zephyr/zephyr_pre0.elf section `noinit' will not fit in region `RAM' in sr_coex sample on nRF7002-DK
I'm trying sample Wi-Fi: Bluetooth LE coexistence — nRF Connect SDK 2.3.99 documentation (nordicsemi.com) and hitting this error about 'noinit' will not fit in region 'RAM'.
Here's a little more and I'll paste the full output further down;
cmake -E echo
/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `noinit' will not fit in region `RAM'
/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `RAM' overflowed by 11548 bytes
collect2: error: ld returned 1 exit status
I'm on nRF Connect SDK 2.3.0.  My board shows in VSCode as NRF5340_xxAA_ENGD
Sticker on the board has PCA10143
0.7.2
2022.52
Full build output (I copied the sample into nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/ since I had been building projects there already).
The only change I made to that same was in prj.conf is below.  But I just took that back out and still get to the same error about RAM.
* Executing task: nRF Connect: Build [clean]: sr_coex/build (active)
Building sr_coex
/bin/sh -c west build -t clean --build-dir /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build
-- west build: running target clean
[1/2] Cleaning additional files...
[2/2] Cleaning all built files...
Cleaning... 653 files.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Generate config nrf7002dk_nrf5340_cpuapp for /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex
Building sr_coex
/bin/sh -c west build --build-dir /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex --pristine --board nrf7002dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/peripheral_hr_coded" -DDTC_OVERLAY_FILE="/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/dts.overlay"
-- Application: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex
-- Found Python3: /opt/nordic/ncs/toolchains/v2.3.0/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
-- Cache files will be written to: /Users/leedrengenberg/Library/Caches/zephyr
-- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.3.0/zephyr)
-- Board: nrf7002dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.15.2 (/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.2 (/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/v2.3.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v2.3.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/dts.overlay
-- Generated zephyr.dts: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/zephyr/dts.cmake
warning: Experimental symbol NET_SOCKETPAIR is enabled.
Parsing /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.3.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig'
Merged configuration '/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/prj.conf'
Configuration saved to '/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/zephyr/.config'
Kconfig header saved to '/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Found assembler: /opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=== child image hci_rpmsg - CPUNET begin ===
loading initial cache file /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.3.0/zephyr/samples/bluetooth/hci_rpmsg
-- Board: nrf7002dk_nrf5340_cpunet
-- Found BOARD.dts: /opt/nordic/ncs/v2.3.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.3.0/zephyr/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.3.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpunet_defconfig'
Merged configuration '/opt/nordic/ncs/v2.3.0/zephyr/samples/bluetooth/hci_rpmsg/prj.conf'
Merged configuration '/opt/nordic/ncs/v2.3.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/child_image/hci_rpmsg.conf'
Configuration saved to '/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr/.config'
Kconfig header saved to '/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr/include/generated/autoconf.h'
-- libmetal version: 1.3.0 (/opt/nordic/ncs/v2.3.0/zephyr/samples/bluetooth/hci_rpmsg)
-- Build type:
-- Host: Darwin/x86_64
-- Target: Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.3.0 (/opt/nordic/ncs/v2.3.0/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS : -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg
=== child image hci_rpmsg - CPUNET end ===
-- libmetal version: 1.3.0 (/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex)
-- Build type:
-- Machine: arm
-- Machine: arm
CMake Warning at /opt/nordic/ncs/v2.3.0/zephyr/CMakeLists.txt:824 (message):
No SOURCES given to Zephyr library: drivers__wifi
Excluding target from build.
No SOURCES given to Zephyr library: drivers__ethernet
-- Configuring done
-- Generating done
[1/498] Preparing syscall dependency handling
[2/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
[3/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
[4/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
[5/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
[6/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
[7/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
[8/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
[9/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
[10/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pem.c.obj
[11/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pkcs12.c.obj
[12/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
[13/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
[14/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
[15/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pkcs5.c.obj
[16/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pkparse.c.obj
[17/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pkwrite.c.obj
[18/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/dhm.c.obj
[19/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/cipher.c.obj
[20/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
[21/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/md.c.obj
[22/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pk.c.obj
[23/498] Generating include/generated/version.h
-- Zephyr version: 3.2.99 (/opt/nordic/ncs/v2.3.0/zephyr), build: v3.2.99-ncs2
[24/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
[25/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/sha1.c.obj
[26/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/sha256.c.obj
[27/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/sha512.c.obj
[28/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ripemd160.c.obj
[29/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/md5.c.obj
[30/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/aesni.c.obj
[31/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/aria.c.obj
[32/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/camellia.c.obj
[33/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/des.c.obj
[34/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/cmac.c.obj
[35/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ccm.c.obj
[36/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/chachapoly.c.obj
[37/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ecdh.c.obj
[38/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ecdsa.c.obj
[39/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ecp.c.obj
[40/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
[41/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/gcm.c.obj
[42/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/hkdf.c.obj
[43/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
[44/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
[45/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/rsa.c.obj
[46/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
[47/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/entropy.c.obj
[48/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/chacha20.c.obj
[49/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/poly1305.c.obj
[50/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ecjpake.c.obj
[51/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
[52/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
[53/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
[54/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
[55/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/x509_crl.c.obj
[56/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/x509.c.obj
[57/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/x509_create.c.obj
[58/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/x509_crt.c.obj
[59/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/x509_csr.c.obj
[60/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/asn1parse.c.obj
[61/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/asn1write.c.obj
[62/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/base64.c.obj
[63/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/bignum.c.obj
[64/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/nist_kw.c.obj
[65/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/oid.c.obj
[66/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/padlock.c.obj
[67/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/platform.c.obj
[68/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/platform_util.c.obj
[69/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/version.c.obj
[70/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/debug.c.obj
[71/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/constant_time.c.obj
[72/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/net_sockets.c.obj
