i am using ubuntu 20.04 as a matter contoller and nrf52840 as matter devce and i am doing BLE - WIFi commssionig and i get BLE timeout error how to solve it.
hello,
this time when i try command i got this error in chip-tool.
[1684230718.566347][6292:6292] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1684230718.566428][6292:6292] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1684230718.566447][6292:6292] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1684230718.566459][6292:6292] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1684230718.566516][6292:6292] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-inDG7Z)
[1684230718.566640][6292:6292] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1684230718.566646][6292:6292] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
[1684230718.567540][6292:6292] CHIP:DL: Got Ethernet interface: enp1s0
[1684230718.568349][6292:6292] CHIP:DL: Found the primary Ethernet interface:enp1s0
[1684230718.569145][6292:6292] CHIP:DL: Got WiFi interface: wlp3s0
[1684230718.570589][6292:6292] CHIP:DL: Found the primary WiFi interface:wlp3s0
[1684230718.570609][6292:6292] CHIP:IN: UDP::Init bind&listen port=0
[1684230718.570621][6292:6292] CHIP:IN: UDP::Init bound to port=35225
[1684230718.570623][6292:6292] CHIP:IN: UDP::Init bind&listen port=0
[1684230718.570632][6292:6292] CHIP:IN: UDP::Init bound to port=57223
[1684230718.570635][6292:6292] CHIP:IN: BLEBase::Init - setting/overriding transport
[1684230718.570638][6292:6292] CHIP:IN: TransportMgr initialized
[1684230718.570644][6292:6292] CHIP:FP: Initializing FabricTable from persistent storage
[1684230718.570674][6292:6292] CHIP:TS: Last Known Good Time: 2023-05-15T15:02:24
[1684230718.570783][6292:6292] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x9E54AB3775C029E2, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1684230718.571095][6292:6292] CHIP:ZCL: Using ZAP configuration...
[1684230718.580035][6292:6292] CHIP:CTL: System State Initialized...
[1684230718.580049][6292:6292] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1684230718.580057][6292:6292] CHIP:CTL: Setting attestation nonce to random value
[1684230718.580063][6292:6292] CHIP:CTL: Setting CSR nonce to random value
[1684230718.580072][6292:6292] CHIP:IN: UDP::Init bind&listen port=5550
[1684230718.580081][6292:6292] CHIP:IN: UDP::Init bound to port=5550
[1684230718.580084][6292:6292] CHIP:IN: UDP::Init bind&listen port=5550
[1684230718.580089][6292:6292] CHIP:IN: UDP::Init bound to port=5550
[1684230718.580091][6292:6292] CHIP:IN: TransportMgr initialized
[1684230718.580171][6292:6294] CHIP:DL: CHIP task running
[1684230718.580188][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1684230718.580249][6292:6294] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1684230718.580257][6292:6294] CHIP:CTL: Setting attestation nonce to random value
[1684230718.580271][6292:6294] CHIP:CTL: Setting CSR nonce to random value
[1684230718.581064][6292:6294] CHIP:CTL: Generating NOC
[1684230718.581298][6292:6294] CHIP:FP: Validating NOC chain
[1684230718.581685][6292:6294] CHIP:FP: NOC chain validation successful
[1684230718.581724][6292:6294] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1684230718.581728][6292:6294] CHIP:TS: Last Known Good Time: 2023-05-15T15:02:24
[1684230718.581731][6292:6294] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1684230718.581732][6292:6294] CHIP:TS: Retaining current Last Known Good Time
[1684230718.582098][6292:6294] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1684230718.582342][6292:6294] CHIP:TS: Committing Last Known Good Time to storage: 2023-05-15T15:02:24
[1684230718.582548][6292:6294] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 9E54AB3775C029E2)
[1684230718.582555][6292:6294] CHIP:IN: UDP::Init bind&listen port=5550
[1684230718.582566][6292:6294] CHIP:IN: UDP::Init bound to port=5550
[1684230718.582569][6292:6294] CHIP:IN: UDP::Init bind&listen port=5550
[1684230718.582577][6292:6294] CHIP:IN: UDP::Init bound to port=5550
[1684230718.582579][6292:6294] CHIP:IN: TransportMgr initialized
[1684230718.584709][6292:6294] CHIP:CTL: Setting wifi credentials from parameters
[1684230718.584715][6292:6294] CHIP:CTL: Setting attestation nonce to random value
[1684230718.584721][6292:6294] CHIP:CTL: Setting CSR nonce to random value
[1684230718.584725][6292:6294] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1684230718.585744][6292:6293] CHIP:DL: TRACE: Bus acquired for name C-1894
[1684230718.587298][6292:6294] CHIP:DL: PlatformBlueZInit init success
[1684230718.588347][6292:6293] CHIP:BLE: BLE removing known devices.
[1684230718.588720][6292:6293] CHIP:BLE: BLE initiating scan.
[1684230718.705438][6292:6294] CHIP:DL: Long dispatch time: 120 ms, for event type 2
[1684230718.710072][6292:6293] CHIP:BLE: Device 0B:5B:28:CE:6D:3E does not look like a CHIP device.
[1684230718.717314][6292:6293] CHIP:BLE: Device 07:42:1D:BD:03:B9 does not look like a CHIP device.
[1684230718.722222][6292:6293] CHIP:BLE: Device 4F:21:E8:36:57:6E does not look like a CHIP device.
[1684230718.726946][6292:6293] CHIP:BLE: Device 04:E3:A7:D7:AE:7C does not look like a CHIP device.
[1684230718.732020][6292:6293] CHIP:BLE: Device 73:3A:B1:23:5F:0A does not look like a CHIP device.
[1684230718.746817][6292:6293] CHIP:BLE: Device CF:4F:81:F5:7D:55 does not look like a CHIP device.
[1684230718.747659][6292:6293] CHIP:BLE: Device 23:E7:6C:82:1E:88 does not look like a CHIP device.
[1684230718.750666][6292:6293] CHIP:BLE: Device 31:6D:B6:CA:BE:31 does not look like a CHIP device.
[1684230718.752190][6292:6293] CHIP:BLE: Device 31:16:44:6F:10:F8 does not look like a CHIP device.
[1684230718.764212][6292:6293] CHIP:BLE: Device 2A:79:29:6C:05:85 does not look like a CHIP device.
[1684230718.776483][6292:6293] CHIP:BLE: Device 1E:66:4F:16:1C:57 does not look like a CHIP device.
[1684230718.785696][6292:6293] CHIP:BLE: Device C8:74:00:1C:D2:D7 does not look like a CHIP device.
[1684230718.787414][6292:6293] CHIP:BLE: Device C3:B4:CA:7C:C4:31 does not look like a CHIP device.
[1684230718.792258][6292:6293] CHIP:BLE: Device 09:6D:AF:75:5F:77 does not look like a CHIP device.
[1684230718.807426][6292:6293] CHIP:BLE: Device C1:C8:16:AE:FD:1D does not look like a CHIP device.
[1684230718.811389][6292:6293] CHIP:BLE: Device 66:6C:EA:A6:B3:38 does not look like a CHIP device.
[1684230718.857189][6292:6293] CHIP:BLE: Device 73:01:BB:FC:F8:62 does not look like a CHIP device.
[1684230718.878114][6292:6293] CHIP:BLE: Device 54:44:A3:07:D5:79 does not look like a CHIP device.
[1684230718.900972][6292:6293] CHIP:BLE: New device scanned: FA:97:EA:11:13:83
[1684230718.900985][6292:6293] CHIP:BLE: Device discriminator match. Attempting to connect.
[1684230719.283789][6292:6293] CHIP:DL: ConnectDevice complete
[1684230720.560238][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560250][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560255][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560260][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560264][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560267][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560271][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560274][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560278][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560281][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560285][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560287][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560293][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560295][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560301][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560304][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560308][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560310][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560314][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0001
[1684230720.560316][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560322][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560325][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560329][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560332][6292:6293] CHIP:DL: Char1 /org/bluez/hci0/dev_FA_97_EA_11_13_83/service0010
[1684230720.560337][6292:6293] CHIP:DL: New BLE connection 0x7fc59c03bd20, device FA:97:EA:11:13:83, path /org/bluez/hci0/dev_FA_97_EA_11_13_83
[1684230720.560364][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1684230720.560373][6292:6294] CHIP:DIS: Closing all BLE connections
[1684230720.560388][6292:6294] CHIP:IN: BleConnectionComplete: endPoint 0x55a0155d5da0
[1684230720.560481][6292:6294] CHIP:IN: SecureSession[0x7fc594021970]: Allocated Type:1 LSID:1813
[1684230720.560489][6292:6294] CHIP:SC: Assigned local session key ID 1813
[1684230720.560515][6292:6294] CHIP:EM: <<< [E:36612i S:0 M:181178120] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1684230720.560530][6292:6294] CHIP:IN: (U) Sending msg 181178120 to IP address 'BLE'
[1684230720.560537][6292:6294] CHIP:IN: Message appended to BLE send queue
[1684230720.560541][6292:6294] CHIP:SC: Sent PBKDF param request
[1684230720.982907][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230721.083632][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1684230721.083656][6292:6294] CHIP:BLE: subscribe complete, ep = 0x55a0155d5da0
[1684230721.084021][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230721.084144][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230721.084160][6292:6294] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1684230721.084166][6292:6294] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1684230721.084169][6292:6294] CHIP:BLE: local and remote recv window size = 5
[1684230721.084348][6292:6294] CHIP:IN: BLE EndPoint 0x55a0155d5da0 Connection Complete
[1684230721.183056][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230721.187629][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230721.187729][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230721.187826][6292:6294] CHIP:EM: >>> [E:36612i S:0 M:96624967] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1684230721.187846][6292:6294] CHIP:EM: Found matching exchange: 36612i, Delegate: 0x7fc594023f50
[1684230721.187862][6292:6294] CHIP:SC: Received PBKDF param response
[1684230721.187884][6292:6294] CHIP:SC: Peer assigned session ID 1039
[1684230721.187902][6292:6294] CHIP:SC: Found MRP parameters in the message
[1684230721.193835][6292:6294] CHIP:EM: <<< [E:36612i S:0 M:181178121] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1684230721.193858][6292:6294] CHIP:IN: (U) Sending msg 181178121 to IP address 'BLE'
[1684230721.194131][6292:6294] CHIP:SC: Sent spake2p msg1
[1684230721.277908][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230723.307448][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.307596][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230723.307679][6292:6294] CHIP:EM: >>> [E:36612i S:0 M:96624968] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1684230723.307698][6292:6294] CHIP:EM: Found matching exchange: 36612i, Delegate: 0x7fc594023f50
[1684230723.307714][6292:6294] CHIP:SC: Received spake2p msg2
[1684230723.308570][6292:6294] CHIP:EM: <<< [E:36612i S:0 M:181178122] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1684230723.308597][6292:6294] CHIP:IN: (U) Sending msg 181178122 to IP address 'BLE'
[1684230723.308915][6292:6294] CHIP:SC: Sent spake2p msg3
[1684230723.393225][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230723.394895][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.395029][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230723.395106][6292:6294] CHIP:EM: >>> [E:36612i S:0 M:96624969] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1684230723.395123][6292:6294] CHIP:EM: Found matching exchange: 36612i, Delegate: 0x7fc594023f50
[1684230723.395178][6292:6294] CHIP:SC: SecureSession[0x7fc594021970, LSID:1813]: State change 'kEstablishing' --> 'kActive'
[1684230723.395187][6292:6294] CHIP:IN: SecureSession[0x7fc594021970]: Activated - Type:1 LSID:1813
[1684230723.395194][6292:6294] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:1813 PSID:1039!
[1684230723.395204][6292:6294] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1684230723.395211][6292:6294] CHIP:TOO: Pairing Success
[1684230723.395215][6292:6294] CHIP:TOO: PASE establishment successful
[1684230723.395223][6292:6294] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1684230723.395231][6292:6294] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1684230723.395237][6292:6294] CHIP:CTL: Sending request for commissioning information
[1684230723.395255][6292:6294] CHIP:DMG: SendReadRequest ReadClient[0x7fc59402c3d0]: Sending Read Request
[1684230723.395323][6292:6294] CHIP:EM: <<< [E:36613i S:1813 M:185546708] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
[1684230723.395340][6292:6294] CHIP:IN: (S) Sending msg 185546708 on secure session with LSID: 1813
[1684230723.395546][6292:6294] CHIP:DMG: MoveToState ReadClient[0x7fc59402c3d0]: Moving to [AwaitingIn]
[1684230723.527884][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230723.574049][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.574131][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230723.664564][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.664623][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230723.664678][6292:6294] CHIP:EM: >>> [E:36613i S:1813 M:68342278] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1684230723.664690][6292:6294] CHIP:EM: Found matching exchange: 36613i, Delegate: 0x7fc59402c3e0
[1684230723.664733][6292:6294] CHIP:DMG: ReportDataMessage =
[1684230723.664738][6292:6294] CHIP:DMG: {
[1684230723.664741][6292:6294] CHIP:DMG: AttributeReportIBs =
[1684230723.664750][6292:6294] CHIP:DMG: [
[1684230723.664753][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.664762][6292:6294] CHIP:DMG: {
[1684230723.664766][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.664772][6292:6294] CHIP:DMG: {
[1684230723.664778][6292:6294] CHIP:DMG: DataVersion = 0x822639a4,
[1684230723.664782][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.664787][6292:6294] CHIP:DMG: {
[1684230723.664792][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.664798][6292:6294] CHIP:DMG: Cluster = 0x31,
[1684230723.664804][6292:6294] CHIP:DMG: Attribute = 0x0000_0003,
[1684230723.664808][6292:6294] CHIP:DMG: }
[1684230723.664815][6292:6294] CHIP:DMG:
[1684230723.664821][6292:6294] CHIP:DMG: Data = 20,
[1684230723.664827][6292:6294] CHIP:DMG: },
[1684230723.664833][6292:6294] CHIP:DMG:
[1684230723.664837][6292:6294] CHIP:DMG: },
[1684230723.664849][6292:6294] CHIP:DMG:
[1684230723.664852][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.664860][6292:6294] CHIP:DMG: {
[1684230723.664864][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.664868][6292:6294] CHIP:DMG: {
[1684230723.664873][6292:6294] CHIP:DMG: DataVersion = 0x2c4d208d,
[1684230723.664880][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.664884][6292:6294] CHIP:DMG: {
[1684230723.664889][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.664894][6292:6294] CHIP:DMG: Cluster = 0x28,
[1684230723.664899][6292:6294] CHIP:DMG: Attribute = 0x0000_0004,
[1684230723.664904][6292:6294] CHIP:DMG: }
[1684230723.664909][6292:6294] CHIP:DMG:
[1684230723.664915][6292:6294] CHIP:DMG: Data = 32773,
[1684230723.664919][6292:6294] CHIP:DMG: },
[1684230723.664926][6292:6294] CHIP:DMG:
[1684230723.664930][6292:6294] CHIP:DMG: },
[1684230723.664939][6292:6294] CHIP:DMG:
[1684230723.664943][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.664949][6292:6294] CHIP:DMG: {
[1684230723.664953][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.664959][6292:6294] CHIP:DMG: {
[1684230723.664964][6292:6294] CHIP:DMG: DataVersion = 0x2c4d208d,
[1684230723.664968][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.664973][6292:6294] CHIP:DMG: {
[1684230723.664977][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.664982][6292:6294] CHIP:DMG: Cluster = 0x28,
[1684230723.664987][6292:6294] CHIP:DMG: Attribute = 0x0000_0002,
[1684230723.664992][6292:6294] CHIP:DMG: }
[1684230723.664997][6292:6294] CHIP:DMG:
[1684230723.665002][6292:6294] CHIP:DMG: Data = 65521,
[1684230723.665006][6292:6294] CHIP:DMG: },
[1684230723.665014][6292:6294] CHIP:DMG:
[1684230723.665017][6292:6294] CHIP:DMG: },
[1684230723.665027][6292:6294] CHIP:DMG:
[1684230723.665031][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.665039][6292:6294] CHIP:DMG: {
[1684230723.665043][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.665049][6292:6294] CHIP:DMG: {
[1684230723.665053][6292:6294] CHIP:DMG: DataVersion = 0x915d7a9a,
[1684230723.665057][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.665062][6292:6294] CHIP:DMG: {
[1684230723.665067][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.665072][6292:6294] CHIP:DMG: Cluster = 0x30,
[1684230723.665076][6292:6294] CHIP:DMG: Attribute = 0x0000_0003,
[1684230723.665081][6292:6294] CHIP:DMG: }
[1684230723.665087][6292:6294] CHIP:DMG:
[1684230723.665091][6292:6294] CHIP:DMG: Data = 0,
[1684230723.665096][6292:6294] CHIP:DMG: },
[1684230723.665102][6292:6294] CHIP:DMG:
[1684230723.665106][6292:6294] CHIP:DMG: },
[1684230723.665116][6292:6294] CHIP:DMG:
[1684230723.665120][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.665128][6292:6294] CHIP:DMG: {
[1684230723.665132][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.665137][6292:6294] CHIP:DMG: {
[1684230723.665141][6292:6294] CHIP:DMG: DataVersion = 0x915d7a9a,
[1684230723.665145][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.665150][6292:6294] CHIP:DMG: {
[1684230723.665155][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.665160][6292:6294] CHIP:DMG: Cluster = 0x30,
[1684230723.665165][6292:6294] CHIP:DMG: Attribute = 0x0000_0002,
[1684230723.665169][6292:6294] CHIP:DMG: }
[1684230723.665176][6292:6294] CHIP:DMG:
[1684230723.665180][6292:6294] CHIP:DMG: Data = 0,
[1684230723.665184][6292:6294] CHIP:DMG: },
[1684230723.665191][6292:6294] CHIP:DMG:
[1684230723.665194][6292:6294] CHIP:DMG: },
[1684230723.665204][6292:6294] CHIP:DMG:
[1684230723.665208][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.665216][6292:6294] CHIP:DMG: {
[1684230723.665219][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.665225][6292:6294] CHIP:DMG: {
[1684230723.665229][6292:6294] CHIP:DMG: DataVersion = 0x915d7a9a,
[1684230723.665234][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.665238][6292:6294] CHIP:DMG: {
[1684230723.665243][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.665248][6292:6294] CHIP:DMG: Cluster = 0x30,
[1684230723.665253][6292:6294] CHIP:DMG: Attribute = 0x0000_0001,
[1684230723.665257][6292:6294] CHIP:DMG: }
[1684230723.665263][6292:6294] CHIP:DMG:
[1684230723.665268][6292:6294] CHIP:DMG: Data =
[1684230723.665272][6292:6294] CHIP:DMG: {
[1684230723.665278][6292:6294] CHIP:DMG: 0x0 = 60,
[1684230723.665283][6292:6294] CHIP:DMG: 0x1 = 900,
[1684230723.665288][6292:6294] CHIP:DMG: },
[1684230723.665292][6292:6294] CHIP:DMG: },
[1684230723.665299][6292:6294] CHIP:DMG:
[1684230723.665303][6292:6294] CHIP:DMG: },
[1684230723.665314][6292:6294] CHIP:DMG:
[1684230723.665318][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.665326][6292:6294] CHIP:DMG: {
[1684230723.665329][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.665334][6292:6294] CHIP:DMG: {
[1684230723.665339][6292:6294] CHIP:DMG: DataVersion = 0x915d7a9a,
[1684230723.665343][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.665348][6292:6294] CHIP:DMG: {
[1684230723.665352][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.665357][6292:6294] CHIP:DMG: Cluster = 0x30,
[1684230723.665362][6292:6294] CHIP:DMG: Attribute = 0x0000_0000,
[1684230723.665367][6292:6294] CHIP:DMG: }
[1684230723.665372][6292:6294] CHIP:DMG:
[1684230723.665377][6292:6294] CHIP:DMG: Data = 0,
[1684230723.665381][6292:6294] CHIP:DMG: },
[1684230723.665388][6292:6294] CHIP:DMG:
[1684230723.665391][6292:6294] CHIP:DMG: },
[1684230723.665415][6292:6294] CHIP:DMG:
[1684230723.665420][6292:6294] CHIP:DMG: AttributeReportIB =
[1684230723.665427][6292:6294] CHIP:DMG: {
[1684230723.665432][6292:6294] CHIP:DMG: AttributeDataIB =
[1684230723.665436][6292:6294] CHIP:DMG: {
[1684230723.665441][6292:6294] CHIP:DMG: DataVersion = 0x822639a4,
[1684230723.665445][6292:6294] CHIP:DMG: AttributePathIB =
[1684230723.665449][6292:6294] CHIP:DMG: {
[1684230723.665454][6292:6294] CHIP:DMG: Endpoint = 0x0,
[1684230723.665459][6292:6294] CHIP:DMG: Cluster = 0x31,
[1684230723.665464][6292:6294] CHIP:DMG: Attribute = 0x0000_FFFC,
[1684230723.665469][6292:6294] CHIP:DMG: }
[1684230723.665475][6292:6294] CHIP:DMG:
[1684230723.665479][6292:6294] CHIP:DMG: Data = 2,
[1684230723.665483][6292:6294] CHIP:DMG: },
[1684230723.665490][6292:6294] CHIP:DMG:
[1684230723.665495][6292:6294] CHIP:DMG: },
[1684230723.665502][6292:6294] CHIP:DMG:
[1684230723.665505][6292:6294] CHIP:DMG: ],
[1684230723.665532][6292:6294] CHIP:DMG:
[1684230723.665536][6292:6294] CHIP:DMG: SuppressResponse = true,
[1684230723.665540][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230723.665544][6292:6294] CHIP:DMG: }
[1684230723.665927][6292:6294] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1684230723.665955][6292:6294] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1684230723.665964][6292:6294] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1684230723.665973][6292:6294] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1684230723.665979][6292:6294] CHIP:CTL: Arming failsafe (60 seconds)
[1684230723.666000][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230723.666014][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230723.666041][6292:6294] CHIP:EM: <<< [E:36614i S:1813 M:185546709] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230723.666051][6292:6294] CHIP:IN: (S) Sending msg 185546709 on secure session with LSID: 1813
[1684230723.666175][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230723.753231][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230723.755807][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.755858][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230723.755928][6292:6294] CHIP:EM: >>> [E:36614i S:1813 M:68342279] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230723.755941][6292:6294] CHIP:EM: Found matching exchange: 36614i, Delegate: 0x7fc59c002c08
[1684230723.755953][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230723.755973][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230723.755978][6292:6294] CHIP:DMG: {
[1684230723.755985][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230723.755990][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230723.756000][6292:6294] CHIP:DMG: [
[1684230723.756006][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230723.756018][6292:6294] CHIP:DMG: {
[1684230723.756025][6292:6294] CHIP:DMG: CommandDataIB =
[1684230723.756033][6292:6294] CHIP:DMG: {
[1684230723.756038][6292:6294] CHIP:DMG: CommandPathIB =
[1684230723.756044][6292:6294] CHIP:DMG: {
[1684230723.756050][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230723.756056][6292:6294] CHIP:DMG: ClusterId = 0x30,
[1684230723.756061][6292:6294] CHIP:DMG: CommandId = 0x1,
[1684230723.756066][6292:6294] CHIP:DMG: },
[1684230723.756072][6292:6294] CHIP:DMG:
[1684230723.756078][6292:6294] CHIP:DMG: CommandFields =
[1684230723.756083][6292:6294] CHIP:DMG: {
[1684230723.756091][6292:6294] CHIP:DMG: 0x0 = 0,
[1684230723.756099][6292:6294] CHIP:DMG: 0x1 = "" (0 chars),
[1684230723.756106][6292:6294] CHIP:DMG: },
[1684230723.756110][6292:6294] CHIP:DMG: },
[1684230723.756118][6292:6294] CHIP:DMG:
[1684230723.756122][6292:6294] CHIP:DMG: },
[1684230723.756130][6292:6294] CHIP:DMG:
[1684230723.756134][6292:6294] CHIP:DMG: ],
[1684230723.756142][6292:6294] CHIP:DMG:
[1684230723.756147][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230723.756150][6292:6294] CHIP:DMG: },
[1684230723.756176][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1684230723.756197][6292:6294] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1684230723.756205][6292:6294] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1684230723.756210][6292:6294] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1684230723.756217][6292:6294] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1684230723.756221][6292:6294] CHIP:CTL: Setting Regulatory Config
[1684230723.756225][6292:6294] CHIP:CTL: Device does not support configurable regulatory location
[1684230723.756245][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230723.756258][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230723.756285][6292:6294] CHIP:EM: <<< [E:36615i S:1813 M:185546710] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230723.756296][6292:6294] CHIP:IN: (S) Sending msg 185546710 on secure session with LSID: 1813
[1684230723.756435][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230723.756471][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230723.843455][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230723.846226][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.846316][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230723.846403][6292:6294] CHIP:EM: >>> [E:36615i S:1813 M:68342280] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230723.846420][6292:6294] CHIP:EM: Found matching exchange: 36615i, Delegate: 0x7fc594020e18
[1684230723.846438][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230723.846467][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230723.846475][6292:6294] CHIP:DMG: {
[1684230723.846484][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230723.846493][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230723.846511][6292:6294] CHIP:DMG: [
[1684230723.846517][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230723.846535][6292:6294] CHIP:DMG: {
[1684230723.846542][6292:6294] CHIP:DMG: CommandDataIB =
[1684230723.846555][6292:6294] CHIP:DMG: {
[1684230723.846566][6292:6294] CHIP:DMG: CommandPathIB =
[1684230723.846578][6292:6294] CHIP:DMG: {
[1684230723.846590][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230723.846602][6292:6294] CHIP:DMG: ClusterId = 0x30,
[1684230723.846612][6292:6294] CHIP:DMG: CommandId = 0x3,
[1684230723.846622][6292:6294] CHIP:DMG: },
[1684230723.846637][6292:6294] CHIP:DMG:
[1684230723.846646][6292:6294] CHIP:DMG: CommandFields =
[1684230723.846660][6292:6294] CHIP:DMG: {
[1684230723.846672][6292:6294] CHIP:DMG: 0x0 = 0,
[1684230723.846685][6292:6294] CHIP:DMG: 0x1 = "" (0 chars),
[1684230723.846696][6292:6294] CHIP:DMG: },
[1684230723.846704][6292:6294] CHIP:DMG: },
[1684230723.846721][6292:6294] CHIP:DMG:
[1684230723.846728][6292:6294] CHIP:DMG: },
[1684230723.846744][6292:6294] CHIP:DMG:
[1684230723.846750][6292:6294] CHIP:DMG: ],
[1684230723.846766][6292:6294] CHIP:DMG:
[1684230723.846774][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230723.846781][6292:6294] CHIP:DMG: },
[1684230723.846826][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1684230723.846857][6292:6294] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1684230723.846870][6292:6294] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1684230723.846878][6292:6294] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1684230723.846890][6292:6294] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1684230723.846897][6292:6294] CHIP:CTL: Sending request for PAI certificate
[1684230723.846905][6292:6294] CHIP:CTL: Sending Certificate Chain request to 0x7fc594023f00 device
[1684230723.846936][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230723.846947][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230723.846983][6292:6294] CHIP:EM: <<< [E:36616i S:1813 M:185546711] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230723.846997][6292:6294] CHIP:IN: (S) Sending msg 185546711 on secure session with LSID: 1813
[1684230723.847222][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230723.847266][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230723.932799][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230723.978176][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230723.978235][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.075305][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.075412][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.160492][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.160604][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.160716][6292:6294] CHIP:EM: >>> [E:36616i S:1813 M:68342281] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230724.160738][6292:6294] CHIP:EM: Found matching exchange: 36616i, Delegate: 0x7fc59c002c08
[1684230724.160758][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230724.160791][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230724.160800][6292:6294] CHIP:DMG: {
[1684230724.160809][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230724.160819][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230724.160835][6292:6294] CHIP:DMG: [
[1684230724.160843][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230724.160857][6292:6294] CHIP:DMG: {
[1684230724.160865][6292:6294] CHIP:DMG: CommandDataIB =
[1684230724.160876][6292:6294] CHIP:DMG: {
[1684230724.160884][6292:6294] CHIP:DMG: CommandPathIB =
[1684230724.160895][6292:6294] CHIP:DMG: {
[1684230724.160906][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230724.160918][6292:6294] CHIP:DMG: ClusterId = 0x3e,
[1684230724.160936][6292:6294] CHIP:DMG: CommandId = 0x3,
[1684230724.160945][6292:6294] CHIP:DMG: },
[1684230724.160957][6292:6294] CHIP:DMG:
[1684230724.160966][6292:6294] CHIP:DMG: CommandFields =
[1684230724.160976][6292:6294] CHIP:DMG: {
[1684230724.160987][6292:6294] CHIP:DMG: 0x0 = [
[1684230724.161075][6292:6294] CHIP:DMG: 0x30, 0x82, 0x01, 0xcb, 0x30, 0x82, 0x01, 0x71, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x56, 0xad, 0x82, 0x22, 0xad, 0x94, 0x5b, 0x64, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x41, 0x9a, 0x93, 0x15, 0xc2, 0x17, 0x3e, 0x0c, 0x8c, 0x87, 0x6d, 0x03, 0xcc, 0xfc, 0x94, 0x48, 0x52, 0x64, 0x7f, 0x7f, 0xec, 0x5e, 0x50, 0x82, 0xf4, 0x05, 0x99, 0x28, 0xec, 0xa8, 0x94, 0xc5, 0x94, 0x15, 0x13, 0x09, 0xac, 0x63, 0x1e, 0x4c, 0xb0, 0x33, 0x92, 0xaf, 0x68, 0x4b, 0x0b, 0xaf, 0xb7, 0xe6, 0x5b, 0x3b, 0x81, 0x62, 0xc2, 0xf5, 0x2b, 0xf9, 0x31, 0xb8, 0xe7, 0x7a, 0xaa, 0x82, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x
[1684230724.161112][6292:6294] CHIP:DMG: ] (463 bytes)
[1684230724.161124][6292:6294] CHIP:DMG: },
[1684230724.161132][6292:6294] CHIP:DMG: },
[1684230724.161146][6292:6294] CHIP:DMG:
[1684230724.161154][6292:6294] CHIP:DMG: },
[1684230724.161169][6292:6294] CHIP:DMG:
[1684230724.161176][6292:6294] CHIP:DMG: ],
[1684230724.161191][6292:6294] CHIP:DMG:
[1684230724.161199][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230724.161207][6292:6294] CHIP:DMG: },
[1684230724.161257][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1684230724.161274][6292:6294] CHIP:CTL: Received certificate chain from the device
[1684230724.161290][6292:6294] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1684230724.161301][6292:6294] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1684230724.161313][6292:6294] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1684230724.161321][6292:6294] CHIP:CTL: Sending request for DAC certificate
[1684230724.161328][6292:6294] CHIP:CTL: Sending Certificate Chain request to 0x7fc594023f00 device
[1684230724.161362][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230724.161374][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230724.161449][6292:6294] CHIP:EM: <<< [E:36617i S:1813 M:185546712] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230724.161475][6292:6294] CHIP:IN: (S) Sending msg 185546712 on secure session with LSID: 1813
[1684230724.161715][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230724.161772][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230724.293522][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230724.345272][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.345372][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.435132][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.435251][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.521386][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.521505][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.521606][6292:6294] CHIP:EM: >>> [E:36617i S:1813 M:68342282] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230724.521628][6292:6294] CHIP:EM: Found matching exchange: 36617i, Delegate: 0x7fc59c061058
[1684230724.521646][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230724.521677][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230724.521686][6292:6294] CHIP:DMG: {
[1684230724.521695][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230724.521704][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230724.521722][6292:6294] CHIP:DMG: [
[1684230724.521730][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230724.521744][6292:6294] CHIP:DMG: {
[1684230724.521756][6292:6294] CHIP:DMG: CommandDataIB =
[1684230724.521767][6292:6294] CHIP:DMG: {
[1684230724.521775][6292:6294] CHIP:DMG: CommandPathIB =
[1684230724.521786][6292:6294] CHIP:DMG: {
[1684230724.521797][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230724.521808][6292:6294] CHIP:DMG: ClusterId = 0x3e,
[1684230724.521818][6292:6294] CHIP:DMG: CommandId = 0x3,
[1684230724.521827][6292:6294] CHIP:DMG: },
[1684230724.521838][6292:6294] CHIP:DMG:
[1684230724.521847][6292:6294] CHIP:DMG: CommandFields =
[1684230724.521857][6292:6294] CHIP:DMG: {
[1684230724.521869][6292:6294] CHIP:DMG: 0x0 = [
[1684230724.521957][6292:6294] CHIP:DMG: 0x30, 0x82, 0x01, 0xe8, 0x30, 0x82, 0x01, 0x8e, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x6f, 0xdc, 0xb6, 0xed, 0x06, 0xf3, 0x58, 0xf9, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x3d, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x50, 0x41, 0x49, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x20, 0x6e, 0x6f, 0x20, 0x50, 0x49, 0x44, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x32, 0x30, 0x32, 0x30, 0x35, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x53, 0x31, 0x25, 0x30, 0x23, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1c, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x78, 0x46, 0x46, 0x46, 0x31, 0x2f, 0x30, 0x78, 0x38, 0x30, 0x30, 0x35, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x35, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x7e, 0xf2, 0xf1, 0x08, 0x2b, 0x2a, 0x56, 0x4a, 0x05, 0x44, 0xc0, 0xa6, 0x13, 0xd2, 0x1b, 0x15, 0x75, 0x00, 0x55, 0x2d, 0x03, 0x5f, 0x23, 0x02, 0x25, 0x2f, 0xce, 0xe8, 0x1d, 0x6e, 0xc6, 0x74, 0x17, 0x34, 0x18, 0xa9, 0x4a, 0x88, 0xdb, 0x
[1684230724.521996][6292:6294] CHIP:DMG: ] (492 bytes)
[1684230724.522006][6292:6294] CHIP:DMG: },
[1684230724.522014][6292:6294] CHIP:DMG: },
[1684230724.522028][6292:6294] CHIP:DMG:
[1684230724.522036][6292:6294] CHIP:DMG: },
[1684230724.522052][6292:6294] CHIP:DMG:
[1684230724.522059][6292:6294] CHIP:DMG: ],
[1684230724.522075][6292:6294] CHIP:DMG:
[1684230724.522083][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230724.522092][6292:6294] CHIP:DMG: },
[1684230724.522143][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1684230724.522160][6292:6294] CHIP:CTL: Received certificate chain from the device
[1684230724.522173][6292:6294] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1684230724.522184][6292:6294] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1684230724.522195][6292:6294] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1684230724.522201][6292:6294] CHIP:CTL: Sending Attestation Request to the device.
[1684230724.522206][6292:6294] CHIP:CTL: Sending Attestation request to 0x7fc594023f00 device
[1684230724.522254][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230724.522265][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230724.522305][6292:6294] CHIP:EM: <<< [E:36618i S:1813 M:185546713] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230724.522321][6292:6294] CHIP:IN: (S) Sending msg 185546713 on secure session with LSID: 1813
[1684230724.522584][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230724.522599][6292:6294] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
[1684230724.522622][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230724.608623][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230724.659927][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.659991][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.749989][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.750064][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.839896][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230724.839995][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230724.840087][6292:6294] CHIP:EM: >>> [E:36618i S:1813 M:68342283] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230724.840107][6292:6294] CHIP:EM: Found matching exchange: 36618i, Delegate: 0x7fc59c061318
[1684230724.840128][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230724.840161][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230724.840170][6292:6294] CHIP:DMG: {
[1684230724.840179][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230724.840188][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230724.840204][6292:6294] CHIP:DMG: [
[1684230724.840212][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230724.840230][6292:6294] CHIP:DMG: {
[1684230724.840239][6292:6294] CHIP:DMG: CommandDataIB =
[1684230724.840251][6292:6294] CHIP:DMG: {
[1684230724.840259][6292:6294] CHIP:DMG: CommandPathIB =
[1684230724.840270][6292:6294] CHIP:DMG: {
[1684230724.840281][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230724.840291][6292:6294] CHIP:DMG: ClusterId = 0x3e,
[1684230724.840305][6292:6294] CHIP:DMG: CommandId = 0x1,
[1684230724.840314][6292:6294] CHIP:DMG: },
[1684230724.840327][6292:6294] CHIP:DMG:
[1684230724.840336][6292:6294] CHIP:DMG: CommandFields =
[1684230724.840347][6292:6294] CHIP:DMG: {
[1684230724.840358][6292:6294] CHIP:DMG: 0x0 = [
[1684230724.840453][6292:6294] CHIP:DMG: 0x15, 0x31, 0x01, 0x1b, 0x02, 0x30, 0x82, 0x02, 0x17, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x08, 0x30, 0x82, 0x02, 0x04, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x70, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x61, 0x04, 0x82, 0x01, 0x5d, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
[1684230724.840510][6292:6294] CHIP:DMG: ] (583 bytes)
[1684230724.840524][6292:6294] CHIP:DMG: 0x1 = [
[1684230724.840562][6292:6294] CHIP:DMG: 0x95, 0xb0, 0xbf, 0xff, 0xe9, 0x86, 0xb2, 0x65, 0x9d, 0x5c, 0xac, 0xc4, 0xf7, 0xcc, 0xb8, 0x45, 0x28, 0x45, 0x7f, 0x86, 0xd4, 0xa1, 0x0b, 0xed, 0x0e, 0x5c, 0xb1, 0x7a, 0x87, 0x8b, 0x57, 0xbc, 0x8b, 0x36, 0xf6, 0x21, 0x80, 0xe0, 0x9e, 0xea, 0x68, 0x78, 0xf2, 0x83, 0x9e, 0xc2, 0x68, 0xec, 0x09, 0xb2, 0xb0, 0x23, 0x0c, 0xd4, 0x17, 0xc9, 0xc3, 0x7a, 0x1a, 0xeb, 0xc5, 0x7d, 0xcc, 0x3e,
[1684230724.840579][6292:6294] CHIP:DMG: ] (64 bytes)
[1684230724.840589][6292:6294] CHIP:DMG: },
[1684230724.840597][6292:6294] CHIP:DMG: },
[1684230724.840614][6292:6294] CHIP:DMG:
[1684230724.840621][6292:6294] CHIP:DMG: },
[1684230724.840637][6292:6294] CHIP:DMG:
[1684230724.840644][6292:6294] CHIP:DMG: ],
[1684230724.840661][6292:6294] CHIP:DMG:
[1684230724.840669][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230724.840677][6292:6294] CHIP:DMG: },
[1684230724.840731][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1684230724.840750][6292:6294] CHIP:CTL: Received Attestation Information from the device
[1684230724.840763][6292:6294] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1684230724.840773][6292:6294] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 583/583
[1684230724.840797][6292:6294] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1684230724.840811][6292:6294] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1684230724.840816][6292:6294] CHIP:CTL: Verifying attestation
[1684230724.844947][6292:6294] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
[1684230724.844971][6292:6294] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
[1684230724.844980][6292:6294] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
[1684230724.844991][6292:6294] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
[1684230724.845000][6292:6294] CHIP:CTL: Sending CSR request to 0x7fc594023f00 device
[1684230724.845054][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230724.845074][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230724.845118][6292:6294] CHIP:EM: <<< [E:36619i S:1813 M:185546714] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230724.845135][6292:6294] CHIP:IN: (S) Sending msg 185546714 on secure session with LSID: 1813
[1684230724.845374][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230724.845389][6292:6294] CHIP:CTL: Sent CSR request, waiting for the CSR
[1684230724.845453][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230724.923799][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230725.200157][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230725.200230][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230725.288004][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230725.288103][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230725.288199][6292:6294] CHIP:EM: >>> [E:36619i S:1813 M:68342284] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230725.288220][6292:6294] CHIP:EM: Found matching exchange: 36619i, Delegate: 0x7fc59c061478
[1684230725.288240][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230725.288276][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230725.288286][6292:6294] CHIP:DMG: {
[1684230725.288296][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230725.288307][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230725.288328][6292:6294] CHIP:DMG: [
[1684230725.288336][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230725.288352][6292:6294] CHIP:DMG: {
[1684230725.288361][6292:6294] CHIP:DMG: CommandDataIB =
[1684230725.288371][6292:6294] CHIP:DMG: {
[1684230725.288380][6292:6294] CHIP:DMG: CommandPathIB =
[1684230725.288393][6292:6294] CHIP:DMG: {
[1684230725.288405][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230725.288416][6292:6294] CHIP:DMG: ClusterId = 0x3e,
[1684230725.288428][6292:6294] CHIP:DMG: CommandId = 0x5,
[1684230725.288438][6292:6294] CHIP:DMG: },
[1684230725.288451][6292:6294] CHIP:DMG:
[1684230725.288461][6292:6294] CHIP:DMG: CommandFields =
[1684230725.288471][6292:6294] CHIP:DMG: {
[1684230725.288484][6292:6294] CHIP:DMG: 0x0 = [
[1684230725.288566][6292:6294] CHIP:DMG: 0x15, 0x30, 0x01, 0xce, 0x30, 0x81, 0xcb, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x9a, 0x8b, 0x14, 0xdc, 0x68, 0x21, 0x0b, 0x10, 0xc2, 0x84, 0x69, 0x65, 0xff, 0xd6, 0xcc, 0x3c, 0x1f, 0xfa, 0x37, 0xaa, 0xbc, 0x7c, 0xb8, 0x0f, 0xa1, 0x5d, 0xaa, 0xd7, 0xc0, 0x97, 0xc4, 0xbb, 0xa7, 0x2a, 0xb6, 0x5b, 0x52, 0x1e, 0xf0, 0x26, 0xb0, 0x2e, 0x95, 0xf7, 0xb5, 0x45, 0xc7, 0xf8, 0xd0, 0xcc, 0x4c, 0xd2, 0x25, 0x58, 0x07, 0x0d, 0x13, 0x2f, 0x1f, 0x60, 0x59, 0x4d, 0xfa, 0x74, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x49, 0x00, 0x30, 0x46, 0x02, 0x21, 0x00, 0xda, 0x2f, 0x62, 0x33, 0x7a, 0x3e, 0x12, 0x23, 0x61, 0x11, 0xd2, 0x3d, 0xb4, 0x55, 0x93, 0x40, 0xdf, 0xb1, 0x3e, 0x63, 0x70, 0x47, 0x04, 0xf4, 0x25, 0x4e, 0x56, 0xc9, 0xf7, 0x00, 0xfb, 0xf6, 0x02, 0x21, 0x00, 0x98, 0xa7, 0x94, 0xac, 0xb6, 0x86, 0xa7, 0xc7, 0x4f, 0xbd, 0xee, 0xde, 0x5d, 0xdf, 0xb9, 0x07, 0x5b, 0xd1, 0x09, 0xbf, 0x29, 0xff, 0xd6, 0x2f, 0x7f, 0x17, 0xa7, 0x60, 0xe5, 0x24, 0xef, 0x4b, 0x30, 0x02, 0x20, 0x8e, 0x94, 0x54, 0x13, 0xe7, 0xfa, 0x23, 0x4a, 0x51, 0xfe, 0xab, 0xc1, 0x41, 0x45, 0xf5, 0x16, 0xea, 0x49, 0x6b, 0x00, 0x5f, 0xc6, 0x21, 0x92, 0x2e, 0xe2, 0x77, 0xec, 0xf4, 0x51, 0x5b, 0xaf, 0x18,
[1684230725.288603][6292:6294] CHIP:DMG: ] (246 bytes)
[1684230725.288614][6292:6294] CHIP:DMG: 0x1 = [
[1684230725.288641][6292:6294] CHIP:DMG: 0x50, 0xf8, 0x21, 0x2b, 0x30, 0xb4, 0xf3, 0x8e, 0xd9, 0x52, 0x7a, 0x0c, 0xb2, 0x34, 0x24, 0xfc, 0x23, 0x99, 0xdf, 0xe2, 0xb0, 0x68, 0x6a, 0x0a, 0x78, 0xf8, 0x37, 0x0e, 0xc5, 0x69, 0x76, 0xee, 0x33, 0x8c, 0x67, 0x75, 0x82, 0x08, 0xa0, 0x85, 0xb3, 0x4c, 0x62, 0xcf, 0xe8, 0x43, 0x0e, 0xf0, 0x9f, 0x53, 0xd6, 0x8d, 0x48, 0xf5, 0xaa, 0xcf, 0x7f, 0x71, 0xea, 0x23, 0x57, 0x57, 0xf2, 0xb5,
[1684230725.288658][6292:6294] CHIP:DMG: ] (64 bytes)
[1684230725.288669][6292:6294] CHIP:DMG: },
[1684230725.288679][6292:6294] CHIP:DMG: },
[1684230725.288696][6292:6294] CHIP:DMG:
[1684230725.288704][6292:6294] CHIP:DMG: },
[1684230725.288722][6292:6294] CHIP:DMG:
[1684230725.288730][6292:6294] CHIP:DMG: ],
[1684230725.288748][6292:6294] CHIP:DMG:
[1684230725.288757][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230725.288764][6292:6294] CHIP:DMG: },
[1684230725.288820][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
[1684230725.288841][6292:6294] CHIP:CTL: Received certificate signing request from the device
[1684230725.288858][6292:6294] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
[1684230725.288869][6292:6294] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
[1684230725.288882][6292:6294] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
[1684230725.289815][6292:6294] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
[1684230725.289832][6292:6294] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
[1684230725.289843][6292:6294] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
[1684230725.289853][6292:6294] CHIP:CTL: Getting certificate chain for the device from the issuer
[1684230725.290042][6292:6294] CHIP:CTL: Verifying Certificate Signing Request
[1684230725.290672][6292:6294] CHIP:CTL: Generating NOC
[1684230725.290883][6292:6294] CHIP:CTL: Providing certificate chain to the commissioner
[1684230725.290894][6292:6294] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
[1684230725.290904][6292:6294] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
[1684230725.291010][6292:6294] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
[1684230725.291016][6292:6294] CHIP:CTL: Sending root certificate to the device
[1684230725.291041][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230725.291060][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230725.291092][6292:6294] CHIP:EM: <<< [E:36620i S:1813 M:185546715] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230725.291105][6292:6294] CHIP:IN: (S) Sending msg 185546715 on secure session with LSID: 1813
[1684230725.291361][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230725.291374][6292:6294] CHIP:CTL: Sent root certificate to the device
[1684230725.291492][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230725.418751][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230725.508634][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230725.600998][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230725.601109][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230725.601242][6292:6294] CHIP:EM: >>> [E:36620i S:1813 M:68342285] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230725.601273][6292:6294] CHIP:EM: Found matching exchange: 36620i, Delegate: 0x7fc59c061318
[1684230725.601298][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230725.601335][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230725.601345][6292:6294] CHIP:DMG: {
[1684230725.601355][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230725.601363][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230725.601386][6292:6294] CHIP:DMG: [
[1684230725.601418][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230725.601442][6292:6294] CHIP:DMG: {
[1684230725.601454][6292:6294] CHIP:DMG: CommandStatusIB =
[1684230725.601468][6292:6294] CHIP:DMG: {
[1684230725.601480][6292:6294] CHIP:DMG: CommandPathIB =
[1684230725.601495][6292:6294] CHIP:DMG: {
[1684230725.601510][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230725.601525][6292:6294] CHIP:DMG: ClusterId = 0x3e,
[1684230725.601539][6292:6294] CHIP:DMG: CommandId = 0xb,
[1684230725.601553][6292:6294] CHIP:DMG: },
[1684230725.601574][6292:6294] CHIP:DMG:
[1684230725.601586][6292:6294] CHIP:DMG: StatusIB =
[1684230725.601602][6292:6294] CHIP:DMG: {
[1684230725.601617][6292:6294] CHIP:DMG: status = 0x00 (SUCCESS),
[1684230725.601631][6292:6294] CHIP:DMG: },
[1684230725.601647][6292:6294] CHIP:DMG:
[1684230725.601659][6292:6294] CHIP:DMG: },
[1684230725.601679][6292:6294] CHIP:DMG:
[1684230725.601709][6292:6294] CHIP:DMG: },
[1684230725.601720][6292:6294] CHIP:DMG:
[1684230725.601725][6292:6294] CHIP:DMG: ],
[1684230725.601737][6292:6294] CHIP:DMG:
[1684230725.601743][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230725.601748][6292:6294] CHIP:DMG: },
[1684230725.601794][6292:6294] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
[1684230725.601803][6292:6294] CHIP:CTL: Device confirmed that it has received the root certificate
[1684230725.601812][6292:6294] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
[1684230725.601817][6292:6294] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
[1684230725.601825][6292:6294] CHIP:CTL: Performing next commissioning step 'SendNOC'
[1684230725.601853][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230725.601865][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230725.601898][6292:6294] CHIP:EM: <<< [E:36621i S:1813 M:185546716] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230725.601910][6292:6294] CHIP:IN: (S) Sending msg 185546716 on secure session with LSID: 1813
[1684230725.602128][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230725.602149][6292:6294] CHIP:CTL: Sent operational certificate to the device
[1684230725.602181][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230725.733703][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230725.868645][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230725.958519][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230726.184836][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230726.184872][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230726.184915][6292:6294] CHIP:EM: >>> [E:36621i S:1813 M:68342286] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230726.184924][6292:6294] CHIP:EM: Found matching exchange: 36621i, Delegate: 0x7fc59c061478
[1684230726.184931][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230726.184941][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230726.184943][6292:6294] CHIP:DMG: {
[1684230726.184945][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230726.184946][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230726.184951][6292:6294] CHIP:DMG: [
[1684230726.184952][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230726.184958][6292:6294] CHIP:DMG: {
[1684230726.184961][6292:6294] CHIP:DMG: CommandDataIB =
[1684230726.184965][6292:6294] CHIP:DMG: {
[1684230726.184969][6292:6294] CHIP:DMG: CommandPathIB =
[1684230726.184973][6292:6294] CHIP:DMG: {
[1684230726.184977][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230726.184982][6292:6294] CHIP:DMG: ClusterId = 0x3e,
[1684230726.184986][6292:6294] CHIP:DMG: CommandId = 0x8,
[1684230726.184991][6292:6294] CHIP:DMG: },
[1684230726.184996][6292:6294] CHIP:DMG:
[1684230726.184999][6292:6294] CHIP:DMG: CommandFields =
[1684230726.185003][6292:6294] CHIP:DMG: {
[1684230726.185008][6292:6294] CHIP:DMG: 0x0 = 0,
[1684230726.185012][6292:6294] CHIP:DMG: 0x1 = 1,
[1684230726.185016][6292:6294] CHIP:DMG: },
[1684230726.185020][6292:6294] CHIP:DMG: },
[1684230726.185025][6292:6294] CHIP:DMG:
[1684230726.185028][6292:6294] CHIP:DMG: },
[1684230726.185034][6292:6294] CHIP:DMG:
[1684230726.185037][6292:6294] CHIP:DMG: ],
[1684230726.185043][6292:6294] CHIP:DMG:
[1684230726.185046][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230726.185051][6292:6294] CHIP:DMG: },
[1684230726.185068][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
[1684230726.185076][6292:6294] CHIP:CTL: Device returned status 0 on receiving the NOC
[1684230726.185080][6292:6294] CHIP:CTL: Operational credentials provisioned on device 0x7fc594023f00
[1684230726.185083][6292:6294] CHIP:TOO: Secure Pairing Success
[1684230726.185086][6292:6294] CHIP:TOO: CASE establishment successful
[1684230726.185092][6292:6294] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
[1684230726.185096][6292:6294] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
[1684230726.185099][6292:6294] CHIP:CTL: Required network information not provided in commissioning parameters
[1684230726.185102][6292:6294] CHIP:CTL: Parameters supplied: wifi (yes) thread (no)
[1684230726.185105][6292:6294] CHIP:CTL: Device supports: wifi (no) thread(yes)
[1684230726.185111][6292:6294] CHIP:CTL: Going from commissioning step 'SendNOC' with lastErr = 'src/controller/AutoCommissioner.cpp:218: CHIP Error 0x0000002F: Invalid argument' -> 'Cleanup'
[1684230726.185117][6292:6294] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = 'src/controller/AutoCommissioner.cpp:218: CHIP Error 0x0000002F: Invalid argument'
[1684230726.185121][6292:6294] CHIP:CTL: Expiring failsafe on proxy 0x7fc594023f00
[1684230726.185136][6292:6294] CHIP:DMG: ICR moving to [AddingComm]
[1684230726.185140][6292:6294] CHIP:DMG: ICR moving to [AddedComma]
[1684230726.185159][6292:6294] CHIP:EM: <<< [E:36622i S:1813 M:185546717] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1684230726.185166][6292:6294] CHIP:IN: (S) Sending msg 185546717 on secure session with LSID: 1813
[1684230726.185232][6292:6294] CHIP:DMG: ICR moving to [CommandSen]
[1684230726.185247][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230726.273296][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1684230726.275716][6292:6293] CHIP:DL: Indication received, conn = 0x7fc59c03bd20
[1684230726.275767][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1684230726.275830][6292:6294] CHIP:EM: >>> [E:36622i S:1813 M:68342287] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1684230726.275842][6292:6294] CHIP:EM: Found matching exchange: 36622i, Delegate: 0x7fc59c061318
[1684230726.275851][6292:6294] CHIP:DMG: ICR moving to [ResponseRe]
[1684230726.275875][6292:6294] CHIP:DMG: InvokeResponseMessage =
[1684230726.275881][6292:6294] CHIP:DMG: {
[1684230726.275887][6292:6294] CHIP:DMG: suppressResponse = false,
[1684230726.275892][6292:6294] CHIP:DMG: InvokeResponseIBs =
[1684230726.275902][6292:6294] CHIP:DMG: [
[1684230726.275906][6292:6294] CHIP:DMG: InvokeResponseIB =
[1684230726.275915][6292:6294] CHIP:DMG: {
[1684230726.275919][6292:6294] CHIP:DMG: CommandDataIB =
[1684230726.275924][6292:6294] CHIP:DMG: {
[1684230726.275928][6292:6294] CHIP:DMG: CommandPathIB =
[1684230726.275934][6292:6294] CHIP:DMG: {
[1684230726.275940][6292:6294] CHIP:DMG: EndpointId = 0x0,
[1684230726.275947][6292:6294] CHIP:DMG: ClusterId = 0x30,
[1684230726.275953][6292:6294] CHIP:DMG: CommandId = 0x1,
[1684230726.275958][6292:6294] CHIP:DMG: },
[1684230726.275964][6292:6294] CHIP:DMG:
[1684230726.275969][6292:6294] CHIP:DMG: CommandFields =
[1684230726.275974][6292:6294] CHIP:DMG: {
[1684230726.275980][6292:6294] CHIP:DMG: 0x0 = 0,
[1684230726.275986][6292:6294] CHIP:DMG: 0x1 = "" (0 chars),
[1684230726.275992][6292:6294] CHIP:DMG: },
[1684230726.275997][6292:6294] CHIP:DMG: },
[1684230726.276005][6292:6294] CHIP:DMG:
[1684230726.276009][6292:6294] CHIP:DMG: },
[1684230726.276017][6292:6294] CHIP:DMG:
[1684230726.276021][6292:6294] CHIP:DMG: ],
[1684230726.276029][6292:6294] CHIP:DMG:
[1684230726.276034][6292:6294] CHIP:DMG: InteractionModelRevision = 1
[1684230726.276038][6292:6294] CHIP:DMG: },
[1684230726.276063][6292:6294] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1684230726.276074][6292:6294] CHIP:CTL: Failsafe disarmed
[1684230726.276083][6292:6294] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1684230726.276095][6292:6294] CHIP:TOO: Device commissioning Failure: src/controller/AutoCommissioner.cpp:218: CHIP Error 0x0000002F: Invalid argument
[1684230726.276108][6292:6294] CHIP:DIS: Closing all BLE connections
[1684230726.276112][6292:6294] CHIP:IN: Clearing BLE pending packets.
[1684230726.276220][6292:6294] CHIP:BLE: Auto-closing end point's BLE connection.
[1684230726.276229][6292:6294] CHIP:DL: Closing BLE GATT connection (con 0x7fc59c03bd20)
[1684230726.276251][6292:6293] CHIP:DL: BluezDisconnect peer=FA:97:EA:11:13:83
[1684230726.364557][6292:6294] CHIP:IN: SecureSession[0x7fc594021970]: MarkForEviction Type:1 LSID:1813
[1684230726.364577][6292:6294] CHIP:SC: SecureSession[0x7fc594021970, LSID:1813]: State change 'kActive' --> 'kPendingEviction'
[1684230726.364871][6292:6294] CHIP:DMG: ICR moving to [AwaitingDe]
[1684230726.364896][6292:6294] CHIP:IN: SecureSession[0x7fc594021970]: Released - Type:1 LSID:1813
[1684230726.364916][6292:6294] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1684230726.364924][6292:6294] CHIP:BLE: no endpoint for unsub complete
[1684230726.364934][6292:6293] CHIP:DL: Bluez disconnected
[1684230726.364951][6292:6293] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1684230726.365038][6292:6292] CHIP:CTL: Shutting down the commissioner
[1684230726.365051][6292:6292] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1684230726.365086][6292:6292] CHIP:CTL: Shutting down the controller
[1684230726.365096][6292:6292] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1684230726.365104][6292:6292] CHIP:FP: Forgetting fabric 0x1
[1684230726.365117][6292:6292] CHIP:TS: Pending Last Known Good Time: 2023-05-15T15:02:24
[1684230726.365227][6292:6292] CHIP:TS: Previous Last Known Good Time: 2023-05-15T15:02:24
[1684230726.365236][6292:6292] CHIP:TS: Reverted Last Known Good Time to previous value
[1684230726.365255][6292:6292] CHIP:CTL: Shutting down the commissioner
[1684230726.365264][6292:6292] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1684230726.365287][6292:6292] CHIP:CTL: Shutting down the controller
[1684230726.365293][6292:6292] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1684230726.365349][6292:6292] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1684230726.365374][6292:6292] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1684230726.365388][6292:6292] CHIP:FP: Shutting down FabricTable
[1684230726.365412][6292:6292] CHIP:TS: Pending Last Known Good Time: 2023-05-15T15:02:24
[1684230726.365472][6292:6292] CHIP:TS: Previous Last Known Good Time: 2023-05-15T15:02:24
[1684230726.365480][6292:6292] CHIP:TS: Reverted Last Known Good Time to previous value
[1684230726.365603][6292:6292] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-CnETlW)
[1684230726.365830][6292:6292] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1684230726.365852][6292:6292] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1684230726.365861][6292:6292] CHIP:DL: Inet Layer shutdown
[1684230726.365869][6292:6292] CHIP:DL: BLE shutdown
[1684230726.366460][6292:6292] CHIP:DL: System Layer shutdown
[1684230726.366609][6292:6292] CHIP:TOO: Run command failure: src/controller/AutoCommissioner.cpp:218: CHIP Error 0x0000002F: Invalid argument
so, is that possible that my pc bluez version which is 5.53 create a problem.
hello,
this are nrf sniffer logs and my nrf device name is d2:52:6a:67:61:fd
No. Time Source PHY Protocol Length Delta time (\302\265s end to start) SN NESN More Data Event counter Info New Column 1 0 77:c6:0a:3c:ae:be LE 1M LE LL 25 0 ADV_IND 2 0 77:c6:0a:3c:ae:be LE 1M LE LL 25 478\302\265s 0 ADV_IND 3 0 77:c6:0a:3c:ae:be LE 1M LE LL 25 736\302\265s 0 ADV_IND 4 0 7d:30:e4:59:cd:06 LE 1M LE LL 25 2974\302\265s 0 ADV_IND 5 0 49:08:83:d3:3a:6c LE 1M LE LL 12 799\302\265s 0 SCAN_REQ 6 0 d6:bf:76:0a:0b:dc LE 1M LE LL 36 2525\302\265s 0 ADV_IND 7 0 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4519\302\265s 0 ADV_NONCONN_IND 8 0 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9 0 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 10 0.015 d2:52:6a:67:61:fd LE 1M LE LL 21 380\302\265s 0 ADV_IND 11 0.015 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 12 0.015 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 13 0.015 43:bd:56:bd:74:f9 LE 1M LE LL 37 6680\302\265s 0 ADV_NONCONN_IND 14 0.015 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 15 0.015 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 16 0.015 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1979\302\265s 0 ADV_NONCONN_IND 17 0.015 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 18 0.015 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 19 0.015 5c:9e:d4:03:82:5b LE 1M LE LL 37 600\302\265s 0 ADV_NONCONN_IND 20 0.015 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 21 0.031 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 22 0.031 64:0d:49:f9:4d:a4 LE 1M LE LL 12 3397\302\265s 0 SCAN_REQ 23 0.031 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 24 0.031 71:c4:79:42:57:d8 LE 1M LE LL 37 369\302\265s 0 ADV_IND 25 0.031 d2:52:6a:67:61:fd LE 1M LE LL 21 1873\302\265s 0 ADV_IND 26 0.031 c5:65:68:79:19:c8 LE 1M LE LL 36 725\302\265s 0 ADV_IND 27 0.031 2e:86:8d:c9:47:bd LE 1M LE LL 21 387\302\265s 0 ADV_NONCONN_IND 28 0.031 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2408\302\265s 0 ADV_NONCONN_IND 29 0.031 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 30 0.031 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 31 0.031 d6:2c:05:d0:15:49 LE 1M LE LL 37 132\302\265s 0 ADV_IND 32 0.031 69:a9:48:2f:b7:16 LE 1M LE LL 37 2701\302\265s 0 ADV_NONCONN_IND 33 0.031 3a:d1:ca:1d:4d:de LE 1M LE LL 26 597\302\265s 0 ADV_NONCONN_IND 34 0.031 31:ea:1b:25:0d:1f LE 1M LE LL 37 3181\302\265s 0 ADV_NONCONN_IND 35 0.046 31:ea:1b:25:0d:1f LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 36 0.046 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 37 0.046 d4:44:a3:07:d8:8f LE 1M LE LL 34 2980\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 38 0.046 SamsungE_07:d8:8f LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 39 0.046 SamsungE_07:d8:8f LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 40 0.046 d5:80:ce:3a:df:84 LE 1M LE LL 36 2174\302\265s 0 ADV_IND 41 0.046 d5:80:ce:3a:df:84 LE 1M LE LL 36 740\302\265s 0 ADV_IND 42 0.046 d5:80:ce:3a:df:84 LE 1M LE LL 36 741\302\265s 0 ADV_IND 43 0.046 d2:52:6a:67:61:fd LE 1M LE LL 19 210\302\265s 0 SCAN_RSP 44 0.046 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 45 0.046 32:43:3c:28:8d:92 LE 1M LE LL 37 280\302\265s 0 ADV_NONCONN_IND 46 0.046 cc:15:14:59:64:aa LE 1M LE LL 36 314\302\265s 0 ADV_IND 47 0.046 cc:15:14:59:64:aa LE 1M LE LL 36 351\302\265s 0 ADV_IND 48 0.046 cc:15:14:59:64:aa LE 1M LE LL 36 352\302\265s 0 ADV_IND 49 0.062 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1575\302\265s 0 SCAN_REQ 50 0.062 1e:28:49:84:c5:cd LE 1M LE LL 37 10298\302\265s 0 ADV_NONCONN_IND 51 0.062 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 52 0.062 58:a9:3f:be:99:29 LE 1M LE LL 6 371\302\265s 0 SCAN_RSP 53 0.062 58:a9:3f:be:99:29 LE 1M LE LL 23 133\302\265s 0 SCAN_RSP 54 0.062 58:a9:3f:be:99:29 LE 1M LE LL 23 367\302\265s 0 ADV_IND 55 0.062 0d:62:2c:2a:24:88 LE 1M LE LL 37 839\302\265s 0 ADV_NONCONN_IND 56 0.062 0d:62:2c:2a:24:88 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 57 0.062 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 58 0.062 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3756\302\265s 0 ADV_NONCONN_IND 59 0.062 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 60 0.062 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 61 0.062 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 2122\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 62 0.062 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 63 0.078 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 64 0.078 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2041\302\265s 0 ADV_NONCONN_IND 65 0.078 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 66 0.078 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 67 0.078 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3744\302\265s 0 SCAN_REQ 68 0.078 cd:5c:f3:7d:98:0b LE 1M LE LL 36 1009\302\265s 0 ADV_IND 69 0.078 e5:ea:46:16:3e:1e LE 1M LE LL 36 1516\302\265s 0 ADV_IND 70 0.078 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3479\302\265s 0 ADV_NONCONN_IND 71 0.078 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 72 0.078 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 73 0.078 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1869\302\265s 0 SCAN_REQ 74 0.078 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3692\302\265s 0 ADV_NONCONN_IND 75 0.078 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 76 0.089 7f:e1:7b:e4:24:1c LE 1M LE LL 12 6535\302\265s 0 SCAN_REQ 77 0.089 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2358\302\265s 0 ADV_NONCONN_IND 78 0.089 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 79 0.089 74:d9:0b:7a:47:5a LE 1M LE LL 23 1766\302\265s 0 ADV_IND 80 0.089 d2:52:6a:67:61:fd LE 1M LE LL 21 10115\302\265s 0 ADV_IND 81 0.089 5c:9e:d4:03:82:5b LE 1M LE LL 37 722\302\265s 0 ADV_NONCONN_IND 82 0.094 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5108\302\265s 0 ADV_NONCONN_IND 83 0.094 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 84 0.094 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 85 0.094 f1:ff:a7:1a:55:8d LE 1M LE LL 36 358\302\265s 0 ADV_IND 86 0.094 3a:d1:ca:1d:4d:de LE 1M LE LL 26 10209\302\265s 0 ADV_NONCONN_IND 87 0.094 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 88 0.094 31:ea:1b:25:0d:1f LE 1M LE LL 37 1933\302\265s 0 ADV_NONCONN_IND 89 0.094 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 90 0.094 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 91 0.094 d2:52:6a:67:61:fd LE 1M LE LL 21 2878\302\265s 0 ADV_IND 92 0.094 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 93 0.094 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 94 0.094 1e:28:49:84:c5:cd LE 1M LE LL 37 12386\302\265s 0 ADV_NONCONN_IND 95 0.094 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 96 0.094 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 97 0.094 11:fe:ef:ed:38:82 LE 1M LE LL 37 2454\302\265s 0 ADV_NONCONN_IND 98 0.094 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 99 0.094 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 100 0.109 0d:62:2c:2a:24:88 LE 1M LE LL 37 305\302\265s 0 ADV_NONCONN_IND 101 0.109 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 102 0.109 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 103 0.109 d2:52:6a:67:61:fd LE 1M LE LL 21 1122\302\265s 0 ADV_IND 104 0.109 d2:52:6a:67:61:fd LE 1M LE LL 21 1337\302\265s 0 ADV_IND 105 0.109 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 106 0.109 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3589\302\265s 0 ADV_NONCONN_IND 107 0.109 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 108 0.109 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 109 0.109 16:ed:93:0f:fa:b0 LE 1M LE LL 37 221\302\265s 0 ADV_NONCONN_IND 110 0.109 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 111 0.109 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 112 0.109 07:69:22:f0:72:30 LE 1M LE LL 37 6391\302\265s 0 ADV_NONCONN_IND 113 0.109 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 114 0.109 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 115 0.109 LE 1M LE LL 98 5419\302\265s 0 Unknown 116 0.109 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1259\302\265s 0 ADV_IND 117 0.109 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1606\302\265s 0 ADV_NONCONN_IND 118 0.125 24:c3:d0:ce:d4:37 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 119 0.125 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 120 0.125 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 121 0.125 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6981\302\265s 0 ADV_NONCONN_IND 122 0.125 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 123 0.125 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 124 0.125 5c:9e:d4:03:82:5b LE 1M LE LL 37 16869\302\265s 0 ADV_NONCONN_IND 125 0.125 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 126 0.125 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 127 0.125 d2:52:6a:67:61:fd LE 1M LE LL 21 422\302\265s 0 ADV_IND 128 0.125 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 129 0.125 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 130 0.125 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3767\302\265s 0 ADV_NONCONN_IND 131 0.125 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 132 0.125 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 133 0.125 31:ea:1b:25:0d:1f LE 1M LE LL 37 5151\302\265s 0 ADV_NONCONN_IND 134 0.125 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 135 0.125 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 136 0.125 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2301\302\265s 0 ADV_NONCONN_IND 137 0.141 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 138 0.141 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 139 0.141 d2:52:6a:67:61:fd LE 1M LE LL 21 1583\302\265s 0 ADV_IND 140 0.141 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 141 0.141 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 142 0.141 32:43:3c:28:8d:92 LE 1M LE LL 37 131\302\265s 0 ADV_NONCONN_IND 143 0.141 32:43:3c:28:8d:92 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 144 0.141 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 145 0.141 77:c6:0a:3c:ae:be LE 1M LE LL 25 1905\302\265s 0 ADV_IND 146 0.141 77:c6:0a:3c:ae:be LE 1M LE LL 25 368\302\265s 0 ADV_IND 147 0.141 77:c6:0a:3c:ae:be LE 1M LE LL 25 368\302\265s 0 ADV_IND 148 0.141 c0:41:04:2e:be:9d LE 1M LE LL 36 4718\302\265s 0 ADV_IND 149 0.141 cf:4f:81:f5:7d:55 LE 1M LE LL 36 5312\302\265s 0 ADV_IND 150 0.141 cf:4f:81:f5:7d:55 LE 1M LE LL 36 354\302\265s 0 ADV_IND 151 0.141 1e:28:49:84:c5:cd LE 1M LE LL 37 1146\302\265s 0 ADV_NONCONN_IND 152 0.141 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 153 0.141 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 154 0.141 d2:52:6a:67:61:fd LE 1M LE LL 21 452\302\265s 0 ADV_IND 155 0.141 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 156 0.141 0d:62:2c:2a:24:88 LE 1M LE LL 37 4322\302\265s 0 ADV_NONCONN_IND 157 0.141 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4378\302\265s 0 ADV_NONCONN_IND 158 0.156 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 159 0.156 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 160 0.156 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1474\302\265s 0 ADV_NONCONN_IND 161 0.156 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 162 0.156 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 163 0.156 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1283\302\265s 0 ADV_NONCONN_IND 164 0.156 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 165 0.156 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 166 0.156 08:ec:5e:66:cd:0d LE 1M LE LL 23 3407\302\265s 0 ADV_NONCONN_IND 167 0.156 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 168 0.156 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 169 0.156 74:d9:0b:7a:47:5a LE 1M LE LL 23 1601\302\265s 0 ADV_IND 170 0.156 c8:de:06:91:ba:f3 LE 1M LE LL 36 440\302\265s 0 ADV_IND 171 0.156 c8:de:06:91:ba:b3 LE 1M LE LL 36 354\302\265s 0 ADV_IND 172 0.156 24:c3:d0:ce:d4:37 LE 1M LE LL 37 447\302\265s 0 ADV_NONCONN_IND 173 0.156 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 174 0.156 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 175 0.156 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4349\302\265s 0 ADV_NONCONN_IND 176 0.156 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 177 0.156 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 178 0.156 5e:93:36:dd:d3:09 LE 1M LE LL 10 736\302\265s 0 ADV_SCAN_IND 179 0.156 5e:93:36:dd:d3:09 LE 1M LE LL 10 454\302\265s 0 ADV_SCAN_IND 180 0.156 5e:93:36:dd:d3:09 LE 1M LE LL 10 454\302\265s 0 ADV_SCAN_IND 181 0.172 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4010\302\265s 0 ADV_NONCONN_IND 182 0.172 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 183 0.172 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 184 0.172 d2:52:6a:67:61:fd LE 1M LE LL 21 7254\302\265s 0 ADV_IND 185 0.172 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 186 0.172 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 187 0.172 fb:18:78:3b:10:36 LE 1M LE LL 28 2085\302\265s 0 ADV_IND 188 0.172 fb:18:78:3b:10:36 LE 1M LE LL 28 446\302\265s 0 ADV_IND 189 0.172 fb:18:78:3b:10:36 LE 1M LE LL 28 446\302\265s 0 ADV_IND 190 0.172 43:bd:56:bd:74:f9 LE 1M LE LL 37 650\302\265s 0 ADV_NONCONN_IND 191 0.172 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 192 0.172 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 193 0.172 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 4533\302\265s 0 ADV_IND 194 0.172 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 195 0.172 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 354\302\265s 0 ADV_IND 196 0.172 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4395\302\265s 0 ADV_NONCONN_IND 197 0.172 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 198 0.172 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 199 0.187 61:9c:87:78:87:2b LE 1M LE LL 23 13080\302\265s 0 ADV_IND 200 0.187 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 2752\302\265s 0 ADV_IND 201 0.189 32:43:3c:28:8d:92 LE 1M LE LL 37 1740\302\265s 0 ADV_NONCONN_IND 202 0.189 d2:52:6a:67:61:fd LE 1M LE LL 21 4829\302\265s 0 ADV_IND 203 0.189 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 204 0.189 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 205 0.189 d5:80:ce:3a:df:84 LE 1M LE LL 36 9038\302\265s 0 ADV_IND 206 0.189 d5:80:ce:3a:df:84 LE 1M LE LL 36 353\302\265s 0 ADV_IND 207 0.189 d5:80:ce:3a:df:84 LE 1M LE LL 36 354\302\265s 0 ADV_IND 208 0.189 0d:62:2c:2a:24:88 LE 1M LE LL 37 252\302\265s 0 ADV_NONCONN_IND 209 0.189 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 210 0.189 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 211 0.189 cc:15:14:59:64:aa LE 1M LE LL 36 1320\302\265s 0 ADV_IND 212 0.189 cc:15:14:59:64:aa LE 1M LE LL 36 351\302\265s 0 ADV_IND 213 0.189 71:c4:79:42:57:d8 LE 1M LE LL 6 274\302\265s 0 SCAN_RSP 214 0.189 16:ed:93:0f:fa:b0 LE 1M LE LL 37 729\302\265s 0 ADV_NONCONN_IND 215 0.189 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 216 0.189 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 217 0.189 d2:52:6a:67:61:fd LE 1M LE LL 21 2490\302\265s 0 ADV_IND 218 0.189 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 219 0.189 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 220 0.203 07:69:22:f0:72:30 LE 1M LE LL 37 2355\302\265s 0 ADV_NONCONN_IND 221 0.203 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 222 0.203 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 223 0.203 25:5f:bf:53:1f:d7 LE 1M LE LL 37 256\302\265s 0 ADV_NONCONN_IND 224 0.203 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 7060\302\265s 0 ADV_NONCONN_IND 225 0.203 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 226 0.203 24:c3:d0:ce:d4:37 LE 1M LE LL 37 800\302\265s 0 ADV_NONCONN_IND 227 0.203 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 228 0.203 24:c3:d0:ce:d4:37 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 229 0.203 d2:52:6a:67:61:fd LE 1M LE LL 21 6198\302\265s 0 ADV_IND 230 0.203 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 231 0.203 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 232 0.203 e5:ea:46:16:3e:1e LE 1M LE LL 36 2768\302\265s 0 ADV_IND 233 0.203 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 234 0.203 e5:ea:46:16:3e:1e LE 1M LE LL 36 741\302\265s 0 ADV_IND 235 0.203 cd:5c:f3:7d:98:0b LE 1M LE LL 36 2028\302\265s 0 ADV_IND 236 0.203 cd:5c:f3:7d:98:0b LE 1M LE LL 36 353\302\265s 0 ADV_IND 237 0.203 cd:5c:f3:7d:98:0b LE 1M LE LL 36 741\302\265s 0 ADV_IND 238 0.203 ef:6e:3d:68:42:19 LE 1M LE LL 36 5129\302\265s 0 ADV_IND 239 0.219 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 240 0.219 ef:6e:3d:68:42:19 LE 1M LE LL 36 489\302\265s 0 ADV_IND 241 0.219 d2:52:6a:67:61:fd LE 1M LE LL 21 6344\302\265s 0 ADV_IND 242 0.219 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 243 0.219 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1062\302\265s 0 ADV_NONCONN_IND 244 0.219 31:ea:1b:25:0d:1f LE 1M LE LL 37 7028\302\265s 0 ADV_NONCONN_IND 245 0.219 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 246 0.219 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 247 0.219 3a:d1:ca:1d:4d:de LE 1M LE LL 26 435\302\265s 0 ADV_NONCONN_IND 248 0.219 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 249 0.219 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 250 0.219 d2:52:6a:67:61:fd LE 1M LE LL 21 9602\302\265s 0 ADV_IND 251 0.219 32:43:3c:28:8d:92 LE 1M LE LL 37 825\302\265s 0 ADV_NONCONN_IND 252 0.219 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 253 0.219 f1:ff:a7:1a:55:8d LE 1M LE LL 36 501\302\265s 0 ADV_IND 254 0.219 f1:ff:a7:1a:55:8d LE 1M LE LL 36 352\302\265s 0 ADV_IND 255 0.219 f1:ff:a7:1a:55:8d LE 1M LE LL 36 740\302\265s 0 ADV_IND 256 0.219 1e:28:49:84:c5:cd LE 1M LE LL 37 5918\302\265s 0 ADV_NONCONN_IND 257 0.219 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 258 0.219 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 259 0.219 11:fe:ef:ed:38:82 LE 1M LE LL 37 7451\302\265s 0 ADV_NONCONN_IND 260 0.235 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 261 0.235 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 262 0.235 0d:62:2c:2a:24:88 LE 1M LE LL 37 1562\302\265s 0 ADV_NONCONN_IND 263 0.235 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 264 0.235 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 265 0.235 d2:52:6a:67:61:fd LE 1M LE LL 21 1503\302\265s 0 ADV_IND 266 0.235 LE 1M LE LL 111 1284\302\265s 0 Unknown 267 0.235 d2:52:6a:67:61:fd LE 1M LE LL 21 668\302\265s 0 ADV_IND 268 0.235 07:69:22:f0:72:30 LE 1M LE LL 37 5865\302\265s 0 ADV_NONCONN_IND 269 0.235 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 270 0.235 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 271 0.235 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1521\302\265s 0 ADV_NONCONN_IND 272 0.235 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 273 0.235 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 274 0.235 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5179\302\265s 0 ADV_NONCONN_IND 275 0.235 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 276 0.235 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 277 0.235 d2:52:6a:67:61:fd LE 1M LE LL 21 621\302\265s 0 ADV_IND 278 0.25 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 279 0.25 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 280 0.25 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 8067\302\265s 0 ADV_IND 281 0.25 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 353\302\265s 0 ADV_IND 282 0.25 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1057\302\265s 0 ADV_NONCONN_IND 283 0.25 d2:52:6a:67:61:fd LE 1M LE LL 21 9059\302\265s 0 ADV_IND 284 0.25 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 285 0.25 d6:2c:05:d0:15:49 LE 1M LE LL 37 1039\302\265s 0 ADV_IND[Malformed Packet] 286 0.25 43:bd:56:bd:74:f9 LE 1M LE LL 37 375\302\265s 0 ADV_NONCONN_IND 287 0.25 71:c9:89:02:1c:fb LE 1M LE LL 12 6287\302\265s 0 SCAN_REQ 288 0.25 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1598\302\265s 0 ADV_NONCONN_IND 289 0.25 d2:52:6a:67:61:fd LE 1M LE LL 21 9354\302\265s 0 ADV_IND 290 0.25 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 291 0.25 3a:d1:ca:1d:4d:de LE 1M LE LL 26 510\302\265s 0 ADV_NONCONN_IND 292 0.25 31:ea:1b:25:0d:1f LE 1M LE LL 37 669\302\265s 0 ADV_NONCONN_IND 293 0.25 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 294 0.25 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 295 0.25 32:43:3c:28:8d:92 LE 1M LE LL 37 9831\302\265s 0 ADV_NONCONN_IND 296 0.25 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 297 0.266 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 298 0.266 e7:70:80:c3:ad:91 LE 1M LE LL 36 2547\302\265s 0 ADV_IND 299 0.266 e7:70:80:c3:ad:91 LE 1M LE LL 36 352\302\265s 0 ADV_IND 300 0.266 1e:28:49:84:c5:cd LE 1M LE LL 37 4213\302\265s 0 ADV_NONCONN_IND 301 0.266 11:fe:ef:ed:38:82 LE 1M LE LL 37 4949\302\265s 0 ADV_NONCONN_IND 302 0.266 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 303 0.266 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 304 0.266 c4:93:3f:79:a7:16 LE 1M LE LL 36 1612\302\265s 0 ADV_IND 305 0.266 c4:d3:3f:79:a7:16 LE 1M LE LL 36 353\302\265s 0 ADV_IND 306 0.266 c4:d3:3f:79:a7:16 LE 1M LE LL 36 742\302\265s 0 ADV_IND 307 0.266 0d:62:2c:2a:24:88 LE 1M LE LL 37 2129\302\265s 0 ADV_NONCONN_IND 308 0.266 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 309 0.266 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 310 0.266 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5618\302\265s 0 ADV_NONCONN_IND 311 0.266 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 312 0.266 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 313 0.266 07:69:22:f0:72:30 LE 1M LE LL 37 1848\302\265s 0 ADV_NONCONN_IND 314 0.282 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 315 0.282 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 316 0.282 d2:52:6a:67:61:fd LE 1M LE LL 21 334\302\265s 0 ADV_IND 317 0.282 25:5f:bf:53:1f:d7 LE 1M LE LL 37 256\302\265s 0 ADV_NONCONN_IND 318 0.282 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 319 0.282 58:a9:3f:be:99:29 LE 1M LE LL 23 4970\302\265s 0 ADV_IND 320 0.282 58:a9:3f:be:99:29 LE 1M LE LL 23 369\302\265s 0 ADV_IND 321 0.282 58:a9:3f:be:99:29 LE 1M LE LL 23 477\302\265s 0 ADV_IND 322 0.282 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 10038\302\265s 0 ADV_NONCONN_IND 323 0.29 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 324 0.29 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 325 0.29 21:02:60:9c:87:78 LE 1M LE LL 23 7079\302\265s 0 AUX_CONNECT_RSP[Malformed Packet] 326 0.29 d2:52:6a:67:61:fd LE 1M LE LL 21 1648\302\265s 0 ADV_IND 327 0.29 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 328 0.29 43:bd:56:bd:74:f9 LE 1M LE LL 37 2509\302\265s 0 ADV_NONCONN_IND 329 0.29 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 330 0.29 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 331 0.29 5c:9e:d4:03:82:5b LE 1M LE LL 37 4677\302\265s 0 ADV_NONCONN_IND 332 0.29 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 333 0.298 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 334 0.298 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3224\302\265s 0 ADV_NONCONN_IND 335 0.298 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 336 0.298 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 337 0.298 LE 1M LE LL 2 1472\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 338 0.298 SamsungE_07:d8:8f LE 1M LE LL 34 841\302\265s 0 ADV_NONCONN_IND 339 0.298 SamsungE_07:d8:8f LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 340 0.298 d6:bf:76:0a:0b:dc LE 1M LE LL 36 3124\302\265s 0 ADV_IND 341 0.298 d6:bf:76:0a:0b:dc LE 1M LE LL 36 353\302\265s 0 ADV_IND 342 0.298 d6:bf:76:0a:0b:dc LE 1M LE LL 36 491\302\265s 0 ADV_IND 343 0.298 d2:52:6a:67:61:fd LE 1M LE LL 21 704\302\265s 0 ADV_IND 344 0.298 3a:d1:ca:1d:4d:de LE 1M LE LL 26 607\302\265s 0 ADV_NONCONN_IND 345 0.298 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 346 0.298 32:43:3c:28:8d:92 LE 1M LE LL 37 9490\302\265s 0 ADV_NONCONN_IND 347 0.298 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 348 0.298 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 349 0.298 c9:2d:18:b6:8c:6b LE 1M LE LL 14 257\302\265s 0 ADV_NONCONN_IND 350 0.298 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 2591\302\265s 0 ADV_IND 351 0.298 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 742\302\265s 0 ADV_IND 352 0.313 d2:52:6a:67:61:fd LE 1M LE LL 21 3089\302\265s 0 ADV_IND 353 0.313 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 354 0.313 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 355 0.313 1e:28:49:84:c5:cd LE 1M LE LL 37 3839\302\265s 0 ADV_NONCONN_IND 356 0.313 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 357 0.313 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 358 0.313 SamsungE_07:d5:79 LE 1M LE LL 34 1216\302\265s 0 ADV_NONCONN_IND 359 0.313 SamsungE_07:d5:79 LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 360 0.313 16:ed:93:0f:fa:b0 LE 1M LE LL 37 387\302\265s 0 ADV_NONCONN_IND 361 0.313 11:fe:ef:ed:38:82 LE 1M LE LL 37 432\302\265s 0 ADV_NONCONN_IND 362 0.313 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 363 0.313 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 364 0.313 0d:62:2c:2a:24:88 LE 1M LE LL 37 939\302\265s 0 ADV_NONCONN_IND 365 0.313 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 366 0.313 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 367 0.313 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 491\302\265s 0 ADV_NONCONN_IND 368 0.329 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 369 0.329 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 370 0.329 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1573\302\265s 0 ADV_NONCONN_IND 371 0.329 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 372 0.329 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 373 0.329 07:69:22:f0:72:30 LE 1M LE LL 37 1849\302\265s 0 ADV_NONCONN_IND 374 0.329 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 375 0.329 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 376 0.329 d2:52:6a:67:61:fd LE 1M LE LL 21 2790\302\265s 0 ADV_IND 377 0.329 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 378 0.329 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 379 0.329 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1346\302\265s 0 ADV_NONCONN_IND 380 0.329 14:0c:b4:f3:95:39 LE 1M LE LL 14 102\302\265s 0 ADV_IND[Malformed Packet] 381 0.329 24:c3:d0:ce:d4:37 LE 1M LE LL 37 438\302\265s 0 ADV_NONCONN_IND 382 0.329 c6:59:d0:fc:f1:b9 LE 1M LE LL 14 394\302\265s 0 ADV_IND 383 0.329 d4:73:61:e6:96:e4 LE 1M LE LL 14 694\302\265s 0 ADV_NONCONN_IND 384 0.329 d4:73:61:e6:96:e4 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 385 0.329 d5:80:ce:3a:df:84 LE 1M LE LL 36 782\302\265s 0 ADV_IND 386 0.329 d5:80:ce:3a:df:84 LE 1M LE LL 36 354\302\265s 0 ADV_IND 387 0.345 d5:80:ce:3a:df:84 LE 1M LE LL 36 354\302\265s 0 ADV_IND 388 0.345 cc:15:14:59:64:aa LE 1M LE LL 36 558\302\265s 0 ADV_IND 389 0.345 cc:15:14:59:64:aa LE 1M LE LL 36 351\302\265s 0 ADV_IND 390 0.345 cc:15:14:59:64:aa LE 1M LE LL 36 740\302\265s 0 ADV_IND 391 0.345 16:8a:48:48:7a:5b LE 1M LE LL 23 2345\302\265s 0 ADV_NONCONN_IND 392 0.345 16:8a:48:48:7a:5b LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 393 0.345 16:8a:48:48:7a:5b LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 394 0.345 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1937\302\265s 0 ADV_NONCONN_IND 395 0.345 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 396 0.345 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 397 0.345 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6113\302\265s 0 ADV_NONCONN_IND 398 0.345 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 399 0.345 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 400 0.345 d2:52:6a:67:61:fd LE 1M LE LL 21 1600\302\265s 0 ADV_IND 401 0.345 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 402 0.345 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 403 0.345 ed:4e:4a:f5:08:6e LE 1M LE LL 14 1373\302\265s 0 ADV_NONCONN_IND 404 0.345 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 405 0.345 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 406 0.345 5c:9e:d4:03:82:5b LE 1M LE LL 37 4665\302\265s 0 ADV_NONCONN_IND 407 0.345 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 408 0.36 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 409 0.36 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3223\302\265s 0 ADV_NONCONN_IND 410 0.36 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 411 0.36 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 412 0.36 e5:ea:46:16:3e:1e LE 1M LE LL 36 3732\302\265s 0 ADV_IND 413 0.36 