Using PDM causes BLE connection to drop
We have a custom board using a nRF52840 module and a PDM peripheral. Some of our recently produced boards are experiencing issues with dropped BLE connections when we turn on PDM. The boards continue to work otherwise and the PDM signals the boards are receiving are fine. There are no issues with BLE communication as long as PDM is not running. Our firmware is based on nRF5 SDK 15 and we are using the NRFX PDM driver.
On the affected boards, the behavior seems to be temperature dependent. We can communicate over BLE while PDM is running at higher temperatures of >35°C, but as we lower the temperature, we start having BLE communication issues. Once a board starts experiencing the issue, the radio stops working completely over the span of about 3°C. Different boards encounter the issue at different temperatures, and most of them are fine all the way down to 0°C which is where we stopped testing.
We're using pins 0.24 and 0.25 for PDM, which don't have any high frequency restrictions in the datasheet. Also, we have found that if we remove the PDM peripheral from an affected board, the BLE issue doesn't occur anymore even if we turn on PDM.
I tried searching the forum for similar issues, but the closest I was able to find was this one, where BLE was causing problems with the PDM signal. We have the inverse issue. https://devzone.nordicsemi.com/f/nordic-q-a/53823/pdm-conflict-with-bluetooth-transceiver
