NRF Connect Programmer v3.0.8 for nrf5340 DK not working on Linux
I have updated to the latest nRF Connect for Desktop 4.0.1 on Linux Mint 20.1 (64 bit x86) with Programmer version 3.0.8 and my nRF5340 Dk as well as my nRF5340 Audio Dk boards fail to recover when the "Erase all" button is pressed. Both cores remain as "Device is protected" after pressing that button. This only happens on Linux and not Windows 10. I can confirm that this happens on two completely separate Linux machines too. I had a working version of nRF Connect on another Linux machine but it stopped working when I updated to the latest version so it is definitely a software issue. Unfortunately I cannot figure out how to "downgrade" the programmer app.
Is there a way to run a specific version of the Programmer app? It seems to always use the latest version regardless of the nRF Connect version being used. It's hard to tell when it even installs it to.
I have attached verbose working (Windows) and non-working (Linux) logs of the process. I also sometimes get the following error log message on Linux:
16:16:21.357	Loading readback protection status for Network core
16:16:22.072	Failed to load readback protection status: async task failure for id: 1682435781358816 msg: [jlink] JLINKARM_DLL_TIME_OUT_ERROR (Origin: "Error when running operation: protection-get")
16:16:22.154	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
I installed the same version of the Jlink driver (version 682c) that was known to work on the Linux version but this had no effect so I reverted back to version 780c.
What is the relationship between the Programmer app and the nrf command line tools? Will I have more luck downgrading command line tools until I get a working version by trial and error? I have found that nrfjprog just says it's done the right thing even when it hasn't.
Here are all the versions of what I am running:
Using nrf-device-lib-js version: 0.6.5
Using nrf-device-lib version: 0.14.7
Using nrfjprog DLL version: 10.19.1
Using JLink version: JLink_V7.80c
Linux log (not working)
14:54:04.945	Using nrf-device-lib-js version: 0.6.5
14:54:04.945	Using nrf-device-lib version: 0.14.7
14:54:04.945	Using nrfjprog DLL version: 10.19.1
14:54:04.945	Using JLink version: JLink_V7.80c
14:54:06.097	Getting serialport options from persistent store 001050008612.pc-nrfconnect-programmer
14:54:11.864	Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
14:54:11.865	JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Dec 3 2021 15:46:49
14:54:11.865	Device family NRF53_FAMILY
14:54:11.865	Device version NRF5340_xxAA_ENGD
14:54:11.865	Board version PCA10095
14:54:11.865	Loading readback protection status for Application core
14:54:11.865	Loading readback protection status for Network core
14:54:11.881	[nrfdl][info](14:54:11.865) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:13.451	[nrfdl][info](14:54:12.654) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:13.451	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:54:13.451	[nrfdl][info](14:54:12.655) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:13.474	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:54:13.474	[nrfdl][info](14:54:12.746) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:13.474	[nrfdl][info](14:54:12.747) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:13.491	[nrfdl][info](14:54:13.443) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:13.543	Parse memory regions for Application core
14:54:13.543	Parse memory regions for Network core
14:54:13.544	Update files regions according to Application core
14:54:13.544	Parse memory regions for file
14:54:13.544	Update files regions according to Network core
14:54:13.547	Device is loaded and ready for further operation
14:54:13.547	[nrfdl][info](14:54:13.539) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:15.742	Recovering NRFDL_DEVICE_CORE_APPLICATION core
14:54:15.751	[nrfdl][info](14:54:15.743) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:17.816	Recovering NRFDL_DEVICE_CORE_APPLICATION core completed
14:54:17.817	Recovering NRFDL_DEVICE_CORE_NETWORK core
14:54:17.817	[nrfdl][info](14:54:17.815) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:17.818	[nrfdl][info](14:54:17.818) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:19.801	[nrfdl][warning](14:54:19.796) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:54:19.813	[nrfdl][warning](14:54:19.808) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:54:19.821	[nrfdl][warning](14:54:19.811) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:54:19.825	[nrfdl][warning](14:54:19.814) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:54:19.829	[nrfdl][warning](14:54:19.817) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4101 is not present.
