Reading Thingy:53 sensor data
Hello everyone !
I am following the tutorial "Reading Thingy:53 sensor data using Bluetooth LE".
It doesn't matter if I don't do it myself or if I take the source program from github the project doesn't build.
I have the following error:
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.3.0\opt\bincmake.EXE' --build 'c:\Users\fduvi\Desktop\stage\Nordic_LTEthingy53_sensor_hub-masterthingy53_sensor_hub-master'
Can someone help me ?
Pierre
Here we can see the error with the source program
  • If i try on git bash it says "command not found"
  • If you open Toolchain Manager from within nRF Connect for desktop, then select the dropdown menu for your version of nRF Connect SDK, select the option for open command prompt and then run the command "west update". Does the same thing happen?
    Regards
    Runar
  • fduvi@MSI MINGW64 /c/ncs/v2.3.0
    $ west update
    === updating zephyr (zephyr):
    HEAD is now at fcaa60a99f [nrf fromtree] soc: nrf53: Warn if workaround for anomaly 160 cannot be applied
    === updating sdk-hostap (modules/lib/hostap):
    HEAD is now at 73de50a27 Fix hidden SSID association
    === updating mcuboot (bootloader/mcuboot):
    HEAD is now at 9c58609b [nrf fromlist] boot: zephyr: Clean up before chainloading by default
    === updating mbedtls (modules/crypto/mbedtls):
    HEAD is now at c2a205601 [nrf noup] Constant size for psa_core_key_attributes_t struct
    === updating nrfxlib (nrfxlib):
    HEAD is now at 6d0f5844 doc: update versions for 2.3.0 release
    === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
    HEAD is now at 150e7b43 [nrf fromtree] secure_fw: crypto: add -Wno-unused-const-variable
    === updating matter (modules/lib/matter):
    HEAD is now at bf8b787ae [nrf noup] Mapped the WiFi security type from Zephyr to Matter
    Synchronizing submodule url for 'third_party/nlio/repo'
    Synchronizing submodule url for 'third_party/nlassert/repo'
    Synchronizing submodule url for 'third_party/nlunit-test/repo'
    Synchronizing submodule url for 'third_party/pigweed/repo'
    === updating cjson (modules/lib/cjson):
    HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
    === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
    HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
    === updating cmock (test/cmock):
    HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
    Synchronizing submodule url for 'vendor/c_exception'
    Synchronizing submodule url for 'vendor/unity'
    === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
    HEAD is now at dbe84b9 Memfault Firmware SDK 0.37.2 (Build 1352)
    === updating cirrus (modules/hal/cirrus-logic):
    HEAD is now at 9f6b381 sdk-mcu-drivers: Added build system configs and generated files
    === updating openthread (modules/lib/openthread):
    HEAD is now at 2060039bb [csl] fix indirect retransmission of frame previously transmitted via CSL (#8770)
    === updating canopennode (modules/lib/canopennode):
    HEAD is now at 53d3415 Merge pull request #5 from teslabs/module-name
    === updating chre (modules/lib/chre):
    HEAD is now at fe0ab36e Merge pull request #6 from yperess/peress/downstream-fix
    === updating cmsis (modules/hal/cmsis):
    HEAD is now at 74981bf Update DSP library for additional platforms
    === updating edtt (tools/edtt):
    HEAD is now at 000fb87 initiator: Fix disconnect with other event at the same time
    === updating fatfs (modules/fs/fatfs):
    HEAD is now at 38f303a zephyr: Add ffconf.h override with ZEPHYR_CONFIG_OVERRIDE
    === updating hal_nordic (modules/hal/nordic):
    HEAD is now at fe0be3c drivers: nrf_802154: Update the IEEE 802.15.4 component
    === updating hal_st (modules/hal/st):
    HEAD is now at cccbc24 sensor: lsm6dso: Disable -Wmaybe-uninitialized for lsm6dso_mode_set
    === updating hal_wurthelektronik (modules/hal/wurthelektronik):
    HEAD is now at 24ca987 Initialized WE HAL module repository.
    === updating libmetal (modules/hal/libmetal):
    HEAD is now at efa2ace lib: update libmetal to SHA cd4fb67a4f50
    === updating liblc3 (modules/lib/liblc3):
    HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename
    === updating littlefs (modules/fs/littlefs):
    HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr
    === updating loramac-node (modules/lib/loramac-node):
    HEAD is now at ce57712f Don't memset the TXRX buffer when radio is set to receive mode (#1345)
    === updating lvgl (modules/lib/gui/lvgl):
    HEAD is now at 5ab83099 zephyr: add missing errno.h include
    === updating lz4 (modules/lib/lz4):
    HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
    === updating mipi-sys-t (modules/debug/mipi-sys-t):
    HEAD is now at 0d521d8 mipi_syst_api.c: Change MIPI_SYST_PCFG_PRINTF_ARGBUF_SIZE macro.
    === updating nanopb (modules/lib/nanopb):
    HEAD is now at dc4deed Merge pull request #1 from pdgendt/zephyr
    === updating net-tools (tools/net-tools):
    HEAD is now at e0828aa net-setup: Add instructions for NAT and routing
    === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
    HEAD is now at 65bc530 irq_ctrl: Add support for level interrupts
    === updating open-amp (modules/lib/open-amp):
    HEAD is now at aedcc26 lib: update open-amp lib to release v2022.10.0
    === updating picolibc (modules/lib/picolibc):
    HEAD is now at 04ada5951 Version 1.7.8
    === updating segger (modules/debug/segger):
    HEAD is now at d4e568a Resolve circular include dependencies
    === updating tinycbor (modules/lib/tinycbor):
    HEAD is now at 9e1f34b module: Deprecate TinyCBOR
    === updating tinycrypt (modules/crypto/tinycrypt):
    HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt
    === updating TraceRecorderSource (modules/debug/TraceRecorder):
    HEAD is now at d926075 Merge pull request #12 from nashif/topic/thread_name
    === updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
    HEAD is now at bcb53bc Merge pull request #4 from joerchan/tfm-library-mode-invalid-data-length-zephyr
    === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
    HEAD is now at f4fc244 Merge pull request #5 from Vge0rge/increase_crypto_timeout
    === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
    HEAD is now at e892019 Merge pull request #11 from rlubos/zephyr-integration
    === updating zcbor (modules/lib/zcbor):
    HEAD is now at 0556eda Update version from 0.5.99 to 0.6.0
    === updating zscilib (modules/lib/zscilib):
    HEAD is now at ca070dd Merge pull request #39 from microbuilder/fix_tests_cmake
    Now the "insert code" seems to work !!
    Here is what it prompts !
    I tried to build the project again but i have the same error..
  • Thanks.
    Have you tried a pristine build after the update?
    Also, can you find the file that is reported missing?
    Regards
    Runar
