severe library problems when trying to use standard code
I am very new to Bluetooth and nRF. However, as i am trying to learn and work on a prototype i can't even get the basic sample codes to run. One of two big problems I'm having is that I'm missing what seems to be all Zephyr/Bluetooth libraries. For example, I'm missing the following from trying to run the Bluetooth peripheral example.
#include <zephyr/sys/byteorder.h>
#include <zephyr/zephyr.h>
#include <zephyr/types.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/services/bas.h>
#include <zephyr/bluetooth/services/hrs.h>
every single one comes back with the error "cannot open source file"
My other problem is that even if I break it down to the point of basic c code allowing a button to turn on and off LED1 when i go to build it I get this error
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.2\opt\bin\cmake.EXE
along with whatever specific path file to my c file.
to be clear I followed the video tutorial exactly, I then installed cmake through there tutorial. It seems to me that in the installation video then i followed exactly (twice after a reinstall) these libraries came up fine but mine are immediately underline with red. and the cmake fatal error i cant find anything related to this from other forums.
Please help! and than you i have the boardnRF52840-DK
  • Hi Walker,
    Please do share the complete log as well.
    -Regards,
    Swathy
  • Building Heart_sensor
    west build --build-dir c:\NordicCoding\Heart_sensor\build c:\NordicCoding\Heart_sensor --pristine --board nrf52840dk_nrf52811 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DBOARD_ROOT:STRING="c:/NordicCoding/Heart_sensor"
    -- Application: C:/NordicCoding/Heart_sensor
    -- Found Python3: C:/ncs/toolchains/v2.1.2/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.1.2/zephyr/.cache
    -- Zephyr version: 3.1.99 (C:/ncs/v2.1.2/zephyr)
    -- Board: nrf52840dk_nrf52811
    -- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.2/opt/zephyr-sdk)
    -- Found dtc: C:/ncs/toolchains/v2.1.2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.2/opt/zephyr-sdk)
    -- Found BOARD.dts: C:/ncs/v2.1.2/zephyr/boards/arm/nrf52840dk_nrf52811/nrf52840dk_nrf52811.dts
    -- Generated zephyr.dts: C:/NordicCoding/Heart_sensor/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NordicCoding/Heart_sensor/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NordicCoding/Heart_sensor/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NordicCoding/Heart_sensor/build/zephyr/dts.cmake
    Parsing C:/ncs/v2.1.2/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.1.2/zephyr/boards/arm/nrf52840dk_nrf52811/nrf52840dk_nrf52811_defconfig'
    Merged configuration 'C:/NordicCoding/Heart_sensor/prj.conf'
    Merged configuration 'C:/NordicCoding/Heart_sensor/build/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/NordicCoding/Heart_sensor/build/zephyr/.config'
    Kconfig header saved to 'C:/NordicCoding/Heart_sensor/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 10.3.0
    -- The CXX compiler identification is GNU 10.3.0
    -- Found assembler: C:/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/NordicCoding/Heart_sensor/build
    [1/222] Generating include/generated/version.h
    -- Zephyr version: 3.1.99 (C:/ncs/v2.1.2/zephyr), build: v3.1.99-ncs1-1
    [2/222] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [3/222] Generating include/generated/driver-validation.h
    [4/222] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [5/222] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [6/222] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [7/222] Generating include/generated/offsets.h
    [8/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [9/222] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/modules/crypto/tinycrypt/lib/source/aes_encrypt.c.obj
    [10/222] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/modules/crypto/tinycrypt/lib/source/aes_decrypt.c.obj
    [11/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [12/222] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/modules/crypto/tinycrypt/lib/source/utils.c.obj
    [13/222] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj
    [14/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [15/222] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [16/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [17/222] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [18/222] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [19/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [20/222] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [21/222] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [22/222] Generating linker_zephyr_pre1.cmd
    [23/222] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [24/222] Generating linker_zephyr_pre0.cmd
    [25/222] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [26/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [27/222] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [28/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [29/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [30/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [31/222] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [32/222] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [33/222] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [34/222] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [35/222] Linking C static library zephyr\arch\common\libisr_tables.a
    [36/222] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [37/222] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [38/222] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [39/222] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [40/222] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [41/222] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [42/222] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [43/222] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [44/222] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [45/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [46/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [47/222] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [48/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [49/222] Linking C static library zephyr\arch\common\libarch__common.a
    [50/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [51/222] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [52/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [53/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [54/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [55/222] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [56/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [57/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [58/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [59/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [60/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [61/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [62/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [63/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [64/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [65/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [66/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [67/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [68/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [69/222] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [70/222] Linking C static library zephyr\lib\posix\liblib__posix.a
    [71/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [72/222] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [73/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [74/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [75/222] Building C object CMakeFiles/app.dir/src/main.c.obj
    [76/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [77/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [78/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [79/222] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
    [80/222] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [81/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [82/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [83/222] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [84/222] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [85/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [86/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [87/222] Linking C static library app\libapp.a
    [88/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [89/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [90/222] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