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 414 0.36 e5:ea:46:16:3e:1e LE 1M LE LL 36 741\302\265s 0 ADV_IND 415 0.36 31:ea:1b:25:0d:1f LE 1M LE LL 37 475\302\265s 0 ADV_NONCONN_IND 416 0.36 25:74:b7:a5:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 417 0.36 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 418 0.36 cd:5c:f3:7d:98:0b LE 1M LE LL 36 68\302\265s 0 ADV_IND 419 0.36 cd:5c:f3:7d:98:0b LE 1M LE LL 36 353\302\265s 0 ADV_IND 420 0.36 cd:5c:f3:7d:98:0b LE 1M LE LL 36 740\302\265s 0 ADV_IND 421 0.36 43:bd:56:bd:74:f9 LE 1M LE LL 37 1649\302\265s 0 ADV_NONCONN_IND 422 0.36 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 423 0.36 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 424 0.36 ef:6e:3d:68:42:19 LE 1M LE LL 36 1459\302\265s 0 ADV_IND 425 0.36 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 426 0.36 ef:6e:3d:68:42:19 LE 1M LE LL 36 741\302\265s 0 ADV_IND 427 0.376 32:43:3c:28:8d:92 LE 1M LE LL 37 7723\302\265s 0 ADV_NONCONN_IND 428 0.376 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 429 0.376 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 430 0.376 d2:52:6a:67:61:fd LE 1M LE LL 21 2966\302\265s 0 ADV_IND 431 0.376 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 432 0.376 eb:db:35:2e:09:1b LE 1M LE LL 36 577\302\265s 0 ADV_IND[Malformed Packet] 433 0.376 1e:28:49:84:c5:cd LE 1M LE LL 37 10368\302\265s 0 ADV_NONCONN_IND 434 0.376 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 435 0.376 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 436 0.376 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1628\302\265s 0 ADV_IND 437 0.376 f1:ff:a7:1a:55:8d LE 1M LE LL 36 352\302\265s 0 ADV_IND 438 0.376 f1:ff:a7:1a:55:8d LE 1M LE LL 36 353\302\265s 0 ADV_IND 439 0.376 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3544\302\265s 0 ADV_NONCONN_IND 440 0.376 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 441 0.376 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 442 0.376 07:69:22:f0:72:30 LE 1M LE LL 37 2475\302\265s 0 ADV_NONCONN_IND 443 0.376 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 444 0.376 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 445 0.376 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2778\302\265s 0 ADV_NONCONN_IND 446 0.376 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 447 0.376 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 448 0.39 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 449 0.39 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 450 0.392 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 451 0.392 d2:52:6a:67:61:fd LE 1M LE LL 21 10607\302\265s 0 ADV_IND 452 0.392 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 453 0.392 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 454 0.392 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4085\302\265s 0 ADV_NONCONN_IND 455 0.392 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 456 0.392 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 457 0.392 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3614\302\265s 0 ADV_NONCONN_IND 458 0.392 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 459 0.392 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 460 0.392 d2:52:6a:67:61:fd LE 1M LE LL 21 7975\302\265s 0 ADV_IND 461 0.392 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 462 0.392 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 463 0.392 0c:6e:66:d7:ed:03 LE 1M LE LL 37 979\302\265s 0 ADV_NONCONN_IND 464 0.392 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 465 0.392 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 466 0.392 3a:d1:ca:1d:4d:de LE 1M LE LL 26 5225\302\265s 0 ADV_NONCONN_IND 467 0.392 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 468 0.407 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 469 0.407 d2:52:6a:67:61:fd LE 1M LE LL 21 15490\302\265s 0 ADV_IND 470 0.407 d2:52:6a:67:61:fd LE 1M LE LL 21 1337\302\265s 0 ADV_IND 471 0.407 d2:52:6a:67:61:fd LE 1M LE LL 21 1335\302\265s 0 ADV_IND 472 0.407 32:43:3c:28:8d:92 LE 1M LE LL 37 3074\302\265s 0 ADV_NONCONN_IND 473 0.407 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 474 0.407 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 475 0.407 58:a9:3f:be:99:29 LE 1M LE LL 23 4283\302\265s 0 ADV_IND 476 0.407 58:a9:3f:be:99:29 LE 1M LE LL 23 368\302\265s 0 ADV_IND 477 0.407 58:a9:3f:be:99:29 LE 1M LE LL 23 368\302\265s 0 ADV_IND 478 0.407 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3569\302\265s 0 ADV_NONCONN_IND 479 0.407 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 480 0.407 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 481 0.407 1e:28:49:84:c5:cd LE 1M LE LL 37 3368\302\265s 0 ADV_NONCONN_IND 482 0.407 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 483 0.407 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 484 0.407 0d:62:2c:2a:24:88 LE 1M LE LL 37 2377\302\265s 0 ADV_NONCONN_IND 485 0.407 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 486 0.423 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 487 0.423 d2:52:6a:67:61:fd LE 1M LE LL 21 935\302\265s 0 ADV_IND 488 0.423 d2:52:6a:67:61:fd LE 1M LE LL 21 1335\302\265s 0 ADV_IND 489 0.423 d2:52:6a:67:61:fd LE 1M LE LL 21 1337\302\265s 0 ADV_IND 490 0.423 11:fe:ef:ed:38:82 LE 1M LE LL 37 483\302\265s 0 ADV_NONCONN_IND 491 0.423 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 492 0.423 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 493 0.423 07:69:22:f0:72:30 LE 1M LE LL 37 83\302\265s 0 ADV_NONCONN_IND 494 0.423 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 495 0.423 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 496 0.423 25:5f:bf:53:1f:d7 LE 1M LE LL 37 265\302\265s 0 ADV_NONCONN_IND 497 0.423 25:5f:bf:53:1f:d7 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 498 0.423 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 499 0.423 08:ec:5e:66:cd:0d LE 1M LE LL 23 4699\302\265s 0 ADV_NONCONN_IND 500 0.423 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 501 0.423 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 502 0.423 e5:ea:46:16:3e:1e LE 1M LE LL 36 117\302\265s 0 ADV_IND 503 0.439 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 504 0.439 e5:ea:46:16:3e:1e LE 1M LE LL 36 354\302\265s 0 ADV_IND 505 0.439 24:c3:d0:ce:d4:37 LE 1M LE LL 37 621\302\265s 0 ADV_NONCONN_IND 506 0.439 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 507 0.439 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 508 0.439 c4:d3:3f:79:a7:16 LE 1M LE LL 36 2197\302\265s 0 ADV_IND 509 0.439 c4:d3:3f:79:a7:16 LE 1M LE LL 36 353\302\265s 0 ADV_IND 510 0.439 cf:4f:81:f5:7d:55 LE 1M LE LL 36 6598\302\265s 0 ADV_IND 511 0.439 c0:41:04:2e:be:9d LE 1M LE LL 36 3241\302\265s 0 ADV_IND 512 0.439 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2927\302\265s 0 ADV_NONCONN_IND 513 0.439 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 514 0.439 c1:c8:16:ae:fd:1d LE 1M LE LL 36 3099\302\265s 0 ADV_IND 515 0.439 c1:c8:16:ae:fd:1d LE 1M LE LL 36 353\302\265s 0 ADV_IND 516 0.439 c1:c8:16:ae:fd:1d LE 1M LE LL 36 354\302\265s 0 ADV_IND 517 0.439 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1828\302\265s 0 ADV_NONCONN_IND 518 0.439 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 519 0.439 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 520 0.439 5c:9e:d4:03:82:5b LE 1M LE LL 37 1897\302\265s 0 ADV_NONCONN_IND 521 0.454 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 522 0.454 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 523 0.454 41:bd:56:bd:74:f9 LE 1M LE LL 37 391\302\265s 0 ADV_NONCONN_IND 524 0.454 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 525 0.454 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 526 0.454 d2:52:6a:67:61:fd LE 1M LE LL 21 1230\302\265s 0 ADV_IND 527 0.454 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 528 0.454 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 529 0.454 17:5f:43:7c:0a:89 LE 1M LE LL 23 931\302\265s 0 ADV_NONCONN_IND 530 0.454 31:ea:1b:25:0d:1f LE 1M LE LL 37 2910\302\265s 0 ADV_NONCONN_IND 531 0.454 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 532 0.454 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1082\302\265s 0 ADV_NONCONN_IND 533 0.454 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 534 0.454 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 535 0.454 c8:de:06:91:ba:b3 LE 1M LE LL 36 2408\302\265s 0 ADV_IND 536 0.454 69:a9:48:2f:b7:16 LE 1M LE LL 37 7340\302\265s 0 ADV_NONCONN_IND 537 0.454 77:c6:0a:3c:ae:be LE 1M LE LL 25 490\302\265s 0 ADV_IND 538 0.454 0b:f9:be:c7:0f:fb LE 1M LE LL 23 2621\302\265s 0 ADV_NONCONN_IND 539 0.454 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 540 0.47 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 541 0.47 d2:52:6a:67:61:fd LE 1M LE LL 21 1959\302\265s 0 ADV_IND 542 0.47 d2:52:6a:67:61:fd LE 1M LE LL 21 1337\302\265s 0 ADV_IND 543 0.47 d2:52:6a:67:61:fd LE 1M LE LL 21 1335\302\265s 0 ADV_IND 544 0.47 32:43:3c:28:8d:92 LE 1M LE LL 37 2915\302\265s 0 ADV_NONCONN_IND 545 0.47 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 546 0.47 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 547 0.47 16:ed:93:0f:fa:b0 LE 1M LE LL 37 632\302\265s 0 ADV_NONCONN_IND 548 0.47 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 549 0.47 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 550 0.47 1e:28:49:84:c5:cd LE 1M LE LL 37 5863\302\265s 0 ADV_NONCONN_IND 551 0.47 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 552 0.47 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 553 0.47 SamsungE_07:d5:79 LE 1M LE LL 34 579\302\265s 0 ADV_NONCONN_IND 554 0.47 SamsungE_07:d5:79 LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 555 0.47 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 556 0.47 2b:5e:0e:c8:62:4c LE 1M LE LL 35 426\302\265s 0 ADV_NONCONN_IND 557 0.47 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 558 0.47 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 559 0.486 0d:62:2c:2a:24:88 LE 1M LE LL 37 1460\302\265s 0 ADV_NONCONN_IND 560 0.486 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 561 0.486 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 562 0.486 11:fe:ef:ed:38:82 LE 1M LE LL 37 457\302\265s 0 ADV_NONCONN_IND 563 0.49 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 564 0.49 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 565 0.49 d2:52:6a:67:61:fd LE 1M LE LL 21 1056\302\265s 0 ADV_IND 566 0.49 40:f0:08:9b:56:91 LE 1M LE LL 37 1198\302\265s 0 ADV_SCAN_IND 567 0.49 07:69:22:f0:72:30 LE 1M LE LL 37 835\302\265s 0 ADV_NONCONN_IND 568 0.49 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3395\302\265s 0 ADV_NONCONN_IND 569 0.49 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 570 0.49 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 571 0.49 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2678\302\265s 0 ADV_NONCONN_IND 572 0.49 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 573 0.49 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 574 0.49 d2:52:6a:67:61:fd LE 1M LE LL 21 14550\302\265s 0 ADV_IND 575 0.502 74:d9:0b:7a:47:5a LE 1M LE LL 23 392\302\265s 0 ADV_IND 576 0.502 74:d9:0b:7a:47:5a LE 1M LE LL 23 514\302\265s 0 ADV_IND 577 0.502 74:d9:0b:7a:47:5a LE 1M LE LL 23 514\302\265s 0 ADV_IND 578 0.502 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5406\302\265s 0 ADV_NONCONN_IND 579 0.502 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 580 0.502 27:f1:d5:6a:d5:82 LE 1M LE LL 37 485\302\265s 0 ADV_NONCONN_IND 581 0.502 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 582 0.502 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 583 0.502 43:bd:56:bd:74:f9 LE 1M LE LL 37 2673\302\265s 0 ADV_NONCONN_IND 584 0.502 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 585 0.502 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 586 0.502 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5156\302\265s 0 ADV_NONCONN_IND 587 0.502 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 588 0.502 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 589 0.502 31:6a:1f:3d:01:1f LE 1M LE LL 37 5159\302\265s 0 ADV_NONCONN_IND 590 0.502 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 591 0.502 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 592 0.502 7d:30:e4:59:cd:06 LE 1M LE LL 25 10904\302\265s 0 ADV_IND 593 0.502 7d:30:e4:59:cd:06 LE 1M LE LL 25 368\302\265s 0 ADV_IND 594 0.502 e5:ea:46:16:3e:1e LE 1M LE LL 36 7288\302\265s 0 ADV_IND 595 0.502 d2:52:6a:67:61:fd LE 1M LE LL 21 1775\302\265s 0 ADV_IND 596 0.517 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 597 0.517 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 598 0.517 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2278\302\265s 0 ADV_NONCONN_IND 599 0.517 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 600 0.517 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 601 0.517 32:43:3c:28:8d:92 LE 1M LE LL 37 1392\302\265s 0 ADV_NONCONN_IND 602 0.517 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 603 0.517 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 604 0.517 ef:6e:3d:68:42:19 LE 1M LE LL 36 446\302\265s 0 ADV_IND 605 0.517 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 606 0.517 cd:5c:f3:7d:98:0b LE 1M LE LL 36 501\302\265s 0 ADV_IND 607 0.517 1e:28:49:84:c5:cd LE 1M LE LL 37 4332\302\265s 0 ADV_NONCONN_IND 608 0.517 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 609 0.517 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 610 0.517 SamsungE_07:d8:8f LE 1M LE LL 34 888\302\265s 0 ADV_NONCONN_IND 611 0.517 SamsungE_07:d8:8f LE 1M LE LL 34 584\302\265s 0 ADV_NONCONN_IND 612 0.517 SamsungE_07:d8:8f LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 613 0.517 2b:5e:0e:c8:62:4c LE 1M LE LL 35 116\302\265s 0 ADV_NONCONN_IND 614 0.533 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 615 0.533 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 616 0.533 0d:62:2c:2a:24:88 LE 1M LE LL 37 838\302\265s 0 ADV_NONCONN_IND 617 0.533 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 618 0.533 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 619 0.533 e6:b0:0f:53:1f:d7 LE 1M LE LL 37 8173\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 620 0.533 38:bf:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 621 0.533 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 622 0.533 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3299\302\265s 0 ADV_NONCONN_IND 623 0.533 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 624 0.533 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 625 0.533 dd:d8:c3:2e:ed:c0 LE 1M LE LL 36 1091\302\265s 0 ADV_IND 626 0.533 f1:ff:a7:1a:55:8d LE 1M LE LL 36 6913\302\265s 0 ADV_IND 627 0.533 f1:ff:a7:1a:55:8d LE 1M LE LL 36 353\302\265s 0 ADV_IND 628 0.533 27:f1:d5:6a:d5:82 LE 1M LE LL 37 13126\302\265s 0 ADV_NONCONN_IND 629 0.533 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 630 0.533 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 631 0.533 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1613\302\265s 0 ADV_NONCONN_IND 632 0.533 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 633 0.533 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 634 0.548 43:bd:56:bd:74:f9 LE 1M LE LL 37 821\302\265s 0 ADV_NONCONN_IND 635 0.548 c0:4e:43:7b:5f:2b LE 1M LE LL 14 1063\302\265s 0 ADV_IND 636 0.548 43:bd:56:bd:74:f9 LE 1M LE LL 37 150\302\265s 0 ADV_NONCONN_IND 637 0.548 d2:52:6a:67:61:fd LE 1M LE LL 21 2371\302\265s 0 ADV_IND 638 0.548 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 639 0.548 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 640 0.548 58:a9:3f:be:99:29 LE 1M LE LL 23 1935\302\265s 0 ADV_IND 641 0.548 58:a9:3f:be:99:29 LE 1M LE LL 23 368\302\265s 0 ADV_IND 642 0.548 58:a9:3f:be:99:29 LE 1M LE LL 23 736\302\265s 0 ADV_IND 643 0.548 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1022\302\265s 0 ADV_NONCONN_IND 644 0.548 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 645 0.548 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 646 0.548 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 7656\302\265s 0 ADV_IND 647 0.548 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 353\302\265s 0 ADV_IND 648 0.548 5c:9e:d4:03:82:5b LE 1M LE LL 37 1795\302\265s 0 ADV_NONCONN_IND 649 0.548 d2:52:6a:67:61:fd LE 1M LE LL 21 5406\302\265s 0 ADV_IND 650 0.548 e5:ea:96:fe:cc:4a LE 1M LE LL 36 83\302\265s 0 ADV_IND 651 0.548 d2:52:6a:67:61:fd LE 1M LE LL 21 2469\302\265s 0 ADV_IND 652 0.548 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6864\302\265s 0 ADV_NONCONN_IND 653 0.548 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 654 0.548 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 655 0.548 32:43:3c:28:8d:92 LE 1M LE LL 37 3267\302\265s 0 ADV_NONCONN_IND 656 0.564 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 657 0.564 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 658 0.564 1e:28:49:84:c5:cd LE 1M LE LL 37 7984\302\265s 0 ADV_NONCONN_IND 659 0.564 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 660 0.564 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 661 0.564 d2:52:6a:67:61:fd LE 1M LE LL 21 131\302\265s 0 ADV_IND 662 0.564 0d:62:2c:2a:24:88 LE 1M LE LL 37 684\302\265s 0 ADV_NONCONN_IND 663 0.564 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 664 0.564 11:fe:ef:ed:38:82 LE 1M LE LL 37 4827\302\265s 0 ADV_NONCONN_IND 665 0.564 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 666 0.564 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 667 0.564 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6237\302\265s 0 ADV_NONCONN_IND 668 0.564 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 669 0.564 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 670 0.564 07:69:22:f0:72:30 LE 1M LE LL 37 1108\302\265s 0 ADV_NONCONN_IND 671 0.564 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 672 0.564 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 673 0.58 e7:70:80:c3:ad:91 LE 1M LE LL 36 8712\302\265s 0 ADV_IND 674 0.58 e7:70:80:c3:ad:91 LE 1M LE LL 36 353\302\265s 0 ADV_IND 675 0.58 e7:70:80:c3:ad:91 LE 1M LE LL 36 742\302\265s 0 ADV_IND 676 0.58 e5:ea:46:16:3e:1e LE 1M LE LL 36 4182\302\265s 0 ADV_IND 677 0.58 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 678 0.58 e5:ea:46:16:3e:1e LE 1M LE LL 36 354\302\265s 0 ADV_IND 679 0.58 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4102\302\265s 0 ADV_NONCONN_IND 680 0.58 25:61:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 681 0.58 77:c6:0a:3c:ae:be LE 1M LE LL 25 365\302\265s 0 ADV_IND 682 0.58 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4921\302\265s 0 ADV_NONCONN_IND 683 0.59 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 684 0.59 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 685 0.596 43:bd:56:bd:74:f9 LE 1M LE LL 37 1442\302\265s 0 ADV_NONCONN_IND 686 0.596 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 687 0.596 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 688 0.596 0c:6e:66:d7:ed:03 LE 1M LE LL 37 780\302\265s 0 ADV_NONCONN_IND 689 0.596 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 690 0.596 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 691 0.596 31:ea:1b:25:0d:1f LE 1M LE LL 37 2659\302\265s 0 ADV_NONCONN_IND 692 0.596 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 693 0.596 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 694 0.596 LE 1M LE LL 2 1710\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 695 0.596 3a:d1:ca:1d:4d:de LE 1M LE LL 26 647\302\265s 0 ADV_NONCONN_IND 696 0.596 d2:52:6a:67:61:fd LE 1M LE LL 19 252\302\265s 0 SCAN_RSP 697 0.611 c1:c8:16:ae:fd:1d LE 1M LE LL 36 1031\302\265s 0 ADV_IND 698 0.611 c1:c8:16:ae:fd:1d LE 1M LE LL 36 353\302\265s 0 ADV_IND 699 0.611 c1:c8:16:ae:fd:1d LE 1M LE LL 36 354\302\265s 0 ADV_IND 700 0.611 5c:9e:d4:03:82:5b LE 1M LE LL 37 4568\302\265s 0 ADV_NONCONN_IND 701 0.611 69:a9:48:2f:b7:16 LE 1M LE LL 37 8676\302\265s 0 ADV_NONCONN_IND 702 0.611 d2:52:6a:67:61:fd LE 1M LE LL 21 6436\302\265s 0 ADV_IND 703 0.611 16:ed:93:0f:fa:b0 LE 1M LE LL 37 7089\302\265s 0 ADV_NONCONN_IND 704 0.611 32:43:3c:28:8d:92 LE 1M LE LL 37 4934\302\265s 0 ADV_NONCONN_IND 705 0.611 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 706 0.611 1e:28:49:84:c5:cd LE 1M LE LL 37 484\302\265s 0 ADV_NONCONN_IND 707 0.611 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 708 0.627 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 709 0.627 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2605\302\265s 0 ADV_NONCONN_IND 710 0.627 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 711 0.627 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 712 0.627 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 2869\302\265s 0 ADV_NONCONN_IND 713 0.627 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 714 0.627 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 715 0.627 c5:20:9f:bb:52:bc LE 1M LE LL 15 4508\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 716 0.627 2e:86:8d:c9:47:bd LE 1M LE LL 21 1253\302\265s 0 ADV_NONCONN_IND 717 0.627 2e:86:8d:c9:47:bd LE 1M LE LL 21 132\302\265s 0 ADV_NONCONN_IND 718 0.627 d6:bf:76:0a:0b:dc LE 1M LE LL 36 993\302\265s 0 ADV_IND 719 0.627 d6:bf:76:0a:0b:dc LE 1M LE LL 36 353\302\265s 0 ADV_IND 720 0.627 d6:bf:76:0a:0b:dc LE 1M LE LL 36 354\302\265s 0 ADV_IND 721 0.627 25:5f:bf:53:1f:d7 LE 1M LE LL 37 308\302\265s 0 ADV_NONCONN_IND 722 0.627 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 723 0.627 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 724 0.627 5e:93:36:dd:d3:09 LE 1M LE LL 10 2593\302\265s 0 ADV_SCAN_IND 725 0.627 5e:93:36:dd:d3:09 LE 1M LE LL 10 454\302\265s 0 ADV_SCAN_IND 726 0.627 5e:93:36:dd:d3:09 LE 1M LE LL 10 454\302\265s 0 ADV_SCAN_IND 727 0.627 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3693\302\265s 0 ADV_NONCONN_IND 728 0.627 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 729 0.643 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 730 0.643 d2:52:6a:67:61:fd LE 1M LE LL 21 5446\302\265s 0 ADV_IND 731 0.643 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 732 0.643 16:8a:48:48:7a:5b LE 1M LE LL 23 565\302\265s 0 ADV_NONCONN_IND 733 0.643 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 4508\302\265s 0 ADV_IND 734 0.643 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 735 0.643 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 354\302\265s 0 ADV_IND 736 0.643 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 8691\302\265s 0 ADV_NONCONN_IND 737 0.643 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 738 0.643 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 739 0.643 43:bd:56:bd:74:f9 LE 1M LE LL 37 191\302\265s 0 ADV_NONCONN_IND 740 0.643 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 741 0.643 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 742 0.643 31:ea:1b:25:0d:1f LE 1M LE LL 37 2566\302\265s 0 ADV_NONCONN_IND 743 0.643 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 744 0.643 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 745 0.643 d2:52:6a:67:61:fd LE 1M LE LL 21 236\302\265s 0 ADV_IND 746 0.643 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 747 0.643 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1129\302\265s 0 ADV_NONCONN_IND 748 0.643 d5:80:ce:3a:df:84 LE 1M LE LL 36 5646\302\265s 0 ADV_IND 749 0.643 d5:80:ce:3a:df:84 LE 1M LE LL 36 353\302\265s 0 ADV_IND 750 0.643 d5:80:ce:3a:df:84 LE 1M LE LL 36 354\302\265s 0 ADV_IND 751 0.658 5c:9e:d4:03:82:5b LE 1M LE LL 37 942\302\265s 0 ADV_NONCONN_IND 752 0.658 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 753 0.658 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 754 0.658 cc:15:14:59:64:aa LE 1M LE LL 36 2971\302\265s 0 ADV_IND 755 0.658 cc:15:14:59:64:aa LE 1M LE LL 36 351\302\265s 0 ADV_IND 756 0.658 cc:15:14:59:62:aa LE 1M LE LL 36 352\302\265s 0 ADV_DIRECT_IND 757 0.658 d2:52:6a:67:61:fd LE 1M LE LL 21 6527\302\265s 0 ADV_IND 758 0.658 69:a9:48:2f:b7:16 LE 1M LE LL 37 873\302\265s 0 ADV_NONCONN_IND 759 0.658 7f:e1:7b:e4:24:1c LE 1M LE LL 12 476\302\265s 0 SCAN_REQ 760 0.658 16:ed:93:0f:fa:b0 LE 1M LE LL 37 9994\302\265s 0 ADV_NONCONN_IND 761 0.658 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 762 0.658 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 763 0.658 85:ea:46:16:3e:1e LE 1M LE LL 36 2323\302\265s 0 ADV_IND 764 0.658 22:43:3c:28:8d:92 LE 1M LE LL 37 4255\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 765 0.658 32:4b:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 766 0.658 30:56:0e:e8:62:4c LE 1M LE LL 35 4574\302\265s 0 ADV_NONCONN_IND 767 0.658 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 768 0.658 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 769 0.658 0d:62:2c:2a:24:88 LE 1M LE LL 37 3342\302\265s 0 ADV_NONCONN_IND 770 0.658 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 771 0.658 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 772 0.658 ef:6e:3d:68:42:19 LE 1M LE LL 36 3955\302\265s 0 ADV_IND 773 0.658 11:fe:ef:ed:38:82 LE 1M LE LL 37 3554\302\265s 0 ADV_NONCONN_IND 774 0.658 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 775 0.658 d2:52:6a:67:61:fd LE 1M LE LL 21 5277\302\265s 0 ADV_IND 776 0.674 07:69:22:f0:72:30 LE 1M LE LL 37 748\302\265s 0 ADV_NONCONN_IND 777 0.674 c2:f4:8b:c3:ec:01 LE 1M LE LL 4 1532808\302\265s 0 ADV_IND 778 0.674 49:08:83:d3:3a:6c LE 1M LE LL 12 3846467\302\265s 0 SCAN_REQ 779 0.674 31:ea:1b:25:0d:1f LE 1M LE LL 37 1283\302\265s 0 ADV_NONCONN_IND 780 0.674 ee:d1:00:30:0e:ef LE 1M LE LL 34 113\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 781 0.674 32:43:3c:28:8d:92 LE 1M LE LL 37 3073\302\265s 0 ADV_NONCONN_IND 782 0.674 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 783 0.674 43:bd:56:bd:74:f9 LE 1M LE LL 37 52989322\302\265s 0 ADV_NONCONN_IND 784 0.674 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 785 0.674 07:69:22:f0:72:30 LE 1M LE LL 37 7356\302\265s 0 ADV_NONCONN_IND 786 0.674 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 787 0.674 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 788 0.684 3a:d1:ca:1d:4d:de LE 1M LE LL 26 15103\302\265s 0 ADV_NONCONN_IND 789 0.685 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 790 0.686 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 791 0.69 11:fe:ef:ed:38:82 LE 1M LE LL 37 3346\302\265s 0 ADV_NONCONN_IND 792 0.69 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 793 0.691 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 794 0.697 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6388\302\265s 0 ADV_NONCONN_IND 795 0.698 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 796 0.699 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 797 0.7 fa:1f:24:e3:99:5d LE 1M LE LL 14 1055\302\265s 0 ADV_NONCONN_IND 798 0.7 fa:1f:24:e3:99:5d LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 799 0.708 5c:9e:d4:07:82:5b LE 1M LE LL 37 7264\302\265s 0 ADV_NONCONN_IND 800 0.717 c5:65:68:79:19:c8 LE 1M LE LL 36 8769\302\265s 0 ADV_IND 801 0.72 69:a9:48:2f:b7:16 LE 1M LE LL 37 2345\302\265s 0 ADV_NONCONN_IND 802 0.721 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 803 0.722 0d:62:2c:2a:24:88 LE 1M LE LL 37 705\302\265s 0 ADV_NONCONN_IND 804 0.722 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 805 0.723 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 806 0.726 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3093\302\265s 0 ADV_NONCONN_IND 807 0.727 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 808 0.727 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 809 0.73 e5:ea:46:16:3e:1e LE 1M LE LL 36 2762\302\265s 0 ADV_IND 810 0.731 24:c3:d0:ce:d4:37 LE 1M LE LL 37 376\302\265s 0 ADV_NONCONN_IND 811 0.732 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 812 0.739 32:43:3c:28:8d:92 LE 1M LE LL 37 6717\302\265s 0 ADV_NONCONN_IND 813 0.739 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 814 0.74 32:43:3c:28:8d:b2 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 815 0.744 d2:52:6a:67:61:fd LE 1M LE LL 21 3220\302\265s 0 ADV_IND 816 0.745 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 817 0.747 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 818 0.753 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 5781\302\265s 0 ADV_IND 819 0.754 25:5f:bf:53:1f:d7 LE 1M LE LL 37 515\302\265s 0 ADV_NONCONN_IND 820 0.754 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 821 0.764 08:ec:5e:66:cd:0d LE 1M LE LL 23 9750\302\265s 0 ADV_NONCONN_IND 822 0.765 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 823 0.765 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 824 0.777 07:69:22:f0:72:30 LE 1M LE LL 37 11154\302\265s 0 ADV_NONCONN_IND 825 0.777 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 826 0.778 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 827 0.785 17:5f:43:7c:0a:89 LE 1M LE LL 23 7003\302\265s 0 ADV_NONCONN_IND 828 0.791 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6081\302\265s 0 ADV_NONCONN_IND 829 0.792 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 830 0.793 11:fe:ef:ed:38:82 LE 1M LE LL 37 845\302\265s 0 ADV_NONCONN_IND 831 0.794 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 832 0.794 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 833 0.795 1f:84:46:51:98:14 LE 1M LE LL 23 587\302\265s 0 ADV_NONCONN_IND 834 0.796 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 835 0.796 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 836 0.797 dd:b9:3b:45:59:8b LE 1M LE LL 24 586\302\265s 0 ADV_IND 837 0.8 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2440\302\265s 0 ADV_NONCONN_IND 838 0.801 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 839 0.806 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4614\302\265s 0 ADV_NONCONN_IND 840 0.806 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 841 0.807 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 842 0.809 5c:9e:d4:03:82:5b LE 1M LE LL 37 1955\302\265s 0 ADV_NONCONN_IND 843 0.81 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 844 0.81 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 845 0.817 0b:f9:be:c7:0f:fb LE 1M LE LL 23 6270\302\265s 0 ADV_NONCONN_IND 846 0.817 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 847 0.818 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 848 0.822 6e:86:8d:c9:47:bd LE 1M LE LL 21 4350\302\265s 0 ADV_NONCONN_IND 849 0.826 0d:62:2c:2a:24:88 LE 1M LE LL 37 3282\302\265s 0 ADV_NONCONN_IND 850 0.831 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4760\302\265s 0 ADV_NONCONN_IND 851 0.832 c8:de:06:91:ba:b3 LE 1M LE LL 36 982\302\265s 0 ADV_IND 852 0.845 31:ea:1b:25:0d:1f LE 1M LE LL 37 11931\302\265s 0 ADV_NONCONN_IND 853 0.845 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 854 0.848 32:43:3c:28:8d:92 LE 1M LE LL 37 1942\302\265s 0 ADV_NONCONN_IND 855 0.848 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 856 0.854 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5670\302\265s 0 ADV_NONCONN_IND 857 0.855 2b:5e:0e:c8:62:4c LE 1M LE LL 35 125\302\265s 0 ADV_NONCONN_IND 858 0.855 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 859 0.856 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 860 0.858 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1943\302\265s 0 ADV_NONCONN_IND 861 0.859 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 862 0.859 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 863 0.867 43:bd:56:bd:74:f9 LE 1M LE LL 37 7592\302\265s 0 ADV_NONCONN_IND 864 0.868 43:bd:56:bd:74:e9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 865 0.881 07:69:22:f0:72:30 LE 1M LE LL 37 12412\302\265s 0 ADV_NONCONN_IND 866 0.893 e5:ea:46:16:3e:1e LE 1M LE LL 36 11779\302\265s 0 ADV_IND 867 0.894 72:10:b2:16:c9:46 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 868 0.895 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 869 0.895 64:0d:49:f9:4d:a4 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 870 0.896 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 871 0.898 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2417\302\265s 0 ADV_NONCONN_IND 872 0.899 3a:d1:ca:1d:4d:de LE 1M LE LL 26 548\302\265s 0 ADV_NONCONN_IND 873 0.9 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 874 0.9 1e:28:49:84:c5:cd LE 1M LE LL 37 342\302\265s 0 ADV_NONCONN_IND 875 0.901 d2:52:6a:67:61:fd LE 1M LE LL 19 160\302\265s 0 SCAN_RSP 876 0.902 1e:28:49:84:c5:cd LE 1M LE LL 37 340\302\265s 0 ADV_NONCONN_IND 877 0.904 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2015\302\265s 0 ADV_NONCONN_IND 878 0.905 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 879 0.906 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 880 0.91 7d:30:e4:59:cd:06 LE 1M LE LL 25 4245\302\265s 0 ADV_IND 881 0.911 79:70:d9:25:16:e2 LE 1M LE LL 25 151\302\265s 0 ADV_IND 882 0.911 79:70:d9:25:16:e2 LE 1M LE LL 25 368\302\265s 0 ADV_IND 883 0.912 79:70:d9:25:16:e2 LE 1M LE LL 25 368\302\265s 0 ADV_IND 884 0.913 0c:6e:66:d7:ed:03 LE 1M LE LL 37 861\302\265s 0 ADV_NONCONN_IND 885 0.914 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 886 0.914 d5:80:ce:3a:df:84 LE 1M LE LL 6 131\302\265s 0 SCAN_RSP 887 0.917 e0:74:8b:d3:ec:07 LE 1M LE LL 32 2217\302\265s 0 ADV_IND[Malformed Packet] 888 0.917 5c:9e:d4:03:82:5b LE 1M LE LL 37 395\302\265s 0 ADV_NONCONN_IND 889 0.918 3e:9e:65:f3:95:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 890 0.923 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 4338\302\265s 0 ADV_IND 891 0.924 72:10:b2:16:c9:46 LE 1M LE LL 12 790\302\265s 0 SCAN_REQ 892 0.924 64:0d:49:f9:4d:a4 LE 1M LE LL 12 464\302\265s 0 SCAN_REQ 893 0.931 0d:62:2c:2a:24:88 LE 1M LE LL 37 6564\302\265s 0 ADV_NONCONN_IND 894 0.932 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 895 0.932 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 896 0.935 77:22:78:56:f4:7d LE 1M LE LL 121 2467\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 897 0.953 31:ea:1b:25:0d:1f LE 1M LE LL 37 16843\302\265s 0 ADV_NONCONN_IND 898 0.953 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 899 0.961 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6809\302\265s 0 ADV_NONCONN_IND 900 0.961 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 901 0.962 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 902 0.963 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1001\302\265s 0 ADV_NONCONN_IND 903 0.964 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 904 0.964 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 905 0.975 43:bd:56:bd:74:f9 LE 1M LE LL 37 10106\302\265s 0 ADV_NONCONN_IND 906 0.99 07:69:22:f0:72:30 LE 1M LE LL 37 14538\302\265s 0 ADV_NONCONN_IND 907 0.99 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 908 1.004 11:fe:ef:ed:38:82 LE 1M LE LL 37 13358\302\265s 0 ADV_NONCONN_IND 909 1.004 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 910 1.005 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 911 1.007 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1527\302\265s 0 ADV_NONCONN_IND 912 1.008 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 913 1.008 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 914 1.009 27:f1:d5:6a:d5:82 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 915 1.01 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 916 1.011 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 917 1.018 5c:9e:d4:03:82:5b LE 1M LE LL 37 6946\302\265s 0 ADV_NONCONN_IND 918 1.019 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 919 1.019 7c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 920 1.022 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2911\302\265s 0 ADV_NONCONN_IND 921 1.023 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 922 1.024 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 923 1.029 d6:bf:03:c5:20:42 LE 1M LE LL 36 4735\302\265s 0 ADV_IND 924 1.037 0d:62:2c:2a:24:88 LE 1M LE LL 37 8071\302\265s 0 ADV_NONCONN_IND 925 1.038 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 926 1.041 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2527\302\265s 0 ADV_NONCONN_IND 927 1.041 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 928 1.042 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 929 1.053 32:43:3c:28:8d:92 LE 1M LE LL 37 11095\302\265s 0 ADV_NONCONN_IND 930 1.054 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 931 1.054 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 932 1.056 d2:52:6a:67:61:fd LE 1M LE LL 21 1181\302\265s 0 ADV_IND 933 1.057 7f:e1:7b:e4:24:1c LE 1M LE LL 12 721\302\265s 0 SCAN_REQ 934 1.059 d2:52:6a:67:61:fd LE 1M LE LL 21 2023\302\265s 0 ADV_IND 935 1.06 c5:65:68:79:19:c8 LE 1M LE LL 36 369\302\265s 0 ADV_IND 936 1.06 31:ea:1b:25:0d:1f LE 1M LE LL 37 374\302\265s 0 ADV_NONCONN_IND 937 1.061 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 938 1.062 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 939 1.068 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6170\302\265s 0 ADV_NONCONN_IND 940 1.069 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 941 1.069 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 942 1.07 16:ed:93:0f:fa:b0 LE 1M LE LL 37 400\302\265s 0 ADV_NONCONN_IND 943 1.071 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 944 1.071 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 945 1.081 43:bd:56:bd:74:f9 LE 1M LE LL 37 9464\302\265s 0 ADV_NONCONN_IND 946 1.082 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 947 1.083 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 948 1.091 07:69:22:f0:72:30 LE 1M LE LL 37 7942\302\265s 0 ADV_NONCONN_IND 949 1.092 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 950 1.092 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 951 1.107 c0:41:04:2e:be:9d LE 1M LE LL 36 14248\302\265s 0 ADV_IND 952 1.107 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 953 1.108 c0:41:04:2e:be:9d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 954 1.112 1e:28:49:84:c5:cd LE 1M LE LL 37 4534\302\265s 0 ADV_NONCONN_IND 955 1.113 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 956 1.115 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2016\302\265s 0 ADV_NONCONN_IND 957 1.116 27:f1:d5:6a:d5:82 LE 1M LE LL 37 610\302\265s 0 ADV_NONCONN_IND 958 1.117 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 959 1.122 5c:9e:d4:03:82:5b LE 1M LE LL 37 4290\302\265s 0 ADV_NONCONN_IND 960 1.123 74:d9:0b:7a:47:5a LE 1M LE LL 6 494\302\265s 0 SCAN_RSP 961 1.123 74:d9:0b:7a:47:4a LE 1M LE LL 23 272\302\265s 0 ADV_IND 962 1.124 0c:6e:66:d7:ed:03 LE 1M LE LL 37 506\302\265s 0 ADV_NONCONN_IND 963 1.124 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 964 1.125 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 965 1.132 50:d3:b9:81:11:84 LE 1M LE LL 12 6891\302\265s 0 SCAN_REQ 966 1.133 7f:e1:7b:e4:24:1c LE 1M LE LL 12 938\302\265s 0 SCAN_REQ 967 1.143 e7:70:80:c3:ad:91 LE 1M LE LL 36 9646\302\265s 0 ADV_IND 968 1.144 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 969 1.144 e7:70:80:c3:ad:91 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 970 1.144 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 276\302\265s 0 ADV_NONCONN_IND 971 1.145 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 972 1.145 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 973 1.151 f1:ff:a7:1a:55:8d LE 1M LE LL 36 4879\302\265s 0 ADV_IND 974 1.151 47:4e:9b:89:59:8e LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 975 1.152 f1:ff:a7:1a:55:8d LE 1M LE LL 36 413\302\265s 0 ADV_IND 976 1.153 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 977 1.162 2b:5e:0e:c8:62:4c LE 1M LE LL 35 8349\302\265s 0 ADV_NONCONN_IND 978 1.162 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 979 1.163 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 980 1.166 c8:de:06:91:ba:b3 LE 1M LE LL 36 3101\302\265s 0 ADV_IND 981 1.167 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 982 1.167 c8:de:06:91:ba:b3 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 983 1.167 c8:de:06:91:ba:b3 LE 1M LE LL 36 137\302\265s 0 ADV_IND 984 1.168 47:4e:9b:89:59:8e LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 985 1.168 c8:de:06:91:ba:b3 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 986 1.168 c8:de:06:91:ba:b3 LE 1M LE LL 36 137\302\265s 0 ADV_IND 987 1.169 71:c9:89:02:1c:fb LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 988 1.169 c8:de:06:91:ba:b3 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 989 1.172 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2541\302\265s 0 ADV_NONCONN_IND 990 1.172 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 991 1.173 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 992 1.179 50:d3:b9:81:11:84 LE 1M LE LL 12 5395\302\265s 0 SCAN_REQ 993 1.185 d6:bf:76:0a:0b:dc LE 1M LE LL 36 5999\302\265s 0 ADV_IND 994 1.186 71:c9:89:02:1c:fb LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 995 1.187 79:70:d9:25:16:e2 LE 1M LE LL 25 560\302\265s 0 ADV_IND 996 1.187 50:9e:bb:01:01:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 997 1.191 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 3862\302\265s 0 ADV_NONCONN_IND 998 1.192 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 999 1.192 07:69:22:f0:72:30 LE 1M LE LL 37 143\302\265s 0 ADV_NONCONN_IND 1000 1.193 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 1001 1.193 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1002 1.206 d2:52:6a:67:61:fd LE 1M LE LL 21 12309\302\265s 0 ADV_IND 1003 1.206 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1004 1.208 d2:52:6a:67:61:fd LE 1M LE LL 21 1010\302\265s 0 ADV_IND 1005 1.209 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1006 1.213 11:fe:ef:ed:38:82 LE 1M LE LL 37 3879\302\265s 0 ADV_NONCONN_IND 1007 1.214 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1008 1.214 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1009 1.215 cc:15:14:59:64:aa LE 1M LE LL 36 73\302\265s 0 ADV_IND 1010 1.215 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1011 1.216 cc:15:14:59:64:aa LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1012 1.216 cc:15:14:59:64:aa LE 1M LE LL 36 134\302\265s 0 ADV_IND 1013 1.222 27:f1:d5:6a:d5:82 LE 1M LE LL 37 5473\302\265s 0 ADV_NONCONN_IND 1014 1.226 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3988\302\265s 0 ADV_NONCONN_IND 1015 1.227 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1016 1.227 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1017 1.229 5c:9e:d4:03:e2:5a LE 1M LE LL 37 1338\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1018 1.23 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1019 1.23 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1020 1.242 5e:93:36:dd:d3:09 LE 1M LE LL 10 11415\302\265s 0 ADV_SCAN_IND 1021 1.242 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1022 1.243 5e:93:36:dd:d3:09 LE 1M LE LL 37 150\302\265s 0 SCAN_RSP 1023 1.244 5e:93:36:dd:d3:09 LE 1M LE LL 10 454\302\265s 0 ADV_SCAN_IND 1024 1.246 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 2031\302\265s 0 ADV_IND 1025 1.246 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1026 1.247 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1027 1.248 d5:80:ce:3a:df:84 LE 1M LE LL 36 902\302\265s 0 ADV_IND 1028 1.249 0d:62:2c:2a:24:88 LE 1M LE LL 37 470\302\265s 0 ADV_NONCONN_IND 1029 1.249 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1030 1.25 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1031 1.255 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5017\302\265s 0 ADV_NONCONN_IND 1032 1.256 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1033 1.256 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1034 1.257 6c:c6:23:80:30:28 LE 1M LE LL 12 931\302\265s 0 SCAN_REQ 1035 1.258 d6:11:ee:07:97:9a LE 1M LE LL 36 415\302\265s 0 ADV_IND 1036 1.259 71:c9:89:02:1c:fb LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 1037 1.262 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2756\302\265s 0 ADV_NONCONN_IND 1038 1.263 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1039 1.263 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1040 1.265 50:d3:b9:81:11:84 LE 1M LE LL 12 836\302\265s 0 SCAN_REQ 1041 1.267 32:43:3c:28:8d:92 LE 1M LE LL 37 2257\302\265s 0 ADV_NONCONN_IND 1042 1.267 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1043 1.277 31:ea:1b:25:0d:1f LE 1M LE LL 37 8831\302\265s 0 ADV_NONCONN_IND 1044 1.277 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1045 1.278 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1046 1.279 16:ed:93:0f:fa:b0 LE 1M LE LL 37 566\302\265s 0 ADV_NONCONN_IND 1047 1.279 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1048 1.28 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1049 1.291 43:bd:56:bd:74:f9 LE 1M LE LL 37 10721\302\265s 0 ADV_NONCONN_IND 1050 1.292 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1051 1.293 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1052 1.294 fb:18:78:3b:10:36 LE 1M LE LL 28 512\302\265s 0 ADV_IND 1053 1.294 7f:ab:0f:33:5d:32 LE 1M LE LL 12 196\302\265s 0 SCAN_REQ 1054 1.308 74:d9:0b:7a:47:5a LE 1M LE LL 23 13532\302\265s 0 ADV_IND 1055 1.32 11:fe:ef:ed:38:82 LE 1M LE LL 37 12045\302\265s 0 ADV_NONCONN_IND 1056 1.33 27:f1:d5:6a:d5:82 LE 1M LE LL 37 9734\302\265s 0 ADV_NONCONN_IND 1057 1.331 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1058 1.332 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1059 1.333 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1022\302\265s 0 ADV_NONCONN_IND 1060 1.334 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1061 1.335 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1062 1.344 7f:ab:0f:33:5d:32 LE 1M LE LL 12 9198\302\265s 0 SCAN_REQ 1063 1.353 0d:62:2c:2a:24:88 LE 1M LE LL 37 9126\302\265s 0 ADV_NONCONN_IND 1064 1.354 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1065 1.357 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2463\302\265s 0 ADV_NONCONN_IND 1066 1.357 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1067 1.358 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1068 1.362 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3870\302\265s 0 ADV_NONCONN_IND 1069 1.363 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1070 1.363 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1071 1.365 d2:52:6a:67:61:fd LE 1M LE LL 21 1683\302\265s 0 ADV_IND 1072 1.366 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1073 1.366 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 1074 1.367 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 1075 1.368 a4:44:a3:07:d8:8f LE 1M LE LL 34 1222\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1076 1.372 6c:c6:23:80:30:28 LE 1M LE LL 12 3311\302\265s 0 SCAN_REQ 1077 1.374 32:43:3c:28:8d:92 LE 1M LE LL 37 1568\302\265s 0 ADV_NONCONN_IND 1078 1.374 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1079 1.381 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6495\302\265s 0 ADV_NONCONN_IND 1080 1.382 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1081 1.382 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1082 1.383 31:ea:1b:25:0d:1f LE 1M LE LL 37 222\302\265s 0 ADV_NONCONN_IND 1083 1.384 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1084 1.384 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1085 1.392 08:ec:5e:66:cd:0d LE 1M LE LL 23 7453\302\265s 0 ADV_NONCONN_IND 1086 1.392 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1087 1.393 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1088 1.393 43:bd:56:bd:74:f9 LE 1M LE LL 37 513\302\265s 0 ADV_NONCONN_IND 1089 1.394 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1090 1.395 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1091 1.396 c5:65:68:79:19:c8 LE 1M LE LL 36 283\302\265s 0 ADV_IND 1092 1.396 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1093 1.404 c1:c8:16:ae:fd:1d LE 1M LE LL 36 7639\302\265s 0 ADV_IND 1094 1.407 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 2588\302\265s 0 ADV_IND 1095 1.415 17:5f:43:7c:0a:89 LE 1M LE LL 23 7686\302\265s 0 ADV_NONCONN_IND 1096 1.422 1f:84:46:51:98:14 LE 1M LE LL 23 6677\302\265s 0 ADV_NONCONN_IND 1097 1.422 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1098 1.427 11:fe:ef:ed:38:82 LE 1M LE LL 37 4323\302\265s 0 ADV_NONCONN_IND 1099 1.428 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1100 1.428 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1101 1.429 6c:c6:23:80:30:28 LE 1M LE LL 12 353\302\265s 0 SCAN_REQ 1102 1.431 5c:9e:d4:03:82:5b LE 1M LE LL 37 1946\302\265s 0 ADV_NONCONN_IND 1103 1.432 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1104 1.433 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1030\302\265s 0 ADV_NONCONN_IND 1105 1.434 0c:6e:66:d7:ed:03 LE 1M LE LL 37 247\302\265s 0 ADV_NONCONN_IND 1106 1.434 0c:6e:66:d7:ed:03 LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 1107 1.436 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1724\302\265s 0 ADV_NONCONN_IND 1108 1.437 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1109 1.438 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1110 1.44 c0:41:04:2e:be:9d LE 1M LE LL 36 2028\302\265s 0 ADV_IND 1111 1.441 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1112 1.441 c0:41:04:2e:be:9d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1113 1.442 c0:41:04:2e:be:9d LE 1M LE LL 36 137\302\265s 0 ADV_IND 1114 1.447 0b:f9:be:c7:0f:fb LE 1M LE LL 23 4689\302\265s 0 ADV_NONCONN_IND 1115 1.455 0d:62:2c:2a:24:88 LE 1M LE LL 37 8536\302\265s 0 ADV_NONCONN_IND 1116 1.456 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1117 1.457 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1118 1.459 7d:30:e4:59:cd:06 LE 1M LE LL 25 2128\302\265s 0 ADV_IND 1119 1.466 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6576\302\265s 0 ADV_NONCONN_IND 1120 1.466 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1121 1.469 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2009\302\265s 0 ADV_NONCONN_IND 1122 1.469 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1123 1.47 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1124 1.482 32:43:3c:28:8d:92 LE 1M LE LL 37 11721\302\265s 0 ADV_NONCONN_IND 1125 1.483 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1126 1.483 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1127 1.486 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2139\302\265s 0 ADV_NONCONN_IND 1128 1.486 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1129 1.487 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1130 1.489 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2340\302\265s 0 ADV_IND 1131 1.49 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1132 1.494 74:d9:0b:7a:47:5a LE 1M LE LL 23 3528\302\265s 0 ADV_IND 1133 1.498 43:bd:56:bd:74:f9 LE 1M LE LL 37 3686\302\265s 0 ADV_NONCONN_IND 1134 1.504 07:69:22:f0:72:30 LE 1M LE LL 37 6049\302\265s 0 ADV_NONCONN_IND 1135 1.505 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 1136 1.505 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1137 1.507 c8:de:06:91:ba:b3 LE 1M LE LL 36 1751\302\265s 0 ADV_IND 1138 1.508 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1139 1.52 d6:bf:76:0a:0b:dc LE 1M LE LL 36 12132\302\265s 0 ADV_IND 1140 1.523 d2:52:6a:67:61:fd LE 1M LE LL 21 2362\302\265s 0 ADV_IND 1141 1.528 11:fe:ef:ed:38:82 LE 1M LE LL 37 5171\302\265s 0 ADV_NONCONN_IND 1142 1.529 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1143 1.529 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1144 1.532 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2167\302\265s 0 ADV_NONCONN_IND 1145 1.533 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1146 1.533 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1147 1.535 1e:28:49:84:c5:cd LE 1M LE LL 37 1668\302\265s 0 ADV_NONCONN_IND 1148 1.536 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1149 1.537 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1150 1.54 5c:9e:d4:03:82:5b LE 1M LE LL 37 3143\302\265s 0 ADV_NONCONN_IND 1151 1.541 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1152 1.542 SamsungE_07:d5:79 LE 1M LE LL 34 1421\302\265s 0 ADV_NONCONN_IND 1153 1.553 64:0d:49:f9:4d:a4 LE 1M LE LL 12 10028\302\265s 0 SCAN_REQ 1154 1.553 cc:15:14:59:64:aa LE 1M LE LL 36 161\302\265s 0 ADV_IND 1155 1.563 0d:62:2c:2a:24:88 LE 1M LE LL 37 9254\302\265s 0 ADV_NONCONN_IND 1156 1.564 64:0d:49:f9:4d:a4 LE 1M LE LL 12 756\302\265s 0 SCAN_REQ 1157 1.566 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1464\302\265s 0 ADV_NONCONN_IND 1158 1.566 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1159 1.572 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5440\302\265s 0 ADV_NONCONN_IND 1160 1.572 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1161 1.573 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1162 1.574 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 563\302\265s 0 ADV_IND[Malformed Packet] 1163 1.575 2b:5e:0e:c8:62:4c LE 1M LE LL 35 303\302\265s 0 ADV_NONCONN_IND 1164 1.575 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1165 1.587 25:5f:bf:53:1f:d7 LE 1M LE LL 37 11944\302\265s 0 ADV_NONCONN_IND 1166 1.588 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1167 1.589 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1168 1.59 31:ea:1b:25:0d:1f LE 1M LE LL 37 850\302\265s 0 ADV_NONCONN_IND 1169 1.59 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1170 1.591 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1171 1.597 64:0d:49:f9:4d:a4 LE 1M LE LL 12 6159\302\265s 0 SCAN_REQ 1172 1.598 d6:11:ee:07:97:9a LE 1M LE LL 36 415\302\265s 0 ADV_IND 1173 1.606 43:bd:56:bd:74:f9 LE 1M LE LL 37 7971\302\265s 0 ADV_NONCONN_IND 1174 1.615 6c:c6:23:80:30:28 LE 1M LE LL 12 8506\302\265s 0 SCAN_REQ 1175 1.618 40:f0:08:9b:56:91 LE 1M LE LL 37 2087\302\265s 0 ADV_SCAN_IND 1176 1.633 11:fe:ef:ed:38:82 LE 1M LE LL 37 14609\302\265s 0 ADV_NONCONN_IND 1177 1.639 1e:28:49:84:c5:cd LE 1M LE LL 37 6235\302\265s 0 ADV_NONCONN_IND 1178 1.64 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1179 1.64 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1180 1.646 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4911\302\265s 0 ADV_NONCONN_IND 1181 1.646 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1182 1.647 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1183 1.648 27:f1:d5:6a:d5:82 LE 1M LE LL 37 478\302\265s 0 ADV_NONCONN_IND 1184 1.648 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1185 1.649 5c:9e:d4:03:82:5b LE 1M LE LL 37 288\302\265s 0 ADV_NONCONN_IND 1186 1.651 6c:c6:23:80:30:28 LE 1M LE LL 12 1364\302\265s 0 SCAN_REQ 1187 1.666 0d:62:2c:2a:24:88 LE 1M LE LL 37 14929\302\265s 0 ADV_NONCONN_IND 1188 1.667 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1189 1.673 d2:52:6a:67:61:fd LE 1M LE LL 21 6228\302\265s 0 ADV_IND 1190 1.674 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1191 1.674 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 1192 1.675 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 1193 1.676 ed:4e:4a:f5:08:6e LE 1M LE LL 14 782\302\265s 0 ADV_NONCONN_IND 1194 1.677 24:c3:d0:ce:d4:37 LE 1M LE LL 37 980\302\265s 0 ADV_NONCONN_IND 1195 1.677 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1196 1.678 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1197 1.682 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3193\302\265s 0 ADV_NONCONN_IND 1198 1.682 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1199 1.683 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1200 1.683 47:4e:9b:89:59:8e LE 1M LE LL 12 375\302\265s 0 SCAN_REQ 1201 1.692 16:ed:93:0f:fa:b0 LE 1M LE LL 37 8221\302\265s 0 ADV_NONCONN_IND 1202 1.692 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1203 1.697 25:5f:bf:53:1f:d7 LE 1M LE LL 37 4115\302\265s 0 ADV_NONCONN_IND 1204 1.697 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1205 1.698 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1206 1.7 d6:bf:03:c5:20:42 LE 1M LE LL 36 1652\302\265s 0 ADV_IND 1207 1.701 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1208 1.701 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1209 1.701 d6:bf:03:c5:20:42 LE 1M LE LL 36 137\302\265s 0 ADV_IND 1210 1.702 47:4e:9b:89:59:8e LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1211 1.702 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1212 1.702 d6:bf:03:c5:20:42 LE 1M LE LL 36 137\302\265s 0 ADV_IND 1213 1.703 7f:e1:7b:e4:24:1c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1214 1.703 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1215 1.707 07:69:22:f0:72:30 LE 1M LE LL 37 3360\302\265s 0 ADV_NONCONN_IND 1216 1.707 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 1217 1.708 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1218 1.709 43:bd:56:bd:74:f9 LE 1M LE LL 37 430\302\265s 0 ADV_NONCONN_IND 1219 1.709 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1220 1.71 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1221 1.727 e5:ea:46:16:3e:1e LE 1M LE LL 36 16070\302\265s 0 ADV_IND 1222 1.727 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1223 1.727 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1224 1.728 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 1225 1.729 e5:ea:46:16:3e:1e LE 1M LE LL 6 1199\302\265s 0 SCAN_RSP 1226 1.731 79:70:d9:25:16:e2 LE 1M LE LL 25 1206\302\265s 0 ADV_IND 1227 1.731 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1228 1.731 79:70:d9:25:16:e2 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1229 1.736 11:fe:ef:ed:38:82 LE 1M LE LL 37 4223\302\265s 0 ADV_NONCONN_IND 1230 1.736 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1231 1.737 c5:65:68:79:19:c8 LE 1M LE LL 36 379\302\265s 0 ADV_IND 1232 1.738 c5:65:68:79:19:c8 LE 1M LE LL 36 353\302\265s 0 ADV_IND 1233 1.739 7f:e1:7b:e4:24:1c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 1234 1.74 49:08:83:d3:3a:6c LE 1M LE LL 12 351\302\265s 0 SCAN_REQ 1235 1.741 1e:28:49:84:c5:cd LE 1M LE LL 37 1245\302\265s 0 ADV_NONCONN_IND 1236 1.742 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1237 1.742 49:08:83:d3:3a:6c LE 1M LE LL 12 407\302\265s 0 SCAN_REQ 1238 1.743 c1:c8:16:ae:fd:1d LE 1M LE LL 36 413\302\265s 0 ADV_IND 1239 1.744 LE 1M LE LL 8 872\302\265s 0 SCAN_REQ[Malformed Packet] 1240 1.751 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6906\302\265s 0 ADV_NONCONN_IND 1241 1.752 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1242 1.752 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1243 1.755 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2348\302\265s 0 ADV_NONCONN_IND 1244 1.756 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1245 1.757 5c:9e:d4:03:82:5b LE 1M LE LL 37 294\302\265s 0 ADV_NONCONN_IND 1246 1.773 4d:42:46:69:3b:05 LE 1M LE LL 245 15914\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1247 1.777 1c:2b:bf:5c:a9:12 LE 1M LE LL 165 2468\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1248 1.781 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1703\302\265s 0 ADV_NONCONN_IND 1249 1.788 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6942\302\265s 0 ADV_NONCONN_IND 1250 1.788 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1251 1.789 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1252 1.8 16:ed:93:0f:fa:b0 LE 1M LE LL 37 10721\302\265s 0 ADV_NONCONN_IND 1253 1.801 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1254 1.801 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1255 1.803 dd:b9:3b:45:59:8b LE 1M LE LL 24 1134\302\265s 0 ADV_IND[Malformed Packet] 1256 1.804 31:ea:1b:25:0d:1f LE 1M LE LL 37 599\302\265s 0 ADV_NONCONN_IND 1257 1.804 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1258 1.806 32:43:3c:28:8d:92 LE 1M LE LL 37 1318\302\265s 0 ADV_NONCONN_IND 1259 1.806 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1260 1.807 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1261 1.813 07:69:22:f0:72:30 LE 1M LE LL 37 5564\302\265s 0 ADV_NONCONN_IND 1262 1.813 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 1263 1.814 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1264 1.819 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 4223\302\265s 0 ADV_NONCONN_IND 1265 1.819 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1266 1.819 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1267 1.823 e7:70:80:c3:ad:91 LE 1M LE LL 36 2929\302\265s 0 ADV_IND 1268 1.823 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1269 1.823 e7:70:80:c3:ad:91 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1270 1.824 e2:55:50:d0:9e:92 LE 1M LE LL 111 136\302\265s 0 SCAN_REQ 1271 1.827 d2:52:6a:67:61:fd LE 1M LE LL 21 2882\302\265s 0 ADV_IND 1272 1.832 f1:ff:a7:1a:55:8d LE 1M LE LL 36 4216\302\265s 0 ADV_IND 1273 1.832 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1274 1.833 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1275 1.833 f1:ff:a7:1a:55:8d LE 1M LE LL 36 134\302\265s 0 ADV_IND 1276 1.838 11:fe:ef:ed:38:82 LE 1M LE LL 37 4122\302\265s 0 ADV_NONCONN_IND 1277 1.841 c8:de:06:91:ba:b3 LE 1M LE LL 36 3103\302\265s 0 ADV_IND 1278 1.842 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1279 1.844 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2240\302\265s 0 ADV_NONCONN_IND 1280 1.845 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1281 1.848 1e:28:49:84:c5:cd LE 1M LE LL 37 2917\302\265s 0 ADV_NONCONN_IND 1282 1.848 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1283 1.849 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1284 1.856 27:f1:d5:6a:d5:82 LE 1M LE LL 37 7005\302\265s 0 ADV_NONCONN_IND 1285 1.857 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1286 1.858 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1287 1.86 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1491\302\265s 0 ADV_NONCONN_IND 1288 1.861 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1289 1.861 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1290 1.87 74:d9:0b:7a:47:5a LE 1M LE LL 23 8271\302\265s 0 ADV_IND 1291 1.87 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1292 1.875 0d:62:2c:2a:24:88 LE 1M LE LL 37 4965\302\265s 0 ADV_NONCONN_IND 1293 1.876 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1294 1.881 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5009\302\265s 0 ADV_NONCONN_IND 1295 1.882 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1296 1.882 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1297 1.883 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 339\302\265s 0 ADV_NONCONN_IND 1298 1.884 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1299 1.884 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1300 1.885 49:08:83:d3:3a:6c LE 1M LE LL 12 837\302\265s 0 SCAN_REQ 1301 1.887 50:d3:b9:81:11:84 LE 1M LE LL 12 1209\302\265s 0 SCAN_REQ 1302 1.889 cc:15:14:59:64:aa LE 1M LE LL 36 2203\302\265s 0 ADV_IND 1303 1.894 e5:ea:46:16:3e:1e LE 1M LE LL 36 4500\302\265s 0 ADV_IND 1304 1.895 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1305 1.895 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1306 1.895 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 1307 1.896 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1308 1.896 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1309 1.896 e5:ea:46:16:3e:1e LE 1M LE LL 36 138\302\265s 0 ADV_IND 1310 1.897 25:5f:bf:53:1f:d7 LE 1M LE LL 37 812\302\265s 0 ADV_NONCONN_IND 1311 1.898 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1312 1.899 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1313 1.903 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 3719\302\265s 0 ADV_IND 1314 1.903 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1315 1.904 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1316 1.904 c2:f4:8b:c3:ec:00 LE 1M LE LL 36 137\302\265s 0 ADV_IND 1317 1.905 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 741\302\265s 0 ADV_IND 1318 1.907 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1609\302\265s 0 ADV_NONCONN_IND 1319 1.907 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1320 1.908 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1321 1.913 32:43:3c:28:8d:92 LE 1M LE LL 37 4254\302\265s 0 ADV_NONCONN_IND 1322 1.913 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1323 1.914 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1324 1.917 07:69:22:f0:72:30 LE 1M LE LL 37 3063\302\265s 0 ADV_NONCONN_IND 1325 1.918 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 1326 1.918 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1327 1.921 43:bd:56:bd:74:f9 LE 1M LE LL 37 2320\302\265s 0 ADV_NONCONN_IND 1328 1.922 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1329 1.923 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1330 1.929 71:c9:89:02:1c:fb LE 1M LE LL 12 6050\302\265s 0 SCAN_REQ 1331 1.93 50:d3:b9:81:11:84 LE 1M LE LL 12 932\302\265s 0 SCAN_REQ 1332 1.931 d6:11:16:57:f1:d0 LE 1M LE LL 36 416\302\265s 0 ADV_IND 1333 1.932 d5:80:ce:3a:df:84 LE 1M LE LL 36 411\302\265s 0 ADV_IND 1334 1.937 71:c9:89:02:1c:fb LE 1M LE LL 12 5549\302\265s 0 SCAN_REQ 1335 1.938 d6:11:ee:07:97:9a LE 1M LE LL 36 415\302\265s 0 ADV_IND 1336 1.939 11:fe:ef:ed:38:82 LE 1M LE LL 37 344\302\265s 0 ADV_NONCONN_IND 1337 1.948 3a:d1:ca:1d:4d:de LE 1M LE LL 26 9042\302\265s 0 ADV_NONCONN_IND 1338 1.949 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1339 1.95 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1340 1.954 1e:28:49:84:c5:cd LE 1M LE LL 37 4169\302\265s 0 ADV_NONCONN_IND 1341 1.955 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1342 1.955 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1343 1.956 27:f1:d5:6a:d5:82 LE 1M LE LL 37 749\302\265s 0 ADV_NONCONN_IND 1344 1.957 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1345 1.958 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1346 1.963 d6:2c:05:d0:15:49 LE 1M LE LL 37 4753\302\265s 0 ADV_IND 1347 1.965 50:d3:b9:81:11:84 LE 1M LE LL 12 1480\302\265s 0 SCAN_REQ 1348 1.971 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5335\302\265s 0 ADV_NONCONN_IND 1349 1.978 0d:62:2c:2a:24:88 LE 1M LE LL 37 7022\302\265s 0 ADV_NONCONN_IND 1350 1.979 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1351 1.979 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1352 1.98 71:c9:89:02:1c:fb LE 1M LE LL 12 330\302\265s 0 SCAN_REQ 1353 1.981 d2:52:6a:67:61:fd LE 1M LE LL 21 1010\302\265s 0 ADV_IND 1354 1.981 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1355 1.982 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 1356 1.983 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 1357 1.986 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3485\302\265s 0 ADV_NONCONN_IND 1358 1.987 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1359 1.987 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1360 1.992 40:f1:08:9b:56:91 LE 1M LE LL 37 4076\302\265s 0 ADV_SCAN_IND 1361 1.997 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4947\302\265s 0 ADV_NONCONN_IND 1362 1.998 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1363 1.999 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1321\302\265s 0 ADV_NONCONN_IND 1364 2 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1365 2 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1366 2.003 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 1691\302\265s 0 ADV_IND 1367 2.003 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1368 2.003 7f:f8:8c:bb:a1:a8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1369 2.004 50:d3:b9:81:11:84 LE 1M LE LL 12 554\302\265s 0 SCAN_REQ 1370 2.005 7f:f8:9c:bb:a1:a8 LE 1M LE LL 24 410\302\265s 0 ADV_IND 1371 2.013 LE 1M LE LL 37 8119\302\265s 0 Unknown 1372 2.014 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1373 2.014 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1374 2.015 32:43:3c:28:8d:92 LE 1M LE LL 37 69\302\265s 0 ADV_NONCONN_IND 1375 2.015 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1376 2.016 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1377 2.017 08:ec:5e:66:cd:0d LE 1M LE LL 23 939\302\265s 0 ADV_NONCONN_IND 1378 2.017 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1379 2.018 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1380 2.02 07:69:22:f0:72:30 LE 1M LE LL 37 2317\302\265s 0 ADV_NONCONN_IND 1381 2.021 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 1382 2.021 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1383 2.025 43:bd:56:bd:74:f9 LE 1M LE LL 37 2931\302\265s 0 ADV_NONCONN_IND 1384 2.026 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1385 2.026 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1386 2.04 d6:bf:03:c5:20:42 LE 1M LE LL 36 13212\302\265s 0 ADV_IND 1387 2.043 11:fe:ef:ed:38:82 LE 1M LE LL 37 2238\302\265s 0 ADV_NONCONN_IND 1388 2.043 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1389 2.045 1f:84:46:51:98:14 LE 1M LE LL 23 1930\302\265s 0 ADV_NONCONN_IND 1390 2.054 74:d9:0b:7a:47:5a LE 1M LE LL 23 8567\302\265s 0 ADV_IND 1391 2.055 1e:28:49:84:c5:cd LE 1M LE LL 37 142\302\265s 0 ADV_NONCONN_IND 1392 2.055 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1393 2.056 74:d9:0b:7a:47:5a LE 1M LE LL 23 209\302\265s 0 ADV_IND 1394 2.057 c4:d3:3f:79:a7:16 LE 1M LE LL 36 1292\302\265s 0 ADV_IND 1395 2.063 27:f1:d5:6a:d5:82 LE 1M LE LL 37 5274\302\265s 0 ADV_NONCONN_IND 1396 2.064 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1043\302\265s 0 ADV_NONCONN_IND 1397 2.065 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1398 2.066 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1399 2.071 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4932\302\265s 0 ADV_NONCONN_IND 1400 2.072 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1401 2.072 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1402 2.077 0b:f9:be:c7:0f:fb LE 1M LE LL 23 4348\302\265s 0 ADV_NONCONN_IND 1403 2.078 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1404 2.078 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1405 2.087 0d:62:2c:2a:24:88 LE 1M LE LL 37 8496\302\265s 0 ADV_NONCONN_IND 1406 2.087 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1407 2.088 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1408 2.089 24:c3:d0:ce:d4:37 LE 1M LE LL 37 634\302\265s 0 ADV_NONCONN_IND 1409 2.089 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1410 2.09 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1411 2.091 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 966\302\265s 0 ADV_NONCONN_IND 1412 2.092 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1413 2.092 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1414 2.105 2b:5e:0e:c8:62:4c LE 1M LE LL 35 11985\302\265s 0 ADV_NONCONN_IND 1415 2.105 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1416 2.106 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1417 2.106 25:5f:bf:53:1f:d7 LE 1M LE LL 37 69\302\265s 0 ADV_NONCONN_IND 1418 2.107 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1419 2.107 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1420 2.115 f4:08:ad:3c:61:f6 LE 1M LE LL 14 6776\302\265s 0 ADV_NONCONN_IND 1421 2.115 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 1422 2.115 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 1423 2.118 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2804\302\265s 0 ADV_NONCONN_IND 1424 2.119 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1425 2.119 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1426 2.12 32:43:3c:28:8d:92 LE 1M LE LL 37 497\302\265s 0 ADV_NONCONN_IND 1427 2.121 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1428 2.121 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1429 2.122 31:ea:1b:25:0d:1f LE 1M LE LL 37 80\302\265s 0 ADV_NONCONN_IND 1430 2.122 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1431 2.123 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1432 2.132 43:bd:56:bd:74:f9 LE 1M LE LL 37 9051\302\265s 0 ADV_NONCONN_IND 1433 2.133 43:bd:56:3d:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1434 2.134 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1435 2.139 d2:52:6a:67:61:fd LE 1M LE LL 21 5060\302\265s 0 ADV_IND 1436 2.141 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1437 2.143 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1438 2.143 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1439 2.143 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 1440 2.151 11:fe:ef:ed:38:82 LE 1M LE LL 37 7957\302\265s 0 ADV_NONCONN_IND 1441 2.152 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1442 2.153 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1443 2.156 e7:70:80:c3:ad:91 LE 1M LE LL 36 3336\302\265s 0 ADV_IND 1444 2.157 3a:d1:ca:1d:4d:de LE 1M LE LL 26 344\302\265s 0 ADV_NONCONN_IND 1445 2.158 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1446 2.158 72:10:b2:16:c9:46 LE 1M LE LL 12 217\302\265s 0 SCAN_REQ 1447 2.162 1e:28:49:84:c5:cd LE 1M LE LL 37 3264\302\265s 0 ADV_NONCONN_IND 1448 2.162 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1449 2.163 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1450 2.168 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4489\302\265s 0 ADV_NONCONN_IND 1451 2.168 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1452 2.169 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1453 2.172 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2254\302\265s 0 ADV_IND 1454 2.173 64:0d:49:f9:4d:a4 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 1455 2.174 f1:ff:a7:1a:55:8d LE 1M LE LL 36 414\302\265s 0 ADV_IND 1456 2.174 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1457 2.175 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1458 2.18 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5199\302\265s 0 ADV_NONCONN_IND 1459 2.181 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1460 2.181 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1461 2.189 0d:62:2c:2a:24:88 LE 1M LE LL 37 7029\302\265s 0 ADV_NONCONN_IND 1462 2.189 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1463 2.19 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1464 2.194 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4333\302\265s 0 ADV_NONCONN_IND 1465 2.195 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1466 2.196 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1467 2.197 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1058\302\265s 0 ADV_NONCONN_IND 1468 2.197 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1469 2.198 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1470 2.211 25:5f:bf:53:1f:d7 LE 1M LE LL 37 12200\302\265s 0 ADV_NONCONN_IND 1471 2.211 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1472 2.212 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1473 2.223 cc:15:14:59:64:aa LE 1M LE LL 36 11350\302\265s 0 ADV_IND 1474 2.225 64:0d:49:f9:4d:a4 LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 1475 2.227 31:ea:1b:25:0d:1f LE 1M LE LL 37 1694\302\265s 0 ADV_NONCONN_IND 1476 2.228 07:69:22:f0:72:30 LE 1M LE LL 37 865\302\265s 0 ADV_NONCONN_IND 1477 2.228 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 1478 2.229 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1479 2.233 43:bd:56:bd:74:f9 LE 1M LE LL 37 4161\302\265s 0 ADV_NONCONN_IND 1480 2.234 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1481 2.235 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1482 2.252 11:fe:ef:ed:38:82 LE 1M LE LL 37 16523\302\265s 0 ADV_NONCONN_IND 1483 2.253 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1484 2.253 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1485 2.258 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4672\302\265s 0 ADV_NONCONN_IND 1486 2.259 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1487 2.26 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1488 2.267 1e:28:49:84:c5:cd LE 1M LE LL 37 6664\302\265s 0 ADV_NONCONN_IND 1489 2.267 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1490 2.268 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1491 2.269 d5:80:ce:3a:df:84 LE 1M LE LL 36 692\302\265s 0 ADV_IND 1492 2.27 67:1d:48:f9:0d:a4 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 1493 2.273 d6:11:ee:07:97:9a LE 1M LE LL 36 2310\302\265s 0 ADV_IND 1494 2.276 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 3370\302\265s 0 ADV_IND 1495 2.277 79:70:d9:25:16:e2 LE 1M LE LL 25 276\302\265s 0 ADV_IND 1496 2.277 79:70:d9:25:16:e2 LE 1M LE LL 25 369\302\265s 0 ADV_IND 1497 2.278 79:70:d9:25:16:e2 LE 1M LE LL 6 475\302\265s 0 SCAN_RSP 1498 2.283 5c:9e:d4:03:82:5b LE 1M LE LL 37 4533\302\265s 0 ADV_NONCONN_IND 1499 2.285 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1640\302\265s 0 ADV_NONCONN_IND 1500 2.286 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1501 2.286 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1502 2.289 0d:62:2c:2a:24:88 LE 1M LE LL 37 2033\302\265s 0 ADV_NONCONN_IND 1503 2.289 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1504 2.29 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1505 2.299 d2:52:6a:67:61:fd LE 1M LE LL 21 8675\302\265s 0 ADV_IND 1506 2.3 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1507 2.302 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1184\302\265s 0 ADV_NONCONN_IND 1508 2.306 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4185\302\265s 0 ADV_NONCONN_IND 1509 2.307 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1510 2.307 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1511 2.314 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6575\302\265s 0 ADV_NONCONN_IND 1512 2.315 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1513 2.315 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1514 2.328 16:ed:93:0f:fa:b0 LE 1M LE LL 37 11672\302\265s 0 ADV_NONCONN_IND 1515 2.328 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1516 2.329 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1517 2.329 7f:e1:7b:e4:24:1c LE 1M LE LL 12 410\302\265s 0 SCAN_REQ 1518 2.333 31:ea:1b:25:0d:1f LE 1M LE LL 37 3280\302\265s 0 ADV_NONCONN_IND 1519 2.333 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1520 2.334 32:43:3c:28:8d:92 LE 1M LE LL 37 69\302\265s 0 ADV_NONCONN_IND 1521 2.334 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1522 2.335 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1523 2.336 07:69:22:f0:72:30 LE 1M LE LL 37 559\302\265s 0 ADV_NONCONN_IND 1524 2.337 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 1525 2.337 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1526 2.351 7f:e1:7b:e4:24:1c LE 1M LE LL 12 13639\302\265s 0 SCAN_REQ 1527 2.357 11:fe:ef:ed:38:82 LE 1M LE LL 37 5719\302\265s 0 ADV_NONCONN_IND 1528 2.358 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1529 2.363 7f:e1:7b:e4:24:1c LE 1M LE LL 12 4780\302\265s 0 SCAN_REQ 1530 2.363 40:f0:08:9b:56:91 LE 1M LE LL 37 548\302\265s 0 ADV_SCAN_IND 1531 2.366 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2156\302\265s 0 ADV_NONCONN_IND 1532 2.366 7f:e1:7b:e4:24:1c LE 1M LE LL 12 215\302\265s 0 SCAN_REQ 1533 2.372 1e:28:49:84:c5:cd LE 1M LE LL 37 5574\302\265s 0 ADV_NONCONN_IND 1534 2.373 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1535 2.38 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6990\302\265s 0 ADV_NONCONN_IND 1536 2.381 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1537 2.382 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1538 2.383 7f:e1:7b:e4:24:1c LE 1M LE LL 12 379\302\265s 0 SCAN_REQ 1539 2.394 c4:d3:3f:79:a7:16 LE 1M LE LL 36 11306\302\265s 0 ADV_IND 1540 2.395 0c:6e:66:d7:ed:03 LE 1M LE LL 37 523\302\265s 0 ADV_NONCONN_IND 1541 2.395 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 85\302\265s 0 ADV_IND 1542 2.408 7f:e1:7b:e4:24:1c LE 1M LE LL 12 12484\302\265s 0 SCAN_REQ 1543 2.409 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 925\302\265s 0 ADV_NONCONN_IND 1544 2.41 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1545 2.411 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1056\302\265s 0 ADV_NONCONN_IND 1546 2.412 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1547 2.412 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1548 2.416 c5:65:68:79:19:c8 LE 1M LE LL 36 3010\302\265s 0 ADV_IND 1549 2.42 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3476\302\265s 0 ADV_NONCONN_IND 1550 2.42 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1551 2.423 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2572\302\265s 0 ADV_NONCONN_IND 1552 2.424 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1553 2.424 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1554 2.431 74:d9:0b:7a:47:5a LE 1M LE LL 23 6236\302\265s 0 ADV_IND 1555 2.432 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1353\302\265s 0 ADV_NONCONN_IND 1556 2.433 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1557 2.436 07:69:22:f0:72:30 LE 1M LE LL 37 2537\302\265s 0 ADV_NONCONN_IND 1558 2.436 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1559 2.437 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1560 2.439 31:ea:1b:25:0d:1f LE 1M LE LL 37 1146\302\265s 0 ADV_NONCONN_IND 1561 2.439 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1562 2.44 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1563 2.441 32:43:3c:28:8d:92 LE 1M LE LL 37 694\302\265s 0 ADV_NONCONN_IND 1564 2.441 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1565 2.442 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1566 2.449 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 6322\302\265s 0 ADV_NONCONN_IND 1567 2.449 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1568 2.449 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1569 2.451 cd:45:0c:ce:f1:94 LE 1M LE LL 37 1255\302\265s 0 ADV_IND 1570 2.456 d2:52:6a:67:61:fd LE 1M LE LL 21 5229\302\265s 0 ADV_IND 1571 2.458 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1572 2.461 c0:41:04:2e:be:9d LE 1M LE LL 36 2343\302\265s 0 ADV_IND 1573 2.464 11:fe:ef:ed:38:82 LE 1M LE LL 37 3450\302\265s 0 ADV_NONCONN_IND 1574 2.465 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1575 2.467 d6:2c:05:d0:15:49 LE 1M LE LL 37 1511\302\265s 0 ADV_IND 1576 2.468 d6:2c:05:d0:15:49 LE 1M LE LL 37 395\302\265s 0 ADV_IND 1577 2.468 d6:2c:05:d0:15:49 LE 1M LE LL 37 395\302\265s 0 ADV_IND[Malformed Packet] 1578 2.472 1e:28:49:84:c5:cd LE 1M LE LL 37 3432\302\265s 0 ADV_NONCONN_IND 1579 2.473 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1580 2.473 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1581 2.486 27:f1:d5:6a:d5:82 LE 1M LE LL 37 12618\302\265s 0 ADV_NONCONN_IND 1582 2.487 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1583 2.488 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1584 2.49 0d:62:2c:2a:24:88 LE 1M LE LL 37 1412\302\265s 0 ADV_NONCONN_IND 1585 2.49 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1586 2.491 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1587 2.492 5c:9e:d4:03:82:5b LE 1M LE LL 37 333\302\265s 0 ADV_NONCONN_IND 1588 2.492 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1589 2.493 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1590 2.497 e7:70:80:c3:ad:91 LE 1M LE LL 36 4204\302\265s 0 ADV_IND 1591 2.504 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6436\302\265s 0 ADV_NONCONN_IND 1592 2.505 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1593 2.511 24:c3:d0:ce:d4:37 LE 1M LE LL 37 6028\302\265s 0 ADV_NONCONN_IND 1594 2.512 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1595 2.512 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1596 2.516 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3469\302\265s 0 ADV_NONCONN_IND 1597 2.517 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1598 2.517 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1599 2.526 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7865\302\265s 0 ADV_NONCONN_IND 1600 2.526 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1601 2.527 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1602 2.528 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1375\302\265s 0 ADV_NONCONN_IND 1603 2.529 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1604 2.53 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1605 2.535 d6:bf:76:0a:0b:dc LE 1M LE LL 36 5257\302\265s 0 ADV_IND 1606 2.536 d5:80:30:95:af:b7 LE 1M LE LL 34 150\302\265s 0 CONNECT_IND 1607 2.536 16:ed:93:0f:fa:b0 LE 1M LE LL 37 161\302\265s 0 ADV_NONCONN_IND 1608 2.537 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1609 2.537 43:bd:56:bd:74:f9 LE 1M LE LL 37 86\302\265s 0 ADV_NONCONN_IND 1610 2.538 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1611 2.539 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1612 2.541 32:43:3c:28:8d:92 LE 1M LE LL 37 1493\302\265s 0 ADV_NONCONN_IND 1613 2.541 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1614 2.542 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1615 2.545 31:ea:1b:25:0d:1f LE 1M LE LL 37 3209\302\265s 0 ADV_NONCONN_IND 1616 2.546 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1617 2.547 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1618 2.55 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 3073\302\265s 0 ADV_IND 1619 2.553 79:70:d9:25:16:e2 LE 1M LE LL 25 2243\302\265s 0 ADV_IND 1620 2.558 e5:ea:46:16:3e:1e LE 1M LE LL 36 5136\302\265s 0 ADV_IND 1621 2.563 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4347\302\265s 0 ADV_IND 1622 2.564 71:c9:89:02:1c:fb LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 1623 2.565 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 1624 2.571 11:fe:ef:ed:38:82 LE 1M LE LL 37 5939\302\265s 0 ADV_NONCONN_IND 1625 2.571 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1626 2.572 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1627 2.578 3a:d1:ca:1d:4d:de LE 1M LE LL 26 5928\302\265s 0 ADV_NONCONN_IND 1628 2.579 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1629 2.58 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1630 2.591 27:f1:d5:6a:d5:82 LE 1M LE LL 37 11391\302\265s 0 ADV_NONCONN_IND 1631 2.592 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1632 2.593 0d:62:2c:2a:24:88 LE 1M LE LL 37 225\302\265s 0 ADV_NONCONN_IND 1633 2.606 d2:52:6a:67:61:fd LE 1M LE LL 21 12762\302\265s 0 ADV_IND 1634 2.608 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1635 2.608 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 1636 2.608 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 1637 2.609 d2:52:6a:67:61:fd LE 1M LE LL 21 629\302\265s 0 ADV_IND 1638 2.61 SamsungE_07:d8:8f LE 1M LE LL 34 234\302\265s 0 ADV_NONCONN_IND 1639 2.615 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5114\302\265s 0 ADV_NONCONN_IND 1640 2.616 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1641 2.616 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1642 2.618 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 969\302\265s 0 ADV_NONCONN_IND 1643 2.618 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1644 2.619 50:d3:b9:81:11:84 LE 1M LE LL 10 185\302\265s 0 SCAN_REQ[Malformed Packet] 1645 2.62 61:a9:08:2f:b7:16 LE 1M LE LL 37 1370\302\265s 0 ADV_NONCONN_IND 1646 2.621 69:a9:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1647 2.624 SamsungE_07:d5:79 LE 1M LE LL 34 2291\302\265s 0 ADV_NONCONN_IND 1648 2.628 25:5f:bf:53:1f:d7 LE 1M LE LL 37 4106\302\265s 0 ADV_NONCONN_IND 1649 2.629 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1650 2.629 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1651 2.633 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3875\302\265s 0 ADV_NONCONN_IND 1652 2.634 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1653 2.635 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1654 2.643 96:9d:fd:95:fa:b0 LE 1M LE LL 37 8235\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1655 2.644 08:ec:5e:66:cd:0d LE 1M LE LL 23 95\302\265s 0 ADV_NONCONN_IND 1656 2.644 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1657 2.647 07:69:22:f0:72:30 LE 1M LE LL 37 2268\302\265s 0 ADV_NONCONN_IND 1658 2.647 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 1659 2.648 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1660 2.654 31:ea:1b:25:0d:1f LE 1M LE LL 37 6141\302\265s 0 ADV_NONCONN_IND 1661 2.655 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1662 2.655 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1663 2.673 17:5f:43:7c:0a:89 LE 1M LE LL 23 17039\302\265s 0 ADV_NONCONN_IND 1664 2.678 11:fe:ef:ed:38:82 LE 1M LE LL 37 5231\302\265s 0 ADV_NONCONN_IND 1665 2.679 11:fe:ef:ed:38:82 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 1666 2.681 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1552\302\265s 0 ADV_NONCONN_IND 1667 2.681 