Please consolidate nRF9160 documentation about CP-RAI and AS-RAI
Knowing, that the AS-RAI implementation is experimental, I would still prefer to have more documentation about the details.
I already asked for these details in an other issue (see Details of AS-RAI and CP-RAI fallback ) but for me there are still some gaps.
The above referred thread discussed, that requesting to use Rel. 14 AS-RAI, the modem falls back to Rel. 13 CP_RAI, if AS-RAI isn't supported by the network provider. So far, so good. The nasty point seems to be, that you can't use this fallback without knowing that, because the supported options seems to differ for AS-RAI and CP-RAI and a function to see, that the modem decided to fall back, is missing.
My results (the trace are provided in the referred thread):
With Rel. 14 AS-RAI only the SO_RAI_NO_DATA seems to work, with SO_RAI_ONE_RESP I had no success.
With requesting Rel. 14 AS-RAI, but fallback to Rel. 13 CP-RAI, SO_RAI_NO_DATA doesn't work, but SO_RAI_ONE_RESP is now working.
My questions:
1. Please document, which options are working in which mode (SO_RAI_NO_DATA, SO_RAI_LAST, SO_RAI_ONE_RESP combined with Rel. 14 AS-RAI, AS-RAI fallback to CP-RAI).
2. Is it possible the check, if the modem falls back to Rel. 13 CP-RAI? Especially, if the first question shows, that there are no common supported options, such a function helps to implement a working application.
Thanks in advance.
  • But to return error, if something doesn't work as expected, is for me a well API designed. And that fix should not be blocked by a single application.
    I agree, but socket API does not have that general quality and so such an approach would require wider API redesign.
    E.g. if you send UDP packet using socket API, you will not get an error in all cases, when the packet was not sent by the device.
    Overloading socket API by passing signalization regarding L2 Link Layer over L3 Network Layer API is not a good approach.
    Socket API insufficiency is also the reason, why you are asking for notifications about packets actually sent.
    But there is a catch, because there could be more than one UDP packet sent (on the way in modem), so you would need to identify to what exact packet is a notification about packets actually sent related.
    And there is not any packet id that could be used for that.
    I guess you request a different API.
    Yes, because there is a mix of layers in one API (socket API overloading).
    SO_RAI_* is Link layer related, SO_SILENCE_ALL is also not related to UDP or TCP either, etc.
    The current socket API is also the reason, why there is no reasonable way, how to provide the information required for bulk transfer timing implementation - power consumption optimized congestion control.
  • > I agree, but socket API does not have that general quality and so such an approach would require wider API redesign.
    Yes, it has some flaws. They are caused by a compromise not to block calls for an actual later outcome. But that seems to be more common. I'm not sure, if the modem's "nrf specific socket" API returns errors on poll, but on other implementations that works.
    The point with a "redesign" would be the timeline. I would guess, it will take that long, that for many it will never come ;-). And I still miss an alternative proposal.
    No, I don't ask. I tired to explain, why RRC idle will not help for your bulk transfer. But for now I don't plan to use a bulk-transfer over UDP. In other cases/systems, using "poll" with POLLOUT does the job, but I don't know, if that is implemented in the "nrf socket". Maybe, once in the future, I would try to switch NSTART-2 or 4 for a coap blockwise FOTA, but not for now and not with more pending messages as a small couple.
    So all in all:
    Without an alternative proposal I don't see, that a discussion about the weakness and flaws helps. At least in my awareness quite a lot are common to that and will benefit from the error codes more then they suffer from things, which are not working with that approach.
  • In other cases/systems, using "poll" with POLLOUT does the job
    In other systems (e.g. Linux) you get only info regarding socket buffer (SOCK_DGRAM in case of UDP) is ready for another send with poll/POLLOUT, but that is not info regarding datagram was actually sent.
    DGRAM socket API is not suitable for link layer control.
    It helps to make clear what are the flaws and what is missing. In other words, what should be handled by extended API.
    One option can be to add LTE link layer API (it could be made also with socket approach by adding special socket type aka LTE link layer or just add special LTE link layer API exposing all LTE under the hood details) and bring control, status info, events, data transport capabilities there.
    It would not break the current higher-level TCP/UDP API and it will bring lower link-level control to applications, that can implement energy-efficient data transport.
  • > in other systems (e.g. Linux) you get only info regarding socket buffer (SOCK_DGRAM in case of UDP) is ready for another send with poll/POLLOUT, but that is not info regarding datagram was actually sent.
    In my experience from other systems, that helps a lot for congestion control. It prevents the system from dropping messages internally. I don't know, if that is implemented by the modems socket implementation. Unfortunately, such stuff is missing in the documentation.
    My impression about such extensions and redesigns is more, that they don't happen. At least not without a huge commercial project requesting it. Therefore, as I wrote, I would be happy if it starts with reporting errors, even if that has also still some drawbacks.
    I guess, even a more complete documentation will take several weeks. And I don't see, that a redesign will happen this year. An error code may have a better chance.
  • In my experience from other systems, that helps a lot for congestion control. It prevents the system from dropping messages internally.
    Of course, but it does not address all states.
    Does queue based socket API layer have any insight into immediate link layer properties?
    It is not a good API pattern to intermix queue and immediate approach in one API.