    [91/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [92/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [93/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [94/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [95/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [96/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [97/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [98/222] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [99/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [100/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [101/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [102/222] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [103/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [104/222] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [105/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [106/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [107/222] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [108/222] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [109/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [110/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/services/hrs.c.obj
    [111/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [112/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [113/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [114/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/services/bas.c.obj
    [115/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
    [116/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [117/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [118/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/services/dis.c.obj
    [119/222] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [120/222] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
    [121/222] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_backend_uart.c.obj
    [122/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
    [123/222] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
    [124/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/long_wq.c.obj
    [125/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
    [126/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
    [127/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [128/222] Linking C static library zephyr\libzephyr.a
    [129/222] Linking C static library zephyr\subsys\bluetooth\common\libsubsys__bluetooth__common.a
    [130/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
    [131/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/ecc.c.obj
    [132/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
    [133/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
    [134/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
    [135/222] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [136/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/keys.c.obj
    [137/222] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_xoshiro128.c.obj
    [138/222] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [139/222] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [140/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
    [141/222] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [142/222] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [143/222] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [144/222] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [145/222] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [146/222] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [147/222] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_bt_hci.c.obj
    [148/222] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [149/222] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [150/222] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [151/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
    [152/222] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [153/222] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [154/222] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [155/222] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [156/222] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [157/222] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [158/222] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [159/222] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [160/222] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [161/222] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [162/222] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
    [163/222] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [164/222] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/ecdh.c.obj
    [165/222] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [166/222] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
    [167/222] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [168/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
    [169/222] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [170/222] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [171/222] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [172/222] Building C object modules/nrf/drivers/mpsl/temp_nrf5/CMakeFiles/..__nrf__drivers__mpsl__temp_nrf5.dir/temp_nrf5_mpsl.c.obj
    [173/222] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [174/222] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/mdk/system_nrf52811.c.obj
    [175/222] Linking C static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
    [176/222] Linking C static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
    [177/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [178/222] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [179/222] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [180/222] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp.c.obj
    [181/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [182/222] Linking C static library modules\nrf\drivers\mpsl\temp_nrf5\lib..__nrf__drivers__mpsl__temp_nrf5.a
    [183/222] Linking C static library modules\nrf\subsys\bluetooth\controller\lib..__nrf__subsys__bluetooth__controller.a
    [184/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [185/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [186/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [187/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [188/222] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [189/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [190/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [191/222] Linking C static library zephyr\subsys\bluetooth\host\libsubsys__bluetooth__host.a
    [192/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [193/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [194/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [195/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [196/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [197/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [198/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [199/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [200/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [201/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [202/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [203/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [204/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [205/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [206/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [207/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [208/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [209/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [210/222] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [211/222] Linking C static library zephyr\kernel\libkernel.a
    [212/222] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\v2.1.2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/NordicCoding/Heart_sensor/build/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/random/libsubsys__random.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/nrf/drivers/mpsl/temp_nrf5/lib..__nrf__drivers__mpsl__temp_nrf5.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v7e-m/nofp" -LC:/NordicCoding/Heart_sensor/build/zephyr -lgcc zephyr/arch/common/libisr_tables.a C:/ncs/v2.1.2/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.12.a -no-pie -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn C:/ncs/v2.1.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a C:/ncs/v2.1.2/nrfxlib/softdevice_controller/lib/cortex-m4/soft-float/libsoftdevice_controller_peripheral.a && cmd.exe /C "cd /D C:\NordicCoding\Heart_sensor\build\zephyr && C:\ncs\toolchains\v2.1.2\opt\bin\cmake.exe -E echo ""
    c:/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `noinit' will not fit in region `SRAM'
    c:/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `SRAM' overflowed by 3644 bytes
    collect2.exe: error: ld returned 1 exit status
    FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.2\opt\bin\cmake.EXE' --build 'c:\NordicCoding\Heart_sensor\build'
    * The terminal process terminated with exit code: 1.
    * Terminal will be reused by tasks, press any key to close it.
