USB UART output buffer remains full after serial disconnect
Windows 11, NCS v2.3.0, VSCode
Hi, I am using the uart_poll_out API for communicating via USB serial.
For each character I want to output, I do this:
uint32_t dtr;
uart_line_ctrl_get(DEV_UART_USB, UART_LINE_CTRL_DTR, &dtr);
if (dtr)
    uart_poll_out(DEV_UART_USB, c);
The other side of the serial connection can disconnect at any time.
I don't want my code to hang trying to write, that's why I checked the DTS beforehand, and basically throw away any data that won't get sent immediately.
The problem I have is:
- I am writing continuously
- The other side disconnects
- I attempt to detect that, and do, eventually, but not before the uart_poll_out puts a few characters into what I assume is an output buffer which fills up a short time later
Then, when the other side re-connects, the bytes that are sitting in the output buffer get sent.  This corrupts the datastream to the receiver as those bytes were for a different connection.
Is there a way to deal with this?
I would basically like to detect that I can't send data, and clear any existing output buffer at that time.
Or any other way to deal with this situation?
I'm not a serial expert and I only had the line_ctrl code because I saw it in an example.  Please let me know.
Thanks.
  • I don't think I can do that, at least not in a practical sense.  The nordic library is layered under many layers of abstraction (zephyr and my own) that you will find difficult to navigate.  What do you think?
    Can we start with some thinking about what in principle is the issue here?  How well do you understand the interplay between the systems described in the problem statement?  What in principle can cause that error, and how does that relate to using the APIs as I have explained?
    Thanks.
  • It would be good to get at least something to go on, but typically you need to clear the buffers somehow, for instance maybe you can call ring_buf_init() again to get clear them, similar for any other buffers you may have.
    Kenneth
    Ok here is the .cpp file where all the UART activity happens.  There's a lot going on there.
    Ultimately though, UartInit is called, and all it does is register an interrupt handler function for RX.
    The interrupt handler function loads that data into a queue.
    A thread consumes from that queue and uart_poll_out the data.
    Everything else is scaffolding.
    0804.UART.cpp
    I don't know which ring buffer you're talking about.  Is there an outbound ring buffer the UART uses which receives bytes from uart_poll_out?  My code never does anything with a ring buffer, no idea if any uart-related libs do.
    Please have a look at the code and please give some specific suggestions about next steps.
    Thanks.
    Doug
    I can't see that you are actually checking the dtr line before each uart_poll_out(), so a start would be to at least check dtr register before each call to uart_poll_out(). I can see that the cdc_acm_driver_api also have an irq_tx_ready() api, not sure if you have access to this api, but if you do it make sense to check this api before trying to call uart_poll_out(). Maybe you have access to uart_tx_abort(), so that is something you can try when you get a USB disconnected event.
    Kenneth
    What is this code doing if not testing the dtr?  Again, I'm not an expert at this, but this code seems to be working, because it notices the difference between a connected USB serial connection and not one.
    static void ThreadFnUARTUSBOutput()
        bool skippedLast = false;
        while (true)
            char c;
            if (UART_USB_OUTPUT_PIPE.Get(c, K_FOREVER))
                // consume the bytes, but only attempt to output if USB serial connected
                uint32_t dtr;
                if (dtr)
                    // sad kludge to protect against:
                    // - sending a stream of data to an endpoint which disconnects midway through
                    // - unknowingly queuing a few additional bytes in the USB output buffer
                    // - those bytes lingering and later getting sent on a new connection, corrupting the stream
                    // this approach hopes:
                    // - the other side is line-oriented and simply discards the malformed message
                    // - too few bytes get in the buffer to form a complete message
                    if (skippedLast)
                        for (int i = 0; i < 6; ++i)
                            uart_poll_out(DEV_UART_USB, '\n');
                    skippedLast = true;
     irq_tx_ready() api
    I'm using the polling API.  I don't want to use the IRQ-driven API.
    Would uart_tx_abort() fix the problem?
    Is the problem description clear enough?
    I am saying I believe several bytes get loaded into some area in memory before I am notified of disconnect (usb callback) and also during that time I am still getting the dtr (probably because the bytes are in ram to be sent out later but aren't blocking yet.
    I asked this question before but didn't get a reply.  Can you answer?
    I want to know if you do understand the problem, and are saying that uart_tx_abort will clear the outbound buffer of unsent bytes.  Have you tested this?
    Thanks.
    Doug
