Using NRF24L01+ with pure assembler programing
Dear people
I have connected NRF24!01+ with PIC16F1826 for use as PRX and have also another similar for PRX
For an initial test I tryed to trasmit a closed / open switch state to a LED and as ussually hapens it does not work
Also I have a Tx packets each 200ms with one Data byte incremented in each Tx
I get SPI write an read ok but at PRX have not getting any received packet
There is the same program for PTX an PRX with  #define    PRX  o rnot at compiling so most of defined values are the same
What I get reading with SPI : in PRX , Reg 0x17 FIFO_STATUS  bit4 TX_EMPTY:
 is 1 before loading data
0 after loading payload   (4 bytes)
1 after CE goes H
At PRX side  not IRQ arises , not changes in Reg 07 bit RX_DR
I only use assembler programming and I didn´t found in the web any complete and working assembler example.
--> I am asking please the simplest example with a detailed list of commands to send for configuring and useing TPX
and PRX, similar at Appendix B, pag 77 in NRF24L01+ data sheet.
*** But please include the waiting delays and other instructions that may be  needed ***
For some address, default values may be used in a first test ? ( only 1 Pipe )
Is it posible not  using CRC ?
I need to have something working before going to a complete use of full NRF24L01+ capabilities
Finally I will insert well tested software in bigger assembler programs
I like to  replace a RS485 conexion with this RF link
I will1452.Control_NRF.rar send the assembler that I am testing if somebody like to see it, but RF part is not working
Waiting some help, Best Regards, Osvaldo Hojvat
  • Hi Osvaldo
    Approximately how often do you expect an order to come in from each PTX?
    I think the best approach is the one you detail in 1). Send a small ping packet from the PTX first, so that the PRX can prepare the ACK payload. Then you send a second packet from the PTX some milliseconds later to pick up the ACK payload.
    Like you say it is much easier to achieve low average current on the PTX side, since each transmit only takes some hundreds of microseconds.
    In order to also achieve low average current on the PRX side you need to keep the PTX's and PRX closely synchronized in time, so that the PRX knows when the PTX's will transmit and can enable the receiver just before the PTX starts the transmission.
    o.hojvat said:
    Please answer if there are posible interference for 2  PTX trasmiting at the same time but diferent frequency.
    If one signal is much stronger than the other it can still cause interference despite being on another channel, but if the distance between the 2 PTX's and the PRX is comparable it shouldn't be an issue.
    As an example if the PTX on the wrong channel is laying next to the PRX, and the PTX on the right channel is far away, then you might get interference from the one on the wrong channel.
    Best regards
    Torbjørn
  • Hi
    I made public the ticket - there are not private information here.
    ----------------------------- Data rate ----------------------
    From one handheld they may be two orders sent in 1 second, by example playing a short horn sound,
    or turning ON / OFF some ligth for a controled locomotive
    At maximun 5 Data in one second while modifying speed control position. But the most important is the last value, when the control stop moving.
    I will prefer the 3) procedure because it is more clear for me, and it will have no interference or colitions problems.
    It is a good idea your suggestion of sincronizing  RF activationat PRX  when it is expected a packet.
    It is rather easy to do for only 6 devices.   Probabely total 100 ms for the 6 PRX , so this will be the maximum delay to trasmit an handheld order.
    I case of no receiving the packet at the expected time, PRX can extend the RF ON time.  I will be not very often
    ---  I guess in each transmition, the PTX will change the tx adress (PIPE 0 ?) and also it will place the same address for PIPE 0 rx.
    --- It may be used PIPE 0 in all 6 PRX ?
    --- Perhaps it may be better to use a diferent PIPE for each PRX.
    Please comment about this matters.
    Anyway I must work (1 to 2 month) with TX / RX devices complete hardware and programms and some other problems may arises.
    Thank you very much for your help.    Now I can use the RF link with my own assembler.
    Best Regards
    Osvaldo
  • Hi Osvaldo
    If each device only sends a couple of packets every second then the chance of collision should be very small. Sending one packet at 1M PHY takes at most ~320us when sending 32 bytes, even less if you send shorter packets. Sending 10 of these packets pr second means you only spend ~0.3% of the available RF time, and even if some other PTX is also transmitting it is very unlikely to send at the same time.
    Once in a rare while it will collide, but then you can use the retransmission mechanism with different ARD to ensure that they will retransmit the packets at different times.
    So that would be my recommendation, but obviously you are free to choose which option you prefer.
    The PTX doesn't change the address. You need to ensure that both the TX address and the RX PIPE0 address is configured to the same value, otherwise the PTX will not be able to receive the ACK.
    Yes, you can use whatever pipe you want on the PRX side. The critical point is that you configure the addresses differently for all PRX's, so you don't get two or more receivers responding to the same packet.
    It is up to you. Either you configure the same address set in all PRX's, but enable different pipes in each of them (use pipe 0-5 for PRX 0-5), or you just use pipe 0 for all of them but make sure to configure unique pipe 0 addresses for each PRX.
    The pipe system is optimized for the use case where you have 6 PTX's and 1 PRX, and is not as streamlined when you have multiple PRX's and one PTX. It still works, but in this mode you will need to configure the TX and pipe 0 address on the PTX every time you want to switch to another PRX, you can't just tell the PTX to transmit to a different pipe (more modern Nordic devices like the nRF52 series have removed this limitation).
    Best regards
    Torbjørn
  • Hi
    I will keep all  yours comments. Thank you
    By the moment  I am working on the complete system programms and it may arises reasons to prefer the use of one of the methods
    Best Regards
  • Hi
    I guess that the usual star of 1 PRX and 6 PTX can be synconized as following:
    At PRX,  the procesor  has a counter from 0 to 5 to 0 ...  , repeating permanently with fixed 10ms (by expamle)  in each step
    PRX will  upload actualized value in ack payload
    Each PTX has asigned a pipe number 0 to 5 and has a similar counter 0 tofive
    At power-on  each PTX (with some diferent delay or at any moment) , may send a short packet and with the ack payload information can adjust his counter to sincronize it wuh the PRX
    Fore more precision  a precounter for the 10ms time  can by used in all devices, andthis value upload also with the 0 to 5 information.
    --- After a initial test packet ,  each PTX will tx only when PRX expect this pipe will do it.
    PRX can pre-load the regarding information for each pipe
    Any collision is avoided
    ------------------------ another aproach ------------
    I guess If there will be only 3 pipes in use ,  each of the 3 available W_ACK_PAYLOAD can store the needed information and only the regarding one will be send with the ack
    I fully working in other matter , but my mind not
    Best Regrds, Osvaldo
