Modem does not connect after Modem delta upgrade
Hi, we used the modem_delta_update example as a reference in our firmware to be able to do modem delta FOTA upgrades from an S3 bucket. We are currently using NCS V2.2 The upgrading works very well, we use it to upgrade modem firmware V1.3.3 to V1.3.4. The problem is that on some units the modem stops connecting to the LTE network after the upgrade. The modem still responds correctly to AT commands, but no matter what I try, it does not want to connect to LTE. I manually programmed modem firmware V1.3.3 and V1.3.4 to see if this will fix the problem, but no luck. Are there any non-volatile settings in the modem that could have been lost?
Thank you for your help.
Hubert
  • Hi Hubert,
    hjetschko said:
    Can I mark this as the solution or do you think there is still something to be concerned about?
    If this fixes the issue on all your devices, then I thing we can say that this is the fix. The XFACTORYRESET might have removed some data that prevented the update to be fulfilled, but I don't know what.
    If you are happy, then let's call this a success. And if you do see any issues afterwards, please let us know.
    Øyvind