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1668 2.682 4b:a8:28:94:c5:c1 LE 1M LE LL 29 386\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1669 2.695 0d:62:2c:2a:24:88 LE 1M LE LL 37 13011\302\265s 0 ADV_NONCONN_IND 1670 2.696 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1671 2.697 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1672 2.698 27:f1:d5:6a:d5:82 LE 1M LE LL 37 690\302\265s 0 ADV_NONCONN_IND 1673 2.698 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1674 2.699 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1675 2.703 fa:1f:24:e3:99:5d LE 1M LE LL 14 2842\302\265s 0 ADV_NONCONN_IND 1676 2.705 5c:9e:d4:03:82:5b LE 1M LE LL 37 2068\302\265s 0 ADV_NONCONN_IND 1677 2.705 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1678 2.707 0b:f9:be:c7:0f:fb LE 1M LE LL 23 1422\302\265s 0 ADV_NONCONN_IND 1679 2.708 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1680 2.708 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1681 2.711 47:4e:9b:89:59:8e LE 1M LE LL 12 2243\302\265s 0 SCAN_REQ 1682 2.711 d6:bf:03:c5:20:42 LE 1M LE LL 36 415\302\265s 0 ADV_IND 1683 2.712 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 1684 2.712 d6:bf:03:c5:20:42 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1685 2.712 d6:bf:03:c5:20:42 LE 1M LE LL 36 137\302\265s 0 ADV_IND 1686 2.713 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1687 2.713 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1688 2.716 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2522\302\265s 0 ADV_NONCONN_IND 1689 2.716 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1690 2.717 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1691 2.717 0c:6e:66:d7:ed:03 LE 1M LE LL 37 233\302\265s 0 ADV_NONCONN_IND 1692 2.718 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1693 2.719 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1694 2.721 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1612\302\265s 0 ADV_NONCONN_IND 1695 2.721 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1696 2.722 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1697 2.723 49:a9:48:2f:b7:16 LE 1M LE LL 37 533\302\265s 0 ADV_NONCONN_IND 1698 2.729 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6259\302\265s 0 ADV_NONCONN_IND 1699 2.73 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1700 2.732 c8:74:00:1c:d2:d7 LE 1M LE LL 36 2162\302\265s 0 ADV_IND 1701 2.734 71:c9:89:02:1c:fb LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 1702 2.734 73:c4:79:40:57:18 LE 1M LE LL 21 223\302\265s 0 ADV_IND[Malformed Packet] 1703 2.74 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5456\302\265s 0 ADV_NONCONN_IND 1704 2.74 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1705 2.741 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1706 2.746 c1:c8:16:ae:fd:1d LE 1M LE LL 36 4385\302\265s 0 ADV_IND 1707 2.746 57:4e:9a:09:59:ce LE 1M LE LL 14 149\302\265s 0 SCAN_REQ 1708 2.747 c1:c8:16:ae:fd:1d LE 1M LE LL 36 398\302\265s 0 ADV_IND 1709 2.748 07:69:22:f0:72:30 LE 1M LE LL 37 644\302\265s 0 ADV_NONCONN_IND 1710 2.748 c5:65:68:79:19:c8 LE 1M LE LL 36 222\302\265s 0 ADV_IND 1711 2.749 47:4e:9b:89:59:8e LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 1712 2.749 c5:65:68:79:19:c8 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1713 2.749 c5:65:68:79:19:c8 LE 1M LE LL 36 137\302\265s 0 ADV_IND 1714 2.751 c5:65:68:79:19:c8 LE 1M LE LL 36 741\302\265s 0 ADV_IND 1715 2.751 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1716 2.751 e5:55:68:fd:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1717 2.752 16:ed:93:0f:fa:b0 LE 1M LE LL 37 444\302\265s 0 ADV_NONCONN_IND 1718 2.752 16:ed:93:0f:fa:b0 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 1719 2.753 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1720 2.757 d2:52:6a:67:61:fd LE 1M LE LL 21 3620\302\265s 0 ADV_IND 1721 2.759 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1722 2.759 47:4e:9b:89:59:8e LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1723 2.759 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 1724 2.76 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 1725 2.769 c4:23:b5:60:6c:09 LE 1M LE LL 14 8092\302\265s 0 ADV_NONCONN_IND 1726 2.774 SamsungE_07:d5:79 LE 1M LE LL 34 5250\302\265s 0 ADV_NONCONN_IND 1727 2.775 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 1728 2.781 11:fe:ef:ed:38:82 LE 1M LE LL 37 5539\302\265s 0 ADV_NONCONN_IND 1729 2.781 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1730 2.782 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1731 2.787 1e:28:49:84:c5:cd LE 1M LE LL 37 4986\302\265s 0 ADV_NONCONN_IND 1732 2.788 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1733 2.788 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1734 2.789 3a:d1:ca:1d:4d:de LE 1M LE LL 26 705\302\265s 0 ADV_NONCONN_IND 1735 2.79 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1736 2.791 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1737 2.796 c0:41:04:2e:be:9d LE 1M LE LL 36 4446\302\265s 0 ADV_IND 1738 2.803 27:f1:d5:6a:d5:82 LE 1M LE LL 37 7417\302\265s 0 ADV_NONCONN_IND 1739 2.804 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1740 2.805 dd:b9:3b:45:59:8b LE 1M LE LL 24 804\302\265s 0 ADV_IND 1741 2.808 74:d9:0b:7a:47:5a LE 1M LE LL 23 2332\302\265s 0 ADV_IND 1742 2.809 64:0d:49:f9:4d:a4 LE 1M LE LL 12 928\302\265s 0 SCAN_REQ 1743 2.823 24:c3:d0:ce:d4:37 LE 1M LE LL 37 13117\302\265s 0 ADV_NONCONN_IND 1744 2.823 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1745 2.824 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1746 2.83 7d:30:e4:59:cd:06 LE 1M LE LL 25 6106\302\265s 0 ADV_IND 1747 2.831 25:5f:bf:53:1f:d7 LE 1M LE LL 37 186\302\265s 0 ADV_NONCONN_IND 1748 2.831 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1749 2.832 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1750 2.836 e4:6a:92:fe:cc:4a LE 1M LE LL 36 4056\302\265s 0 ADV_IND 1751 2.837 e5:ea:9a:fe:cc:4a LE 1M LE LL 36 353\302\265s 0 ADV_IND 1752 2.839 e7:70:80:c3:ad:91 LE 1M LE LL 36 1656\302\265s 0 ADV_IND 1753 2.839 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 1754 2.84 e7:70:80:c3:ad:91 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1755 2.841 f1:ff:a7:1a:55:8d LE 1M LE LL 36 737\302\265s 0 ADV_IND 1756 2.843 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2412\302\265s 0 ADV_NONCONN_IND 1757 2.844 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1758 2.851 32:43:3c:28:8d:92 LE 1M LE LL 37 6462\302\265s 0 ADV_NONCONN_IND 1759 2.851 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1760 2.852 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1761 2.855 07:69:22:f0:72:30 LE 1M LE LL 37 3058\302\265s 0 ADV_NONCONN_IND 1762 2.856 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 1763 2.856 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1764 2.862 31:ea:1b:25:0d:1f LE 1M LE LL 37 4904\302\265s 0 ADV_NONCONN_IND 1765 2.862 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1766 2.863 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1767 2.885 e5:ea:46:16:3e:1e LE 1M LE LL 36 22015\302\265s 0 ADV_IND 1768 2.89 11:fe:ef:ed:38:82 LE 1M LE LL 37 4528\302\265s 0 ADV_NONCONN_IND 1769 2.891 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1770 2.891 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 356\302\265s 0 ADV_IND 1771 2.892 3a:d1:ca:1d:4d:de LE 1M LE LL 26 198\302\265s 0 ADV_NONCONN_IND 1772 2.893 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1773 2.893 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1774 2.897 0d:62:2c:2a:24:88 LE 1M LE LL 37 2968\302\265s 0 ADV_NONCONN_IND 1775 2.897 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1776 2.898 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1777 2.906 41:9c:87:78:87:2b LE 1M LE LL 23 8005\302\265s 0 ADV_IND 1778 2.912 d2:52:6a:67:61:fd LE 1M LE LL 21 5969\302\265s 0 ADV_IND 1779 2.914 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1780 2.914 64:0d:49:f9:4d:a4 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1781 2.919 5c:9e:d4:03:82:5b LE 1M LE LL 37 4557\302\265s 0 ADV_NONCONN_IND 1782 2.92 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1783 2.92 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1784 2.923 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1864\302\265s 0 ADV_NONCONN_IND 1785 2.923 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1786 2.924 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1787 2.927 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2222\302\265s 0 ADV_NONCONN_IND 1788 2.927 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1789 2.929 64:0d:49:f9:4d:a4 LE 1M LE LL 12 1349\302\265s 0 SCAN_REQ 1790 2.93 40:f0:08:9b:56:91 LE 1M LE LL 37 331\302\265s 0 ADV_SCAN_IND 1791 2.931 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1180\302\265s 0 ADV_NONCONN_IND 1792 2.932 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1793 2.932 0c:6e:66:d7:ed:03 LE 1M LE LL 37 233\302\265s 0 ADV_NONCONN_IND 1794 2.933 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1795 2.934 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1796 2.936 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1590\302\265s 0 ADV_NONCONN_IND 1797 2.936 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1798 2.937 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1799 2.948 2b:5e:0e:c8:62:4c LE 1M LE LL 35 11378\302\265s 0 ADV_NONCONN_IND 1800 2.949 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1801 2.95 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1802 2.955 07:69:22:f0:72:30 LE 1M LE LL 37 5379\302\265s 0 ADV_NONCONN_IND 1803 2.956 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 1804 2.956 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1805 2.957 32:43:3c:28:8d:92 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 1806 2.958 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1807 2.958 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1808 2.961 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2168\302\265s 0 ADV_NONCONN_IND 1809 2.961 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1810 2.962 16:ed:93:0f:fa:b0 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1811 2.965 43:bd:56:bd:74:f9 LE 1M LE LL 37 2591\302\265s 0 ADV_NONCONN_IND 1812 2.969 31:ea:1b:25:0d:1f LE 1M LE LL 37 4017\302\265s 0 ADV_NONCONN_IND 1813 2.97 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1814 2.993 11:fe:ef:ed:38:82 LE 1M LE LL 37 22604\302\265s 0 ADV_NONCONN_IND 1815 2.993 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1816 2.994 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1817 2.996 74:d9:0b:7a:47:5a LE 1M LE LL 23 1605\302\265s 0 ADV_IND 1818 2.998 0d:62:2c:2a:24:88 LE 1M LE LL 37 1857\302\265s 0 ADV_NONCONN_IND 1819 2.998 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1820 3.001 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1888\302\265s 0 ADV_NONCONN_IND 1821 3.001 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1822 3.002 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1823 3.007 72:c4:71:2c:70:59 LE 1M LE LL 12 4529\302\265s 0 SCAN_REQ 1824 3.008 7f:e1:7b:e4:24:1c LE 1M LE LL 12 808\302\265s 0 SCAN_REQ 1825 3.009 72:c4:71:2c:70:59 LE 1M LE LL 12 808\302\265s 0 SCAN_REQ 1826 3.013 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3484\302\265s 0 ADV_NONCONN_IND 1827 3.013 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1828 3.014 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1829 3.019 5c:9e:d4:03:82:5b LE 1M LE LL 37 4470\302\265s 0 ADV_NONCONN_IND 1830 3.02 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1831 3.02 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1832 3.031 24:c3:d0:ce:d4:37 LE 1M LE LL 37 9913\302\265s 0 ADV_NONCONN_IND 1833 3.031 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1834 3.032 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1835 3.033 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 978\302\265s 0 ADV_NONCONN_IND 1836 3.034 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1837 3.034 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1838 3.04 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5266\302\265s 0 ADV_NONCONN_IND 1839 3.041 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1840 3.041 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1841 3.042 25:5f:bf:53:1f:d7 LE 1M LE LL 37 342\302\265s 0 ADV_NONCONN_IND 1842 3.042 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1843 3.043 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1844 3.046 1f:84:46:51:98:14 LE 1M LE LL 23 2627\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1845 3.05 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4022\302\265s 0 ADV_NONCONN_IND 1846 3.051 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 1847 3.054 e5:ea:46:16:3e:1e LE 1M LE LL 36 2762\302\265s 0 ADV_IND 1848 3.055 4d:dc:b7:a2:f3:be LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 1849 3.056 e5:ea:46:16:3e:1e LE 1M LE LL 36 165\302\265s 0 ADV_IND 1850 3.058 32:43:3c:28:8d:92 LE 1M LE LL 37 1753\302\265s 0 ADV_NONCONN_IND 1851 3.058 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1852 3.059 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1853 3.062 07:69:22:f0:72:30 LE 1M LE LL 37 2433\302\265s 0 ADV_NONCONN_IND 1854 3.062 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 1855 3.063 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1856 3.065 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1989\302\265s 0 ADV_NONCONN_IND 1857 3.066 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1858 3.066 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1859 3.069 43:bd:56:bd:74:f9 LE 1M LE LL 37 1968\302\265s 0 ADV_NONCONN_IND 1860 3.07 31:ea:1b:25:0d:1f LE 1M LE LL 37 1515\302\265s 0 ADV_NONCONN_IND 1861 3.071 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1862 3.075 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 3544\302\265s 0 ADV_NONCONN_IND 1863 3.075 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1864 3.076 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1865 3.083 c1:c8:16:ae:fd:1d LE 1M LE LL 36 7148\302\265s 0 ADV_IND 1866 3.084 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1867 3.084 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 1868 3.084 c1:c8:16:ae:fd:1d LE 1M LE LL 36 135\302\265s 0 ADV_IND 1869 3.09 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 5706\302\265s 0 ADV_IND 1870 3.095 1e:28:49:84:c5:cd LE 1M LE LL 37 4152\302\265s 0 ADV_NONCONN_IND 1871 3.095 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1872 3.096 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1873 3.098 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 1238\302\265s 0 ADV_IND 1874 3.098 11:fe:ef:ed:38:82 LE 1M LE LL 37 465\302\265s 0 ADV_NONCONN_IND 1875 3.099 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1876 3.104 0d:62:2c:2a:24:88 LE 1M LE LL 37 4423\302\265s 0 ADV_NONCONN_IND 1877 3.104 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1878 3.105 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1879 3.109 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4384\302\265s 0 ADV_NONCONN_IND 1880 3.11 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1881 3.111 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1882 3.119 27:f1:d5:6a:d5:82 LE 1M LE LL 37 7656\302\265s 0 ADV_NONCONN_IND 1883 3.12 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1884 3.121 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 1885 3.133 24:c3:d0:ce:d4:37 LE 1M LE LL 37 12265\302\265s 0 ADV_NONCONN_IND 1886 3.134 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1887 3.134 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1888 3.138 ef:6e:3d:68:42:19 LE 1M LE LL 36 2897\302\265s 0 ADV_IND 1889 3.138 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1890 3.142 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3513\302\265s 0 ADV_NONCONN_IND 1891 3.142 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1892 3.147 25:5f:bf:53:1f:d7 LE 1M LE LL 37 4093\302\265s 0 ADV_NONCONN_IND 1893 3.147 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1894 3.148 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1895 3.153 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4502\302\265s 0 ADV_NONCONN_IND 1896 3.153 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1897 3.154 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1898 3.156 cf:4f:81:b5:39:55 LE 1M LE LL 36 1599\302\265s 0 ADV_IND 1899 3.157 cf:4f:81:f5:7d:55 LE 1M LE LL 36 741\302\265s 0 ADV_IND 1900 3.158 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1901 3.158 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1902 3.158 cf:4f:81:f5:7d:55 LE 1M LE LL 36 138\302\265s 0 ADV_IND 1903 3.163 07:69:22:f0:72:30 LE 1M LE LL 37 4941\302\265s 0 ADV_NONCONN_IND 1904 3.164 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1905 3.165 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1906 3.166 32:43:3c:28:8d:92 LE 1M LE LL 37 1457\302\265s 0 ADV_NONCONN_IND 1907 3.167 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1908 3.168 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 1909 3.17 e7:70:80:c3:ad:91 LE 1M LE LL 36 2080\302\265s 0 ADV_IND 1910 3.173 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2779\302\265s 0 ADV_NONCONN_IND 1911 3.174 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1912 3.176 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1567\302\265s 0 ADV_IND 1913 3.176 31:6a:b7:a1:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1914 3.184 49:08:83:d3:3a:6c LE 1M LE LL 12 7808\302\265s 0 SCAN_REQ 1915 3.185 61:9c:87:78:87:2b LE 1M LE LL 23 549\302\265s 0 ADV_IND 1916 3.185 74:d9:0b:7a:47:5a LE 1M LE LL 23 239\302\265s 0 ADV_IND 1917 3.186 c8:de:06:91:ba:b3 LE 1M LE LL 36 150\302\265s 0 ADV_NONCONN_IND 1918 3.186 c8:de:06:91:ba:b3 LE 1M LE LL 36 353\302\265s 0 ADV_IND 1919 3.187 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1920 3.196 1e:28:49:84:c5:cd LE 1M LE LL 37 8718\302\265s 0 ADV_NONCONN_IND 1921 3.201 d6:bf:76:0a:0b:dc LE 1M LE LL 36 4559\302\265s 0 ADV_IND 1922 3.201 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1923 3.205 0d:62:2c:2a:24:88 LE 1M LE LL 37 3883\302\265s 0 ADV_NONCONN_IND 1924 3.206 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1925 3.211 cf:c8:cc:72:d8:be LE 1M LE LL 14 4517\302\265s 0 ADV_NONCONN_IND 1926 3.211 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 1927 3.212 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 1928 3.216 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4692\302\265s 0 ADV_IND 1929 3.217 7f:ab:1f:33:5d:b2 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1930 3.217 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 415\302\265s 0 ADV_IND 1931 3.218 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 354\302\265s 0 ADV_IND 1932 3.219 46:cd:f9:15:6d:d0 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1933 3.219 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 1934 3.219 3a:d1:ca:1d:4d:de LE 1M LE LL 26 282\302\265s 0 ADV_NONCONN_IND 1935 3.22 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1936 3.221 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1937 3.221 d2:52:6a:67:61:fd LE 1M LE LL 21 73\302\265s 0 ADV_IND 1938 3.223 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 1939 3.223 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1940 3.224 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 1941 3.224 d2:52:6a:67:61:fd LE 1M LE LL 21 627\302\265s 0 ADV_IND 1942 3.225 46:cd:f9:15:6d:d0 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 1943 3.225 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 1944 3.226 27:f1:d5:6a:d5:82 LE 1M LE LL 37 958\302\265s 0 ADV_NONCONN_IND 1945 3.227 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1946 3.228 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 1947 3.233 cc:15:14:59:64:aa LE 1M LE LL 36 4879\302\265s 0 ADV_IND 1948 3.235 SamsungE_07:d5:79 LE 1M LE LL 34 1534\302\265s 0 ADV_NONCONN_IND 1949 3.236 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 1950 3.238 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1071\302\265s 0 ADV_NONCONN_IND 1951 3.238 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1952 3.239 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1953 3.239 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 355\302\265s 0 ADV_NONCONN_IND 1954 3.24 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1955 3.241 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1956 3.245 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4010\302\265s 0 ADV_NONCONN_IND 1957 3.246 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 1958 3.246 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 1959 3.247 7f:ab:0f:33:5d:32 LE 1M LE LL 12 427\302\265s 0 SCAN_REQ 1960 3.255 2b:5e:0e:c8:62:4c LE 1M LE LL 35 8145\302\265s 0 ADV_NONCONN_IND 1961 3.256 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 1962 3.264 07:69:22:f0:72:30 LE 1M LE LL 37 7879\302\265s 0 ADV_NONCONN_IND 1963 3.265 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 1964 3.265 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 1965 3.266 08:ec:5e:66:cd:0d LE 1M LE LL 23 227\302\265s 0 ADV_NONCONN_IND 1966 3.266 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1967 3.267 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1968 3.267 7f:ab:0f:33:5d:32 LE 1M LE LL 12 173\302\265s 0 SCAN_REQ 1969 3.269 32:43:3c:28:8d:92 LE 1M LE LL 37 2259\302\265s 0 ADV_NONCONN_IND 1970 3.27 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1971 3.273 d5:80:ce:3a:df:84 LE 1M LE LL 36 2137\302\265s 0 ADV_IND 1972 3.274 49:08:83:d3:3a:6c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 1973 3.276 43:bd:56:bd:74:f9 LE 1M LE LL 37 2488\302\265s 0 ADV_NONCONN_IND 1974 3.284 31:ea:1b:25:0d:1f LE 1M LE LL 37 7417\302\265s 0 ADV_NONCONN_IND 1975 3.285 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1976 3.285 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 1977 3.286 47:4e:9b:89:59:8e LE 1M LE LL 12 528\302\265s 0 SCAN_REQ 1978 3.3 40:f0:08:9b:56:91 LE 1M LE LL 37 13871\302\265s 0 ADV_SCAN_IND 1979 3.301 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 1980 3.302 71:c9:89:02:1c:fb LE 1M LE LL 12 857\302\265s 0 SCAN_REQ 1981 3.302 1e:28:49:84:c5:cd LE 1M LE LL 37 265\302\265s 0 ADV_NONCONN_IND 1982 3.303 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1983 3.303 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 1984 3.307 0d:62:2c:2a:24:88 LE 1M LE LL 37 2958\302\265s 0 ADV_NONCONN_IND 1985 3.307 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1986 3.308 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 1987 3.311 5e:93:36:dd:d3:09 LE 1M LE LL 10 2693\302\265s 0 ADV_SCAN_IND 1988 3.311 79:70:d9:25:16:e2 LE 1M LE LL 25 298\302\265s 0 ADV_IND 1989 3.312 49:08:83:d3:3a:6c LE 1M LE LL 12 186\302\265s 0 SCAN_REQ 1990 3.313 5e:93:36:dd:d3:09 LE 1M LE LL 10 980\302\265s 0 ADV_SCAN_IND 1991 3.319 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6322\302\265s 0 ADV_NONCONN_IND 1992 3.32 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 1993 3.321 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 1994 3.327 5c:9e:d4:03:82:5b LE 1M LE LL 37 5419\302\265s 0 ADV_NONCONN_IND 1995 3.327 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 1996 3.328 2f:ae:be:97:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 1997 3.336 0b:f9:be:c7:0f:fb LE 1M LE LL 23 7722\302\265s 0 ADV_NONCONN_IND 1998 3.336 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 1999 3.337 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2000 3.34 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3009\302\265s 0 ADV_NONCONN_IND 2001 3.341 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2002 3.341 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2003 3.346 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4730\302\265s 0 ADV_NONCONN_IND 2004 3.352 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5118\302\265s 0 ADV_NONCONN_IND 2005 3.352 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2006 3.36 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6961\302\265s 0 ADV_NONCONN_IND 2007 3.36 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2008 3.361 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2009 3.362 50:d3:b9:81:11:84 LE 1M LE LL 12 698\302\265s 0 SCAN_REQ 2010 3.37 74:d9:0b:7a:47:5a LE 1M LE LL 23 8278\302\265s 0 ADV_IND 2011 3.372 71:c9:89:02:1c:fb LE 1M LE LL 12 929\302\265s 0 SCAN_REQ 2012 3.372 74:d9:0b:7a:47:5a LE 1M LE LL 23 550\302\265s 0 ADV_IND 2013 3.373 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 2014 3.373 07:69:22:f0:72:30 LE 1M LE LL 37 517\302\265s 0 ADV_NONCONN_IND 2015 3.374 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2016 3.375 d2:52:6a:67:61:fd LE 1M LE LL 19 361\302\265s 0 SCAN_RSP 2017 3.376 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 2018 3.377 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2019 3.378 32:43:3c:28:8d:92 LE 1M LE LL 37 144\302\265s 0 ADV_NONCONN_IND 2020 3.378 50:d3:b9:81:11:84 LE 1M LE LL 12 284\302\265s 0 SCAN_REQ 2021 3.379 e5:ea:46:16:3e:1e LE 1M LE LL 36 414\302\265s 0 ADV_IND 2022 3.38 71:c9:89:02:1c:fb LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 2023 3.381 e5:4e:03:c5:20:42 LE 1M LE LL 36 1033\302\265s 0 ADV_IND[Malformed Packet] 2024 3.382 16:ed:93:0f:fa:b0 LE 1M LE LL 37 290\302\265s 0 ADV_NONCONN_IND 2025 3.384 71:c9:89:02:1c:fb LE 1M LE LL 12 1313\302\265s 0 SCAN_REQ 2026 3.392 31:ea:1b:25:0d:1f LE 1M LE LL 37 8612\302\265s 0 ADV_NONCONN_IND 2027 3.393 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2028 3.393 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2029 3.402 50:d3:b9:81:11:84 LE 1M LE LL 12 8292\302\265s 0 SCAN_REQ 2030 3.406 c4:d3:3f:79:a7:16 LE 1M LE LL 36 4181\302\265s 0 ADV_IND 2031 3.407 1e:28:49:84:c5:cd LE 1M LE LL 37 361\302\265s 0 ADV_NONCONN_IND 2032 3.408 1e:28:49:84:c5:cd LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2033 3.409 11:fe:ef:ed:38:82 LE 1M LE LL 37 793\302\265s 0 ADV_NONCONN_IND 2034 3.409 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2035 3.41 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2036 3.416 0d:62:2c:2a:24:88 LE 1M LE LL 37 5680\302\265s 0 ADV_NONCONN_IND 2037 3.417 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2038 3.417 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2039 3.421 c1:c8:16:ae:fd:1d LE 1M LE LL 36 3001\302\265s 0 ADV_IND 2040 3.421 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2041 3.421 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2042 3.422 c1:c8:16:ae:fd:1d LE 1M LE LL 36 135\302\265s 0 ADV_IND 2043 3.423 71:c9:89:02:1c:fb LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 2044 3.423 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 281\302\265s 0 SCAN_RSP 2045 3.424 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 137\302\265s 0 ADV_IND 2046 3.425 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2047 3.431 c5:65:68:79:19:c8 LE 1M LE LL 36 5685\302\265s 0 ADV_IND 2048 3.435 5c:9e:d4:03:82:5b LE 1M LE LL 37 3660\302\265s 0 ADV_NONCONN_IND 2049 3.435 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2050 3.436 50:d3:b9:81:11:84 LE 1M LE LL 12 391\302\265s 0 SCAN_REQ 2051 3.442 27:f1:d5:6a:d5:82 LE 1M LE LL 37 5871\302\265s 0 ADV_NONCONN_IND 2052 3.443 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2053 3.444 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1017\302\265s 0 ADV_NONCONN_IND 2054 3.445 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2055 3.446 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2056 3.447 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 980\302\265s 0 ADV_NONCONN_IND 2057 3.447 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2058 3.448 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2059 3.454 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5880\302\265s 0 ADV_NONCONN_IND 2060 3.455 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2061 3.456 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2062 3.459 61:9c:87:78:87:2b LE 1M LE LL 23 3139\302\265s 0 ADV_IND 2063 3.466 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6875\302\265s 0 ADV_NONCONN_IND 2064 3.467 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2065 3.467 64:0d:49:f9:4d:a4 LE 1M LE LL 12 349\302\265s 0 SCAN_REQ 2066 3.469 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1389\302\265s 0 ADV_NONCONN_IND 2067 3.47 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2068 3.478 ef:6e:3d:68:42:19 LE 1M LE LL 36 7593\302\265s 0 ADV_IND 2069 3.478 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2070 3.482 07:69:22:f0:72:30 LE 1M LE LL 37 3892\302\265s 0 ADV_NONCONN_IND 2071 3.483 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2072 3.486 50:d3:b9:81:11:84 LE 1M LE LL 12 2722\302\265s 0 SCAN_REQ 2073 3.486 40:f0:08:9b:56:91 LE 1M LE LL 37 290\302\265s 0 ADV_SCAN_IND 2074 3.489 4e:14:1a:db:9e:19 LE 1M LE LL 12 2250\302\265s 0 ADV_IND 2075 3.49 64:0d:49:f9:4d:a4 LE 1M LE LL 12 841\302\265s 0 SCAN_REQ 2076 3.492 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1946\302\265s 0 ADV_IND 2077 3.5 31:ea:1b:25:0d:1f LE 1M LE LL 37 7950\302\265s 0 ADV_NONCONN_IND 2078 3.509 e5:ea:92:fe:cc:4a LE 1M LE LL 36 7907\302\265s 0 ADV_IND 2079 3.51 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1466\302\265s 0 ADV_IND 2080 3.513 e7:70:80:c3:ad:91 LE 1M LE LL 36 2212\302\265s 0 ADV_IND 2081 3.515 1e:28:49:84:c5:cd LE 1M LE LL 37 2008\302\265s 0 ADV_NONCONN_IND 2082 3.516 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2083 3.517 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2084 3.517 11:fe:ef:ed:38:82 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 2085 3.518 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2086 3.518 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2087 3.523 c8:de:06:99:ba:b3 LE 1M LE LL 36 4633\302\265s 0 ADV_IND 2088 3.524 c8:de:06:91:ba:b3 LE 1M LE LL 36 352\302\265s 0 ADV_IND 2089 3.526 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1687\302\265s 0 ADV_NONCONN_IND 2090 3.531 d2:52:6a:67:61:fd LE 1M LE LL 21 4795\302\265s 0 ADV_IND 2091 3.531 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2092 3.532 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2093 3.533 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 2094 3.534 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2095 3.535 d6:bf:76:0a:0b:dc LE 1M LE LL 6 921\302\265s 0 SCAN_RSP 2096 3.536 d6:bf:76:0a:0b:dc LE 1M LE LL 36 137\302\265s 0 ADV_IND 2097 3.544 5c:9e:d4:03:82:5b LE 1M LE LL 37 8156\302\265s 0 ADV_NONCONN_IND 2098 3.549 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4914\302\265s 0 ADV_NONCONN_IND 2099 3.55 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2100 3.551 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2101 3.558 74:d9:0b:7a:47:5a LE 1M LE LL 23 7183\302\265s 0 ADV_IND 2102 3.559 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2103 3.559 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2104 3.563 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4488\302\265s 0 ADV_NONCONN_IND 2105 3.564 0c:6e:66:d7:ed:03 LE 1M LE LL 37 432\302\265s 0 ADV_NONCONN_IND 2106 3.571 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5972\302\265s 0 ADV_NONCONN_IND 2107 3.571 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2108 3.572 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2109 3.574 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2003\302\265s 0 ADV_NONCONN_IND 2110 3.575 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2111 3.575 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2112 3.581 32:43:3c:28:8d:92 LE 1M LE LL 37 5839\302\265s 0 ADV_NONCONN_IND 2113 3.582 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2114 3.583 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2115 3.586 Anonymous LE 1M LE LL 153 3384\302\265s 0 AUX_CONNECT_RSP[Malformed Packet] 2116 3.59 07:69:22:f0:72:30 LE 1M LE LL 37 2060\302\265s 0 ADV_NONCONN_IND 2117 3.59 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2118 3.595 43:bd:56:bd:74:f9 LE 1M LE LL 37 4127\302\265s 0 ADV_NONCONN_IND 2119 3.596 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2120 3.596 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2121 3.605 31:ea:1b:25:0d:1f LE 1M LE LL 37 8722\302\265s 0 ADV_NONCONN_IND 2122 3.606 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2123 3.607 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2124 3.612 d5:80:ce:3a:df:84 LE 1M LE LL 36 5519\302\265s 0 ADV_IND 2125 3.617 f7:11:16:57:f1:d0 LE 1M LE LL 36 3766\302\265s 0 ADV_IND 2126 3.617 d6:11:16:57:f1:d0 LE 1M LE LL 36 354\302\265s 0 ADV_IND 2127 3.622 0d:62:2c:2a:24:88 LE 1M LE LL 37 4029\302\265s 0 ADV_NONCONN_IND 2128 3.622 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2129 3.623 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2130 3.632 3a:d1:ca:1d:4d:de LE 1M LE LL 26 8752\302\265s 0 ADV_NONCONN_IND 2131 3.633 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2132 3.633 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2133 3.643 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 8753\302\265s 0 ADV_IND 2134 3.647 69:a9:48:2f:b7:16 LE 1M LE LL 37 4472\302\265s 0 ADV_NONCONN_IND 2135 3.65 5c:9e:d4:03:82:5b LE 1M LE LL 37 2796\302\265s 0 ADV_NONCONN_IND 2136 3.652 c7:a0:ff:b8:da:bc LE 1M LE LL 14 1531\302\265s 0 ADV_NONCONN_IND 2137 3.653 c7:a0:9c:b8:da:bc LE 1M LE LL 11 132\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2138 3.657 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4001\302\265s 0 ADV_NONCONN_IND 2139 3.668 1f:84:46:51:98:14 LE 1M LE LL 23 11213\302\265s 0 ADV_NONCONN_IND 2140 3.669 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2141 3.669 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2142 3.672 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2953\302\265s 0 ADV_NONCONN_IND 2143 3.673 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2144 3.674 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2145 3.674 25:5f:bf:53:1f:d7 LE 1M LE LL 37 349\302\265s 0 ADV_NONCONN_IND 2146 3.675 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2147 3.676 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2148 3.676 2b:5e:0e:c8:62:4c LE 1M LE LL 35 127\302\265s 0 ADV_NONCONN_IND 2149 3.677 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2150 3.677 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2151 3.688 d2:52:6a:67:61:fd LE 1M LE LL 21 10395\302\265s 0 ADV_IND 2152 3.688 32:43:3c:28:8d:92 LE 1M LE LL 37 197\302\265s 0 ADV_NONCONN_IND 2153 3.689 e5:42:93:8f:fa:b0 LE 1M LE LL 37 87\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2154 3.689 c1:36:6c:af:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2155 3.697 07:69:22:f0:72:30 LE 1M LE LL 37 7514\302\265s 0 ADV_NONCONN_IND 2156 3.698 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 2157 3.698 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2158 3.7 43:bd:56:bd:74:f9 LE 1M LE LL 37 1009\302\265s 0 ADV_NONCONN_IND 2159 3.704 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 3976\302\265s 0 ADV_NONCONN_IND 2160 3.704 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2161 3.706 c9:2d:18:b6:8c:6b LE 1M LE LL 14 1060\302\265s 0 ADV_NONCONN_IND 2162 3.708 e5:ea:46:16:3e:1e LE 1M LE LL 36 2354\302\265s 0 ADV_IND 2163 3.71 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1604\302\265s 0 ADV_IND 2164 3.714 d6:bf:03:c5:20:42 LE 1M LE LL 36 3018\302\265s 0 ADV_IND 2165 3.715 31:ea:1b:25:0d:1f LE 1M LE LL 37 1347\302\265s 0 ADV_NONCONN_IND 2166 3.716 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2167 3.718 1e:28:49:84:c5:cd LE 1M LE LL 37 1572\302\265s 0 ADV_NONCONN_IND 2168 3.718 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2169 3.719 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2170 3.722 11:fe:ef:ed:38:82 LE 1M LE LL 37 2672\302\265s 0 ADV_NONCONN_IND 2171 3.723 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2172 3.723 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2173 3.733 3a:d1:ca:1d:4d:de LE 1M LE LL 26 9676\302\265s 0 ADV_NONCONN_IND 2174 3.734 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2175 3.735 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2176 3.74 c6:59:d0:fc:e1:b9 LE 1M LE LL 14 4965\302\265s 0 ADV_IND[Malformed Packet] 2177 3.741 c4:d3:3f:79:a7:16 LE 1M LE LL 36 934\302\265s 0 ADV_IND 2178 3.747 74:d9:0b:7a:47:5a LE 1M LE LL 23 5080\302\265s 0 ADV_IND 2179 3.757 c1:c8:16:ae:fd:1d LE 1M LE LL 36 10051\302\265s 0 ADV_IND 2180 3.758 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 312\302\265s 0 ADV_IND 2181 3.758 47:4e:9b:89:59:8e LE 1M LE LL 12 191\302\265s 0 SCAN_REQ 2182 3.758 c1:c8:16:ae:fd:1d LE 1M LE LL 36 163\302\265s 0 ADV_IND 2183 3.759 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 177\302\265s 0 ADV_IND 2184 3.76 24:c3:d0:ce:d4:37 LE 1M LE LL 37 739\302\265s 0 ADV_NONCONN_IND 2185 3.761 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2186 3.761 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2187 3.774 25:5f:bf:53:1f:d7 LE 1M LE LL 37 12821\302\265s 0 ADV_NONCONN_IND 2188 3.775 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2189 3.776 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2190 3.777 0c:6e:66:d7:ed:03 LE 1M LE LL 37 912\302\265s 0 ADV_NONCONN_IND 2191 3.777 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2192 3.778 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2193 3.779 2b:5e:0e:c8:62:4c LE 1M LE LL 35 89\302\265s 0 ADV_NONCONN_IND 2194 3.779 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2195 3.78 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2196 3.791 16:f5:93:cf:fa:b0 LE 1M LE LL 37 11375\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2197 3.792 15:2b:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2198 3.792 17:c8:6c:ef:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2199 3.799 07:69:22:f0:72:30 LE 1M LE LL 37 6261\302\265s 0 ADV_NONCONN_IND 2200 3.8 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 2201 3.8 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2202 3.801 43:bd:56:bd:74:f9 LE 1M LE LL 37 376\302\265s 0 ADV_NONCONN_IND 2203 3.81 dd:b9:3b:45:59:8b LE 1M LE LL 24 8280\302\265s 0 ADV_IND 2204 3.819 ef:6e:3d:68:42:19 LE 1M LE LL 36 9035\302\265s 0 ADV_IND 2205 3.82 1e:28:49:84:c5:cd LE 1M LE LL 37 1118\302\265s 0 ADV_NONCONN_IND 2206 3.821 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2207 3.822 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2208 3.825 cf:4f:81:f5:7d:55 LE 1M LE LL 36 2762\302\265s 0 ADV_IND 2209 3.828 ec:af:39:d1:f5:fe LE 1M LE LL 14 2681\302\265s 0 ADV_NONCONN_IND 2210 3.828 ec:af:39:d1:f5:fe LE 1M LE LL 14 264\302\265s 0 ADV_NONCONN_IND 2211 3.829 ec:af:39:d1:f5:fe LE 1M LE LL 14 263\302\265s 0 ADV_NONCONN_IND 2212 3.832 11:fe:ef:ed:38:82 LE 1M LE LL 37 3187\302\265s 0 ADV_NONCONN_IND 2213 3.833 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2214 3.84 d2:52:6a:67:61:fd LE 1M LE LL 21 7134\302\265s 0 ADV_IND 2215 3.842 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2216 3.843 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2217 3.85 e7:70:80:c3:ad:91 LE 1M LE LL 36 6464\302\265s 0 ADV_IND 2218 3.852 e7:70:80:c3:ad:91 LE 1M LE LL 6 1198\302\265s 0 SCAN_RSP 2219 3.852 e7:70:80:c3:ad:91 LE 1M LE LL 36 136\302\265s 0 ADV_IND 2220 3.858 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6089\302\265s 0 ADV_NONCONN_IND 2221 3.859 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2222 3.86 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2223 3.862 0c:93:1a:db:9e:19 LE 1M LE LL 12 1507\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2224 3.864 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2080\302\265s 0 ADV_NONCONN_IND 2225 3.864 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2226 3.866 79:78:d9:25:16:e2 LE 1M LE LL 25 1636\302\265s 0 ADV_IND 2227 3.867 79:70:d9:25:16:e2 LE 1M LE LL 25 368\302\265s 0 ADV_IND 2228 3.872 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4288\302\265s 0 ADV_IND 2229 3.874 e5:ea:46:16:3e:1e LE 1M LE LL 36 1924\302\265s 0 ADV_IND 2230 3.875 e5:ea:46:16:3e:1e LE 1M LE LL 6 1198\302\265s 0 SCAN_RSP 2231 3.876 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 2232 3.879 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3354\302\265s 0 ADV_NONCONN_IND 2233 3.88 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2234 3.881 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2235 3.882 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1375\302\265s 0 ADV_NONCONN_IND 2236 3.883 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2237 3.883 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2238 3.884 0c:6e:66:d7:ed:03 LE 1M LE LL 37 598\302\265s 0 ADV_NONCONN_IND 2239 3.885 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2240 3.886 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2241 3.893 32:43:3c:28:8d:92 LE 1M LE LL 37 6745\302\265s 0 ADV_NONCONN_IND 2242 3.893 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2243 3.894 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2244 3.897 08:ec:5e:66:cd:0d LE 1M LE LL 23 2944\302\265s 0 ADV_NONCONN_IND 2245 3.897 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2246 3.898 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2247 3.907 07:69:22:f0:72:30 LE 1M LE LL 37 9047\302\265s 0 ADV_NONCONN_IND 2248 3.908 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 2249 3.908 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2250 3.912 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 3790\302\265s 0 ADV_IND 2251 3.927 1e:28:49:84:c5:cd LE 1M LE LL 37 13821\302\265s 0 ADV_NONCONN_IND 2252 3.927 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2253 3.933 11:fe:ef:ed:38:82 LE 1M LE LL 37 5797\302\265s 0 ADV_NONCONN_IND 2254 3.934 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2255 3.934 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2256 3.935 0d:62:2c:2a:24:88 LE 1M LE LL 37 694\302\265s 0 ADV_NONCONN_IND 2257 3.936 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2258 3.937 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2259 3.946 3a:d1:ca:1d:4d:de LE 1M LE LL 26 8741\302\265s 0 ADV_NONCONN_IND 2260 3.946 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2261 3.947 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2262 3.949 d5:80:ce:3a:df:84 LE 1M LE LL 36 1193\302\265s 0 ADV_IND 2263 3.958 7f:ab:0f:33:5d:32 LE 1M LE LL 12 9282\302\265s 0 SCAN_REQ 2264 3.959 d6:11:16:57:f1:d0 LE 1M LE LL 36 416\302\265s 0 ADV_IND 2265 3.964 5c:9e:d4:03:82:5b LE 1M LE LL 37 4863\302\265s 0 ADV_NONCONN_IND 2266 3.965 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2267 3.965 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2268 3.968 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2416\302\265s 0 ADV_NONCONN_IND 2269 3.969 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2270 3.969 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2271 3.983 d6:2c:05:d0:15:49 LE 1M LE LL 37 13495\302\265s 0 ADV_IND 2272 3.984 d6:2c:07:d0:15:49 LE 1M LE LL 37 395\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2273 3.985 d6:2c:05:d0:15:49 LE 1M LE LL 37 395\302\265s 0 ADV_IND[Malformed Packet] 2274 3.986 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1160\302\265s 0 ADV_NONCONN_IND 2275 3.987 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2276 3.987 25:5f:bf:53:1f:d7 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2277 3.989 2b:5e:0e:c8:62:4c LE 1M LE LL 35 752\302\265s 0 ADV_NONCONN_IND 2278 3.989 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2279 3.99 2b:5e:0e:c8:62:4c LE 1M LE LL 35 177\302\265s 0 ADV_NONCONN_IND 2280 3.991 d2:52:6a:67:61:fd LE 1M LE LL 21 1458\302\265s 0 ADV_IND 2281 3.993 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2282 3.995 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2283 3.999 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4007\302\265s 0 ADV_NONCONN_IND 2284 3.999 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2285 4 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2286 4.002 32:43:3c:28:8d:92 LE 1M LE LL 37 1726\302\265s 0 ADV_NONCONN_IND 2287 4.003 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2288 4.003 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2289 4.007 43:bd:56:bd:74:f9 LE 1M LE LL 37 3685\302\265s 0 ADV_NONCONN_IND 2290 4.008 4b:bd:56:bd:74:f9 LE 1M LE LL 229 455\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2291 4.013 07:69:22:f0:72:30 LE 1M LE LL 37 3377\302\265s 0 ADV_NONCONN_IND 2292 4.03 1e:28:49:84:c5:cd LE 1M LE LL 37 16079\302\265s 0 ADV_NONCONN_IND 2293 4.03 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2294 4.031 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2295 4.034 31:ea:1b:25:0d:1f LE 1M LE LL 37 2955\302\265s 0 ADV_NONCONN_IND 2296 4.035 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2297 4.035 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2298 4.038 11:fe:ef:ed:38:82 LE 1M LE LL 37 2603\302\265s 0 ADV_NONCONN_IND 2299 4.039 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2300 4.039 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2301 4.043 71:c9:89:02:1c:fb LE 1M LE LL 12 3282\302\265s 0 SCAN_REQ 2302 4.044 e5:ea:46:16:3e:1e LE 1M LE LL 36 414\302\265s 0 ADV_IND 2303 4.044 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2304 4.045 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2305 4.045 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 2306 4.048 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3073\302\265s 0 ADV_NONCONN_IND 2307 4.049 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2308 4.05 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2309 4.055 71:c9:89:02:1c:fb LE 1M LE LL 12 5444\302\265s 0 SCAN_REQ 2310 4.056 d6:bf:03:c5:20:42 LE 1M LE LL 36 415\302\265s 0 ADV_IND 2311 4.057 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 2312 4.057 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2313 4.057 d6:bf:03:c5:20:42 LE 1M LE LL 36 138\302\265s 0 ADV_IND 2314 4.063 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5675\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2315 4.064 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2316 4.064 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2317 4.067 5c:9e:d4:03:82:5b LE 1M LE LL 37 1994\302\265s 0 ADV_NONCONN_IND 2318 4.067 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2319 4.068 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2320 4.071 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2414\302\265s 0 ADV_NONCONN_IND 2321 4.071 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2322 4.072 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2323 4.083 71:c9:89:02:1c:fb LE 1M LE LL 12 11176\302\265s 0 SCAN_REQ 2324 4.084 c4:d3:3f:79:a7:16 LE 1M LE LL 36 414\302\265s 0 ADV_IND 2325 4.084 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2326 4.085 c4:d3:3f:79:a7:16 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2327 4.085 c4:d3:3f:79:a7:16 LE 1M LE LL 36 137\302\265s 0 ADV_IND[Malformed Packet] 2328 4.092 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6193\302\265s 0 ADV_NONCONN_IND 2329 4.092 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2330 4.093 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2331 4.096 c1:c8:16:ae:fd:1d LE 1M LE LL 36 2546\302\265s 0 ADV_IND 2332 4.096 0c:6e:66:d7:ed:03 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2333 4.097 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2334 4.097 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2335 4.098 71:c9:89:02:1c:fb LE 1M LE LL 12 253\302\265s 0 SCAN_REQ 2336 4.099 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 415\302\265s 0 ADV_IND 2337 4.099 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 2338 4.099 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2339 4.1 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 138\302\265s 0 ADV_IND 2340 4.109 c5:65:68:79:19:c8 LE 1M LE LL 36 9374\302\265s 0 ADV_IND 2341 4.11 c5:65:68:79:19:c8 LE 1M LE LL 36 353\302\265s 0 ADV_IND 2342 4.111 c5:65:68:79:19:c8 LE 1M LE LL 36 354\302\265s 0 ADV_IND 2343 4.121 74:d9:0b:7a:47:5a LE 1M LE LL 23 9705\302\265s 0 ADV_IND 2344 4.121 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2345 4.122 07:69:22:f0:72:30 LE 1M LE LL 37 548\302\265s 0 ADV_NONCONN_IND 2346 4.123 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2347 4.132 1e:28:49:84:c5:cd LE 1M LE LL 37 8573\302\265s 0 ADV_NONCONN_IND 2348 4.132 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2349 4.133 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2350 4.136 c0:41:04:2e:be:9d LE 1M LE LL 36 2564\302\265s 0 ADV_IND 2351 4.136 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2352 4.137 c0:41:04:2e:be:9d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2353 4.137 c0:41:04:2e:be:9d LE 1M LE LL 36 137\302\265s 0 ADV_IND 2354 4.143 0d:62:2c:2a:24:88 LE 1M LE LL 37 5676\302\265s 0 ADV_NONCONN_IND 2355 4.144 31:ea:1b:25:0d:1f LE 1M LE LL 37 362\302\265s 0 ADV_NONCONN_IND 2356 4.144 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2357 4.145 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2358 4.154 ef:6e:3d:68:42:19 LE 1M LE LL 36 8586\302\265s 0 ADV_IND 2359 4.154 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2360 4.155 ef:6e:3d:68:42:19 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2361 4.155 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 2362 4.155 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2363 4.156 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2364 4.156 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 2365 4.157 cf:4f:81:f5:7d:55 LE 1M LE LL 36 879\302\265s 0 ADV_IND 2366 4.158 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2367 4.158 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2368 4.158 cf:4f:81:f5:7d:55 LE 1M LE LL 36 137\302\265s 0 ADV_IND 2369 4.159 64:0d:49:f9:4d:a4 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 2370 4.159 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2371 4.159 cf:4f:81:f5:7d:55 LE 1M LE LL 36 137\302\265s 0 ADV_IND 2372 4.167 54:54:a3:07:d5:79 LE 1M LE LL 34 7029\302\265s 0 ADV_NONCONN_IND 2373 4.171 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3513\302\265s 0 ADV_NONCONN_IND 2374 4.171 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2375 4.174 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2352\302\265s 0 ADV_NONCONN_IND 2376 4.175 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2377 4.176 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2378 4.184 e7:70:80:c3:ad:91 LE 1M LE LL 36 7730\302\265s 0 ADV_IND 2379 4.185 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2380 4.186 e7:70:80:c3:ad:91 LE 1M LE LL 36 415\302\265s 0 ADV_IND 2381 4.193 f1:ff:a7:1a:55:8d LE 1M LE LL 36 7177\302\265s 0 ADV_IND 2382 4.194 64:0d:49:f9:4d:a4 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 2383 4.195 f1:ff:a7:1a:55:8d LE 1M LE LL 36 414\302\265s 0 ADV_IND 2384 4.196 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 687\302\265s 0 SCAN_RSP 2385 4.197 64:0d:49:f9:4d:a4 LE 1M LE LL 12 655\302\265s 0 SCAN_REQ 2386 4.197 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 415\302\265s 0 ADV_IND[Malformed Packet] 2387 4.198 0c:6e:66:d7:ed:03 LE 1M LE LL 37 366\302\265s 0 ADV_NONCONN_IND 2388 4.199 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2389 4.199 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2390 4.2 71:c9:89:02:1c:fb LE 1M LE LL 12 158\302\265s 0 SCAN_REQ 2391 4.201 2b:5e:0e:c8:62:4c LE 1M LE LL 35 923\302\265s 0 ADV_NONCONN_IND 2392 4.201 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2393 4.204 e5:ea:46:16:3e:1e LE 1M LE LL 36 1975\302\265s 0 ADV_IND 2394 4.205 64:0d:49:f9:4d:a4 LE 1M LE LL 12 888\302\265s 0 SCAN_REQ 2395 4.207 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2213\302\265s 0 ADV_NONCONN_IND 2396 4.212 43:bd:56:bd:74:f9 LE 1M LE LL 37 4387\302\265s 0 ADV_NONCONN_IND 2397 4.214 32:43:3c:28:8d:92 LE 1M LE LL 37 1266\302\265s 0 ADV_NONCONN_IND 2398 4.214 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2399 4.227 07:69:22:f0:72:30 LE 1M LE LL 37 12418\302\265s 0 ADV_NONCONN_IND 2400 4.228 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 2401 4.228 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2402 4.234 1e:28:49:84:c5:cd LE 1M LE LL 37 4848\302\265s 0 ADV_NONCONN_IND 2403 4.234 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2404 4.235 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2405 4.237 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2412\302\265s 0 SCAN_REQ 2406 4.243 cc:15:14:59:64:aa LE 1M LE LL 36 5028\302\265s 0 ADV_IND 2407 4.247 50:d3:b9:81:11:84 LE 1M LE LL 12 4144\302\265s 0 SCAN_REQ 2408 4.248 11:fe:ef:ed:38:82 LE 1M LE LL 37 990\302\265s 0 ADV_NONCONN_IND 2409 4.249 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2410 4.249 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2411 4.25 0d:62:2c:2a:24:88 LE 1M LE LL 37 78\302\265s 0 ADV_NONCONN_IND 2412 4.25 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2413 4.251 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2414 4.252 31:ea:1b:25:0d:1f LE 1M LE LL 37 357\302\265s 0 ADV_NONCONN_IND 2415 4.252 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2416 4.253 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2417 4.272 5c:9e:d4:03:82:5b LE 1M LE LL 37 18453\302\265s 0 ADV_NONCONN_IND 2418 4.272 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2419 4.273 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2420 4.274 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1175\302\265s 0 ADV_NONCONN_IND 2421 4.275 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2422 4.276 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2423 4.277 24:c3:d0:ce:d4:37 LE 1M LE LL 37 713\302\265s 0 ADV_NONCONN_IND 2424 4.278 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2425 4.278 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2426 4.283 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4210\302\265s 0 ADV_NONCONN_IND 2427 4.283 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2428 4.284 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2429 4.287 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1946\302\265s 0 SCAN_REQ 2430 4.29 47:4e:9b:89:59:8e LE 1M LE LL 12 2707\302\265s 0 SCAN_REQ 2431 4.293 45:9b:f4:8b:17:f9 LE 1M LE LL 24 3755\302\265s 0 ADV_IND 2432 4.296 d2:52:6a:67:61:fd LE 1M LE LL 21 1941\302\265s 0 ADV_IND 2433 4.296 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2434 4.296 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2435 4.297 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 2436 4.298 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2437 4.298 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2438 4.298 SamsungE_07:d8:8f LE 1M LE LL 34 80\302\265s 0 ADV_NONCONN_IND 2439 4.3 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1272\302\265s 0 ADV_NONCONN_IND 2440 4.301 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2441 4.301 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2442 4.304 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1970\302\265s 0 ADV_NONCONN_IND 2443 4.304 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2444 4.305 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2445 4.315 16:ed:93:0f:fa:b0 LE 1M LE LL 37 10137\302\265s 0 ADV_NONCONN_IND 2446 4.316 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2447 4.316 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2448 4.32 32:43:3c:28:8d:92 LE 1M LE LL 37 3597\302\265s 0 ADV_NONCONN_IND 2449 4.321 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2450 4.321 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2451 4.322 43:bd:56:bd:74:f9 LE 1M LE LL 37 547\302\265s 0 ADV_NONCONN_IND 2452 4.328 07:69:22:f0:72:30 LE 1M LE LL 37 5817\302\265s 0 ADV_NONCONN_IND 2453 4.329 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2454 4.334 7f:e1:7b:e4:24:1c LE 1M LE LL 12 4900\302\265s 0 SCAN_REQ 2455 4.34 1e:28:49:84:c5:cd LE 1M LE LL 37 5298\302\265s 0 ADV_NONCONN_IND 2456 4.34 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2457 4.343 5e:93:36:dd:d3:09 LE 1M LE LL 10 2753\302\265s 0 ADV_SCAN_IND 2458 4.344 72:10:b2:16:c9:46 LE 1M LE LL 12 763\302\265s 0 SCAN_REQ 2459 4.345 5e:93:36:dd:d3:09 LE 1M LE LL 10 981\302\265s 0 ADV_SCAN_IND 2460 4.349 11:fe:ef:ed:38:82 LE 1M LE LL 37 3303\302\265s 0 ADV_NONCONN_IND 2461 4.349 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2462 4.35 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2463 4.357 31:ea:1b:25:0d:1f LE 1M LE LL 37 6926\302\265s 0 ADV_NONCONN_IND 2464 4.358 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2465 4.358 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2466 4.365 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 6235\302\265s 0 ADV_IND 2467 4.369 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3522\302\265s 0 ADV_NONCONN_IND 2468 4.37 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2469 4.373 e5:ea:46:16:3e:1e LE 1M LE LL 36 2525\302\265s 0 ADV_IND 2470 4.377 69:a9:48:2f:b7:16 LE 1M LE LL 37 4328\302\265s 0 ADV_NONCONN_IND 2471 4.379 5c:9e:d4:03:82:5b LE 1M LE LL 37 1578\302\265s 0 ADV_NONCONN_IND 2472 4.386 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 6769\302\265s 0 ADV_NONCONN_IND 2473 4.387 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2474 4.387 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2475 4.389 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1107\302\265s 0 ADV_NONCONN_IND 2476 4.39 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2477 4.391 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2478 4.396 d6:bf:03:c5:20:42 LE 1M LE LL 36 5197\302\265s 0 ADV_IND 2479 4.397 d6:bf:03:c5:20:42 LE 1M LE LL 36 354\302\265s 0 ADV_IND 2480 4.397 72:10:b2:16:c9:46 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 2481 4.398 d6:bf:03:c5:20:42 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2482 4.398 d6:bf:03:c5:20:42 LE 1M LE LL 36 138\302\265s 0 ADV_IND 2483 4.4 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1562\302\265s 0 ADV_NONCONN_IND 2484 4.401 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2485 4.401 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2486 4.402 25:5f:bf:53:1f:d7 LE 1M LE LL 37 359\302\265s 0 ADV_NONCONN_IND 2487 4.402 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2488 4.403 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2489 4.411 2b:5e:0e:c8:62:4c LE 1M LE LL 35 7625\302\265s 0 ADV_NONCONN_IND 2490 4.412 2b:5e:0e:c8:62:4c LE 1M LE LL 35 177\302\265s 0 ADV_NONCONN_IND 2491 4.412 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2492 4.418 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5141\302\265s 0 ADV_NONCONN_IND 2493 4.418 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2494 4.419 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2495 4.422 43:bd:56:bd:74:f9 LE 1M LE LL 37 3119\302\265s 0 ADV_NONCONN_IND 2496 4.423 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2497 4.424 43:bd:56:bd:74:f9 LE 1M LE LL 37 673\302\265s 0 ADV_NONCONN_IND 2498 4.427 5d:d8:c3:2a:ed:c9 LE 1M LE LL 164 2456\302\265s 0 ADV_IND[Malformed Packet] 2499 4.429 32:43:3c:28:8d:92 LE 1M LE LL 37 1175\302\265s 0 ADV_NONCONN_IND 2500 4.43 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2501 4.436 c1:c8:16:ae:fd:1d LE 1M LE LL 36 5221\302\265s 0 ADV_IND 2502 4.436 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 271\302\265s 0 ADV_IND 2503 4.437 ac:c6:03:00:20:20 LE 1M LE LL 12 232\302\265s 0 SCAN_REQ 2504 4.437 c1:c8:16:ae:fd:1d LE 1M LE LL 36 339\302\265s 0 ADV_IND 2505 4.442 1e:28:49:84:c5:cd LE 1M LE LL 37 3912\302\265s 0 ADV_NONCONN_IND 2506 4.442 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2507 4.443 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2508 4.45 0d:62:2c:2a:24:88 LE 1M LE LL 37 6736\302\265s 0 ADV_NONCONN_IND 2509 4.45 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2510 4.451 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2511 4.455 d2:52:6a:67:61:fd LE 1M LE LL 21 3356\302\265s 0 ADV_IND 2512 4.456 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2513 4.458 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2514 4.458 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2515 4.459 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2516 4.462 31:ea:1b:25:0d:1f LE 1M LE LL 37 3503\302\265s 0 ADV_NONCONN_IND 2517 4.463 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2518 4.463 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2519 4.472 3a:d1:ca:1d:4d:de LE 1M LE LL 26 8136\302\265s 0 ADV_NONCONN_IND 2520 4.473 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2521 4.473 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2522 4.483 5c:9e:d4:03:82:5b LE 1M LE LL 37 9171\302\265s 0 ADV_NONCONN_IND 2523 4.484 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2524 4.484 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2525 4.49 ef:6e:3d:68:42:19 LE 1M LE LL 36 5321\302\265s 0 ADV_IND 2526 4.491 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2527 4.492 ef:6e:3d:68:42:19 LE 1M LE LL 36 414\302\265s 0 ADV_IND 2528 4.492 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2529 4.493 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2530 4.496 cf:4f:81:f5:7d:55 LE 1M LE LL 36 3202\302\265s 0 ADV_IND 2531 4.497 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2532 4.498 cf:4f:81:f5:7d:55 LE 1M LE LL 36 416\302\265s 0 ADV_IND 2533 4.498 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2534 4.499 cf:4f:81:f5:7d:55 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2535 4.499 27:f1:d5:6a:d5:82 LE 1M LE LL 37 240\302\265s 0 ADV_NONCONN_IND 2536 4.5 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2537 4.501 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2538 4.507 74:d9:0b:7a:47:5a LE 1M LE LL 23 6389\302\265s 0 ADV_IND 2539 4.509 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1717\302\265s 0 ADV_NONCONN_IND 2540 4.51 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2541 4.515 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5124\302\265s 0 ADV_NONCONN_IND 2542 4.516 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2543 4.516 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2544 4.521 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3891\302\265s 0 ADV_NONCONN_IND 2545 4.521 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2546 4.522 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2547 4.522 e7:70:80:c3:ad:91 LE 1M LE LL 36 202\302\265s 0 ADV_IND 2548 4.524 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2549 4.524 e7:70:80:c3:ad:91 LE 1M LE LL 36 415\302\265s 0 ADV_IND 2550 4.525 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2551 4.525 e7:70:80:c3:ad:91 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2552 4.526 43:bd:56:bd:74:f9 LE 1M LE LL 37 713\302\265s 0 ADV_NONCONN_IND 2553 4.527 da:f4:8b:c3:ec:01 LE 1M LE LL 6 338\302\265s 0 SCAN_RSP 2554 4.527 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 138\302\265s 0 ADV_IND 2555 4.529 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2016\302\265s 0 ADV_IND 2556 4.531 6c:c6:23:80:30:28 LE 1M LE LL 12 880\302\265s 0 SCAN_REQ 2557 4.531 7f:ab:0f:33:5d:32 LE 1M LE LL 12 545\302\265s 0 SCAN_REQ 2558 4.535 32:43:3c:28:8d:92 LE 1M LE LL 37 3114\302\265s 0 ADV_NONCONN_IND 2559 4.535 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2560 4.536 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2561 4.539 e5:ea:46:16:3e:1e LE 1M LE LL 36 2726\302\265s 0 ADV_IND 2562 4.54 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2563 4.541 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 2564 4.541 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2565 4.541 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2566 4.544 d6:bf:76:0a:0b:dc LE 1M LE LL 36 2807\302\265s 0 ADV_IND 2567 4.546 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2568 4.546 d6:bf:76:0a:0b:dc LE 1M LE LL 36 415\302\265s 0 ADV_IND 2569 4.556 11:fe:ef:ed:38:82 LE 1M LE LL 37 9254\302\265s 0 ADV_NONCONN_IND 2570 4.556 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2571 4.557 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2572 4.57 31:ea:1b:25:0d:1f LE 1M LE LL 37 12552\302\265s 0 ADV_NONCONN_IND 2573 4.57 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2574 4.571 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2575 4.572 3a:d1:ca:1d:4d:de LE 1M LE LL 26 637\302\265s 0 ADV_NONCONN_IND 2576 4.573 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2577 4.573 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2578 4.579 cc:15:14:59:64:aa LE 1M LE LL 36 5617\302\265s 0 ADV_IND 2579 4.581 6c:c6:23:80:30:28 LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 2580 4.581 cc:15:14:59:64:aa LE 1M LE LL 36 414\302\265s 0 ADV_IND 2581 4.582 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2582 4.582 cc:15:14:59:64:aa LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2583 4.584 0b:f9:be:c7:0f:fb LE 1M LE LL 23 1466\302\265s 0 ADV_NONCONN_IND 2584 4.584 0b:f9:be:c7:0f:fb LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 2585 4.584 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2586 4.585 5c:9e:d4:03:82:5b LE 1M LE LL 37 731\302\265s 0 ADV_NONCONN_IND 2587 4.586 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2588 4.594 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7893\302\265s 0 ADV_NONCONN_IND 2589 4.604 27:f1:d5:6a:d5:82 LE 1M LE LL 37 9232\302\265s 0 ADV_NONCONN_IND 2590 4.605 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2591 4.606 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2592 4.611 d2:52:6a:67:61:fd LE 1M LE LL 21 5327\302\265s 0 ADV_IND 2593 4.613 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2594 4.613 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2595 4.614 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2596 4.614 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 2597 4.615 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2598 4.615 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2599 4.616 25:5f:bf:53:1f:d7 LE 1M LE LL 37 857\302\265s 0 ADV_NONCONN_IND 2600 4.617 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2601 4.617 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2602 4.62 40:f0:08:9b:56:91 LE 1M LE LL 37 1827\302\265s 0 ADV_SCAN_IND 2603 4.62 2b:5e:0e:c8:62:4c LE 1M LE LL 35 334\302\265s 0 ADV_NONCONN_IND 2604 4.621 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2605 4.623 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1392\302\265s 0 ADV_NONCONN_IND 2606 4.623 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2607 4.624 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2608 4.631 d6:51:16:57:f1:d0 LE 1M LE LL 36 6744\302\265s 0 ADV_IND 2609 4.632 79:54:9b:70:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2610 4.633 07:69:22:f0:72:30 LE 1M LE LL 37 477\302\265s 0 ADV_NONCONN_IND 2611 4.638 32:43:3c:28:8d:92 LE 1M LE LL 37 4579\302\265s 0 ADV_NONCONN_IND 2612 4.638 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2613 4.639 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2614 4.64 43:bd:56:bd:74:f9 LE 1M LE LL 37 489\302\265s 0 ADV_NONCONN_IND 2615 4.64 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2616 4.641 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2617 4.644 d5:80:38:95:af:b7 LE 1M LE LL 34 2013\302\265s 0 CONNECT_IND 2618 4.653 1e:28:49:84:c5:cd LE 1M LE LL 37 9417\302\265s 0 ADV_NONCONN_IND 2619 4.654 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2620 4.661 11:fe:ef:ed:38:82 LE 1M LE LL 37 6421\302\265s 0 ADV_NONCONN_IND 2621 4.661 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2622 4.662 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2623 4.674 31:ea:1b:25:0d:1f LE 1M LE LL 37 11302\302\265s 0 ADV_NONCONN_IND 2624 4.674 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2625 4.675 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2626 4.676 3a:d1:ca:1d:4d:de LE 1M LE LL 26 639\302\265s 0 ADV_NONCONN_IND 2627 4.676 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2628 4.677 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2629 4.687 5c:9e:d4:03:82:5b LE 1M LE LL 37 9169\302\265s 0 ADV_NONCONN_IND 2630 4.687 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2631 4.691 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 2966\302\265s 0 ADV_IND 2632 4.691 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2633 4.691 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2634 4.694 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2206\302\265s 0 ADV_NONCONN_IND 2635 4.694 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2636 4.695 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 2637 4.696 79:70:d9:25:16:e2 LE 1M LE LL 25 1060\302\265s 0 ADV_IND 2638 4.699 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2738\302\265s 0 ADV_NONCONN_IND 2639 4.7 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2640 4.702 e5:ea:46:16:3e:1e LE 1M LE LL 36 2162\302\265s 0 ADV_IND 2641 4.704 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2642 4.704 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 2643 4.706 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1480\302\265s 0 ADV_NONCONN_IND 2644 4.707 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2645 4.707 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2646 4.721 25:5f:bf:53:1f:d7 LE 1M LE LL 37 12863\302\265s 0 ADV_NONCONN_IND 2647 4.721 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2648 4.722 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2649 4.723 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1079\302\265s 0 ADV_NONCONN_IND 2650 4.724 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2651 4.724 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2652 4.725 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 265\302\265s 0 ADV_IND 2653 4.726 6c:c6:23:80:30:28 LE 1M LE LL 12 790\302\265s 0 SCAN_REQ 2654 4.727 64:0d:49:f9:4d:a4 LE 1M LE LL 12 449\302\265s 0 SCAN_REQ 2655 4.731 d6:bf:03:c5:20:42 LE 1M LE LL 36 4298\302\265s 0 ADV_IND 2656 4.732 d6:bf:03:c5:20:42 LE 1M LE LL 36 354\302\265s 0 ADV_IND 2657 4.732 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2658 4.733 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2659 4.733 d6:bf:03:c5:20:42 LE 1M LE LL 36 138\302\265s 0 ADV_IND 2660 4.738 43:bd:56:bd:74:f9 LE 1M LE LL 37 5058\302\265s 0 ADV_NONCONN_IND 2661 4.739 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2662 4.74 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2663 4.745 7d:30:e4:59:cd:06 LE 1M LE LL 25 4543\302\265s 0 ADV_IND 2664 4.746 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 2665 4.747 64:0d:49:f9:4d:a4 LE 1M LE LL 12 840\302\265s 0 SCAN_REQ 2666 4.758 1e:28:49:84:c5:cd LE 1M LE LL 37 10667\302\265s 0 ADV_NONCONN_IND 2667 4.758 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2668 4.759 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2669 4.76 SamsungE_07:d8:8f LE 1M LE LL 34 748\302\265s 0 ADV_NONCONN_IND 2670 4.764 11:fe:ef:ed:38:82 LE 1M LE LL 37 3376\302\265s 0 ADV_NONCONN_IND 2671 4.764 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2672 4.771 d2:52:6a:67:61:fd LE 1M LE LL 21 6128\302\265s 0 ADV_IND 2673 4.771 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 2674 4.772 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 2675 4.773 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 2676 4.773 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2677 4.774 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 518\302\265s 0 ADV_IND 2678 4.774 d2:52:6a:67:61:fd LE 1M LE LL 21 124\302\265s 0 ADV_IND 2679 4.777 50:d3:b9:81:11:84 LE 1M LE LL 12 2238\302\265s 0 SCAN_REQ 2680 4.778 c1:c8:16:ae:fd:1d LE 1M LE LL 36 840\302\265s 0 ADV_IND 2681 4.778 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2682 4.779 64:0d:49:f9:4d:a4 LE 1M LE LL 12 681\302\265s 0 SCAN_REQ 2683 4.782 31:ea:1b:25:0d:1f LE 1M LE LL 37 3202\302\265s 0 ADV_NONCONN_IND 2684 4.783 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2685 4.783 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2686 4.784 50:d3:b9:81:11:84 LE 1M LE LL 12 339\302\265s 0 SCAN_REQ 2687 4.784 71:c9:89:02:1c:fb LE 1M LE LL 12 114\302\265s 0 SCAN_REQ 2688 4.785 SamsungE_07:d5:79 LE 1M LE LL 34 214\302\265s 0 ADV_NONCONN_IND 2689 4.786 3a:d1:ca:1d:4d:de LE 1M LE LL 26 514\302\265s 0 ADV_NONCONN_IND 2690 4.786 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2691 4.787 3a:d1:ca:1d:4d:de LE 1M LE LL 26 695\302\265s 0 ADV_NONCONN_IND 2692 4.792 5c:9e:d4:03:82:5b LE 1M LE LL 37 3934\302\265s 0 ADV_NONCONN_IND 2693 4.792 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2694 4.793 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2695 4.798 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4270\302\265s 0 ADV_NONCONN_IND 2696 4.798 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2697 4.799 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2698 4.801 50:d3:b9:81:11:84 LE 1M LE LL 12 1632\302\265s 0 SCAN_REQ 2699 4.807 40:f0:08:9b:56:91 LE 1M LE LL 37 6589\302\265s 0 ADV_SCAN_IND 2700 4.808 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2701 4.809 64:0d:49:f9:4d:a4 LE 1M LE LL 12 708\302\265s 0 SCAN_REQ 2702 4.811 dd:b9:3b:45:59:8b LE 1M LE LL 24 1551\302\265s 0 ADV_IND 2703 4.812 dd:b9:3b:45:59:8b LE 1M LE LL 24 826\302\265s 0 ADV_IND 2704 4.812 8e:c3:91:99:b0:24 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2705 4.813 dd:b9:3b:45:59:8b LE 1M LE LL 24 300\302\265s 0 ADV_IND 2706 4.813 44:0d:49:c9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2707 4.814 0c:6e:66:d7:ed:03 LE 1M LE LL 37 468\302\265s 0 ADV_NONCONN_IND 2708 4.814 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2709 4.815 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2710 4.82 c0:4e:43:7b:5f:2b LE 1M LE LL 14 4692\302\265s 0 ADV_IND 2711 4.824 d4:73:61:e6:96:e4 LE 1M LE LL 14 3806\302\265s 0 ADV_NONCONN_IND 2712 4.824 d4:73:61:e6:96:e4 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 2713 4.825 ef:6e:3d:68:42:19 LE 1M LE LL 36 330\302\265s 0 ADV_IND 2714 4.826 17:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND[Malformed Packet] 2715 4.826 ef:6e:3d:68:42:19 LE 1M LE LL 36 354\302\265s 0 ADV_IND 2716 4.827 47:4e:9b:89:59:8e LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2717 4.827 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2718 4.828 2b:5e:0e:c8:62:4c LE 1M LE LL 35 648\302\265s 0 ADV_NONCONN_IND 2719 4.828 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2720 4.829 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2721 4.831 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1548\302\265s 0 ADV_IND 2722 4.831 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 2723 4.832 cf:4f:81:f5:7d:55 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2724 4.832 cf:4f:81:f5:7d:55 LE 1M LE LL 36 136\302\265s 0 ADV_IND 2725 4.832 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2726 4.833 cf:4f:81:f5:7d:55 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2727 4.833 cf:4f:81:f5:7d:55 LE 1M LE LL 36 137\302\265s 0 ADV_IND 2728 4.834 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2729 4.834 cf:4f:81:f5:7d:55 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2730 4.836 07:69:22:f0:72:30 LE 1M LE LL 37 1888\302\265s 0 ADV_NONCONN_IND 2731 4.837 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2732 4.837 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2733 4.838 43:bd:56:bd:74:f9 LE 1M LE LL 37 922\302\265s 0 ADV_NONCONN_IND 2734 4.839 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2735 4.84 64:0d:49:f9:4d:a4 LE 1M LE LL 12 163\302\265s 0 SCAN_REQ 2736 4.848 32:43:3c:28:8d:92 LE 1M LE LL 37 8378\302\265s 0 ADV_NONCONN_IND 2737 4.849 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2738 4.849 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2739 4.852 50:d3:b9:81:11:84 LE 1M LE LL 12 2158\302\265s 0 SCAN_REQ 2740 4.853 45:9b:f4:8b:97:f9 LE 1M LE LL 24 411\302\265s 0 ADV_IND 2741 4.853 6c:c7:a3:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2742 4.853 45:9b:f4:8b:97:f9 LE 1M LE LL 24 150\302\265s 0 ADV_IND 2743 4.854 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2744 4.854 45:9b:f4:8b:97:f9 LE 1M LE LL 6 150\302\265s 0 ADV_NONCONN_IND 2745 4.857 e7:70:80:c3:ad:91 LE 1M LE LL 36 3241\302\265s 0 ADV_IND 2746 4.858 c2:f4:8b:c5:ec:01 LE 1M LE LL 36 515\302\265s 0 ADV_IND 2747 4.859 e7:70:80:c3:ad:91 LE 1M LE LL 36 579\302\265s 0 ADV_IND 2748 4.865 1e:28:49:84:c5:cd LE 1M LE LL 37 5820\302\265s 0 ADV_NONCONN_IND 2749 4.866 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2750 4.867 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2751 4.867 11:fe:ef:ed:38:82 LE 1M LE LL 37 172\302\265s 0 ADV_NONCONN_IND 2752 4.868 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2753 4.868 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2754 4.872 e5:ea:46:16:3e:1e LE 1M LE LL 36 3908\302\265s 0 ADV_IND 2755 4.873 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2756 4.873 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2757 4.874 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 2758 4.874 6c:c6:63:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2759 4.879 74:d9:0b:7a:47:5a LE 1M LE LL 23 4541\302\265s 0 ADV_IND 2760 4.881 d6:bf:76:0a:0b:dc LE 1M LE LL 36 1485\302\265s 0 ADV_IND 2761 4.881 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 2762 4.881 d6:bf:76:0a:0b:dc LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2763 4.882 d6:bf:76:0a:0b:dc LE 1M LE LL 36 136\302\265s 0 ADV_IND 2764 4.882 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2765 4.886 c2:f4:e6:80:5e:ae LE 1M LE LL 36 4085\302\265s 0 ADV_IND 2766 4.889 31:ea:1b:25:0d:1f LE 1M LE LL 37 2418\302\265s 0 ADV_NONCONN_IND 2767 4.89 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2768 4.89 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2769 4.895 eb:db:35:2e:09:1b LE 1M LE LL 20 3884\302\265s 0 ADV_IND 2770 4.9 ee:37:74:86:9f:d7 LE 1M LE LL 36 5011\302\265s 0 ADV_IND 2771 4.902 5c:9e:d4:03:82:5b LE 1M LE LL 37 1460\302\265s 0 ADV_NONCONN_IND 2772 4.913 24:c3:d0:ce:d4:37 LE 1M LE LL 37 11155\302\265s 0 ADV_NONCONN_IND 2773 4.914 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2774 4.914 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2775 4.915 SamsungE_07:d8:8f LE 1M LE LL 34 440\302\265s 0 ADV_NONCONN_IND 2776 4.919 cc:15:14:59:64:aa LE 1M LE LL 36 3689\302\265s 0 ADV_IND 2777 4.92 6c:c6:23:80:30:28 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 2778 4.921 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1288\302\265s 0 ADV_NONCONN_IND 2779 4.926 50:d3:b9:81:11:84 LE 1M LE LL 12 4290\302\265s 0 SCAN_REQ 2780 4.926 1f:84:46:51:98:14 LE 1M LE LL 23 256\302\265s 0 ADV_NONCONN_IND 2781 4.927 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2782 4.93 d2:52:6a:67:61:fd LE 1M LE LL 21 2613\302\265s 0 ADV_IND 2783 4.93 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2784 4.93 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 2785 4.931 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 2786 4.932 7d:41:a8:84:30:20 LE 1M LE LL 44 150\302\265s 0 SCAN_REQ 2787 4.932 25:5f:bf:53:1f:d7 LE 1M LE LL 37 444\302\265s 0 ADV_NONCONN_IND 2788 4.934 50:d3:b9:81:11:84 LE 1M LE LL 12 1317\302\265s 0 SCAN_REQ 2789 4.935 71:c4:79:42:57:d8 LE 1M LE LL 21 410\302\265s 0 ADV_IND 2790 4.935 6c:c6:33:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2791 4.935 71:c4:79:42:57:d8 LE 1M LE LL 21 151\302\265s 0 ADV_IND 2792 4.936 SamsungE_07:d5:79 LE 1M LE LL 34 466\302\265s 0 ADV_NONCONN_IND 2793 4.945 07:69:22:f0:72:30 LE 1M LE LL 37 8866\302\265s 0 ADV_NONCONN_IND 2794 4.946 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 2795 4.946 07:69:22:f0:72:30 LE 1M LE LL 37 193\302\265s 0 ADV_NONCONN_IND 2796 4.953 32:43:3c:28:8d:92 LE 1M LE LL 37 5842\302\265s 0 ADV_NONCONN_IND 2797 4.953 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2798 4.954 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2799 4.96 43:bd:56:bd:74:f9 LE 1M LE LL 37 5444\302\265s 0 ADV_NONCONN_IND 2800 4.96 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2801 4.961 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2802 4.964 d5:80:ce:3a:df:84 LE 1M LE LL 36 1924\302\265s 0 ADV_IND 2803 4.965 6e:e5:33:80:20:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2804 4.965 d5:80:ce:3a:df:84 LE 1M LE LL 36 415\302\265s 0 ADV_IND 2805 4.967 1e:28:49:84:c5:cd LE 1M LE LL 37 1522\302\265s 0 ADV_NONCONN_IND 2806 4.968 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2807 4.968 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2808 4.976 79:70:d9:25:16:e2 LE 1M LE LL 25 7657\302\265s 0 ADV_IND 2809 4.978 6e:e1:3b:80:30:40 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 2810 4.978 79:70:d9:25:16:e2 LE 1M LE LL 25 151\302\265s 0 ADV_IND 2811 4.979 0d:62:2c:2a:24:88 LE 1M LE LL 37 394\302\265s 0 ADV_NONCONN_IND 2812 4.992 3a:d1:ca:1d:4d:de LE 1M LE LL 26 13089\302\265s 0 ADV_NONCONN_IND 2813 4.993 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2814 4.993 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2815 4.996 d6:2c:05:d0:15:49 LE 1M LE LL 37 1955\302\265s 0 ADV_IND 2816 4.998 40:f0:08:9b:56:91 LE 1M LE LL 37 1969\302\265s 0 ADV_SCAN_IND 2817 4.999 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2818 5.005 5c:9e:d4:03:82:5b LE 1M LE LL 37 6685\302\265s 0 ADV_NONCONN_IND 2819 5.009 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3644\302\265s 0 ADV_NONCONN_IND 2820 5.01 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2821 5.011 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2822 5.016 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4770\302\265s 0 ADV_NONCONN_IND 2823 5.016 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2824 5.017 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2825 5.019 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1596\302\265s 0 ADV_IND 2826 5.021 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1372\302\265s 0 ADV_NONCONN_IND 2827 5.021 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2828 5.025 7d:30:e4:59:cd:06 LE 1M LE LL 25 3504\302\265s 0 ADV_IND[Malformed Packet] 2829 5.026 2f:f0:ca:6a:d5:82 LE 1M LE LL 37 707\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2830 5.027 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2831 5.034 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6621\302\265s 0 ADV_NONCONN_IND 2832 5.034 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2833 5.035 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2834 5.036 25:5f:bf:53:1f:d7 LE 1M LE LL 37 934\302\265s 0 ADV_NONCONN_IND 2835 5.037 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2836 5.037 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2837 5.039 e5:ea:46:16:3e:1e LE 1M LE LL 36 924\302\265s 0 ADV_IND 2838 5.04 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2839 5.041 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 2840 5.042 2b:5e:0e:c8:62:4c LE 1M LE LL 35 747\302\265s 0 ADV_NONCONN_IND 2841 5.042 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2842 5.043 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 2843 5.046 43:bd:56:bd:74:f9 LE 1M LE LL 37 2774\302\265s 0 ADV_NONCONN_IND 2844 5.047 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2845 5.048 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2846 5.052 07:69:22:f0:72:30 LE 1M LE LL 37 3687\302\265s 0 ADV_NONCONN_IND 2847 5.052 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 2848 5.053 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2849 5.067 74:d9:0b:7a:47:5a LE 1M LE LL 23 14170\302\265s 0 ADV_IND 2850 5.073 d6:bf:03:c5:20:42 LE 1M LE LL 36 5566\302\265s 0 ADV_IND 2851 5.074 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2852 5.074 d6:bf:03:c5:20:42 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2853 5.074 d6:bf:03:c5:20:42 LE 1M LE LL 36 137\302\265s 0 ADV_IND 2854 5.079 0d:62:2c:2a:24:88 LE 1M LE LL 37 4073\302\265s 0 ADV_NONCONN_IND 2855 5.079 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2856 5.08 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2857 5.082 d2:52:6a:67:61:fd LE 1M LE LL 21 1887\302\265s 0 ADV_IND 2858 5.084 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 2859 5.084 6c:c6:23:80:30:28 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 2860 5.084 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 2861 5.085 d2:52:6a:67:61:fd LE 1M LE LL 21 629\302\265s 0 ADV_IND 2862 5.087 1f:84:46:51:98:14 LE 1M LE LL 23 1542\302\265s 0 ADV_NONCONN_IND 2863 5.087 1f:94:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2864 5.088 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2865 5.096 31:ea:1b:25:0d:1f LE 1M LE LL 37 8071\302\265s 0 ADV_NONCONN_IND 2866 5.097 31:ea:1b:25:0d:1f LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 2867 5.097 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 2868 5.099 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1875\302\265s 0 ADV_NONCONN_IND 2869 5.1 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2870 5.101 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2871 5.105 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 3742\302\265s 0 ADV_IND 2872 5.106 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 2873 5.107 ed:4e:4a:f5:08:6e LE 1M LE LL 14 202\302\265s 0 ADV_NONCONN_IND 2874 5.112 5c:9e:d4:03:82:5b LE 1M LE LL 37 4884\302\265s 0 ADV_NONCONN_IND 2875 5.112 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2876 5.113 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2877 5.114 69:a9:48:2f:b7:16 LE 1M LE LL 37 562\302\265s 0 ADV_NONCONN_IND 2878 5.115 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2879 5.117 c5:65:68:79:19:c8 LE 1M LE LL 36 2108\302\265s 0 ADV_IND 2880 5.121 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3156\302\265s 0 ADV_NONCONN_IND 2881 5.121 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2882 5.122 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2883 5.122 0c:6e:66:d7:ed:03 LE 1M LE LL 37 212\302\265s 0 ADV_NONCONN_IND 2884 5.123 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2885 5.124 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2886 5.131 7f:ab:0f:33:5d:32 LE 1M LE LL 12 6717\302\265s 0 SCAN_REQ 2887 5.131 45:9b:f4:8b:97:f9 LE 1M LE LL 24 410\302\265s 0 ADV_IND 2888 5.132 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2889 5.132 27:f1:d5:6a:d5:82 LE 1M LE LL 37 341\302\265s 0 ADV_NONCONN_IND 2890 5.133 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2891 5.134 1f:84:46:51:98:14 LE 1M LE LL 23 324\302\265s 0 ADV_NONCONN_IND 2892 5.139 2e:86:8d:c9:47:bd LE 1M LE LL 21 5117\302\265s 0 ADV_NONCONN_IND 2893 5.14 16:ed:93:0f:fa:b0 LE 1M LE LL 37 528\302\265s 0 ADV_NONCONN_IND 2894 5.141 c0:41:04:2e:be:9d LE 1M LE LL 36 400\302\265s 0 ADV_IND 2895 5.142 6c:c6:23:80:30:28 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 2896 5.143 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1184\302\265s 0 ADV_NONCONN_IND 2897 5.144 25:5f:bf:53:1f:d7 LE 1M LE LL 37 703\302\265s 0 ADV_NONCONN_IND 2898 5.145 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2899 5.146 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2900 5.15 43:bd:56:bd:74:f9 LE 1M LE LL 37 3712\302\265s 0 ADV_NONCONN_IND 2901 5.15 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 2902 5.151 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2903 5.155 08:ec:5e:66:cd:0d LE 1M LE LL 23 3044\302\265s 0 ADV_NONCONN_IND 2904 5.155 08:ec:5e:66:cd:0d LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 2905 5.155 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2906 5.161 07:69:22:f0:72:30 LE 1M LE LL 37 5206\302\265s 0 ADV_NONCONN_IND 2907 5.162 07:69:22:f0:72:30 LE 1M LE LL 37 171\302\265s 0 ADV_NONCONN_IND 2908 5.162 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2909 5.165 ef:6e:3d:68:42:19 LE 1M LE LL 36 2328\302\265s 0 ADV_IND 2910 5.165 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2911 5.166 ef:6e:3d:68:42:19 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2912 5.166 6c:c6:23:80:30:28 LE 1M LE LL 12 654\302\265s 0 SCAN_REQ 2913 5.167 cf:4f:81:f5:7d:55 LE 1M LE LL 36 736\302\265s 0 ADV_IND 2914 5.177 7f:ab:0f:33:5d:32 LE 1M LE LL 12 9631\302\265s 0 SCAN_REQ 2915 5.178 11:fe:ef:ed:38:82 LE 1M LE LL 37 766\302\265s 0 ADV_NONCONN_IND 2916 5.179 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2917 