Can't send data to nrf Connect app o NRF52832
 I am trying to send two values to nrf Connect app through BLE  using NUS service.
The connection is working fine, device connects with the nrf Connect app but when I enable the notifications , There is no value being notify on the nrf Connect app
using nRF sdk 16.00, softdevice s132
void send_data_via_nus(float X, float Y, ble_nus_t nus_service)
uint8_t data[8];
memcpy(data, &X, sizeof(X));
memcpy(data + sizeof(X), &Y, sizeof(Y));
uint16_t length = sizeof(X) + sizeof(Y);
ret_code_t err_code;
err_code = ble_nus_data_send(&m_nus, data, &length, m_conn_handle);
if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
How I am handling the NUS service
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
/**@snippet [Handling the data received over BLE] */
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
The UART PART
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if (index >= m_ble_nus_max_data_len)
                if (index > 1)
                    do
                        err_code = ble_nus_data_send(&m_nus,data_array, &length, m_conn_handle);
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@snippet [Handling the data received over UART] */
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
#if defined (UART_PRESENT)
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
