psa_generate_key failed! with Error: -134
Hi nordic team,
I am working on an application which uses crypto cell feature, wifi capability of nrf7002DK, mbedTLS etc. I proceeded my development after individually verifying each features on nrf7002dk (crypto cell, wifi, mbedTLS etc).
My current problem is that, psa_generate_key() failed to generate key and returns error code of -134. This is happening only if I integrate my complete application(crypto cell, wifi, mbedtls etc). If I run crypto cell specific changes alone it works and if I run  along with wifi + mbedTLS changes it fails. I am not sure what causes this problem.
Just sharing my prj.conf below.
With below configuration crypto cell feature for private key generation is working as expected.
#   Application project specific configuration
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
# Target memory specific options
CONFIG_HW_UNIQUE_KEY=y
CONFIG_HW_UNIQUE_KEY_RANDOM=y
CONFIG_PM_SINGLE_IMAGE=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_RESET_ON_FATAL_ERROR=y
CONFIG_REBOOT=y
CONFIG_NRF_SECURITY=y
CONFIG_FPU=y
CONFIG_FP_HARDABI=y
CONFIG_KERNEL_MEM_POOL=y
# System settings
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_NANO=n
# Enable nordic security backend and PSA APIs
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_TRUSTED_EXECUTION_SECURE=y
CONFIG_BUILD_WITH_TFM=n
# For hardware crypto accelerator
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
# Memories
CONFIG_MAIN_STACK_SIZE=16384
# Below section is the primary contributor to SRAM and is currently
# tuned for performance, but this will be revisited in the future.
CONFIG_HEAP_MEM_POOL_SIZE=153600
CONFIG_MBEDTLS_HEAP_SIZE=120000
# Enable logging using RTT and UART
CONFIG_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BUFFER_SIZE=15360
# General
CONFIG_POSIX_CLOCK=y
CONFIG_POSIX_MAX_FDS=8
CONFIG_HW_STACK_PROTECTION=y
CONFIG_HW_ID_LIBRARY_SOURCE_NET_MAC=y
CONFIG_DK_LIBRARY=y
CONFIG_PM=y
# Kernel options
CONFIG_ENTROPY_GENERATOR=y
# Memory support
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
But when I add below configuration for enabling wifi & network, spa_generate_key fails with -134.
# WiFi driver
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
# WPA supplicant
CONFIG_WPA_SUPP=y
# NET sockets
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_POLL_MAX=8
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_IPV4=y
CONFIG_NET_TCP=y
CONFIG_NET_SOCKETS_OFFLOAD=n
CONFIG_NET_NATIVE=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_CONTEXT_SNDTIMEO=y
CONFIG_NET_TCP_ISN_RFC6528=y
CONFIG_NET_MGMT_EVENT_INFO=y
CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
CONFIG_NET_MAX_CONTEXTS=5
CONFIG_NET_CONTEXT_SYNC_RECV=y
# Network address config
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_CONFIG_NEED_IPV4=y
CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.99"
CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
# Server IPV4/IPV6 address config
#Mainnet.Incubed
CONFIG_NET_CONFIG_PEER_IPV4_ADDR="167.86.94.248"
Can some one please tell me what should be the problem with key_generation and wifi network configuration.
Thanks
Vipin Das