5.183 7f:ab:0f:33:5d:32 LE 1M LE LL 12 3365\302\265s 0 SCAN_REQ 2918 5.184 0d:62:2c:2a:24:88 LE 1M LE LL 37 856\302\265s 0 ADV_NONCONN_IND 2919 5.184 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2920 5.186 40:f0:08:9b:56:91 LE 1M LE LL 37 1683\302\265s 0 ADV_SCAN_IND 2921 5.187 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2922 5.192 e7:70:80:c3:ad:91 LE 1M LE LL 36 5344\302\265s 0 ADV_IND 2923 5.193 6c:c6:23:80:30:28 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 2924 5.193 e7:70:80:c3:ad:91 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 2925 5.193 e7:70:80:c3:ad:91 LE 1M LE LL 36 136\302\265s 0 ADV_IND 2926 5.199 e5:ea:46:16:3e:1e LE 1M LE LL 36 4955\302\265s 0 ADV_IND 2927 5.199 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2928 5.2 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 2929 5.2 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 2930 5.2 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 2931 5.206 f1:ff:a7:1a:55:8d LE 1M LE LL 36 5205\302\265s 0 ADV_IND 2932 5.216 0b:f9:be:c7:0f:fb LE 1M LE LL 23 10155\302\265s 0 ADV_NONCONN_IND 2933 5.217 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2934 5.217 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 2935 5.218 5c:9e:d4:03:82:5b LE 1M LE LL 37 675\302\265s 0 ADV_NONCONN_IND 2936 5.219 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2937 5.219 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2938 5.22 cf:c8:cc:72:d8:be LE 1M LE LL 14 111\302\265s 0 ADV_NONCONN_IND 2939 5.22 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 2940 5.22 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 2941 5.222 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1898\302\265s 0 ADV_NONCONN_IND 2942 5.223 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2943 5.227 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3415\302\265s 0 ADV_NONCONN_IND 2944 5.228 7f:ab:0f:33:5d:32 LE 1M LE LL 12 572\302\265s 0 SCAN_REQ 2945 5.241 d2:52:6a:67:61:fd LE 1M LE LL 21 13226\302\265s 0 ADV_IND 2946 5.242 27:f1:d5:6a:d5:82 LE 1M LE LL 37 669\302\265s 0 ADV_NONCONN_IND 2947 5.253 25:5f:bf:53:1f:d7 LE 1M LE LL 37 10687\302\265s 0 ADV_NONCONN_IND 2948 5.254 07:68:f4:cf:8b:17 LE 1M LE LL 101 179\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2949 5.256 43:bd:56:bd:74:f9 LE 1M LE LL 37 1654\302\265s 0 ADV_NONCONN_IND 2950 5.263 32:43:3c:28:8d:92 LE 1M LE LL 37 6671\302\265s 0 ADV_NONCONN_IND 2951 5.264 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2952 5.264 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2953 5.265 07:69:22:f0:72:30 LE 1M LE LL 37 542\302\265s 0 ADV_NONCONN_IND 2954 5.266 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 2955 5.266 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2956 5.287 11:fe:ef:ed:38:82 LE 1M LE LL 37 20227\302\265s 0 ADV_NONCONN_IND 2957 5.288 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2958 5.288 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2959 5.29 1e:28:49:84:c5:cd LE 1M LE LL 37 1858\302\265s 0 ADV_NONCONN_IND 2960 5.291 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2961 5.292 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 2962 5.295 7d:30:e4:59:cd:06 LE 1M LE LL 25 3059\302\265s 0 ADV_IND 2963 5.296 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 2964 5.305 d5:80:ce:3a:df:84 LE 1M LE LL 36 8757\302\265s 0 ADV_IND 2965 5.31 31:ea:1b:25:0d:1f LE 1M LE LL 37 4519\302\265s 0 ADV_NONCONN_IND 2966 5.31 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2967 5.311 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2968 5.312 3a:d1:ca:1d:4d:de LE 1M LE LL 26 630\302\265s 0 ADV_NONCONN_IND 2969 5.313 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 2970 5.313 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 2971 5.325 5c:9e:d4:03:82:5b LE 1M LE LL 37 11685\302\265s 0 ADV_NONCONN_IND 2972 5.326 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2973 5.327 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 2974 5.327 0c:6e:66:d7:ed:03 LE 1M LE LL 37 346\302\265s 0 ADV_NONCONN_IND 2975 5.328 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 2976 5.329 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 2977 5.33 69:ad:50:2f:b7:16 LE 1M LE LL 37 1083\302\265s 0 ADV_NONCONN_IND 2978 5.331 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2979 5.332 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1123\302\265s 0 ADV_NONCONN_IND 2980 5.342 47:4e:9b:89:59:8e LE 1M LE LL 12 9519\302\265s 0 SCAN_REQ 2981 5.343 16:ed:93:0f:fa:b0 LE 1M LE LL 37 648\302\265s 0 ADV_NONCONN_IND 2982 5.344 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2983 5.345 2b:5e:0e:c8:62:4c LE 1M LE LL 35 666\302\265s 0 ADV_NONCONN_IND 2984 5.345 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 2985 5.346 2b:5e:0e:c8:62:4c LE 1M LE LL 35 177\302\265s 0 ADV_NONCONN_IND 2986 5.356 25:5f:bf:53:1f:d7 LE 1M LE LL 37 9454\302\265s 0 ADV_NONCONN_IND 2987 5.356 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2988 5.357 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2989 5.36 43:bd:56:bd:74:f9 LE 1M LE LL 37 2442\302\265s 0 ADV_NONCONN_IND 2990 5.36 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 2991 5.361 f0:39:a7:b1:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 2992 5.365 32:43:3c:28:8d:92 LE 1M LE LL 37 2925\302\265s 0 ADV_NONCONN_IND 2993 5.365 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2994 5.366 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 2995 5.368 07:69:22:f0:72:30 LE 1M LE LL 37 2422\302\265s 0 ADV_NONCONN_IND 2996 5.369 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 2997 5.37 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 2998 5.382 5e:93:36:dd:d3:09 LE 1M LE LL 10 12178\302\265s 0 ADV_SCAN_IND 2999 5.389 Tilgin_9c:87:78 LE 1M LE LL 23 6758\302\265s 0 AUX_CONNECT_RSP[Malformed Packet] 3000 5.39 61:9c:87:78:87:2b LE 1M LE LL 23 876\302\265s 0 ADV_IND 3001 5.391 11:fe:ef:ed:38:82 LE 1M LE LL 37 364\302\265s 0 ADV_NONCONN_IND 3002 5.391 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3003 5.392 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3004 5.397 d2:52:6a:67:61:fd LE 1M LE LL 21 4784\302\265s 0 ADV_IND 3005 5.399 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 3006 5.399 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3007 5.4 d2:52:6a:67:61:fd LE 1M LE LL 21 1010\302\265s 0 ADV_IND 3008 5.402 64:0d:49:f9:4d:a4 LE 1M LE LL 12 1559\302\265s 0 SCAN_REQ 3009 5.403 45:9b:f4:8b:97:f9 LE 1M LE LL 24 411\302\265s 0 ADV_IND 3010 5.403 6c:c6:23:80:30:28 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3011 5.403 45:9b:f4:8b:97:f9 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3012 5.416 d6:bf:03:c5:20:42 LE 1M LE LL 36 12294\302\265s 0 ADV_IND 3013 5.419 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3283\302\265s 0 ADV_NONCONN_IND 3014 5.42 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3015 5.421 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3016 5.427 5c:9e:d4:03:82:5b LE 1M LE LL 37 5438\302\265s 0 ADV_NONCONN_IND 3017 5.427 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3018 5.428 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3019 5.433 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4271\302\265s 0 ADV_NONCONN_IND 3020 5.433 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3021 5.434 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3022 5.436 61:a9:68:2f:b7:16 LE 1M LE LL 37 2289\302\265s 0 ADV_NONCONN_IND 3023 5.439 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2029\302\265s 0 ADV_NONCONN_IND 3024 5.439 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3025 5.441 74:d9:0b:7a:47:5a LE 1M LE LL 23 886\302\265s 0 ADV_IND 3026 5.441 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3027 5.441 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3028 5.453 16:ed:93:0f:fa:b0 LE 1M LE LL 37 11095\302\265s 0 ADV_NONCONN_IND 3029 5.453 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3030 5.454 2b:5e:0e:c8:62:4c LE 1M LE LL 35 662\302\265s 0 ADV_NONCONN_IND 3031 5.455 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3032 5.455 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3033 5.456 c5:65:68:79:19:c8 LE 1M LE LL 36 140\302\265s 0 ADV_IND 3034 5.458 c1:c8:16:ae:fd:1d LE 1M LE LL 36 1919\302\265s 0 ADV_IND 3035 5.459 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3036 5.461 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2444\302\265s 0 ADV_NONCONN_IND 3037 5.462 c6:f1:43:db:77:1d LE 1M LE LL 36 697\302\265s 0 ADV_IND 3038 5.468 32:43:3c:28:8d:92 LE 1M LE LL 37 5643\302\265s 0 ADV_NONCONN_IND 3039 5.469 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3040 5.473 07:69:22:f0:72:30 LE 1M LE LL 37 4295\302\265s 0 ADV_NONCONN_IND 3041 5.474 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3042 5.475 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3043 5.493 1e:28:49:84:c5:cd LE 1M LE LL 37 17956\302\265s 0 ADV_NONCONN_IND 3044 5.493 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3045 5.494 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3046 5.503 0d:62:2c:2a:24:88 LE 1M LE LL 37 8631\302\265s 0 ADV_NONCONN_IND 3047 5.504 0d:62:2c:2a:24:88 LE 1M LE LL 5 180\302\265s 0 ADV_NONCONN_IND 3048 5.504 f1:c9:e3:d0:15:49 LE 1M LE LL 37 349\302\265s 0 ADV_IND 3049 5.505 ef:6e:3d:68:42:19 LE 1M LE LL 36 286\302\265s 0 ADV_IND 3050 5.506 cf:4f:81:f5:7d:55 LE 1M LE LL 6 1087\302\265s 0 SCAN_RSP 3051 5.517 2e:86:8d:c9:47:bd LE 1M LE LL 21 10891\302\265s 0 ADV_NONCONN_IND 3052 5.52 31:ea:1b:25:0d:1f LE 1M LE LL 37 2419\302\265s 0 ADV_NONCONN_IND 3053 5.52 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3054 5.521 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3055 5.529 5c:9e:d4:03:82:5b LE 1M LE LL 37 7842\302\265s 0 ADV_NONCONN_IND 3056 5.53 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3057 5.53 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 3058 5.534 47:4e:9b:89:59:8e LE 1M LE LL 12 3103\302\265s 0 SCAN_REQ 3059 5.535 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 927\302\265s 0 ADV_NONCONN_IND 3060 5.536 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3061 5.539 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 2710\302\265s 0 ADV_IND 3062 5.541 c8:de:06:91:ba:b3 LE 1M LE LL 36 2075\302\265s 0 ADV_IND 3063 5.542 69:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3064 5.546 f1:ff:a7:1a:55:8d LE 1M LE LL 36 4336\302\265s 0 ADV_IND 3065 5.547 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3066 5.552 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5257\302\265s 0 ADV_NONCONN_IND 3067 5.553 16:ed:93:0f:fa:b0 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 3068 5.553 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3069 5.554 d2:52:6a:67:61:fd LE 1M LE LL 21 671\302\265s 0 ADV_IND 3070 5.556 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 3071 5.557 71:c9:89:02:1c:fb LE 1M LE LL 12 856\302\265s 0 SCAN_REQ 3072 5.558 2b:5e:0e:c8:62:4c LE 1M LE LL 35 874\302\265s 0 ADV_NONCONN_IND 3073 5.558 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3074 5.559 2b:5e:0e:c8:62:4c LE 1M LE LL 35 180\302\265s 0 ADV_NONCONN_IND 3075 5.56 27:f1:d5:6a:d5:82 LE 1M LE LL 37 867\302\265s 0 ADV_NONCONN_IND 3076 5.561 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3077 5.562 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3078 5.568 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5296\302\265s 0 ADV_NONCONN_IND 3079 5.568 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3080 5.569 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3081 5.57 43:bd:56:bd:74:f9 LE 1M LE LL 37 541\302\265s 0 ADV_NONCONN_IND 3082 5.57 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3083 5.571 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3084 5.572 7d:30:e4:59:cd:06 LE 1M LE LL 25 768\302\265s 0 ADV_IND 3085 5.573 0c:c1:99:81:70:04 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 3086 5.574 7f:e1:7b:e4:24:1c LE 1M LE LL 12 840\302\265s 0 SCAN_REQ 3087 5.576 32:43:3c:28:8d:92 LE 1M LE LL 37 1161\302\265s 0 ADV_NONCONN_IND 3088 5.576 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3089 5.577 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3090 5.591 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 14023\302\265s 0 ADV_NONCONN_IND 3091 5.592 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3092 5.592 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3093 5.595 1e:28:49:84:c5:cd LE 1M LE LL 37 3049\302\265s 0 ADV_NONCONN_IND 3094 5.596 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3095 5.597 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3096 5.61 0d:62:2c:2a:24:88 LE 1M LE LL 37 13009\302\265s 0 ADV_NONCONN_IND 3097 5.61 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3098 5.611 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3099 5.62 31:ea:1b:25:0d:1f LE 1M LE LL 37 9086\302\265s 0 ADV_NONCONN_IND 3100 5.621 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3101 5.622 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3102 5.629 74:d9:0b:7a:47:5a LE 1M LE LL 23 6527\302\265s 0 ADV_IND 3103 5.631 5c:9e:d4:03:82:5b LE 1M LE LL 37 2305\302\265s 0 ADV_NONCONN_IND 3104 5.632 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3105 5.635 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2838\302\265s 0 ADV_NONCONN_IND 3106 5.636 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 3107 5.636 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3108 5.637 d5:80:ce:3a:df:84 LE 1M LE LL 36 705\302\265s 0 ADV_IND 3109 5.638 6c:cb:b9:85:38:84 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3110 5.639 d5:80:ce:3a:df:84 LE 1M LE LL 36 164\302\265s 0 ADV_IND 3111 5.639 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3112 5.64 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 443\302\265s 0 ADV_NONCONN_IND 3113 5.642 d6:11:ee:07:97:9a LE 1M LE LL 36 1601\302\265s 0 ADV_IND 3114 5.643 d6:11:ee:07:97:9a LE 1M LE LL 36 353\302\265s 0 ADV_IND 3115 5.643 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3116 5.644 d6:11:ee:17:93:aa LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3117 5.644 d6:11:ee:07:97:9a LE 1M LE LL 36 138\302\265s 0 ADV_IND 3118 5.644 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3119 5.645 d6:11:ee:07:97:9a LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3120 5.648 HuaweiTe_d1:97:cf LE 1M LE LL 28 3290\302\265s 0 ADV_IND 3121 5.65 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1693\302\265s 0 ADV_NONCONN_IND 3122 5.651 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3123 5.653 d6:11:16:57:f1:d0 LE 1M LE LL 36 2343\302\265s 0 ADV_IND 3124 5.655 48:e3:bf:81:10:04 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 3125 5.656 71:c9:89:02:1c:fb LE 1M LE LL 12 935\302\265s 0 SCAN_REQ 3126 5.656 16:ed:93:0f:fa:b0 LE 1M LE LL 37 550\302\265s 0 ADV_NONCONN_IND 3127 5.657 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3128 5.659 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1668\302\265s 0 ADV_NONCONN_IND 3129 5.666 61:9c:87:78:87:2b LE 1M LE LL 23 6429\302\265s 0 ADV_IND 3130 5.669 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2499\302\265s 0 ADV_NONCONN_IND 3131 5.669 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3132 5.675 43:bd:56:bd:74:f9 LE 1M LE LL 37 4840\302\265s 0 ADV_NONCONN_IND 3133 5.675 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3134 5.676 25:5f:bf:53:1f:d7 LE 1M LE LL 37 370\302\265s 0 ADV_NONCONN_IND 3135 5.677 79:70:d9:25:16:e2 LE 1M LE LL 25 290\302\265s 0 ADV_IND 3136 5.678 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 3137 5.68 07:69:22:f0:72:30 LE 1M LE LL 37 1505\302\265s 0 ADV_NONCONN_IND 3138 5.681 32:43:3c:28:8d:92 LE 1M LE LL 37 855\302\265s 0 ADV_NONCONN_IND 3139 5.681 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3140 5.682 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3141 5.697 1e:28:49:84:c5:cd LE 1M LE LL 37 15001\302\265s 0 ADV_NONCONN_IND 3142 5.698 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3143 5.698 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3144 5.703 11:fe:ef:ed:38:82 LE 1M LE LL 37 3923\302\265s 0 ADV_NONCONN_IND 3145 5.703 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3146 5.704 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3147 5.708 d2:52:6a:67:61:fd LE 1M LE LL 21 3873\302\265s 0 ADV_IND 3148 5.71 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 3149 5.71 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3150 5.71 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3151 5.711 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3152 5.713 c9:2d:18:b6:8c:6b LE 1M LE LL 14 1378\302\265s 0 ADV_NONCONN_IND 3153 5.726 31:ea:1b:25:0d:1f LE 1M LE LL 37 13000\302\265s 0 ADV_NONCONN_IND 3154 5.727 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3155 5.736 0c:6e:66:d7:ed:03 LE 1M LE LL 37 8561\302\265s 0 ADV_NONCONN_IND 3156 5.736 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 3157 5.737 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3158 5.738 5c:9e:d4:03:82:5b LE 1M LE LL 37 783\302\265s 0 ADV_NONCONN_IND 3159 5.739 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3160 5.739 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3161 5.741 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1137\302\265s 0 ADV_NONCONN_IND 3162 5.741 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3163 5.742 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3164 5.748 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5737\302\265s 0 ADV_NONCONN_IND 3165 5.749 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3166 5.749 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3167 5.752 d6:bf:03:c5:20:42 LE 1M LE LL 36 2627\302\265s 0 ADV_IND 3168 5.753 d5:48:f4:d5:20:42 LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 3169 5.754 24:c3:d0:ce:d4:37 LE 1M LE LL 37 277\302\265s 0 ADV_NONCONN_IND 3170 5.756 40:f0:08:9b:56:91 LE 1M LE LL 37 1972\302\265s 0 ADV_SCAN_IND 3171 5.759 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2378\302\265s 0 ADV_NONCONN_IND 3172 5.759 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3173 5.763 1f:84:46:51:98:14 LE 1M LE LL 23 2870\302\265s 0 ADV_NONCONN_IND 3174 5.766 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3063\302\265s 0 ADV_NONCONN_IND 3175 5.766 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3176 5.777 08:ec:5e:66:cd:0d LE 1M LE LL 23 10402\302\265s 0 ADV_NONCONN_IND 3177 5.778 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3178 5.778 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3179 5.78 07:69:22:f0:72:30 LE 1M LE LL 37 1416\302\265s 0 ADV_NONCONN_IND 3180 5.78 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 3181 5.781 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3182 5.783 43:bd:56:bd:76:f9 LE 1M LE LL 37 2120\302\265s 0 ADV_NONCONN_IND 3183 5.784 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3184 5.785 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3185 5.794 c1:c8:16:ae:fd:1d LE 1M LE LL 36 9049\302\265s 0 ADV_IND 3186 5.796 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3187 5.796 c1:c8:16:ae:fd:1d LE 1M LE LL 36 415\302\265s 0 ADV_IND 3188 5.798 c5:65:68:79:19:c8 LE 1M LE LL 36 1587\302\265s 0 ADV_IND 3189 5.799 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3190 5.8 c5:65:68:79:19:c8 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3191 5.801 1e:28:49:84:c5:cd LE 1M LE LL 37 509\302\265s 0 ADV_NONCONN_IND 3192 5.802 17:5f:43:7c:0a:89 LE 1M LE LL 23 1198\302\265s 0 ADV_NONCONN_IND 3193 5.804 11:fe:ef:ed:38:82 LE 1M LE LL 37 1140\302\265s 0 ADV_NONCONN_IND 3194 5.804 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3195 5.81 7f:f8:8c:bb:a1:98 LE 1M LE LL 24 5103\302\265s 0 ADV_IND 3196 5.811 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 368\302\265s 0 ADV_IND 3197 5.813 dd:b9:3b:45:59:8b LE 1M LE LL 24 2333\302\265s 0 ADV_IND 3198 5.814 74:d9:0b:7a:47:5a LE 1M LE LL 23 880\302\265s 0 ADV_IND 3199 5.82 6c:c6:23:80:30:28 LE 1M LE LL 12 4996\302\265s 0 SCAN_REQ 3200 5.828 31:ea:1b:25:0d:1f LE 1M LE LL 37 8731\302\265s 0 ADV_NONCONN_IND 3201 5.832 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 3636\302\265s 0 ADV_IND 3202 5.834 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3203 5.834 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3204 5.837 ec:af:39:d1:f5:fe LE 1M LE LL 14 2647\302\265s 0 ADV_NONCONN_IND 3205 5.839 ef:6e:3d:68:42:19 LE 1M LE LL 36 1609\302\265s 0 ADV_IND 3206 5.84 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3207 5.84 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3208 5.84 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 3209 5.841 0b:f9:be:c7:0f:fb LE 1M LE LL 23 654\302\265s 0 ADV_NONCONN_IND 3210 5.842 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3211 5.842 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3212 5.843 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1024\302\265s 0 ADV_IND 3213 5.844 cf:4f:81:f5:7d:55 LE 1M LE LL 36 353\302\265s 0 ADV_IND 3214 5.845 cf:4f:81:f5:7d:55 LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 3215 5.847 7d:30:e4:59:cd:06 LE 1M LE LL 25 2106\302\265s 0 ADV_IND 3216 5.848 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 3217 5.851 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2428\302\265s 0 ADV_NONCONN_IND 3218 5.853 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1987\302\265s 0 ADV_NONCONN_IND 3219 5.854 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3220 5.854 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3221 5.86 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4798\302\265s 0 ADV_NONCONN_IND 3222 5.86 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3223 5.861 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3224 5.865 e5:ea:46:16:3e:1e LE 1M LE LL 36 3834\302\265s 0 ADV_IND 3225 5.865 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3226 5.866 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3227 5.866 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 3228 5.866 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3229 5.867 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3230 5.867 e5:ea:46:16:3e:1e LE 1M LE LL 36 138\302\265s 0 ADV_IND 3231 5.868 e7:70:80:c3:ad:91 LE 1M LE LL 36 130\302\265s 0 ADV_IND 3232 5.869 47:4e:9b:89:59:8e LE 1M LE LL 12 653\302\265s 0 SCAN_REQ 3233 5.873 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4070\302\265s 0 ADV_NONCONN_IND 3234 5.873 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3235 5.875 e5:ea:90:fe:c4:42 LE 1M LE LL 36 901\302\265s 0 ADV_IND 3236 5.876 6c:c6:23:80:30:28 LE 1M LE LL 12 1258\302\265s 0 SCAN_REQ 3237 5.881 f1:ff:a7:1a:55:8d LE 1M LE LL 36 4609\302\265s 0 ADV_IND 3238 5.886 07:69:22:f0:72:30 LE 1M LE LL 37 4569\302\265s 0 ADV_NONCONN_IND 3239 5.887 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3240 5.887 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3241 5.888 25:5f:bf:53:1f:d7 LE 1M LE LL 37 702\302\265s 0 ADV_NONCONN_IND 3242 5.889 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3243 5.889 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3244 5.895 49:08:83:d3:3a:6c LE 1M LE LL 12 4988\302\265s 0 SCAN_REQ 3245 5.895 d6:bf:76:0a:0b:fc LE 1M LE LL 36 415\302\265s 0 ADV_IND 3246 5.897 47:4e:9b:89:59:8e LE 1M LE LL 12 1260\302\265s 0 SCAN_REQ 3247 5.902 47:4e:9b:89:59:8e LE 1M LE LL 12 5128\302\265s 0 SCAN_REQ 3248 5.903 6c:c6:23:80:30:28 LE 1M LE LL 12 932\302\265s 0 SCAN_REQ 3249 5.909 1e:28:49:84:c5:cd LE 1M LE LL 37 5578\302\265s 0 ADV_NONCONN_IND 3250 5.911 11:fe:ef:ed:38:82 LE 1M LE LL 37 2048\302\265s 0 ADV_NONCONN_IND 3251 5.912 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3252 5.913 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3253 5.916 0d:62:2c:2a:24:88 LE 1M LE LL 37 3230\302\265s 0 ADV_NONCONN_IND 3254 5.917 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3255 5.917 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3256 5.935 cc:15:14:59:64:aa LE 1M LE LL 36 17788\302\265s 0 ADV_IND 3257 5.937 6c:c6:23:80:30:28 LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 3258 5.937 cc:15:14:59:64:aa LE 1M LE LL 36 414\302\265s 0 ADV_IND 3259 5.94 31:ea:1b:25:0d:1f LE 1M LE LL 37 2228\302\265s 0 ADV_NONCONN_IND 3260 5.94 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3261 5.941 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3262 5.947 5c:9e:d4:03:82:5b LE 1M LE LL 37 5345\302\265s 0 ADV_NONCONN_IND 3263 5.947 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3264 5.948 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3265 5.949 79:70:d9:25:16:e2 LE 1M LE LL 25 1038\302\265s 0 ADV_IND 3266 5.951 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1514\302\265s 0 ADV_NONCONN_IND 3267 5.952 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3268 5.954 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2297\302\265s 0 ADV_NONCONN_IND 3269 5.955 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3270 5.956 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3271 5.959 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2613\302\265s 0 ADV_NONCONN_IND 3272 5.959 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3273 5.96 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3274 5.961 54:1a:f6:0b:96:59 LE 1M LE LL 152 188\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 3275 5.962 4d:bb:b4:8b:57:e9 LE 1M LE LL 6 93\302\265s 0 SCAN_RSP 3276 5.962 45:9b:f4:8b:97:f9 LE 1M LE LL 24 132\302\265s 0 ADV_IND 3277 5.968 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5818\302\265s 0 ADV_NONCONN_IND 3278 5.969 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3279 5.969 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3280 5.971 d5:80:ce:3a:df:84 LE 1M LE LL 36 1206\302\265s 0 ADV_IND 3281 5.971 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3282 5.972 d5:80:ce:3a:df:84 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3283 5.972 d5:80:ce:3a:df:84 LE 1M LE LL 36 135\302\265s 0 ADV_IND 3284 5.973 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3285 5.973 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3286 5.973 d5:80:ce:3a:df:84 LE 1M LE LL 36 137\302\265s 0 ADV_IND 3287 5.974 2b:5e:0e:c8:62:4c LE 1M LE LL 35 436\302\265s 0 ADV_NONCONN_IND 3288 5.988 07:69:22:f0:72:30 LE 1M LE LL 37 13502\302\265s 0 ADV_NONCONN_IND 3289 5.988 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 3290 5.989 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3291 5.99 ce:52:f1:1d:9a:0b LE 1M LE LL 36 595\302\265s 0 ADV_IND[Malformed Packet] 3292 5.992 43:bd:56:bd:74:f9 LE 1M LE LL 37 1332\302\265s 0 ADV_NONCONN_IND 3293 5.992 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3294 6.001 74:d9:0b:7a:47:5a LE 1M LE LL 23 8076\302\265s 0 ADV_IND 3295 6.001 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3296 6.002 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3297 6.002 LE 1M LE LL 36 160\302\265s 0 Unknown 3298 6.003 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 742\302\265s 0 ADV_IND 3299 6.012 11:fe:ef:ed:38:82 LE 1M LE LL 37 8648\302\265s 0 ADV_NONCONN_IND 3300 6.013 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3301 6.013 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3302 6.017 1e:28:49:84:c5:cd LE 1M LE LL 37 3105\302\265s 0 ADV_NONCONN_IND 3303 6.017 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3304 6.018 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3305 6.018 d2:52:6a:67:61:fd LE 1M LE LL 21 225\302\265s 0 ADV_IND 3306 6.019 5f:ab:4a:c2:70:a2 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3307 6.02 d2:52:6a:67:61:fd LE 1M LE LL 21 1010\302\265s 0 ADV_IND 3308 6.02 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3309 6.021 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3310 6.022 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3311 6.023 0d:62:2c:2a:24:88 LE 1M LE LL 37 1247\302\265s 0 ADV_NONCONN_IND 3312 6.024 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3313 6.024 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3314 6.034 e5:ea:46:16:3e:1e LE 1M LE LL 36 9024\302\265s 0 ADV_IND 3315 6.034 5f:ab:4a:c2:70:a2 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3316 6.034 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3317 6.035 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 3318 6.044 31:ea:1b:25:0d:1f LE 1M LE LL 37 9070\302\265s 0 ADV_NONCONN_IND 3319 6.051 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6683\302\265s 0 ADV_NONCONN_IND 3320 6.052 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 3321 6.052 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3322 6.055 5c:9e:d4:03:82:5b LE 1M LE LL 37 2664\302\265s 0 ADV_NONCONN_IND 3323 6.056 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3324 6.057 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3325 6.059 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2379\302\265s 0 ADV_NONCONN_IND 3326 6.06 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3327 6.061 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3328 6.061 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 122\302\265s 0 ADV_NONCONN_IND 3329 6.062 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3330 6.062 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3331 6.066 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2878\302\265s 0 ADV_NONCONN_IND 3332 6.066 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3333 6.067 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3334 6.078 16:ed:93:0f:fa:b0 LE 1M LE LL 37 10428\302\265s 0 ADV_NONCONN_IND 3335 6.078 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3336 6.079 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3337 6.08 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 780\302\265s 0 ADV_IND 3338 6.082 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2058\302\265s 0 ADV_NONCONN_IND 3339 6.083 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3340 6.087 d6:bf:03:c5:20:42 LE 1M LE LL 36 3888\302\265s 0 ADV_IND 3341 6.088 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3342 6.088 07:69:22:f0:72:30 LE 1M LE LL 37 440\302\265s 0 ADV_NONCONN_IND 3343 6.089 01:68:60:8f:8a:51 LE 1M LE LL 132 117\302\265s 0 SCAN_REQ 3344 6.094 32:43:3c:28:8d:92 LE 1M LE LL 37 3701\302\265s 0 ADV_NONCONN_IND 3345 6.112 43:bd:56:bd:74:f9 LE 1M LE LL 37 17883\302\265s 0 ADV_NONCONN_IND 3346 6.113 64:0d:49:f9:4d:a4 LE 1M LE LL 12 73\302\265s 0 SCAN_REQ 3347 6.113 4e:14:1a:db:9e:19 LE 1M LE LL 12 549\302\265s 0 ADV_IND 3348 6.117 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 4046\302\265s 0 ADV_IND 3349 6.118 c6:f1:43:db:57:1d LE 1M LE LL 36 519\302\265s 0 ADV_IND 3350 6.119 c6:f1:43:db:57:1d LE 1M LE LL 36 353\302\265s 0 ADV_IND 3351 6.122 11:fe:ef:ed:38:82 LE 1M LE LL 37 2513\302\265s 0 ADV_NONCONN_IND 3352 6.126 1e:28:49:84:c5:cd LE 1M LE LL 37 3730\302\265s 0 ADV_NONCONN_IND 3353 6.127 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3354 6.127 de:43:9d:d0:76:21 LE 1M LE LL 12 109\302\265s 0 SCAN_REQ 3355 6.131 0d:62:2c:2a:24:88 LE 1M LE LL 37 3285\302\265s 0 ADV_NONCONN_IND 3356 6.131 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3357 6.132 f0:39:b1:3c:61:f6 LE 1M LE LL 14 88\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 3358 6.135 72:c4:71:2c:70:59 LE 1M LE LL 12 3178\302\265s 0 SCAN_REQ 3359 6.136 6c:c6:23:80:30:28 LE 1M LE LL 12 933\302\265s 0 SCAN_REQ 3360 6.137 c5:65:68:79:19:c8 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3361 6.138 c1:c8:16:ae:fd:1d LE 1M LE LL 36 499\302\265s 0 ADV_IND 3362 6.149 7f:e1:7b:e4:24:1c LE 1M LE LL 12 10776\302\265s 0 SCAN_REQ 3363 6.153 31:ea:1b:25:0d:1f LE 1M LE LL 37 4099\302\265s 0 ADV_NONCONN_IND 3364 6.153 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3365 6.155 7f:e1:7b:e4:24:1c LE 1M LE LL 12 978\302\265s 0 SCAN_REQ 3366 6.156 5c:9e:d4:03:82:5b LE 1M LE LL 37 1072\302\265s 0 ADV_NONCONN_IND 3367 6.159 SamsungE_07:d8:8f LE 1M LE LL 34 3008\302\265s 0 ADV_NONCONN_IND 3368 6.162 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2142\302\265s 0 ADV_NONCONN_IND 3369 6.163 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3370 6.163 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3371 6.169 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4985\302\265s 0 ADV_IND 3372 6.169 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 397\302\265s 0 ADV_NONCONN_IND 3373 6.17 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3374 6.171 6c:63:bc:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 3375 6.173 d2:52:6a:67:61:fd LE 1M LE LL 21 1606\302\265s 0 ADV_IND 3376 6.174 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 3377 6.175 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3378 6.175 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3379 6.176 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3380 6.177 ef:6e:3d:68:42:19 LE 1M LE LL 36 1112\302\265s 0 ADV_IND 3381 6.178 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3382 6.178 ef:6e:3d:68:42:19 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3383 6.178 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 3384 6.179 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3385 6.179 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3386 6.179 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 3387 6.182 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2322\302\265s 0 ADV_NONCONN_IND 3388 6.183 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3389 6.183 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3390 6.185 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1085\302\265s 0 ADV_IND 3391 6.186 cf:4f:81:f5:7d:55 LE 1M LE LL 36 741\302\265s 0 ADV_IND 3392 6.186 76:e8:bb:73:ea:18 LE 1M LE LL 157 354\302\265s 0 ADV_IND[Malformed Packet] 3393 6.19 07:69:22:f0:72:30 LE 1M LE LL 37 1960\302\265s 0 ADV_NONCONN_IND 3394 6.19 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3395 6.191 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3396 6.194 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3202\302\265s 0 ADV_NONCONN_IND 3397 6.195 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3398 6.196 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3399 6.198 32:43:3c:28:8d:92 LE 1M LE LL 37 1776\302\265s 0 ADV_NONCONN_IND 3400 6.198 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3401 6.199 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3402 6.2 e5:e2:46:16:3c:1e LE 1M LE LL 36 612\302\265s 0 ADV_IND 3403 6.2 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 3404 6.202 4d:dc:b7:a2:f3:be LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 3405 6.205 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2850\302\265s 0 SCAN_REQ 3406 6.216 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 10562\302\265s 0 ADV_NONCONN_IND 3407 6.216 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3408 6.218 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1761\302\265s 0 ADV_IND 3409 6.219 61:9c:87:78:87:2b LE 1M LE LL 23 449\302\265s 0 ADV_IND 3410 6.219 4d:dc:b7:a2:f3:be LE 1M LE LL 12 157\302\265s 0 SCAN_REQ 3411 6.22 f1:ff:a7:1a:55:8d LE 1M LE LL 36 162\302\265s 0 ADV_IND 3412 6.22 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3413 6.22 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3414 6.221 11:fe:ef:ed:38:82 LE 1M LE LL 37 978\302\265s 0 ADV_NONCONN_IND 3415 6.222 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3416 6.223 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3417 6.225 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2111\302\265s 0 SCAN_REQ 3418 6.227 6c:c6:23:80:30:28 LE 1M LE LL 12 1415\302\265s 0 SCAN_REQ 3419 6.231 1e:28:49:84:c5:cd LE 1M LE LL 37 4086\302\265s 0 ADV_NONCONN_IND 3420 6.233 0d:62:2c:2a:24:88 LE 1M LE LL 37 1769\302\265s 0 ADV_NONCONN_IND 3421 6.234 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3422 6.234 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3423 6.236 ad:75:da:90:f5:26 LE 1M LE LL 36 1233\302\265s 0 ADV_IND[Malformed Packet] 3424 6.237 6c:c6:23:80:30:28 LE 1M LE LL 12 417\302\265s 0 SCAN_REQ 3425 6.237 87:8f:8b:28:0b:ff LE 1M LE LL 164 482\302\265s 0 ADV_IND[Malformed Packet] 3426 6.239 7f:e1:7b:e4:24:1c LE 1M LE LL 12 648\302\265s 0 SCAN_REQ 3427 6.241 45:9b:f4:8b:97:f9 LE 1M LE LL 24 1903\302\265s 0 ADV_IND 3428 6.242 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3429 6.243 50:d3:b9:81:11:84 LE 1M LE LL 12 831\302\265s 0 SCAN_REQ 3430 6.251 7f:e1:7b:e4:24:1c LE 1M LE LL 12 8436\302\265s 0 SCAN_REQ 3431 6.264 0c:6e:66:d7:ed:03 LE 1M LE LL 37 12109\302\265s 0 ADV_NONCONN_IND 3432 6.264 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3433 6.266 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1040\302\265s 0 ADV_NONCONN_IND 3434 6.266 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3435 6.267 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3436 6.271 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3247\302\265s 0 ADV_NONCONN_IND 3437 6.271 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3438 6.272 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3439 6.273 c3:b4:ca:7c:c4:31 LE 1M LE LL 36 787\302\265s 0 ADV_IND 3440 6.274 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 431\302\265s 0 ADV_NONCONN_IND 3441 6.274 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3442 6.277 cc:15:14:59:64:aa LE 1M LE LL 36 1919\302\265s 0 ADV_IND 3443 6.277 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3444 6.277 cc:15:14:59:64:aa LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3445 6.278 cc:15:14:59:64:aa LE 1M LE LL 36 135\302\265s 0 ADV_IND 3446 6.278 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3447 6.279 cc:15:14:59:64:aa LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3448 6.279 50:d3:b9:81:11:84 LE 1M LE LL 12 653\302\265s 0 SCAN_REQ 3449 6.284 69:a9:4a:2d:83:16 LE 1M LE LL 37 4320\302\265s 0 ADV_NONCONN_IND 3450 6.285 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3451 6.29 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5148\302\265s 0 ADV_NONCONN_IND 3452 6.293 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2050\302\265s 0 ADV_NONCONN_IND 3453 6.293 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3454 6.294 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3455 6.298 07:69:22:f0:72:30 LE 1M LE LL 37 3163\302\265s 0 ADV_NONCONN_IND 3456 6.298 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 3457 6.299 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3458 6.301 43:bd:56:bd:74:f9 LE 1M LE LL 37 1469\302\265s 0 ADV_NONCONN_IND 3459 6.302 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3460 6.302 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3461 6.306 32:43:3c:28:8d:92 LE 1M LE LL 37 2964\302\265s 0 ADV_NONCONN_IND 3462 6.306 32:43:3c:28:8d:92 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 3463 6.307 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3464 6.313 d5:80:ce:3a:df:84 LE 1M LE LL 36 6119\302\265s 0 ADV_IND 3465 6.314 46:cd:f9:15:6d:d0 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3466 6.314 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3467 6.315 d5:80:ce:3a:df:84 LE 1M LE LL 36 135\302\265s 0 ADV_IND 3468 6.315 3f:d4:35:96:2a:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3469 6.316 d5:80:ce:3a:df:84 LE 1M LE LL 6 872\302\265s 0 SCAN_RSP 3470 6.321 42:cd:f9:15:6d:d1 LE 1M LE LL 12 4960\302\265s 0 SCAN_REQ 3471 6.322 d6:11:ee:07:97:9a LE 1M LE LL 36 414\302\265s 0 ADV_IND 3472 6.322 3f:d4:35:96:2a:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3473 6.323 d6:11:ee:07:97:9a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3474 6.323 d6:11:ee:07:97:9a LE 1M LE LL 36 137\302\265s 0 ADV_IND 3475 6.323 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3476 6.324 cf:b6:22:07:97:9a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3477 6.325 40:f0:08:9b:56:91 LE 1M LE LL 37 977\302\265s 0 ADV_SCAN_IND 3478 6.325 46:cd:f9:15:6d:d1 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3479 6.327 6c:c6:23:80:30:28 LE 1M LE LL 12 1477\302\265s 0 SCAN_REQ 3480 6.328 d6:11:16:57:f1:d0 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3481 6.332 d2:52:6a:67:61:fd LE 1M LE LL 21 4335\302\265s 0 ADV_IND 3482 6.333 46:cd:f9:15:6d:d0 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3483 6.333 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 3484 6.334 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3485 6.335 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 3486 6.336 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3487 6.336 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3488 6.337 1e:28:49:84:c5:cd LE 1M LE LL 37 873\302\265s 0 ADV_NONCONN_IND 3489 6.338 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3490 6.338 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3491 6.34 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 767\302\265s 0 SCAN_RSP 3492 6.34 6c:c6:23:80:30:28 LE 1M LE LL 12 654\302\265s 0 SCAN_REQ 3493 6.341 50:d3:b9:81:11:84 LE 1M LE LL 12 934\302\265s 0 SCAN_REQ 3494 6.355 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 13273\302\265s 0 ADV_IND 3495 6.355 46:cd:f9:15:6d:d0 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3496 6.356 7f:f8:8c:bb:a1:a8 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3497 6.356 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 131\302\265s 0 ADV_IND 3498 6.356 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3499 6.357 7f:f8:8c:bb:a1:a8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3500 6.363 e5:ea:46:16:3e:1e LE 1M LE LL 36 6452\302\265s 0 ADV_IND 3501 6.364 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3502 6.364 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3503 6.366 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1963\302\265s 0 ADV_NONCONN_IND 3504 6.367 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 3505 6.367 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3506 6.374 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 6076\302\265s 0 ADV_NONCONN_IND 3507 6.374 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3508 6.375 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3509 6.379 74:d9:0b:7a:47:5a LE 1M LE LL 23 3294\302\265s 0 ADV_IND 3510 6.379 74:d9:0b:7a:47:5a LE 1M LE LL 6 475\302\265s 0 SCAN_RSP 3511 6.395 2b:5e:0e:c8:62:4c LE 1M LE LL 35 15178\302\265s 0 ADV_NONCONN_IND 3512 6.395 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3513 6.396 16:ed:93:0f:fa:b0 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3514 6.396 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3515 6.397 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3516 6.401 08:ec:5e:66:cd:0d LE 1M LE LL 23 3775\302\265s 0 ADV_NONCONN_IND 3517 6.401 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3518 6.402 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3519 6.402 7d:30:e4:59:cd:06 LE 1M LE LL 25 303\302\265s 0 ADV_IND 3520 6.403 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 3521 6.404 50:d3:b9:81:11:84 LE 1M LE LL 12 841\302\265s 0 SCAN_REQ 3522 6.407 32:43:3c:28:8d:92 LE 1M LE LL 37 2397\302\265s 0 ADV_NONCONN_IND 3523 6.408 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3524 6.408 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3525 6.416 5e:93:36:dd:d3:09 LE 1M LE LL 10 7334\302\265s 0 ADV_SCAN_IND 3526 6.417 6c:c6:23:80:30:28 LE 1M LE LL 12 764\302\265s 0 SCAN_REQ 3527 6.418 5e:93:36:dd:d3:09 LE 1M LE LL 10 980\302\265s 0 ADV_SCAN_IND 3528 6.425 11:fe:ef:ed:38:82 LE 1M LE LL 37 7088\302\265s 0 ADV_NONCONN_IND 3529 6.426 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3530 6.426 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3531 6.427 23:c5:05:52:14:fd LE 1M LE LL 103 626\302\265s 0 ADV_IND[Malformed Packet] 3532 6.429 6c:c6:23:80:30:28 LE 1M LE LL 12 335\302\265s 0 SCAN_REQ 3533 6.429 7f:ab:0f:33:5d:32 LE 1M LE LL 12 546\302\265s 0 SCAN_REQ 3534 6.435 17:5f:43:7c:0a:89 LE 1M LE LL 23 5589\302\265s 0 ADV_NONCONN_IND 3535 6.435 17:5f:43:7c:0a:89 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3536 6.439 0d:62:2c:2a:24:88 LE 1M LE LL 37 2839\302\265s 0 ADV_NONCONN_IND 3537 6.442 dd:d8:c3:2e:ed:c8 LE 1M LE LL 36 2835\302\265s 0 ADV_IND 3538 6.447 2e:86:8d:c9:47:bd LE 1M LE LL 21 4835\302\265s 0 ADV_NONCONN_IND 3539 6.447 2e:86:8d:c9:47:bd LE 1M LE LL 21 132\302\265s 0 ADV_NONCONN_IND 3540 6.451 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 3600\302\265s 0 ADV_IND 3541 6.452 3f:d4:35:96:2a:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3542 6.452 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3543 6.452 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 136\302\265s 0 ADV_IND 3544 6.453 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3545 6.453 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3546 6.453 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 138\302\265s 0 ADV_IND 3547 6.454 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3548 6.454 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3549 6.464 cd:45:0c:ce:f1:94 LE 1M LE LL 37 9671\302\265s 0 ADV_IND 3550 6.465 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3551 6.465 3f:d4:35:96:2a:a4 LE 1M LE LL 12 698\302\265s 0 SCAN_REQ 3552 6.467 7f:ab:0f:33:5d:32 LE 1M LE LL 12 1105\302\265s 0 SCAN_REQ 3553 6.468 0b:f9:be:c7:0f:fb LE 1M LE LL 23 675\302\265s 0 ADV_NONCONN_IND 3554 6.468 47:4e:9b:89:59:8e LE 1M LE LL 12 290\302\265s 0 SCAN_REQ 3555 6.469 c5:65:68:79:19:c8 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3556 6.471 31:ea:1b:25:0d:1f LE 1M LE LL 37 2029\302\265s 0 ADV_NONCONN_IND 3557 6.472 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3558 6.472 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3559 6.473 c1:c8:16:ae:fd:1d LE 1M LE LL 36 580\302\265s 0 ADV_IND 3560 6.474 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3561 6.474 c1:c8:16:ae:fd:1d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3562 6.474 c1:c8:16:ae:fd:1d LE 1M LE LL 36 136\302\265s 0 ADV_IND 3563 6.475 3f:d4:35:96:2a:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3564 6.476 c1:c8:16:ae:fd:1d LE 1M LE LL 6 882\302\265s 0 SCAN_RSP 3565 6.477 3a:d1:ca:1d:4d:de LE 1M LE LL 26 940\302\265s 0 ADV_NONCONN_IND 3566 6.478 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3567 6.478 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3568 6.479 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 147\302\265s 0 ADV_NONCONN_IND 3569 6.479 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3570 6.48 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3571 6.482 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1623\302\265s 0 ADV_NONCONN_IND 3572 6.483 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3573 6.483 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3574 6.486 d2:52:6a:67:61:fd LE 1M LE LL 21 2956\302\265s 0 ADV_IND 3575 6.487 72:10:b2:16:c9:46 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3576 6.487 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3577 6.488 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3578 6.488 6c:c6:23:80:30:28 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3579 6.489 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 3580 6.49 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3581 6.49 7f:ab:0f:33:5d:32 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3582 6.49 d2:52:6a:67:61:fd LE 1M LE LL 19 149\302\265s 0 SCAN_RSP 3583 6.491 72:10:b2:16:c9:46 LE 1M LE LL 12 806\302\265s 0 SCAN_REQ 3584 6.493 6e:c6:2b:80:30:28 LE 1M LE LL 12 1268\302\265s 0 SCAN_REQ 3585 6.493 61:9c:87:78:87:2b LE 1M LE LL 23 303\302\265s 0 ADV_IND 3586 6.494 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3587 6.494 61:9c:87:78:87:2b LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3588 6.505 07:69:22:f0:72:30 LE 1M LE LL 37 10580\302\265s 0 ADV_NONCONN_IND 3589 6.505 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3590 6.506 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3591 6.508 43:bd:56:bd:74:f9 LE 1M LE LL 37 2052\302\265s 0 ADV_NONCONN_IND 3592 6.509 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3593 6.51 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3594 6.512 32:43:3c:28:8d:92 LE 1M LE LL 37 1754\302\265s 0 ADV_NONCONN_IND 3595 6.513 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3596 6.513 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3597 6.514 72:10:b2:16:c9:46 LE 1M LE LL 12 274\302\265s 0 SCAN_REQ 3598 6.514 ef:6e:3d:68:42:19 LE 1M LE LL 36 414\302\265s 0 ADV_IND 3599 6.515 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3600 6.515 ef:6e:3d:68:42:19 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3601 6.516 ef:6e:3d:68:42:19 LE 1M LE LL 36 137\302\265s 0 ADV_IND 3602 6.523 e5:ea:46:16:3e:1e LE 1M LE LL 36 7597\302\265s 0 ADV_IND 3603 6.525 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3604 6.525 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 3605 6.526 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3606 6.528 11:fe:ef:ed:38:82 LE 1M LE LL 37 2321\302\265s 0 ADV_NONCONN_IND 3607 6.529 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3608 6.529 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3609 6.532 e7:70:80:c3:ad:91 LE 1M LE LL 36 2514\302\265s 0 ADV_IND 3610 6.534 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3611 6.534 e7:70:80:c3:ad:91 LE 1M LE LL 36 415\302\265s 0 ADV_IND 3612 6.535 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3613 6.535 e7:70:80:c3:ad:91 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3614 6.54 1e:28:49:84:c5:cd LE 1M LE LL 37 4664\302\265s 0 ADV_NONCONN_IND 3615 6.54 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3616 6.541 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3617 6.553 f1:ff:a7:1a:55:8d LE 1M LE LL 36 11630\302\265s 0 ADV_IND 3618 6.554 6c:c6:23:80:30:28 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 3619 6.555 f1:ff:a7:1a:55:8d LE 1M LE LL 36 414\302\265s 0 ADV_IND 3620 6.574 d6:bf:76:0a:0b:dc LE 1M LE LL 37 18905\302\265s 0 ADV_IND[Malformed Packet] 3621 6.575 d6:bf:76:0a:0b:dc LE 1M LE LL 36 345\302\265s 0 ADV_IND 3622 6.576 0c:6e:66:d7:ed:03 LE 1M LE LL 37 433\302\265s 0 ADV_NONCONN_IND 3623 6.577 5c:9e:d4:03:82:5b LE 1M LE LL 37 795\302\265s 0 ADV_NONCONN_IND 3624 6.577 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3625 6.579 31:ea:1b:25:0d:1f LE 1M LE LL 37 1399\302\265s 0 ADV_NONCONN_IND 3626 6.587 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7491\302\265s 0 ADV_NONCONN_IND 3627 6.588 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3628 6.588 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3629 6.606 27:f1:d5:6a:d5:82 LE 1M LE LL 37 17906\302\265s 0 ADV_NONCONN_IND 3630 6.607 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3631 6.608 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3632 6.609 2b:5e:0e:c8:62:4c LE 1M LE LL 35 750\302\265s 0 ADV_NONCONN_IND 3633 6.61 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3634 6.61 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3635 6.612 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1331\302\265s 0 ADV_NONCONN_IND 3636 6.612 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3637 6.613 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3638 6.617 cc:15:14:59:64:aa LE 1M LE LL 36 3189\302\265s 0 ADV_IND 3639 6.619 32:43:3c:28:8d:92 LE 1M LE LL 37 1898\302\265s 0 ADV_NONCONN_IND 3640 6.619 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3641 6.629 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 8826\302\265s 0 ADV_IND 3642 6.635 11:fe:ef:ed:38:82 LE 1M LE LL 37 6241\302\265s 0 ADV_NONCONN_IND 3643 6.636 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3644 6.643 d2:52:6a:67:61:fd LE 1M LE LL 21 7119\302\265s 0 ADV_IND 3645 6.645 d2:52:6a:67:61:fd LE 1M LE LL 21 1336\302\265s 0 ADV_IND 3646 6.645 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3647 6.645 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3648 6.646 d2:52:6a:67:61:fd LE 1M LE LL 21 628\302\265s 0 ADV_IND 3649 6.647 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3650 6.647 d2:52:6a:67:61:fd LE 1M LE LL 19 150\302\265s 0 SCAN_RSP 3651 6.653 d6:11:ee:37:97:da LE 1M LE LL 36 5836\302\265s 0 ADV_IND 3652 6.654 d6:11:ee:07:97:9a LE 1M LE LL 36 353\302\265s 0 ADV_IND 3653 6.655 64:0d:49:f9:4d:a4 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 3654 6.664 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 8404\302\265s 0 ADV_IND 3655 6.665 c6:1d:56:57:f1:d0 LE 1M LE LL 68 452\302\265s 0 ADV_IND[Malformed Packet] 3656 6.668 cd:5c:f3:7d:98:0b LE 1M LE LL 36 3018\302\265s 0 ADV_IND 3657 6.669 cd:5c:f3:7d:98:0b LE 1M LE LL 36 741\302\265s 0 ADV_IND 3658 6.67 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3659 6.67 cd:5c:f3:7d:98:0b LE 1M LE LL 6 152\302\265s 0 SCAN_RSP 3660 6.672 7d:30:e4:59:cd:06 LE 1M LE LL 25 2219\302\265s 0 ADV_IND 3661 6.674 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 3662 6.675 64:0d:49:f9:4d:a4 LE 1M LE LL 12 840\302\265s 0 SCAN_REQ 3663 6.68 31:ea:1b:25:0d:1f LE 1M LE LL 37 5775\302\265s 0 ADV_NONCONN_IND 3664 6.681 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3665 6.682 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3666 6.69 e5:ea:46:16:3e:1e LE 1M LE LL 36 7727\302\265s 0 ADV_IND 3667 6.691 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3668 6.692 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 3669 6.696 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3814\302\265s 0 ADV_NONCONN_IND 3670 6.696 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3671 6.697 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3672 6.7 40:f0:08:9b:56:91 LE 1M LE LL 37 2567\302\265s 0 ADV_SCAN_IND 3673 6.706 fa:1f:24:e3:99:5d LE 1M LE LL 14 6293\302\265s 0 ADV_NONCONN_IND 3674 6.709 07:69:22:f0:72:30 LE 1M LE LL 37 2332\302\265s 0 ADV_NONCONN_IND 3675 6.71 27:f1:d5:6a:d5:82 LE 1M LE LL 37 766\302\265s 0 ADV_NONCONN_IND 3676 6.711 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3677 6.712 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3678 6.715 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2376\302\265s 0 ADV_NONCONN_IND 3679 6.715 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3680 6.716 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3681 6.717 43:bd:56:bd:74:f9 LE 1M LE LL 37 1008\302\265s 0 ADV_NONCONN_IND 3682 6.718 25:5f:bf:53:1f:d7 LE 1M LE LL 37 706\302\265s 0 ADV_NONCONN_IND 3683 6.719 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3684 6.725 f5:ce:00:2f:bb:4c LE 1M LE LL 33 6019\302\265s 0 ADV_IND 3685 6.726 f5:ce:00:2f:bb:4c LE 1M LE LL 33 498\302\265s 0 ADV_IND 3686 6.727 f5:ce:00:2f:bb:4c LE 1M LE LL 33 498\302\265s 0 ADV_IND 3687 6.727 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3688 6.728 f5:ce:00:2f:bb:4c LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3689 6.743 11:fe:ef:ed:38:82 LE 1M LE LL 37 15641\302\265s 0 ADV_NONCONN_IND 3690 6.744 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3691 6.744 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3692 6.747 1e:28:49:84:c5:cd LE 1M LE LL 37 2477\302\265s 0 ADV_NONCONN_IND 3693 6.748 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3694 6.748 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3695 6.753 0d:62:2c:2a:24:88 LE 1M LE LL 37 4282\302\265s 0 ADV_NONCONN_IND 3696 6.754 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3697 6.754 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3698 6.765 d7:bf:03:c5:20:42 LE 1M LE LL 36 10250\302\265s 0 ADV_IND 3699 6.766 d6:bf:23:c5:20:42 LE 1M LE LL 36 353\302\265s 0 ADV_IND[Malformed Packet] 3700 6.767 d6:bf:03:c5:20:42 LE 1M LE LL 36 742\302\265s 0 ADV_IND 3701 6.767 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3702 6.767 d6:bf:03:c5:20:42 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3703 6.777 c4:23:b5:60:6c:09 LE 1M LE LL 14 9691\302\265s 0 ADV_NONCONN_IND 3704 6.781 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3775\302\265s 0 SCAN_REQ 3705 6.785 SamsungE_07:d5:79 LE 1M LE LL 34 3372\302\265s 0 ADV_NONCONN_IND 3706 6.786 79:70:d9:25:16:e2 LE 1M LE LL 25 619\302\265s 0 ADV_IND 3707 6.786 SamsungE_07:d8:8f LE 1M LE LL 34 251\302\265s 0 ADV_NONCONN_IND 3708 6.787 6c:c6:23:80:30:28 LE 1M LE LL 12 195\302\265s 0 SCAN_REQ 3709 6.787 79:70:d9:25:16:e2 LE 1M LE LL 25 410\302\265s 0 ADV_IND 3710 6.788 SamsungE_07:d8:8f LE 1M LE LL 34 462\302\265s 0 ADV_NONCONN_IND 3711 6.79 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 1370\302\265s 0 ADV_IND 3712 6.791 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 3713 6.792 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3714 6.792 0c:6e:66:d7:ed:03 LE 1M LE LL 37 297\302\265s 0 ADV_NONCONN_IND 3715 6.794 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1087\302\265s 0 ADV_NONCONN_IND 3716 6.794 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3717 6.795 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3718 6.801 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5366\302\265s 0 ADV_NONCONN_IND 3719 6.801 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3720 6.802 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3721 6.804 c5:67:68:79:19:88 LE 1M LE LL 36 2155\302\265s 0 ADV_IND 3722 6.808 c1:c8:16:ae:fd:1d LE 1M LE LL 36 2940\302\265s 0 ADV_IND 3723 6.808 6c:e7:23:80:20:28 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3724 6.809 c1:c8:16:ae:fd:1d LE 1M LE LL 36 416\302\265s 0 ADV_IND 3725 6.817 07:69:22:f0:72:30 LE 1M LE LL 37 7441\302\265s 0 ADV_NONCONN_IND 3726 6.817 07:69:22:f0:72:30 LE 1M LE LL 37 186\302\265s 0 ADV_NONCONN_IND 3727 6.818 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3728 6.82 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1952\302\265s 0 ADV_NONCONN_IND 3729 6.821 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3730 6.821 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3731 6.828 43:bd:56:bd:74:f9 LE 1M LE LL 37 6746\302\265s 0 ADV_NONCONN_IND 3732 6.829 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3733 6.83 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3734 6.831 32:43:3c:28:8d:92 LE 1M LE LL 37 489\302\265s 0 ADV_NONCONN_IND 3735 6.831 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3736 6.832 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3737 6.834 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1373\302\265s 0 ADV_IND 3738 6.837 c0:41:04:2a:be:9d LE 1M LE LL 36 2643\302\265s 0 ADV_IND 3739 6.842 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 5148\302\265s 0 ADV_NONCONN_IND 3740 6.848 11:fe:ef:ed:38:82 LE 1M LE LL 37 5242\302\265s 0 ADV_NONCONN_IND 3741 6.848 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3742 6.849 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3743 6.852 ef:6e:3d:68:42:19 LE 1M LE LL 36 2806\302\265s 0 ADV_IND 3744 6.853 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 3745 6.853 ef:6e:3d:68:42:19 LE 1M LE LL 36 354\302\265s 0 ADV_IND 3746 6.862 0d:62:2c:2a:24:88 LE 1M LE LL 37 8629\302\265s 0 ADV_NONCONN_IND 3747 6.863 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3748 6.863 1c:14:09:ce:06:1b LE 1M LE LL 32 117\302\265s 0 ADV_IND[Malformed Packet] 3749 6.865 71:c4:79:42:57:d8 LE 1M LE LL 21 1567\302\265s 0 SCAN_RSP 3750 6.866 6c:c5:23:80:20:28 LE 1M LE LL 12 766\302\265s 0 SCAN_REQ 3751 6.867 cf:4f:81:f5:7d:55 LE 1M LE LL 36 688\302\265s 0 ADV_IND 3752 6.887 31:ea:1b:25:0d:1f LE 1M LE LL 37 19111\302\265s 0 ADV_NONCONN_IND 3753 6.887 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3754 6.888 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3755 6.89 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2153\302\265s 0 ADV_IND 3756 6.892 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1026\302\265s 0 ADV_NONCONN_IND 3757 6.892 8c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 3758 6.893 3a:d1:ca:1d:4d:de LE 1M LE LL 26 400\302\265s 0 ADV_NONCONN_IND 3759 6.894 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3760 6.895 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 3761 6.899 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3915\302\265s 0 ADV_NONCONN_IND 3762 6.899 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3763 6.9 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3764 6.904 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 3255\302\265s 0 ADV_IND 3765 6.905 6c:c6:23:80:30:28 LE 1M LE LL 12 790\302\265s 0 SCAN_REQ 3766 6.909 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3857\302\265s 0 ADV_NONCONN_IND 3767 6.911 eb:db:35:2e:09:1b LE 1M LE LL 20 2325\302\265s 0 ADV_IND 3768 6.919 c2:f4:e6:80:5e:ae LE 1M LE LL 36 7361\302\265s 0 ADV_IND 3769 6.92 c2:f4:e6:80:5e:ae LE 1M LE LL 36 742\302\265s 0 ADV_IND 3770 6.922 07:69:22:f0:72:30 LE 1M LE LL 37 1103\302\265s 0 ADV_NONCONN_IND 3771 6.922 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 3772 6.923 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3773 6.924 27:f1:d5:6a:d5:82 LE 1M LE LL 37 758\302\265s 0 ADV_NONCONN_IND 3774 6.925 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3775 6.926 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3776 6.927 43:bd:56:bd:74:f9 LE 1M LE LL 37 1139\302\265s 0 ADV_NONCONN_IND 3777 6.928 2b:5e:0e:c8:62:4c LE 1M LE LL 35 408\302\265s 0 ADV_NONCONN_IND 3778 6.928 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3779 6.94 32:43:3c:28:8d:92 LE 1M LE LL 37 10848\302\265s 0 ADV_NONCONN_IND 3780 6.94 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3781 6.941 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3782 6.944 7d:30:e4:59:cd:06 LE 1M LE LL 25 2710\302\265s 0 ADV_IND 3783 6.945 6c:c6:23:80:30:28 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 3784 6.954 cc:14:14:59:64:aa LE 1M LE LL 36 9368\302\265s 0 ADV_IND 3785 6.957 1e:28:49:84:c5:cd LE 1M LE LL 37 1919\302\265s 0 ADV_NONCONN_IND 3786 6.957 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3787 6.958 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3788 6.967 50:d3:b9:81:11:84 LE 1M LE LL 12 8584\302\265s 0 SCAN_REQ 3789 6.97 0d:62:2c:2a:24:88 LE 1M LE LL 37 2959\302\265s 0 ADV_NONCONN_IND 3790 6.97 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3791 6.981 d5:80:ce:3a:df:84 LE 1M LE LL 36 10032\302\265s 0 ADV_IND 3792 6.981 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3793 6.982 d5:80:ce:3a:df:84 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3794 6.982 d5:80:ce:3a:df:84 LE 1M LE LL 36 135\302\265s 0 ADV_IND 3795 6.982 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3796 6.992 d6:11:ee:07:97:9a LE 1M LE LL 36 8959\302\265s 0 ADV_IND 3797 6.995 31:ea:1b:25:0d:1f LE 1M LE LL 37 3533\302\265s 0 ADV_NONCONN_IND 3798 6.996 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3799 6.997 31:ea:1b:25:0d:1f LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3800 6.999 5c:9e:d4:03:82:5b LE 1M LE LL 37 2225\302\265s 0 ADV_NONCONN_IND 3801 7 5c:9e:d4:03:82:5b LE 1M LE LL 37 252\302\265s 0 ADV_NONCONN_IND 3802 7 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 3803 7.001 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 320\302\265s 0 ADV_IND 3804 7.002 50:d3:b9:81:11:84 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3805 7.002 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3806 7.003 6c:c6:23:80:30:28 LE 1M LE LL 12 654\302\265s 0 SCAN_REQ 3807 7.003 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3808 7.005 50:d3:b9:81:11:84 LE 1M LE LL 12 1242\302\265s 0 SCAN_REQ 3809 7.006 6c:c6:23:80:30:28 LE 1M LE LL 12 933\302\265s 0 SCAN_REQ 3810 7.007 d6:11:16:57:f1:d0 LE 1M LE LL 36 416\302\265s 0 ADV_DIRECT_IND 3811 7.009 15:33:e7:97:6f:a1 LE 1M LE LL 10 2315\302\265s 0 ADV_SCAN_IND[Malformed Packet] 3812 7.01 24:c3:d0:ce:d4:37 LE 1M LE LL 37 495\302\265s 0 ADV_NONCONN_IND 3813 7.011 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3814 7.018 e5:ea:46:16:3e:1e LE 1M LE LL 36 7457\302\265s 0 ADV_IND 3815 7.019 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3816 7.019 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3817 7.02 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 3818 7.02 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3819 7.025 d6:2c:05:d0:15:49 LE 1M LE LL 37 4399\302\265s 0 ADV_IND[Malformed Packet] 3820 7.025 27:f1:d5:6a:d5:82 LE 1M LE LL 37 112\302\265s 0 ADV_NONCONN_IND 3821 7.026 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 3822 7.027 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 3823 7.028 16:ed:93:0f:fa:b0 LE 1M LE LL 37 514\302\265s 0 ADV_NONCONN_IND 3824 7.028 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3825 7.029 43:bd:56:bd:74:f9 LE 1M LE LL 37 98\302\265s 0 ADV_NONCONN_IND 3826 7.03 25:5f:bf:53:1f:d7 LE 1M LE LL 37 986\302\265s 0 ADV_NONCONN_IND 3827 7.031 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3828 7.031 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3829 7.037 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5117\302\265s 0 ADV_NONCONN_IND 3830 7.037 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 3831 7.038 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3832 7.041 32:43:3c:28:8d:92 LE 1M LE LL 37 3349\302\265s 0 ADV_NONCONN_IND 3833 7.042 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3834 7.043 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3835 7.049 7f:ab:0f:33:5d:32 LE 1M LE LL 12 6491\302\265s 0 SCAN_REQ 3836 7.054 6c:c6:23:80:30:28 LE 1M LE LL 12 4063\302\265s 0 SCAN_REQ 3837 7.054 4e:14:1a:db:9e:19 LE 1M LE LL 12 549\302\265s 0 ADV_IND 3838 7.056 50:d3:b9:81:11:84 LE 1M LE LL 12 1599\302\265s 0 SCAN_REQ 3839 7.058 11:fe:ef:ed:38:82 LE 1M LE LL 37 1926\302\265s 0 ADV_NONCONN_IND 3840 7.059 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3841 7.06 79:70:d9:25:16:e2 LE 1M LE LL 25 403\302\265s 0 ADV_IND 3842 7.06 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3843 7.069 40:f0:08:9b:56:91 LE 1M LE LL 37 9147\302\265s 0 ADV_SCAN_IND 3844 7.07 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3845 7.074 45:9b:f4:8b:97:b9 LE 1M LE LL 24 3623\302\265s 0 ADV_IND[Malformed Packet] 3846 7.076 0d:62:2c:2a:24:88 LE 1M LE LL 37 2253\302\265s 0 ADV_NONCONN_IND 3847 7.077 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3848 7.077 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3849 7.081 7f:ab:0f:33:5d:32 LE 1M LE LL 12 3275\302\265s 0 SCAN_REQ 3850 7.082 71:c9:89:02:1c:fb LE 1M LE LL 12 932\302\265s 0 SCAN_REQ 3851 7.093 SamsungE_07:d8:8f LE 1M LE LL 34 10940\302\265s 0 ADV_NONCONN_IND 3852 7.098 0b:f9:be:c7:0f:fb LE 1M LE LL 23 4099\302\265s 0 ADV_NONCONN_IND 3853 7.098 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3854 7.098 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 3855 7.101 31:ea:1b:25:0d:1f LE 1M LE LL 37 1808\302\265s 0 ADV_NONCONN_IND 3856 7.102 77:4b:0a:1d:4d:de LE 1M LE LL 26 808\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 3857 7.102 0c:6e:66:d7:ed:03 LE 1M LE LL 37 435\302\265s 0 ADV_NONCONN_IND 3858 7.106 05:cc:17:f5:20:42 LE 1M LE LL 36 3258\302\265s 0 ADV_IND[Malformed Packet] 3859 7.107 d6:bf:03:c5:20:42 LE 1M LE LL 36 353\302\265s 0 ADV_IND 3860 7.107 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3861 7.108 d6:bf:03:c5:20:42 LE 1M LE LL 36 416\302\265s 0 ADV_IND 3862 7.116 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7486\302\265s 0 ADV_NONCONN_IND 3863 7.116 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3864 7.117 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3865 7.125 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 7688\302\265s 0 ADV_IND 3866 7.125 10:d3:b1:61:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3867 7.126 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 164\302\265s 0 ADV_IND 3868 7.134 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7545\302\265s 0 ADV_NONCONN_IND 3869 7.135 LE 1M LE LL 41 468\302\265s 0 Unknown 3870 7.136 43:bd:56:bd:74:f9 LE 1M LE LL 37 715\302\265s 0 ADV_NONCONN_IND 3871 7.136 07:69:22:f0:72:30 LE 1M LE LL 37 466\302\265s 0 ADV_NONCONN_IND 3872 7.139 c5:65:68:79:19:c8 LE 1M LE LL 36 2488\302\265s 0 ADV_IND 3873 7.14 50:d3:bd:a1:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3874 7.14 c5:65:68:79:19:c8 LE 1M LE LL 100 163\302\265s 0 ADV_IND[Malformed Packet] 3875 7.141 c5:65:68:79:19:c8 LE 1M LE LL 36 229\302\265s 0 ADV_IND 3876 7.145 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3733\302\265s 0 ADV_NONCONN_IND 3877 7.146 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3878 7.146 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3879 7.147 ed:4e:4a:f5:08:6e LE 1M LE LL 14 311\302\265s 0 ADV_NONCONN_IND 3880 7.147 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 3881 7.148 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 3882 7.15 32:43:3c:28:8d:92 LE 1M LE LL 37 1575\302\265s 0 ADV_NONCONN_IND 3883 7.15 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3884 7.151 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3885 7.152 7f:ab:0f:33:5d:32 LE 1M LE LL 12 579\302\265s 0 SCAN_REQ 3886 7.161 11:fe:ef:ed:38:82 LE 1M LE LL 37 9578\302\265s 0 ADV_NONCONN_IND 3887 7.162 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3888 7.167 1e:28:49:84:c5:cd LE 1M LE LL 37 4980\302\265s 0 ADV_NONCONN_IND 3889 7.168 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3890 7.168 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3891 7.169 6c:c6:23:80:30:28 LE 1M LE LL 12 388\302\265s 0 SCAN_REQ 3892 7.17 42:f4:8b:c3:ec:00 LE 1M LE LL 36 414\302\265s 0 ADV_IND[Malformed Packet] 3893 7.17 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 355\302\265s 0 ADV_IND 3894 7.174 c0:41:04:2e:be:9d LE 1M LE LL 36 2653\302\265s 0 ADV_IND 3895 7.174 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3896 7.174 c0:41:04:2e:be:9d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3897 7.18 e5:ea:46:16:3e:1e LE 1M LE LL 36 5895\302\265s 0 ADV_IND 3898 7.187 0d:62:2c:2a:24:88 LE 1M LE LL 37 5953\302\265s 0 ADV_NONCONN_IND 3899 7.193 ef:6e:3d:68:42:19 LE 1M LE LL 36 6126\302\265s 0 ADV_IND 3900 7.201 e7:70:80:c3:ad:91 LE 1M LE LL 36 7353\302\265s 0 ADV_IND 3901 7.203 5c:9e:d4:03:82:5b LE 1M LE LL 37 1687\302\265s 0 ADV_NONCONN_IND 3902 7.206 31:ea:1b:25:0d:1f LE 1M LE LL 37 2155\302\265s 0 ADV_NONCONN_IND 3903 7.206 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3904 7.207 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3905 7.207 cf:4f:81:f5:7d:55 LE 1M LE LL 36 75\302\265s 0 ADV_IND 3906 7.211 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3725\302\265s 0 ADV_NONCONN_IND 3907 7.212 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 3908 7.214 7d:a1:e7:e3:cf:fe LE 1M LE LL 198 1668\302\265s 0 ADV_IND[Malformed Packet] 3909 7.22 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4542\302\265s 0 ADV_NONCONN_IND 3910 7.221 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3911 7.222 6c:c6:23:80:30:28 LE 1M LE LL 12 1517\302\265s 0 SCAN_REQ 3912 7.225 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2184\302\265s 0 ADV_IND 3913 7.231 c8:de:06:91:ba:b3 LE 1M LE LL 36 6196\302\265s 0 ADV_IND 3914 7.237 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5272\302\265s 0 ADV_NONCONN_IND 3915 7.238 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3916 7.238 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3917 7.241 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2150\302\265s 0 ADV_NONCONN_IND 3918 7.241 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3919 7.242 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3920 7.243 6c:c6:23:80:30:28 LE 1M LE LL 12 853\302\265s 0 SCAN_REQ 3921 7.255 40:f0:08:9b:56:91 LE 1M LE LL 37 11957\302\265s 0 ADV_SCAN_IND 3922 7.256 2b:5e:0e:c8:62:4c LE 1M LE LL 35 329\302\265s 0 ADV_NONCONN_IND 3923 7.257 32:43:3c:28:8d:92 LE 1M LE LL 37 851\302\265s 0 ADV_NONCONN_IND 3924 7.258 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3925 7.258 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3926 7.267 1e:28:49:84:c5:cd LE 1M LE LL 37 8742\302\265s 0 ADV_NONCONN_IND 3927 7.268 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3928 7.268 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3929 7.27 11:fe:ef:ed:38:82 LE 1M LE LL 37 1425\302\265s 0 ADV_NONCONN_IND 3930 7.271 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3931 7.271 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3932 7.275 6c:c6:23:80:30:28 LE 1M LE LL 12 3162\302\265s 0 SCAN_REQ 3933 7.29 0d:62:2c:2a:24:88 LE 1M LE LL 37 14855\302\265s 0 ADV_NONCONN_IND 3934 7.29 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3935 7.292 cc:15:14:59:64:aa LE 1M LE LL 36 689\302\265s 0 ADV_IND 3936 7.292 cc:15:14:59:64:aa LE 1M LE LL 36 488\302\265s 0 ADV_IND 3937 7.305 5c:9e:d4:03:82:5b LE 1M LE LL 37 12733\302\265s 0 ADV_NONCONN_IND 3938 7.309 fb:18:78:3b:10:36 LE 1M LE LL 28 2966\302\265s 0 ADV_IND 3939 7.309 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3940 7.311 74:d9:0b:7a:47:5a LE 1M LE LL 23 1833\302\265s 0 ADV_IND 3941 7.314 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2122\302\265s 0 ADV_NONCONN_IND 3942 7.316 d5:80:ce:3a:df:84 LE 1M LE LL 36 1764\302\265s 0 ADV_IND 3943 7.316 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 3944 7.326 24:c3:d0:ce:d4:37 LE 1M LE LL 37 9792\302\265s 0 ADV_NONCONN_IND 3945 7.327 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3946 7.327 64:0d:49:f9:4d:a4 LE 1M LE LL 12 168\302\265s 0 SCAN_REQ 3947 7.336 c2:f4:8b:c3:ec:61 LE 1M LE LL 4 8184\302\265s 0 ADV_IND 3948 7.337 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 997\302\265s 0 ADV_IND 3949 7.338 16:ed:93:0f:fa:b0 LE 1M LE LL 37 454\302\265s 0 ADV_NONCONN_IND 3950 7.338 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3951 7.339 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3952 7.341 07:69:22:f0:72:30 LE 1M LE LL 37 1812\302\265s 0 ADV_NONCONN_IND 3953 7.342 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3954 7.342 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 3955 7.343 25:5f:bf:53:1f:d7 LE 1M LE LL 37 706\302\265s 0 ADV_NONCONN_IND 3956 7.344 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3957 7.344 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3958 7.346 e5:ea:46:16:3e:1e LE 1M LE LL 36 1208\302\265s 0 ADV_IND 3959 7.346 64:0d:49:f9:4d:a4 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 3960 7.347 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 3961 7.347 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 3962 7.348 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3963 7.348 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 3964 7.348 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 3965 7.358 2b:5e:0e:c8:62:4c LE 1M LE LL 35 9448\302\265s 0 ADV_NONCONN_IND 3966 7.358 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3967 7.359 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 3968 7.364 32:43:3c:28:8d:92 LE 1M LE LL 37 4601\302\265s 0 ADV_NONCONN_IND 3969 7.365 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3970 7.365 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3971 7.373 11:fe:ef:ed:38:82 LE 1M LE LL 37 7276\302\265s 0 ADV_NONCONN_IND 3972 7.373 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3973 7.374 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3974 7.378 6c:c6:23:80:30:28 LE 1M LE LL 12 4207\302\265s 0 SCAN_REQ 3975 7.394 0d:62:2c:2a:24:88 LE 1M LE LL 37 15689\302\265s 0 ADV_NONCONN_IND 3976 7.395 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3977 7.406 SamsungE_07:d8:8f LE 1M LE LL 34 11098\302\265s 0 ADV_NONCONN_IND 3978 7.411 5c:9e:d4:03:82:5b LE 1M LE LL 37 4448\302\265s 0 ADV_NONCONN_IND 3979 7.412 5c:9e:f4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 3980 7.413 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1086\302\265s 0 ADV_NONCONN_IND 3981 7.414 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 3982 7.422 0c:6e:66:d7:ed:03 LE 1M LE LL 37 8188\302\265s 0 ADV_NONCONN_IND 3983 7.423 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 480\302\265s 0 ADV_NONCONN_IND 3984 7.424 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 3985 7.424 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 3986 7.429 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4103\302\265s 0 ADV_NONCONN_IND 3987 7.429 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3988 7.43 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 3989 7.444 16:ed:93:0f:fa:b0 LE 1M LE LL 37 13585\302\265s 0 ADV_NONCONN_IND 3990 7.444 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3991 7.445 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 3992 7.446 d6:bf:03:c5:20:42 LE 1M LE LL 36 619\302\265s 0 ADV_IND 3993 7.447 d6:bf:03:c5:20:42 LE 1M LE LL 36 353\302\265s 0 ADV_IND 3994 7.447 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 3995 7.451 07:69:22:f0:72:30 LE 1M LE LL 37 4034\302\265s 0 ADV_NONCONN_IND 3996 7.455 5e:93:36:dd:d3:09 LE 1M LE LL 10 2763\302\265s 0 ADV_SCAN_IND 3997 7.458 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 3333\302\265s 0 ADV_IND 3998 7.459 7f:e1:7b:e4:24:1c LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 3999 7.466 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6510\302\265s 0 ADV_NONCONN_IND 4000 7.467 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4001 7.467 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4002 7.473 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 5231\302\265s 0 ADV_NONCONN_IND 4003 7.473 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4004 7.473 0e:dc:ae:5f:e2:00 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4005 7.477 c5:65:68:79:19:c8 LE 1M LE LL 36 3053\302\265s 0 ADV_IND 4006 7.478 11:fe:ef:ed:38:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4007 7.478 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4008 7.481 1e:28:49:84:c5:cd LE 1M LE LL 37 2480\302\265s 0 ADV_NONCONN_IND 4009 7.482 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4010 7.482 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4011 7.49 7d:30:e4:59:cd:06 LE 1M LE LL 25 7608\302\265s 0 ADV_IND 4012 7.491 49:08:83:d3:3a:6c LE 1M LE LL 12 799\302\265s 0 SCAN_REQ 4013 7.492 7f:30:e4:59:cd:06 LE 1M LE LL 25 410\302\265s 0 ADV_IND 4014 7.496 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4031\302\265s 0 ADV_IND 4015 7.497 49:08:83:d3:3a:6c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 4016 7.498 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 4017 7.503 74:d9:0b:7a:47:5a LE 1M LE LL 23 4860\302\265s 0 ADV_IND 4018 7.513 e5:ea:46:16:3e:1e LE 1M LE LL 36 9383\302\265s 0 ADV_IND 4019 7.514 7f:e1:7b:e4:24:1c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 4020 7.517 31:ea:1b:25:0d:1f LE 1M LE LL 37 2510\302\265s 0 ADV_NONCONN_IND 4021 7.524 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6804\302\265s 0 ADV_NONCONN_IND 4022 7.525 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4023 7.526 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1426\302\265s 0 ADV_NONCONN_IND 4024 7.527 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 4025 7.528 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4026 7.529 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1403\302\265s 0 ADV_NONCONN_IND 4027 7.53 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4028 7.531 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4029 7.534 ea:ce:0d:a8:42:19 LE 1M LE LL 36 3482\302\265s 0 ADV_IND[Malformed Packet] 4030 7.535 24:c3:d0:ce:d4:37 LE 1M LE LL 37 278\302\265s 0 ADV_NONCONN_IND 4031 7.536 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4032 7.537 e7:70:80:c3:ad:91 LE 1M LE LL 36 1324\302\265s 0 ADV_IND 4033 7.547 cf:4f:81:f5:7d:55 LE 1M LE LL 36 8863\302\265s 0 ADV_IND 4034 7.551 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4396\302\265s 0 ADV_NONCONN_IND 4035 7.553 43:bd:56:bd:74:f9 LE 1M LE LL 37 1606\302\265s 0 ADV_NONCONN_IND 4036 7.554 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4037 7.555 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4038 7.557 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1298\302\265s 0 ADV_IND 4039 7.559 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1769\302\265s 0 ADV_NONCONN_IND 4040 7.559 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4041 7.564 c8:fe:06:99:ba:b3 LE 1M LE LL 36 3970\302\265s 0 SCAN_RSP 4042 7.564 c8:de:06:91:ba:b3 LE 1M LE LL 36 353\302\265s 0 ADV_IND 4043 7.566 SamsungE_07:d8:8f LE 1M LE LL 34 933\302\265s 0 ADV_NONCONN_IND 4044 7.571 32:43:3c:28:8d:92 LE 1M LE LL 37 4811\302\265s 0 ADV_NONCONN_IND 4045 7.571 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4046 7.572 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4047 7.581 1e:28:49:84:c5:cd LE 1M LE LL 37 8736\302\265s 0 ADV_NONCONN_IND 4048 7.582 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4049 7.582 1e:28:49:84:c5:cd LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 4050 7.583 11:fe:ef:ed:38:82 LE 1M LE LL 37 801\302\265s 0 ADV_NONCONN_IND 4051 7.584 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4052 7.584 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4053 7.605 0d:62:2c:2a:24:88 LE 1M LE LL 37 20145\302\265s 0 ADV_NONCONN_IND 4054 7.606 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4055 7.606 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4056 7.613 79:70:d9:25:16:e2 LE 1M LE LL 25 6999\302\265s 0 ADV_IND 4057 7.615 72:10:b2:16:c9:46 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 4058 7.615 79:70:d9:25:16:e2 LE 1M LE LL 25 410\302\265s 0 ADV_IND 4059 7.616 4e:14:1a:db:9e:19 LE 1M LE LL 12 479\302\265s 0 ADV_IND 4060 7.619 5c:9e:d4:03:82:5b LE 1M LE LL 37 3171\302\265s 0 ADV_NONCONN_IND 4061 7.62 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 4062 7.62 5c:9e:d4:03:82:5b LE 1M LE LL 37 252\302\265s 0 ADV_NONCONN_IND 4063 7.623 45:9b:f4:89:97:f9 LE 1M LE LL 24 2403\302\265s 0 ADV_IND 4064 7.628 44:f0:88:9b:56:91 LE 1M LE LL 37 4809\302\265s 0 ADV_SCAN_IND 4065 7.629 cc:15:14:79:64:aa LE 1M LE LL 36 437\302\265s 0 ADV_IND[Malformed Packet] 4066 7.634 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4371\302\265s 0 ADV_NONCONN_IND 4067 7.634 1c:2b:bf:5c:a9:92 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4068 7.635 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4069 7.636 0c:6e:66:d7:ed:03 LE 1M LE LL 37 775\302\265s 0 ADV_NONCONN_IND 4070 7.637 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4071 7.637 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4072 7.644 24:c3:d0:ce:d4:37 LE 1M LE LL 37 6073\302\265s 0 ADV_NONCONN_IND 4073 7.644 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4074 7.645 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4075 7.65 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4764\302\265s 0 ADV_NONCONN_IND 4076 7.651 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4077 7.652 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4078 7.653 1f:84:46:51:98:14 LE 1M LE LL 23 609\302\265s 0 ADV_NONCONN_IND 4079 7.653 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4080 7.654 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4081 7.656 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2617\302\265s 0 ADV_NONCONN_IND 4082 7.657 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4083 7.658 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4084 7.658 d5:80:fe:3a:dc:86 LE 1M LE LL 36 342\302\265s 0 ADV_IND 4085 7.659 d5:80:ce:3a:df:84 LE 1M LE LL 36 353\302\265s 0 ADV_IND 4086 7.66 08:ec:5e:66:cd:0d LE 1M LE LL 23 980\302\265s 0 ADV_NONCONN_IND 4087 7.666 07:69:22:f0:72:30 LE 1M LE LL 37 5383\302\265s 0 ADV_NONCONN_IND 4088 7.667 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 4089 7.667 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4090 7.676 e5:ea:46:16:3e:1e LE 1M LE LL 36 8365\302\265s 0 ADV_IND 4091 7.677 2b:5e:0e:c8:62:4c LE 1M LE LL 35 465\302\265s 0 ADV_NONCONN_IND 4092 7.677 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4093 7.678 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4094 7.68 32:43:3c:28:8d:92 LE 1M LE LL 37 1478\302\265s 0 ADV_NONCONN_IND 4095 7.683 1e:28:49:84:c5:cd LE 1M LE LL 37 2900\302\265s 0 ADV_NONCONN_IND 4096 7.683 fb:0c:91:37:ca:08 LE 1M LE LL 166 116\302\265s 0 ADV_IND[Malformed Packet] 4097 7.686 17:5f:43:7c:0a:89 LE 1M LE LL 23 1699\302\265s 0 ADV_NONCONN_IND 4098 7.688 74:d9:0b:7a:47:5a LE 1M LE LL 23 1324\302\265s 0 ADV_IND 4099 7.706 SamsungE_07:d5:79 LE 1M LE LL 34 17730\302\265s 0 ADV_NONCONN_IND 4100 7.716 SamsungE_07:d8:8f LE 1M LE LL 34 9896\302\265s 0 ADV_NONCONN_IND 4101 7.717 LE 1M LE LL 34 584\302\265s 0 Unknown 4102 7.718 SamsungE_07:d8:8f LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 4103 7.722 5c:9e:d4:03:82:5b LE 1M LE LL 37 3218\302\265s 0 ADV_NONCONN_IND 4104 7.722 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4105 7.723 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 4106 7.727 31:ea:1b:25:0d:1f LE 1M LE LL 37 4021\302\265s 0 ADV_NONCONN_IND 4107 7.731 0b:f9:be:c7:0f:fb LE 1M LE LL 23 2837\302\265s 0 ADV_NONCONN_IND 4108 7.731 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4109 7.734 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3186\302\265s 0 ADV_NONCONN_IND 4110 7.735 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4111 7.736 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4112 7.738 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2056\302\265s 0 ADV_NONCONN_IND 4113 7.739 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4114 7.739 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4115 7.741 0c:6e:66:d7:ed:03 LE 1M LE LL 37 774\302\265s 0 ADV_NONCONN_IND 4116 7.741 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4117 7.742 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4118 7.748 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5449\302\265s 0 ADV_NONCONN_IND 4119 7.748 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4120 7.749 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4121 7.753 2e:86:8d:c8:e7:bd LE 1M LE LL 22 4153\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4122 7.756 69:a9:48:2f:b7:16 LE 1M LE LL 37 2468\302\265s 0 ADV_NONCONN_IND 4123 7.759 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2921\302\265s 0 ADV_NONCONN_IND 4124 7.76 25:5f:bf:53:1f:d7 LE 1M LE LL 37 421\302\265s 0 ADV_NONCONN_IND 4125 7.761 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4126 7.761 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4127 7.763 16:ed:9f:0f:f2:b6 LE 1M LE LL 229 1131\302\265s 0 ADV_SCAN_IND[Malformed Packet] 4128 7.767 07:69:22:f0:72:30 LE 1M LE LL 37 1949\302\265s 0 ADV_NONCONN_IND 4129 7.767 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4130 7.77 43:bd:56:bd:74:f9 LE 1M LE LL 37 2017\302\265s 0 ADV_NONCONN_IND 4131 7.77 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4132 7.771 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4133 7.783 1e:28:49:84:c5:cd LE 1M LE LL 37 11383\302\265s 0 ADV_NONCONN_IND 4134 7.783 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4135 7.784 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4136 7.786 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1629\302\265s 0 ADV_NONCONN_IND 4137 7.787 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4138 7.787 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4139 7.788 32:43:3c:28:8d:92 LE 1M LE LL 37 854\302\265s 0 ADV_NONCONN_IND 4140 7.789 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4141 7.789 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4142 7.795 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 5055\302\265s 0 ADV_IND 4143 7.796 50:d3:b9:81:11:84 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 4144 7.797 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 416\302\265s 0 ADV_IND 4145 7.797 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4146 7.798 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4147 7.808 c1:c8:16:ae:fd:1d LE 1M LE LL 36 10562\302\265s 0 ADV_IND 4148 7.813 c5:65:68:79:19:c8 LE 1M LE LL 36 3944\302\265s 0 ADV_IND 4149 7.813 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4150 7.813 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4151 7.814 c5:65:68:79:19:c8 LE 1M LE LL 36 138\302\265s 0 ADV_IND 4152 7.814 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 4153 7.815 c5:65:68:79:19:c8 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4154 7.816 0d:62:2c:2a:24:88 LE 1M LE LL 37 1593\302\265s 0 ADV_NONCONN_IND 4155 7.817 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4156 7.817 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4157 7.827 dd:b9:3b:45:59:8b LE 1M LE LL 24 9282\302\265s 0 ADV_IND 4158 7.828 50:d3:b9:81:11:84 LE 1M LE LL 12 