14:54:19.839	[nrfdl][warning](14:54:19.829) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.841	[nrfdl][warning](14:54:19.839) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.844	[nrfdl][warning](14:54:19.840) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.846	[nrfdl][warning](14:54:19.841) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.847	[nrfdl][warning](14:54:19.842) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.849	[nrfdl][warning](14:54:19.843) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.850	[nrfdl][warning](14:54:19.843) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.855	[nrfdl][warning](14:54:19.853) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.856	[nrfdl][warning](14:54:19.854) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.875	[nrfdl][warning](14:54:19.874) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.886	[nrfdl][warning](14:54:19.884) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:54:19.942	Recovering NRFDL_DEVICE_CORE_NETWORK core completed
14:54:19.952	Device recovery completed
14:54:19.957	Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
14:54:19.958	JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Dec 3 2021 15:46:49
14:54:19.958	Device family NRF53_FAMILY
14:54:19.958	Device version NRF5340_xxAA_ENGD
14:54:19.958	Board version PCA10095
14:54:19.958	Loading readback protection status for Application core
14:54:19.958	Loading readback protection status for Network core
14:54:19.959	[nrfdl][info](14:54:19.941) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:19.964	[nrfdl][info](14:54:19.959) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:19.965	[nrfdl][info](14:54:19.959) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:20.950	[nrfdl][info](14:54:20.809) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:20.950	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:54:20.950	[nrfdl][info](14:54:20.810) Loaded plugin /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:54:20.955	Readback protection status: NRFDL_PROTECTION_STATUS_ALL
14:54:20.955	[nrfdl][info](14:54:20.891) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
14:54:21.684	Parse memory regions for Application core
14:54:21.684	Parse memory regions for Network core
14:54:21.687	Update files regions according to Application core
14:54:21.687	Parse memory regions for file
14:54:21.687	Update files regions according to Network core
14:54:21.695	Device is loaded and ready for further operation
14:54:21.695	[nrfdl][info](14:54:21.676) close plugin dll at path: /tmp/.mount_nrfconqOeoqj/resources/app.asar.unpacked/node_modules/@nordicsemiconductor/nrf-device-lib-js/Release/00-nrfdl-jlink-plugin.nrfdl
Windows log (working):
14:48:37.369	Using nrf-device-lib-js version: 0.6.5
14:48:37.369	Using nrf-device-lib version: 0.14.7
14:48:37.369	Using nrfjprog DLL version: 10.19.1
14:48:37.369	Using JLink version: JLink_V7.80c
14:48:37.830	[nrfdl][info](14:48:37.831) plugin added new device: 10 sn:
14:48:37.832	Getting serialport options from persistent store 001050008612.pc-nrfconnect-programmer
14:48:37.833	Getting serialport options from persistent store .pc-nrfconnect-programmer
14:48:42.028	Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
14:48:42.028	JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Dec 3 2021 15:46:49
14:48:42.028	Device family NRF53_FAMILY
14:48:42.028	Device version NRF5340_xxAA_ENGD
14:48:42.028	Board version PCA10095
14:48:42.028	Loading readback protection status for Application core
14:48:42.028	Loading readback protection status for Network core
14:48:42.038	[nrfdl][info](14:48:42.029) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:43.173	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:48:43.173	[nrfdl][info](14:48:42.562) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:43.173	[nrfdl][info](14:48:42.563) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:43.188	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:48:43.188	[nrfdl][info](14:48:42.825) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:43.188	[nrfdl][info](14:48:42.825) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:43.203	[nrfdl][info](14:48:43.150) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:43.326	Parse memory regions for Application core
14:48:43.326	Parse memory regions for Network core
14:48:43.327	Update files regions according to Application core
14:48:43.327	Parse memory regions for file
14:48:43.327	Update files regions according to Network core
14:48:43.337	Device is loaded and ready for further operation
14:48:43.337	[nrfdl][info](14:48:43.323) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:48.819	Recovering NRFDL_DEVICE_CORE_APPLICATION core
14:48:48.824	[nrfdl][info](14:48:48.820) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:50.613	Recovering NRFDL_DEVICE_CORE_APPLICATION core completed
14:48:50.613	Recovering NRFDL_DEVICE_CORE_NETWORK core
14:48:50.613	[nrfdl][info](14:48:50.613) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:50.613	[nrfdl][info](14:48:50.614) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:52.267	[nrfdl][warning](14:48:52.264) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:48:52.272	[nrfdl][warning](14:48:52.265) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:48:52.275	[nrfdl][warning](14:48:52.265) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:48:52.279	[nrfdl][warning](14:48:52.266) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4225 is not present.