[73/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
[74/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
[75/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_cli.c.obj
[76/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
[77/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
[78/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
[79/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_srv.c.obj
[80/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
[81/498] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v2.3.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
[82/498] Generating misc/generated/syscalls_subdirs.trigger
[83/498] Creating directories for 'hci_rpmsg_subimage'
[84/498] Linking C static library modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a
[85/498] No download step for 'hci_rpmsg_subimage'
[86/498] No update step for 'hci_rpmsg_subimage'
[87/498] No patch step for 'hci_rpmsg_subimage'
[88/498] No configure step for 'hci_rpmsg_subimage'
[88/498] Performing build step for 'hci_rpmsg_subimage'
[1/230] Preparing syscall dependency handling
[2/230] Generating include/generated/version.h
[3/230] Generating misc/generated/syscalls_subdirs.trigger
[4/230] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[5/230] Generating include/generated/driver-validation.h
[6/230] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[7/230] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[8/230] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[9/230] Generating include/generated/offsets.h
[10/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[11/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[12/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[13/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[14/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[15/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[16/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[17/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[18/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[19/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[20/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[21/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[22/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[23/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[24/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[25/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[26/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[27/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[28/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[29/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[30/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[31/230] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[32/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[33/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[34/230] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[35/230] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[36/230] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[37/230] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[38/230] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[39/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[40/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/ipc_service.c.obj
[41/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_rpmsg.c.obj
[42/230] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.3.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[43/230] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.3.0/modules/crypto/tinycrypt/lib/source/utils.c.obj
[44/230] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.3.0/modules/crypto/tinycrypt/lib/source/aes_decrypt.c.obj
[45/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/backends/ipc_rpmsg_static_vrings.c.obj
[46/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_static_vrings.c.obj
[47/230] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[48/230] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.3.0/modules/crypto/tinycrypt/lib/source/aes_encrypt.c.obj
[49/230] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[50/230] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[51/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[52/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[53/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[54/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[55/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[56/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[57/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[58/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[59/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[60/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[61/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[62/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[63/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[64/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[65/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[66/230] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[67/230] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[68/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/addr.c.obj
[69/230] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[70/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
[71/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/bt_str.c.obj
[72/230] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
[73/230] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_raw.c.obj
[74/230] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
[75/230] Generating linker_zephyr_pre1.cmd
[76/230] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[77/230] Generating linker_zephyr_pre0.cmd
[78/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[79/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[80/230] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[81/230] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[82/230] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[83/230] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[84/230] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[85/230] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[86/230] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[87/230] Linking C static library zephyr/arch/common/libisr_tables.a
[88/230] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[89/230] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[90/230] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[91/230] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[92/230] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
[93/230] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
[94/230] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
[95/230] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
[96/230] Linking C static library zephyr/subsys/net/libsubsys__net.a
[97/230] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
[98/230] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
[99/230] Linking C static library zephyr/subsys/random/libsubsys__random.a
[100/230] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
[101/230] Linking C static library zephyr/drivers/console/libdrivers__console.a
[102/230] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
[103/230] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
[104/230] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
[105/230] Linking C static library zephyr/arch/common/libarch__common.a
[106/230] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[107/230] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[108/230] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
[109/230] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
[110/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
[111/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
[112/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
[113/230] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/ecdh.c.obj
[114/230] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[115/230] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/api_init/mpsl_fem_api_init.c.obj
[116/230] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
[117/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.3.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
[118/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[119/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.3.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[120/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[121/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[122/230] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.3.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
[123/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/dma.c.obj
[124/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/device.c.obj
[125/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/init.c.obj
[126/230] Linking C static library zephyr/drivers/mbox/libdrivers__mbox.a
[127/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/io.c.obj
[128/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/irq.c.obj
[129/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/log.c.obj
[130/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
[131/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