919\302\265s 0 SCAN_REQ 4159 7.829 dd:b9:3b:45:59:8b LE 1M LE LL 24 707\302\265s 0 ADV_IND 4160 7.829 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 4161 7.841 3a:d1:ca:1d:4d:de LE 1M LE LL 26 11015\302\265s 0 ADV_NONCONN_IND 4162 7.841 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4163 7.842 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4164 7.843 ec:af:39:d1:f5:fe LE 1M LE LL 14 983\302\265s 0 ADV_NONCONN_IND 4165 7.846 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2072\302\265s 0 ADV_NONCONN_IND 4166 7.846 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4167 7.851 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4096\302\265s 0 ADV_NONCONN_IND 4168 7.851 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4169 7.852 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4170 7.864 27:f1:d5:6a:d5:82 LE 1M LE LL 37 11632\302\265s 0 ADV_NONCONN_IND 4171 7.865 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4172 7.866 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4173 7.866 07:69:22:f0:72:30 LE 1M LE LL 37 90\302\265s 0 ADV_NONCONN_IND 4174 7.867 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4175 7.867 07:69:22:f0:72:30 LE 1M LE LL 37 193\302\265s 0 ADV_NONCONN_IND 4176 7.869 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1335\302\265s 0 ADV_NONCONN_IND 4177 7.869 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4178 7.87 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4179 7.873 ef:6e:3d:68:42:19 LE 1M LE LL 36 2787\302\265s 0 ADV_IND 4180 7.874 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 4181 7.875 ef:6e:3d:68:42:19 LE 1M LE LL 36 354\302\265s 0 ADV_IND 4182 7.88 cf:4f:81:f5:7d:55 LE 1M LE LL 36 4638\302\265s 0 ADV_IND 4183 7.88 cf:4f:81:f5:7d:55 LE 1M LE LL 36 353\302\265s 0 ADV_IND 4184 7.888 2b:5e:0e:c8:62:4c LE 1M LE LL 35 7116\302\265s 0 ADV_NONCONN_IND 4185 7.889 79:70:d9:25:16:e2 LE 1M LE LL 25 408\302\265s 0 ADV_IND 4186 7.889 79:70:d9:25:16:e2 LE 1M LE LL 25 368\302\265s 0 ADV_IND 4187 7.891 11:fe:ef:ed:38:82 LE 1M LE LL 37 1883\302\265s 0 ADV_NONCONN_IND 4188 7.893 32:43:3c:28:8d:92 LE 1M LE LL 37 1012\302\265s 0 ADV_NONCONN_IND 4189 7.893 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4190 7.894 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4191 7.896 e5:ea:92:fe:cc:4a LE 1M LE LL 36 1437\302\265s 0 ADV_IND[Malformed Packet] 4192 7.898 c8:de:06:91:ba:b3 LE 1M LE LL 36 2055\302\265s 0 ADV_IND 4193 7.899 75:9b:f4:8b:97:f9 LE 1M LE LL 24 1034\302\265s 0 ADV_IND 4194 7.918 eb:db:35:2e:09:1b LE 1M LE LL 20 18313\302\265s 0 ADV_IND 4195 7.922 0d:62:2c:2a:24:88 LE 1M LE LL 37 3505\302\265s 0 ADV_NONCONN_IND 4196 7.922 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4197 7.928 c6:f1:43:db:57:1d LE 1M LE LL 36 5237\302\265s 0 ADV_IND 4198 7.929 c2:f4:e6:80:4e:ae LE 1M LE LL 6 322\302\265s 0 SCAN_RSP 4199 7.929 c2:f4:e6:80:5e:ae LE 1M LE LL 36 138\302\265s 0 ADV_IND 4200 7.937 31:ea:1b:25:0d:1f LE 1M LE LL 37 7477\302\265s 0 ADV_NONCONN_IND 4201 7.937 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4202 7.938 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4203 7.949 0c:6e:66:d7:ed:03 LE 1M LE LL 37 10413\302\265s 0 ADV_NONCONN_IND 4204 7.949 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4205 7.95 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4206 7.955 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4826\302\265s 0 ADV_NONCONN_IND 4207 7.956 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4208 7.956 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4209 7.961 cc:15:14:59:64:aa LE 1M LE LL 36 4828\302\265s 0 ADV_IND 4210 7.963 64:0d:49:f9:4d:a4 LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 4211 7.963 cc:15:14:59:64:aa LE 1M LE LL 36 414\302\265s 0 ADV_IND 4212 7.966 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2732\302\265s 0 ADV_NONCONN_IND 4213 7.967 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4214 7.968 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4215 7.971 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2929\302\265s 0 ADV_NONCONN_IND 4216 7.972 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4217 7.972 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4218 7.986 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 13275\302\265s 0 ADV_IND 4219 7.987 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 4220 7.988 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 4221 7.993 c2:f4:36:0c:1e:5b LE 1M LE LL 36 4528\302\265s 0 ADV_IND[Malformed Packet] 4222 7.993 1e:28:49:84:c5:cd LE 1M LE LL 37 308\302\265s 0 ADV_NONCONN_IND 4223 7.994 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4224 7.996 11:fe:ef:ed:38:82 LE 1M LE LL 37 1426\302\265s 0 ADV_NONCONN_IND 4225 7.996 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4226 7.997 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4227 7.999 d5:80:ce:3a:df:84 LE 1M LE LL 36 2142\302\265s 0 ADV_IND 4228 8.001 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 4229 8.001 d5:80:ce:3a:df:84 LE 1M LE LL 36 163\302\265s 0 ADV_IND 4230 8.01 e5:ea:46:16:3e:1e LE 1M LE LL 36 8127\302\265s 0 ADV_IND 4231 8.011 64:0d:49:f9:4d:a4 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 4232 8.011 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 4233 8.014 cd:5c:f3:7d:98:0b LE 1M LE LL 36 1780\302\265s 0 ADV_IND 4234 8.016 d6:11:16:57:f1:50 LE 1M LE LL 36 2454\302\265s 0 ADV_IND 4235 8.017 d6:11:16:57:f1:d0 LE 1M LE LL 36 742\302\265s 0 ADV_IND 4236 8.025 SamsungE_07:d8:8f LE 1M LE LL 34 7213\302\265s 0 ADV_NONCONN_IND 4237 8.026 SamsungE_07:d8:8f LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 4238 8.027 SamsungE_07:d8:8f LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 4239 8.029 0d:62:2c:2a:24:88 LE 1M LE LL 37 1473\302\265s 0 ADV_NONCONN_IND 4240 8.029 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4241 8.03 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4242 8.033 d6:2c:05:d0:15:49 LE 1M LE LL 37 2992\302\265s 0 ADV_IND 4243 8.039 31:ea:1b:25:0d:1f LE 1M LE LL 37 5602\302\265s 0 ADV_NONCONN_IND 4244 8.04 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4245 8.042 69:6e:82:e7:ae:df LE 1M LE LL 32 1615\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4246 8.048 3a:d1:ca:1d:4d:de LE 1M LE LL 26 5600\302\265s 0 ADV_NONCONN_IND 4247 8.048 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4248 8.05 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 825\302\265s 0 ADV_NONCONN_IND 4249 8.053 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3126\302\265s 0 ADV_NONCONN_IND 4250 8.054 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4251 8.06 24:c3:d0:ce:d4:37 LE 1M LE LL 37 6076\302\265s 0 ADV_NONCONN_IND 4252 8.061 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4253 8.061 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4254 8.071 74:d9:0b:7a:47:5a LE 1M LE LL 23 9501\302\265s 0 ADV_IND 4255 8.073 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1892\302\265s 0 ADV_NONCONN_IND 4256 8.074 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4257 8.08 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5884\302\265s 0 ADV_NONCONN_IND 4258 8.081 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4259 8.081 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4260 8.083 43:bd:56:bd:74:f9 LE 1M LE LL 37 1716\302\265s 0 ADV_NONCONN_IND 4261 8.084 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4262 8.085 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4263 8.097 2b:5e:0e:c8:62:4c LE 1M LE LL 35 11357\302\265s 0 ADV_NONCONN_IND 4264 8.097 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4265 8.098 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4266 8.099 32:43:3c:28:8d:92 LE 1M LE LL 37 857\302\265s 0 ADV_NONCONN_IND 4267 8.1 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4268 8.1 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4269 8.102 11:fe:ef:ed:38:82 LE 1M LE LL 37 1641\302\265s 0 ADV_NONCONN_IND 4270 8.103 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4271 8.103 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4272 8.104 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 427\302\265s 0 ADV_NONCONN_IND 4273 8.104 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4274 8.105 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4275 8.132 f4:08:ad:3c:61:f6 LE 1M LE LL 14 27041\302\265s 0 ADV_NONCONN_IND 4276 8.132 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 4277 8.133 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 4278 8.134 c3:e7:c0:d3:8a:f0 LE 1M LE LL 45 671\302\265s 0 ADV_IND[Malformed Packet] 4279 8.135 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 670\302\265s 0 ADV_IND 4280 8.137 0d:62:2c:2a:24:88 LE 1M LE LL 37 2259\302\265s 0 ADV_NONCONN_IND 4281 8.143 5c:9e:d4:03:82:5b LE 1M LE LL 37 5263\302\265s 0 ADV_NONCONN_IND 4282 8.145 85:65:68:79:19:c8 LE 1M LE LL 36 1690\302\265s 0 ADV_IND 4283 8.146 c5:65:68:79:19:c8 LE 1M LE LL 36 354\302\265s 0 ADV_IND 4284 8.149 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3285\302\265s 0 ADV_NONCONN_IND 4285 8.15 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4286 8.151 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4287 8.153 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1827\302\265s 0 ADV_NONCONN_IND 4288 8.159 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 6056\302\265s 0 ADV_NONCONN_IND 4289 8.16 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4290 8.166 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5338\302\265s 0 ADV_NONCONN_IND 4291 8.166 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4292 8.167 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4293 8.169 79:70:d9:25:16:e2 LE 1M LE LL 25 1348\302\265s 0 ADV_IND 4294 8.169 79:70:d9:25:16:e2 LE 1M LE LL 6 476\302\265s 0 SCAN_RSP 4295 8.17 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 4296 8.174 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3946\302\265s 0 ADV_NONCONN_IND 4297 8.178 d4:44:a3:07:d8:8f LE 1M LE LL 42 3343\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4298 8.178 SamsungE_05:d8:8d LE 1M LE LL 162 520\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4299 8.182 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1911\302\265s 0 ADV_NONCONN_IND 4300 8.182 c0:41:04:2e:be:9d LE 1M LE LL 36 129\302\265s 0 ADV_IND 4301 8.189 40:f0:08:9b:56:91 LE 1M LE LL 37 6498\302\265s 0 ADV_SCAN_IND 4302 8.19 25:5f:bf:53:1f:d7 LE 1M LE LL 37 500\302\265s 0 ADV_NONCONN_IND 4303 8.191 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4304 8.192 43:bd:56:bd:74:f9 LE 1M LE LL 37 1092\302\265s 0 ADV_NONCONN_IND 4305 8.193 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4306 8.194 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4307 8.199 32:43:3c:28:8d:92 LE 1M LE LL 37 4905\302\265s 0 ADV_NONCONN_IND 4308 8.2 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4309 8.2 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4310 8.201 2b:5e:0e:c8:62:4c LE 1M LE LL 35 593\302\265s 0 ADV_NONCONN_IND 4311 8.202 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4312 8.202 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4313 8.205 1e:28:49:84:c5:cd LE 1M LE LL 37 2948\302\265s 0 ADV_NONCONN_IND 4314 8.206 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4315 8.207 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4316 8.21 CAB_70:80:c3 LE 1M LE LL 36 2853\302\265s 0 AUX_CONNECT_RSP[Malformed Packet: length of contained item exceeds length of containing item] 4317 8.21 e7:70:80:c3:ad:91 LE 1M LE LL 36 352\302\265s 0 ADV_IND 4318 8.229 f1:ff:a7:1a:55:8d LE 1M LE LL 36 18395\302\265s 0 ADV_IND 4319 8.243 31:ea:1b:25:0d:1f LE 1M LE LL 37 13392\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4320 8.244 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4321 8.244 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4322 8.253 c6:f1:43:db:57:1d LE 1M LE LL 36 8393\302\265s 0 ADV_IND 4323 8.258 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4412\302\265s 0 ADV_NONCONN_IND 4324 8.258 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4325 8.262 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3078\302\265s 0 ADV_NONCONN_IND 4326 8.262 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4327 8.263 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4328 8.265 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 1407\302\265s 0 ADV_IND 4329 8.271 24:c3:d0:ce:d4:37 LE 1M LE LL 37 6202\302\265s 0 ADV_NONCONN_IND 4330 8.272 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4331 8.279 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6730\302\265s 0 ADV_NONCONN_IND 4332 8.28 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4333 8.28 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4334 8.285 1f:84:46:51:98:14 LE 1M LE LL 23 4865\302\265s 0 ADV_NONCONN_IND 4335 8.286 1f:84:46:51:98:14 LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 4336 8.286 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4337 8.288 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1222\302\265s 0 ADV_NONCONN_IND 4338 8.288 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4339 8.289 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4340 8.29 07:69:22:f0:72:30 LE 1M LE LL 37 111\302\265s 0 ADV_NONCONN_IND 4341 8.29 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4342 8.291 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4343 8.293 08:ec:5e:66:cd:0d LE 1M LE LL 23 2104\302\265s 0 ADV_NONCONN_IND 4344 8.294 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4345 8.294 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4346 8.295 cc:15:14:59:64:aa LE 1M LE LL 36 725\302\265s 0 ADV_IND 4347 8.298 43:bd:56:bd:74:f9 LE 1M LE LL 37 2361\302\265s 0 ADV_NONCONN_IND 4348 8.299 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4349 8.3 32:43:3c:28:8d:92 LE 1M LE LL 37 538\302\265s 0 ADV_NONCONN_IND 4350 8.3 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4351 8.301 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4352 8.305 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4342\302\265s 0 ADV_NONCONN_IND 4353 8.306 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4354 8.306 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4355 8.308 7d:30:e4:59:cd:06 LE 1M LE LL 25 978\302\265s 0 ADV_IND 4356 8.311 1e:28:49:84:c5:cd LE 1M LE LL 37 2869\302\265s 0 ADV_NONCONN_IND 4357 8.312 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4358 8.312 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 387\302\265s 0 ADV_IND 4359 8.338 da:b3:65:01:97:9a LE 1M LE LL 36 24876\302\265s 0 ADV_IND[Malformed Packet] 4360 8.338 50:0e:22:37:97:9a LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 4361 8.339 e5:ea:46:16:3e:1e LE 1M LE LL 36 859\302\265s 0 ADV_IND 4362 8.346 5c:9e:d4:03:82:5b LE 1M LE LL 37 6255\302\265s 0 ADV_NONCONN_IND 4363 8.347 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4364 8.347 31:ea:1b:25:0d:1f LE 1M LE LL 37 264\302\265s 0 ADV_NONCONN_IND 4365 8.348 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4366 8.348 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4367 8.362 3a:d1:ca:1d:4d:de LE 1M LE LL 26 13055\302\265s 0 ADV_NONCONN_IND 4368 8.363 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4369 8.364 0b:f9:be:c7:0f:fb LE 1M LE LL 23 588\302\265s 0 ADV_NONCONN_IND 4370 8.367 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3595\302\265s 0 ADV_NONCONN_IND 4371 8.368 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4372 8.369 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4373 8.371 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2380\302\265s 0 ADV_NONCONN_IND 4374 8.372 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4375 8.373 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4376 8.378 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5335\302\265s 0 ADV_NONCONN_IND 4377 8.379 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4378 8.379 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4379 8.388 16:ed:93:0f:fa:b0 LE 1M LE LL 37 7982\302\265s 0 ADV_NONCONN_IND 4380 8.388 16:ed:93:0f:fa:b0 LE 1M LE LL 165 181\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4381 8.391 07:69:22:f0:72:30 LE 1M LE LL 37 1189\302\265s 0 ADV_NONCONN_IND 4382 8.393 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1352\302\265s 0 ADV_NONCONN_IND 4383 8.393 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4384 8.394 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4385 8.401 43:bd:56:bd:74:f9 LE 1M LE LL 37 6150\302\265s 0 ADV_NONCONN_IND 4386 8.402 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4387 8.402 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4388 8.405 32:43:3c:28:8d:92 LE 1M LE LL 37 2413\302\265s 0 ADV_NONCONN_IND 4389 8.406 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4390 8.406 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4391 8.41 1e:28:49:84:c5:cd LE 1M LE LL 37 3730\302\265s 0 ADV_NONCONN_IND 4392 8.411 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4393 8.412 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4394 8.413 11:fe:ef:ed:38:82 LE 1M LE LL 37 804\302\265s 0 ADV_NONCONN_IND 4395 8.413 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4396 8.414 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4397 8.415 71:c9:89:02:1c:fb LE 1M LE LL 12 427\302\265s 0 SCAN_REQ 4398 8.43 61:9c:c7:78:87:2b LE 1M LE LL 23 15324\302\265s 0 ADV_IND 4399 8.431 50:d3:b9:81:11:84 LE 1M LE LL 12 928\302\265s 0 SCAN_REQ 4400 8.446 79:70:d9:25:16:e2 LE 1M LE LL 25 14618\302\265s 0 ADV_IND 4401 8.447 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4402 8.447 79:70:d9:25:16:e2 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4403 8.447 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 4404 8.452 50:d3:b9:81:11:84 LE 1M LE LL 12 4526\302\265s 0 SCAN_REQ 4405 8.454 5c:9e:d4:03:82:5b LE 1M LE LL 37 2126\302\265s 0 ADV_NONCONN_IND 4406 8.455 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4407 8.455 45:9b:f4:8b:97:f9 LE 1M LE LL 6 85\302\265s 0 SCAN_RSP 4408 8.464 3a:d1:ca:1d:4d:de LE 1M LE LL 26 8971\302\265s 0 ADV_NONCONN_IND 4409 8.465 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4410 8.466 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4411 8.472 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5836\302\265s 0 ADV_NONCONN_IND 4412 8.473 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4413 8.473 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4414 8.474 0c:6e:66:d7:ed:03 LE 1M LE LL 37 127\302\265s 0 ADV_NONCONN_IND 4415 8.474 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4416 8.475 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4417 8.476 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 816\302\265s 0 ADV_IND 4418 8.477 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4419 8.477 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4420 8.477 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 137\302\265s 0 ADV_IND 4421 8.478 50:d3:b9:81:11:84 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 4422 8.481 c5:65:68:79:19:c8 LE 1M LE LL 36 1954\302\265s 0 ADV_IND 4423 8.481 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 4424 8.482 c4:d3:3f:79:a7:16 LE 1M LE LL 36 705\302\265s 0 ADV_IND 4425 8.483 c1:c8:16:ae:fd:1d LE 1M LE LL 36 525\302\265s 0 ADV_IND 4426 8.484 c1:c8:16:ae:fd:1d LE 1M LE LL 36 355\302\265s 0 ADV_IND[Malformed Packet] 4427 8.488 5e:93:36:dd:d3:09 LE 1M LE LL 10 4402\302\265s 0 ADV_SCAN_IND 4428 8.489 5c:44:a3:07:d8:8f LE 1M LE LL 34 245\302\265s 0 ADV_NONCONN_IND 4429 8.491 07:69:22:f0:72:30 LE 1M LE LL 37 1811\302\265s 0 ADV_NONCONN_IND 4430 8.491 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4431 8.496 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4449\302\265s 0 ADV_NONCONN_IND 4432 8.497 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4433 8.498 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4434 8.502 e5:ea:46:16:3e:1e LE 1M LE LL 36 3614\302\265s 0 ADV_IND 4435 8.502 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 4436 8.503 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4437 8.503 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 4438 8.507 43:bd:56:bd:74:f9 LE 1M LE LL 37 3986\302\265s 0 ADV_NONCONN_IND 4439 8.509 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1004\302\265s 0 ADV_NONCONN_IND 4440 8.509 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4441 8.51 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4442 8.513 32:43:3c:28:8d:92 LE 1M LE LL 37 3036\302\265s 0 ADV_NONCONN_IND 4443 8.514 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4444 8.514 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4445 8.515 1e:28:49:84:c5:cd LE 1M LE LL 37 605\302\265s 0 ADV_NONCONN_IND 4446 8.516 1e:28:49:84:c5:cd LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 4447 8.517 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4448 8.518 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1006\302\265s 0 ADV_NONCONN_IND 4449 8.518 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4450 8.519 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4451 8.523 71:c9:89:02:1c:fb LE 1M LE LL 12 3395\302\265s 0 SCAN_REQ 4452 8.538 7f:f8:8c:bb:a0:a8 LE 1M LE LL 24 15017\302\265s 0 ADV_IND 4453 8.539 d6:2c:05:d0:15:49 LE 1M LE LL 37 845\302\265s 0 ADV_IND 4454 8.545 ef:6e:3d:68:42:19 LE 1M LE LL 36 6043\302\265s 0 ADV_IND 4455 8.546 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 4456 8.558 0d:62:2c:2a:24:88 LE 1M LE LL 37 11878\302\265s 0 ADV_NONCONN_IND 4457 8.559 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4458 8.561 31:ea:1b:25:0d:1f LE 1M LE LL 37 2151\302\265s 0 ADV_NONCONN_IND 4459 8.562 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4460 8.562 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4461 8.567 f1:ff:a7:1a:55:8d LE 1M LE LL 36 3918\302\265s 0 ADV_IND 4462 8.567 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4463 8.575 3a:d1:ca:1d:4d:de LE 1M LE LL 26 7935\302\265s 0 ADV_NONCONN_IND 4464 8.576 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4465 8.579 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3078\302\265s 0 ADV_NONCONN_IND 4466 8.58 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4467 8.581 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4468 8.586 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5455\302\265s 0 ADV_NONCONN_IND 4469 8.587 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4470 8.587 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4471 8.588 71:c9:89:02:1c:fb LE 1M LE LL 12 487\302\265s 0 SCAN_REQ 4472 8.589 7d:30:e4:59:cd:06 LE 1M LE LL 25 411\302\265s 0 ADV_IND 4473 8.59 50:9b:b9:81:11:84 LE 1M LE LL 12 797\302\265s 0 SCAN_REQ 4474 8.597 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6910\302\265s 0 ADV_NONCONN_IND 4475 8.598 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4476 8.601 07:69:22:f0:72:30 LE 1M LE LL 37 2833\302\265s 0 ADV_NONCONN_IND 4477 8.602 c2:f4:e6:80:5e:ae LE 1M LE LL 36 873\302\265s 0 ADV_IND 4478 8.603 c2:f4:e6:80:5e:ae LE 1M LE LL 36 353\302\265s 0 ADV_IND 4479 8.603 27:f1:d5:6a:d5:82 LE 1M LE LL 37 212\302\265s 0 ADV_NONCONN_IND 4480 8.604 64:0d:49:f9:4d:a4 LE 1M LE LL 12 284\302\265s 0 SCAN_REQ 4481 8.613 32:43:3c:28:8d:92 LE 1M LE LL 37 9108\302\265s 0 ADV_NONCONN_IND 4482 8.614 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4483 8.614 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4484 8.616 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1493\302\265s 0 ADV_NONCONN_IND 4485 8.617 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4486 8.617 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4487 8.621 11:ce:ef:ed:38:82 LE 1M LE LL 37 3037\302\265s 0 ADV_NONCONN_IND 4488 8.621 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4489 8.622 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4490 8.624 1e:28:49:84:c5:cd LE 1M LE LL 37 1225\302\265s 0 ADV_NONCONN_IND 4491 8.624 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4492 8.625 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4493 8.628 74:d9:0b:7a:47:5a LE 1M LE LL 23 3051\302\265s 0 ADV_IND 4494 8.633 cc:15:14:59:64:aa LE 1M LE LL 36 4939\302\265s 0 ADV_IND 4495 8.643 SamsungE_07:d8:8f LE 1M LE LL 34 9469\302\265s 0 ADV_NONCONN_IND 4496 8.645 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1291\302\265s 0 ADV_IND 4497 8.663 0d:62:2c:2a:24:88 LE 1M LE LL 37 17912\302\265s 0 ADV_NONCONN_IND 4498 8.664 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4499 8.667 31:ea:1b:25:0d:1f LE 1M LE LL 37 3399\302\265s 0 ADV_NONCONN_IND 4500 8.668 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4501 8.668 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4502 8.672 e5:ea:46:16:3e:1e LE 1M LE LL 36 3080\302\265s 0 ADV_IND 4503 8.676 d5:80:ce:3a:df:84 LE 1M LE LL 36 4023\302\265s 0 ADV_IND 4504 8.678 49:08:83:d3:3a:6c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 4505 8.679 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1665\302\265s 0 ADV_NONCONN_IND 4506 8.68 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4507 8.681 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4508 8.683 cd:5c:f3:7d:98:0b LE 1M LE LL 36 2236\302\265s 0 ADV_IND 4509 8.684 0c:6e:66:d7:ed:03 LE 1M LE LL 37 473\302\265s 0 ADV_NONCONN_IND 4510 8.685 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4511 8.696 24:c3:d0:ce:d4:37 LE 1M LE LL 37 10455\302\265s 0 ADV_NONCONN_IND 4512 8.696 24:c3:d0:ce:d4:37 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4513 8.697 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4514 8.703 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5490\302\265s 0 ADV_NONCONN_IND 4515 8.703 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4516 8.705 07:69:22:f0:72:30 LE 1M LE LL 37 976\302\265s 0 ADV_NONCONN_IND 4517 8.705 27:f1:d5:6a:d5:82 LE 1M LE LL 37 68\302\265s 0 ADV_NONCONN_IND 4518 8.706 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4519 8.707 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4520 8.708 61:9c:87:78:87:2b LE 1M LE LL 23 791\302\265s 0 ADV_IND 4521 8.715 43:bd:56:bd:74:f9 LE 1M LE LL 37 7209\302\265s 0 ADV_NONCONN_IND 4522 8.716 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4523 8.723 11:fe:ef:ed:38:82 LE 1M LE LL 37 6149\302\265s 0 ADV_NONCONN_IND 4524 8.723 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4525 8.724 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4526 8.727 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2463\302\265s 0 ADV_NONCONN_IND 4527 8.727 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4528 8.728 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4529 8.733 1e:28:49:84:c5:cd LE 1M LE LL 37 4822\302\265s 0 ADV_NONCONN_IND 4530 8.733 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4531 8.734 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4532 8.769 0d:62:2c:2a:24:88 LE 1M LE LL 37 34335\302\265s 0 ADV_NONCONN_IND 4533 8.769 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4534 8.77 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4535 8.772 31:ea:1b:25:0d:1f LE 1M LE LL 37 2146\302\265s 0 ADV_NONCONN_IND 4536 8.773 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4537 8.773 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4538 8.781 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6802\302\265s 0 ADV_NONCONN_IND 4539 8.781 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4540 8.782 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 203\302\265s 0 ADV_NONCONN_IND 4541 8.785 5c:9e:d4:03:82:5b LE 1M LE LL 37 3207\302\265s 0 ADV_NONCONN_IND 4542 8.786 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4543 8.787 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4544 8.787 8a:40:5c:67:0b:fd LE 1M LE LL 126 214\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4545 8.799 24:c3:d0:ce:d4:37 LE 1M LE LL 37 10988\302\265s 0 ADV_NONCONN_IND 4546 8.8 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4547 8.803 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2370\302\265s 0 ADV_NONCONN_IND 4548 8.803 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4549 8.804 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4550 8.807 42:f4:8b:c3:ee:01 LE 1M LE LL 36 3063\302\265s 0 ADV_IND 4551 8.808 7f:e1:7b:e4:24:1c LE 1M LE LL 12 729\302\265s 0 SCAN_REQ 4552 8.809 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 169\302\265s 0 ADV_IND 4553 8.813 07:69:22:f0:72:30 LE 1M LE LL 37 3785\302\265s 0 ADV_NONCONN_IND 4554 8.813 07:69:22:f0:72:30 LE 1M LE LL 37 196\302\265s 0 ADV_NONCONN_IND 4555 8.814 49:08:83:d3:3a:6c LE 1M LE LL 12 180\302\265s 0 SCAN_REQ 4556 8.814 74:d9:0b:7a:47:5a LE 1M LE LL 23 187\302\265s 0 ADV_IND[Malformed Packet] 4557 8.815 c1:c8:16:ae:fd:1d LE 1M LE LL 36 623\302\265s 0 ADV_IND 4558 8.816 c1:c8:16:ae:fd:1d LE 1M LE LL 36 354\302\265s 0 ADV_IND 4559 8.817 43:bd:56:bd:74:f9 LE 1M LE LL 37 703\302\265s 0 ADV_NONCONN_IND 4560 8.818 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4561 8.819 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4562 8.82 32:43:3c:28:8d:92 LE 1M LE LL 37 524\302\265s 0 ADV_NONCONN_IND 4563 8.82 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4564 8.821 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4565 8.822 c5:65:68:79:19:c8 LE 1M LE LL 36 732\302\265s 0 ADV_IND 4566 8.825 11:fe:ef:ed:38:82 LE 1M LE LL 37 2972\302\265s 0 ADV_NONCONN_IND 4567 8.826 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4568 8.829 dd:b9:3b:45:59:8b LE 1M LE LL 24 2936\302\265s 0 ADV_IND 4569 8.832 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2586\302\265s 0 ADV_NONCONN_IND 4570 8.832 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4571 8.835 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1985\302\265s 0 ADV_NONCONN_IND 4572 8.835 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4573 8.836 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4574 8.842 1e:28:49:84:c5:cd LE 1M LE LL 37 5449\302\265s 0 ADV_NONCONN_IND 4575 8.842 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4576 8.843 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4577 8.845 c0:4e:43:7b:5f:2b LE 1M LE LL 14 1733\302\265s 0 ADV_IND 4578 8.877 0d:62:2c:2a:24:88 LE 1M LE LL 37 31719\302\265s 0 ADV_NONCONN_IND 4579 8.877 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4580 8.882 eb:6e:3d:68:42:19 LE 1M LE LL 36 3929\302\265s 0 ADV_IND[Malformed Packet] 4581 8.882 21:ea:1b:05:0d:1f LE 1M LE LL 37 279\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4582 8.883 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4583 8.885 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1299\302\265s 0 ADV_NONCONN_IND 4584 8.885 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4585 8.886 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4586 8.89 5c:9e:d4:03:82:5b LE 1M LE LL 37 4455\302\265s 0 ADV_NONCONN_IND 4587 8.891 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4588 8.892 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4589 8.895 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2777\302\265s 0 ADV_NONCONN_IND 4590 8.896 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4591 8.896 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4592 8.904 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7957\302\265s 0 ADV_NONCONN_IND 4593 8.905 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4594 8.906 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4595 8.907 f1:ff:a7:1a:55:8d LE 1M LE LL 36 552\302\265s 0 ADV_IND 4596 8.913 c8:de:06:91:ba:b3 LE 1M LE LL 36 5979\302\265s 0 ADV_IND 4597 8.92 43:bd:56:bd:74:f9 LE 1M LE LL 37 6990\302\265s 0 ADV_NONCONN_IND 4598 8.925 eb:db:35:2e:09:1b LE 1M LE LL 20 4272\302\265s 0 ADV_IND 4599 8.926 32:43:3c:28:8d:92 LE 1M LE LL 37 661\302\265s 0 ADV_NONCONN_IND 4600 8.926 32:43:3c:28:8d:92 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4601 8.927 11:fe:ef:ed:38:82 LE 1M LE LL 37 391\302\265s 0 ADV_NONCONN_IND 4602 8.928 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4603 8.928 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4604 8.929 08:ec:5e:66:cd:0d LE 1M LE LL 23 156\302\265s 0 ADV_NONCONN_IND 4605 8.929 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4606 8.93 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4607 8.937 d6:bf:76:0a:0b:dc LE 1M LE LL 36 7552\302\265s 0 ADV_IND 4608 8.941 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2916\302\265s 0 ADV_NONCONN_IND 4609 8.941 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4610 8.943 17:5f:43:7c:0a:89 LE 1M LE LL 23 1510\302\265s 0 ADV_NONCONN_IND 4611 8.944 c2:f4:e6:80:5e:ae LE 1M LE LL 36 743\302\265s 0 ADV_IND 4612 8.95 1e:28:49:84:c5:cd LE 1M LE LL 37 5216\302\265s 0 ADV_NONCONN_IND 4613 8.959 SamsungE_07:d8:af LE 1M LE LL 162 8712\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4614 8.968 d6:bf:03:c5:20:42 LE 1M LE LL 36 7901\302\265s 0 ADV_IND 4615 8.974 cc:15:14:59:64:aa LE 1M LE LL 36 5570\302\265s 0 ADV_IND 4616 8.976 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1665\302\265s 0 ADV_IND 4617 8.982 0d:62:2c:2a:24:88 LE 1M LE LL 37 6069\302\265s 0 ADV_NONCONN_IND 4618 8.983 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4619 8.985 0b:f9:be:c7:0f:fb LE 1M LE LL 23 1943\302\265s 0 ADV_NONCONN_IND 4620 8.986 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4621 8.986 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4622 8.987 61:9c:87:78:87:2b LE 1M LE LL 23 978\302\265s 0 ADV_IND 4623 8.994 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6310\302\265s 0 ADV_NONCONN_IND 4624 8.995 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4625 8.998 5c:9e:d4:03:82:5b LE 1M LE LL 37 3047\302\265s 0 ADV_NONCONN_IND 4626 8.999 5c:9e:d4:03:82:5b LE 1M LE LL 37 252\302\265s 0 ADV_NONCONN_IND 4627 8.999 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 4628 9.001 74:d9:0b:7a:47:5a LE 1M LE LL 23 1447\302\265s 0 ADV_IND 4629 9.004 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2311\302\265s 0 ADV_NONCONN_IND 4630 9.004 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4631 9.013 16:ed:93:0f:fa:b0 LE 1M LE LL 37 8069\302\265s 0 ADV_NONCONN_IND 4632 9.013 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4633 9.014 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4634 9.016 d5:80:ce:3a:df:84 LE 1M LE LL 36 1366\302\265s 0 ADV_IND 4635 9.026 07:69:22:f0:72:30 LE 1M LE LL 37 9978\302\265s 0 ADV_NONCONN_IND 4636 9.026 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4637 9.029 32:43:3c:28:8d:92 LE 1M LE LL 37 2106\302\265s 0 ADV_NONCONN_IND 4638 9.03 33:d3:bd:28:89:92 LE 1M LE LL 53 179\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4639 9.031 d6:11:16:57:f1:d0 LE 1M LE LL 36 676\302\265s 0 ADV_IND 4640 9.043 25:5f:bf:53:1f:d7 LE 1M LE LL 37 12123\302\265s 0 ADV_NONCONN_IND 4641 9.044 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4642 9.044 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4643 9.045 2b:5e:0e:c8:62:4c LE 1M LE LL 35 111\302\265s 0 ADV_NONCONN_IND 4644 9.045 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4645 9.046 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4646 9.049 1e:28:49:84:c5:cd LE 1M LE LL 37 2323\302\265s 0 ADV_NONCONN_IND 4647 9.049 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4648 9.05 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4649 9.073 c6:f1:43:db:5f:1d LE 1M LE LL 36 22693\302\265s 0 ADV_IND 4650 9.086 0d:62:2c:2a:24:88 LE 1M LE LL 37 13090\302\265s 0 ADV_NONCONN_IND 4651 9.087 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4652 9.092 31:ea:1b:25:0d:1f LE 1M LE LL 37 4638\302\265s 0 ADV_NONCONN_IND 4653 9.092 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4654 9.093 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4655 9.094 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1175\302\265s 0 ADV_NONCONN_IND 4656 9.095 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4657 9.096 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4658 9.097 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 849\302\265s 0 ADV_NONCONN_IND 4659 9.098 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4660 9.098 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4661 9.105 5c:9e:d4:03:82:5b LE 1M LE LL 37 6962\302\265s 0 ADV_NONCONN_IND 4662 9.106 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4663 9.107 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4664 9.116 SamsungE_07:d8:8f LE 1M LE LL 34 9115\302\265s 0 ADV_NONCONN_IND 4665 9.117 16:ed:93:0f:fa:b0 LE 1M LE LL 37 431\302\265s 0 ADV_NONCONN_IND 4666 9.118 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4667 9.119 27:f1:d5:6a:d5:82 LE 1M LE LL 37 837\302\265s 0 ADV_NONCONN_IND 4668 9.12 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4669 9.12 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4670 9.123 43:bd:56:bd:74:f9 LE 1M LE LL 37 2480\302\265s 0 ADV_NONCONN_IND 4671 9.124 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4672 9.125 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4673 9.126 07:69:22:f0:72:30 LE 1M LE LL 37 629\302\265s 0 ADV_NONCONN_IND 4674 9.127 07:69:22:f0:72:30 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4675 9.127 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 4676 9.132 7d:30:e4:59:cd:06 LE 1M LE LL 25 4158\302\265s 0 ADV_IND 4677 9.133 5f:ab:4a:c2:70:a2 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 4678 9.136 32:43:3c:28:8d:92 LE 1M LE LL 37 3435\302\265s 0 ADV_NONCONN_IND 4679 9.138 11:fe:ef:ed:38:82 LE 1M LE LL 37 1015\302\265s 0 ADV_NONCONN_IND 4680 9.138 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4681 9.139 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4682 9.144 25:5f:bf:53:1f:d7 LE 1M LE LL 37 4615\302\265s 0 ADV_NONCONN_IND 4683 9.144 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4684 9.145 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4685 9.146 2b:5e:0e:c8:62:4c LE 1M LE LL 35 737\302\265s 0 ADV_NONCONN_IND 4686 9.147 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4687 9.147 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4688 9.15 50:d3:b9:81:11:84 LE 1M LE LL 12 2942\302\265s 0 SCAN_REQ 4689 9.151 c4:d3:3f:79:a7:16 LE 1M LE LL 36 415\302\265s 0 ADV_IND 4690 9.152 5f:ab:4a:c2:70:a2 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 4691 9.156 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 4071\302\265s 0 ADV_IND 4692 9.157 ed:4e:4a:f5:08:6e LE 1M LE LL 14 428\302\265s 0 ADV_NONCONN_IND 4693 9.157 1e:28:49:84:c5:cd LE 1M LE LL 37 534\302\265s 0 ADV_NONCONN_IND 4694 9.158 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4695 9.158 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4696 9.162 50:d3:b9:81:11:84 LE 1M LE LL 12 3535\302\265s 0 SCAN_REQ 4697 9.163 c5:65:68:79:19:c8 LE 1M LE LL 36 415\302\265s 0 ADV_IND 4698 9.163 5f:ab:4a:c2:70:a2 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 4699 9.175 e5:ea:46:16:3e:1e LE 1M LE LL 36 11746\302\265s 0 ADV_IND 4700 9.179 45:65:34:45:09:77 LE 1M LE LL 36 3029\302\265s 0 ADV_IND 4701 9.18 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 4702 9.192 74:d9:0b:7a:47:5a LE 1M LE LL 23 11601\302\265s 0 ADV_IND 4703 9.196 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3631\302\265s 0 ADV_NONCONN_IND 4704 9.196 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4705 9.197 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4706 9.198 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 236\302\265s 0 ADV_NONCONN_IND 4707 9.198 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4708 9.199 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4709 9.202 c0:41:04:2e:be:9d LE 1M LE LL 36 3023\302\265s 0 ADV_IND 4710 9.203 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 4711 9.203 c0:41:04:2e:be:9d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4712 9.204 71:c9:89:02:1c:fb LE 1M LE LL 12 655\302\265s 0 SCAN_REQ 4713 9.207 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2784\302\265s 0 ADV_NONCONN_IND 4714 9.215 ef:6e:3d:68:42:19 LE 1M LE LL 36 8214\302\265s 0 ADV_IND 4715 9.216 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4716 9.217 71:c9:88:03:1c:fb LE 1M LE LL 12 681\302\265s 0 SCAN_REQ 4717 9.217 e7:70:80:c3:ad:91 LE 1M LE LL 36 496\302\265s 0 ADV_IND 4718 9.22 5c:9e:d4:03:82:5b LE 1M LE LL 37 2359\302\265s 0 ADV_NONCONN_IND 4719 9.221 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4720 9.221 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4721 9.224 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2027\302\265s 0 ADV_NONCONN_IND 4722 9.225 26:8f:8b:0f:fa:b0 LE 1M LE LL 37 357\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4723 9.225 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4724 9.228 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2773\302\265s 0 ADV_NONCONN_IND 4725 9.229 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4726 9.229 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4727 9.231 cf:c8:cc:72:d8:be LE 1M LE LL 14 1352\302\265s 0 ADV_NONCONN_IND 4728 9.231 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 4729 9.232 cf:c8:cc:7e:d8:be LE 1M LE LL 14 133\302\265s 0 ADV_NONCONN_IND 4730 9.233 07:69:22:f0:72:30 LE 1M LE LL 37 944\302\265s 0 ADV_NONCONN_IND 4731 9.233 07:69:22:f0:72:30 LE 1M LE LL 37 196\302\265s 0 ADV_NONCONN_IND 4732 9.234 07:69:22:f0:72:30 LE 1M LE LL 37 193\302\265s 0 ADV_NONCONN_IND 4733 9.24 11:fe:ef:ed:38:82 LE 1M LE LL 37 5850\302\265s 0 ADV_NONCONN_IND 4734 9.241 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4735 9.241 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4736 9.243 32:43:3c:28:8d:92 LE 1M LE LL 37 1638\302\265s 0 ADV_NONCONN_IND 4737 9.244 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4738 9.244 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4739 9.245 f1:ff:a7:1a:55:8d LE 1M LE LL 36 411\302\265s 0 ADV_IND 4740 9.246 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4741 9.246 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4742 9.246 f1:ff:a7:1a:55:8d LE 1M LE LL 36 134\302\265s 0 ADV_IND 4743 9.247 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4744 9.247 f1:ff:a7:1a:55:8d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4745 9.247 f1:ff:a7:1a:55:8d LE 1M LE LL 36 136\302\265s 0 ADV_IND 4746 9.25 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2247\302\265s 0 ADV_NONCONN_IND 4747 9.251 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4748 9.251 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4749 9.259 1e:28:49:84:c5:cd LE 1M LE LL 37 6993\302\265s 0 ADV_NONCONN_IND 4750 9.259 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4751 9.26 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4752 9.263 64:0d:49:f9:4d:a4 LE 1M LE LL 12 3010\302\265s 0 SCAN_REQ 4753 9.273 79:70:d9:25:16:e2 LE 1M LE LL 25 9907\302\265s 0 ADV_IND 4754 9.274 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4755 9.274 79:70:d9:25:16:e2 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4756 9.274 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 4757 9.275 79:70:d9:25:16:e2 LE 1M LE LL 6 476\302\265s 0 SCAN_RSP 4758 9.276 64:0d:49:f9:4d:a4 LE 1M LE LL 12 1351\302\265s 0 SCAN_REQ 4759 9.277 c2:f4:e6:80:5e:ae LE 1M LE LL 36 162\302\265s 0 ADV_IND 4760 9.277 72:c4:71:2c:70:59 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4761 9.278 c2:f4:e6:80:5e:ae LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4762 9.278 c2:f4:e6:80:5e:ae LE 1M LE LL 36 137\302\265s 0 ADV_IND 4763 9.279 64:0d:49:f9:4d:a4 LE 1M LE LL 12 713\302\265s 0 SCAN_REQ 4764 9.28 71:c9:89:02:1c:fb LE 1M LE LL 12 831\302\265s 0 SCAN_REQ 4765 9.297 0d:62:2c:2a:24:88 LE 1M LE LL 37 17281\302\265s 0 ADV_NONCONN_IND 4766 9.298 3a:d1:ca:1d:4d:de LE 1M LE LL 26 402\302\265s 0 ADV_NONCONN_IND 4767 9.299 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4768 9.3 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4769 9.301 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1499\302\265s 0 ADV_NONCONN_IND 4770 9.302 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4771 9.303 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4772 9.304 50:d3:b9:81:11:84 LE 1M LE LL 12 1010\302\265s 0 SCAN_REQ 4773 9.307 b5:c7:23:03:b9:42 LE 1M LE LL 36 3046\302\265s 0 ADV_IND[Malformed Packet] 4774 9.308 d6:bf:03:c5:20:42 LE 1M LE LL 36 354\302\265s 0 ADV_IND 4775 9.312 64:0d:49:f9:4d:a4 LE 1M LE LL 12 3393\302\265s 0 SCAN_REQ 4776 9.312 cc:15:14:59:64:aa LE 1M LE LL 36 143\302\265s 0 ADV_IND 4777 9.314 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1954\302\265s 0 ADV_NONCONN_IND 4778 9.319 5c:9e:d4:03:82:5b LE 1M LE LL 37 4605\302\265s 0 ADV_NONCONN_IND 4779 9.32 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4780 9.321 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4781 9.323 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1795\302\265s 0 ADV_IND 4782 9.324 cf:4f:81:f5:7d:55 LE 1M LE LL 36 490\302\265s 0 ADV_IND 4783 9.324 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4784 9.324 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4785 9.325 cf:4f:81:f5:7d:55 LE 1M LE LL 36 138\302\265s 0 ADV_IND 4786 9.329 40:f0:08:9b:56:91 LE 1M LE LL 37 3646\302\265s 0 ADV_SCAN_IND 4787 9.329 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4788 9.335 27:f1:d5:6a:d5:82 LE 1M LE LL 37 5262\302\265s 0 ADV_NONCONN_IND 4789 9.335 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4790 9.337 e5:ea:46:16:3e:1e LE 1M LE LL 36 1033\302\265s 0 ADV_IND[Malformed Packet] 4791 9.337 59:4b:8b:0f:b7:16 LE 1M LE LL 37 219\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4792 9.338 24:c3:d0:ce:d4:37 LE 1M LE LL 37 267\302\265s 0 ADV_NONCONN_IND 4793 9.346 32:43:3c:28:8d:92 LE 1M LE LL 37 8002\302\265s 0 ADV_NONCONN_IND 4794 9.347 32:43:3c:28:8d:92 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 4795 9.347 2f:36:7c:0c:24:1c LE 1M LE LL 12 92\302\265s 0 SCAN_REQ 4796 9.349 d5:80:ce:3a:df:84 LE 1M LE LL 36 1597\302\265s 0 ADV_IND 4797 9.351 4d:dc:b7:a2:f3:be LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 4798 9.351 d5:80:ce:3a:df:84 LE 1M LE LL 36 415\302\265s 0 ADV_IND 4799 9.352 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4800 9.352 d5:80:ce:3a:df:84 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 4801 9.353 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1128\302\265s 0 ADV_NONCONN_IND 4802 9.354 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4803 9.354 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4804 9.359 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4485\302\265s 0 ADV_NONCONN_IND 4805 9.36 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4806 9.36 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4807 9.362 cd:5c:f3:7d:98:0b LE 1M LE LL 36 1491\302\265s 0 ADV_IND 4808 9.365 1e:28:49:84:c5:cd LE 1M LE LL 37 2892\302\265s 0 ADV_NONCONN_IND 4809 9.366 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4810 9.367 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 304\302\265s 0 ADV_NONCONN_IND 4811 9.367 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4812 9.367 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4813 9.38 ec:af:39:d1:f5:fe LE 1M LE LL 14 12145\302\265s 0 ADV_NONCONN_IND 4814 9.38 ec:af:39:d1:f5:fe LE 1M LE LL 14 265\302\265s 0 ADV_NONCONN_IND 4815 9.381 ec:af:39:d1:f5:fe LE 1M LE LL 14 262\302\265s 0 ADV_NONCONN_IND 4816 9.382 74:d9:0b:7a:47:5a LE 1M LE LL 28 1399\302\265s 0 ADV_IND 4817 9.384 4d:dc:b7:a2:f3:be LE 1M LE LL 12 968\302\265s 0 SCAN_REQ 4818 9.384 74:d9:0b:7a:47:5a LE 1M LE LL 28 549\302\265s 0 ADV_IND 4819 9.397 0d:62:2c:2a:24:88 LE 1M LE LL 37 12294\302\265s 0 ADV_NONCONN_IND 4820 9.397 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4821 9.398 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4822 9.399 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1016\302\265s 0 ADV_NONCONN_IND 4823 9.4 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4824 9.401 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4825 9.404 31:ea:1b:25:0d:1f LE 1M LE LL 37 2465\302\265s 0 ADV_NONCONN_IND 4826 9.404 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4827 9.405 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4828 9.408 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2555\302\265s 0 ADV_NONCONN_IND 4829 9.408 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4830 9.409 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4831 9.418 0c:6e:66:d7:ed:03 LE 1M LE LL 37 8852\302\265s 0 ADV_NONCONN_IND 4832 9.419 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4833 9.419 74:d9:0b:7a:47:5a LE 1M LE LL 28 86\302\265s 0 ADV_IND[Malformed Packet] 4834 9.426 5c:9e:d4:03:82:5b LE 1M LE LL 37 6090\302\265s 0 ADV_NONCONN_IND 4835 9.426 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4836 9.427 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4837 9.433 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6213\302\265s 0 ADV_NONCONN_IND 4838 9.434 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4839 9.434 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4840 9.438 07:69:22:f0:72:30 LE 1M LE LL 37 3647\302\265s 0 ADV_NONCONN_IND 4841 9.439 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 4842 9.44 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4843 9.44 24:c3:d0:ce:d4:37 LE 1M LE LL 37 116\302\265s 0 ADV_NONCONN_IND 4844 9.441 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4845 9.441 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4846 9.453 11:fe:ef:ed:38:82 LE 1M LE LL 37 11754\302\265s 0 ADV_NONCONN_IND 4847 9.454 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4848 9.454 74:d9:0b:7a:47:5a LE 1M LE LL 7 178\302\265s 0 SCAN_RSP[Malformed Packet] 4849 9.463 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7977\302\265s 0 ADV_NONCONN_IND 4850 9.463 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4851 9.464 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4852 9.469 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4488\302\265s 0 ADV_NONCONN_IND 4853 9.469 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4854 9.47 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 4855 9.471 1e:28:49:84:c5:cd LE 1M LE LL 37 1071\302\265s 0 ADV_NONCONN_IND 4856 9.472 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4857 9.472 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4858 9.474 dd:d8:c3:2e:6d:c8 LE 1M LE LL 36 1502\302\265s 0 ADV_IND 4859 9.475 46:cd:f9:15:6d:d0 LE 1M LE LL 12 868\302\265s 0 SCAN_REQ 4860 9.489 74:d9:0b:7a:47:5a LE 1M LE LL 28 13537\302\265s 0 ADV_IND 4861 9.493 c1:c8:16:ae:fd:1d LE 1M LE LL 36 3994\302\265s 0 ADV_IND 4862 9.494 c1:c8:16:ae:fd:1d LE 1M LE LL 36 353\302\265s 0 ADV_IND 4863 9.495 c1:c8:16:ae:fd:1d LE 1M LE LL 36 354\302\265s 0 ADV_IND 4864 9.495 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 287\302\265s 0 ADV_IND 4865 9.498 0d:62:2c:2a:24:88 LE 1M LE LL 37 2388\302\265s 0 ADV_NONCONN_IND 4866 9.499 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4867 9.499 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4868 9.501 c5:65:68:79:19:c8 LE 1M LE LL 36 901\302\265s 0 ADV_IND 4869 9.501 c5:65:68:79:19:c8 LE 1M LE LL 36 353\302\265s 0 ADV_IND 4870 9.502 46:cd:f9:15:6d:d0 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 4871 9.502 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4872 9.502 c5:65:68:79:19:c8 LE 1M LE LL 36 138\302\265s 0 ADV_IND 4873 9.506 HuaweiTe_d1:97:cf LE 1M LE LL 28 3357\302\265s 0 ADV_IND[Malformed Packet] 4874 9.509 31:ea:1b:25:0d:1f LE 1M LE LL 37 2801\302\265s 0 ADV_NONCONN_IND 4875 9.51 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4876 9.517 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 6933\302\265s 0 ADV_NONCONN_IND 4877 9.518 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4878 9.518 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4879 9.521 5e:93:36:dd:d3:09 LE 1M LE LL 10 2295\302\265s 0 ADV_SCAN_IND 4880 9.523 74:d9:0b:7a:47:5a LE 1M LE LL 28 1575\302\265s 0 ADV_IND 4881 9.527 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3889\302\265s 0 ADV_NONCONN_IND 4882 9.537 c0:41:04:2e:be:9d LE 1M LE LL 36 10020\302\265s 0 ADV_IND 4883 9.54 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2621\302\265s 0 ADV_NONCONN_IND 4884 9.541 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4885 9.542 1f:84:46:51:98:14 LE 1M LE LL 23 557\302\265s 0 ADV_NONCONN_IND 4886 9.542 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4887 9.542 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4888 9.546 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3582\302\265s 0 ADV_NONCONN_IND 4889 9.547 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4890 9.548 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4891 9.553 ef:6e:3d:68:42:19 LE 1M LE LL 36 4483\302\265s 0 ADV_IND 4892 9.555 e7:70:80:c3:ad:91 LE 1M LE LL 36 2251\302\265s 0 ADV_IND 4893 9.556 e7:70:80:c3:ad:91 LE 1M LE LL 36 354\302\265s 0 ADV_IND 4894 9.559 32:43:3c:28:8d:92 LE 1M LE LL 37 2458\302\265s 0 ADV_NONCONN_IND 4895 9.56 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4896 9.56 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4897 9.566 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5866\302\265s 0 ADV_NONCONN_IND 4898 9.567 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4899 9.567 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4900 9.576 1e:28:49:84:c5:cd LE 1M LE LL 37 8245\302\265s 0 ADV_NONCONN_IND 4901 9.577 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4902 9.577 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4903 9.583 47:4e:9b:89:59:8e LE 1M LE LL 12 5305\302\265s 0 SCAN_REQ 4904 9.584 7f:ab:0f:33:5d:32 LE 1M LE LL 12 933\302\265s 0 SCAN_REQ 4905 9.587 f1:ff:a7:1a:55:8d LE 1M LE LL 36 3309\302\265s 0 ADV_IND 4906 9.594 94:d9:0b:7a:47:5a LE 1M LE LL 28 6665\302\265s 0 ADV_IND[Malformed Packet] 4907 9.596 c8:de:06:91:ba:b3 LE 1M LE LL 36 1708\302\265s 0 ADV_IND 4908 9.597 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4909 9.603 47:4e:9b:89:59:8e LE 1M LE LL 12 6193\302\265s 0 SCAN_REQ 4910 9.608 d6:bf:76:0a:0b:dc LE 1M LE LL 36 4928\302\265s 0 ADV_IND 4911 9.609 0b:f9:be:c7:0f:fb LE 1M LE LL 23 276\302\265s 0 ADV_NONCONN_IND 4912 9.61 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 4913 9.61 0b:f9:be:c7:0f:fb LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 4914 9.618 31:ea:1b:25:0d:1f LE 1M LE LL 37 7838\302\265s 0 ADV_NONCONN_IND 4915 9.619 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4916 9.619 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4917 9.621 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1306\302\265s 0 ADV_NONCONN_IND 4918 9.628 74:d9:0b:7a:47:5a LE 1M LE LL 28 7029\302\265s 0 ADV_IND 4919 9.629 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4920 9.629 74:d9:0b:7a:47:5a LE 1M LE LL 6 149\302\265s 0 SCAN_RSP 4921 9.629 74:d9:0b:7a:47:5a LE 1M LE LL 28 272\302\265s 0 ADV_IND 4922 9.631 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1449\302\265s 0 ADV_NONCONN_IND 4923 9.632 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4924 9.632 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4925 9.641 5c:9e:d4:03:82:5b LE 1M LE LL 37 7734\302\265s 0 ADV_NONCONN_IND 4926 9.641 7f:ab:0f:33:5d:32 LE 1M LE LL 12 129\302\265s 0 SCAN_REQ 4927 9.642 d6:bf:03:c5:20:42 LE 1M LE LL 36 416\302\265s 0 ADV_IND 4928 9.642 16:ed:93:0f:fa:b0 LE 1M LE LL 37 133\302\265s 0 ADV_NONCONN_IND 4929 9.643 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4930 9.643 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4931 9.648 07:69:22:f0:72:30 LE 1M LE LL 37 4267\302\265s 0 ADV_NONCONN_IND 4932 9.648 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 4933 9.649 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 4934 9.65 cc:15:14:59:64:aa LE 1M LE LL 36 576\302\265s 0 ADV_IND 4935 9.651 7f:ab:0f:33:5d:32 LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 4936 9.652 cc:15:14:59:64:aa LE 1M LE LL 36 414\302\265s 0 ADV_IND 4937 9.656 cf:4f:81:f5:7d:55 LE 1M LE LL 36 4277\302\265s 0 ADV_IND 4938 9.658 7f:ab:0f:33:5d:32 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 4939 9.658 cf:4f:81:f5:7d:55 LE 1M LE LL 36 416\302\265s 0 ADV_IND 4940 9.661 11:fe:ef:ed:38:82 LE 1M LE LL 37 2240\302\265s 0 ADV_NONCONN_IND 4941 9.661 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4942 9.662 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4943 9.664 32:43:3c:28:8d:92 LE 1M LE LL 37 1636\302\265s 0 ADV_NONCONN_IND 4944 9.665 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4945 9.665 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 4946 9.666 e5:ea:46:16:3e:1e LE 1M LE LL 36 108\302\265s 0 ADV_IND 4947 9.667 15:6b:77:7a:47:5a LE 1M LE LL 28 778\302\265s 0 ADV_IND[Malformed Packet] 4948 9.668 74:d9:0b:7a:47:5a LE 1M LE LL 28 515\302\265s 0 ADV_IND 4949 9.668 74:d9:0b:7a:47:5a LE 1M LE LL 28 513\302\265s 0 ADV_IND 4950 9.67 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1355\302\265s 0 ADV_NONCONN_IND 4951 9.671 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4952 9.684 1e:28:49:84:c5:cd LE 1M LE LL 37 12617\302\265s 0 ADV_NONCONN_IND 4953 9.685 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1406\302\265s 0 ADV_NONCONN_IND 4954 9.686 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4955 9.689 d5:80:ce:3a:9f:84 LE 1M LE LL 36 2982\302\265s 0 ADV_IND 4956 9.69 d5:80:ce:3a:df:84 LE 1M LE LL 36 353\302\265s 0 ADV_IND 4957 9.69 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4958 9.691 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 4959 9.691 d5:80:ce:3a:df:84 LE 1M LE LL 36 137\302\265s 0 ADV_IND 4960 9.695 cb:54:ed:79:f8:0b LE 1M LE LL 36 3143\302\265s 0 ADV_IND[Malformed Packet] 4961 9.701 74:d9:0b:7a:47:5a LE 1M LE LL 28 6053\302\265s 0 ADV_IND 4962 9.709 0d:62:2c:2a:24:88 LE 1M LE LL 37 7974\302\265s 0 ADV_NONCONN_IND 4963 9.714 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4759\302\265s 0 ADV_NONCONN_IND 4964 9.715 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 4965 9.716 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 4966 9.727 31:ea:1b:25:0d:1f LE 1M LE LL 37 11220\302\265s 0 ADV_NONCONN_IND 4967 9.728 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4968 9.729 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4969 9.731 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2268\302\265s 0 ADV_NONCONN_IND 4970 9.732 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 4971 9.732 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 4972 9.737 74:d9:0b:7a:47:5a LE 1M LE LL 28 4623\302\265s 0 ADV_IND 4973 9.746 5c:9e:d4:03:82:5b LE 1M LE LL 37 8435\302\265s 0 ADV_NONCONN_IND 4974 9.747 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 4975 9.748 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1221\302\265s 0 ADV_NONCONN_IND 4976 9.749 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4977 9.749 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 4978 9.754 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3929\302\265s 0 ADV_NONCONN_IND 4979 9.755 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 4980 9.755 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 4981 9.757 c1:c8:e4:fd:0c:5d LE 1M LE LL 5 1039\302\265s 0 ADV_IND 4982 9.758 24:c3:d0:ce:d4:37 LE 1M LE LL 37 568\302\265s 0 ADV_NONCONN_IND 4983 9.758 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4984 9.764 c6:59:d0:fc:f1:b9 LE 1M LE LL 14 5885\302\265s 0 ADV_IND 4985 9.765 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 4986 9.771 11:fe:ef:ed:38:82 LE 1M LE LL 37 5909\302\265s 0 ADV_NONCONN_IND 4987 9.771 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4988 9.773 32:43:3c:28:8d:92 LE 1M LE LL 37 1636\302\265s 0 ADV_NONCONN_IND 4989 9.774 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4990 9.774 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 4991 9.775 25:5f:bf:53:1f:d7 LE 1M LE LL 37 239\302\265s 0 ADV_NONCONN_IND 4992 9.776 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4993 9.776 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 4994 9.787 2b:5e:0e:c8:62:4c LE 1M LE LL 35 10111\302\265s 0 ADV_NONCONN_IND 4995 9.787 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4996 9.788 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 4997 9.789 1e:28:49:84:c5:cd LE 1M LE LL 37 444\302\265s 0 ADV_NONCONN_IND 4998 9.789 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 4999 9.79 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5000 9.797 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 7150\302\265s 0 ADV_IND 5001 9.807 74:d9:0b:7a:47:5a LE 1M LE LL 28 9102\302\265s 0 ADV_IND 5002 9.812 0d:62:2c:2a:24:88 LE 1M LE LL 37 4796\302\265s 0 ADV_NONCONN_IND 5003 9.816 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3508\302\265s 0 ADV_NONCONN_IND 5004 9.816 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5005 9.817 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5006 9.819 79:70:d9:25:16:e2 LE 1M LE LL 25 1317\302\265s 0 ADV_IND 5007 9.819 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5008 9.819 79:70:d9:25:16:e2 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5009 9.82 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 5010 9.829 c4:d3:3f:79:a7:16 LE 1M LE LL 36 8733\302\265s 0 ADV_IND 5011 9.833 e5:ea:46:16:3e:1e LE 1M LE LL 36 3908\302\265s 0 ADV_IND 5012 9.834 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 133\302\265s 0 ADV_IND 5013 9.835 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 741\302\265s 0 ADV_IND 5014 9.837 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1750\302\265s 0 ADV_NONCONN_IND 5015 9.838 dd:b9:3b:45:59:8b LE 1M LE LL 24 539\302\265s 0 ADV_IND 5016 9.84 c5:65:68:79:19:c8 LE 1M LE LL 36 2023\302\265s 0 ADV_IND 5017 9.843 74:d9:0b:7a:47:5a LE 1M LE LL 28 2335\302\265s 0 ADV_IND 5018 9.849 07:69:22:f0:72:30 LE 1M LE LL 37 6125\302\265s 0 ADV_NONCONN_IND 5019 9.85 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 5020 9.85 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5021 9.855 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4003\302\265s 0 ADV_NONCONN_IND 5022 9.855 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5023 9.856 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5024 9.858 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1422\302\265s 0 ADV_NONCONN_IND 5025 9.858 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5026 9.859 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5027 9.86 5c:9e:d4:03:82:5b LE 1M LE LL 37 579\302\265s 0 ADV_NONCONN_IND 5028 9.861 LE 1M LE LL 111 150\302\265s 0 Unknown 5029 9.864 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2084\302\265s 0 ADV_NONCONN_IND 5030 9.871 11:fe:ef:ed:38:82 LE 1M LE LL 37 7385\302\265s 0 ADV_NONCONN_IND 5031 9.872 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5032 9.873 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5033 9.876 c0:45:06:2e:be:bd LE 1M LE LL 36 2948\302\265s 0 ADV_IND[Malformed Packet] 5034 9.877 64:0d:49:f9:4d:a4 LE 1M LE LL 12 224\302\265s 0 SCAN_REQ 5035 9.877 74:d9:0b:7a:47:5a LE 1M LE LL 28 549\302\265s 0 ADV_IND 5036 9.878 50:d1:b9:81:1d:82 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5037 9.878 32:43:3c:28:8d:92 LE 1M LE LL 37 488\302\265s 0 ADV_NONCONN_IND 5038 9.879 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5039 9.879 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5040 9.889 ef:6e:3d:68:42:19 LE 1M LE LL 36 9162\302\265s 0 ADV_IND 5041 9.892 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2224\302\265s 0 ADV_NONCONN_IND 5042 9.892 89:e1:5b:d1:0d:c8 LE 1M LE LL 6 105\302\265s 0 SCAN_RSP 5043 9.892 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 77\302\265s 0 ADV_IND 5044 9.893 64:0d:49:f9:4d:a4 LE 1M LE LL 12 790\302\265s 0 SCAN_REQ 5045 9.894 50:d5:b9:81:1d:92 LE 1M LE LL 12 463\302\265s 0 SCAN_REQ 5046 9.898 1e:28:49:84:c5:cd LE 1M LE LL 37 3796\302\265s 0 ADV_NONCONN_IND 5047 9.898 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_SCAN_IND 5048 9.899 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5049 9.904 c6:f1:43:db:5f:1d LE 1M LE LL 52 4397\302\265s 0 ADV_IND[Malformed Packet] 5050 9.905 c6:f1:43:db:57:1d LE 1M LE LL 36 225\302\265s 0 ADV_IND 5051 9.906 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 5052 9.914 e5:ea:92:fe:cc:4a LE 1M LE LL 40 8174\302\265s 0 ADV_IND[Malformed Packet] 5053 9.915 64:0d:49:f9:4d:a4 LE 1M LE LL 12 303\302\265s 0 SCAN_REQ 5054 9.916 74:d9:0b:7a:47:5a LE 1M LE LL 28 549\302\265s 0 ADV_IND 5055 9.916 LE 1M LE LL 4 150\302\265s 0 SCAN_REQ[Malformed Packet] 5056 9.92 0d:62:2c:2a:24:88 LE 1M LE LL 37 3911\302\265s 0 ADV_NONCONN_IND 5057 9.921 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5058 9.921 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5059 9.925 f1:ff:a7:1a:55:8d LE 1M LE LL 36 3681\302\265s 0 ADV_IND 5060 9.926 3a:c1:ce:5d:4f:de LE 1M LE LL 18 824\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5061 9.936 71:c9:89:02:1c:fb LE 1M LE LL 12 8924\302\265s 0 SCAN_REQ 5062 9.94 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3851\302\265s 0 ADV_NONCONN_IND 5063 9.94 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5064 9.941 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5065 9.944 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3217\302\265s 0 ADV_NONCONN_IND 5066 9.945 0c:6e:66:d7:ed:03 LE 1M LE LL 37 247\302\265s 0 ADV_NONCONN_IND 5067 9.946 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5068 9.95 07:69:22:f0:72:30 LE 1M LE LL 37 3842\302\265s 0 ADV_NONCONN_IND 5069 9.95 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 5070 9.951 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5071 9.96 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 8449\302\265s 0 ADV_IND 5072 9.961 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 5073 9.962 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 415\302\265s 0 ADV_IND 5074 9.963 47:b7:71:1f:34:f9 LE 1M LE LL 37 1407\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5075 9.964 16:ed:93:0f:fa:b0 LE 1M LE LL 37 264\302\265s 0 ADV_NONCONN_IND 5076 9.964 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5077 9.966 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1418\302\265s 0 ADV_NONCONN_IND 5078 9.967 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5079 9.968 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5080 9.969 24:c3:d0:ce:d4:37 LE 1M LE LL 37 550\302\265s 0 ADV_NONCONN_IND 5081 9.969 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5082 9.97 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5083 9.971 11:fe:ef:ed:38:82 LE 1M LE LL 37 1134\302\265s 0 ADV_NONCONN_IND 5084 9.972 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5085 9.973 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5086 9.979 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6483\302\265s 0 ADV_NONCONN_IND 5087 9.98 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5088 9.981 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5089 9.988 32:43:3c:28:8d:92 LE 1M LE LL 37 6787\302\265s 0 ADV_NONCONN_IND 5090 9.988 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5091 9.989 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5092 9.992 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2465\302\265s 0 ADV_NONCONN_IND 5093 9.992 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5094 9.993 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5095 9.994 2e:86:8d:c9:47:bd LE 1M LE LL 17 815\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5096 9.996 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1733\302\265s 0 ADV_IND 5097 9.997 50:d3:b9:81:11:84 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 5098 10.001 e5:ea:46:16:3e:1e LE 1M LE LL 36 3230\302\265s 0 ADV_IND 5099 10.001 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 5100 10.002 50:d3:b9:81:11:84 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 5101 10.007 1e:28:49:84:c5:cd LE 1M LE LL 37 4648\302\265s 0 ADV_NONCONN_IND 5102 10.008 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5103 10.008 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5104 10.02 0d:62:2c:2a:24:88 LE 1M LE LL 37 11240\302\265s 0 ADV_NONCONN_IND 5105 10.021 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5106 10.021 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5107 10.025 74:d9:0b:7a:47:5a LE 1M LE LL 28 3157\302\265s 0 ADV_IND 5108 10.025 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5109 10.025 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5110 10.029 cd:5c:f3:7d:98:0b LE 1M LE LL 36 3404\302\265s 0 ADV_IND 5111 10.03 50:d3:b9:81:11:84 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 5112 10.033 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2741\302\265s 0 ADV_NONCONN_IND 5113 10.034 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5114 10.035 3a:d1:ca:1d:4d:de LE 1M LE LL 26 735\302\265s 0 ADV_NONCONN_IND 5115 10.041 31:ea:1b:25:0d:1f LE 1M LE LL 37 5940\302\265s 0 ADV_NONCONN_IND 5116 10.042 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5117 10.042 31:ea:1b:25:0d:1f LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5118 10.044 d5:2f:05:d0:15:7a LE 1M LE LL 37 1817\302\265s 0 ADV_IND[Malformed Packet] 5119 10.045 d6:2c:05:d0:15:49 LE 1M LE LL 37 396\302\265s 0 ADV_IND 5120 10.047 50:d3:b9:81:11:84 LE 1M LE LL 12 921\302\265s 0 SCAN_REQ 5121 10.047 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 377\302\265s 0 ADV_NONCONN_IND 5122 10.048 0c:6e:66:d7:ed:03 LE 1M LE LL 37 575\302\265s 0 ADV_NONCONN_IND 5123 10.049 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5124 10.049 7f:e1:7b:e4:24:1c LE 1M LE LL 12 292\302\265s 0 SCAN_REQ 5125 10.053 07:69:22:f0:72:30 LE 1M LE LL 37 3936\302\265s 0 ADV_NONCONN_IND 5126 10.054 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5127 10.058 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3675\302\265s 0 SCAN_REQ 5128 10.064 5c:9e:d4:03:82:5b LE 1M LE LL 37 5417\302\265s 0 ADV_NONCONN_IND 5129 10.064 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5130 10.065 16:ed:93:0f:fa:b0 LE 1M LE LL 37 604\302\265s 0 ADV_NONCONN_IND 5131 10.066 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5132 10.066 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5133 10.068 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1693\302\265s 0 SCAN_REQ 5134 10.073 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3941\302\265s 0 ADV_NONCONN_IND 5135 10.073 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5136 10.077 40:f0:08:9b:56:91 LE 1M LE LL 37 3826\302\265s 0 ADV_SCAN_IND 5137 10.08 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2331\302\265s 0 ADV_NONCONN_IND 5138 10.081 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5139 10.088 32:43:3c:28:8d:92 LE 1M LE LL 37 6787\302\265s 0 ADV_NONCONN_IND 5140 10.088 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5141 10.089 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5142 10.094 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4339\302\265s 0 ADV_NONCONN_IND 5143 10.094 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5144 10.095 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5145 10.096 Anonymous LE 1M LE LL 36 544\302\265s 0 AUX_CONNECT_RSP[Malformed Packet] 5146 10.099 78:ab:ba:4e:e4:be LE 1M LE LL 53 2938\302\265s 0 ADV_IND[Malformed Packet] 5147 10.11 1e:28:49:84:c5:cd LE 1M LE LL 37 10322\302\265s 0 ADV_NONCONN_IND 5148 10.11 49:08:83:d3:3a:6c LE 1M LE LL 12 301\302\265s 0 SCAN_REQ 5149 10.124 0d:62:2c:2a:24:88 LE 1M LE LL 37 13197\302\265s 0 ADV_NONCONN_IND 5150 10.124 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5151 10.135 74:d9:0b:7a:47:5a LE 1M LE LL 28 9941\302\265s 0 ADV_IND 5152 10.138 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2746\302\265s 0 ADV_NONCONN_IND 5153 10.138 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5154 10.147 31:ea:1b:25:0d:1f LE 1M LE LL 37 8096\302\265s 0 ADV_NONCONN_IND 5155 10.147 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5156 10.148 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5157 10.148 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 67\302\265s 0 ADV_NONCONN_IND 5158 10.149 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5159 10.149 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5160 10.162 07:69:22:f0:72:30 LE 1M LE LL 37 11803\302\265s 0 ADV_NONCONN_IND 5161 10.162 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 5162 10.163 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5163 10.164 0f:84:46:51:b8:14 LE 1M LE LL 23 1070\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5164 10.165 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5165 10.168 e5:ea:46:16:3e:1e LE 1M LE LL 36 3339\302\265s 0 ADV_IND 5166 10.173 74:d9:0b:7a:47:5a LE 1M LE LL 28 4620\302\265s 0 ADV_IND 5167 10.174 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5168 10.174 16:ed:93:0f:fa:b0 LE 1M LE LL 37 191\302\265s 0 ADV_NONCONN_IND 5169 10.175 43:bd:56:bd:74:f9 LE 1M LE LL 37 981\302\265s 0 ADV_NONCONN_IND 5170 10.176 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5171 10.179 11:fe:ef:ed:38:82 LE 1M LE LL 37 2420\302\265s 0 ADV_NONCONN_IND 5172 10.18 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5173 10.18 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5174 10.181 25:5f:bf:53:1f:d7 LE 1M LE LL 37 233\302\265s 0 ADV_NONCONN_IND 5175 10.181 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5176 10.187 32:cb:d3:f2:71:8c LE 1M LE LL 23 5087\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5177 10.189 08:ec:5e:66:cd:0d LE 1M LE LL 23 1846\302\265s 0 ADV_NONCONN_IND 5178 10.189 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5179 10.19 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5180 10.191 17:5f:43:7c:0a:89 LE 1M LE LL 23 1260\302\265s 0 ADV_NONCONN_IND 5181 10.193 32:43:3c:28:8d:92 LE 1M LE LL 37 1244\302\265s 0 ADV_NONCONN_IND 5182 10.193 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5183 10.21 74:d9:0b:7a:47:5a LE 1M LE LL 28 15912\302\265s 0 ADV_IND 5184 10.211 6c:c6:23:80:30:28 LE 1M LE LL 12 1139\302\265s 0 SCAN_REQ 5185 10.218 1e:28:49:84:c5:cd LE 1M LE LL 37 6674\302\265s 0 ADV_NONCONN_IND 5186 10.223 ef:6e:3d:68:42:19 LE 1M LE LL 36 4523\302\265s 0 ADV_IND 5187 10.224 6c:c6:23:80:30:28 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 5188 10.225 ef:6e:3d:68:42:19 LE 1M LE LL 36 414\302\265s 0 ADV_IND 5189 10.235 0b:f9:be:c7:0f:fb LE 1M LE LL 23 10541\302\265s 0 ADV_NONCONN_IND 5190 10.236 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5191 10.236 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5192 10.251 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 14339\302\265s 0 ADV_NONCONN_IND 5193 10.254 31:ea:1b:25:0d:1f LE 1M LE LL 37 2999\302\265s 0 ADV_NONCONN_IND 5194 10.255 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5195 10.256 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1014\302\265s 0 ADV_NONCONN_IND 5196 10.257 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5197 10.257 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5198 10.258 3a:d1:ca:1d:4d:de LE 1M LE LL 26 374\302\265s 0 ADV_NONCONN_IND 5199 10.259 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5200 10.26 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5201 10.265 f1:ff:a7:1a:55:8d LE 1M LE LL 36 5257\302\265s 0 ADV_IND 5202 10.266 6c:c6:23:80:30:28 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 5203 10.267 f1:ff:a7:1a:55:8d LE 1M LE LL 36 414\302\265s 0 ADV_IND 5204 10.268 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5205 10.268 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5206 10.271 07:69:22:f0:72:30 LE 1M LE LL 37 3013\302\265s 0 ADV_NONCONN_IND 5207 10.272 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 5208 10.272 07:69:22:f0:72:30 LE 1M LE LL 37 193\302\265s 0 ADV_NONCONN_IND 5209 10.276 5c:9e:d4:03:82:5b LE 1M LE LL 37 3014\302\265s 0 ADV_NONCONN_IND 5210 10.276 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5211 10.277 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5212 10.281 74:d9:0b:7a:47:5a LE 1M LE LL 28 3945\302\265s 0 ADV_IND 5213 10.282 24:c3:d0:ce:d4:37 LE 1M LE LL 37 526\302\265s 0 ADV_NONCONN_IND 5214 10.282 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5215 10.283 43:bd:56:bd:74:f9 LE 1M LE LL 37 424\302\265s 0 ADV_NONCONN_IND 5216 10.284 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5217 10.285 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5218 10.286 27:f1:d5:6a:d5:82 LE 1M LE LL 37 969\302\265s 0 ADV_NONCONN_IND 5219 10.287 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5220 10.288 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5221 10.301 32:43:3c:28:8d:92 LE 1M LE LL 37 12530\302\265s 0 ADV_NONCONN_IND 5222 10.301 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5223 10.302 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5224 10.303 2b:5e:0e:c8:62:4c LE 1M LE LL 35 591\302\265s 0 ADV_NONCONN_IND 5225 10.303 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5226 10.304 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5227 10.32 1e:28:49:84:c5:cd LE 1M LE LL 37 15444\302\265s 0 ADV_NONCONN_IND 5228 10.32 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5229 10.321 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5230 10.324 cc:15:14:59:64:aa LE 1M LE LL 36 2312\302\265s 0 ADV_IND 5231 10.325 6c:c6:23:80:30:28 LE 1M LE LL 12 869\302\265s 0 SCAN_REQ 5232 10.325 cc:15:14:59:64:aa LE 1M LE LL 36 414\302\265s 0 ADV_IND 5233 10.326 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5234 10.326 c8:15:14:59:64:aa LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5235 10.332 e5:ea:46:16:3e:1e LE 1M LE LL 36 5320\302\265s 0 ADV_IND 5236 10.332 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 5237 10.333 0d:62:2c:2a:24:88 LE 1M LE LL 37 209\302\265s 0 ADV_NONCONN_IND 5238 10.336 cf:4f:81:f5:7d:55 LE 1M LE LL 36 2991\302\265s 0 ADV_IND 5239 10.338 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 5240 10.338 cf:4f:81:f5:7d:55 LE 1M LE LL 36 416\302\265s 0 ADV_IND 5241 10.339 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5242 10.339 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5243 10.349 3a:d1:ca:1d:4d:de LE 1M LE LL 26 10203\302\265s 0 ADV_NONCONN_IND 5244 10.35 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5245 10.351 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5246 10.357 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6224\302\265s 0 ADV_NONCONN_IND 5247 10.358 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5248 10.359 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5249 10.362 d5:80:38:95:af:b7 LE 1M LE LL 34 3476\302\265s 0 CONNECT_IND 5250 10.365 d5:80:ce:3a:df:84 LE 1M LE LL 36 1996\302\265s 0 ADV_IND 5251 10.365 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5252 10.366 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5253 10.366 d5:80:ce:3a:df:84 LE 1M LE LL 36 137\302\265s 0 ADV_IND 5254 10.369 INIT_a6:8d:89 LE 1M LE LL 23 2570\302\265s 0 AUX_CONNECT_RSP[Malformed Packet: length of contained item exceeds length of containing item] 5255 10.369 1e:86:95:c9:47:bd LE 1M LE LL 29 117\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5256 10.37 2e:86:8d:c9:47:bd LE 1M LE LL 21 67\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5257 10.371 07:69:22:f0:72:30 LE 1M LE LL 37 1091\302\265s 0 ADV_NONCONN_IND 5258 10.372 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5259 10.372 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5260 10.381 11:fe:ef:ed:38:82 LE 1M LE LL 37 8370\302\265s 0 ADV_NONCONN_IND 5261 10.381 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5262 10.382 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5263 10.383 25:5f:bf:53:1f:d7 LE 1M LE LL 37 857\302\265s 0 ADV_NONCONN_IND 5264 10.384 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5265 10.384 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5266 10.386 43:bd:56:bd:74:f9 LE 1M LE LL 37 1084\302\265s 0 ADV_NONCONN_IND 5267 10.387 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5268 10.387 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5269 10.389 27:f1:d5:6a:d5:82 LE 1M LE LL 37 972\302\265s 0 ADV_NONCONN_IND 5270 10.39 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5271 10.39 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5272 10.393 74:d9:0b:7a:47:5a LE 1M LE LL 28 1979\302\265s 0 ADV_IND 5273 10.395 69:a9:48:2f:b7:16 LE 1M LE LL 37 1611\302\265s 0 ADV_NONCONN_IND 5274 10.396 69:a9:68:2f:b7:06 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5275 10.405 c6:f1:43:db:37:1d LE 1M LE LL 36 9037\302\265s 0 ADV_IND[Malformed Packet] 5276 10.406 32:43:3c:28:8d:92 LE 1M LE LL 37 1077\302\265s 0 ADV_NONCONN_IND 5277 10.407 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5278 10.412 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4341\302\265s 0 ADV_NONCONN_IND 5279 10.412 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5280 10.413 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5281 10.428 1e:28:49:84:c5:cd LE 1M LE LL 37 14818\302\265s 0 ADV_NONCONN_IND 5282 10.428 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5283 10.429 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5284 10.452 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 22721\302\265s 0 ADV_IND 5285 10.456 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3875\302\265s 0 ADV_NONCONN_IND 5286 10.457 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5287 10.458 3a:d1:ca:1d:4d:de LE 1M LE LL 26 834\302\265s 0 ADV_NONCONN_IND 5288 10.459 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5289 10.46 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5290 10.464 74:d9:0b:7a:47:5a LE 1M LE LL 28 3891\302\265s 0 ADV_IND 5291 10.466 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1399\302\265s 0 ADV_NONCONN_IND 5292 10.466 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5293 10.467 31:ea:1b:25:0d:1f LE 1M LE LL 37 876\302\265s 0 ADV_NONCONN_IND 5294 10.468 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5295 10.469 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5296 10.472 07:69:22:f0:72:30 LE 1M LE LL 37 2731\302\265s 0 ADV_NONCONN_IND 5297 10.472 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 5298 10.473 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5299 10.479 cd:45:0c:ce:f1:94 LE 1M LE LL 37 5936\302\265s 0 ADV_IND 5300 10.484 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4508\302\265s 0 ADV_NONCONN_IND 5301 10.484 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5302 10.488 11:fe:ef:ed:38:82 LE 1M LE LL 37 3498\302\265s 0 ADV_NONCONN_IND 5303 10.489 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5304 10.489 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5305 10.493 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2731\302\265s 0 ADV_NONCONN_IND 5306 10.493 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5307 10.494 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5308 10.495 27:f1:d5:6a:d5:82 LE 1M LE LL 37 971\302\265s 0 ADV_NONCONN_IND 5309 10.496 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5310 10.497 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5311 10.51 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 12694\302\265s 0 ADV_IND[Malformed Packet] 5312 10.51 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 5313 10.512 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 5314 10.515 32:43:3c:28:8d:92 LE 1M LE LL 37 3325\302\265s 0 ADV_NONCONN_IND 5315 10.516 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5316 10.516 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5317 10.519 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2465\302\265s 0 ADV_NONCONN_IND 5318 10.52 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5319 10.52 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5320 10.528 1e:28:49:84:c5:cd LE 1M LE LL 37 7316\302\265s 0 ADV_NONCONN_IND 5321 10.528 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5322 10.529 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5323 10.537 74:d9:0b:7a:47:5a LE 1M LE LL 28 7997\302\265s 0 ADV_IND 5324 10.541 0d:62:2c:2a:24:88 LE 1M LE LL 37 2875\302\265s 0 ADV_NONCONN_IND 5325 10.541 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5326 10.547 c0:41:04:2e:be:9d LE 1M LE LL 36 5669\302\265s 0 ADV_IND 5327 10.549 d6:2c:05:d0:15:49 LE 1M LE LL 37 1414\302\265s 0 ADV_IND 5328 10.556 5e:93:36:dd:d3:09 LE 1M LE LL 10 6454\302\265s 0 ADV_SCAN_IND 5329 10.565 0c:6e:66:d7:ed:03 LE 1M LE LL 37 8923\302\265s 0 ADV_NONCONN_IND 5330 10.566 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5331 10.566 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5332 10.57 31:ea:1b:25:0d:1f LE 1M LE LL 37 3377\302\265s 0 ADV_NONCONN_IND 5333 10.57 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5334 10.571 3c:d9:1b:1c:47:4a LE 1M LE LL 28 107\302\265s 0 ADV_IND[Malformed Packet] 5335 10.572 74:d9:0b:7a:47:5a LE 1M LE LL 28 513\302\265s 0 ADV_IND 5336 10.575 07:69:22:f0:72:30 LE 1M LE LL 37 2623\302\265s 0 ADV_NONCONN_IND 5337 10.575 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5338 10.588 16:ed:93:0f:fa:b0 LE 1M LE LL 37 12128\302\265s 0 ADV_NONCONN_IND 5339 10.588 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5340 10.589 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5341 10.591 11:fe:ef:ed:38:82 LE 1M LE LL 37 1624\302\265s 0 ADV_NONCONN_IND 5342 10.591 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5343 10.592 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5344 10.594 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2104\302\265s 0 ADV_NONCONN_IND 5345 10.595 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5346 10.596 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5347 10.603 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7298\302\265s 0 ADV_NONCONN_IND 5348 10.604 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5349 10.606 74:d9:0b:7a:47:5a LE 1M LE LL 28 2191\302\265s 0 ADV_IND 5350 10.607 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5351 10.607 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5352 10.615 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 8167\302\265s 0 ADV_NONCONN_IND 5353 10.616 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5354 10.618 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1611\302\265s 0 ADV_IND 5355 10.625 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6729\302\265s 0 ADV_NONCONN_IND 5356 10.625 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5357 10.626 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5358 10.631 d6:bf:76:0a:0b:dc LE 1M LE LL 36 4562\302\265s 0 ADV_IND 5359 10.632 1e:28:49:84:c5:cd LE 1M LE LL 37 510\302\265s 0 ADV_NONCONN_IND 5360 10.632 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5361 10.633 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5362 10.633 c2:f4:e6:80:5e:ae LE 1M LE LL 36 210\302\265s 0 ADV_IND 5363 10.634 c2:f4:e6:80:5e:ae LE 1M LE LL 36 741\302\265s 0 ADV_IND 5364 10.642 SamsungE_07:d5:79 LE 1M LE LL 34 7345\302\265s 0 ADV_NONCONN_IND 5365 10.645 74:d9:0b:7a:47:5a LE 1M LE LL 28 2033\302\265s 0 ADV_IND 5366 10.645 50:d9:aa:01:10:f7 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5367 10.648 d6:bf:03:c5:20:42 LE 1M LE LL 36 2739\302\265s 0 ADV_IND 5368 10.649 0d:62:2c:2a:24:88 LE 1M LE LL 37 333\302\265s 0 ADV_NONCONN_IND 5369 10.657 50:d3:b9:81:11:84 LE 1M LE LL 12 7685\302\265s 0 SCAN_REQ 5370 10.658 7f:e1:7b:e4:24:1c LE 1M LE LL 12 833\302\265s 0 SCAN_REQ 5371 10.66 e5:ea:46:16:3e:1e LE 1M LE LL 36 2242\302\265s 0 ADV_IND 5372 10.662 cc:15:14:59:64:aa LE 1M LE LL 36 1798\302\265s 0 ADV_IND 5373 10.663 50:d1:a9:01:11:86 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 5374 10.663 cc:15:14:59:64:aa LE 1M LE LL 36 413\302\265s 0 ADV_IND 5375 10.669 SamsungE_07:d8:8f LE 1M LE LL 34 5534\302\265s 0 ADV_NONCONN_IND 5376 10.67 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 534\302\265s 0 ADV_NONCONN_IND 5377 10.671 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5378 10.671 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5379 10.673 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1452\302\265s 0 ADV_NONCONN_IND 5380 10.674 3a:d1:ca:1d:4d:de LE 1M LE LL 26 735\302\265s 0 ADV_NONCONN_IND 5381 10.675 31:ea:1b:25:0d:1f LE 1M LE LL 37 298\302\265s 0 ADV_NONCONN_IND 5382 10.68 74:d9:0b:7a:47:5a LE 1M LE LL 28 4759\302\265s 0 ADV_IND 5383 10.684 07:69:22:f0:72:30 LE 1M LE LL 37 3861\302\265s 0 ADV_NONCONN_IND 5384 10.685 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5385 10.692 