14:48:52.283	[nrfdl][warning](14:48:52.280) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4101 is not present.
14:48:52.300	[nrfdl][warning](14:48:52.296) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.312	[nrfdl][warning](14:48:52.311) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.313	[nrfdl][warning](14:48:52.311) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.315	[nrfdl][warning](14:48:52.312) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.327	[nrfdl][warning](14:48:52.327) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.329	[nrfdl][warning](14:48:52.327) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.331	[nrfdl][warning](14:48:52.327) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.343	[nrfdl][warning](14:48:52.343) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.346	[nrfdl][warning](14:48:52.343) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.377	[nrfdl][warning](14:48:52.375) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.381	[nrfdl][warning](14:48:52.376) [jlink] [NRFJPROG][nRF53][] SPU peripheral slave with apb index 4224 is not present.
14:48:52.551	[nrfdl][info](14:48:52.551) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:52.551	Recovering NRFDL_DEVICE_CORE_NETWORK core completed
14:48:52.555	Device recovery completed
14:48:52.559	Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
14:48:52.559	JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Dec 3 2021 15:46:49
14:48:52.559	Device family NRF53_FAMILY
14:48:52.560	Device version NRF5340_xxAA_ENGD
14:48:52.560	Board version PCA10095
14:48:52.560	Loading readback protection status for Application core
14:48:52.560	Loading readback protection status for Network core
14:48:52.564	[nrfdl][info](14:48:52.561) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:54.035	[nrfdl][info](14:48:53.203) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:54.035	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:48:54.035	[nrfdl][info](14:48:53.204) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:54.039	[nrfdl][info](14:48:53.349) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:54.039	Readback protection status: NRFDL_PROTECTION_STATUS_NONE
14:48:54.039	[nrfdl][info](14:48:53.351) Loaded plugin C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
14:48:54.094	[nrfdl][info](14:48:53.992) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:54.229	[nrfdl][info](14:48:54.229) close plugin dll at path: C:\Users\david\AppData\Local\Programs\nrfconnect\resources\app.asar.unpacked\node_modules\@nordicsemiconductor\nrf-device-lib-js\Release\00-nrfdl-jlink-plugin.nrfdl
14:48:54.235	Parse memory regions for Application core
14:48:54.235	Parse memory regions for Network core
14:48:54.237	Update files regions according to Application core
14:48:54.237	Parse memory regions for file
14:48:54.237	Update files regions according to Network core
14:48:54.244	Device is loaded and ready for further operation
Please save me from having to use Windows.
David
  • Thank you, the CTRL-AP chapter linked above was very insightful. Much appreciated.
  • After testing a while with my nRF5340-DK and the nRF Connect Programmer, my feeling is, the DK is bricked, because the target nRF5340 is "bricked". The Programmer tries to check, if it recognizes a valid Nordic device via JLink. If I switch the DK off and connect a nordic device to the external debug output of the nRF5340-DK, the nRF Connect Programmer detects both.
    My conclusion: the onboard nRF5340 is somehow in a state, where Jlink can't read the device info.
    I tried to understand the other comments, but I miss the sequence to unclock the nRF5340.
    What I tried:
    > nrfjprog -v
    nrfjprog version: 10.15.1 external
    JLinkARM.dll version: 7.80c
    > nrfjprog -e --log
    ERROR: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    > nrfjprog --recover --log
    Edit:
    Oh, what a mess! What a ridiculous waste of time!
    It depends on using a debug header (TC2030-CTX). With that, the DK switches to the external debug interface and if on start no nordic device is connected to that external debug interface, the nRF5340-DK is refused by the programmer.
    The nRF9160-DK doesn't show that effect. That works with and without that debug header.
