nrf52840 DK HW rev 3.0.1
Dear Forum,
We obtained a nrf52840DK in HW rev. 2.0.1 some time ago. This HW-revision worked in every aspect as expected, which means:
1) It could be adressed;
read deviceversion:
>>nrfjprog --deviceversion
NRF52840_xxAA_REV2
read MAC:
>>nrfjprog --memrd 0x100000A4 --n 8
[MACBYTES]
2) It's memory could be read out with the nordic programmer:
Select Device-->(read button enabled)
Code compiled for pci10056 could be uploaded and run on the DK.
4) Segger Embedded Studio's debugger could run code on BM833 devices connected via PINs VTG, SWD IO, SWD CLK and GND DETECT as well as on the DK. This fails, the PINs no longer are available and the DK is not detected by the debugger.
Now we needed further DKs and reordered them, they came as nrf52840DK in HW rev. 3.0.1, they operate on a 5340 chip, as can be seen on the PCB.
This revision failed to worked in every aspect as expected, which means:
1) It cannot be adressed;
read deviceversion:
ERROR: The operation attempted is unavailable due to readback protection in
ERROR: your device. Please use --recover to unlock the device.
read MAC:
Select Device-->(read button disabled)
Code compiled for pci10056 could be uploaded and run.
After forcedly clearing the device, code compiled for pci10056 can be be uploaded, but will not run.
After each unplug/replug, the forced clearing has to be done again, else the state will be as described above for rev. 3.0.1
3) Segger Embedded Studio's debugger running code: This fails, the named PINs no longer are available and the DK is generally not detected by the debugger, even standalone.
Question: How must the rev. 3.0.1 DK be prepared and adressed to behave as a nrf52840 DK rev. 2.0.1?
Additional Info:
Using Ubuntu Linux,  20.04.6 LTS
nrfjprog --version
nrfjprog version: 10.12.1
JLinkARM.dll version: 6.88a
nrfConnect for Desktop: 3.11.0
Programmer: 2.3.3
Segger Embedded Studio: 5.4.4
Richard
  • Hi Amanda,
    I followed the steps concerning:
    J-Link>SWDSelect
    The APPROTECTSTATUS register can be read without selecting a different AP:
    SWDReadAP 3
        Read AP register 3 = 0x00000001
    A value of 1 means that access port protection is disabled.
    This allows the code to be accessed while the DK stays connected. But as soon as Idisconnect & reconnect the DK, the APPROTECT is reported to be enabled again.
    Performing the above steps without " ERASEALL operation:" doesn't allow to re-disable APPROTECT.
    So it seems that the uploaded code/Softdevice enable the APPROTECT by default.
    So I went to the example describing on how to set the APPROTECT withing the App (see Step 2: Setting UICR.APPROTECT):
    I tried adding the code to the main of my project. As stated, I use Segger Embedded Studio: 5.4.4
    I got a complaint from the compiler:
    ‘UICR_APPROTECT_PALL_HwDisabled’ undeclared (first use in this function); did you mean ‘UICR_APPROTECT_PALL_Disabled’?
    Now I read in the related post, which I assume is source of the trouble:
    NOTE: If using the nRF5 SDK then ensure that it has been updated to MDK version 8.45.0 or newer.
    I'm using SDK 17.0.2. I could not determine the MDK version used, but checking for MDK, I found out, that this is some KEIL related stuff, which I'm not using since I use Segger Embedded Studio.
    How can I create that APPROTECT-setting code using Segger Embedded Studio?
    Richard
  • Hi Amanda,
    thank you very much for all the support. Now, following the post you linked, I was able to compile my code for the nrf52840 DK as well as BM833.
    But I also use a BM833A which is a nRF52811 chipset. There, I still cannot compile using the additional code.
    Now checking the definition for e.g. "UICR_APPROTECT_PALL_HwDisabled" in the new MDK (shipped with SDK 17.1.0) renders, that it is found in the following files:
    ./modules/nrfx/mdk/nrf52833_bitfields.h
    ./modules/nrfx/mdk/nrf52820_bitfields.h
    ./modules/nrfx/mdk/nrf52840_bitfields.h
    ./modules/nrfx/mdk/nrf52_bitfields.h
    The also (in this folder) contained file nrf52811_bitfields.h doesn't contain the required definitions.
    Again, I'd like to know if there is a solution to that, because generally 52811 seems to support APPROTECT:
    https://infocenter.nordicsemi.com/pdf/nRF52811_PS_v1.0.pdf
    Richard
    According to https://infocenter.nordicsemi.com/pdf/in_151_v1.0.1.pdf?cp=18_6,  it is required to upgrade to the latest MDK (version 8.43.0 or later) to support APPROTECT.
    Amanda H.