[132/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
[133/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
[134/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
[135/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
[136/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/init.c.obj
[137/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/irq.c.obj
[138/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/log.c.obj
[139/230] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
[140/230] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
[141/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/shmem.c.obj
[142/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/time.c.obj
[143/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/version.c.obj
[144/230] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
[145/230] Linking C static library modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a
[146/230] Linking C static library modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a
[147/230] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
[148/230] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/sys.c.obj
[149/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtio.c.obj
[150/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtqueue.c.obj
[151/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg.c.obj
[152/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg_virtio.c.obj
[153/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/elf_loader.c.obj
[154/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc.c.obj
[155/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc_virtio.c.obj
[156/230] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[157/230] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
[158/230] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/rsc_table_parser.c.obj
[159/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[160/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[161/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[162/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[163/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[164/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[165/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[166/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[167/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[168/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[169/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[170/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[171/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[172/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[173/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[174/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[175/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[176/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[177/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[178/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[179/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[180/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[181/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[182/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[183/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
[184/230] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[185/230] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[186/230] Building C object CMakeFiles/app.dir/src/main.c.obj
[187/230] Linking C static library zephyr/libzephyr.a
[188/230] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
[189/230] Generating ../../../include/generated/libc/minimal/strerror_table.h
[190/230] Linking C static library modules/libmetal/libmetal/lib/libmetal.a
[191/230] Linking C static library modules/open-amp/open-amp/lib/libopen_amp.a
[192/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[193/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[194/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[195/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[196/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[197/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[198/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[199/230] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[200/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[201/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[202/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[203/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[204/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[205/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[206/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[207/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[208/230] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
[209/230] Linking C static library app/libapp.a
[210/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[211/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[212/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[213/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[214/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[215/230] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[216/230] Linking C static library zephyr/kernel/libkernel.a
[217/230] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
[218/230] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf -fuse-ld=bfd -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/random/libsubsys__random.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/mbox/libdrivers__mbox.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/libmetal/libmetal/lib/libmetal.a modules/open-amp/open-amp/lib/libopen_amp.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"/opt/nordic/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/thumb/v8-m.main/nofp" -L/Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr -lgcc zephyr/arch/common/libisr_tables.a /opt/nordic/ncs/v2.3.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m33+nodsp/soft-float/liboberon_3.0.12.a -no-pie -mcpu=cortex-m33+nodsp -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn /opt/nordic/ncs/v2.3.0/nrfxlib/softdevice_controller/lib/cortex-m33+nodsp/soft-float/libsoftdevice_controller_multirole.a /opt/nordic/ncs/v2.3.0/nrfxlib/mpsl/lib/cortex-m33+nodsp/soft-float/libmpsl.a && cd /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg/zephyr && /opt/nordic/ncs/toolchains/v2.3.0/Cellar/cmake/3.20.5/bin/cmake -E echo
[482/498] Linking C static library modules/hostap/lib..__modules__lib__hostap__zephyr.a
FAILED: modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-build hci_rpmsg/zephyr/zephyr.hex hci_rpmsg/zephyr/zephyr.elf hci_rpmsg/zephyr/merged_CPUNET.hex
cd /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build/hci_rpmsg && /opt/nordic/ncs/toolchains/v2.3.0/Cellar/cmake/3.20.5/bin/cmake --build . --
[484/498] Linking C executable zephyr/zephyr_pre0.elf
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/v2.3.0/bin/cmake --build /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build
* The terminal process terminated with exit code: 1.
  • I uninstalled nRF Connect SDK v2.3..0 and reinstalled it.  Same error.
    I edited the build configuration and turned on "Enable debug options", same error.  Turned it back off, same error.
    I set CONFIG_HEAP_MEM_POOL_SIZE=1000 in my prj.conf and still same error.
    I purposely broke my prj.conf by setting CONFIG_HEAP_MEM_POOL_SIZE=a1000 just to make sure I'm editing the file that's actually being used and got an new CMake error right after that config file was merged.
    Are we testing the same of very similar boards?  Mine shows in VSCode as
    NRF7002DK_NRF5340_CPUAPP
    And from command line;
    nrfjprog --deviceversion
    1050782657 - NRF5340_xxAA_REV1
    nrfjprog --version
    nrfjprog version: 10.19.0 external
    JLinkARM.dll version: 7.84d
    I also tried setting the build configuration to nrf700dk_nrf5340_cpunet but that resulted in compile errors.
    I'm doing all this work on a MacBook Pro, with Intel i9, running Ventura 13.3.1.
    I have nRF Connect for Desktop v4.1.1
    Toolchain Manager v1.2.2.
    Any ideas for something else I can try or more info I can provide?
  • Do you get the same error when building from command line (using west)?
  • I've never built from the command line and my initial attempts failed.  Maybe you could give me a hint.
    When I build in VSCode I see this command getting run;
    Building sr_coex
    I tried that from the command line and I guess 'west' isn't in my path, so I tried adding the path to west from the toolchains dir;
    /bin/sh -c /opt/nordic/ncs/toolchains/v2.3.0/bin/west build --build-dir /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex/build /Users/leedrengenberg/github/nordic/nRF-Connect-SDK-Fundamentals/v2.x.x/sr_coex
    But this just gives the usage for west.
    Then I thought I probably don't need the `/bin/sh -c` so I tried without that, but then I get;
    west: error: argument <command>: invalid choice: 'build' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate')
    In Code it looks like it's calling west with a 'build' command, so I'm a bit confused on that.
  • I wiped out everything and set up the SDK over again (currently with nRF Connect SDK 2.4.0 and it's working now.  I'm not sure what was causing the problem before but we can close this now.
