or "scratch" algorithm?
    Generally, but there may be some lag here.
    Correct.
    I guess this is also a bonus when the partitioning is the same, as you can treat both the same.
    I understand that.
    If it is to some consolidation, you can use our nRF9160DK or nRF5340DK to program the Thingy91, which lets you repartition.
    Sigurd Hellesvik