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6501\302\265s 0 ADV_NONCONN_IND 5386 10.692 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5387 10.693 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5388 10.697 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3959\302\265s 0 ADV_NONCONN_IND 5389 10.698 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5390 10.698 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5391 10.699 NICE_11:f6:07 LE 1M LE LL 36 797\302\265s 0 AUX_CONNECT_RSP[Malformed Packet] 5392 10.701 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1265\302\265s 0 ADV_NONCONN_IND 5393 10.702 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5394 10.702 d5:80:ce:3a:df:84 LE 1M LE LL 6 342\302\265s 0 SCAN_RSP 5395 10.703 d5:80:ce:3a:df:84 LE 1M LE LL 36 135\302\265s 0 ADV_IND 5396 10.708 5c:9e:d4:03:82:5b LE 1M LE LL 37 4971\302\265s 0 ADV_NONCONN_IND 5397 10.708 7f:f8:94:bb:b9:a8 LE 1M LE LL 25 80\302\265s 0 ADV_IND[Malformed Packet] 5398 10.71 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1150\302\265s 0 SCAN_REQ 5399 10.712 71:c4:79:42:57:d8 LE 1M LE LL 21 2177\302\265s 0 ADV_IND 5400 10.716 70:d8:89:01:11:c7 LE 1M LE LL 12 3315\302\265s 0 SCAN_REQ 5401 10.716 d6:11:16:57:f1:d4 LE 1M LE LL 36 163\302\265s 0 ADV_IND[Malformed Packet] 5402 10.717 d6:11:16:57:f1:d0 LE 1M LE LL 36 355\302\265s 0 ADV_IND 5403 10.72 43:bd:56:bd:74:f9 LE 1M LE LL 37 2258\302\265s 0 ADV_NONCONN_IND 5404 10.72 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5405 10.721 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5406 10.723 32:43:3c:28:8d:92 LE 1M LE LL 37 1805\302\265s 0 ADV_NONCONN_IND 5407 10.724 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5408 10.724 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5409 10.734 2b:5e:0e:c8:62:4c LE 1M LE LL 35 8712\302\265s 0 ADV_NONCONN_IND 5410 10.734 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5411 10.735 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5412 10.749 2e:86:8d:c9:47:1d LE 1M LE LL 21 14020\302\265s 0 ADV_NONCONN_IND 5413 10.751 0d:62:2c:2a:24:88 LE 1M LE LL 37 1345\302\265s 0 ADV_NONCONN_IND 5414 10.751 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5415 10.753 74:d9:0b:7a:47:5a LE 1M LE LL 28 1182\302\265s 0 ADV_IND 5416 10.753 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5417 10.774 0c:6e:66:d7:ed:03 LE 1M LE LL 37 20917\302\265s 0 ADV_NONCONN_IND 5418 10.775 0c:6e:66:d7:ed:03 LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 5419 10.777 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1630\302\265s 0 ADV_NONCONN_IND 5420 10.778 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5421 10.778 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5422 10.78 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 910\302\265s 0 ADV_NONCONN_IND 5423 10.78 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5424 10.781 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5425 10.781 50:d3:b9:81:11:84 LE 1M LE LL 12 317\302\265s 0 SCAN_REQ 5426 10.782 c2:f4:8b:c2:ec:01 LE 1M LE LL 36 414\302\265s 0 ADV_IND 5427 10.783 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 354\302\265s 0 ADV_IND 5428 10.784 07:69:22:f0:72:30 LE 1M LE LL 37 1050\302\265s 0 ADV_NONCONN_IND 5429 10.785 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 5430 10.785 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5431 10.787 c4:23:b5:60:6c:09 LE 1M LE LL 14 1787\302\265s 0 ADV_NONCONN_IND 5432 10.79 74:d9:0b:7a:47:5a LE 1M LE LL 28 2104\302\265s 0 ADV_IND 5433 10.795 SamsungE_07:d5:79 LE 1M LE LL 34 4685\302\265s 0 ADV_NONCONN_IND 5434 10.796 16:ed:93:0f:fa:b0 LE 1M LE LL 37 835\302\265s 0 ADV_NONCONN_IND 5435 10.796 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5436 10.797 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5437 10.803 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5207\302\265s 0 ADV_NONCONN_IND 5438 10.803 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5439 10.804 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5440 10.806 50:d3:b9:81:11:84 LE 1M LE LL 12 2280\302\265s 0 SCAN_REQ 5441 10.809 43:bd:56:bd:74:f9 LE 1M LE LL 37 2569\302\265s 0 ADV_NONCONN_IND 5442 10.81 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5443 10.814 08:ec:5e:66:cd:0d LE 1M LE LL 23 3582\302\265s 0 ADV_NONCONN_IND 5444 10.814 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5445 10.815 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5446 10.816 5c:9e:d4:03:82:5b LE 1M LE LL 37 585\302\265s 0 ADV_NONCONN_IND 5447 10.816 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5448 10.817 d7:6a:43:d4:0a:1a LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5449 10.818 e5:ea:46:16:3e:1e LE 1M LE LL 36 755\302\265s 0 ADV_IND 5450 10.818 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5451 10.819 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5452 10.819 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 5453 10.822 4e:14:1a:db:9e:19 LE 1M LE LL 12 3010\302\265s 0 ADV_IND 5454 10.83 74:d9:0b:7a:47:5a LE 1M LE LL 28 7223\302\265s 0 ADV_IND 5455 10.834 de:73:66:57:96:e4 LE 1M LE LL 14 3885\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5456 10.843 1e:28:49:84:c5:cd LE 1M LE LL 37 8621\302\265s 0 ADV_NONCONN_IND 5457 10.843 c1:c8:16:ae:fd:1d LE 1M LE LL 36 157\302\265s 0 ADV_IND 5458 10.844 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5459 10.844 c1:c8:16:ae:fd:1d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5460 10.844 c1:c8:16:ae:fd:1d LE 1M LE LL 36 136\302\265s 0 ADV_IND 5461 10.845 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5462 10.845 c1:c8:16:ae:fd:1d LE 1M LE LL 36 163\302\265s 0 ADV_IND 5463 10.846 dd:b9:3b:45:59:8b LE 1M LE LL 24 190\302\265s 0 ADV_IND 5464 10.846 7f:ab:0f:33:5d:32 LE 1M LE LL 12 320\302\265s 0 SCAN_REQ 5465 10.847 c4:d3:3f:79:a7:16 LE 1M LE LL 36 414\302\265s 0 ADV_IND 5466 10.848 c0:4e:43:7b:5f:2b LE 1M LE LL 14 320\302\265s 0 ADV_IND 5467 10.853 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 5309\302\265s 0 ADV_IND 5468 10.855 7f:ab:0f:33:5d:32 LE 1M LE LL 12 980\302\265s 0 SCAN_REQ 5469 10.858 0d:62:2c:2a:24:88 LE 1M LE LL 37 3361\302\265s 0 ADV_NONCONN_IND 5470 10.859 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5471 10.86 be:1a:9f:1b:5e:c2 LE 1M LE LL 250 1402\302\265s 0 SCAN_REQ 5472 10.863 74:d9:0b:7a:47:5a LE 1M LE LL 28 400\302\265s 0 ADV_IND 5473 10.863 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5474 10.864 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5475 10.864 74:d9:0b:7a:47:5a LE 1M LE LL 28 272\302\265s 0 ADV_IND 5476 10.865 7f:ab:0f:33:5d:32 LE 1M LE LL 12 968\302\265s 0 SCAN_REQ 5477 10.879 0c:6e:66:d7:ed:03 LE 1M LE LL 37 13716\302\265s 0 ADV_NONCONN_IND 5478 10.88 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5479 10.884 31:ea:1b:25:0d:1f LE 1M LE LL 37 3381\302\265s 0 ADV_NONCONN_IND 5480 10.884 31:ea:1b:25:0d:1f LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5481 10.885 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5482 10.886 c0:41:04:2e:be:9d LE 1M LE LL 36 810\302\265s 0 ADV_IND 5483 10.886 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5484 10.887 c0:41:04:2e:be:9d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5485 10.891 ef:6e:3d:68:42:19 LE 1M LE LL 36 4262\302\265s 0 ADV_IND 5486 10.892 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5487 10.892 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5488 10.892 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 5489 10.893 07:69:22:f0:72:30 LE 1M LE LL 37 835\302\265s 0 ADV_NONCONN_IND 5490 10.894 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 5491 10.895 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5492 10.899 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4393\302\265s 0 ADV_NONCONN_IND 5493 10.9 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5494 10.901 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5495 10.905 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3464\302\265s 0 ADV_NONCONN_IND 5496 10.905 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5497 10.906 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5498 10.907 74:d9:0b:7a:47:5a LE 1M LE LL 28 1066\302\265s 0 ADV_IND 5499 10.908 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5500 10.908 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5501 10.911 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3160\302\265s 0 ADV_NONCONN_IND 5502 10.912 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5503 10.917 7f:ab:0f:33:5d:32 LE 1M LE LL 12 4399\302\265s 0 SCAN_REQ 5504 10.92 79:70:d9:25:16:e2 LE 1M LE LL 25 3208\302\265s 0 ADV_IND 5505 10.922 61:9c:87:78:87:2b LE 1M LE LL 23 1271\302\265s 0 ADV_IND 5506 10.924 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2704\302\265s 0 ADV_NONCONN_IND 5507 10.925 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5508 10.926 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5509 10.926 45:9b:f4:8b:97:f9 LE 1M LE LL 24 219\302\265s 0 ADV_IND[Malformed Packet] 5510 10.927 45:9b:f4:8b:97:f9 LE 1M LE LL 24 736\302\265s 0 ADV_IND 5511 10.928 45:9b:f4:8b:97:f9 LE 1M LE LL 24 639\302\265s 0 ADV_IND 5512 10.935 32:43:3c:28:8d:92 LE 1M LE LL 37 6846\302\265s 0 ADV_NONCONN_IND 5513 10.936 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5514 10.936 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5515 10.937 7f:ab:0f:33:5d:32 LE 1M LE LL 12 208\302\265s 0 SCAN_REQ 5516 10.937 eb:db:35:2e:09:1b LE 1M LE LL 20 301\302\265s 0 ADV_IND 5517 10.94 2e:86:8d:c9:47:bd LE 1M LE LL 21 2183\302\265s 0 ADV_NONCONN_IND 5518 10.942 7f:ab:0f:33:5d:32 LE 1M LE LL 12 1469\302\265s 0 SCAN_REQ 5519 10.943 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1122\302\265s 0 ADV_NONCONN_IND 5520 10.943 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5521 10.945 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 864\302\265s 0 ADV_IND 5522 10.945 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5523 10.945 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5524 10.949 f1:ff:a7:1a:55:8d LE 1M LE LL 36 3167\302\265s 0 ADV_IND 5525 10.95 1e:28:49:84:c5:cd LE 1M LE LL 37 1179\302\265s 0 ADV_NONCONN_IND 5526 10.96 7f:ab:0f:33:5d:32 LE 1M LE LL 12 9428\302\265s 0 SCAN_REQ 5527 10.965 0d:62:2c:2a:24:88 LE 1M LE LL 37 4708\302\265s 0 ADV_NONCONN_IND 5528 10.966 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5529 10.967 d6:bf:76:0a:0b:dc LE 1M LE LL 36 1076\302\265s 0 ADV_IND 5530 10.968 c2:f4:e6:80:5e:ae LE 1M LE LL 36 491\302\265s 0 ADV_IND 5531 10.976 74:d9:0b:7a:47:5a LE 1M LE LL 28 8194\302\265s 0 ADV_IND 5532 10.978 e5:ea:46:16:3e:1e LE 1M LE LL 36 1169\302\265s 0 ADV_IND 5533 10.983 d6:bf:03:c5:20:42 LE 1M LE LL 36 4692\302\265s 0 ADV_IND 5534 10.986 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2202\302\265s 0 ADV_NONCONN_IND 5535 10.987 31:ea:1b:25:0d:1f LE 1M LE LL 37 1508\302\265s 0 ADV_NONCONN_IND 5536 10.988 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5537 10.989 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5538 10.991 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1762\302\265s 0 ADV_NONCONN_IND 5539 10.991 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5540 10.992 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5541 11 07:69:22:f0:72:30 LE 1M LE LL 37 7943\302\265s 0 ADV_NONCONN_IND 5542 11.001 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 5543 11.001 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5544 11.008 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5900\302\265s 0 ADV_NONCONN_IND 5545 11.008 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5546 11.009 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5547 11.011 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2028\302\265s 0 ADV_NONCONN_IND 5548 11.012 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5549 11.013 cf:4f:81:f5:7d:55 LE 1M LE LL 36 320\302\265s 0 ADV_IND[Malformed Packet] 5550 11.015 74:d9:0b:7a:47:5a LE 1M LE LL 28 1517\302\265s 0 ADV_IND 5551 11.017 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1889\302\265s 0 ADV_NONCONN_IND 5552 11.017 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5553 11.024 5c:9e:d4:03:82:5b LE 1M LE LL 37 6457\302\265s 0 ADV_NONCONN_IND 5554 11.025 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5555 11.026 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5556 11.03 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4212\302\265s 0 ADV_NONCONN_IND 5557 11.031 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5558 11.031 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5559 11.037 d5:80:ce:3a:df:84 LE 1M LE LL 36 4924\302\265s 0 ADV_IND 5560 11.038 32:43:3c:28:8d:92 LE 1M LE LL 37 1396\302\265s 0 ADV_NONCONN_IND 5561 11.039 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5562 11.049 74:d9:0b:7a:47:5a LE 1M LE LL 28 9923\302\265s 0 ADV_IND 5563 11.051 d6:2c:05:d0:15:49 LE 1M LE LL 37 2038\302\265s 0 ADV_IND 5564 11.052 2b:5e:0e:c8:62:4c LE 1M LE LL 35 355\302\265s 0 ADV_NONCONN_IND 5565 11.053 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5566 11.057 7d:30:e4:59:cd:06 LE 1M LE LL 25 3806\302\265s 0 ADV_IND 5567 11.072 0d:62:2c:2a:24:88 LE 1M LE LL 37 15282\302\265s 0 ADV_NONCONN_IND 5568 11.073 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5569 11.086 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 13050\302\265s 0 ADV_NONCONN_IND 5570 11.087 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5571 11.088 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5572 11.092 31:ea:1b:25:0d:1f LE 1M LE LL 37 3818\302\265s 0 ADV_NONCONN_IND 5573 11.092 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5574 11.093 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5575 11.102 07:69:22:f0:72:30 LE 1M LE LL 37 8352\302\265s 0 ADV_NONCONN_IND 5576 11.102 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 5577 11.103 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5578 11.111 16:ed:93:0f:fa:b0 LE 1M LE LL 37 7779\302\265s 0 ADV_NONCONN_IND 5579 11.111 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5580 11.112 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5581 11.12 74:d9:0b:7a:47:5a LE 1M LE LL 28 7437\302\265s 0 ADV_IND 5582 11.121 27:f1:d5:6a:d5:82 LE 1M LE LL 37 737\302\265s 0 ADV_NONCONN_IND 5583 11.122 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5584 11.131 24:c3:d0:ce:d4:37 LE 1M LE LL 37 9304\302\265s 0 ADV_NONCONN_IND 5585 11.132 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5586 11.132 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5587 11.14 1c:8f:d4:12:82:4b LE 1M LE LL 37 7314\302\265s 0 ADV_NONCONN_IND 5588 11.141 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5589 11.141 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5590 11.144 e5:ea:46:16:3e:1e LE 1M LE LL 36 2310\302\265s 0 ADV_IND 5591 11.145 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5592 11.145 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5593 11.145 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 5594 11.155 74:d9:0b:7a:47:5a LE 1M LE LL 28 9471\302\265s 0 ADV_IND 5595 11.158 ed:4e:4a:f5:08:6e LE 1M LE LL 14 3098\302\265s 0 ADV_NONCONN_IND 5596 11.159 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 5597 11.163 1e:28:49:84:c5:cd LE 1M LE LL 37 3819\302\265s 0 ADV_NONCONN_IND 5598 11.176 c1:c8:16:ae:fd:1d LE 1M LE LL 36 12665\302\265s 0 ADV_IND 5599 11.176 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5600 11.177 c1:c8:16:ae:fd:1d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5601 11.177 c1:c8:16:ae:fd:1d LE 1M LE LL 36 136\302\265s 0 ADV_IND 5602 11.182 30:16:5f:79:a7:16 LE 1M LE LL 36 5011\302\265s 0 ADV_IND[Malformed Packet] 5603 11.183 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 803\302\265s 0 ADV_IND 5604 11.184 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 5605 11.184 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5606 11.185 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 136\302\265s 0 ADV_IND 5607 11.188 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2614\302\265s 0 ADV_NONCONN_IND 5608 11.192 64:0d:49:f9:4d:a4 LE 1M LE LL 12 4198\302\265s 0 SCAN_REQ 5609 11.193 c5:65:68:79:19:c8 LE 1M LE LL 36 415\302\265s 0 ADV_IND 5610 11.194 31:ea:1b:25:0d:1f LE 1M LE LL 37 466\302\265s 0 ADV_NONCONN_IND 5611 11.194 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5612 11.195 0c:6e:66:d7:ed:03 LE 1M LE LL 37 374\302\265s 0 ADV_NONCONN_IND 5613 11.196 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5614 11.196 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5615 11.198 64:0d:49:f9:4d:a4 LE 1M LE LL 12 1184\302\265s 0 SCAN_REQ 5616 11.201 40:f0:08:9b:56:91 LE 1M LE LL 37 3518\302\265s 0 ADV_SCAN_IND 5617 11.208 11:fe:ef:ed:38:82 LE 1M LE LL 37 5833\302\265s 0 ADV_NONCONN_IND 5618 11.214 64:0d:49:f9:4d:a4 LE 1M LE LL 12 5970\302\265s 0 SCAN_REQ 5619 11.215 16:ed:93:0f:fa:b0 LE 1M LE LL 37 451\302\265s 0 ADV_NONCONN_IND 5620 11.215 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5621 11.217 43:bd:56:bd:74:f9 LE 1M LE LL 37 1556\302\265s 0 ADV_NONCONN_IND 5622 11.223 69:a9:48:2f:b7:16 LE 1M LE LL 37 5995\302\265s 0 ADV_NONCONN_IND 5623 11.227 ef:6e:3d:68:42:19 LE 1M LE LL 36 3039\302\265s 0 ADV_IND 5624 11.229 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2241\302\265s 0 ADV_NONCONN_IND 5625 11.23 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5626 11.231 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5627 11.231 74:d9:0b:7a:47:5a LE 1M LE LL 6 265\302\265s 0 SCAN_RSP 5628 11.237 e7:70:80:c3:ad:91 LE 1M LE LL 36 5275\302\265s 0 ADV_IND 5629 11.237 e7:70:80:c3:ad:91 LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 5630 11.239 cf:c8:cc:72:d8:be LE 1M LE LL 14 937\302\265s 0 ADV_NONCONN_IND 5631 11.242 32:43:3c:28:8d:92 LE 1M LE LL 37 3211\302\265s 0 ADV_NONCONN_IND 5632 11.243 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5633 11.245 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 2507\302\265s 0 ADV_NONCONN_IND 5634 11.246 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5635 11.246 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 5636 11.253 71:c4:79:42:57:d8 LE 1M LE LL 21 6386\302\265s 0 ADV_IND 5637 11.253 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5638 11.254 71:a4:79:42:57:d8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5639 11.264 SamsungE_07:d5:79 LE 1M LE LL 34 9969\302\265s 0 ADV_NONCONN_IND 5640 11.265 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 5641 11.268 74:d9:0b:7a:47:5a LE 1M LE LL 28 2976\302\265s 0 ADV_IND 5642 11.271 1e:28:49:84:c5:cd LE 1M LE LL 37 2675\302\265s 0 ADV_NONCONN_IND 5643 11.272 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5644 11.272 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 167\302\265s 0 ADV_IND 5645 11.282 0d:62:2c:2a:24:88 LE 1M LE LL 37 10030\302\265s 0 ADV_NONCONN_IND 5646 11.283 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5647 11.286 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2953\302\265s 0 ADV_IND 5648 11.291 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4041\302\265s 0 ADV_NONCONN_IND 5649 11.291 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5650 11.298 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6451\302\265s 0 ADV_NONCONN_IND 5651 11.299 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5652 11.3 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5653 11.302 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2451\302\265s 0 ADV_NONCONN_IND 5654 11.303 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5655 11.304 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5656 11.306 d6:bf:76:0a:0b:dc LE 1M LE LL 36 1662\302\265s 0 ADV_IND 5657 11.309 e5:ea:46:16:3e:1e LE 1M LE LL 36 2511\302\265s 0 ADV_IND 5658 11.31 7f:e1:7b:e4:24:1c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 5659 11.317 43:bd:56:bd:74:f9 LE 1M LE LL 37 7092\302\265s 0 ADV_NONCONN_IND 5660 11.318 d6:bf:03:c5:20:42 LE 1M LE LL 36 491\302\265s 0 ADV_IND 5661 11.323 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4335\302\265s 0 ADV_NONCONN_IND 5662 11.331 7d:30:e4:59:cd:06 LE 1M LE LL 25 7725\302\265s 0 ADV_IND 5663 11.331 27:f1:d5:6a:d5:82 LE 1M LE LL 37 259\302\265s 0 ADV_NONCONN_IND 5664 11.332 50:d3:b9:81:11:84 LE 1M LE LL 12 162\302\265s 0 SCAN_REQ 5665 11.332 7d:30:e4:59:cd:06 LE 1M LE LL 25 411\302\265s 0 ADV_IND 5666 11.335 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2404\302\265s 0 ADV_NONCONN_IND 5667 11.336 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5668 11.336 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5669 11.342 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5424\302\265s 0 ADV_NONCONN_IND 5670 11.343 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5671 11.343 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5672 11.346 5c:9e:d4:03:82:5b LE 1M LE LL 37 2049\302\265s 0 ADV_NONCONN_IND 5673 11.346 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5674 11.347 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5675 11.366 2b:5e:0e:c8:62:4c LE 1M LE LL 35 18901\302\265s 0 ADV_NONCONN_IND 5676 11.367 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5677 11.367 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5678 11.372 cd:5c:f3:7d:98:0b LE 1M LE LL 36 4423\302\265s 0 ADV_IND 5679 11.373 50:d3:b9:81:11:84 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 5680 11.374 cd:5c:f3:7d:98:0b LE 1M LE LL 36 416\302\265s 0 ADV_IND 5681 11.378 d5:80:ce:3a:df:84 LE 1M LE LL 36 3612\302\265s 0 ADV_IND 5682 11.379 50:d3:b9:81:11:84 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 5683 11.38 d5:80:ce:3a:df:84 LE 1M LE LL 36 414\302\265s 0 ADV_IND 5684 11.388 ec:af:39:d1:f5:fe LE 1M LE LL 14 8044\302\265s 0 ADV_NONCONN_IND 5685 11.389 0d:62:2c:2a:24:88 LE 1M LE LL 37 574\302\265s 0 ADV_NONCONN_IND 5686 11.389 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5687 11.4 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 9927\302\265s 0 ADV_NONCONN_IND 5688 11.4 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5689 11.401 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5690 11.404 40:f0:08:9b:56:91 LE 1M LE LL 37 3376\302\265s 0 ADV_SCAN_IND 5691 11.406 0c:6e:66:d7:ed:03 LE 1M LE LL 37 673\302\265s 0 ADV_NONCONN_IND 5692 11.406 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5693 11.407 3a:d1:ca:1d:4d:de LE 1M LE LL 26 399\302\265s 0 ADV_NONCONN_IND 5694 11.408 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5695 11.408 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5696 11.417 07:69:22:f0:72:30 LE 1M LE LL 37 8553\302\265s 0 ADV_NONCONN_IND 5697 11.418 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5698 11.418 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5699 11.433 27:f1:d5:6a:d5:82 LE 1M LE LL 37 13783\302\265s 0 ADV_NONCONN_IND 5700 11.433 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5701 11.434 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5702 11.441 08:ec:5e:66:cd:0d LE 1M LE LL 23 6864\302\265s 0 ADV_NONCONN_IND 5703 11.442 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5704 11.442 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5705 11.446 SamsungE_07:d8:af LE 1M LE LL 34 3683\302\265s 0 ADV_NONCONN_IND 5706 11.448 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1030\302\265s 0 ADV_NONCONN_IND 5707 11.448 2a:4d:c1:5f:8a:0b LE 1M LE LL 99 117\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5708 11.45 32:43:3c:28:8d:92 LE 1M LE LL 37 1330\302\265s 0 ADV_NONCONN_IND 5709 11.451 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5710 11.451 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5711 11.454 17:5f:43:7c:0a:89 LE 1M LE LL 23 1890\302\265s 0 ADV_NONCONN_IND 5712 11.456 71:c9:89:02:1c:fb LE 1M LE LL 12 2433\302\265s 0 SCAN_REQ 5713 11.47 2b:5e:0e:c8:62:4c LE 1M LE LL 35 13769\302\265s 0 ADV_NONCONN_IND 5714 11.474 e5:ea:46:16:3e:1e LE 1M LE LL 36 3440\302\265s 0 ADV_IND 5715 11.477 50:d3:b9:81:11:84 LE 1M LE LL 12 2105\302\265s 0 SCAN_REQ 5716 11.481 1e:28:49:84:c5:cd LE 1M LE LL 37 4210\302\265s 0 ADV_NONCONN_IND 5717 11.483 0b:f9:be:c7:0f:fb LE 1M LE LL 23 1757\302\265s 0 ADV_NONCONN_IND 5718 11.483 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5719 11.484 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5720 11.491 74:d9:0b:7a:47:5a LE 1M LE LL 28 6839\302\265s 0 ADV_IND 5721 11.493 0d:62:2c:2a:24:88 LE 1M LE LL 37 1864\302\265s 0 ADV_NONCONN_IND 5722 11.494 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5723 11.5 31:ea:1b:25:0d:1f LE 1M LE LL 37 5855\302\265s 0 ADV_NONCONN_IND 5724 11.5 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5725 11.501 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5726 11.507 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5707\302\265s 0 ADV_NONCONN_IND 5727 11.508 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5728 11.508 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5729 11.509 0c:6e:66:d7:ed:03 LE 1M LE LL 37 678\302\265s 0 ADV_NONCONN_IND 5730 11.51 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5731 11.511 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5732 11.512 c1:c8:16:ae:fd:1d LE 1M LE LL 36 1210\302\265s 0 ADV_IND 5733 11.513 50:d3:b9:81:11:84 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 5734 11.514 c1:c8:16:ae:fd:1d LE 1M LE LL 36 414\302\265s 0 ADV_IND 5735 11.52 07:69:22:f0:72:30 LE 1M LE LL 37 6070\302\265s 0 ADV_NONCONN_IND 5736 11.521 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 5737 11.522 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5738 11.522 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 5739 11.523 16:ed:93:0f:fa:b0 LE 1M LE LL 37 730\302\265s 0 ADV_NONCONN_IND 5740 11.524 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 106\302\265s 0 ADV_IND 5741 11.547 25:5f:bf:53:1f:d7 LE 1M LE LL 37 22778\302\265s 0 ADV_NONCONN_IND 5742 11.548 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5743 11.548 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5744 11.551 5c:9e:d4:03:82:5b LE 1M LE LL 37 2082\302\265s 0 ADV_NONCONN_IND 5745 11.551 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5746 11.552 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5747 11.557 d6:2c:05:d0:15:49 LE 1M LE LL 37 4833\302\265s 0 ADV_IND 5748 11.558 49:08:83:d3:3a:6c LE 1M LE LL 12 921\302\265s 0 SCAN_REQ 5749 11.559 d6:2c:05:d0:15:49 LE 1M LE LL 37 240\302\265s 0 ADV_IND 5750 11.562 c0:41:04:2e:be:9d LE 1M LE LL 36 3165\302\265s 0 ADV_IND 5751 11.563 7f:ab:0f:33:5d:32 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 5752 11.565 74:d9:0b:7a:47:5a LE 1M LE LL 28 1797\302\265s 0 ADV_IND 5753 11.571 e7:70:80:c3:ad:91 LE 1M LE LL 36 5111\302\265s 0 ADV_IND 5754 11.572 f7:c4:8e:ec:1e:ff LE 1M LE LL 172 872\302\265s 0 SCAN_REQ 5755 11.578 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4815\302\265s 0 ADV_NONCONN_IND 5756 11.584 1e:28:49:84:c5:cd LE 1M LE LL 37 5439\302\265s 0 ADV_NONCONN_IND 5757 11.585 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5758 11.585 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5759 11.588 5e:93:36:dd:d3:09 LE 1M LE LL 10 2649\302\265s 0 ADV_SCAN_IND 5760 11.589 49:08:83:d3:3a:6c LE 1M LE LL 12 764\302\265s 0 SCAN_REQ 5761 11.59 5e:93:36:dd:d3:09 LE 1M LE LL 10 980\302\265s 0 ADV_SCAN_IND 5762 11.597 SamsungE_07:d8:8f LE 1M LE LL 34 6851\302\265s 0 ADV_NONCONN_IND 5763 11.598 3a:b4:01:07:d8:8a LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 5764 11.6 0d:62:2c:2a:24:88 LE 1M LE LL 37 1223\302\265s 0 ADV_NONCONN_IND 5765 11.602 31:ea:1b:25:0d:1f LE 1M LE LL 37 1480\302\265s 0 ADV_NONCONN_IND 5766 11.602 31:ea:1b:25:0d:1f LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5767 11.603 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5768 11.608 7d:30:e4:59:cd:06 LE 1M LE LL 25 5033\302\265s 0 ADV_IND 5769 11.609 7f:ab:0f:33:5d:32 LE 1M LE LL 12 799\302\265s 0 SCAN_REQ 5770 11.611 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1784\302\265s 0 ADV_NONCONN_IND 5771 11.613 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1444\302\265s 0 ADV_NONCONN_IND 5772 11.614 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5773 11.615 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5774 11.62 07:69:22:f0:72:30 LE 1M LE LL 37 5432\302\265s 0 ADV_NONCONN_IND 5775 11.621 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 5776 11.622 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5777 11.623 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1531\302\265s 0 ADV_NONCONN_IND 5778 11.624 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5779 11.625 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5780 11.637 e5:ea:46:16:3e:1e LE 1M LE LL 36 11643\302\265s 0 ADV_IND 5781 11.64 43:bd:56:bd:74:f9 LE 1M LE LL 37 3497\302\265s 0 ADV_NONCONN_IND 5782 11.641 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5783 11.644 d6:bf:76:0a:0b:dc LE 1M LE LL 36 2754\302\265s 0 ADV_IND 5784 11.645 c2:f4:e6:80:5e:ae LE 1M LE LL 36 595\302\265s 0 ADV_IND 5785 11.651 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5504\302\265s 0 ADV_NONCONN_IND 5786 11.653 32:43:3c:28:8d:92 LE 1M LE LL 37 1176\302\265s 0 ADV_NONCONN_IND 5787 11.653 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5788 11.654 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5789 11.657 5c:9e:d4:03:82:5b LE 1M LE LL 37 2548\302\265s 0 ADV_NONCONN_IND 5790 11.657 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5791 11.658 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5792 11.675 6c:c6:23:80:30:28 LE 1M LE LL 12 16793\302\265s 0 SCAN_REQ 5793 11.676 cc:15:14:59:64:aa LE 1M LE LL 36 413\302\265s 0 ADV_IND 5794 11.678 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2227\302\265s 0 ADV_NONCONN_IND 5795 11.688 cf:4f:81:f5:7d:55 LE 1M LE LL 36 8838\302\265s 0 ADV_IND 5796 11.688 cf:4f:81:f5:7d:55 LE 1M LE LL 36 353\302\265s 0 ADV_IND 5797 11.689 1e:28:49:84:c5:cd LE 1M LE LL 37 370\302\265s 0 ADV_NONCONN_IND 5798 11.706 0d:62:2c:2a:24:88 LE 1M LE LL 37 16262\302\265s 0 ADV_NONCONN_IND 5799 11.706 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5800 11.707 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5801 11.707 31:ea:1b:25:0d:1f LE 1M LE LL 37 232\302\265s 0 ADV_NONCONN_IND 5802 11.708 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5803 11.709 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5804 11.709 6c:c6:23:80:30:28 LE 1M LE LL 12 80\302\265s 0 SCAN_REQ 5805 11.711 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1989\302\265s 0 ADV_NONCONN_IND 5806 11.712 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5807 11.713 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1213\302\265s 0 ADV_NONCONN_IND 5808 11.714 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5809 11.714 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5810 11.715 d5:80:ce:3a:df:84 LE 1M LE LL 36 345\302\265s 0 ADV_IND 5811 11.716 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5812 11.716 d5:80:ce:3a:df:84 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 5813 11.716 d5:80:ce:3a:df:84 LE 1M LE LL 36 135\302\265s 0 ADV_IND 5814 11.721 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4235\302\265s 0 ADV_NONCONN_IND 5815 11.722 07:69:22:f0:72:30 LE 1M LE LL 37 1057\302\265s 0 ADV_NONCONN_IND 5816 11.723 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 5817 11.723 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5818 11.725 11:fe:ef:ed:38:82 LE 1M LE LL 37 872\302\265s 0 ADV_NONCONN_IND 5819 11.725 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5820 11.726 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5821 11.726 6c:c6:23:80:30:28 LE 1M LE LL 12 147\302\265s 0 SCAN_REQ 5822 11.732 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5651\302\265s 0 ADV_NONCONN_IND 5823 11.733 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5824 11.738 43:bd:56:bd:74:f9 LE 1M LE LL 37 5302\302\265s 0 ADV_NONCONN_IND 5825 11.739 43:bd:56:bd:74:f9 LE 1M LE LL 37 671\302\265s 0 ADV_NONCONN_IND 5826 11.74 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5827 11.742 79:70:d9:25:16:e2 LE 1M LE LL 25 1049\302\265s 0 ADV_IND 5828 11.742 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5829 11.742 79:70:d9:25:16:e2 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5830 11.743 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 5831 11.744 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1487\302\265s 0 ADV_NONCONN_IND 5832 11.749 6c:c6:23:80:30:28 LE 1M LE LL 12 4379\302\265s 0 SCAN_REQ 5833 11.756 24:c3:d0:ce:d4:37 LE 1M LE LL 37 6339\302\265s 0 ADV_NONCONN_IND 5834 11.756 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5835 11.757 6c:c6:23:80:30:28 LE 1M LE LL 12 382\302\265s 0 SCAN_REQ 5836 11.76 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2855\302\265s 0 ADV_NONCONN_IND 5837 11.761 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5838 11.762 32:43:3c:28:8d:92 LE 1M LE LL 37 1175\302\265s 0 ADV_NONCONN_IND 5839 11.763 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5840 11.763 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5841 11.772 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 8455\302\265s 0 ADV_IND 5842 11.773 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5843 11.773 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5844 11.773 Anonymous LE 1M LE LL 36 137\302\265s 0 AUX_CONNECT_RSP[Malformed Packet: length of contained item exceeds length of containing item] 5845 11.774 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 742\302\265s 0 ADV_IND 5846 11.779 74:d9:0b:7a:47:5a LE 1M LE LL 28 3859\302\265s 0 ADV_IND 5847 11.779 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5848 11.781 5c:9e:d4:03:82:5b LE 1M LE LL 37 1654\302\265s 0 ADV_NONCONN_IND 5849 11.781 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 5850 11.793 1e:28:49:84:c5:cd LE 1M LE LL 37 11137\302\265s 0 ADV_NONCONN_IND 5851 11.793 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5852 11.794 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5853 11.795 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 262\302\265s 0 ADV_IND 5854 11.796 64:0d:49:f9:4d:a4 LE 1M LE LL 12 789\302\265s 0 SCAN_REQ 5855 11.805 e5:ea:46:16:3e:1e LE 1M LE LL 36 8678\302\265s 0 ADV_IND 5856 11.811 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5546\302\265s 0 ADV_NONCONN_IND 5857 11.811 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 5858 11.812 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 5859 11.818 1c:2b:bf:5c:a9:52 LE 1M LE LL 37 5592\302\265s 0 ADV_NONCONN_IND 5860 11.818 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5861 11.819 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5862 11.821 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1441\302\265s 0 ADV_NONCONN_IND 5863 11.821 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5864 11.822 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5865 11.832 07:69:22:f0:72:30 LE 1M LE LL 37 9182\302\265s 0 ADV_NONCONN_IND 5866 11.832 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 5867 11.833 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5868 11.834 16:ed:93:0f:fa:b0 LE 1M LE LL 37 897\302\265s 0 ADV_NONCONN_IND 5869 11.835 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5870 11.835 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5871 11.847 43:bd:56:bd:74:f9 LE 1M LE LL 37 11539\302\265s 0 ADV_NONCONN_IND 5872 11.848 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 5873 11.849 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5874 11.85 dd:b9:3b:45:59:8b LE 1M LE LL 24 1135\302\265s 0 ADV_IND 5875 11.851 64:0d:49:f9:4d:a4 LE 1M LE LL 12 920\302\265s 0 SCAN_REQ 5876 11.852 dd:b9:3b:45:59:8b LE 1M LE LL 24 705\302\265s 0 ADV_IND 5877 11.856 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 3399\302\265s 0 ADV_IND 5878 11.857 64:0d:49:f9:4d:a4 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 5879 11.858 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 417\302\265s 0 ADV_IND 5880 11.862 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3820\302\265s 0 ADV_NONCONN_IND 5881 11.863 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5882 11.863 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5883 11.864 32:43:3c:28:8d:92 LE 1M LE LL 37 521\302\265s 0 ADV_NONCONN_IND 5884 11.865 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5885 11.865 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 5886 11.878 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 12538\302\265s 0 ADV_NONCONN_IND 5887 11.878 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5888 11.879 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5889 11.88 7d:30:e4:59:cd:06 LE 1M LE LL 25 531\302\265s 0 ADV_IND 5890 11.883 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3584\302\265s 0 ADV_NONCONN_IND 5891 11.884 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 5892 11.887 5c:9e:d4:03:82:5b LE 1M LE LL 37 2413\302\265s 0 ADV_NONCONN_IND 5893 11.888 64:0d:49:f9:4d:a4 LE 1M LE LL 12 444\302\265s 0 SCAN_REQ 5894 11.888 5c:9e:d4:03:82:5b LE 1M LE LL 37 258\302\265s 0 ADV_NONCONN_IND 5895 11.895 ef:6e:3d:68:42:19 LE 1M LE LL 36 6484\302\265s 0 ADV_IND 5896 11.895 1e:28:49:84:c5:cd LE 1M LE LL 37 165\302\265s 0 ADV_NONCONN_IND 5897 11.896 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5898 11.912 0c:6e:66:d7:ed:03 LE 1M LE LL 37 15395\302\265s 0 ADV_NONCONN_IND 5899 11.913 31:ea:1b:25:0d:1f LE 1M LE LL 37 893\302\265s 0 ADV_NONCONN_IND 5900 11.914 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5901 11.914 31:ea:1b:25:0e:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5902 11.919 7f:e1:7b:e4:24:5c LE 1M LE LL 12 4398\302\265s 0 SCAN_REQ 5903 11.921 0d:62:2c:2a:24:88 LE 1M LE LL 37 2151\302\265s 0 ADV_NONCONN_IND 5904 11.922 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5905 11.929 3a:d1:ca:1d:4d:de LE 1M LE LL 26 7229\302\265s 0 ADV_NONCONN_IND 5906 11.93 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5907 11.931 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5908 11.937 07:69:22:f0:72:30 LE 1M LE LL 37 5434\302\265s 0 ADV_NONCONN_IND 5909 11.937 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 5910 11.938 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5911 11.938 16:ed:93:0f:fa:b0 LE 1M LE LL 37 274\302\265s 0 ADV_NONCONN_IND 5912 11.939 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5913 11.94 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5914 11.943 eb:db:35:2e:09:1b LE 1M LE LL 20 3000\302\265s 0 ADV_IND 5915 11.945 69:a9:48:2f:b7:16 LE 1M LE LL 37 1530\302\265s 0 ADV_NONCONN_IND 5916 11.95 43:bd:56:bd:74:f9 LE 1M LE LL 37 4922\302\265s 0 ADV_NONCONN_IND 5917 11.954 LE 1M LE LL 5 3432\302\265s 0 Unknown 5918 11.955 27:f1:d5:6a:d5:82 LE 1M LE LL 37 712\302\265s 0 ADV_NONCONN_IND 5919 11.955 f1:ff:a7:1a:55:8d LE 1M LE LL 36 294\302\265s 0 ADV_IND[Malformed Packet] 5920 11.965 74:d9:0b:7a:47:5a LE 1M LE LL 28 9220\302\265s 0 ADV_IND 5921 11.966 40:f0:08:9b:56:91 LE 1M LE LL 37 948\302\265s 0 ADV_SCAN_IND 5922 11.969 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2243\302\265s 0 ADV_NONCONN_IND 5923 11.97 e5:ea:46:16:3e:1e LE 1M LE LL 36 1155\302\265s 0 ADV_IND 5924 11.971 25:5f:bf:53:1f:d7 LE 1M LE LL 37 641\302\265s 0 ADV_NONCONN_IND 5925 11.972 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5926 11.973 32:43:3c:28:8d:92 LE 1M LE LL 37 551\302\265s 0 ADV_NONCONN_IND 5927 11.973 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5928 11.974 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5929 11.982 c2:f4:e6:80:5e:ae LE 1M LE LL 36 7862\302\265s 0 ADV_IND 5930 11.983 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 5931 11.983 c2:f4:e6:80:5e:ae LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 5932 11.983 c2:f4:e6:80:5e:ae LE 1M LE LL 36 137\302\265s 0 ADV_IND 5933 11.984 72:10:b2:16:c9:46 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 5934 11.986 d6:bf:03:c5:20:42 LE 1M LE LL 36 1301\302\265s 0 ADV_IND 5935 11.987 d6:bf:03:c5:20:42 LE 1M LE LL 36 741\302\265s 0 ADV_IND 5936 11.988 d6:bf:03:c5:20:42 LE 1M LE LL 36 354\302\265s 0 ADV_IND 5937 11.996 1e:28:49:84:c5:cd LE 1M LE LL 37 7935\302\265s 0 ADV_NONCONN_IND 5938 11.997 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5939 11.997 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5940 12.009 7f:e1:7b:e4:24:1c LE 1M LE LL 12 11465\302\265s 0 SCAN_REQ 5941 12.014 cc:15:14:59:64:2a LE 1M LE LL 36 4924\302\265s 0 ADV_IND 5942 12.015 cc:15:14:59:64:aa LE 1M LE LL 36 352\302\265s 0 ADV_IND 5943 12.022 31:ea:1b:25:0d:1f LE 1M LE LL 37 7205\302\265s 0 ADV_NONCONN_IND 5944 12.023 31:e8:5f:5d:0c:47 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5945 12.024 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5946 12.025 cf:4f:81:f5:6d:55 LE 1M LE LL 36 1178\302\265s 0 ADV_IND 5947 12.026 cf:4f:81:f5:7d:55 LE 1M LE LL 36 740\302\265s 0 ADV_IND 5948 12.028 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1673\302\265s 0 ADV_NONCONN_IND 5949 12.037 3a:d1:ca:1d:4d:de LE 1M LE LL 26 8308\302\265s 0 ADV_NONCONN_IND 5950 12.038 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 5951 12.038 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 5952 12.04 74:d9:0b:7a:47:5a LE 1M LE LL 28 1247\302\265s 0 ADV_IND 5953 12.042 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1858\302\265s 0 ADV_NONCONN_IND 5954 12.043 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5955 12.044 1f:84:46:51:98:14 LE 1M LE LL 23 1153\302\265s 0 ADV_NONCONN_IND 5956 12.045 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5957 12.045 61:9c:87:78:87:2b LE 1M LE LL 23 500\302\265s 0 ADV_IND 5958 12.046 cd:5c:f3:7d:98:0b LE 1M LE LL 36 186\302\265s 0 ADV_IND 5959 12.051 d5:80:ce:3a:df:84 LE 1M LE LL 36 5229\302\265s 0 ADV_IND 5960 12.055 c6:f1:43:db:57:1d LE 1M LE LL 36 3602\302\265s 0 ADV_IND 5961 12.057 43:bd:56:bd:74:f9 LE 1M LE LL 37 1738\302\265s 0 ADV_NONCONN_IND 5962 12.058 d6:2c:05:d0:15:49 LE 1M LE LL 37 421\302\265s 0 ADV_IND 5963 12.062 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3466\302\265s 0 ADV_NONCONN_IND 5964 12.063 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 5965 12.065 08:ec:5e:66:cd:0d LE 1M LE LL 23 1944\302\265s 0 ADV_NONCONN_IND 5966 12.066 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5967 12.066 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5968 12.073 24:c3:d0:ce:d4:37 LE 1M LE LL 37 6941\302\265s 0 ADV_NONCONN_IND 5969 12.074 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5970 12.074 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5971 12.076 25:5f:bf:53:1f:d7 LE 1M LE LL 37 983\302\265s 0 ADV_NONCONN_IND 5972 12.076 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5973 12.077 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 5974 12.078 32:43:3c:28:8d:92 LE 1M LE LL 37 1176\302\265s 0 ADV_NONCONN_IND 5975 12.079 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5976 12.079 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5977 12.081 71:c4:79:42:57:d8 LE 1M LE LL 21 745\302\265s 0 ADV_IND 5978 12.093 2b:5e:0e:c8:62:4c LE 1M LE LL 35 12619\302\265s 0 ADV_NONCONN_IND 5979 12.094 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 5980 12.099 1e:28:49:84:c5:cd LE 1M LE LL 37 4186\302\265s 0 ADV_NONCONN_IND 5981 12.099 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5982 12.1 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5983 12.107 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 7007\302\265s 0 ADV_IND 5984 12.112 0b:f9:be:c7:0f:fb LE 1M LE LL 23 4834\302\265s 0 ADV_NONCONN_IND 5985 12.113 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 5986 12.114 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1345\302\265s 0 ADV_NONCONN_IND 5987 12.128 31:ea:1b:25:0d:1f LE 1M LE LL 37 13323\302\265s 0 ADV_NONCONN_IND 5988 12.129 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 5989 12.129 0d:62:2c:2a:24:88 LE 1M LE LL 37 550\302\265s 0 ADV_NONCONN_IND 5990 12.133 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3472\302\265s 0 ADV_NONCONN_IND 5991 12.134 ce:14:1a:db:9e:19 LE 1M LE LL 12 68\302\265s 0 ADV_IND[Malformed Packet] 5992 12.135 e5:ea:46:16:3e:1e LE 1M LE LL 36 1343\302\265s 0 ADV_IND 5993 12.14 11:fe:ef:ed:38:82 LE 1M LE LL 37 3936\302\265s 0 ADV_NONCONN_IND 5994 12.14 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 5995 12.143 07:69:22:f0:72:30 LE 1M LE LL 37 3000\302\265s 0 ADV_NONCONN_IND 5996 12.144 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 5997 12.145 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 5998 12.147 74:d9:0b:7a:47:5a LE 1M LE LL 28 1680\302\265s 0 ADV_IND 5999 12.147 16:ed:93:0f:fa:b0 LE 1M LE LL 37 196\302\265s 0 ADV_NONCONN_IND 6000 12.148 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6001 12.148 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6002 12.153 40:f0:08:9b:56:91 LE 1M LE LL 37 4508\302\265s 0 ADV_SCAN_IND 6003 12.155 69:a9:48:2f:b7:16 LE 1M LE LL 37 1126\302\265s 0 ADV_NONCONN_IND 6004 12.155 50:d3:b9:81:11:84 LE 1M LE LL 12 396\302\265s 0 SCAN_REQ 6005 12.157 43:bd:56:bd:74:f9 LE 1M LE LL 37 1428\302\265s 0 ADV_NONCONN_IND 6006 12.158 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6007 12.159 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6008 12.178 25:5f:bf:53:1f:d7 LE 1M LE LL 37 18516\302\265s 0 ADV_NONCONN_IND 6009 12.178 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6010 12.179 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6011 12.181 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1668\302\265s 0 ADV_NONCONN_IND 6012 12.181 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6013 12.182 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6014 12.187 74:d9:0b:7a:47:5a LE 1M LE LL 28 5105\302\265s 0 ADV_IND 6015 12.189 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 1551\302\265s 0 ADV_IND 6016 12.19 50:d3:b9:81:11:84 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6017 12.191 c1:c8:16:ae:fd:1d LE 1M LE LL 36 270\302\265s 0 ADV_IND 6018 12.193 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2234\302\265s 0 ADV_NONCONN_IND 6019 12.194 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6020 12.199 1e:28:49:84:c5:cd LE 1M LE LL 37 4809\302\265s 0 ADV_NONCONN_IND 6021 12.2 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6022 12.2 50:d3:a9:81:19:84 LE 1M LE LL 12 84\302\265s 0 SCAN_REQ 6023 12.205 c5:65:68:79:19:c8 LE 1M LE LL 36 4997\302\265s 0 ADV_IND 6024 12.219 0c:6e:66:d7:ed:03 LE 1M LE LL 37 12893\302\265s 0 ADV_NONCONN_IND 6025 12.219 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6026 12.222 74:d9:0b:7a:47:5a LE 1M LE LL 28 2269\302\265s 0 ADV_IND 6027 12.229 ef:6e:3d:68:42:19 LE 1M LE LL 36 7109\302\265s 0 ADV_IND 6028 12.231 50:d3:b9:81:11:84 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6029 12.237 31:ea:1b:25:0d:1f LE 1M LE LL 37 6047\302\265s 0 ADV_NONCONN_IND 6030 12.237 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6031 12.238 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6032 12.24 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1343\302\265s 0 ADV_NONCONN_IND 6033 12.24 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6034 12.241 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6035 12.245 11:fe:ef:ed:38:82 LE 1M LE LL 37 4155\302\265s 0 ADV_NONCONN_IND 6036 12.246 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6037 12.246 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6038 12.248 e7:70:80:c3:ad:91 LE 1M LE LL 36 1604\302\265s 0 ADV_IND 6039 12.252 e5:42:b3:0f:fa:b0 LE 1M LE LL 37 3381\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6040 12.253 cf:cd:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6041 12.262 43:bd:56:bd:74:f9 LE 1M LE LL 37 9000\302\265s 0 ADV_NONCONN_IND 6042 12.263 43:bd:56:bd:75:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6043 12.264 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6044 12.271 27:f7:d5:68:d5:82 LE 1M LE LL 36 7204\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6045 12.272 27:f1:d5:6a:d5:82 LE 1M LE LL 37 463\302\265s 0 ADV_NONCONN_IND 6046 12.273 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6047 12.281 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7409\302\265s 0 ADV_NONCONN_IND 6048 12.281 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6049 12.282 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6050 12.283 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1041\302\265s 0 ADV_NONCONN_IND 6051 12.284 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6052 12.284 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6053 12.285 79:70:d9:25:16:e2 LE 1M LE LL 25 593\302\265s 0 ADV_IND 6054 12.292 f1:ff:a7:1a:55:8d LE 1M LE LL 36 6423\302\265s 0 ADV_IND 6055 12.293 5f:ab:4a:c2:70:a2 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6056 12.302 e5:ea:46:16:3e:1e LE 1M LE LL 36 8051\302\265s 0 ADV_IND 6057 12.302 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 6058 12.303 a1:ca:46:17:7e:1e LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 6059 12.316 c2:f4:e6:80:5e:ae LE 1M LE LL 36 12536\302\265s 0 ADV_IND 6060 12.321 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4925\302\265s 0 ADV_NONCONN_IND 6061 12.322 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6062 12.323 d6:bf:76:0a:0b:dc LE 1M LE LL 36 852\302\265s 0 ADV_IND 6063 12.328 74:d9:0b:7a:47:5a LE 1M LE LL 28 4507\302\265s 0 ADV_IND 6064 12.344 0d:62:2c:2a:24:88 LE 1M LE LL 37 16142\302\265s 0 ADV_NONCONN_IND 6065 12.345 31:ea:1b:25:0d:1f LE 1M LE LL 37 222\302\265s 0 ADV_NONCONN_IND 6066 12.345 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6067 12.346 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6068 12.346 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 91\302\265s 0 ADV_NONCONN_IND 6069 12.347 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6070 12.348 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6071 12.352 cc:15:14:59:64:aa LE 1M LE LL 36 4120\302\265s 0 ADV_IND 6072 12.354 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1434\302\265s 0 ADV_NONCONN_IND 6073 12.355 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 6074 12.356 16:ed:93:0f:fa:b0 LE 1M LE LL 37 983\302\265s 0 ADV_NONCONN_IND 6075 12.356 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6076 12.357 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6077 12.359 07:69:22:f0:72:30 LE 1M LE LL 37 1713\302\265s 0 ADV_NONCONN_IND 6078 12.36 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 6079 12.36 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6080 12.364 74:d9:0b:7a:47:5a LE 1M LE LL 28 3546\302\265s 0 ADV_IND 6081 12.372 74:44:a3:67:d8:93 LE 1M LE LL 162 7605\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6082 12.376 43:bd:56:bd:74:f9 LE 1M LE LL 37 2735\302\265s 0 ADV_NONCONN_IND 6083 12.378 cd:5c:f3:7d:98:0b LE 1M LE LL 36 1487\302\265s 0 ADV_IND 6084 12.381 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2854\302\265s 0 ADV_NONCONN_IND 6085 12.382 25:5f:bf:53:1f:d7 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6086 12.385 32:43:3c:28:8d:92 LE 1M LE LL 37 2429\302\265s 0 ADV_NONCONN_IND 6087 12.385 32:43:3c:28:8d:92 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 6088 12.386 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6089 12.39 d5:80:ce:3a:df:84 LE 1M LE LL 36 3968\302\265s 0 ADV_IND 6090 12.393 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2100\302\265s 0 ADV_NONCONN_IND 6091 12.393 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6092 12.399 72:c4:71:2c:70:59 LE 1M LE LL 12 5126\302\265s 0 SCAN_REQ 6093 12.408 1e:28:49:84:c5:cd LE 1M LE LL 37 9707\302\265s 0 ADV_NONCONN_IND 6094 12.409 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6095 12.42 5c:9e:d4:03:82:5b LE 1M LE LL 37 10758\302\265s 0 ADV_NONCONN_IND 6096 12.421 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6097 12.421 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6098 12.426 7d:30:e4:59:cd:06 LE 1M LE LL 25 4179\302\265s 0 ADV_IND 6099 12.428 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1740\302\265s 0 ADV_NONCONN_IND 6100 12.429 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6101 12.433 2e:86:8d:c9:47:bd LE 1M LE LL 21 4181\302\265s 0 ADV_NONCONN_IND 6102 12.446 31:ea:1b:25:0d:1f LE 1M LE LL 37 12649\302\265s 0 ADV_NONCONN_IND 6103 12.447 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6104 12.451 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4467\302\265s 0 ADV_NONCONN_IND 6105 12.452 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6106 12.453 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6107 12.454 11:fe:ef:ed:38:82 LE 1M LE LL 37 1031\302\265s 0 ADV_NONCONN_IND 6108 12.455 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6109 12.455 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6110 12.458 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2668\302\265s 0 ADV_NONCONN_IND 6111 12.459 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6112 12.46 f0:f5:93:0f:fa:b0 LE 1M LE LL 37 340\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6113 12.46 07:69:22:f0:72:30 LE 1M LE LL 37 460\302\265s 0 ADV_NONCONN_IND 6114 12.461 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 6115 12.462 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6116 12.468 e5:ea:46:16:3e:1e LE 1M LE LL 36 5865\302\265s 0 ADV_IND 6117 12.47 74:d9:0b:7a:47:5a LE 1M LE LL 28 2147\302\265s 0 ADV_IND 6118 12.472 64:0d:49:f9:4d:a4 LE 1M LE LL 12 969\302\265s 0 SCAN_REQ 6119 12.472 74:d9:0b:7a:47:5a LE 1M LE LL 28 550\302\265s 0 ADV_IND 6120 12.473 4d:dc:b7:a2:f3:be LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 6121 12.473 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 6122 12.48 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6443\302\265s 0 ADV_NONCONN_IND 6123 12.48 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6124 12.486 cd:45:0c:ce:f1:94 LE 1M LE LL 37 5116\302\265s 0 ADV_IND 6125 12.487 32:43:3c:28:8d:92 LE 1M LE LL 37 760\302\265s 0 ADV_NONCONN_IND 6126 12.488 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6127 12.501 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 12581\302\265s 0 ADV_NONCONN_IND 6128 12.501 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6129 12.501 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6130 12.507 74:d9:0b:7a:47:5a LE 1M LE LL 28 5484\302\265s 0 ADV_IND 6131 12.508 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6132 12.508 74:d9:0b:7a:47:5a LE 1M LE LL 6 149\302\265s 0 SCAN_RSP 6133 12.51 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1711\302\265s 0 ADV_NONCONN_IND 6134 12.51 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6135 12.517 1e:28:49:84:c5:cd LE 1M LE LL 37 6682\302\265s 0 ADV_NONCONN_IND 6136 12.518 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6137 12.518 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6138 12.519 5c:9e:d4:03:82:5b LE 1M LE LL 37 498\302\265s 0 ADV_NONCONN_IND 6139 12.52 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6140 12.521 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6141 12.528 c1:c8:16:ae:fd:1d LE 1M LE LL 36 7467\302\265s 0 ADV_IND 6142 12.529 c1:c8:16:ae:fd:1d LE 1M LE LL 6 477\302\265s 0 SCAN_RSP 6143 12.53 c1:c8:16:ae:fd:1d LE 1M LE LL 36 136\302\265s 0 ADV_IND 6144 12.531 7d:dc:b7:8b:4f:3e LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6145 12.532 d5:80:38:95:af:b7 LE 1M LE LL 34 1546\302\265s 0 CONNECT_IND 6146 12.536 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2693\302\265s 0 ADV_NONCONN_IND 6147 12.536 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6148 12.541 4d:dc:b7:a2:f3:be LE 1M LE LL 12 4377\302\265s 0 SCAN_REQ 6149 12.541 c5:65:68:79:19:c8 LE 1M LE LL 36 416\302\265s 0 ADV_IND 6150 12.542 7f:e1:7b:e4:24:1c LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 6151 12.543 74:d9:0b:7a:47:5a LE 1M LE LL 28 690\302\265s 0 ADV_IND 6152 12.544 4d:dc:b7:a2:f3:be LE 1M LE LL 12 968\302\265s 0 SCAN_REQ 6153 12.552 31:ea:1b:25:0d:1f LE 1M LE LL 37 7404\302\265s 0 ADV_NONCONN_IND 6154 12.552 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6155 12.555 79:70:d9:25:16:e2 LE 1M LE LL 25 2731\302\265s 0 ADV_IND 6156 12.556 7f:e1:7b:e4:24:1c LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 6157 12.557 79:70:d9:25:16:e2 LE 1M LE LL 25 410\302\265s 0 ADV_IND 6158 12.56 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2295\302\265s 0 ADV_NONCONN_IND 6159 12.56 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6160 12.561 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6161 12.563 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2055\302\265s 0 ADV_NONCONN_IND 6162 12.564 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 6163 12.565 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6164 12.568 07:69:22:f0:72:30 LE 1M LE LL 37 2931\302\265s 0 ADV_NONCONN_IND 6165 12.568 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 6166 12.569 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6167 12.571 50:9d:53:4b:09:cc LE 1M LE LL 12 1237\302\265s 0 SCAN_REQ 6168 12.572 7f:61:7b:e4:24:1c LE 1M LE LL 12 832\302\265s 0 SCAN_REQ 6169 12.577 74:d9:0b:7a:47:5a LE 1M LE LL 28 5399\302\265s 0 ADV_IND 6170 12.578 46:cd:f9:15:6d:d0 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 6171 12.578 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 6172 12.578 4d:b9:d7:a5:74:f9 LE 1M LE LL 37 191\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6173 12.579 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6174 12.58 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6175 12.588 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7899\302\265s 0 ADV_NONCONN_IND 6176 12.589 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6177 12.589 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6178 12.59 50:9d:53:4b:09:cc LE 1M LE LL 12 387\302\265s 0 SCAN_REQ 6179 12.591 e7:70:80:c3:ad:91 LE 1M LE LL 36 414\302\265s 0 ADV_IND 6180 12.591 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6181 12.592 e7:70:80:c3:ad:91 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6182 12.592 e7:70:80:c3:ad:91 LE 1M LE LL 36 136\302\265s 0 ADV_IND 6183 12.592 46:cd:f9:15:6d:d0 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6184 12.593 e7:70:80:c3:ad:91 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6185 12.595 32:43:3c:28:8d:92 LE 1M LE LL 37 1865\302\265s 0 ADV_NONCONN_IND 6186 12.595 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6187 12.602 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 6195\302\265s 0 ADV_IND 6188 12.602 46:cd:f9:15:6d:d0 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6189 12.603 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 6190 12.608 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 5677\302\265s 0 ADV_IND 6191 12.609 50:9d:53:4b:09:cc LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6192 12.609 7f:f8:8c:bb:a1:a8 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6193 12.61 7f:e1:7b:e4:24:1c LE 1M LE LL 12 554\302\265s 0 SCAN_REQ 6194 12.611 46:cd:f9:15:6d:d0 LE 1M LE LL 12 832\302\265s 0 SCAN_REQ 6195 12.613 74:d9:0b:7a:47:5a LE 1M LE LL 28 1939\302\265s 0 ADV_IND 6196 12.613 50:9d:53:4b:09:cc LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6197 12.614 74:d9:0b:7a:47:5a LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6198 12.616 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2181\302\265s 0 SCAN_REQ 6199 12.622 5c:9e:d4:03:82:5b LE 1M LE LL 37 5572\302\265s 0 ADV_NONCONN_IND 6200 12.622 LE 1M LE LL 21 226\302\265s 0 Unknown 6201 12.623 2e:86:8d:c9:47:bd LE 1M LE LL 21 132\302\265s 0 ADV_NONCONN_IND 6202 12.625 46:cd:f9:15:6d:d0 LE 1M LE LL 12 2304\302\265s 0 SCAN_REQ 6203 12.635 e5:ea:46:16:3e:1e LE 1M LE LL 36 9721\302\265s 0 ADV_IND 6204 12.636 50:9d:53:4b:09:cc LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6205 12.636 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6206 12.636 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 6207 12.638 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1299\302\265s 0 ADV_NONCONN_IND 6208 12.639 f1:c4:7f:42:57:d8 LE 1M LE LL 6 294\302\265s 0 SCAN_RSP 6209 12.639 7f:e1:7b:e4:24:1c LE 1M LE LL 12 530\302\265s 0 SCAN_REQ 6210 12.64 71:c4:79:42:57:d8 LE 1M LE LL 21 410\302\265s 0 ADV_IND 6211 12.651 74:d9:0b:7a:47:5a LE 1M LE LL 28 10563\302\265s 0 ADV_IND 6212 12.654 31:ea:1b:25:0d:1f LE 1M LE LL 37 2554\302\265s 0 ADV_NONCONN_IND 6213 12.654 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6214 12.658 SamsungE_0b:d5:79 LE 1M LE LL 34 3243\302\265s 0 ADV_NONCONN_IND 6215 12.661 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2735\302\265s 0 ADV_NONCONN_IND 6216 12.661 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6217 12.664 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2625\302\265s 0 ADV_NONCONN_IND 6218 12.665 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6219 12.666 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6220 12.667 11:fe:ef:ed:38:82 LE 1M LE LL 37 324\302\265s 0 ADV_NONCONN_IND 6221 12.667 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6222 12.668 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6223 12.669 07:69:22:f0:72:30 LE 1M LE LL 37 1122\302\265s 0 ADV_NONCONN_IND 6224 12.67 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 6225 12.67 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6226 12.673 1f:84:46:51:98:14 LE 1M LE LL 23 2357\302\265s 0 ADV_NONCONN_IND 6227 12.673 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6228 12.674 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6229 12.68 43:bd:56:bd:74:f9 LE 1M LE LL 37 5505\302\265s 0 ADV_NONCONN_IND 6230 12.68 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6231 12.681 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6232 12.686 74:d9:0b:7a:47:5a LE 1M LE LL 28 3966\302\265s 0 ADV_IND 6233 12.686 74:d9:0b:7a:47:5a LE 1M LE LL 6 475\302\265s 0 SCAN_RSP 6234 12.688 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1913\302\265s 0 ADV_NONCONN_IND 6235 12.689 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6236 12.694 50:9d:53:4b:09:cc LE 1M LE LL 12 4377\302\265s 0 SCAN_REQ 6237 12.696 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2162\302\265s 0 ADV_NONCONN_IND 6238 12.697 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6239 12.698 08:ec:5e:66:cd:0d LE 1M LE LL 23 606\302\265s 0 ADV_NONCONN_IND 6240 12.698 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6241 12.699 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6242 12.699 50:9d:53:4b:09:cc LE 1M LE LL 12 436\302\265s 0 SCAN_REQ 6243 12.7 cf:4f:81:f5:7d:55 LE 1M LE LL 36 414\302\265s 0 ADV_IND 6244 12.701 47:4e:9b:89:59:8e LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6245 12.702 32:43:3c:28:8d:92 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 6246 12.702 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6247 12.703 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6248 12.707 fa:1f:24:e3:99:5d LE 1M LE LL 14 4166\302\265s 0 ADV_NONCONN_IND 6249 12.707 fa:1f:24:e3:99:5c LE 1M LE LL 142 132\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6250 12.717 cd:5c:f3:7d:98:0b LE 1M LE LL 36 8642\302\265s 0 ADV_IND 6251 12.719 17:5f:43:7c:0a:89 LE 1M LE LL 23 979\302\265s 0 ADV_NONCONN_IND 6252 12.719 74:d9:0b:7a:47:5a LE 1M LE LL 28 349\302\265s 0 ADV_IND 6253 12.729 5c:9e:d4:03:82:5b LE 1M LE LL 37 9694\302\265s 0 ADV_NONCONN_IND 6254 12.73 d5:80:ce:3a:df:84 LE 1M LE LL 36 363\302\265s 0 ADV_IND 6255 12.731 d6:11:ee:07:97:9a LE 1M LE LL 36 752\302\265s 0 ADV_IND[Malformed Packet] 6256 12.732 d5:80:ce:3a:df:84 LE 1M LE LL 36 341\302\265s 0 ADV_IND 6257 12.736 0b:f9:be:c7:0f:fb LE 1M LE LL 23 3434\302\265s 0 ADV_NONCONN_IND 6258 12.736 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6259 12.736 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6260 12.741 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4408\302\265s 0 ADV_NONCONN_IND 6261 12.742 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6262 12.742 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6263 12.756 74:d9:0b:7a:47:5a LE 1M LE LL 28 12973\302\265s 0 ADV_IND 6264 12.763 31:ea:1b:25:0d:1f LE 1M LE LL 37 6930\302\265s 0 ADV_NONCONN_IND 6265 12.764 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6266 12.765 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 636\302\265s 0 ADV_IND 6267 12.768 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3454\302\265s 0 ADV_NONCONN_IND 6268 12.769 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6269 12.772 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2208\302\265s 0 ADV_NONCONN_IND 6270 12.772 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6271 12.773 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6272 12.778 07:69:22:f0:72:30 LE 1M LE LL 37 5506\302\265s 0 ADV_NONCONN_IND 6273 12.779 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6274 12.78 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6275 12.787 43:bd:56:bd:74:f9 LE 1M LE LL 37 7035\302\265s 0 ADV_NONCONN_IND 6276 12.788 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6277 12.789 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6278 12.792 c4:23:b5:60:6c:09 LE 1M LE LL 14 3423\302\265s 0 ADV_NONCONN_IND 6279 12.797 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4426\302\265s 0 ADV_NONCONN_IND 6280 12.798 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6281 12.802 32:43:3c:28:8d:92 LE 1M LE LL 37 3194\302\265s 0 ADV_NONCONN_IND 6282 12.802 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6283 12.803 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6284 12.804 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1482\302\265s 0 ADV_NONCONN_IND 6285 12.805 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6286 12.806 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6287 12.809 SamsungE_07:d5:79 LE 1M LE LL 34 3046\302\265s 0 ADV_NONCONN_IND 6288 12.81 SamsungE_07:d5:79 LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 6289 12.811 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 6290 12.817 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5457\302\265s 0 ADV_NONCONN_IND 6291 12.817 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6292 12.818 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6293 12.821 50:d3:b9:81:11:84 LE 1M LE LL 12 2387\302\265s 0 SCAN_REQ 6294 12.828 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7484\302\265s 0 ADV_NONCONN_IND 6295 12.829 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6296 12.829 79:70:d9:25:16:e2 LE 1M LE LL 25 69\302\265s 0 ADV_IND 6297 12.83 56:d9:a2:01:11:e7 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6298 12.83 79:70:d9:25:16:e2 LE 1M LE LL 25 150\302\265s 0 ADV_IND 6299 12.833 1e:28:49:84:c5:cd LE 1M LE LL 37 3205\302\265s 0 ADV_NONCONN_IND 6300 12.842 50:27:bf:61:19:84 LE 1M LE LL 12 8220\302\265s 0 SCAN_REQ 6301 12.844 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1439\302\265s 0 ADV_NONCONN_IND 6302 12.844 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6303 12.851 dd:b9:3b:45:59:8b LE 1M LE LL 24 6103\302\265s 0 ADV_IND 6304 12.853 c0:4e:42:7b:5f:2b LE 1M LE LL 14 1516\302\265s 0 ADV_IND 6305 12.854 49:08:83:d3:3a:6c LE 1M LE LL 12 852\302\265s 0 SCAN_REQ 6306 12.854 c0:4e:43:7b:5f:2b LE 1M LE LL 14 321\302\265s 0 ADV_IND 6307 12.864 c1:c8:16:ae:fd:1d LE 1M LE LL 36 10009\302\265s 0 ADV_IND 6308 12.868 74:d9:0b:7a:47:5a LE 1M LE LL 28 3286\302\265s 0 ADV_IND 6309 12.871 79:ab:0f:33:5d:32 LE 1M LE LL 12 3235\302\265s 0 SCAN_REQ 6310 12.874 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2266\302\265s 0 ADV_NONCONN_IND 6311 12.875 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6312 12.879 7f:ab:0f:33:5d:32 LE 1M LE LL 12 3893\302\265s 0 SCAN_REQ 6313 12.879 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 410\302\265s 0 ADV_IND 6314 12.88 0d:62:2c:2a:24:88 LE 1M LE LL 37 331\302\265s 0 ADV_NONCONN_IND 6315 12.881 0d:62:2c:2a:24:88 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 6316 12.882 fd:ac:0f:33:1d:33 LE 1M LE LL 12 1190\302\265s 0 SCAN_REQ 6317 12.882 c5:65:68:79:19:c8 LE 1M LE LL 36 163\302\265s 0 ADV_IND 6318 12.883 c5:65:68:79:19:c8 LE 1M LE LL 36 354\302\265s 0 ADV_IND 6319 12.891 43:bd:56:bd:74:f9 LE 1M LE LL 37 7216\302\265s 0 ADV_NONCONN_IND 6320 12.892 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6321 12.892 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6322 12.898 50:d3:b9:81:11:84 LE 1M LE LL 12 4779\302\265s 0 SCAN_REQ 6323 12.901 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3084\302\265s 0 ADV_NONCONN_IND 6324 12.902 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6325 12.903 32:43:3c:28:8d:92 LE 1M LE LL 37 691\302\265s 0 ADV_NONCONN_IND 6326 12.903 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6327 12.904 f2:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6328 12.904 7e:8b:29:b4:1f:81 LE 1M LE LL 120 76\302\265s 0 ADV_SCAN_IND[Malformed Packet] 6329 12.907 40:f0:08:9b:56:91 LE 1M LE LL 37 1512\302\265s 0 ADV_SCAN_IND 6330 12.908 49:08:83:d3:3a:6c LE 1M LE LL 12 1035\302\265s 0 SCAN_REQ 6331 12.909 40:f0:08:9b:56:91 LE 1M LE LL 37 332\302\265s 0 ADV_SCAN_IND 6332 12.923 2b:5e:0e:c8:62:4c LE 1M LE LL 35 14316\302\265s 0 ADV_NONCONN_IND 6333 12.924 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6334 12.926 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1396\302\265s 0 ADV_IND 6335 12.926 7f:ab:0f:33:5d:32 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 6336 12.929 5c:9e:d4:03:82:5b LE 1M LE LL 37 2198\302\265s 0 ADV_NONCONN_IND 6337 12.929 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6338 12.931 e7:70:80:c3:ad:91 LE 1M LE LL 36 1139\302\265s 0 ADV_IND 6339 12.931 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6340 12.933 1e:28:49:84:c5:cd LE 1M LE LL 37 1358\302\265s 0 ADV_NONCONN_IND 6341 12.933 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6342 12.937 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3204\302\265s 0 ADV_NONCONN_IND 6343 12.938 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6344 12.938 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6345 12.941 74:d9:0b:7a:47:5a LE 1M LE LL 28 2610\302\265s 0 ADV_IND 6346 12.942 77:ab:8f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6347 12.952 0c:6e:66:d7:ed:03 LE 1M LE LL 37 10030\302\265s 0 ADV_NONCONN_IND 6348 12.952 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6349 12.957 7f:ab:0f:33:5d:32 LE 1M LE LL 12 3974\302\265s 0 SCAN_REQ 6350 12.961 e5:ea:46:16:3e:1e LE 1M LE LL 36 4419\302\265s 0 ADV_IND 6351 12.962 4f:dc:82:4d:be:ce LE 1M LE LL 36 778\302\265s 0 ADV_IND[Malformed Packet] 6352 12.964 SamsungE_07:d5:71 LE 1M LE LL 34 1166\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6353 12.965 SamsungE_07:d5:78 LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 6354 12.966 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 6355 12.97 f1:ff:a7:1a:55:8d LE 1M LE LL 36 3783\302\265s 0 ADV_IND 6356 12.971 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6357 12.971 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6358 12.971 f1:ff:a7:1a:55:8d LE 1M LE LL 36 134\302\265s 0 ADV_IND 6359 12.972 49:08:83:d3:3a:6c LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6360 12.976 31:ea:1b:25:0d:1f LE 1M LE LL 37 2994\302\265s 0 ADV_NONCONN_IND 6361 12.976 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6362 12.977 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6363 12.977 7d:30:e4:59:cd:06 LE 1M LE LL 25 344\302\265s 0 ADV_IND 6364 12.978 3a:d1:ca:1d:4d:de LE 1M LE LL 26 150\302\265s 0 ADV_NONCONN_IND 6365 12.979 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6366 12.981 11:fe:ef:ed:38:82 LE 1M LE LL 37 2058\302\265s 0 ADV_NONCONN_IND 6367 12.981 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6368 12.982 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6369 12.987 0d:62:2c:2a:24:88 LE 1M LE LL 37 4589\302\265s 0 ADV_NONCONN_IND 6370 12.988 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6371 12.988 56:f6:b2:80:58:8f LE 1M LE LL 34 96\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6372 12.99 c2:f4:e6:80:5e:ae LE 1M LE LL 36 1244\302\265s 0 ADV_IND 6373 12.99 c2:f4:e6:80:5e:ae LE 1M LE LL 36 353\302\265s 0 ADV_IND[Malformed Packet] 6374 12.991 2e:86:8d:c9:47:bd LE 1M LE LL 21 105\302\265s 0 ADV_NONCONN_IND 6375 12.997 d6:bf:03:c5:20:44 LE 1M LE LL 36 6118\302\265s 0 ADV_IND 6376 12.998 d6:bf:03:c5:20:42 LE 1M LE LL 36 741\302\265s 0 ADV_IND 6377 12.999 d6:bf:03:c5:20:42 LE 1M LE LL 36 354\302\265s 0 ADV_IND 6378 13 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6379 13 43:bd:56:bd:74:f9 LE 1M LE LL 37 282\302\265s 0 ADV_NONCONN_IND 6380 13.008 32:43:3c:28:8d:92 LE 1M LE LL 37 7434\302\265s 0 ADV_NONCONN_IND 6381 13.008 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6382 13.009 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6383 13.01 74:d9:0b:7a:47:5a LE 1M LE LL 28 559\302\265s 0 ADV_IND 6384 13.01 72:10:b2:16:c9:46 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 6385 13.011 74:d9:0b:7a:47:5a LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6386 13.013 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2450\302\265s 0 ADV_NONCONN_IND 6387 13.014 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6388 13.024 2b:5e:0e:c8:62:4c LE 1M LE LL 35 9476\302\265s 0 ADV_NONCONN_IND 6389 13.024 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6390 13.025 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6391 13.026 cc:15:14:59:64:aa LE 1M LE LL 36 748\302\265s 0 ADV_IND 6392 13.032 5c:9e:d4:03:82:5b LE 1M LE LL 37 6300\302\265s 0 ADV_NONCONN_IND 6393 13.033 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6394 13.039 1e:28:49:84:c5:cd LE 1M LE LL 37 5760\302\265s 0 ADV_NONCONN_IND 6395 13.04 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6396 13.04 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6397 13.041 cf:4f:81:f5:7d:55 LE 1M LE LL 6 190\302\265s 0 SCAN_RSP 6398 13.041 cf:4f:81:f5:7d:55 LE 1M LE LL 36 137\302\265s 0 ADV_IND 6399 13.043 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1612\302\265s 0 ADV_NONCONN_IND 6400 13.045 74:d9:0b:7a:47:5a LE 1M LE LL 28 1178\302\265s 0 ADV_IND 6401 13.045 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6402 13.061 0c:6e:66:d7:ed:03 LE 1M LE LL 37 15215\302\265s 0 ADV_NONCONN_IND 6403 13.061 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6404 13.065 64:0d:49:f9:4d:a4 LE 1M LE LL 12 3186\302\265s 0 SCAN_REQ 6405 13.067 d5:80:ce:3a:df:84 LE 1M LE LL 36 2474\302\265s 0 ADV_IND 6406 13.075 d6:11:16:57:f1:d0 LE 1M LE LL 36 7422\302\265s 0 ADV_IND 6407 13.077 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1051\302\265s 0 ADV_NONCONN_IND 6408 13.077 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6409 13.078 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6410 13.08 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1585\302\265s 0 ADV_NONCONN_IND 6411 13.08 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6412 13.081 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6413 13.082 3a:d1:ca:1d:4d:de LE 1M LE LL 26 788\302\265s 0 ADV_NONCONN_IND 6414 13.083 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 6415 13.083 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6416 13.088 0d:62:2c:2a:24:88 LE 1M LE LL 37 3908\302\265s 0 ADV_NONCONN_IND 6417 13.088 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6418 13.089 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6419 13.094 07:69:22:f0:72:30 LE 1M LE LL 37 5039\302\265s 0 ADV_NONCONN_IND 6420 13.095 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 6421 13.095 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6422 13.109 27:f1:d5:6a:d5:82 LE 1M LE LL 37 13162\302\265s 0 ADV_NONCONN_IND 6423 13.11 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6424 13.11 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6425 13.111 32:43:3c:28:8d:92 LE 1M LE LL 37 63\302\265s 0 ADV_NONCONN_IND 6426 13.111 32:43:3c:28:8d:92 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 6427 13.112 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6428 13.119 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7113\302\265s 0 ADV_NONCONN_IND 6429 13.12 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6430 13.121 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6431 13.124 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2602\302\265s 0 ADV_NONCONN_IND 6432 13.124 2b:5e:0e:c8:62:4c LE 1M LE LL 35 177\302\265s 0 ADV_NONCONN_IND 6433 13.125 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6434 13.127 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 1859\302\265s 0 ADV_NONCONN_IND 6435 13.127 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6436 13.128 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6437 13.129 e5:ea:46:16:3e:1e LE 1M LE LL 36 1037\302\265s 0 ADV_IND 6438 13.129 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6439 13.13 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6440 13.13 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 6441 13.131 6c:c6:23:80:30:28 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6442 13.135 64:0d:49:f9:4d:a4 LE 1M LE LL 12 3186\302\265s 0 SCAN_REQ 6443 13.14 5c:9e:d4:03:82:5b LE 1M LE LL 37 5075\302\265s 0 ADV_NONCONN_IND 6444 13.145 1e:28:49:84:c5:cd LE 1M LE LL 37 4373\302\265s 0 ADV_NONCONN_IND 6445 13.147 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1952\302\265s 0 ADV_NONCONN_IND 6446 13.148 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6447 13.148 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6448 13.149 64:0d:49:f9:4d:a4 LE 1M LE LL 12 324\302\265s 0 SCAN_REQ 6449 13.153 74:d9:0b:7a:47:5a LE 1M LE LL 28 4026\302\265s 0 ADV_IND[Malformed Packet] 6450 13.154 74:d9:0b:7a:47:5a LE 1M LE LL 28 514\302\265s 0 ADV_IND 6451 13.154 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6452 13.155 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 6453 13.167 0c:6e:66:d7:ed:03 LE 1M LE LL 37 12647\302\265s 0 ADV_NONCONN_IND 6454 13.168 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6455 13.169 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6456 13.18 16:ed:93:0f:fa:b0 LE 1M LE LL 37 10671\302\265s 0 ADV_NONCONN_IND 6457 13.18 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6458 13.181 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6459 13.183 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1586\302\265s 0 ADV_NONCONN_IND 6460 13.183 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6461 13.184 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6462 13.186 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1413\302\265s 0 ADV_NONCONN_IND 6463 13.187 3a:d1:ca:1d:4d:de LE 1M LE LL 26 742\302\265s 0 ADV_NONCONN_IND 6464 13.187 31:ea:1b:25:0d:1f LE 1M LE LL 37 297\302\265s 0 ADV_NONCONN_IND 6465 13.191 0d:62:2c:2a:24:88 LE 1M LE LL 37 3691\302\265s 0 ADV_NONCONN_IND 6466 13.192 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6467 13.192 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6468 13.196 07:69:22:f0:72:30 LE 1M LE LL 37 3163\302\265s 0 ADV_NONCONN_IND 6469 13.197 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 6470 13.197 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6471 13.201 c1:c8:16:ae:fd:1d LE 1M LE LL 36 3422\302\265s 0 ADV_IND 6472 13.208 43:bd:56:bd:74:f9 LE 1M LE LL 37 6562\302\265s 0 ADV_NONCONN_IND 6473 13.209 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6474 13.211 c6:f1:43:db:57:1d LE 1M LE LL 36 1594\302\265s 0 ADV_IND 6475 13.213 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2340\302\265s 0 ADV_NONCONN_IND 6476 13.214 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6477 13.217 32:43:3c:28:8d:92 LE 1M LE LL 37 1941\302\265s 0 ADV_NONCONN_IND 6478 13.217 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6479 13.218 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6480 13.224 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6491\302\265s 0 ADV_NONCONN_IND 6481 13.225 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6482 13.226 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6483 13.227 74:d9:0b:7a:47:5a LE 1M LE LL 28 1317\302\265s 0 ADV_IND 6484 13.233 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5891\302\265s 0 ADV_NONCONN_IND 6485 13.234 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6486 13.245 ef:6e:3d:68:42:19 LE 1M LE LL 36 10285\302\265s 0 ADV_IND 6487 13.245 c7:48:cc:72:d8:be LE 1M LE LL 14 240\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6488 13.246 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 6489 13.247 5c:9e:d4:03:82:5b LE 1M LE LL 37 1003\302\265s 0 ADV_NONCONN_IND 6490 13.247 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6491 13.248 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6492 13.249 1e:28:49:84:c5:cd LE 1M LE LL 37 134\302\265s 0 ADV_NONCONN_IND 6493 13.249 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6494 13.25 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6495 13.256 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5702\302\265s 0 ADV_NONCONN_IND 6496 13.256 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6497 13.257 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6498 13.27 e7:70:80:c3:ad:91 LE 1M LE LL 36 12317\302\265s 0 ADV_IND 6499 13.272 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2463\302\265s 0 ADV_NONCONN_IND 6500 13.273 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6501 13.28 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6299\302\265s 0 ADV_NONCONN_IND 6502 13.28 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6503 13.281 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6504 13.283 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1586\302\265s 0 ADV_NONCONN_IND 6505 13.283 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6506 13.284 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6507 13.292 31:ea:1b:25:0d:1f LE 1M LE LL 37 7541\302\265s 0 ADV_NONCONN_IND 6508 13.293 3a:d1:ca:1d:4d:de LE 1M LE LL 26 493\302\265s 0 ADV_NONCONN_IND 6509 13.293 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6510 13.295 e5:ea:46:16:3e:1e LE 1M LE LL 36 1518\302\265s 0 ADV_IND 6511 13.298 11:fe:ef:ed:38:82 LE 1M LE LL 37 2747\302\265s 0 ADV_NONCONN_IND 6512 13.299 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6513 13.301 1f:84:46:51:98:14 LE 1M LE LL 23 1265\302\265s 0 ADV_NONCONN_IND 6514 13.303 07:69:22:f0:72:30 LE 1M LE LL 37 2008\302\265s 0 ADV_NONCONN_IND 6515 13.303 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6516 13.309 f1:ff:a7:1a:55:8d LE 1M LE LL 36 5017\302\265s 0 ADV_IND 6517 13.31 43:bb:56:bd:74:f9 LE 1M LE LL 37 393\302\265s 0 ADV_NONCONN_IND 6518 13.31 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6519 13.311 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6520 13.314 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2232\302\265s 0 ADV_NONCONN_IND 6521 13.315 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6522 13.315 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6523 13.32 fb:18:78:3b:10:36 LE 1M LE LL 28 4600\302\265s 0 ADV_IND 6524 13.321 32:43:3c:28:8d:92 LE 1M LE LL 37 164\302\265s 0 ADV_NONCONN_IND 6525 13.321 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6526 13.322 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6527 13.325 c2:f4:e6:80:5e:ae LE 1M LE LL 36 2214\302\265s 0 ADV_IND 6528 13.328 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3217\302\265s 0 ADV_NONCONN_IND 6529 13.329 25:5f:bf:53:1f:d7 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6530 13.333 74:d9:0b:7a:47:5a LE 1M LE LL 28 4329\302\265s 0 ADV_IND 6531 13.334 d6:bf:76:0a:0b:dc LE 1M LE LL 36 314\302\265s 0 ADV_IND 6532 13.335 d6:bf:76:0a:0b:dc LE 1M LE LL 36 353\302\265s 0 ADV_IND 6533 13.337 d6:bf:03:c5:20:42 LE 1M LE LL 36 2190\302\265s 0 ADV_IND 6534 13.34 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2754\302\265s 0 ADV_NONCONN_IND 6535 13.341 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6536 13.342 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6537 13.344 17:5f:43:7c:0a:89 LE 1M LE LL 23 1862\302\265s 0 ADV_NONCONN_IND 6538 13.352 1e:28:49:84:c5:cd LE 1M LE LL 37 8230\302\265s 0 ADV_NONCONN_IND 6539 13.353 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6540 13.356 5c:9e:d4:03:82:5b LE 1M LE LL 37 2377\302\265s 0 ADV_NONCONN_IND 6541 13.356 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 6542 13.357 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6543 13.36 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2945\302\265s 0 ADV_NONCONN_IND 6544 13.361 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6545 13.361 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6546 13.363 0b:f9:be:c7:0f:fb LE 1M LE LL 23 1622\302\265s 0 ADV_NONCONN_IND 6547 13.364 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6548 13.364 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6549 13.364 cc:15:14:59:64:aa LE 1M LE LL 36 170\302\265s 0 ADV_IND 6550 13.376 74:d9:0b:7a:47:5a LE 1M LE LL 23 10786\302\265s 0 ADV_IND 6551 13.377 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1507\302\265s 0 ADV_NONCONN_IND 6552 13.379 ec:af:39:d1:f5:fe LE 1M LE LL 14 825\302\265s 0 ADV_NONCONN_IND 6553 13.379 ec:af:39:d1:f5:fe LE 1M LE LL 14 264\302\265s 0 ADV_NONCONN_IND 6554 13.38 ec:af:39:d1:f5:fe LE 1M LE LL 14 261\302\265s 0 ADV_NONCONN_IND 6555 13.381 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1249\302\265s 0 ADV_NONCONN_IND 6556 13.381 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6557 13.382 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6558 13.383 79:70:d9:25:16:e2 LE 1M LE LL 25 619\302\265s 0 ADV_IND 6559 13.389 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5617\302\265s 0 ADV_NONCONN_IND 6560 13.39 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6561 13.394 cf:5c:f3:7d:98:0b LE 1M LE LL 36 4311\302\265s 0 ADV_IND 6562 13.396 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1861\302\265s 0 ADV_NONCONN_IND 6563 13.397 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6564 13.399 d5:80:ce:3a:df:84 LE 1M LE LL 36 1245\302\265s 0 ADV_IND 6565 13.401 45:9b:f4:8b:97:f9 LE 1M LE LL 24 1474\302\265s 0 ADV_IND[Malformed Packet] 6566 13.401 0d:62:2c:2a:24:88 LE 1M LE LL 37 407\302\265s 0 ADV_NONCONN_IND 6567 13.404 11:fe:ef:ed:38:82 LE 1M LE LL 37 2432\302\265s 0 ADV_NONCONN_IND 6568 13.405 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6569 13.405 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6570 13.407 07:69:22:f0:72:30 LE 1M LE LL 37 1114\302\265s 0 ADV_NONCONN_IND 6571 13.407 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 6572 13.408 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6573 13.416 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 7640\302\265s 0 ADV_IND 6574 13.417 7f:ab:0f:33:5d:32 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6575 13.419 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2005\302\265s 0 ADV_NONCONN_IND 6576 13.422 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 2551\302\265s 0 ADV_IND 6577 13.425 7f:ab:0f:33:5d:32 LE 1M LE LL 12 2111\302\265s 0 SCAN_REQ 6578 13.425 45:9b:f4:8b:97:f9 LE 1M LE LL 37 411\302\265s 0 ADV_IND 6579 13.427 32:43:3c:28:8d:92 LE 1M LE LL 37 1674\302\265s 0 ADV_NONCONN_IND 6580 13.428 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6581 13.428 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6582 13.432 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3371\302\265s 0 ADV_NONCONN_IND 6583 13.433 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6584 13.433 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6585 13.442 2b:5e:0e:c8:62:4c LE 1M LE LL 35 8217\302\265s 0 ADV_NONCONN_IND 6586 13.442 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6587 13.443 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6588 13.452 1e:28:49:84:c5:cd LE 1M LE LL 37 8551\302\265s 0 ADV_NONCONN_IND 6589 13.452 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6590 13.453 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6591 13.465 24:c3:d0:ce:d4:37 LE 1M LE LL 37 11326\302\265s 0 ADV_NONCONN_IND 6592 13.465 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6593 13.466 LE 1M LE LL 98 124\302\265s 0 Unknown 6594 13.481 0c:6e:66:d7:ed:03 LE 1M LE LL 37 14089\302\265s 0 ADV_NONCONN_IND 6595 13.481 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6596 13.482 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6597 13.485 71:c4:79:42:d7:d8 LE 1M LE LL 69 3114\302\265s 0 ADV_IND[Malformed Packet] 