Baudrate serial with Dongle BLE nrf52840
I use a dongle BLE nrf52840 with a software Bluetooth shell from NCS 2.0.
I use this dongle with this sample as a central device, i connect it to peripheral and receive 6 notifications at 10Hz and one more at 50Hz.
I use a socket to be connected to my dongle BLE with my PC.
To be able to save all my data i used to play with the serial baudrate.
1 ) Is it ok to configure baudrate with Uart_line_ctrl_set ?
2) Is it possible to configure Buadrate to 1M or even more (4M) for transmission ?
If it's possible, how to configure it ?
If it's not , is there another way to have all my datas ?
Pierre-Yves
  • Are you pointing zephyr,console and zephyr,shell to uart0 or cdc_acm_uart0? => Yes
    Which one is it? "uart0" or "cdc_acm_uart0"?
    Can you please share your build-folder/zephyr/zephyr.dts file?
    Piwy said:
    as i say before i have many data that i receive with notification on my shell interface, but when i want to retrieve all the datas, i loss some of them, is it possible to increase the speed  of transmission, diplay ?
    Maybe i don't explain verywell i'm sorry, told me if it's not clear
    Could you share an example of a working scenario and a non-working scenario?
    Håkon
  • To have the same confifuration as me you can take the bluettooth shell sample with the dongle BLE nrf52840 dts, i use the exactly same configuration.
      Using Bluetooth Shell
    With the sample you can scan device and connect to it as a central device in BLE. When youa re conencted you can discover services and subscribe to one caracteristic. I modify the sample to be able to subscribe to more notification. I subsribe to curstome services witch send accelerometer data, pressure...ect. these data are send at 10HZ for 6 of them and one is send at 50Hz.
    i try to receive all theses data. When i receive a data i print it with printf or with printk. But the speed of print is more lent than the n umber of data that i receive. I tried to increase the speed of uart0 to be able to print more data but i loss many data, is it possible to print more faster the data that i receive ?
    If i receive less data i succed to print them all (it's the working scenario) but i need to print more data.
    Is it more clear ?
    Pierre-Yves
    As the zephyr/tests/bluetooth/shell sample can be configured in many ways, can you please answer these questions so that I'm able to fully understand how you've setup the sample?
    Håkon
    Thanks you for your reply.
    Here is my zephyr.dts file
    7268.zephyr.dts
    Pierre-Yves