6598 13.487 7f:ab:0f:33:5d:32 LE 1M LE LL 12 639\302\265s 0 SCAN_REQ 6599 13.488 16:ed:93:0f:fa:b0 LE 1M LE LL 37 980\302\265s 0 ADV_NONCONN_IND 6600 13.496 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 7834\302\265s 0 ADV_NONCONN_IND 6601 13.496 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6602 13.497 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6603 13.499 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2043\302\265s 0 ADV_NONCONN_IND 6604 13.5 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 6605 13.501 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6606 13.504 31:ea:1b:25:0d:1f LE 1M LE LL 37 3095\302\265s 0 ADV_NONCONN_IND 6607 13.505 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6608 13.505 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6609 13.51 07:69:22:f0:72:30 LE 1M LE LL 37 3964\302\265s 0 ADV_NONCONN_IND 6610 13.51 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6611 13.511 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6612 13.52 43:bd:56:bd:74:f9 LE 1M LE LL 37 8301\302\265s 0 ADV_NONCONN_IND 6613 13.52 7f:ab:0f:33:5d:32 LE 1M LE LL 12 80\302\265s 0 SCAN_REQ 6614 13.521 43:bd:56:bd:74:f9 LE 1M LE LL 37 1031\302\265s 0 ADV_NONCONN_IND 6615 13.523 27:f1:d5:6a:d5:82 LE 1M LE LL 37 947\302\265s 0 ADV_NONCONN_IND 6616 13.524 27:f1:d5:6a:d5:82 LE 1M LE LL 37 748\302\265s 0 ADV_NONCONN_IND 6617 13.524 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6618 13.532 32:43:3c:28:8d:92 LE 1M LE LL 37 7278\302\265s 0 ADV_NONCONN_IND 6619 13.533 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6620 13.533 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6621 13.541 25:5f:bf:53:1f:d7 LE 1M LE LL 37 7747\302\265s 0 ADV_NONCONN_IND 6622 13.542 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6623 13.542 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6624 13.547 c6:f1:43:db:57:1d LE 1M LE LL 36 3988\302\265s 0 ADV_IND 6625 13.551 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3775\302\265s 0 ADV_NONCONN_IND 6626 13.552 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6627 13.569 5c:9e:d4:03:82:5b LE 1M LE LL 37 17417\302\265s 0 ADV_NONCONN_IND 6628 13.57 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 6629 13.571 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6630 13.573 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1695\302\265s 0 ADV_NONCONN_IND 6631 13.573 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6632 13.574 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6633 13.576 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1655\302\265s 0 ADV_IND 6634 13.577 50:d3:b9:81:11:84 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6635 13.578 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND[Malformed Packet] 6636 13.582 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3791\302\265s 0 ADV_NONCONN_IND 6637 13.582 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6638 13.583 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6639 13.587 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3181\302\265s 0 ADV_NONCONN_IND 6640 13.587 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6641 13.588 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6642 13.589 71:c4:79:42:57:d8 LE 1M LE LL 37 1294\302\265s 0 ADV_IND 6643 13.59 71:c4:79:42:57:d8 LE 1M LE LL 36 369\302\265s 0 ADV_IND[Malformed Packet] 6644 13.591 71:c4:79:42:57:d8 LE 1M LE LL 37 744\302\265s 0 ADV_IND 6645 13.601 c0:41:04:2e:be:9d LE 1M LE LL 36 9498\302\265s 0 ADV_IND 6646 13.604 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2465\302\265s 0 ADV_NONCONN_IND 6647 13.605 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6648 13.606 e7:70:80:c3:ad:91 LE 1M LE LL 36 839\302\265s 0 ADV_IND 6649 13.607 50:d3:b9:81:11:84 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 6650 13.608 e7:70:80:c3:ad:91 LE 1M LE LL 36 415\302\265s 0 ADV_IND 6651 13.609 31:ea:1b:25:0d:1f LE 1M LE LL 37 1308\302\265s 0 ADV_NONCONN_IND 6652 13.61 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6653 13.61 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6654 13.613 0d:62:2c:2a:24:88 LE 1M LE LL 37 2446\302\265s 0 ADV_NONCONN_IND 6655 13.614 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6656 13.614 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6657 13.617 07:69:22:f0:72:30 LE 1M LE LL 37 2530\302\265s 0 ADV_NONCONN_IND 6658 13.618 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 6659 13.618 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6660 13.625 2e:86:8d:c9:47:bd LE 1M LE LL 21 5777\302\265s 0 ADV_NONCONN_IND 6661 13.625 LE 1M LE LL 21 132\302\265s 0 Unknown 6662 13.625 2e:86:8d:c9:47:bd LE 1M LE LL 21 132\302\265s 0 ADV_NONCONN_IND 6663 13.628 e5:ea:46:16:3e:1e LE 1M LE LL 36 2172\302\265s 0 ADV_IND 6664 13.631 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2804\302\265s 0 ADV_NONCONN_IND 6665 13.632 27:f1:d5:6a:d5:82 LE 1M LE LL 37 691\302\265s 0 ADV_NONCONN_IND 6666 13.64 32:43:3c:28:8d:92 LE 1M LE LL 37 7960\302\265s 0 ADV_NONCONN_IND 6667 13.641 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6668 13.641 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6669 13.642 f1:ff:a7:1a:55:8d LE 1M LE LL 36 732\302\265s 0 ADV_IND 6670 13.644 50:d3:b9:81:11:84 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 6671 13.644 f1:ff:a7:1a:55:8d LE 1M LE LL 36 414\302\265s 0 ADV_IND 6672 13.648 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2942\302\265s 0 ADV_NONCONN_IND 6673 13.648 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6674 13.649 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6675 13.652 1e:28:49:84:c5:cd LE 1M LE LL 37 2582\302\265s 0 ADV_NONCONN_IND 6676 13.652 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6677 13.653 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6678 13.658 c2:f4:e6:80:5e:ae LE 1M LE LL 36 5165\302\265s 0 ADV_IND 6679 13.659 2b:5e:0e:c8:62:4c LE 1M LE LL 35 406\302\265s 0 ADV_NONCONN_IND 6680 13.66 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6681 13.662 79:70:d9:25:16:e2 LE 1M LE LL 25 1836\302\265s 0 ADV_IND 6682 13.663 50:d3:b9:81:11:84 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 6683 13.666 5e:93:36:dd:d3:09 LE 1M LE LL 10 2670\302\265s 0 ADV_SCAN_IND 6684 13.673 d6:bf:76:0a:0b:dc LE 1M LE LL 36 6811\302\265s 0 ADV_IND 6685 13.673 d6:bf:76:0a:0b:dc LE 1M LE LL 36 353\302\265s 0 ADV_IND 6686 13.674 de:4f:b2:1f:f5:dc LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 6687 13.676 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1199\302\265s 0 ADV_NONCONN_IND 6688 13.676 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6689 13.677 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6690 13.685 e7:a0:9f:b8:da:be LE 1M LE LL 126 8105\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6691 13.689 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2200\302\265s 0 ADV_NONCONN_IND 6692 13.689 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6693 13.69 16:ed:93:0f:fa:b0 LE 1M LE LL 37 683\302\265s 0 ADV_NONCONN_IND 6694 13.691 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6695 13.691 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6696 13.708 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 15960\302\265s 0 ADV_NONCONN_IND 6697 13.708 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6698 13.709 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6699 13.71 31:ea:1b:25:0d:1f LE 1M LE LL 37 658\302\265s 0 ADV_NONCONN_IND 6700 13.71 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6701 13.711 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6702 13.714 cf:4f:81:f5:7d:55 LE 1M LE LL 36 2328\302\265s 0 ADV_IND 6703 13.715 64:0d:49:f9:4d:a4 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 6704 13.716 cf:4f:81:f5:7d:55 LE 1M LE LL 36 417\302\265s 0 ADV_IND 6705 13.717 0d:62:2c:2a:24:88 LE 1M LE LL 37 1047\302\265s 0 ADV_NONCONN_IND 6706 13.718 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6707 13.718 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6708 13.721 2e:86:8d:89:41:bd LE 1M LE LL 21 2053\302\265s 0 ADV_NONCONN_IND 6709 13.724 07:69:22:f0:72:30 LE 1M LE LL 37 3281\302\265s 0 ADV_NONCONN_IND 6710 13.725 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6711 13.731 d5:80:ce:3a:df:84 LE 1M LE LL 36 6150\302\265s 0 ADV_IND 6712 13.732 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6713 13.733 d5:80:ce:3a:df:84 LE 1M LE LL 36 415\302\265s 0 ADV_IND 6714 13.735 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1693\302\265s 0 ADV_NONCONN_IND 6715 13.736 cd:5c:f3:7d:98:0b LE 1M LE LL 6 298\302\265s 0 SCAN_RSP 6716 13.736 cd:5c:f3:7d:98:0b LE 1M LE LL 36 137\302\265s 0 ADV_IND 6717 13.737 27:f1:d5:6a:d5:82 LE 1M LE LL 37 356\302\265s 0 ADV_NONCONN_IND 6718 13.742 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4946\302\265s 0 ADV_IND 6719 13.744 d6:11:ee:07:97:9a LE 1M LE LL 36 1250\302\265s 0 ADV_IND 6720 13.747 51:95:e0:01:7f:4a LE 1M LE LL 34 2708\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6721 13.75 32:43:3c:28:8d:92 LE 1M LE LL 37 2576\302\265s 0 ADV_NONCONN_IND 6722 13.75 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6723 13.751 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6724 13.753 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2121\302\265s 0 ADV_NONCONN_IND 6725 13.754 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6726 13.754 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6727 13.755 1e:28:49:84:c5:cd LE 1M LE LL 37 81\302\265s 0 ADV_NONCONN_IND 6728 13.755 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6729 13.756 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6730 13.757 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 617\302\265s 0 ADV_NONCONN_IND 6731 13.757 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6732 13.758 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6733 13.762 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4355\302\265s 0 ADV_NONCONN_IND 6734 13.763 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6735 13.763 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6736 13.782 5c:9e:d4:03:82:5b LE 1M LE LL 37 18045\302\265s 0 ADV_NONCONN_IND 6737 13.782 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6738 13.783 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6739 13.785 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1066\302\265s 0 ADV_NONCONN_IND 6740 13.785 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6741 13.786 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6742 13.788 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2018\302\265s 0 ADV_NONCONN_IND 6743 13.789 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6744 13.789 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6745 13.797 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6937\302\265s 0 ADV_NONCONN_IND 6746 13.797 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6747 13.798 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6748 13.8 7d:50:e4:d9:cd:06 LE 1M LE LL 25 1991\302\265s 0 ADV_IND 6749 13.801 64:0d:49:f9:4d:a4 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 6750 13.809 45:9b:f4:8b:97:f9 LE 1M LE LL 37 7932\302\265s 0 ADV_IND 6751 13.812 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2838\302\265s 0 SCAN_REQ 6752 13.814 64:0d:49:f9:4d:a4 LE 1M LE LL 12 980\302\265s 0 SCAN_REQ 6753 13.814 4e:14:1a:db:9e:19 LE 1M LE LL 12 185\302\265s 0 ADV_IND 6754 13.816 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1535\302\265s 0 ADV_NONCONN_IND 6755 13.816 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6756 13.817 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 295\302\265s 0 ADV_NONCONN_IND 6757 13.818 31:ea:1b:25:0d:1f LE 1M LE LL 37 660\302\265s 0 ADV_NONCONN_IND 6758 13.819 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6759 13.819 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6760 13.823 11:fe:ef:ed:38:82 LE 1M LE LL 37 3866\302\265s 0 ADV_NONCONN_IND 6761 13.824 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6762 13.825 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6763 13.832 07:69:22:f0:72:30 LE 1M LE LL 37 7362\302\265s 0 ADV_NONCONN_IND 6764 13.833 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6765 13.833 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6766 13.836 69:ab:78:2f:b7:d6 LE 1M LE LL 61 2567\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6767 13.837 69:a9:48:2f:b7:16 LE 1M LE LL 37 263\302\265s 0 ADV_NONCONN_IND 6768 13.844 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6678\302\265s 0 ADV_NONCONN_IND 6769 13.845 7f:e1:7b:e4:24:1c LE 1M LE LL 12 912\302\265s 0 SCAN_REQ 6770 13.847 43:bd:56:bd:74:f9 LE 1M LE LL 36 956\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6771 13.847 43:bd:56:bd:74:f9 LE 1M LE LL 37 464\302\265s 0 ADV_NONCONN_IND 6772 13.85 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2594\302\265s 0 SCAN_REQ 6773 13.853 32:43:3c:28:8d:92 LE 1M LE LL 37 2103\302\265s 0 ADV_NONCONN_IND 6774 13.853 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6775 13.857 40:f0:08:9b:56:91 LE 1M LE LL 37 3295\302\265s 0 ADV_SCAN_IND 6776 13.859 68:eb:3a:76:64:b2 LE 1M LE LL 165 2186\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6777 13.862 dd:b9:3b:45:59:8b LE 1M LE LL 24 1453\302\265s 0 ADV_IND[Malformed Packet] 6778 13.863 2b:5e:0e:c8:62:4c LE 1M LE LL 35 346\302\265s 0 ADV_NONCONN_IND 6779 13.863 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6780 13.864 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6781 13.867 c1:c8:16:ae:fd:1d LE 1M LE LL 36 2815\302\265s 0 ADV_IND 6782 13.868 7f:e1:7b:e4:24:1e LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6783 13.868 c1:c8:16:ae:fd:1d LE 1M LE LL 36 414\302\265s 0 ADV_IND 6784 13.869 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 6785 13.869 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6786 13.869 c1:c8:16:ae:fd:1d LE 1M LE LL 36 137\302\265s 0 ADV_IND 6787 13.878 45:9b:f4:8b:97:f9 LE 1M LE LL 6 8422\302\265s 0 SCAN_RSP 6788 13.885 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 6192\302\265s 0 ADV_IND 6789 13.885 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 6790 13.885 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 6791 13.886 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 138\302\265s 0 ADV_IND 6792 13.887 24:c3:d0:ce:d4:37 LE 1M LE LL 37 996\302\265s 0 ADV_NONCONN_IND 6793 13.888 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6794 13.888 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6795 13.89 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1163\302\265s 0 SCAN_REQ 6796 13.89 c5:65:68:79:19:c8 LE 1M LE LL 36 415\302\265s 0 ADV_IND 6797 13.891 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6798 13.891 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 6799 13.891 c5:65:68:79:19:c8 LE 1M LE LL 36 137\302\265s 0 ADV_IND 6800 13.905 16:ed:93:0f:fa:b0 LE 1M LE LL 37 12976\302\265s 0 ADV_NONCONN_IND 6801 13.905 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6802 13.906 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6803 13.907 c0:41:ee:52:5a:8a LE 1M LE LL 36 943\302\265s 0 ADV_IND 6804 13.908 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6805 13.909 c0:41:ee:52:5a:8a LE 1M LE LL 36 164\302\265s 0 ADV_IND 6806 13.918 ef:6e:3d:68:42:19 LE 1M LE LL 36 9229\302\265s 0 ADV_IND 6807 13.919 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 6808 13.921 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1521\302\265s 0 ADV_NONCONN_IND 6809 13.925 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4066\302\265s 0 ADV_NONCONN_IND 6810 13.926 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6811 13.926 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6812 13.928 7f:e1:7b:e4:24:1c LE 1M LE LL 12 897\302\265s 0 SCAN_REQ 6813 13.931 1f:84:46:51:98:14 LE 1M LE LL 23 3126\302\265s 0 ADV_NONCONN_IND 6814 13.931 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 6815 13.935 c0:41:04:2e:be:9d LE 1M LE LL 36 3252\302\265s 0 ADV_IND 6816 13.938 74:d9:0b:7a:47:5a LE 1M LE LL 23 2312\302\265s 0 ADV_IND 6817 13.941 e7:70:80:c3:ad:91 LE 1M LE LL 36 3142\302\265s 0 ADV_IND 6818 13.944 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2454\302\265s 0 ADV_NONCONN_IND 6819 13.945 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6820 13.945 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6821 13.951 eb:db:35:2e:09:1b LE 1M LE LL 20 5671\302\265s 0 ADV_IND 6822 13.955 e5:ea:46:16:3e:1e LE 1M LE LL 36 2921\302\265s 0 ADV_IND 6823 13.957 08:ec:5e:66:cd:0d LE 1M LE LL 23 2435\302\265s 0 ADV_NONCONN_IND 6824 13.962 32:43:3c:28:8d:92 LE 1M LE LL 37 3799\302\265s 0 ADV_NONCONN_IND 6825 13.962 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6826 13.963 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6827 13.965 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 1600\302\265s 0 ADV_IND 6828 13.967 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1746\302\265s 0 ADV_NONCONN_IND 6829 13.967 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6830 13.97 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2607\302\265s 0 ADV_NONCONN_IND 6831 13.971 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6832 13.971 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6833 13.991 24:c3:d0:ce:d4:37 LE 1M LE LL 37 19144\302\265s 0 ADV_NONCONN_IND 6834 13.991 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6835 13.992 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6836 13.992 0c:6e:66:d7:ed:03 LE 1M LE LL 37 144\302\265s 0 ADV_NONCONN_IND 6837 13.993 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6838 13.994 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6839 14 c2:f4:e6:80:5e:ae LE 1M LE LL 36 5591\302\265s 0 ADV_IND 6840 14.001 50:9d:53:4b:09:cc LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 6841 14.001 c2:f4:e6:80:5e:ae LE 1M LE LL 36 417\302\265s 0 ADV_IND 6842 14.012 16:ed:93:0f:fa:b0 LE 1M LE LL 37 10402\302\265s 0 ADV_NONCONN_IND 6843 14.013 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6844 14.013 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6845 14.027 11:fe:ef:ed:38:82 LE 1M LE LL 37 13455\302\265s 0 ADV_NONCONN_IND 6846 14.028 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6847 14.028 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6848 14.03 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1640\302\265s 0 ADV_NONCONN_IND 6849 14.031 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6850 14.031 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6851 14.032 0d:62:2c:2a:24:88 LE 1M LE LL 37 223\302\265s 0 ADV_NONCONN_IND 6852 14.033 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6853 14.033 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6854 14.038 c6:f1:43:db:57:1d LE 1M LE LL 36 4531\302\265s 0 ADV_IND 6855 14.039 c6:f1:43:db:77:15 LE 1M LE LL 36 353\302\265s 0 ADV_IND 6856 14.04 7f:ab:0f:33:5d:32 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6857 14.043 cc:15:14:59:64:aa LE 1M LE LL 36 2971\302\265s 0 ADV_IND 6858 14.045 cc:15:14:59:64:aa LE 1M LE LL 6 1195\302\265s 0 SCAN_RSP 6859 14.045 cc:15:14:59:64:aa LE 1M LE LL 36 135\302\265s 0 ADV_IND 6860 14.045 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6861 14.046 cc:15:14:59:64:aa LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 6862 14.047 07:69:22:f0:72:30 LE 1M LE LL 37 705\302\265s 0 ADV_NONCONN_IND 6863 14.047 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 6864 14.048 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6865 14.05 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1828\302\265s 0 ADV_IND 6866 14.051 cf:4f:81:f5:7d:55 LE 1M LE LL 36 353\302\265s 0 ADV_IND 6867 14.052 cf:4f:81:f5:7d:55 LE 1M LE LL 6 477\302\265s 0 SCAN_RSP 6868 14.052 cf:4f:81:f5:7d:55 LE 1M LE LL 36 138\302\265s 0 ADV_IND 6869 14.052 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 6870 14.053 43:bd:56:bd:74:f9 LE 1M LE LL 37 790\302\265s 0 ADV_NONCONN_IND 6871 14.057 SamsungE_07:d5:79 LE 1M LE LL 34 3771\302\265s 0 ADV_NONCONN_IND 6872 14.058 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 6873 14.065 d5:80:ce:3a:df:84 LE 1M LE LL 36 6139\302\265s 0 ADV_IND 6874 14.067 1e:28:49:84:c5:cd LE 1M LE LL 37 2035\302\265s 0 ADV_NONCONN_IND 6875 14.068 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6876 14.069 cd:5c:f3:7d:98:0b LE 1M LE LL 36 923\302\265s 0 ADV_IND 6877 14.07 e2:f4:8b:c3:ec:01 LE 1M LE LL 36 763\302\265s 0 ADV_IND[Malformed Packet] 6878 14.071 cd:5c:f3:7d:98:0b LE 1M LE LL 36 79\302\265s 0 ADV_IND 6879 14.073 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1910\302\265s 0 ADV_NONCONN_IND 6880 14.074 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6881 14.074 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6882 14.075 25:5f:bf:53:1f:d7 LE 1M LE LL 37 734\302\265s 0 ADV_NONCONN_IND 6883 14.076 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6884 14.076 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6885 14.083 d6:2c:05:d0:15:49 LE 1M LE LL 37 6644\302\265s 0 ADV_IND[Malformed Packet] 6886 14.084 d6:2c:05:d0:15:49 LE 1M LE LL 37 395\302\265s 0 ADV_IND 6887 14.085 7f:ab:0f:33:5d:32 LE 1M LE LL 12 1061\302\265s 0 SCAN_REQ 6888 14.091 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5113\302\265s 0 ADV_NONCONN_IND 6889 14.091 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6890 14.092 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6891 14.093 5c:9e:d4:03:82:5b LE 1M LE LL 37 824\302\265s 0 ADV_NONCONN_IND 6892 14.094 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6893 14.094 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6894 14.098 2e:06:8e:49:47:3d LE 1M LE LL 149 2859\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6895 14.101 50:9d:53:4b:09:cc LE 1M LE LL 12 2412\302\265s 0 SCAN_REQ 6896 14.115 16:ed:93:0f:fa:b0 LE 1M LE LL 37 13151\302\265s 0 ADV_NONCONN_IND 6897 14.123 e5:ea:46:16:3e:1e LE 1M LE LL 36 7734\302\265s 0 ADV_IND 6898 14.124 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 6899 14.125 e5:ea:46:16:3e:1e LE 1M LE LL 36 415\302\265s 0 ADV_IND 6900 14.129 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4558\302\265s 0 ADV_NONCONN_IND 6901 14.13 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6902 14.131 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 6903 14.132 11:fe:ef:ed:38:82 LE 1M LE LL 37 316\302\265s 0 ADV_NONCONN_IND 6904 14.132 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6905 14.133 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6906 14.137 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4138\302\265s 0 ADV_NONCONN_IND 6907 14.138 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6908 14.138 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6909 14.141 0d:62:2c:2a:24:88 LE 1M LE LL 37 2101\302\265s 0 ADV_NONCONN_IND 6910 14.141 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6911 14.142 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6912 14.149 f4:08:ad:3c:61:f6 LE 1M LE LL 14 6347\302\265s 0 ADV_NONCONN_IND 6913 14.149 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 6914 14.149 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 6915 14.154 69:a9:48:2f:b7:16 LE 1M LE LL 37 4393\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 6916 14.155 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6917 14.157 07:69:22:f0:72:30 LE 1M LE LL 37 1484\302\265s 0 ADV_NONCONN_IND 6918 14.16 43:bd:56:bd:74:f9 LE 1M LE LL 37 2625\302\265s 0 ADV_NONCONN_IND 6919 14.16 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6920 14.161 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6921 14.167 1e:28:49:84:c5:cd LE 1M LE LL 37 5781\302\265s 0 ADV_NONCONN_IND 6922 14.168 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6923 14.168 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6924 14.174 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4778\302\265s 0 ADV_NONCONN_IND 6925 14.174 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6926 14.175 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 6927 14.183 25:5f:bf:53:1f:d7 LE 1M LE LL 37 8235\302\265s 0 ADV_NONCONN_IND 6928 14.184 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6929 14.184 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6930 14.193 24:c3:d0:ce:d4:37 LE 1M LE LL 37 7891\302\265s 0 ADV_NONCONN_IND 6931 14.193 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6932 14.194 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6933 14.196 5c:9e:d4:03:82:5b LE 1M LE LL 37 1446\302\265s 0 ADV_NONCONN_IND 6934 14.196 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6935 14.197 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6936 14.206 0c:6e:66:d7:ed:03 LE 1M LE LL 37 8941\302\265s 0 ADV_NONCONN_IND 6937 14.207 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6938 14.207 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6939 14.208 c1:c8:16:ae:fd:1d LE 1M LE LL 36 713\302\265s 0 ADV_IND 6940 14.21 72:10:b2:16:c9:46 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6941 14.21 c1:c8:16:ae:fd:1d LE 1M LE LL 36 415\302\265s 0 ADV_IND 6942 14.216 79:70:d9:25:16:e2 LE 1M LE LL 25 5050\302\265s 0 ADV_IND 6943 14.216 79:70:d9:25:16:e2 LE 1M LE LL 25 368\302\265s 0 ADV_IND 6944 14.217 79:70:d9:25:16:e2 LE 1M LE LL 25 369\302\265s 0 ADV_IND 6945 14.222 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4283\302\265s 0 ADV_NONCONN_IND 6946 14.222 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6947 14.223 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6948 14.225 c5:65:68:79:19:cb LE 1M LE LL 36 2298\302\265s 0 ADV_IND[Malformed Packet] 6949 14.226 c5:65:68:79:19:c8 LE 1M LE LL 36 353\302\265s 0 ADV_IND 6950 14.232 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 5747\302\265s 0 ADV_IND 6951 14.235 11:fe:ef:cd:38:82 LE 1M LE LL 37 2078\302\265s 0 ADV_NONCONN_IND 6952 14.235 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6953 14.236 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6954 14.238 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2048\302\265s 0 ADV_NONCONN_IND 6955 14.239 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 6956 14.24 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6957 14.242 31:ea:1b:25:0d:1f LE 1M LE LL 37 2458\302\265s 0 ADV_NONCONN_IND 6958 14.243 31:ea:1b:25:0d:1f LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 6959 14.244 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 6960 14.248 61:9c:87:78:87:2b LE 1M LE LL 23 4506\302\265s 0 ADV_IND 6961 14.253 ef:6e:3d:68:42:19 LE 1M LE LL 36 4434\302\265s 0 ADV_IND 6962 14.254 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6963 14.256 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1745\302\265s 0 ADV_NONCONN_IND 6964 14.257 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6965 14.258 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6966 14.262 07:69:22:f0:72:30 LE 1M LE LL 37 3310\302\265s 0 ADV_NONCONN_IND 6967 14.262 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 6968 14.263 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 6969 14.265 43:bd:56:bd:74:f9 LE 1M LE LL 37 1363\302\265s 0 ADV_NONCONN_IND 6970 14.265 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 6971 14.266 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 6972 14.27 c0:41:04:2e:be:9d LE 1M LE LL 36 3361\302\265s 0 ADV_IND 6973 14.273 e7:70:80:c3:ad:91 LE 1M LE LL 36 2843\302\265s 0 ADV_IND 6974 14.274 50:d1:b9:81:19:88 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 6975 14.28 2b:5e:0e:c8:62:4c LE 1M LE LL 35 5308\302\265s 0 ADV_NONCONN_IND 6976 14.28 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6977 14.281 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 6978 14.283 32:43:3c:28:8d:92 LE 1M LE LL 37 1503\302\265s 0 ADV_NONCONN_IND 6979 14.283 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6980 14.284 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6981 14.289 e5:ea:46:16:3e:1e LE 1M LE LL 36 4664\302\265s 0 ADV_IND 6982 14.29 25:5f:bf:53:1f:d7 LE 1M LE LL 37 217\302\265s 0 ADV_NONCONN_IND 6983 14.29 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6984 14.291 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 6985 14.301 24:c3:d0:ce:d4:37 LE 1M LE LL 37 10389\302\265s 0 ADV_NONCONN_IND 6986 14.302 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 6987 14.303 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6988 14.303 5c:9e:d4:03:82:5b LE 1M LE LL 37 198\302\265s 0 ADV_NONCONN_IND 6989 14.304 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6990 14.304 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 6991 14.307 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2687\302\265s 0 ADV_NONCONN_IND 6992 14.308 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 6993 14.309 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 6994 14.325 45:ab:f4:8b:96:c1 LE 1M LE LL 36 15960\302\265s 0 ADV_IND[Malformed Packet] 6995 14.34 3a:d1:ca:1d:4d:de LE 1M LE LL 26 14846\302\265s 0 ADV_NONCONN_IND 6996 14.341 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 6997 14.343 11:fe:ef:ed:38:82 LE 1M LE LL 37 1562\302\265s 0 ADV_NONCONN_IND 6998 14.343 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 6999 14.344 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7000 14.348 31:ea:1b:25:0d:1f LE 1M LE LL 37 3781\302\265s 0 ADV_NONCONN_IND 7001 14.349 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7002 14.349 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7003 14.35 d6:bf:76:0a:0b:dc LE 1M LE LL 36 600\302\265s 0 ADV_IND 7004 14.352 0d:62:2c:2a:24:88 LE 1M LE LL 37 1428\302\265s 0 ADV_NONCONN_IND 7005 14.352 c8:d3:30:3c:77:dc LE 1M LE LL 102 115\302\265s 0 SCAN_RSP[Malformed Packet] 7006 14.366 27:f1:d5:6a:d5:82 LE 1M LE LL 37 12952\302\265s 0 ADV_NONCONN_IND 7007 14.367 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7008 14.368 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7009 14.37 43:bd:56:bd:74:f9 LE 1M LE LL 37 1196\302\265s 0 ADV_NONCONN_IND 7010 14.37 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7011 14.371 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7012 14.373 c6:f1:43:db:57:1d LE 1M LE LL 36 1403\302\265s 0 ADV_IND 7013 14.376 1e:28:49:84:c5:cd LE 1M LE LL 37 2690\302\265s 0 ADV_NONCONN_IND 7014 14.377 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7015 14.379 49:08:83:d3:3a:6c LE 1M LE LL 12 2438\302\265s 0 SCAN_REQ 7016 14.385 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 5320\302\265s 0 ADV_NONCONN_IND 7017 14.385 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7018 14.389 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3686\302\265s 0 ADV_NONCONN_IND 7019 14.39 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7020 14.39 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7021 14.395 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3860\302\265s 0 ADV_NONCONN_IND 7022 14.395 25:5f:bf:53:1f:d7 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7023 14.396 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7024 14.399 d5:80:ce:3a:df:84 LE 1M LE LL 36 2555\302\265s 0 ADV_IND 7025 14.399 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7026 14.399 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7027 14.4 d5:80:ce:3a:df:84 LE 1M LE LL 36 136\302\265s 0 ADV_IND 7028 14.401 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7029 14.403 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1561\302\265s 0 ADV_NONCONN_IND 7030 14.403 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7031 14.404 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7032 14.412 cd:5c:f3:7d:98:0b LE 1M LE LL 36 7436\302\265s 0 ADV_IND 7033 14.412 cd:5c:f3:7d:98:0b LE 1M LE LL 36 353\302\265s 0 ADV_IND[Malformed Packet] 7034 14.417 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4113\302\265s 0 ADV_NONCONN_IND 7035 14.435 16:ed:93:0f:fa:b0 LE 1M LE LL 37 17578\302\265s 0 ADV_NONCONN_IND 7036 14.435 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7037 14.436 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7038 14.443 71:c4:79:42:57:d8 LE 1M LE LL 37 6533\302\265s 0 ADV_IND 7039 14.445 11:fe:ef:ed:38:82 LE 1M LE LL 37 2096\302\265s 0 ADV_NONCONN_IND 7040 14.446 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7041 14.45 31:ea:1b:25:0d:1f LE 1M LE LL 37 3780\302\265s 0 ADV_NONCONN_IND 7042 14.45 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7043 14.451 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7044 14.456 0d:62:2c:2a:24:88 LE 1M LE LL 37 4343\302\265s 0 ADV_NONCONN_IND 7045 14.456 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7046 14.457 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7047 14.459 e5:ea:46:16:3e:1e LE 1M LE LL 36 1680\302\265s 0 ADV_IND 7048 14.459 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7049 14.46 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7050 14.46 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 7051 14.461 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7052 14.464 2e:8e:8d:09:47:bd LE 1M LE LL 21 2810\302\265s 0 ADV_NONCONN_IND 7053 14.469 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4984\302\265s 0 ADV_NONCONN_IND 7054 14.47 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7055 14.473 07:69:22:f0:72:30 LE 1M LE LL 37 2793\302\265s 0 ADV_NONCONN_IND 7056 14.477 43:bd:56:bd:74:f9 LE 1M LE LL 37 3870\302\265s 0 ADV_NONCONN_IND 7057 14.478 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7058 14.479 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7059 14.484 1e:28:49:84:c5:cd LE 1M LE LL 37 4525\302\265s 0 ADV_NONCONN_IND 7060 14.484 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7061 14.485 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7062 14.489 cd:45:0c:ce:f1:94 LE 1M LE LL 37 4169\302\265s 0 ADV_IND 7063 14.491 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1024\302\265s 0 SCAN_REQ 7064 14.491 32:43:3c:28:8d:92 LE 1M LE LL 37 584\302\265s 0 ADV_NONCONN_IND 7065 14.492 79:70:d9:25:16:e2 LE 1M LE LL 25 269\302\265s 0 ADV_IND 7066 14.493 7f:e1:7b:e4:24:1c LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 7067 14.495 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2005\302\265s 0 ADV_NONCONN_IND 7068 14.497 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1358\302\265s 0 ADV_NONCONN_IND 7069 14.498 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7070 14.498 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7071 14.503 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4767\302\265s 0 ADV_NONCONN_IND 7072 14.504 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7073 14.504 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7074 14.505 74:d9:0b:7a:47:5a LE 1M LE LL 23 164\302\265s 0 ADV_IND 7075 14.505 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7076 14.506 74:d9:0b:7a:47:5a LE 1M LE LL 6 149\302\265s 0 SCAN_RSP 7077 14.506 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 699\302\265s 0 ADV_IND 7078 14.507 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7079 14.519 5c:9e:d4:03:82:5b LE 1M LE LL 37 12246\302\265s 0 ADV_NONCONN_IND 7080 14.522 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2061\302\265s 0 ADV_NONCONN_IND 7081 14.522 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7082 14.523 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7083 14.524 61:9c:87:78:87:2b LE 1M LE LL 23 589\302\265s 0 ADV_IND 7084 14.532 45:9b:f4:8b:97:f9 LE 1M LE LL 37 7765\302\265s 0 ADV_IND 7085 14.533 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7086 14.533 45:9b:f4:8b:97:f9 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7087 14.541 16:ed:93:0f:fa:b0 LE 1M LE LL 37 7846\302\265s 0 ADV_NONCONN_IND 7088 14.543 c1:c8:16:ae:fd:1d LE 1M LE LL 36 2284\302\265s 0 ADV_IND 7089 14.545 7f:e1:7b:e4:24:1c LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 7090 14.545 c1:c8:16:ae:fd:1d LE 1M LE LL 36 415\302\265s 0 ADV_IND 7091 14.548 11:fe:ef:ed:38:82 LE 1M LE LL 37 2092\302\265s 0 ADV_NONCONN_IND 7092 14.548 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7093 14.549 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7094 14.549 3a:d1:ca:1d:4d:de LE 1M LE LL 26 186\302\265s 0 ADV_NONCONN_IND 7095 14.55 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 242\302\265s 0 SCAN_RSP 7096 14.55 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 138\302\265s 0 ADV_IND 7097 14.551 3a:d1:ca:1d:4d:de LE 1M LE LL 26 322\302\265s 0 ADV_NONCONN_IND 7098 14.555 31:ea:1b:25:0d:1f LE 1M LE LL 37 3695\302\265s 0 ADV_NONCONN_IND 7099 14.555 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7100 14.556 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7101 14.562 1f:84:46:51:98:14 LE 1M LE LL 23 5454\302\265s 0 ADV_NONCONN_IND 7102 14.562 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7103 14.563 1f:94:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 SCAN_REQ 7104 14.564 0d:62:2c:2a:24:88 LE 1M LE LL 37 961\302\265s 0 ADV_NONCONN_IND 7105 14.564 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7106 14.565 0d:62:2c:2a:24:88 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7107 14.577 07:69:22:f0:72:30 LE 1M LE LL 37 11256\302\265s 0 ADV_NONCONN_IND 7108 14.577 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 7109 14.578 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7110 14.584 08:ec:5e:66:cd:0d LE 1M LE LL 23 6071\302\265s 0 ADV_NONCONN_IND 7111 14.585 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7112 14.585 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7113 14.585 1e:28:49:84:c5:cd LE 1M LE LL 37 183\302\265s 0 ADV_NONCONN_IND 7114 14.586 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7115 14.587 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7116 14.591 d2:2c:04:50:15:49 LE 1M LE LL 37 3844\302\265s 0 ADV_IND 7117 14.592 d6:2c:05:d0:15:49 LE 1M LE LL 37 395\302\265s 0 ADV_IND 7118 14.598 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6493\302\265s 0 ADV_NONCONN_IND 7119 14.599 25:5f:bf:53:1f:d7 LE 1M LE LL 37 108\302\265s 0 ADV_NONCONN_IND 7120 14.599 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7121 14.6 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7122 14.605 c0:41:04:2e:be:9d LE 1M LE LL 36 4526\302\265s 0 ADV_IND 7123 14.605 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7124 14.606 e7:70:80:c3:ad:91 LE 1M LE LL 36 137\302\265s 0 ADV_IND 7125 14.606 e7:70:80:c3:ad:91 LE 1M LE LL 36 353\302\265s 0 ADV_IND 7126 14.608 24:c3:d0:ce:d4:37 LE 1M LE LL 37 678\302\265s 0 ADV_NONCONN_IND 7127 14.621 6f:54:d4:dd:c1:58 LE 1M LE LL 12 12811\302\265s 0 SCAN_REQ 7128 14.621 e4:b4:8f:07:0f:fb LE 1M LE LL 23 384\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7129 14.622 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7130 14.623 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1106\302\265s 0 ADV_NONCONN_IND 7131 14.624 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7132 14.624 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7133 14.626 e5:ea:46:16:3e:1e LE 1M LE LL 36 1777\302\265s 0 ADV_IND 7134 14.628 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 7135 14.628 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 7136 14.642 16:ed:93:0f:fa:b0 LE 1M LE LL 37 12986\302\265s 0 ADV_NONCONN_IND 7137 14.642 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7138 14.643 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7139 14.645 6f:54:d4:dd:c1:58 LE 1M LE LL 12 1683\302\265s 0 SCAN_REQ 7140 14.649 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3994\302\265s 0 ADV_NONCONN_IND 7141 14.65 11:fe:ef:ed:38:82 LE 1M LE LL 37 287\302\265s 0 ADV_NONCONN_IND 7142 14.651 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1301\302\265s 0 ADV_IND 7143 14.654 2e:86:8d:c9:47:bd LE 1M LE LL 21 2902\302\265s 0 ADV_NONCONN_IND 7144 14.661 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 6065\302\265s 0 ADV_NONCONN_IND 7145 14.662 31:ea:1b:25:0d:1f LE 1M LE LL 37 1268\302\265s 0 ADV_NONCONN_IND 7146 14.663 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7147 14.664 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7148 14.67 0d:62:2c:2a:24:88 LE 1M LE LL 37 6225\302\265s 0 ADV_NONCONN_IND 7149 14.671 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7150 14.671 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7151 14.673 c2:f4:e6:80:5e:ae LE 1M LE LL 36 1735\302\265s 0 ADV_IND 7152 14.674 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7153 14.676 69:a9:48:2f:b7:16 LE 1M LE LL 37 1839\302\265s 0 ADV_NONCONN_IND 7154 14.678 07:69:22:f0:72:30 LE 1M LE LL 37 1486\302\265s 0 ADV_NONCONN_IND 7155 14.687 c4:d3:3f:7d:a3:17 LE 1M LE LL 36 8583\302\265s 0 ADV_IND 7156 14.687 c4:d3:3f:79:a7:16 LE 1M LE LL 36 353\302\265s 0 ADV_IND 7157 14.688 d6:bf:76:0a:0b:dc LE 1M LE LL 36 504\302\265s 0 ADV_IND 7158 14.689 1e:28:49:84:c5:cd LE 1M LE LL 37 384\302\265s 0 ADV_NONCONN_IND 7159 14.692 43:bd:56:bd:74:f9 LE 1M LE LL 37 2576\302\265s 0 ADV_NONCONN_IND 7160 14.693 6c:c6:23:80:30:28 LE 1M LE LL 12 466\302\265s 0 SCAN_REQ 7161 14.694 f4:d9:4a:6a:47:5a LE 1M LE LL 23 548\302\265s 0 ADV_IND[Malformed Packet] 7162 14.694 74:d9:0b:7a:47:5a LE 1M LE LL 23 513\302\265s 0 ADV_IND 7163 14.696 6c:c6:23:80:30:28 LE 1M LE LL 12 1035\302\265s 0 SCAN_REQ 7164 14.705 32:43:3c:28:8d:92 LE 1M LE LL 37 8688\302\265s 0 ADV_NONCONN_IND 7165 14.706 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1495\302\265s 0 ADV_NONCONN_IND 7166 14.707 25:5f:bf:53:1f:d7 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 7167 14.708 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7168 14.708 24:c3:d0:ce:d4:37 LE 1M LE LL 37 388\302\265s 0 ADV_NONCONN_IND 7169 14.709 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7170 14.709 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7171 14.721 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 11007\302\265s 0 ADV_IND 7172 14.721 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7173 14.722 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7174 14.722 6c:c6:23:80:30:28 LE 1M LE LL 12 654\302\265s 0 SCAN_REQ 7175 14.723 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 7176 14.726 5c:9e:d4:03:82:5b LE 1M LE LL 37 2230\302\265s 0 ADV_NONCONN_IND 7177 14.726 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7178 14.727 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7179 14.73 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2682\302\265s 0 ADV_NONCONN_IND 7180 14.731 0c:6e:66:d7:ed:03 LE 1M LE LL 37 247\302\265s 0 ADV_NONCONN_IND 7181 14.731 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7182 14.737 d5:80:ce:3a:df:84 LE 1M LE LL 36 5750\302\265s 0 ADV_IND 7183 14.738 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7184 14.738 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7185 14.738 d5:80:ce:3a:df:84 LE 1M LE LL 36 136\302\265s 0 ADV_IND 7186 14.739 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7187 14.739 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7188 14.739 d5:80:ce:3a:df:84 LE 1M LE LL 36 137\302\265s 0 ADV_IND 7189 14.741 7f:ab:0f:33:5d:32 LE 1M LE LL 12 1145\302\265s 0 SCAN_REQ 7190 14.742 6c:c6:23:80:30:28 LE 1M LE LL 12 666\302\265s 0 SCAN_REQ 7191 14.742 f5:ce:00:2f:bb:4c LE 1M LE LL 33 300\302\265s 0 ADV_IND 7192 14.747 cd:5c:f3:7d:98:0b LE 1M LE LL 36 3866\302\265s 0 ADV_IND 7193 14.747 7f:ab:0f:33:5d:32 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7194 14.747 cd:5c:f3:7d:98:0b LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7195 14.748 cd:5c:f3:7d:98:0b LE 1M LE LL 36 136\302\265s 0 ADV_IND 7196 14.748 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7197 14.748 cd:5c:f3:7d:98:0b LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7198 14.749 cd:5c:f3:7d:98:0b LE 1M LE LL 36 137\302\265s 0 ADV_IND 7199 14.752 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2840\302\265s 0 ADV_NONCONN_IND 7200 14.753 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7201 14.753 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7202 14.754 7f:ab:0f:33:5d:32 LE 1M LE LL 12 191\302\265s 0 SCAN_REQ 7203 14.755 d1:fe:8f:6d:38:c2 LE 1M LE LL 37 501\302\265s 0 ADV_NONCONN_IND 7204 14.755 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7205 14.759 7f:ab:0f:33:5d:32 LE 1M LE LL 12 3480\302\265s 0 SCAN_REQ 7206 14.759 6c:c6:23:80:30:28 LE 1M LE LL 12 207\302\265s 0 SCAN_REQ 7207 14.764 78:70:d9:25:16:e2 LE 1M LE LL 25 4196\302\265s 0 ADV_IND 7208 14.764 31:ea:1b:25:0d:1f LE 1M LE LL 37 264\302\265s 0 ADV_NONCONN_IND 7209 14.765 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7210 14.765 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7211 14.769 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3257\302\265s 0 ADV_NONCONN_IND 7212 14.77 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7213 14.77 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7214 14.78 7f:ab:0f:33:5d:32 LE 1M LE LL 12 9052\302\265s 0 SCAN_REQ 7215 14.78 45:9b:f4:8b:97:f9 LE 1M LE LL 37 247\302\265s 0 ADV_IND 7216 14.783 07:69:22:f0:72:30 LE 1M LE LL 37 2373\302\265s 0 ADV_NONCONN_IND 7217 14.789 e5:ea:46:16:3e:1e LE 1M LE LL 36 5780\302\265s 0 ADV_IND 7218 14.79 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 7219 14.791 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 7220 14.795 43:bd:56:bd:74:f9 LE 1M LE LL 37 3394\302\265s 0 ADV_NONCONN_IND 7221 14.795 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7222 14.796 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7223 14.806 25:5f:bf:53:1f:d7 LE 1M LE LL 37 9846\302\265s 0 ADV_NONCONN_IND 7224 14.807 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7225 14.808 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7226 14.809 2b:5e:0e:c8:62:4c LE 1M LE LL 35 715\302\265s 0 ADV_NONCONN_IND 7227 14.809 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7228 14.81 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7229 14.811 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1362\302\265s 0 ADV_NONCONN_IND 7230 14.812 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7231 14.813 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7232 14.826 5c:9e:d4:03:82:5b LE 1M LE LL 37 12700\302\265s 0 ADV_NONCONN_IND 7233 14.826 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7234 14.827 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7235 14.832 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5180\302\265s 0 ADV_NONCONN_IND 7236 14.833 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7237 14.834 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7238 14.854 3a:d1:ca:1d:4d:de LE 1M LE LL 26 20437\302\265s 0 ADV_NONCONN_IND 7239 14.855 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7240 14.856 11:fe:ef:ed:38:82 LE 1M LE LL 37 289\302\265s 0 ADV_NONCONN_IND 7241 14.861 c0:4e:43:7b:5f:2b LE 1M LE LL 14 4932\302\265s 0 ADV_IND 7242 14.865 6f:54:d4:dd:c1:58 LE 1M LE LL 12 3356\302\265s 0 SCAN_REQ 7243 14.873 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 8480\302\265s 0 ADV_NONCONN_IND 7244 14.875 0d:62:2c:2a:24:88 LE 1M LE LL 37 1484\302\265s 0 ADV_NONCONN_IND 7245 14.876 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7246 14.876 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7247 14.881 74:d9:0b:7a:47:5a LE 1M LE LL 23 4383\302\265s 0 ADV_IND 7248 14.884 cb:e5:c0:d3:8a:f0 LE 1M LE LL 36 2847\302\265s 0 ADV_IND[Malformed Packet] 7249 14.885 b0:28:30:d3:8a:f0 LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 7250 14.888 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 3039\302\265s 0 ADV_IND 7251 14.891 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2225\302\265s 0 ADV_NONCONN_IND 7252 14.892 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7253 14.896 1e:28:49:84:c5:cd LE 1M LE LL 37 4022\302\265s 0 ADV_NONCONN_IND 7254 14.897 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7255 14.897 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7256 14.908 32:43:3c:28:8d:92 LE 1M LE LL 37 10848\302\265s 0 ADV_NONCONN_IND 7257 14.909 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7258 14.91 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7259 14.913 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3371\302\265s 0 ADV_NONCONN_IND 7260 14.914 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7261 14.914 25:5f:bf:53:1f:d7 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7262 14.918 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3513\302\265s 0 ADV_NONCONN_IND 7263 14.919 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7264 14.919 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7265 14.926 ef:6e:3d:68:42:19 LE 1M LE LL 36 5884\302\265s 0 ADV_IND 7266 14.929 5c:9e:d4:03:82:5b LE 1M LE LL 37 2703\302\265s 0 ADV_NONCONN_IND 7267 14.929 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7268 14.942 0c:6e:66:d7:ed:03 LE 1M LE LL 37 12054\302\265s 0 ADV_NONCONN_IND 7269 14.942 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7270 14.943 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7271 14.947 c0:41:04:2e:be:9d LE 1M LE LL 36 4015\302\265s 0 ADV_IND 7272 14.955 eb:db:35:2e:09:1b LE 1M LE LL 20 7248\302\265s 0 ADV_IND 7273 14.958 e5:ea:46:16:3e:1e LE 1M LE LL 36 2594\302\265s 0 ADV_IND 7274 14.964 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5889\302\265s 0 ADV_NONCONN_IND 7275 14.965 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7276 14.965 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7277 14.975 0d:62:2c:2a:24:88 LE 1M LE LL 37 9546\302\265s 0 ADV_NONCONN_IND 7278 14.976 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7279 14.976 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7280 14.977 71:c4:79:42:57:d8 LE 1M LE LL 6 263\302\265s 0 SCAN_RSP 7281 14.977 71:c4:79:42:57:d8 LE 1M LE LL 37 132\302\265s 0 ADV_IND 7282 14.98 31:ea:1b:25:0d:1f LE 1M LE LL 37 2260\302\265s 0 ADV_NONCONN_IND 7283 14.981 71:c9:89:02:1c:fb LE 1M LE LL 12 568\302\265s 0 SCAN_REQ 7284 14.985 SamsungE_07:d5:79 LE 1M LE LL 34 3983\302\265s 0 ADV_NONCONN_IND 7285 14.986 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 7286 14.995 27:f1:d5:6a:d5:82 LE 1M LE LL 37 8836\302\265s 0 ADV_NONCONN_IND 7287 14.996 63:b2:fb:0c:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7288 14.997 07:69:22:f0:72:30 LE 1M LE LL 37 278\302\265s 0 ADV_NONCONN_IND 7289 14.997 1e:28:49:84:c5:cd LE 1M LE LL 37 447\302\265s 0 ADV_NONCONN_IND 7290 14.998 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7291 14.998 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7292 15.002 64:0d:49:f9:4d:a4 LE 1M LE LL 12 2980\302\265s 0 SCAN_REQ 7293 15.005 43:bd:56:bd:74:f9 LE 1M LE LL 37 3372\302\265s 0 ADV_NONCONN_IND 7294 15.006 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7295 15.011 c2:f4:e6:80:5e:ae LE 1M LE LL 36 4307\302\265s 0 ADV_IND 7296 15.011 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7297 15.012 c2:f4:e6:80:5e:ae LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7298 15.012 c2:f4:e6:80:5e:ae LE 1M LE LL 36 136\302\265s 0 ADV_IND 7299 15.015 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2965\302\265s 0 ADV_NONCONN_IND 7300 15.017 32:43:3c:28:8d:92 LE 1M LE LL 37 1504\302\265s 0 ADV_NONCONN_IND 7301 15.018 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7302 15.018 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7303 15.019 25:5f:bf:53:1f:d7 LE 1M LE LL 37 246\302\265s 0 ADV_NONCONN_IND 7304 15.019 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7305 15.02 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7306 15.024 d6:bf:76:0a:0b:dc LE 1M LE LL 36 3399\302\265s 0 ADV_IND 7307 15.024 64:0d:49:f9:4d:a4 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7308 15.025 d6:bf:76:0a:0b:dc LE 1M LE LL 6 149\302\265s 0 SCAN_RSP 7309 15.026 c4:d3:bf:79:a7:16 LE 1M LE LL 36 1376\302\265s 0 ADV_IND 7310 15.027 24:c3:d0:ce:d4:37 LE 1M LE LL 37 379\302\265s 0 ADV_NONCONN_IND 7311 15.028 5c:9e:d4:03:82:5b LE 1M LE LL 37 828\302\265s 0 ADV_NONCONN_IND 7312 15.029 5c:9e:d4:03:82:5b LE 1M LE LL 37 250\302\265s 0 ADV_NONCONN_IND 7313 15.029 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7314 15.03 d5:80:04:0e:a6:f4 LE 1M LE LL 34 384\302\265s 0 CONNECT_IND 7315 15.033 79:70:d9:25:16:e2 LE 1M LE LL 25 2349\302\265s 0 ADV_IND 7316 15.033 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7317 15.049 0c:6e:66:d7:ed:03 LE 1M LE LL 37 15236\302\265s 0 ADV_NONCONN_IND 7318 15.05 64:0d:49:f9:4d:a4 LE 1M LE LL 12 550\302\265s 0 SCAN_REQ 7319 15.051 6f:54:d4:dd:c1:58 LE 1M LE LL 12 937\302\265s 0 SCAN_REQ 7320 15.052 cc:15:14:59:64:aa LE 1M LE LL 36 1460\302\265s 0 ADV_IND 7321 15.053 64:0d:49:f9:4d:a4 LE 1M LE LL 12 198\302\265s 0 SCAN_REQ 7322 15.053 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 7323 15.059 cf:4f:81:f5:7d:55 LE 1M LE LL 36 5152\302\265s 0 ADV_IND 7324 15.064 50:d3:b9:81:11:84 LE 1M LE LL 12 4191\302\265s 0 SCAN_REQ 7325 15.066 74:d9:0b:7a:47:5a LE 1M LE LL 23 1806\302\265s 0 ADV_IND 7326 15.068 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2642\302\265s 0 ADV_NONCONN_IND 7327 15.071 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2262\302\265s 0 ADV_NONCONN_IND 7328 15.072 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7329 15.074 61:8c:87:78:87:1b LE 1M LE LL 23 2134\302\265s 0 ADV_NONCONN_IND 7330 15.075 61:9c:87:78:87:2b LE 1M LE LL 23 513\302\265s 0 ADV_IND 7331 15.075 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7332 15.076 61:9c:87:78:87:2b LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7333 15.079 0d:62:2c:2a:24:88 LE 1M LE LL 37 3755\302\265s 0 ADV_NONCONN_IND 7334 15.08 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7335 15.082 31:ea:1b:25:0d:1f LE 1M LE LL 37 2044\302\265s 0 ADV_NONCONN_IND 7336 15.083 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7337 15.084 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7338 15.084 1c:2f:b7:5d:a9:12 LE 1M LE LL 53 132\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7339 15.085 cd:5c:f3:7d:98:0b LE 1M LE LL 36 530\302\265s 0 ADV_IND 7340 15.086 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7341 15.088 64:0d:49:f9:4d:a4 LE 1M LE LL 12 1903\302\265s 0 SCAN_REQ 7342 15.093 d6:2c:05:d0:15:49 LE 1M LE LL 37 4382\302\265s 0 ADV_IND 7343 15.094 6f:54:d4:dd:c1:58 LE 1M LE LL 12 923\302\265s 0 SCAN_REQ 7344 15.096 64:0d:49:f9:4d:a4 LE 1M LE LL 12 1905\302\265s 0 SCAN_REQ 7345 15.097 d6:11:16:57:f1:d0 LE 1M LE LL 36 163\302\265s 0 ADV_IND 7346 15.098 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7347 15.102 1e:28:49:84:c5:cd LE 1M LE LL 37 3605\302\265s 0 ADV_NONCONN_IND 7348 15.102 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7349 15.103 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7350 15.104 07:69:22:f0:72:30 LE 1M LE LL 37 938\302\265s 0 ADV_NONCONN_IND 7351 15.105 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 7352 15.105 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7353 15.108 43:bd:56:bd:74:f9 LE 1M LE LL 37 2614\302\265s 0 ADV_NONCONN_IND 7354 15.109 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7355 15.11 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7356 15.116 50:d3:b9:81:11:84 LE 1M LE LL 12 5656\302\265s 0 SCAN_REQ 7357 15.117 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 7358 15.119 32:43:3c:28:8d:92 LE 1M LE LL 37 1994\302\265s 0 ADV_NONCONN_IND 7359 15.122 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3070\302\265s 0 ADV_NONCONN_IND 7360 15.123 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7361 15.123 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7362 15.125 e5:ea:46:16:3e:1e LE 1M LE LL 36 1374\302\265s 0 ADV_IND 7363 15.126 1a:f4:0f:00:14:f3 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7364 15.126 e5:ea:46:16:3e:1e LE 1M LE LL 36 163\302\265s 0 ADV_IND 7365 15.127 e5:ea:46:16:3e:1e LE 1M LE LL 36 355\302\265s 0 ADV_IND[Malformed Packet] 7366 15.128 5c:9e:d4:03:82:5b LE 1M LE LL 37 975\302\265s 0 ADV_NONCONN_IND 7367 15.129 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7368 15.129 25:5f:bf:53:1f:d7 LE 1M LE LL 37 301\302\265s 0 ADV_NONCONN_IND 7369 15.134 50:d3:b9:81:11:84 LE 1M LE LL 12 4344\302\265s 0 SCAN_REQ 7370 15.14 SamsungE_07:d5:79 LE 1M LE LL 34 5611\302\265s 0 ADV_NONCONN_IND 7371 15.141 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 7372 15.147 50:d3:b9:81:11:84 LE 1M LE LL 12 6076\302\265s 0 SCAN_REQ 7373 15.148 45:9b:f4:8b:97:f9 LE 1M LE LL 37 411\302\265s 0 ADV_IND 7374 15.148 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7375 15.153 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4466\302\265s 0 ADV_NONCONN_IND 7376 15.16 11:fe:ef:ed:38:82 LE 1M LE LL 37 6901\302\265s 0 ADV_NONCONN_IND 7377 15.161 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7378 15.161 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7379 15.164 50:d3:b9:81:11:84 LE 1M LE LL 12 2100\302\265s 0 SCAN_REQ 7380 15.167 40:f0:08:9b:56:92 LE 1M LE LL 37 3269\302\265s 0 ADV_SCAN_IND 7381 15.169 72:10:b2:16:c9:46 LE 1M LE LL 12 1035\302\265s 0 SCAN_REQ 7382 15.169 3a:d1:ca:1d:4d:de LE 1M LE LL 26 546\302\265s 0 ADV_NONCONN_IND 7383 15.17 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7384 15.171 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7385 15.171 2a:a6:8d:c9:47:bd LE 1M LE LL 21 210\302\265s 0 ADV_DIRECT_IND 7386 15.172 2e:86:8d:c9:47:bd LE 1M LE LL 21 133\302\265s 0 ADV_NONCONN_IND 7387 15.175 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3235\302\265s 0 SCAN_REQ 7388 15.176 ed:4e:4a:f5:08:6e LE 1M LE LL 14 441\302\265s 0 ADV_NONCONN_IND 7389 15.176 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 7390 15.178 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1296\302\265s 0 ADV_NONCONN_IND 7391 15.183 0d:62:2c:2a:24:88 LE 1M LE LL 37 4544\302\265s 0 ADV_NONCONN_IND 7392 15.183 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7393 15.184 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7394 15.187 1f:84:46:51:98:14 LE 1M LE LL 23 2774\302\265s 0 ADV_NONCONN_IND 7395 15.187 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7396 15.191 31:ea:1b:25:0d:1f LE 1M LE LL 37 3473\302\265s 0 ADV_NONCONN_IND 7397 15.192 c6:f1:43:db:37:1d LE 1M LE LL 36 106\302\265s 0 ADV_IND 7398 15.205 27:f1:d5:6a:d5:82 LE 1M LE LL 37 12706\302\265s 0 ADV_NONCONN_IND 7399 15.205 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7400 15.208 43:bd:56:bd:74:f9 LE 1M LE LL 37 2430\302\265s 0 ADV_NONCONN_IND 7401 15.209 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7402 15.21 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7403 15.211 2b:8b:dd:98:4a:b0 LE 1M LE LL 37 724\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7404 15.212 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 7405 15.212 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7406 15.213 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 756\302\265s 0 ADV_IND 7407 15.214 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 7408 15.215 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 7409 15.217 08:ec:5e:66:cd:0d LE 1M LE LL 23 1310\302\265s 0 ADV_NONCONN_IND 7410 15.217 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7411 15.218 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7412 15.22 c1:c8:16:ae:fd:1d LE 1M LE LL 36 1959\302\265s 0 ADV_IND 7413 15.221 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 7414 15.222 c1:c8:16:ae:fd:1d LE 1M LE LL 36 415\302\265s 0 ADV_IND 7415 15.222 72:10:b2:16:c9:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7416 15.222 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7417 15.225 32:cb:d3:f2:71:8c LE 1M LE LL 23 2184\302\265s 0 ADV_IND 7418 15.227 LE 1M LE LL 36 2122\302\265s 0 Unknown 7419 15.232 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4028\302\265s 0 ADV_NONCONN_IND 7420 15.233 25:5f:bf:53:1f:d7 LE 1M LE LL 37 740\302\265s 0 ADV_NONCONN_IND 7421 15.233 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7422 15.234 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7423 15.249 cf:c8:cc:72:d8:be LE 1M LE LL 14 14645\302\265s 0 ADV_NONCONN_IND 7424 15.249 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 7425 15.249 cf:c8:cc:72:d8:be LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 7426 15.253 74:d9:0b:7a:47:5a LE 1M LE LL 23 3269\302\265s 0 ADV_IND 7427 15.253 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7428 15.254 0b:f9:be:c7:0f:fb LE 1M LE LL 23 324\302\265s 0 ADV_NONCONN_IND 7429 15.254 0b:f9:be:c7:0f:fb LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 7430 15.257 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2296\302\265s 0 ADV_NONCONN_IND 7431 15.257 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7432 15.258 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7433 15.266 ef:6e:3d:68:42:19 LE 1M LE LL 36 7185\302\265s 0 ADV_IND 7434 15.266 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7435 15.266 ef:6e:3d:68:42:19 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7436 15.267 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 7437 15.27 11:fe:ef:ed:38:82 LE 1M LE LL 37 3099\302\265s 0 ADV_NONCONN_IND 7438 15.278 e7:70:80:c3:ad:91 LE 1M LE LL 36 7685\302\265s 0 ADV_IND 7439 15.279 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 7440 15.28 e7:70:80:c3:ad:91 LE 1M LE LL 36 415\302\265s 0 ADV_IND 7441 15.285 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4335\302\265s 0 ADV_NONCONN_IND 7442 15.285 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7443 15.286 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7444 15.287 3a:d1:ca:1d:4d:de LE 1M LE LL 26 724\302\265s 0 ADV_NONCONN_IND 7445 15.288 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7446 15.288 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7447 15.29 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1573\302\265s 0 ADV_NONCONN_IND 7448 15.291 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7449 15.291 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7450 15.294 31:ea:1b:25:0d:1f LE 1M LE LL 37 2519\302\265s 0 ADV_NONCONN_IND 7451 15.295 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7452 15.295 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7453 15.307 79:70:d9:25:16:e2 LE 1M LE LL 25 11261\302\265s 0 ADV_IND 7454 15.308 79:70:d9:25:16:e2 LE 1M LE LL 6 1124\302\265s 0 SCAN_RSP 7455 15.309 6f:54:d4:dd:c1:58 LE 1M LE LL 12 564\302\265s 0 SCAN_REQ 7456 15.311 43:bd:56:bd:74:f9 LE 1M LE LL 37 1416\302\265s 0 ADV_NONCONN_IND 7457 15.312 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7458 15.312 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7459 15.316 1e:28:49:84:c5:cd LE 1M LE LL 37 3293\302\265s 0 ADV_NONCONN_IND 7460 15.317 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7461 15.317 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7462 15.324 fb:18:78:3b:10:36 LE 1M LE LL 28 5984\302\265s 0 ADV_IND 7463 15.327 32:43:3c:28:8d:92 LE 1M LE LL 37 3246\302\265s 0 ADV_NONCONN_IND 7464 15.328 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7465 15.335 2b:5e:0e:c8:62:4c LE 1M LE LL 35 7444\302\265s 0 ADV_NONCONN_IND 7466 15.336 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7467 15.337 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7468 15.339 5c:9e:d4:03:82:5b LE 1M LE LL 37 2422\302\265s 0 ADV_NONCONN_IND 7469 15.34 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7470 15.341 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7471 15.343 c2:f4:e6:80:5e:ae LE 1M LE LL 36 2385\302\265s 0 ADV_IND 7472 15.344 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7473 15.361 0c:6e:66:d7:ed:03 LE 1M LE LL 37 16471\302\265s 0 ADV_NONCONN_IND 7474 15.361 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7475 15.365 d6:bf:76:0a:0b:dc LE 1M LE LL 36 3469\302\265s 0 ADV_IND 7476 15.366 6f:54:d4:dd:c1:58 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 7477 15.367 75:9b:74:83:37:19 LE 1M LE LL 39 164\302\265s 0 ADV_IND[Malformed Packet] 7478 15.377 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 10043\302\265s 0 ADV_IND 7479 15.379 11:fe:ef:ed:38:82 LE 1M LE LL 37 1607\302\265s 0 ADV_NONCONN_IND 7480 15.38 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7481 15.383 cc:15:14:59:64:aa LE 1M LE LL 36 3042\302\265s 0 ADV_IND 7482 15.384 cc:15:14:59:64:aa LE 1M LE LL 36 351\302\265s 0 ADV_IND 7483 15.384 cc:15:14:59:64:aa LE 1M LE LL 36 352\302\265s 0 ADV_IND 7484 15.385 ec:af:39:d1:f5:fe LE 1M LE LL 14 360\302\265s 0 ADV_NONCONN_IND 7485 15.389 0d:62:2c:2a:24:88 LE 1M LE LL 37 4154\302\265s 0 ADV_NONCONN_IND 7486 15.39 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7487 15.393 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2481\302\265s 0 ADV_NONCONN_IND 7488 15.393 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7489 15.394 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7490 15.396 cf:47:81:f5:7d:51 LE 1M LE LL 44 1788\302\265s 0 ADV_IND[Malformed Packet] 7491 15.397 cf:4f:81:f5:7d:55 LE 1M LE LL 36 677\302\265s 0 ADV_IND 7492 15.399 cf:4f:81:f5:7d:55 LE 1M LE LL 6 1199\302\265s 0 SCAN_RSP 7493 15.399 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 107\302\265s 0 ADV_NONCONN_IND 7494 15.4 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7495 15.4 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7496 15.402 70:c4:79:42:57:d8 LE 1M LE LL 33 1871\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7497 15.403 71:c4:79:42:57:d8 LE 1M LE LL 37 399\302\265s 0 ADV_IND 7498 15.404 50:9d:53:4b:09:cc LE 1M LE LL 12 894\302\265s 0 SCAN_REQ 7499 15.405 45:9b:f4:8b:97:f9 LE 1M LE LL 37 806\302\265s 0 ADV_IND 7500 15.407 d5:80:ce:3a:df:84 LE 1M LE LL 36 1242\302\265s 0 ADV_IND 7501 15.413 27:f1:d5:6a:d5:82 LE 1M LE LL 37 5531\302\265s 0 ADV_NONCONN_IND 7502 15.416 43:bd:56:bd:74:f9 LE 1M LE LL 37 2444\302\265s 0 ADV_NONCONN_IND 7503 15.417 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7504 15.417 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7505 15.421 07:69:22:f0:72:30 LE 1M LE LL 37 3217\302\265s 0 ADV_NONCONN_IND 7506 15.422 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 7507 15.422 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7508 15.423 1e:28:49:84:c5:cd LE 1M LE LL 37 458\302\265s 0 ADV_NONCONN_IND 7509 15.424 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7510 15.424 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7511 15.425 cd:5c:f3:7d:98:0b LE 1M LE LL 6 343\302\265s 0 SCAN_RSP 7512 15.425 cd:5c:f3:7d:98:0b LE 1M LE LL 36 136\302\265s 0 ADV_IND 7513 15.426 50:9d:53:4b:09:cc LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 7514 15.43 d6:11:16:57:f1:d0 LE 1M LE LL 36 3054\302\265s 0 ADV_IND 7515 15.43 d6:11:16:57:f1:d0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 7516 15.431 d6:11:16:57:f1:d0 LE 1M LE LL 36 354\302\265s 0 ADV_IND[Malformed Packet] 7517 15.432 32:43:3c:28:8d:92 LE 1M LE LL 37 844\302\265s 0 ADV_NONCONN_IND 7518 15.433 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7519 15.433 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7520 15.439 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4943\302\265s 0 ADV_NONCONN_IND 7521 15.439 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7522 15.44 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7523 15.441 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1358\302\265s 0 ADV_NONCONN_IND 7524 15.442 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7525 15.443 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7526 15.444 74:d9:0b:7a:47:5a LE 1M LE LL 23 1143\302\265s 0 ADV_IND 7527 15.445 6f:54:d4:dd:c1:58 LE 1M LE LL 12 994\302\265s 0 SCAN_REQ 7528 15.446 50:9d:53:4b:09:cc LE 1M LE LL 12 471\302\265s 0 SCAN_REQ 7529 15.448 5c:9e:d4:03:82:5b LE 1M LE LL 37 1976\302\265s 0 ADV_NONCONN_IND 7530 15.449 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7531 15.449 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7532 15.464 e5:ea:46:16:3e:1e LE 1M LE LL 36 14188\302\265s 0 ADV_IND 7533 15.468 72:c4:71:2c:70:59 LE 1M LE LL 12 3846\302\265s 0 SCAN_REQ 7534 15.471 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2223\302\265s 0 ADV_NONCONN_IND 7535 15.482 45:bb:f4:8b:97:f9 LE 1M LE LL 37 10894\302\265s 0 ADV_IND 7536 15.483 45:9b:f4:8b:97:f9 LE 1M LE LL 37 369\302\265s 0 ADV_IND 7537 15.486 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3035\302\265s 0 ADV_NONCONN_IND 7538 15.488 11:fe:ef:ed:38:82 LE 1M LE LL 37 1566\302\265s 0 ADV_NONCONN_IND 7539 15.488 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7540 15.489 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7541 15.494 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4845\302\265s 0 ADV_NONCONN_IND 7542 15.495 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7543 15.495 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7544 15.497 0d:62:2c:2a:24:88 LE 1M LE LL 37 1418\302\265s 0 ADV_NONCONN_IND 7545 15.498 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7546 15.498 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7547 15.5 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1791\302\265s 0 ADV_NONCONN_IND 7548 15.501 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7549 15.501 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7550 15.509 31:ea:1b:25:0d:1f LE 1M LE LL 37 6895\302\265s 0 ADV_NONCONN_IND 7551 15.512 71:c4:79:42:57:d8 LE 1M LE LL 37 3035\302\265s 0 ADV_IND 7552 15.513 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7553 15.513 27:f1:d5:6a:d5:82 LE 1M LE LL 37 537\302\265s 0 ADV_NONCONN_IND 7554 15.514 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7555 15.518 69:a9:48:2f:b7:16 LE 1M LE LL 37 3001\302\265s 0 ADV_NONCONN_IND 7556 15.52 45:9b:f4:8b:97:f9 LE 1M LE LL 37 1879\302\265s 0 ADV_IND 7557 15.521 50:9d:53:4b:09:cc LE 1M LE LL 12 1003\302\265s 0 SCAN_REQ 7558 15.522 07:69:22:f0:72:30 LE 1M LE LL 37 269\302\265s 0 ADV_NONCONN_IND 7559 15.522 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 7560 15.523 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7561 15.525 43:bd:56:bd:74:f9 LE 1M LE LL 37 1360\302\265s 0 ADV_NONCONN_IND 7562 15.525 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7563 15.526 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7564 15.531 1e:28:49:84:c5:cd LE 1M LE LL 37 4535\302\265s 0 ADV_NONCONN_IND 7565 15.532 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7566 15.532 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7567 15.538 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 5678\302\265s 0 ADV_IND 7568 15.539 4d:dc:b7:a2:f3:be LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7569 15.539 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7570 15.541 32:43:3c:28:8d:92 LE 1M LE LL 37 1637\302\265s 0 ADV_NONCONN_IND 7571 15.541 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7572 15.542 2b:5e:0e:c8:62:4c LE 1M LE LL 35 566\302\265s 0 ADV_NONCONN_IND 7573 15.543 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7574 15.543 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7575 15.545 40:f0:08:9b:56:91 LE 1M LE LL 37 820\302\265s 0 ADV_SCAN_IND 7576 15.546 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1343\302\265s 0 ADV_NONCONN_IND 7577 15.547 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7578 15.548 5c:9e:d4:03:82:5b LE 1M LE LL 37 827\302\265s 0 ADV_NONCONN_IND 7579 15.549 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7580 15.549 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7581 15.556 c1:c8:16:ae:fd:1d LE 1M LE LL 36 6336\302\265s 0 ADV_IND 7582 15.557 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7583 15.557 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 402\302\265s 0 ADV_IND 7584 15.558 45:9b:f5:8b:97:f9 LE 1M LE LL 37 151\302\265s 0 ADV_IND 7585 15.558 4d:dc:b7:a2:f3:be LE 1M LE LL 12 107\302\265s 0 SCAN_REQ 7586 15.567 6f:54:d4:dd:c1:58 LE 1M LE LL 12 8682\302\265s 0 SCAN_REQ 7587 15.577 0c:6e:66:d7:ed:03 LE 1M LE LL 37 10205\302\265s 0 ADV_NONCONN_IND 7588 15.578 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7589 15.586 3a:d1:ca:1d:4d:de LE 1M LE LL 26 7306\302\265s 0 ADV_NONCONN_IND 7590 15.586 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7591 15.587 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7592 15.588 11:fe:ef:ed:38:82 LE 1M LE LL 37 324\302\265s 0 ADV_NONCONN_IND 7593 15.588 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7594 15.589 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7595 15.59 45:5b:f4:8f:97:f9 LE 1M LE LL 37 1161\302\265s 0 ADV_IND[Malformed Packet] 7596 15.591 45:9b:f4:8b:97:f9 LE 1M LE LL 37 368\302\265s 0 ADV_IND 7597 15.592 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7598 15.592 45:9b:f4:8b:97:f9 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7599 15.596 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3698\302\265s 0 ADV_NONCONN_IND 7600 15.601 ef:6e:3d:68:42:19 LE 1M LE LL 36 4279\302\265s 0 ADV_IND 7601 15.601 4d:dc:b7:a2:f3:be LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7602 15.601 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7603 15.602 ef:6e:3d:68:42:19 LE 1M LE LL 36 135\302\265s 0 ADV_IND 7604 15.603 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1302\302\265s 0 ADV_NONCONN_IND 7605 15.606 0d:62:2c:2a:24:88 LE 1M LE LL 37 2735\302\265s 0 ADV_NONCONN_IND 7606 15.607 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7607 15.608 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7608 15.609 31:ea:1b:25:0d:1f LE 1M LE LL 37 1418\302\265s 0 ADV_NONCONN_IND 7609 15.61 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7610 15.61 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7611 15.615 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4197\302\265s 0 ADV_NONCONN_IND 7612 15.616 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7613 15.617 27:f1:d5:6a:d5:82 LE 1M LE LL 37 725\302\265s 0 ADV_NONCONN_IND 7614 15.624 07:69:22:f0:72:30 LE 1M LE LL 37 6818\302\265s 0 ADV_NONCONN_IND 7615 15.625 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 7616 15.625 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7617 15.63 e5:ea:46:16:3e:1e LE 1M LE LL 36 4517\302\265s 0 ADV_IND 7618 15.633 43:bd:56:bd:74:f9 LE 1M LE LL 37 2345\302\265s 0 ADV_NONCONN_IND 7619 15.634 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7620 15.637 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 3005\302\265s 0 ADV_NONCONN_IND 7621 15.637 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7622 15.638 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7623 15.639 1e:28:49:84:c5:cd LE 1M LE LL 37 1081\302\265s 0 ADV_NONCONN_IND 7624 15.64 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7625 15.64 1e:28:49:84:c5:cd LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 7626 15.645 32:43:3c:28:8d:92 LE 1M LE LL 37 3983\302\265s 0 ADV_NONCONN_IND 7627 15.645 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7628 15.646 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7629 15.65 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4318\302\265s 0 ADV_NONCONN_IND 7630 15.651 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7631 15.652 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7632 15.653 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1363\302\265s 0 ADV_NONCONN_IND 7633 15.654 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7634 15.654 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7635 15.656 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1437\302\265s 0 ADV_IND 7636 15.657 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7637 15.661 71:c4:79:42:57:d8 LE 1M LE LL 37 3821\302\265s 0 ADV_IND 7638 15.661 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7639 15.662 dd:d8:e1:d0:bc:32 LE 1M LE LL 236 281\302\265s 0 ADV_IND[Malformed Packet] 7640 15.685 4e:14:1a:db:9e:19 LE 1M LE LL 12 21550\302\265s 0 ADV_IND 7641 15.7 16:ed:93:0f:fa:b0 LE 1M LE LL 37 14984\302\265s 0 ADV_NONCONN_IND 7642 15.701 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7643 15.701 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7644 15.703 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1569\302\265s 0 ADV_NONCONN_IND 7645 15.704 04:5f:33:32:e1:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7646 15.705 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7647 15.705 46:cd:f9:15:6d:d0 LE 1M LE LL 12 88\302\265s 0 SCAN_REQ 7648 15.706 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 414\302\265s 0 ADV_IND[Malformed Packet] 7649 15.707 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 740\302\265s 0 ADV_IND 7650 15.71 31:ea:1b:25:0d:1f LE 1M LE LL 37 2863\302\265s 0 ADV_NONCONN_IND 7651 15.711 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7652 15.711 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7653 15.712 0d:62:2c:2a:24:88 LE 1M LE LL 37 602\302\265s 0 ADV_NONCONN_IND 7654 15.713 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7655 15.713 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7656 15.717 7d:30:e4:59:cd:06 LE 1M LE LL 25 3918\302\265s 0 ADV_IND 7657 15.718 46:cd:f9:15:6d:d0 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7658 15.718 7d:30:e4:59:cd:06 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7659 15.719 64:0d:49:f9:4d:a4 LE 1M LE LL 12 562\302\265s 0 SCAN_REQ 7660 15.72 6f:54:d4:dd:c1:58 LE 1M LE LL 12 841\302\265s 0 SCAN_REQ 7661 15.723 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2420\302\265s 0 ADV_NONCONN_IND 7662 15.723 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7663 15.724 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7664 15.732 07:69:22:f0:72:30 LE 1M LE LL 37 7088\302\265s 0 ADV_NONCONN_IND 7665 15.732 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 7666 15.733 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7667 15.74 5e:93:36:dd:d3:09 LE 1M LE LL 10 6387\302\265s 0 ADV_SCAN_IND 7668 15.74 6f:54:d4:dd:c1:50 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7669 15.74 43:bd:56:bd:74:f9 LE 1M LE LL 37 341\302\265s 0 ADV_NONCONN_IND 7670 15.741 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7671 15.743 1e:28:49:84:c5:cd LE 1M LE LL 37 1390\302\265s 0 ADV_NONCONN_IND 7672 15.744 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7673 15.744 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7674 15.747 d5:80:ce:3a:df:84 LE 1M LE LL 36 2681\302\265s 0 ADV_IND 7675 15.748 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7676 15.748 d5:80:ce:3a:df:84 LE 1M LE LL 6 149\302\265s 0 SCAN_RSP 7677 15.748 d5:80:ce:3a:df:84 LE 1M LE LL 36 136\302\265s 0 ADV_IND 7678 15.749 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7679 15.75 32:43:3c:28:8d:92 LE 1M LE LL 37 1233\302\265s 0 ADV_NONCONN_IND 7680 15.752 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1818\302\265s 0 ADV_NONCONN_IND 7681 15.753 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7682 15.753 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7683 15.759 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5110\302\265s 0 ADV_NONCONN_IND 7684 15.759 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7685 15.76 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7686 15.761 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1022\302\265s 0 ADV_NONCONN_IND 7687 15.762 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7688 15.763 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7689 15.766 fa:cd:a9:42:57:d8 LE 1M LE LL 37 3539\302\265s 0 ADV_IND[Malformed Packet] 7690 15.767 8f:e8:de:42:53:d8 LE 1M LE LL 37 368\302\265s 0 ADV_IND[Malformed Packet] 7691 15.768 d6:11:16:57:f1:d0 LE 1M LE LL 36 836\302\265s 0 ADV_IND 7692 15.772 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2805\302\265s 0 SCAN_REQ 7693 15.783 49:08:83:d3:3a:6c LE 1M LE LL 12 11058\302\265s 0 SCAN_REQ 7694 15.783 c6:59:d0:fc:f1:b9 LE 1M LE LL 14 321\302\265s 0 ADV_IND 7695 15.784 7f:e1:7b:e4:24:1c LE 1M LE LL 12 851\302\265s 0 SCAN_REQ 7696 15.786 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1627\302\265s 0 ADV_NONCONN_IND 7697 15.787 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7698 15.794 3a:d1:ca:1d:4d:de LE 1M LE LL 26 7302\302\265s 0 ADV_NONCONN_IND 7699 15.795 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7700 15.796 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7701 15.798 e5:ea:46:16:3e:1e LE 1M LE LL 36 1426\302\265s 0 ADV_IND 7702 15.799 71:c9:89:02:1c:fb LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 7703 15.799 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 7704 15.804 16:ed:93:0f:fa:b0 LE 1M LE LL 37 4295\302\265s 0 ADV_NONCONN_IND 7705 15.805 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7706 15.805 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7707 15.808 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2082\302\265s 0 SCAN_REQ 7708 15.81 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2367\302\265s 0 ADV_NONCONN_IND 7709 15.811 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7710 15.811 47:4e:9b:89:59:8e LE 1M LE LL 12 240\302\265s 0 SCAN_REQ 7711 15.813 71:c9:89:02:1c:fb LE 1M LE LL 12 931\302\265s 0 SCAN_REQ 7712 15.814 0d:62:2c:2a:24:88 LE 1M LE LL 37 1700\302\265s 0 ADV_NONCONN_IND 7713 15.817 31:ea:1b:25:0d:1f LE 1M LE LL 37 2042\302\265s 0 ADV_NONCONN_IND 7714 15.821 47:4e:9b:89:59:8e LE 1M LE LL 12 3851\302\265s 0 SCAN_REQ 7715 15.824 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2945\302\265s 0 ADV_NONCONN_IND 7716 15.829 69:a9:48:2f:b7:16 LE 1M LE LL 37 4253\302\265s 0 ADV_NONCONN_IND 7717 15.83 47:4e:9b:89:59:8e LE 1M LE LL 12 849\302\265s 0 SCAN_REQ 7718 15.837 46:5a:8b:89:59:8e LE 1M LE LL 12 6612\302\265s 0 SCAN_REQ 7719 15.838 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1286\302\265s 0 SCAN_REQ 7720 15.839 45:9b:f4:8b:97:f9 LE 1M LE LL 37 411\302\265s 0 ADV_IND 7721 15.84 07:69:22:f0:72:30 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7722 15.84 57:4e:9b:89:59:8e LE 1M LE LL 12 63\302\265s 0 SCAN_REQ 7723 15.841 c6:f1:43:db:57:1d LE 1M LE LL 36 1093\302\265s 0 ADV_IND 7724 15.842 c6:f1:43:db:57:1d LE 1M LE LL 36 353\302\265s 0 ADV_IND 7725 15.844 08:ec:5e:66:cd:0d LE 1M LE LL 23 1364\302\265s 0 ADV_NONCONN_IND 7726 15.844 1e:28:49:84:c5:cd LE 1M LE LL 37 92\302\265s 0 ADV_NONCONN_IND 7727 15.845 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7728 15.845 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7729 15.852 17:5f:43:7c:0a:89 LE 1M LE LL 23 5829\302\265s 0 ADV_NONCONN_IND 7730 15.853 79:70:d9:25:16:e2 LE 1M LE LL 25 1402\302\265s 0 ADV_IND 7731 15.854 47:4e:9b:89:59:8e LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7732 15.854 79:70:d9:25:16:e2 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7733 15.854 79:70:d9:25:16:e2 LE 1M LE LL 25 131\302\265s 0 ADV_IND 7734 15.856 5c:9e:d4:03:82:5b LE 1M LE LL 37 1106\302\265s 0 ADV_NONCONN_IND 7735 15.856 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7736 15.857 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7737 15.859 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1384\302\265s 0 ADV_NONCONN_IND 7738 15.859 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7739 15.86 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 7740 15.861 24:c3:d0:ce:d4:37 LE 1M LE LL 37 734\302\265s 0 ADV_NONCONN_IND 7741 15.861 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7742 15.862 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7743 15.863 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1205\302\265s 0 SCAN_REQ 7744 15.866 71:c4:79:42:57:d8 LE 1M LE LL 37 2475\302\265s 0 ADV_IND 7745 15.867 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7746 15.87 ff:f8:ac:d9:a1:a8 LE 1M LE LL 24 2777\302\265s 0 ADV_IND[Malformed Packet] 7747 15.883 0b:f9:be:c7:0f:fb LE 1M LE LL 23 13606\302\265s 0 ADV_NONCONN_IND 7748 15.884 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7749 15.884 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 7750 15.886 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1611\302\265s 0 ADV_NONCONN_IND 7751 15.887 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7752 15.887 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7753 15.89 c1:c8:16:ae:fd:1d LE 1M LE LL 36 2056\302\265s 0 ADV_IND 7754 15.89 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7755 15.891 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7756 15.891 c1:c8:16:ae:fd:1d LE 1M LE LL 36 135\302\265s 0 ADV_IND 7757 15.892 50:d3:b9:81:11:84 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 7758 15.893 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 1044\302\265s 0 ADV_IND 7759 15.894 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7760 15.894 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7761 15.894 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 136\302\265s 0 ADV_IND 7762 15.895 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7763 15.895 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7764 15.896 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 137\302\265s 0 ADV_IND 7765 15.899 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3465\302\265s 0 ADV_NONCONN_IND 7766 15.9 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7767 15.901 11:fe:ef:ed:38:82 LE 1M LE LL 37 310\302\265s 0 ADV_NONCONN_IND 7768 15.908 EvertzMi_65:68:59 LE 1M LE LL 36 6574\302\265s 0 AUX_CONNECT_RSP[Malformed Packet] 7769 15.908 c5:65:68:79:19:c8 LE 1M LE LL 36 352\302\265s 0 ADV_IND 7770 15.909 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7771 15.909 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7772 15.91 c5:65:68:79:19:c8 LE 1M LE LL 36 139\302\265s 0 ADV_IND 7773 15.91 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7774 15.91 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7775 15.913 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2353\302\265s 0 ADV_NONCONN_IND 7776 15.913 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7777 15.914 16:ed:93:0f:fa:b0 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7778 15.917 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2191\302\265s 0 ADV_NONCONN_IND 7779 15.917 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7780 15.918 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7781 15.922 31:ea:1b:25:0d:1f LE 1M LE LL 37 4395\302\265s 0 ADV_NONCONN_IND 7782 15.923 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7783 15.924 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7784 15.929 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4821\302\265s 0 ADV_NONCONN_IND 7785 15.93 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7786 15.93 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7787 15.934 69:a9:48:2f:b7:16 LE 1M LE LL 37 3000\302\265s 0 ADV_NONCONN_IND 7788 15.936 71:c4:79:42:57:d8 LE 1M LE LL 37 1960\302\265s 0 ADV_IND 7789 15.937 50:d3:b9:81:11:84 LE 1M LE LL 12 894\302\265s 0 SCAN_REQ 7790 15.943 ef:6e:3d:68:42:19 LE 1M LE LL 36 5377\302\265s 0 ADV_IND 7791 15.946 1e:28:49:84:c5:cd LE 1M LE LL 37 2687\302\265s 0 ADV_NONCONN_IND 7792 15.947 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7793 15.949 07:69:22:f0:72:30 LE 1M LE LL 37 1561\302\265s 0 ADV_NONCONN_IND 7794 15.949 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 7795 15.95 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7796 15.955 32:43:3c:28:8d:92 LE 1M LE LL 37 5286\302\265s 0 ADV_NONCONN_IND 7797 15.956 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7798 15.956 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7799 15.957 eb:db:35:2e:09:1b LE 1M LE LL 20 204\302\265s 0 ADV_IND 7800 15.958 e5:ea:46:16:3e:1e LE 1M LE LL 36 411\302\265s 0 ADV_IND 7801 15.958 e5:ea:46:16:3e:1e LE 1M LE LL 36 353\302\265s 0 ADV_IND 7802 15.959 e7:70:80:c3:ad:91 LE 1M LE LL 36 173\302\265s 0 ADV_IND 7803 15.961 5c:9e:d4:03:82:5b LE 1M LE LL 37 1322\302\265s 0 ADV_NONCONN_IND 7804 15.962 c0:41:04:2e:be:9d LE 1M LE LL 36 1501\302\265s 0 ADV_IND 7805 15.963 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7806 15.969 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5671\302\265s 0 ADV_NONCONN_IND 7807 15.969 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7808 15.987 0c:6e:66:d7:ed:03 LE 1M LE LL 37 16993\302\265s 0 ADV_NONCONN_IND 7809 15.987 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 7810 15.988 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7811 15.99 d6:bf:03:c5:20:42 LE 1M LE LL 36 1828\302\265s 0 ADV_IND 7812 15.991 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7813 15.996 f1:ff:a7:1a:55:8d LE 1M LE LL 36 4744\302\265s 0 ADV_IND 7814 16.01 6c:c6:23:80:30:28 LE 1M LE LL 12 13041\302\265s 0 SCAN_REQ 7815 16.01 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 7816 16.015 6f:54:d4:dd:c1:58 LE 1M LE LL 12 4560\302\265s 0 SCAN_REQ 7817 16.021 3a:d1:ca:1d:4d:de LE 1M LE LL 26 5207\302\265s 0 ADV_NONCONN_IND 7818 16.021 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7819 16.022 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7820 16.023 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 978\302\265s 0 ADV_NONCONN_IND 7821 16.024 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7822 16.025 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7823 16.026 6c:c6:23:80:30:28 LE 1M LE LL 12 1424\302\265s 0 SCAN_REQ 7824 16.027 c2:f4:e6:80:5e:ae LE 1M LE LL 36 415\302\265s 0 ADV_IND 7825 16.032 27:f1:d5:6a:d5:82 LE 1M LE LL 37 4357\302\265s 0 ADV_NONCONN_IND 7826 16.037 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4939\302\265s 0 ADV_IND 7827 16.038 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7828 16.04 9f:c4:79:42:57:d8 LE 1M LE LL 37 2754\302\265s 0 ADV_IND[Malformed Packet] 7829 16.041 71:c4:79:42:57:d8 LE 1M LE LL 37 367\302\265s 0 ADV_IND 7830 16.042 d6:bf:76:0a:0b:dc LE 1M LE LL 36 821\302\265s 0 ADV_IND 7831 16.043 69:a9:48:2f:b7:16 LE 1M LE LL 37 634\302\265s 0 ADV_NONCONN_IND 7832 16.044 d6:bf:76:0a:0b:dc LE 1M LE LL 36 453\302\265s 0 ADV_IND 7833 16.047 1e:28:49:84:c5:cd LE 1M LE LL 37 2759\302\265s 0 ADV_NONCONN_IND 7834 16.048 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7835 16.048 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7836 16.049 43:bd:56:bd:74:f9 LE 1M LE LL 37 674\302\265s 0 ADV_NONCONN_IND 7837 16.05 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7838 16.051 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7839 16.052 07:69:22:f0:72:30 LE 1M LE LL 37 99\302\265s 0 ADV_NONCONN_IND 7840 16.052 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 7841 16.053 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7842 16.057 6c:c6:23:80:30:28 LE 1M LE LL 12 3673\302\265s 0 SCAN_REQ 7843 16.059 cc:15:14:59:64:aa LE 1M LE LL 36 1987\302\265s 0 ADV_IND 7844 16.063 5c:9e:d4:03:82:5b LE 1M LE LL 37 3764\302\265s 0 ADV_NONCONN_IND 7845 16.065 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1385\302\265s 0 ADV_NONCONN_IND 7846 16.065 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7847 16.066 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7848 16.074 cf:4f:81:f5:7d:55 LE 1M LE LL 36 7317\302\265s 0 ADV_IND 7849 16.074 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7850 16.074 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7851 16.075 cf:4f:81:f5:7d:55 LE 1M LE LL 36 137\302\265s 0 ADV_IND 7852 16.075 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 7853 16.076 cf:4f:81:f5:7d:55 LE 1M LE LL 6 871\302\265s 0 SCAN_RSP 7854 16.078 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1242\302\265s 0 ADV_NONCONN_IND 7855 16.078 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7856 16.079 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7857 16.085 6c:c6:23:80:30:28 LE 1M LE LL 12 5700\302\265s 0 SCAN_REQ 7858 16.085 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 7859 16.088 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2203\302\265s 0 ADV_NONCONN_IND 7860 16.09 d5:80:ce:3a:df:84 LE 1M LE LL 36 1185\302\265s 0 ADV_IND 7861 16.09 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7862 16.09 d5:80:ce:3a:df:84 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 7863 16.091 d5:80:ce:3a:df:84 LE 1M LE LL 36 135\302\265s 0 ADV_IND 7864 16.092 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7865 16.101 cd:5c:f3:7d:98:0b LE 1M LE LL 36 9261\302\265s 0 ADV_IND 7866 16.107 d6:2c:05:d0:15:49 LE 1M LE LL 37 5359\302\265s 0 ADV_IND 7867 16.108 7f:ab:0f:33:5d:32 LE 1M LE LL 12 921\302\265s 0 SCAN_REQ 7868 16.109 3a:d1:ca:1d:4d:de LE 1M LE LL 26 882\302\265s 0 ADV_NONCONN_IND 7869 16.11 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7870 16.111 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7871 16.116 40:f0:08:9b:56:91 LE 1M LE LL 37 5006\302\265s 0 ADV_SCAN_IND[Malformed Packet] 7872 16.119 0d:62:2c:2a:24:88 LE 1M LE LL 37 2883\302\265s 0 ADV_NONCONN_IND 7873 16.12 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7874 16.123 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2482\302\265s 0 ADV_NONCONN_IND 7875 16.123 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7876 16.124 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7877 16.127 31:ea:1b:25:0d:1f LE 1M LE LL 37 2445\302\265s 0 ADV_NONCONN_IND 7878 16.127 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7879 16.128 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7880 16.138 27:f1:d5:6a:d5:82 LE 1M LE LL 37 9192\302\265s 0 ADV_NONCONN_IND 7881 16.138 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7882 16.139 27:f1:d5:6a:d5:82 LE 1M LE LL 37 644\302\265s 0 ADV_NONCONN_IND 7883 16.148 43:bd:56:bd:74:f9 LE 1M LE LL 37 8505\302\265s 0 ADV_NONCONN_IND 7884 16.149 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7885 16.15 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7886 16.151 69:a9:48:2f:b7:16 LE 1M LE LL 37 1015\302\265s 0 ADV_NONCONN_IND 7887 16.152 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7888 16.153 69:a9:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7889 16.155 6c:c6:23:80:30:28 LE 1M LE LL 12 2122\302\265s 0 SCAN_REQ 7890 16.157 1e:28:49:84:c5:cd LE 1M LE LL 37 1006\302\265s 0 ADV_NONCONN_IND 7891 16.157 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7892 16.159 07:69:22:f0:72:30 LE 1M LE LL 37 937\302\265s 0 ADV_NONCONN_IND 7893 16.159 59:4b:7a:fc:61:f6 LE 1M LE LL 14 102\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 7894 16.159 f4:08:ad:3c:61:f6 LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 7895 16.165 32:43:3c:28:8d:92 LE 1M LE LL 37 5180\302\265s 0 ADV_NONCONN_IND 7896 16.165 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7897 16.166 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7898 16.166 c2:f2:43:db:57:1d LE 1M LE LL 60 179\302\265s 0 ADV_IND[Malformed Packet] 7899 16.171 5c:9e:d4:03:82:5b LE 1M LE LL 37 4316\302\265s 0 ADV_NONCONN_IND 7900 16.172 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7901 16.178 25:5f:bf:53:1f:d7 LE 1M LE LL 37 6059\302\265s 0 ADV_NONCONN_IND 7902 16.179 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7903 16.179 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7904 16.181 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1630\302\265s 0 ADV_NONCONN_IND 7905 16.182 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7906 16.183 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7907 16.201 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 17850\302\265s 0 ADV_IND 7908 16.203 11:fe:ef:ed:38:82 LE 1M LE LL 37 1626\302\265s 0 ADV_NONCONN_IND 7909 16.203 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7910 16.214 74:d9:0b:7a:47:5a LE 1M LE LL 23 9891\302\265s 0 ADV_IND 7911 16.215 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1366\302\265s 0 ADV_NONCONN_IND 7912 16.216 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7913 16.223 0d:62:2c:2a:24:88 LE 1M LE LL 37 7088\302\265s 0 ADV_NONCONN_IND 7914 16.224 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7915 16.224 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7916 16.227 31:ea:1b:25:0d:1f LE 1M LE LL 37 2043\302\265s 0 ADV_NONCONN_IND 7917 16.227 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7918 16.228 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7919 16.232 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 3803\302\265s 0 ADV_IND 7920 16.233 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 7921 16.234 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 354\302\265s 0 ADV_IND 7922 16.235 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1390\302\265s 0 ADV_NONCONN_IND 7923 16.241 c5:65:68:79:19:c8 LE 1M LE LL 36 5250\302\265s 0 ADV_IND 7924 16.242 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7925 16.244 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1391\302\265s 0 ADV_NONCONN_IND 7926 16.245 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7927 16.245 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 7928 16.253 69:a9:48:2f:b7:16 LE 1M LE LL 37 6749\302\265s 0 ADV_NONCONN_IND 7929 16.254 43:bd:56:bd:74:f9 LE 1M LE LL 37 1163\302\265s 0 ADV_NONCONN_IND 7930 16.255 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 7931 16.26 1e:28:49:84:c5:cd LE 1M LE LL 37 4541\302\265s 0 ADV_NONCONN_IND 7932 16.26 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7933 16.261 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 7934 16.264 72:10:b2:16:c9:46 LE 1M LE LL 12 2852\302\265s 0 SCAN_REQ 7935 16.265 71:c4:79:42:57:d8 LE 1M LE LL 37 411\302\265s 0 ADV_IND 7936 16.266 32:43:3c:28:8d:92 LE 1M LE LL 37 656\302\265s 0 ADV_NONCONN_IND 7937 16.267 72:10:b2:16:c9:46 LE 1M LE LL 12 1213\302\265s 0 SCAN_REQ 7938 16.268 45:9b:f4:8b:97:f9 LE 1M LE LL 37 411\302\265s 0 ADV_IND[Malformed Packet] 7939 16.274 5c:9e:d4:03:82:5b LE 1M LE LL 37 6007\302\265s 0 ADV_NONCONN_IND 7940 16.279 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3883\302\265s 0 ADV_NONCONN_IND 7941 16.279 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7942 16.28 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 7943 16.28 25:5f:bf:53:1f:d7 LE 1M LE LL 37 114\302\265s 0 ADV_NONCONN_IND 7944 16.281 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7945 16.281 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7946 16.288 e5:ea:46:16:3e:1e LE 1M LE LL 36 5992\302\265s 0 ADV_IND 7947 16.289 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 7948 16.29 64:0d:49:f9:4d:a4 LE 1M LE LL 12 545\302\265s 0 SCAN_REQ 7949 16.291 e7:70:80:c3:ad:91 LE 1M LE LL 36 896\302\265s 0 ADV_IND 7950 16.296 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4469\302\265s 0 ADV_NONCONN_IND 7951 16.296 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 7952 16.299 Anonymous LE 1M LE LL 36 2204\302\265s 0 AUX_CONNECT_RSP[Malformed Packet: length of contained item exceeds length of containing item] 7953 16.299 c0:41:04:2e:be:9d LE 1M LE LL 36 361\302\265s 0 ADV_IND 7954 16.3 6f:54:d4:dd:c1:58 LE 1M LE LL 12 152\302\265s 0 SCAN_REQ 7955 16.301 64:0d:49:f9:4d:a4 LE 1M LE LL 12 682\302\265s 0 SCAN_REQ 7956 16.304 72:10:b2:16:c9:46 LE 1M LE LL 12 2690\302\265s 0 SCAN_REQ 7957 16.304 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 7958 16.305 45:9b:f4:8b:97:f9 LE 1M LE LL 37 368\302\265s 0 ADV_IND[Malformed Packet] 7959 16.322 3a:d1:ca:1d:4d:de LE 1M LE LL 26 16546\302\265s 0 ADV_NONCONN_IND 7960 16.323 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 7961 16.323 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 7962 16.324 72:10:b2:16:c9:46 LE 1M LE LL 12 754\302\265s 0 SCAN_REQ 7963 16.33 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5059\302\265s 0 ADV_NONCONN_IND 7964 16.33 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7965 16.331 31:ea:1b:25:0d:1f LE 1M LE LL 37 572\302\265s 0 ADV_NONCONN_IND 7966 16.332 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7967 16.332 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7968 16.335 72:10:b2:16:c9:46 LE 1M LE LL 12 2307\302\265s 0 SCAN_REQ 7969 16.342 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 6326\302\265s 0 ADV_NONCONN_IND 7970 16.342 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 7971 16.361 43:bd:56:bd:74:f9 LE 1M LE LL 37 18326\302\265s 0 ADV_NONCONN_IND 7972 16.362 1e:28:49:84:c5:cd LE 1M LE LL 37 496\302\265s 0 ADV_NONCONN_IND 7973 16.362 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7974 16.365 72:10:b2:16:c9:46 LE 1M LE LL 12 2500\302\265s 0 SCAN_REQ 7975 16.366 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 7976 16.366 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7977 16.367 64:0d:49:f9:4d:a4 LE 1M LE LL 12 677\302\265s 0 SCAN_REQ 7978 16.369 07:69:22:f0:72:30 LE 1M LE LL 37 1918\302\265s 0 ADV_NONCONN_IND 7979 16.37 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 7980 16.37 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 7981 16.373 5c:9e:d4:03:82:5b LE 1M LE LL 37 2450\302\265s 0 ADV_NONCONN_IND 7982 16.374 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7983 16.374 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 7984 16.38 d6:bf:76:0a:0b:dc LE 1M LE LL 36 5097\302\265s 0 ADV_IND 7985 16.381 25:5f:bf:53:1f:d7 LE 1M LE LL 37 525\302\265s 0 ADV_NONCONN_IND 7986 16.381 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 7987 16.383 SamsungE_07:d5:79 LE 1M LE LL 34 1025\302\265s 0 ADV_NONCONN_IND 7988 16.384 SamsungE_07:d5:79 LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 7989 16.385 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 7990 16.39 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5250\302\265s 0 ADV_NONCONN_IND 7991 16.391 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7992 16.391 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 7993 16.393 cc:15:14:59:64:aa LE 1M LE LL 36 1178\302\265s 0 ADV_IND[Malformed Packet] 7994 16.394 cc:15:14:59:64:aa LE 1M LE LL 36 351\302\265s 0 ADV_IND 7995 16.394 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 7996 16.394 cc:15:14:59:64:aa LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 7997 16.395 cc:15:14:59:64:aa LE 1M LE LL 36 135\302\265s 0 ADV_IND 7998 16.401 79:70:d9:25:16:e2 LE 1M LE LL 25 6025\302\265s 0 ADV_IND 7999 16.402 0c:6e:66:d7:ed:03 LE 1M LE LL 37 447\302\265s 0 ADV_NONCONN_IND 8000 16.402 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8001 16.403 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8002 16.407 cf:4f:81:f5:7d:55 LE 1M LE LL 36 3953\302\265s 0 ADV_IND 8003 16.408 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8004 16.408 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 265\302\265s 0 ADV_IND 8005 16.409 7f:e1:7b:e4:24:1c LE 1M LE LL 12 790\302\265s 0 SCAN_REQ 8006 16.41 7f:f8:8c:ba:a1:a8 LE 1M LE LL 24 411\302\265s 0 ADV_IND 8007 16.413 11:fe:ef:ed:38:82 LE 1M LE LL 37 2584\302\265s 0 ADV_NONCONN_IND 8008 16.413 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8009 16.414 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8010 16.425 d5:80:ce:3a:df:84 LE 1M LE LL 36 10243\302\265s 0 ADV_IND 8011 16.425 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8012 16.425 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8013 16.426 d5:80:ce:3a:df:84 LE 1M LE LL 36 136\302\265s 0 ADV_IND 8014 16.426 7f:e1:7b:e4:24:1c LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8015 16.426 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8016 16.427 d5:80:ce:3a:df:84 LE 1M LE LL 36 137\302\265s 0 ADV_IND 8017 16.431 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3576\302\265s 0 ADV_NONCONN_IND 8018 16.431 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8019 16.432 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8020 16.435 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2309\302\265s 0 ADV_NONCONN_IND 8021 16.437 cd:5c:f3:7d:98:0b LE 1M LE LL 36 1887\302\265s 0 ADV_IND 8022 16.438 71:c9:89:02:1c:fb LE 1M LE LL 12 1006\302\265s 0 SCAN_REQ 8023 16.444 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5490\302\265s 0 ADV_NONCONN_IND 8024 16.445 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8025 16.445 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8026 16.451 e5:ea:46:16:3e:1e LE 1M LE LL 36 5819\302\265s 0 ADV_IND 8027 16.452 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8028 16.452 e5:ea:46:16:3e:1e LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8029 16.452 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 8030 16.453 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8031 16.453 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8032 16.454 e5:ea:46:16:3e:1e LE 1M LE LL 36 138\302\265s 0 ADV_IND 8033 16.454 e5:ea:46:16:3e:1e LE 1M LE LL 6 476\302\265s 0 SCAN_RSP 8034 16.456 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1677\302\265s 0 ADV_NONCONN_IND 8035 16.457 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8036 16.458 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8037 16.46 50:d3:b9:81:11:84 LE 1M LE LL 12 1966\302\265s 0 SCAN_REQ 8038 16.461 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 8039 16.461 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8040 16.462 45:9b:f4:8b:97:f9 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8041 16.462 45:9b:f4:8b:97:f9 LE 1M LE LL 37 132\302\265s 0 ADV_IND 8042 16.464 50:d3:b9:81:11:84 LE 1M LE LL 12 2162\302\265s 0 SCAN_REQ 8043 16.465 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 8044 16.466 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8045 16.466 08:ec:5e:66:cd:0d LE 1M LE LL 23 219\302\265s 0 ADV_NONCONN_IND 8046 16.466 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8047 16.471 50:d3:b9:81:11:84 LE 1M LE LL 12 4437\302\265s 0 SCAN_REQ 8048 16.474 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2461\302\265s 0 SCAN_REQ 8049 16.476 2e:86:8d:c9:47:bd LE 1M LE LL 21 2453\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8050 16.48 43:bd:56:bd:74:f9 LE 1M LE LL 37 2902\302\265s 0 ADV_NONCONN_IND 8051 16.48 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8052 16.481 30:b6:52:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8053 16.482 50:d3:b9:81:11:84 LE 1M LE LL 12 255\302\265s 0 SCAN_REQ 8054 16.491 7f:e1:7b:e4:24:1c LE 1M LE LL 12 9194\302\265s 0 SCAN_REQ 8055 16.492 71:c9:89:02:1c:fb LE 1M LE LL 12 1106\302\265s 0 SCAN_REQ 8056 16.495 c6:f1:43:db:57:1d LE 1M LE LL 36 2394\302\265s 0 ADV_IND 8057 16.497 7f:e1:7b:e4:24:1c LE 1M LE LL 12 1127\302\265s 0 SCAN_REQ 8058 16.497 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 8059 16.499 50:d3:b9:81:11:84 LE 1M LE LL 12 1243\302\265s 0 SCAN_REQ 8060 16.499 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND[Malformed Packet] 8061 16.5 45:9b:f4:8b:97:f9 LE 1M LE LL 37 736\302\265s 0 ADV_IND 8062 16.506 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5329\302\265s 0 ADV_NONCONN_IND 8063 16.507 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8064 16.507 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8065 16.516 0b:f9:be:c7:0f:fb LE 1M LE LL 23 8266\302\265s 0 ADV_NONCONN_IND 8066 16.516 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8067 16.517 0b:f9:be:c7:0f:fb LE 1M LE LL 23 133\302\265s 0 ADV_NONCONN_IND 8068 16.528 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 11146\302\265s 0 ADV_IND 8069 16.529 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8070 16.529 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8071 16.534 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4732\302\265s 0 ADV_NONCONN_IND 8072 16.535 4b:ab:2c:50:19:e0 LE 1M LE LL 165 387\302\265s 0 SCAN_RSP[Malformed Packet] 8073 16.537 31:ea:1b:25:0d:1f LE 1M LE LL 37 1454\302\265s 0 ADV_NONCONN_IND 8074 16.538 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8075 16.539 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8076 16.547 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 7631\302\265s 0 ADV_NONCONN_IND 8077 16.547 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8078 16.548 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8079 16.559 27:f1:d5:6a:d5:82 LE 1M LE LL 37 10679\302\265s 0 ADV_NONCONN_IND 8080 16.56 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8081 16.56 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8082 16.567 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 6318\302\265s 0 ADV_IND 8083 16.568 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8084 16.569 c1:c8:16:ae:fd:1d LE 1M LE LL 36 1655\302\265s 0 ADV_IND 8085 16.57 c1:c8:16:ae:fd:1d LE 1M LE LL 36 354\302\265s 0 ADV_IND 8086 16.581 32:43:3c:28:8d:92 LE 1M LE LL 37 10385\302\265s 0 ADV_NONCONN_IND 8087 16.581 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8088 16.582 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8089 16.587 25:5f:bf:53:1f:d7 LE 1M LE LL 37 4620\302\265s 0 ADV_NONCONN_IND 8090 16.588 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8091 16.588 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8092 16.594 74:d9:0b:7a:47:5a LE 1M LE LL 23 5072\302\265s 0 ADV_IND 8093 16.599 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5592\302\265s 0 ADV_NONCONN_IND 8094 16.6 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8095 16.611 0c:6e:66:d7:ed:03 LE 1M LE LL 37 10750\302\265s 0 ADV_NONCONN_IND 8096 16.612 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8097 16.612 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8098 16.613 cf:6e:3d:68:42:19 LE 1M LE LL 36 84\302\265s 0 ADV_IND 8099 16.614 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 8100 16.615 ef:6e:3d:68:42:19 LE 1M LE LL 6 1198\302\265s 0 SCAN_RSP 8101 16.619 e5:ea:46:16:3e:1e LE 1M LE LL 36 3628\302\265s 0 ADV_IND 8102 16.619 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8103 16.62 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8104 16.62 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 8105 16.621 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 8106 16.622 11:fe:ff:ed:38:82 LE 1M LE LL 37 768\302\265s 0 ADV_NONCONN_IND 8107 16.623 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8108 16.623 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8109 16.625 50:d3:b9:81:11:84 LE 1M LE LL 12 1443\302\265s 0 SCAN_REQ 8110 16.631 e7:70:80:c3:ad:91 LE 1M LE LL 36 6092\302\265s 0 ADV_IND 8111 16.632 e7:70:80:c3:ad:91 LE 1M LE LL 36 354\302\265s 0 ADV_IND 8112 16.634 c0:41:04:2e:be:9d LE 1M LE LL 36 1258\302\265s 0 ADV_IND 8113 16.634 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8114 16.635 c0:41:04:2e:be:9d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8115 16.641 31:ea:1b:25:0d:1f LE 1M LE LL 37 6448\302\265s 0 ADV_NONCONN_IND 8116 16.642 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8117 16.65 16:ed:93:0f:fa:b0 LE 1M LE LL 37 8329\302\265s 0 ADV_NONCONN_IND 8118 16.651 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8119 16.652 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8120 16.655 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2811\302\265s 0 ADV_NONCONN_IND 8121 16.659 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3850\302\265s 0 ADV_NONCONN_IND 8122 16.66 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8123 16.662 c6:f1:47:db:57:1d LE 1M LE LL 36 2533\302\265s 0 ADV_IND 8124 16.666 f1:ff:a7:1a:55:8d LE 1M LE LL 36 2755\302\265s 0 ADV_IND 8125 16.666 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8126 16.674 43:bd:56:bd:74:f9 LE 1M LE LL 37 7376\302\265s 0 ADV_NONCONN_IND 8127 16.678 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 4216\302\265s 0 ADV_IND 8128 16.681 5c:9e:d4:03:82:5b LE 1M LE LL 37 2674\302\265s 0 ADV_NONCONN_IND 8129 16.682 LE 1M LE LL 25 150\302\265s 0 Unknown 8130 16.684 07:69:22:f0:72:30 LE 1M LE LL 37 2092\302\265s 0 ADV_NONCONN_IND 8131 16.685 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 8132 16.685 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8133 16.688 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 2579\302\265s 0 ADV_IND 8134 16.691 32:43:3c:28:8d:92 LE 1M LE LL 37 2270\302\265s 0 ADV_NONCONN_IND 8135 16.691 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8136 16.693 SamsungE_07:dd:79 LE 1M LE LL 34 873\302\265s 0 ADV_NONCONN_IND 8137 16.694 SamsungE_07:d5:79 LE 1M LE LL 34 585\302\265s 0 ADV_NONCONN_IND 8138 16.694 25:5f:bf:53:1f:d7 LE 1M LE LL 37 446\302\265s 0 ADV_NONCONN_IND 8139 16.701 7f:ab:0f:33:5d:32 LE 1M LE LL 12 6112\302\265s 0 SCAN_REQ 8140 16.707 25:b4:8e:80:5e:ae LE 1M LE LL 36 5490\302\265s 0 ADV_IND[Malformed Packet] 8141 16.707 2b:5e:0e:c8:62:4c LE 1M LE LL 35 267\302\265s 0 ADV_NONCONN_IND 8142 16.708 24:c3:d0:ce:d4:37 LE 1M LE LL 37 727\302\265s 0 ADV_NONCONN_IND 8143 16.709 24:c3:d0:ce:d4:37 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 8144 16.709 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8145 16.714 7f:ab:0f:33:5d:32 LE 1M LE LL 12 4132\302\265s 0 SCAN_REQ 8146 16.714 71:c4:79:42:57:d8 LE 1M LE LL 37 411\302\265s 0 ADV_IND 8147 16.721 0c:6e:66:d7:ed:03 LE 1M LE LL 37 5655\302\265s 0 ADV_NONCONN_IND 8148 16.724 6f:54:d4:dd:c1:58 LE 1M LE LL 12 3594\302\265s 0 SCAN_REQ 8149 16.733 6f:54:d4:dd:c1:58 LE 1M LE LL 12 8422\302\265s 0 SCAN_REQ 8150 16.74 0d:62:2c:2a:24:88 LE 1M LE LL 37 6804\302\265s 0 ADV_NONCONN_IND 8151 16.746 3a:d1:ca:1d:4d:de LE 1M LE LL 26 5257\302\265s 0 ADV_NONCONN_IND 8152 16.746 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8153 16.747 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8154 16.748 31:ea:1b:25:0d:1f LE 1M LE LL 37 627\302\265s 0 ADV_NONCONN_IND 8155 16.749 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8156 16.749 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8157 16.75 cf:4f:81:f5:7d:55 LE 1M LE LL 36 254\302\265s 0 ADV_IND 8158 16.752 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2014\302\265s 0 ADV_NONCONN_IND 8159 16.753 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8160 16.756 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2808\302\265s 0 ADV_NONCONN_IND 8161 16.757 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8162 16.757 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8163 16.759 26:71:d5:6a:d5:82 LE 1M LE LL 165 1301\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8164 16.766 d5:80:ce:3a:df:84 LE 1M LE LL 36 6307\302\265s 0 ADV_IND 8165 16.768 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 8166 16.773 cd:5c:f3:7d:98:0b LE 1M LE LL 36 4651\302\265s 0 ADV_IND 8167 16.775 43:bd:56:bd:74:f9 LE 1M LE LL 37 2482\302\265s 0 ADV_NONCONN_IND 8168 16.776 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8169 16.779 69:a9:48:2f:b7:16 LE 1M LE LL 37 2226\302\265s 0 ADV_NONCONN_IND 8170 16.78 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8171 16.78 45:9b:f4:8b:97:f9 LE 1M LE LL 37 151\302\265s 0 ADV_IND 8172 16.782 5c:9e:d4:03:82:5b LE 1M LE LL 37 1308\302\265s 0 ADV_NONCONN_IND 8173 16.782 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8174 16.783 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8175 16.785 07:69:22:f0:72:30 LE 1M LE LL 37 1272\302\265s 0 ADV_NONCONN_IND 8176 16.785 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 8177 16.786 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8178 16.786 e5:ea:46:16:3e:1e LE 1M LE LL 36 123\302\265s 0 ADV_IND 8179 16.787 79:44:d5:5d:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8180 16.787 e5:ea:46:16:3e:1e LE 1M LE LL 36 415\302\265s 0 ADV_IND 8181 16.789 1e:28:49:84:c5:cd LE 1M LE LL 37 1206\302\265s 0 ADV_NONCONN_IND 8182 16.79 32:43:3c:28:8d:92 LE 1M LE LL 37 862\302\265s 0 ADV_NONCONN_IND 8183 16.791 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8184 16.791 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8185 16.797 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5246\302\265s 0 ADV_NONCONN_IND 8186 16.798 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8187 16.798 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8188 16.8 50:a9:33:2b:29:d4 LE 1M LE LL 12 1266\302\265s 0 SCAN_REQ 8189 16.8 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 8190 16.807 c4:23:b7:60:6c:09 LE 1M LE LL 14 6315\302\265s 0 ADV_NONCONN_IND 8191 16.81 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3225\302\265s 0 ADV_NONCONN_IND 8192 16.811 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8193 16.812 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8194 16.818 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5726\302\265s 0 ADV_NONCONN_IND 8195 16.818 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8196 16.819 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8197 16.819 7d:30:e4:59:cd:06 LE 1M LE LL 6 170\302\265s 0 SCAN_RSP 8198 16.82 6f:54:d4:dd:c1:58 LE 1M LE LL 12 562\302\265s 0 SCAN_REQ 8199 16.825 0c:6e:66:d7:ed:03 LE 1M LE LL 37 4712\302\265s 0 ADV_NONCONN_IND 8200 16.83 c7:71:43:db:57:1d LE 1M LE LL 36 4705\302\265s 0 ADV_IND 8201 16.843 0d:62:2c:2a:24:88 LE 1M LE LL 37 12295\302\265s 0 ADV_NONCONN_IND 8202 16.85 SamsungE_07:d5:79 LE 1M LE LL 34 6532\302\265s 0 ADV_NONCONN_IND 8203 16.852 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 1679\302\265s 0 SCAN_RSP 8204 16.853 3a:d1:ca:1d:4d:de LE 1M LE LL 26 988\302\265s 0 ADV_NONCONN_IND 8205 16.853 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8206 16.86 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6287\302\265s 0 ADV_NONCONN_IND 8207 16.861 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8208 16.862 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8209 16.865 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2673\302\265s 0 ADV_NONCONN_IND 8210 16.865 f9:28:0f:6e:fa:91 LE 1M LE LL 133 180\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8211 16.876 dd:b9:3b:45:59:8b LE 1M LE LL 24 9784\302\265s 0 ADV_IND 8212 16.883 69:a9:48:2f:b7:16 LE 1M LE LL 37 6089\302\265s 0 ADV_NONCONN_IND 8213 16.883 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8214 16.884 f9:b1:c8:6f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8215 16.888 07:69:22:f0:72:30 LE 1M LE LL 37 3281\302\265s 0 ADV_NONCONN_IND 8216 16.888 07:69:22:f0:72:30 LE 1M LE LL 37 175\302\265s 0 ADV_NONCONN_IND 8217 16.889 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8218 16.892 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 2783\302\265s 0 ADV_NONCONN_IND 8219 16.893 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8220 16.893 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8221 16.894 1e:28:49:84:c5:cd LE 1M LE LL 37 997\302\265s 0 ADV_NONCONN_IND 8222 16.895 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8223 16.895 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8224 16.9 5c:9e:d4:03:82:5b LE 1M LE LL 37 4546\302\265s 0 ADV_NONCONN_IND 8225 16.901 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8226 16.901 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8227 16.904 c1:c8:16:ae:fd:1d LE 1M LE LL 36 1742\302\265s 0 ADV_IND 8228 16.904 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8229 16.904 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8230 16.905 c1:c8:16:ae:fd:1d LE 1M LE LL 36 135\302\265s 0 ADV_IND 8231 16.906 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 8232 16.913 2b:5e:0e:c8:62:4c LE 1M LE LL 35 6849\302\265s 0 ADV_NONCONN_IND 8233 16.914 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8234 16.914 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8235 16.916 c5:65:68:79:19:c8 LE 1M LE LL 36 2024\302\265s 0 ADV_IND 8236 16.917 50:9d:53:4b:09:cc LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8237 16.917 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8238 16.918 c5:65:68:79:19:c8 LE 1M LE LL 36 136\302\265s 0 ADV_IND 8239 16.919 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 8240 16.92 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1178\302\265s 0 ADV_NONCONN_IND 8241 16.921 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8242 16.921 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8243 16.929 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6998\302\265s 0 ADV_NONCONN_IND 8244 16.929 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8245 16.93 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8246 16.946 0d:62:2c:2a:24:88 LE 1M LE LL 37 16191\302\265s 0 ADV_NONCONN_IND 8247 16.947 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8248 16.948 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8249 16.952 ef:6e:3d:68:42:19 LE 1M LE LL 36 3598\302\265s 0 ADV_IND 8250 16.952 64:0d:49:f9:4d:a4 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8251 16.952 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8252 16.953 ef:6e:3d:68:42:19 LE 1M LE LL 36 136\302\265s 0 ADV_IND 8253 16.953 e5:ea:46:16:3e:1e LE 1M LE LL 36 349\302\265s 0 ADV_IND 8254 16.954 e5:ea:46:16:3e:1e LE 1M LE LL 36 354\302\265s 0 ADV_IND 8255 16.959 79:70:d9:25:16:e2 LE 1M LE LL 25 4194\302\265s 0 ADV_IND 8256 16.959 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8257 16.959 79:70:d9:25:16:e2 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8258 16.96 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 8259 16.96 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8260 16.962 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1904\302\265s 0 ADV_NONCONN_IND 8261 16.969 74:d9:0b:7a:47:5a LE 1M LE LL 23 6805\302\265s 0 ADV_IND 8262 16.97 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8263 16.97 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8264 16.973 e7:70:80:c3:ad:91 LE 1M LE LL 36 2478\302\265s 0 ADV_IND 8265 16.973 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8266 16.982 43:bd:56:bd:74:f9 LE 1M LE LL 37 9148\302\265s 0 ADV_NONCONN_IND 8267 16.991 69:a9:48:2f:b7:16 LE 1M LE LL 37 8474\302\265s 0 ADV_NONCONN_IND 8268 16.993 07:69:22:f0:72:30 LE 1M LE LL 37 1118\302\265s 0 ADV_NONCONN_IND 8269 16.993 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8270 16.998 32:43:3c:28:8d:92 LE 1M LE LL 37 4067\302\265s 0 ADV_NONCONN_IND 8271 16.998 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8272 16.999 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8273 17 d6:bf:03:e5:20:42 LE 1M LE LL 36 873\302\265s 0 ADV_IND 8274 17.004 1e:28:49:84:c5:cd LE 1M LE LL 37 2978\302\265s 0 ADV_NONCONN_IND 8275 17.004 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8276 17.005 f1:ff:a7:1a:55:8d LE 1M LE LL 36 432\302\265s 0 ADV_IND 8277 17.005 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8278 17.008 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2026\302\265s 0 ADV_NONCONN_IND 8279 17.008 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8280 17.009 64:0d:49:f9:4d:a4 LE 1M LE LL 12 197\302\265s 0 SCAN_REQ 8281 17.019 dd:d8:f1:d0:9c:32 LE 1M LE LL 36 10206\302\265s 0 ADV_IND 8282 17.021 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1461\302\265s 0 ADV_NONCONN_IND 8283 17.022 6f:54:d4:dd:c1:58 LE 1M LE LL 12 265\302\265s 0 SCAN_REQ 8284 17.027 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5216\302\265s 0 ADV_NONCONN_IND 8285 17.028 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8286 17.029 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1372\302\265s 0 ADV_NONCONN_IND 8287 17.03 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8288 17.031 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8289 17.038 11:fe:ef:ed:38:82 LE 1M LE LL 37 6922\302\265s 0 ADV_NONCONN_IND 8290 17.038 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8291 17.039 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8292 17.06 31:ea:1b:25:0d:1f LE 1M LE LL 37 20679\302\265s 0 ADV_NONCONN_IND 8293 17.061 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8294 17.061 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8295 17.062 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1042\302\265s 0 ADV_NONCONN_IND 8296 17.063 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8297 17.064 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8298 17.065 16:ed:93:0f:fa:b0 LE 1M LE LL 37 881\302\265s 0 ADV_NONCONN_IND 8299 17.066 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8300 17.067 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8301 17.07 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3436\302\265s 0 ADV_NONCONN_IND 8302 17.071 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8303 17.071 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8304 17.073 1f:84:46:51:98:14 LE 1M LE LL 23 856\302\265s 0 ADV_NONCONN_IND 8305 17.073 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8306 17.073 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8307 17.074 cc:15:14:59:64:aa LE 1M LE LL 36 226\302\265s 0 ADV_IND 8308 17.087 43:bd:56:bd:74:f9 LE 1M LE LL 37 12267\302\265s 0 ADV_NONCONN_IND 8309 17.087 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8310 17.088 08:ec:5e:66:cd:0d LE 1M LE LL 23 345\302\265s 0 ADV_NONCONN_IND 8311 17.089 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8312 17.089 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8313 17.092 7d:30:e4:59:cd:06 LE 1M LE LL 25 3148\302\265s 0 ADV_IND 8314 17.094 07:69:22:f0:72:30 LE 1M LE LL 37 1408\302\265s 0 ADV_NONCONN_IND 8315 17.095 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8316 17.1 32:43:3c:28:8d:92 LE 1M LE LL 37 5316\302\265s 0 ADV_NONCONN_IND 8317 17.101 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8318 17.101 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8319 17.102 d5:80:ce:3a:df:84 LE 1M LE LL 36 138\302\265s 0 ADV_IND 8320 17.108 cd:5c:f3:7d:98:0b LE 1M LE LL 36 5901\302\265s 0 ADV_IND 8321 17.109 5c:9e:d4:03:82:5b LE 1M LE LL 37 162\302\265s 0 ADV_NONCONN_IND 8322 17.109 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8323 17.11 1e:28:49:84:c5:cd LE 1M LE LL 37 725\302\265s 0 ADV_NONCONN_IND 8324 17.111 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8325 17.112 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8326 17.114 e5:ea:46:16:3e:1e LE 1M LE LL 36 1942\302\265s 0 ADV_IND 8327 17.115 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 8328 17.116 e5:ea:46:16:3e:1e LE 1M LE LL 6 871\302\265s 0 SCAN_RSP 8329 17.126 2b:5e:0e:c8:62:4c LE 1M LE LL 35 9808\302\265s 0 ADV_NONCONN_IND 8330 17.127 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8331 17.127 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8332 17.133 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5727\302\265s 0 ADV_NONCONN_IND 8333 17.134 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8334 17.134 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8335 17.138 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3246\302\265s 0 ADV_NONCONN_IND 8336 17.139 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8337 17.139 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8338 17.14 0b:f9:be:c7:0f:fb LE 1M LE LL 23 202\302\265s 0 ADV_NONCONN_IND 8339 17.14 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8340 17.141 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8341 17.145 11:fe:ef:ed:38:82 LE 1M LE LL 37 3791\302\265s 0 ADV_NONCONN_IND 8342 17.145 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8343 17.146 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8344 17.151 50:44:a3:07:d8:8f LE 1M LE LL 34 4807\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8345 17.154 b5:c7:45:03:81:22 LE 1M LE LL 119 3120\302\265s 0 ADV_IND[Malformed Packet] 8346 17.158 SamsungE_07:d5:79 LE 1M LE LL 34 2798\302\265s 0 ADV_NONCONN_IND 8347 17.164 71:c9:89:02:1c:fb LE 1M LE LL 12 5540\302\265s 0 SCAN_REQ 8348 17.166 31:ea:1b:25:0d:1f LE 1M LE LL 37 1807\302\265s 0 ADV_NONCONN_IND 8349 17.167 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8350 17.169 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2089\302\265s 0 ADV_NONCONN_IND 8351 17.17 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8352 17.17 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8353 17.171 27:f1:d5:6a:d5:82 LE 1M LE LL 37 582\302\265s 0 ADV_NONCONN_IND 8354 17.172 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8355 17.173 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8356 17.178 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4564\302\265s 0 ADV_NONCONN_IND 8357 17.178 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8358 17.179 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8359 17.179 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 125\302\265s 0 ADV_IND 8360 17.18 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8361 17.18 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8362 17.181 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 137\302\265s 0 ADV_IND 8363 17.181 70:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8364 17.182 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 8365 17.185 ed:4e:4a:f5:08:6e LE 1M LE LL 14 2655\302\265s 0 ADV_NONCONN_IND 8366 17.185 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 8367 17.185 49:08:83:d3:3a:6c LE 1M LE LL 12 84\302\265s 0 SCAN_REQ 8368 17.186 71:c9:89:02:1c:fb LE 1M LE LL 12 876\302\265s 0 SCAN_REQ 8369 17.197 07:69:22:f0:72:30 LE 1M LE LL 37 10031\302\265s 0 ADV_NONCONN_IND 8370 17.197 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8371 17.205 71:c9:89:02:1c:fb LE 1M LE LL 12 7866\302\265s 0 SCAN_REQ 8372 17.206 71:c4:79:42:57:d8 LE 1M LE LL 37 411\302\265s 0 ADV_IND 8373 17.207 32:43:3c:28:8d:92 LE 1M LE LL 37 712\302\265s 0 ADV_NONCONN_IND 8374 17.214 1e:28:49:84:c5:cd LE 1M LE LL 37 6165\302\265s 0 ADV_NONCONN_IND 8375 17.214 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8376 17.215 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8377 17.216 40:e1:2b:97:ef:a1 LE 1M LE LL 10 538\302\265s 0 ADV_SCAN_IND 8378 17.217 50:d3:b9:81:11:84 LE 1M LE LL 12 1087\302\265s 0 SCAN_REQ 8379 17.219 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2371\302\265s 0 ADV_NONCONN_IND 8380 17.222 7f:f8:8e:bb:a1:a8 LE 1M LE LL 24 2224\302\265s 0 ADV_IND[Malformed Packet] 8381 17.223 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 367\302\265s 0 ADV_IND 8382 17.224 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 736\302\265s 0 ADV_IND 8383 17.224 6f:54:d4:dd:c1:58 LE 1M LE LL 12 152\302\265s 0 SCAN_REQ 8384 17.228 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3735\302\265s 0 ADV_NONCONN_IND 8385 17.229 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8386 17.229 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8387 17.235 24:c3:d0:ce:d4:37 LE 1M LE LL 37 5100\302\265s 0 ADV_NONCONN_IND 8388 17.235 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8389 17.236 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8390 17.237 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 1062\302\265s 0 ADV_IND 8391 17.238 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 353\302\265s 0 ADV_IND 8392 17.239 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 354\302\265s 0 ADV_IND 8393 17.244 71:c9:89:02:1c:fb LE 1M LE LL 12 5130\302\265s 0 SCAN_REQ 8394 17.246 d9:fe:ef:ed:38:82 LE 1M LE LL 37 1671\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8395 17.246 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8396 17.254 71:c9:89:02:1c:fb LE 1M LE LL 12 7672\302\265s 0 SCAN_REQ 8397 17.255 c5:65:68:79:19:c8 LE 1M LE LL 36 415\302\265s 0 ADV_IND 8398 17.256 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8399 17.256 c5:65:68:79:19:c8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8400 17.256 c5:65:68:79:19:c8 LE 1M LE LL 36 138\302\265s 0 ADV_IND 8401 17.257 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8402 17.27 16:ed:93:0f:fa:b0 LE 1M LE LL 37 13563\302\265s 0 ADV_NONCONN_IND 8403 17.271 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8404 17.272 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8405 17.274 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1826\302\265s 0 ADV_NONCONN_IND 8406 17.275 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8407 17.275 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8408 17.278 71:c9:89:02:1c:fb LE 1M LE LL 12 2434\302\265s 0 SCAN_REQ 8409 17.282 61:9c:87:78:87:2b LE 1M LE LL 23 3736\302\265s 0 ADV_IND 8410 17.283 30:aa:46:16:3e:1e LE 1M LE LL 36 829\302\265s 0 ADV_IND[Malformed Packet] 8411 17.284 71:c9:89:02:1c:fb LE 1M LE LL 12 510\302\265s 0 SCAN_REQ 8412 17.299 3a:d1:ca:1d:4d:de LE 1M LE LL 26 14648\302\265s 0 ADV_NONCONN_IND 8413 17.3 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8414 17.3 69:a9:48:2f:b7:16 LE 1M LE LL 37 94\302\265s 0 ADV_NONCONN_IND 8415 17.303 07:69:22:f0:72:30 LE 1M LE LL 37 3029\302\265s 0 ADV_NONCONN_IND 8416 17.304 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8417 17.305 43:bd:56:bd:74:f9 LE 1M LE LL 37 120\302\265s 0 ADV_NONCONN_IND 8418 17.31 32:43:3c:28:8d:92 LE 1M LE LL 37 4723\302\265s 0 ADV_NONCONN_IND 8419 17.31 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8420 17.311 e7:70:80:c3:ad:91 LE 1M LE LL 36 84\302\265s 0 ADV_IND 8421 17.314 1e:28:49:84:c5:cd LE 1M LE LL 37 3144\302\265s 0 ADV_NONCONN_IND 8422 17.315 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8423 17.317 5c:9e:d4:03:82:5b LE 1M LE LL 37 1785\302\265s 0 ADV_NONCONN_IND 8424 17.317 db:44:a2:c5:d5:79 LE 1M LE LL 34 98\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8425 17.318 5c:9e:d4:03:82:5b LE 1M LE LL 37 428\302\265s 0 ADV_NONCONN_IND 8426 17.321 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2305\302\265s 0 ADV_NONCONN_IND 8427 17.321 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8428 17.322 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8429 17.327 c6:f3:43:db:57:1d LE 1M LE LL 36 5085\302\265s 0 ADV_IND 8430 17.329 50:d3:b9:81:11:84 LE 1M LE LL 12 1257\302\265s 0 SCAN_REQ 8431 17.332 fb:18:78:3b:10:36 LE 1M LE LL 28 3247\302\265s 0 ADV_IND[Malformed Packet] 8432 17.335 d6:bf:03:c5:20:42 LE 1M LE LL 36 2434\302\265s 0 ADV_IND 8433 17.336 d6:bf:03:c5:20:42 LE 1M LE LL 36 353\302\265s 0 ADV_IND 8434 17.337 2b:5e:0e:c8:62:4c LE 1M LE LL 35 323\302\265s 0 ADV_NONCONN_IND 8435 17.34 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2600\302\265s 0 ADV_NONCONN_IND 8436 17.34 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8437 17.341 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8438 17.341 0c:6e:66:d7:ed:03 LE 1M LE LL 37 120\302\265s 0 ADV_NONCONN_IND 8439 17.342 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8440 17.342 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8441 17.343 74:d9:0b:7a:47:5a LE 1M LE LL 6 174\302\265s 0 SCAN_RSP 8442 17.344 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 869\302\265s 0 ADV_IND 8443 17.344 4e:cb:ef:91:31:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8444 17.345 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 415\302\265s 0 ADV_IND 8445 17.349 11:fe:ef:ed:38:82 LE 1M LE LL 37 3652\302\265s 0 ADV_NONCONN_IND 8446 17.35 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8447 17.35 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8448 17.369 7d:30:e4:59:cd:06 LE 1M LE LL 25 18132\302\265s 0 ADV_IND 8449 17.37 7f:ab:0f:33:5d:32 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 8450 17.374 c2:f4:e6:80:5e:ae LE 1M LE LL 36 3631\302\265s 0 ADV_IND 8451 17.374 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8452 17.374 c2:f4:e6:80:5e:ae LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8453 17.375 16:ed:93:0f:fa:b0 LE 1M LE LL 37 270\302\265s 0 ADV_NONCONN_IND 8454 17.375 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8455 17.376 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8456 17.378 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1881\302\265s 0 ADV_NONCONN_IND 8457 17.379 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8458 17.38 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8459 17.388 6f:54:d4:dd:c1:58 LE 1M LE LL 12 7982\302\265s 0 SCAN_REQ 8460 17.389 7f:ab:0f:33:5d:32 LE 1M LE LL 12 567\302\265s 0 SCAN_REQ 8461 17.389 71:c4:79:40:57:d8 LE 1M LE LL 37 411\302\265s 0 ADV_IND[Malformed Packet] 8462 17.39 d6:bf:76:0a:0b:dc LE 1M LE LL 36 751\302\265s 0 ADV_IND 8463 17.391 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8464 17.391 d6:bf:76:0a:0b:dc LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8465 17.392 7f:ab:0f:33:5d:32 LE 1M LE LL 12 655\302\265s 0 SCAN_REQ 8466 17.393 d6:bf:76:0a:0b:dc LE 1M LE LL 36 416\302\265s 0 ADV_IND 8467 17.393 ec:af:39:d1:f5:fe LE 1M LE LL 14 344\302\265s 0 ADV_NONCONN_IND 8468 17.401 69:a9:c8:2f:b7:16 LE 1M LE LL 37 7365\302\265s 0 ADV_NONCONN_IND 8469 17.402 69:a9:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8470 17.408 07:69:22:f0:72:30 LE 1M LE LL 37 5798\302\265s 0 ADV_NONCONN_IND 8471 17.408 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 8472 17.409 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8473 17.412 43:bd:56:bd:74:f9 LE 1M LE LL 37 2611\302\265s 0 ADV_NONCONN_IND 8474 17.413 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8475 17.414 32:43:3c:28:8d:92 LE 1M LE LL 37 707\302\265s 0 ADV_NONCONN_IND 8476 17.419 1e:28:49:84:c5:cd LE 1M LE LL 37 4289\302\265s 0 ADV_NONCONN_IND 8477 17.419 1e:28:49:84:c5:cd LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8478 17.42 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8479 17.424 5c:9e:d4:03:82:5b LE 1M LE LL 37 4288\302\265s 0 ADV_NONCONN_IND 8480 17.425 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8481 17.426 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8482 17.43 cf:4f:81:f5:7d:55 LE 1M LE LL 36 3817\302\265s 0 ADV_IND 8483 17.438 d5:80:ce:3a:df:84 LE 1M LE LL 36 7432\302\265s 0 ADV_IND 8484 17.438 2b:5e:0e:c8:62:4c LE 1M LE LL 35 465\302\265s 0 ADV_NONCONN_IND 8485 17.442 cd:5c:f3:7d:98:0b LE 1M LE LL 36 3642\302\265s 0 ADV_IND 8486 17.443 24:c3:d0:ce:d4:37 LE 1M LE LL 37 397\302\265s 0 ADV_NONCONN_IND 8487 17.444 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8488 17.451 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6369\302\265s 0 ADV_NONCONN_IND 8489 17.451 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8490 17.452 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8491 17.453 11:7e:ef:ed:38:82 LE 1M LE LL 37 1301\302\265s 0 ADV_NONCONN_IND 8492 17.454 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8493 17.455 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8494 17.459 d5:11:ee:07:97:9a LE 1M LE LL 36 4148\302\265s 0 ADV_IND[Malformed Packet] 8495 17.47 0d:62:2c:2a:24:88 LE 1M LE LL 37 10089\302\265s 0 ADV_NONCONN_IND 8496 17.47 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8497 17.478 16:ed:93:0f:fa:b0 LE 1M LE LL 37 7475\302\265s 0 ADV_NONCONN_IND 8498 17.478 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8499 17.479 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8500 17.482 3a:d1:ca:1d:4d:de LE 1M LE LL 26 2499\302\265s 0 ADV_NONCONN_IND 8501 17.483 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8502 17.483 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8503 17.489 31:ea:1b:25:0d:1f LE 1M LE LL 37 5652\302\265s 0 ADV_NONCONN_IND 8504 17.49 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8505 17.49 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8506 17.494 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 3659\302\265s 0 ADV_IND 8507 17.507 69:a9:48:2f:b7:16 LE 1M LE LL 37 12362\302\265s 0 ADV_NONCONN_IND 8508 17.512 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4639\302\265s 0 ADV_IND 8509 17.513 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8510 17.513 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8511 17.515 43:bd:56:bd:74:f9 LE 1M LE LL 37 1387\302\265s 0 ADV_NONCONN_IND 8512 17.517 07:69:22:f0:72:30 LE 1M LE LL 37 2322\302\265s 0 ADV_NONCONN_IND 8513 17.518 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8514 17.521 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 2805\302\265s 0 ADV_NONCONN_IND 8515 17.521 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8516 17.522 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8517 17.522 1e:28:49:84:c5:cd LE 1M LE LL 37 330\302\265s 0 ADV_NONCONN_IND 8518 17.523 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8519 17.523 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8520 17.529 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5096\302\265s 0 ADV_NONCONN_IND 8521 17.529 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8522 17.53 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8523 17.54 2b:5e:0e:c8:62:4c LE 1M LE LL 35 9459\302\265s 0 ADV_NONCONN_IND 8524 17.54 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8525 17.541 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8526 17.55 24:c3:d0:ce:d4:37 LE 1M LE LL 37 8850\302\265s 0 ADV_NONCONN_IND 8527 17.551 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8528 17.551 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8529 17.558 0c:6e:66:d7:ed:03 LE 1M LE LL 37 6369\302\265s 0 ADV_NONCONN_IND 8530 17.559 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8531 17.559 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8532 17.562 11:fe:ef:ed:38:82 LE 1M LE LL 37 2551\302\265s 0 ADV_NONCONN_IND 8533 17.563 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8534 17.563 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8535 17.572 0d:62:2c:2a:24:88 LE 1M LE LL 37 8426\302\265s 0 ADV_NONCONN_IND 8536 17.578 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 5316\302\265s 0 ADV_IND 8537 17.578 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8538 17.579 6c:c6:23:80:70:29 LE 1M LE LL 12 683\302\265s 0 SCAN_REQ 8539 17.58 c1:c8:16:ae:fd:1d LE 1M LE LL 36 556\302\265s 0 ADV_IND 8540 17.581 64:0d:49:f9:4d:a4 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 8541 17.582 c1:c8:16:ae:fd:1d LE 1M LE LL 36 415\302\265s 0 ADV_IND 8542 17.582 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8543 17.583 c1:c8:16:ae:fd:1d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8544 17.585 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2114\302\265s 0 ADV_NONCONN_IND 8545 17.585 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8546 17.586 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8547 17.587 3a:d1:ca:1d:4d:de LE 1M LE LL 26 619\302\265s 0 ADV_NONCONN_IND 8548 17.588 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8549 17.588 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8550 17.596 31:ea:1b:25:0d:1f LE 1M LE LL 37 6901\302\265s 0 ADV_NONCONN_IND 8551 17.596 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8552 17.597 61:c6:5e:2f:e9:c8 LE 1M LE LL 36 99\302\265s 0 ADV_IND[Malformed Packet] 8553 17.61 69:a9:48:2f:b7:16 LE 1M LE LL 37 13056\302\265s 0 ADV_NONCONN_IND 8554 17.611 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8555 17.612 69:a9:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8556 17.616 40:f0:08:9b:56:91 LE 1M LE LL 37 3820\302\265s 0 ADV_SCAN_IND 8557 17.616 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8558 17.618 07:69:22:f0:72:30 LE 1M LE LL 37 1208\302\265s 0 ADV_NONCONN_IND 8559 17.618 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8560 17.622 43:bd:56:bd:74:f9 LE 1M LE LL 37 3224\302\265s 0 ADV_NONCONN_IND 8561 17.623 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8562 17.624 32:43:3c:28:8d:92 LE 1M LE LL 37 725\302\265s 0 ADV_NONCONN_IND 8563 17.625 d6:2c:05:d0:15:49 LE 1M LE LL 37 221\302\265s 0 ADV_IND 8564 17.625 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8565 17.626 d6:2c:05:d0:15:49 LE 1M LE LL 27 921\302\265s 0 SCAN_RSP 8566 17.627 6c:c6:23:80:30:28 LE 1M LE LL 12 708\302\265s 0 SCAN_REQ 8567 17.629 1e:28:49:84:c5:cd LE 1M LE LL 37 1264\302\265s 0 ADV_NONCONN_IND 8568 17.629 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8569 17.637 f4:bb:6b:e4:ce:75 LE 1M LE LL 37 7616\302\265s 0 ADV_NONCONN_IND 8570 17.642 5c:9e:d4:03:82:5b LE 1M LE LL 37 4351\302\265s 0 ADV_NONCONN_IND 8571 17.642 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8572 17.643 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8573 17.644 2b:5e:0e:c8:62:4c LE 1M LE LL 35 750\302\265s 0 ADV_NONCONN_IND 8574 17.645 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8575 17.645 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8576 17.646 7d:30:e4:59:cd:06 LE 1M LE LL 25 556\302\265s 0 ADV_IND 8577 17.653 e7:70:80:c3:ad:91 LE 1M LE LL 36 6456\302\265s 0 ADV_IND 8578 17.653 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8579 17.654 e7:70:80:c3:ad:91 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8580 17.654 e7:70:80:c3:ad:91 LE 1M LE LL 36 137\302\265s 0 ADV_IND 8581 17.655 e7:70:80:c3:ad:91 LE 1M LE LL 6 476\302\265s 0 SCAN_RSP 8582 17.655 24:c3:d0:ce:d4:37 LE 1M LE LL 37 102\302\265s 0 ADV_NONCONN_IND 8583 17.656 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8584 17.656 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8585 17.659 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1993\302\265s 0 ADV_NONCONN_IND 8586 17.659 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8587 17.66 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8588 17.664 7f:e1:7b:e4:24:1c LE 1M LE LL 12 4093\302\265s 0 SCAN_REQ 8589 17.672 11:fe:ef:ed:38:82 LE 1M LE LL 37 7587\302\265s 0 ADV_NONCONN_IND 8590 17.673 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8591 17.675 0d:62:2c:2a:24:88 LE 1M LE LL 37 2181\302\265s 0 ADV_NONCONN_IND 8592 17.676 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8593 17.676 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8594 17.677 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 236\302\265s 0 ADV_IND 8595 17.681 c8:de:06:91:ba:b3 LE 1M LE LL 36 3343\302\265s 0 ADV_IND 8596 17.69 16:ed:93:0f:fa:b0 LE 1M LE LL 37 9276\302\265s 0 ADV_NONCONN_IND 8597 17.693 c7:a0:9f:b8:da:bc LE 1M LE LL 14 2237\302\265s 0 ADV_NONCONN_IND 8598 17.695 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1441\302\265s 0 ADV_NONCONN_IND 8599 17.695 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8600 17.698 31:ea:1b:25:0d:1f LE 1M LE LL 37 2342\302\265s 0 ADV_NONCONN_IND 8601 17.699 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8602 17.699 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8603 17.704 1f:84:46:51:98:14 LE 1M LE LL 23 4265\302\265s 0 ADV_NONCONN_IND 8604 17.704 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8605 17.705 1f:84:46:51:98:14 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8606 17.708 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3027\302\265s 0 SCAN_REQ 8607 17.712 69:a9:48:2f:b7:16 LE 1M LE LL 37 4025\302\265s 0 ADV_NONCONN_IND 8608 17.713 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8609 17.716 08:ec:5e:66:cd:0d LE 1M LE LL 23 2363\302\265s 0 ADV_NONCONN_IND 8610 17.716 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8611 17.716 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8612 17.72 07:69:22:f0:72:30 LE 1M LE LL 37 2995\302\265s 0 ADV_NONCONN_IND 8613 17.72 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 8614 17.721 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8615 17.725 32:43:3c:28:8d:92 LE 1M LE LL 37 3445\302\265s 0 ADV_NONCONN_IND 8616 17.725 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8617 17.726 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8618 17.729 1e:28:49:84:c5:cd LE 1M LE LL 37 3037\302\265s 0 ADV_NONCONN_IND 8619 17.73 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8620 17.73 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8621 17.732 d6:bf:76:0a:0b:dc LE 1M LE LL 36 894\302\265s 0 ADV_IND 8622 17.732 7f:e1:7b:e4:24:1c LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8623 17.732 d6:bf:76:0a:0b:dc LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8624 17.736 74:d9:0b:7a:47:5a LE 1M LE LL 23 3735\302\265s 0 ADV_IND 8625 17.737 6f:54:d4:dd:c1:58 LE 1M LE LL 12 930\302\265s 0 SCAN_REQ 8626 17.738 74:d9:0b:7a:47:5a LE 1M LE LL 23 301\302\265s 0 ADV_IND 8627 17.739 32:4b:d3:f3:71:88 LE 1M LE LL 31 931\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 8628 17.74 32:cb:d3:f2:71:8c LE 1M LE LL 23 68\302\265s 0 ADV_NONCONN_IND 8629 17.744 25:5f:bf:53:1f:d7 LE 1M LE LL 37 4095\302\265s 0 ADV_NONCONN_IND 8630 17.744 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8631 17.745 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8632 17.746 7f:e1:7b:e4:24:1c LE 1M LE LL 12 731\302\265s 0 SCAN_REQ 8633 17.749 6e:86:0d:c9:47:bd LE 1M LE LL 21 2763\302\265s 0 ADV_NONCONN_IND 8634 17.751 5c:9e:d4:03:82:5b LE 1M LE LL 37 1288\302\265s 0 ADV_NONCONN_IND 8635 17.751 2b:5e:0e:c8:62:4c LE 1M LE LL 35 125\302\265s 0 ADV_NONCONN_IND 8636 17.752 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8637 17.752 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8638 17.753 cc:15:14:59:64:aa LE 1M LE LL 36 70\302\265s 0 ADV_IND 8639 17.761 0c:6e:66:d7:ed:03 LE 1M LE LL 37 8136\302\265s 0 ADV_NONCONN_IND 8640 17.762 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8641 17.763 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1148\302\265s 0 ADV_NONCONN_IND 8642 17.764 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8643 17.764 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8644 17.767 0b:f9:be:c7:0f:fb LE 1M LE LL 23 2633\302\265s 0 ADV_NONCONN_IND 8645 17.768 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8646 17.768 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8647 17.77 6f:54:d4:dd:e1:58 LE 1M LE LL 12 1860\302\265s 0 SCAN_REQ 8648 17.771 cf:4f:81:f5:7d:55 LE 1M LE LL 36 415\302\265s 0 ADV_IND 8649 17.778 11:fe:ef:ed:38:82 LE 1M LE LL 37 6395\302\265s 0 ADV_NONCONN_IND 8650 17.78 e5:ea:46:16:3e:1e LE 1M LE LL 36 2092\302\265s 0 ADV_IND 8651 17.781 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8652 17.781 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8653 17.781 e5:ea:46:16:3e:1e LE 1M LE LL 36 137\302\265s 0 ADV_IND 8654 17.782 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8655 17.784 79:70:d9:25:16:e2 LE 1M LE LL 25 2298\302\265s 0 ADV_IND 8656 17.792 d6:11:0e:57:f1:d0 LE 1M LE LL 36 7120\302\265s 0 ADV_IND[Malformed Packet] 8657 17.792 d6:11:16:57:f1:d0 LE 1M LE LL 36 352\302\265s 0 ADV_IND 8658 17.793 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8659 17.795 3a:d1:ca:1d:4d:de LE 1M LE LL 26 1606\302\265s 0 ADV_NONCONN_IND 8660 17.795 16:ed:93:0f:fa:b0 LE 1M LE LL 37 499\302\265s 0 ADV_NONCONN_IND 8661 17.796 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8662 17.797 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8663 17.799 31:ea:1b:25:0d:1f LE 1M LE LL 37 2414\302\265s 0 ADV_NONCONN_IND 8664 17.8 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8665 17.8 31:ea:1b:25:0d:1f LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8666 17.801 27:f1:d5:6a:d5:82 LE 1M LE LL 37 386\302\265s 0 ADV_NONCONN_IND 8667 17.802 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8668 17.803 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8669 17.806 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2726\302\265s 0 ADV_NONCONN_IND 8670 17.816 5e:93:36:dd:d3:09 LE 1M LE LL 10 10012\302\265s 0 ADV_SCAN_IND 8671 17.817 6f:54:d4:dd:c1:58 LE 1M LE LL 12 765\302\265s 0 SCAN_REQ 8672 17.821 69:a9:48:2f:b7:16 LE 1M LE LL 37 3830\302\265s 0 ADV_NONCONN_IND 8673 17.822 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8674 17.823 69:a1:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8675 17.826 07:69:22:f0:72:30 LE 1M LE LL 37 2662\302\265s 0 ADV_NONCONN_IND 8676 17.827 07:69:22:f0:72:30 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8677 17.827 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8678 17.831 32:43:3c:28:8d:92 LE 1M LE LL 37 3436\302\265s 0 ADV_NONCONN_IND 8679 17.831 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8680 17.832 32:43:3c:28:8d:92 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8681 17.835 61:bc:87:78:87:2b LE 1M LE LL 23 2188\302\265s 0 ADV_IND 8682 17.837 1e:28:49:84:c5:cd LE 1M LE LL 37 2387\302\265s 0 ADV_NONCONN_IND 8683 17.838 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8684 17.844 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5723\302\265s 0 ADV_NONCONN_IND 8685 17.844 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8686 17.845 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8687 17.851 5c:9e:d4:03:82:5b LE 1M LE LL 37 5201\302\265s 0 ADV_NONCONN_IND 8688 17.851 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8689 17.852 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8690 17.856 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3874\302\265s 0 ADV_NONCONN_IND 8691 17.857 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8692 17.857 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8693 17.868 24:c3:d0:ce:d4:37 LE 1M LE LL 37 10098\302\265s 0 ADV_NONCONN_IND 8694 17.868 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8695 17.869 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8696 17.878 dd:b9:3b:45:59:8b LE 1M LE LL 24 9144\302\265s 0 ADV_IND 8697 17.885 11:fe:ef:ed:38:82 LE 1M LE LL 37 6682\302\265s 0 ADV_NONCONN_IND 8698 17.886 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8699 17.894 3a:d1:ca:1d:4d:de LE 1M LE LL 26 8249\302\265s 0 ADV_NONCONN_IND 8700 17.895 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8701 17.896 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8702 17.898 0d:62:2c:2a:24:88 LE 1M LE LL 37 1535\302\265s 0 ADV_NONCONN_IND 8703 17.898 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8704 17.899 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8705 17.902 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3259\302\265s 0 ADV_NONCONN_IND 8706 17.903 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8707 17.904 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8708 17.907 31:ea:1b:25:0d:1f LE 1M LE LL 37 2959\302\265s 0 ADV_NONCONN_IND 8709 17.908 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8710 17.909 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8711 17.913 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 4343\302\265s 0 ADV_IND 8712 17.914 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8713 17.914 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8714 17.914 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 137\302\265s 0 ADV_IND 8715 17.915 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8716 17.92 c1:c8:16:ae:fd:1d LE 1M LE LL 36 5387\302\265s 0 ADV_IND 8717 17.934 07:69:22:f0:72:30 LE 1M LE LL 37 12644\302\265s 0 ADV_NONCONN_IND 8718 17.934 07:69:22:f0:72:30 LE 1M LE LL 37 170\302\265s 0 ADV_NONCONN_IND 8719 17.935 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8720 17.938 32:43:3c:28:8d:92 LE 1M LE LL 37 2821\302\265s 0 ADV_NONCONN_IND 8721 17.938 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8722 17.939 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8723 17.941 e5:ea:46:16:3e:1e LE 1M LE LL 36 2074\302\265s 0 ADV_IND 8724 17.943 71:c9:89:02:1c:fb LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 8725 17.943 71:c4:79:42:57:d8 LE 1M LE LL 37 220\302\265s 0 ADV_IND 8726 17.951 5c:9e:d4:03:82:5b LE 1M LE LL 37 7227\302\265s 0 ADV_NONCONN_IND 8727 17.951 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8728 17.952 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8729 17.955 ef:6e:3d:68:42:19 LE 1M LE LL 36 2953\302\265s 0 ADV_IND 8730 17.956 71:c9:89:02:1c:fb LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 8731 17.957 ef:6e:3d:68:42:19 LE 1M LE LL 36 415\302\265s 0 ADV_IND 8732 17.958 ef:6e:3d:68:42:19 LE 1M LE LL 6 477\302\265s 0 SCAN_RSP 8733 17.965 2b:5e:0e:c8:62:4c LE 1M LE LL 35 7491\302\265s 0 ADV_NONCONN_IND 8734 17.966 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8735 17.967 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8736 17.968 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1075\302\265s 0 ADV_NONCONN_IND 8737 17.969 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8738 17.969 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8739 17.971 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1150\302\265s 0 ADV_NONCONN_IND 8740 17.971 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8741 17.972 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8742 17.985 c0:41:04:2e:be:9d LE 1M LE LL 36 12857\302\265s 0 ADV_IND 8743 17.986 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8744 17.986 c0:41:04:2e:be:9d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8745 17.987 71:c9:89:02:1c:fb LE 1M LE LL 12 654\302\265s 0 SCAN_REQ 8746 17.989 11:fe:ef:ed:38:82 LE 1M LE LL 37 1992\302\265s 0 ADV_NONCONN_IND 8747 17.992 e7:70:80:c3:ad:91 LE 1M LE LL 36 2551\302\265s 0 ADV_IND 8748 17.992 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8749 17.993 e7:70:80:c3:ad:91 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8750 17.993 e7:70:80:c3:ad:91 LE 1M LE LL 36 135\302\265s 0 ADV_IND 8751 17.993 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8752 17.994 e7:70:80:c3:ad:91 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8753 17.994 e7:70:80:c3:ad:91 LE 1M LE LL 36 136\302\265s 0 ADV_IND 8754 17.995 50:d3:bf:81:78:82 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 8755 17.995 c2:f4:36:0c:1e:5b LE 1M LE LL 36 354\302\265s 0 ADV_IND 8756 17.996 3a:d1:ca:1d:4d:de LE 1M LE LL 26 931\302\265s 0 ADV_NONCONN_IND 8757 17.997 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8758 18 c6:d1:43:db:57:1d LE 1M LE LL 62 2300\302\265s 0 ADV_IND[Malformed Packet] 8759 18.001 71:c9:89:02:1c:fb LE 1M LE LL 12 663\302\265s 0 SCAN_REQ 8760 18.006 76:d2:73:5b:89:e0 LE 1M LE LL 246 5113\302\265s 0 ADV_IND[Malformed Packet] 8761 18.014 31:ea:1b:25:0d:1f LE 1M LE LL 37 5406\302\265s 0 ADV_NONCONN_IND 8762 18.014 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8763 18.015 50:d3:b9:81:11:84 LE 1M LE LL 12 65\302\265s 0 SCAN_REQ 8764 18.015 f6:bf:03:c5:20:42 LE 1M LE LL 36 223\302\265s 0 ADV_IND 8765 18.016 d6:bf:03:c5:20:42 LE 1M LE LL 36 353\302\265s 0 ADV_IND 8766 18.017 7f:ab:0f:33:5d:32 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 8767 18.017 f1:ff:a7:1a:55:8d LE 1M LE LL 36 74\302\265s 0 ADV_IND 8768 18.019 71:c9:89:02:1c:fb LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 8769 18.019 f1:ff:a7:1a:55:8d LE 1M LE LL 36 414\302\265s 0 ADV_IND 8770 18.02 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 8771 18.02 f1:ff:a7:1a:55:8d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8772 18.029 69:a9:48:2f:b7:16 LE 1M LE LL 37 8680\302\265s 0 ADV_NONCONN_IND 8773 18.036 71:c9:89:02:1c:fb LE 1M LE LL 12 6340\302\265s 0 SCAN_REQ 8774 18.036 7f:f8:cc:b8:a1:a8 LE 1M LE LL 24 150\302\265s 0 ADV_IND 8775 18.038 32:43:3c:28:8d:92 LE 1M LE LL 37 1698\302\265s 0 ADV_NONCONN_IND 8776 18.038 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8777 18.039 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8778 18.04 1e:28:49:84:c5:cd LE 1M LE LL 37 531\302\265s 0 ADV_NONCONN_IND 8779 18.04 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8780 18.041 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8781 18.043 43:bd:56:bd:74:f9 LE 1M LE LL 37 1895\302\265s 0 ADV_NONCONN_IND 8782 18.044 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8783 18.045 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8784 18.054 5c:9e:d4:03:82:5b LE 1M LE LL 37 9110\302\265s 0 ADV_NONCONN_IND 8785 18.055 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8786 18.056 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 8787 18.056 79:70:d9:25:16:e2 LE 1M LE LL 25 388\302\265s 0 ADV_IND 8788 18.057 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8789 18.072 2b:5e:0e:c8:62:4c LE 1M LE LL 35 14665\302\265s 0 ADV_NONCONN_IND 8790 18.072 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8791 18.073 d6:bf:76:0a:0b:dc LE 1M LE LL 36 230\302\265s 0 ADV_IND 8792 18.074 d6:bf:76:0a:0b:dc LE 1M LE LL 36 353\302\265s 0 ADV_IND[Malformed Packet] 8793 18.074 0c:6e:66:d7:ed:03 LE 1M LE LL 37 377\302\265s 0 ADV_NONCONN_IND 8794 18.091 cc:15:14:59:64:aa LE 1M LE LL 36 16706\302\265s 0 ADV_IND 8795 18.093 6f:54:d4:dd:c1:58 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 8796 18.097 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4404\302\265s 0 ADV_NONCONN_IND 8797 18.105 cf:4f:81:f5:7d:55 LE 1M LE LL 36 7345\302\265s 0 ADV_IND 8798 18.105 16:ed:93:0f:fa:b0 LE 1M LE LL 37 298\302\265s 0 ADV_NONCONN_IND 8799 18.106 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8800 18.11 6f:54:d4:dd:c1:58 LE 1M LE LL 12 3619\302\265s 0 SCAN_REQ 8801 18.111 74:d9:0b:7a:47:5a LE 1M LE LL 23 1250\302\265s 0 ADV_IND 8802 18.119 45:9b:f4:8b:97:f9 LE 1M LE LL 37 7296\302\265s 0 ADV_IND 8803 18.12 31:ea:1b:25:0d:1f LE 1M LE LL 37 541\302\265s 0 ADV_NONCONN_IND 8804 18.12 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8805 18.122 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1405\302\265s 0 ADV_NONCONN_IND 8806 18.124 cd:5c:f3:7d:98:0b LE 1M LE LL 36 1709\302\265s 0 ADV_IND 8807 18.126 6f:54:d4:dd:c1:58 LE 1M LE LL 12 873\302\265s 0 SCAN_REQ 8808 18.131 69:a9:48:2f:b7:16 LE 1M LE LL 37 5568\302\265s 0 ADV_NONCONN_IND 8809 18.132 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8810 18.142 07:69:22:f0:72:30 LE 1M LE LL 37 8981\302\265s 0 ADV_NONCONN_IND 8811 18.143 32:43:3c:28:8d:92 LE 1M LE LL 37 945\302\265s 0 ADV_NONCONN_IND 8812 18.143 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8813 18.144 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8814 18.145 1e:28:49:84:c5:cd LE 1M LE LL 37 531\302\265s 0 ADV_NONCONN_IND 8815 18.145 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8816 18.146 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8817 18.152 43:bd:56:bd:74:f9 LE 1M LE LL 37 5633\302\265s 0 ADV_NONCONN_IND 8818 18.153 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8819 18.154 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8820 18.156 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1803\302\265s 0 ADV_NONCONN_IND 8821 18.156 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8822 18.157 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8823 18.161 c6:f1:43:db:57:1d LE 1M LE LL 40 3672\302\265s 0 ADV_IND[Malformed Packet] 8824 18.166 6f:54:d4:dd:c1:58 LE 1M LE LL 12 4313\302\265s 0 SCAN_REQ 8825 18.166 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 164\302\265s 0 ADV_IND 8826 18.175 2b:5e:0e:c8:62:4c LE 1M LE LL 35 8490\302\265s 0 ADV_NONCONN_IND 8827 18.175 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8828 18.176 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8829 18.178 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1970\302\265s 0 ADV_NONCONN_IND 8830 18.179 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8831 18.179 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8832 18.193 7d:30:e4:59:cd:06 LE 1M LE LL 25 12839\302\265s 0 ADV_IND 8833 18.194 50:9d:53:4b:09:cc LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 8834 18.195 6f:54:d4:dd:c1:58 LE 1M LE LL 12 842\302\265s 0 SCAN_REQ 8835 18.2 11:fe:ef:ed:38:82 LE 1M LE LL 37 4805\302\265s 0 ADV_NONCONN_IND 8836 18.2 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8837 18.201 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8838 18.212 16:ed:93:0f:fa:b0 LE 1M LE LL 37 11162\302\265s 0 ADV_NONCONN_IND 8839 18.213 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8840 18.213 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8841 18.216 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2418\302\265s 0 ADV_NONCONN_IND 8842 18.217 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8843 18.218 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8844 18.221 31:ea:1b:25:0d:1f LE 1M LE LL 37 2327\302\265s 0 ADV_NONCONN_IND 8845 18.221 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8846 18.222 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8847 18.227 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 5154\302\265s 0 ADV_NONCONN_IND 8848 18.235 69:a9:48:2f:b7:16 LE 1M LE LL 37 7023\302\265s 0 ADV_NONCONN_IND 8849 18.235 69:a9:28:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8850 18.236 40:e1:2b:97:6e:a1 LE 1M LE LL 42 70\302\265s 0 ADV_SCAN_IND[Malformed Packet] 8851 18.245 07:69:22:f0:72:30 LE 1M LE LL 37 8365\302\265s 0 ADV_NONCONN_IND 8852 18.245 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8853 18.247 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 1392\302\265s 0 ADV_IND 8854 18.248 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8855 18.248 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8856 18.248 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 136\302\265s 0 ADV_IND 8857 18.249 32:43:3c:28:8d:92 LE 1M LE LL 37 485\302\265s 0 ADV_NONCONN_IND 8858 18.25 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8859 18.251 1e:28:49:84:c5:cd LE 1M LE LL 37 1157\302\265s 0 ADV_NONCONN_IND 8860 18.252 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8861 18.252 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8862 18.255 c1:c8:16:ae:fd:1d LE 1M LE LL 36 2350\302\265s 0 ADV_IND 8863 18.255 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8864 18.256 c1:c8:16:ae:fd:1d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8865 18.256 c1:c8:16:ae:fd:1d LE 1M LE LL 36 135\302\265s 0 ADV_IND 8866 18.259 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3013\302\265s 0 ADV_NONCONN_IND 8867 18.267 43:bd:56:bd:74:f9 LE 1M LE LL 37 7157\302\265s 0 ADV_NONCONN_IND 8868 18.268 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8869 18.269 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8870 18.273 e5:ea:46:16:3e:1e LE 1M LE LL 36 3633\302\265s 0 ADV_IND 8871 18.273 6f:54:d4:dd:c1:58 LE 1M LE LL 12 200\302\265s 0 SCAN_REQ 8872 18.277 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3297\302\265s 0 ADV_NONCONN_IND 8873 18.277 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8874 18.28 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2317\302\265s 0 ADV_NONCONN_IND 8875 18.281 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8876 18.281 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8877 18.289 ef:6e:3d:68:42:19 LE 1M LE LL 36 7393\302\265s 0 ADV_IND 8878 18.289 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8879 18.29 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 8880 18.29 ef:6e:3d:68:42:19 LE 1M LE LL 36 135\302\265s 0 ADV_IND 8881 18.291 64:0d:49:f9:4d:a4 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 8882 18.298 74:d9:0b:7a:47:5a LE 1M LE LL 23 6932\302\265s 0 ADV_IND 8883 18.299 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8884 18.299 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8885 18.3 7f:e1:7b:e4:24:1c LE 1M LE LL 12 394\302\265s 0 SCAN_REQ 8886 18.303 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3610\302\265s 0 ADV_NONCONN_IND 8887 18.309 11:fe:ef:ed:38:82 LE 1M LE LL 37 5366\302\265s 0 ADV_NONCONN_IND 8888 18.31 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8889 18.31 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8890 18.317 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6791\302\265s 0 ADV_NONCONN_IND 8891 18.318 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8892 18.318 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8893 18.321 27:f1:d5:6a:d5:82 LE 1M LE LL 37 2414\302\265s 0 ADV_NONCONN_IND 8894 18.322 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8895 18.323 27:f1:d5:6a:d5:82 LE 1M LE LL 37 758\302\265s 0 ADV_NONCONN_IND 8896 18.324 31:ea:1b:25:0d:1f LE 1M LE LL 37 151\302\265s 0 ADV_NONCONN_IND 8897 18.324 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8898 18.325 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8899 18.326 56:e8:e2:4b:7f:fe LE 1M LE LL 164 1143\302\265s 0 ADV_IND[Malformed Packet] 8900 18.329 7f:e1:7b:e4:24:1c LE 1M LE LL 12 808\302\265s 0 SCAN_REQ 8901 18.331 e7:70:80:c3:ad:91 LE 1M LE LL 36 2435\302\265s 0 ADV_IND 8902 18.332 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 710\302\265s 0 ADV_NONCONN_IND 8903 18.337 79:70:d9:25:16:e2 LE 1M LE LL 25 4476\302\265s 0 ADV_IND 8904 18.343 08:ec:5e:66:cd:0d LE 1M LE LL 23 5414\302\265s 0 ADV_NONCONN_IND 8905 18.351 07:69:22:f0:72:30 LE 1M LE LL 37 7950\302\265s 0 ADV_NONCONN_IND 8906 18.352 07:69:22:f0:72:30 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8907 18.352 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8908 18.355 32:43:3c:28:8d:92 LE 1M LE LL 37 2817\302\265s 0 ADV_NONCONN_IND 8909 18.356 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8910 18.356 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8911 18.357 1e:28:49:84:c5:cd LE 1M LE LL 37 531\302\265s 0 ADV_NONCONN_IND 8912 18.358 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8913 18.358 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8914 18.36 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1353\302\265s 0 ADV_NONCONN_IND 8915 18.361 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8916 18.361 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8917 18.365 17:5f:43:7c:0a:89 LE 1M LE LL 23 3565\302\265s 0 ADV_NONCONN_IND 8918 18.366 17:5f:43:7c:0c:89 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 8919 18.372 32:cb:d3:f2:71:8c LE 1M LE LL 23 6229\302\265s 0 ADV_NONCONN_IND 8920 18.376 40:f0:08:9b:56:91 LE 1M LE LL 37 3867\302\265s 0 ADV_SCAN_IND 8921 18.379 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2534\302\265s 0 ADV_NONCONN_IND 8922 18.38 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 8923 18.382 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2317\302\265s 0 ADV_NONCONN_IND 8924 18.383 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 8925 18.384 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8926 18.389 24:c3:d0:ce:d4:37 LE 1M LE LL 37 4903\302\265s 0 ADV_NONCONN_IND 8927 18.389 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8928 18.39 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8929 18.406 3a:d1:ca:1d:4d:de LE 1M LE LL 26 15277\302\265s 0 ADV_NONCONN_IND 8930 18.406 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 8931 18.407 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 8932 18.412 11:fe:ef:ed:38:82 LE 1M LE LL 37 4740\302\265s 0 ADV_NONCONN_IND 8933 18.413 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8934 18.413 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8935 18.415 d6:bf:76:0a:0b:dc LE 1M LE LL 36 1568\302\265s 0 ADV_IND 8936 18.416 7f:e1:7b:e4:24:1c LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 8937 18.417 d6:bf:76:0a:0b:dc LE 1M LE LL 36 164\302\265s 0 ADV_IND 8938 18.418 16:ed:93:0f:fa:b0 LE 1M LE LL 37 778\302\265s 0 ADV_NONCONN_IND 8939 18.419 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8940 18.419 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8941 18.425 0d:62:2c:2a:24:88 LE 1M LE LL 37 5796\302\265s 0 ADV_NONCONN_IND 8942 18.426 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8943 18.426 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8944 18.43 31:ea:1b:25:0d:1f LE 1M LE LL 37 3244\302\265s 0 ADV_NONCONN_IND 8945 18.431 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8946 18.431 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8947 18.434 cc:15:14:59:64:aa LE 1M LE LL 36 2326\302\265s 0 ADV_IND 8948 18.438 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3647\302\265s 0 ADV_NONCONN_IND 8949 18.438 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8950 18.441 e5:ea:46:16:3e:1e LE 1M LE LL 36 2627\302\265s 0 ADV_IND 8951 18.446 69:a9:48:2f:b7:16 LE 1M LE LL 37 4154\302\265s 0 ADV_NONCONN_IND 8952 18.447 cf:4f:81:f5:7d:55 LE 1M LE LL 36 1204\302\265s 0 ADV_IND 8953 18.448 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 8954 18.448 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 8955 18.449 d5:80:ce:3a:df:84 LE 1M LE LL 36 798\302\265s 0 ADV_IND 8956 18.461 07:69:22:f0:72:30 LE 1M LE LL 37 11338\302\265s 0 ADV_NONCONN_IND 8957 18.462 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8958 18.465 32:43:3c:28:8d:92 LE 1M LE LL 37 2812\302\265s 0 ADV_NONCONN_IND 8959 18.465 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8960 18.466 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8961 18.47 d6:11:ee:07:97:9a LE 1M LE LL 36 4113\302\265s 0 ADV_IND 8962 18.48 43:bd:56:bd:74:f9 LE 1M LE LL 37 9602\302\265s 0 ADV_NONCONN_IND 8963 18.481 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 8964 18.484 2b:5e:0e:c8:62:4c LE 1M LE LL 35 2773\302\265s 0 ADV_NONCONN_IND 8965 18.485 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8966 18.485 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 8967 18.488 74:d9:0b:7a:47:5a LE 1M LE LL 23 2166\302\265s 0 ADV_IND[Malformed Packet] 8968 18.489 0c:6e:66:d7:ed:03 LE 1M LE LL 37 512\302\265s 0 ADV_NONCONN_IND 8969 18.489 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 8970 18.491 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 1051\302\265s 0 ADV_IND 8971 18.492 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 8972 18.493 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 416\302\265s 0 ADV_IND 8973 18.495 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1652\302\265s 0 ADV_NONCONN_IND 8974 18.495 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8975 18.496 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 8976 18.514 11:fe:ef:ed:38:82 LE 1M LE LL 37 18042\302\265s 0 ADV_NONCONN_IND 8977 18.515 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8978 18.515 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8979 18.522 16:ed:93:0f:fa:b0 LE 1M LE LL 37 6169\302\265s 0 ADV_NONCONN_IND 8980 18.522 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 8981 18.529 71:c4:79:42:57:d8 LE 1M LE LL 37 5985\302\265s 0 ADV_IND 8982 18.532 27:f1:d5:6a:d5:82 LE 1M LE LL 37 3456\302\265s 0 ADV_NONCONN_IND 8983 18.533 45:9b:f4:8b:97:f9 LE 1M LE LL 37 284\302\265s 0 ADV_IND 8984 18.534 45:9b:f4:8b:97:f9 LE 1M LE LL 37 368\302\265s 0 ADV_IND 8985 18.539 31:ea:1b:25:0d:1f LE 1M LE LL 37 4484\302\265s 0 ADV_NONCONN_IND 8986 18.539 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8987 18.54 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8988 18.543 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2661\302\265s 0 ADV_NONCONN_IND 8989 18.543 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8990 18.544 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 8991 18.554 69:a9:48:2f:b7:16 LE 1M LE LL 37 9442\302\265s 0 ADV_NONCONN_IND 8992 18.555 69:a9:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 8993 18.563 SamsungE_07:d5:79 LE 1M LE LL 34 8226\302\265s 0 ADV_NONCONN_IND 8994 18.565 07:69:22:f0:72:30 LE 1M LE LL 37 1166\302\265s 0 ADV_NONCONN_IND 8995 18.565 07:69:22:f0:72:30 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 8996 18.566 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 8997 18.567 32:43:3c:28:8d:92 LE 1M LE LL 37 321\302\265s 0 ADV_NONCONN_IND 8998 18.567 32:43:3c:28:8d:92 LE 1M LE LL 37 177\302\265s 0 ADV_NONCONN_IND 8999 18.568 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9000 18.573 25:5f:bf:53:1f:d7 LE 1M LE LL 37 5242\302\265s 0 ADV_NONCONN_IND 9001 18.574 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9002 18.574 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9003 18.575 1e:28:49:84:c5:cd LE 1M LE LL 37 673\302\265s 0 ADV_NONCONN_IND 9004 18.576 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9005 18.577 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9006 18.59 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 12577\302\265s 0 ADV_IND 9007 18.59 49:08:83:d3:3a:6c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9008 18.591 5c:9e:d4:03:82:5b LE 1M LE LL 37 398\302\265s 0 ADV_NONCONN_IND 9009 18.591 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 9010 18.592 45:f7:a3:b0:6a:e7 LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 9011 18.592 2b:5e:0e:c8:62:4c LE 1M LE LL 35 124\302\265s 0 ADV_NONCONN_IND 9012 18.593 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 9013 18.593 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 9014 18.594 72:c4:71:2c:70:59 LE 1M LE LL 12 465\302\265s 0 SCAN_REQ 9015 18.597 45:9b:f4:8b:97:f9 LE 1M LE LL 37 2911\302\265s 0 ADV_IND 9016 18.598 0c:6e:66:d7:ed:03 LE 1M LE LL 37 263\302\265s 0 ADV_NONCONN_IND 9017 18.599 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 9018 18.603 24:c3:d0:ce:d4:37 LE 1M LE LL 37 3655\302\265s 0 ADV_NONCONN_IND 9019 18.603 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9020 18.604 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9021 18.606 c5:65:68:79:19:c8 LE 1M LE LL 36 2251\302\265s 0 ADV_IND 9022 18.608 c5:65:68:79:19:c8 LE 1M LE LL 36 741\302\265s 0 ADV_IND 9023 18.608 72:c4:71:2c:70:59 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9024 18.609 f5:29:5c:16:3e:1e LE 1M LE LL 36 855\302\265s 0 ADV_IND[Malformed Packet] 9025 18.615 79:70:d9:25:16:e2 LE 1M LE LL 25 5845\302\265s 0 ADV_IND 9026 18.616 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 9027 18.616 79:70:d9:25:16:e2 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9028 18.616 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 9029 18.617 72:10:b2:16:c9:46 LE 1M LE LL 12 798\302\265s 0 SCAN_REQ 9030 18.621 3a:d1:ca:1d:4d:de LE 1M LE LL 26 3135\302\265s 0 ADV_NONCONN_IND 9031 18.621 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 9032 18.622 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 9033 18.626 ef:6e:3d:68:42:19 LE 1M LE LL 36 3896\302\265s 0 ADV_IND 9034 18.628 72:c4:71:2c:70:59 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 9035 18.628 ef:6e:3d:68:42:19 LE 1M LE LL 36 414\302\265s 0 ADV_IND 9036 18.629 72:18:b2:06:dd:46 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9037 18.629 d6:2c:05:d0:15:49 LE 1M LE LL 27 247\302\265s 0 SCAN_RSP 9038 18.63 d6:2c:05:d0:15:49 LE 1M LE LL 37 182\302\265s 0 ADV_IND 9039 18.631 d6:2c:05:d0:15:49 LE 1M LE LL 37 955\302\265s 0 ADV_IND 9040 18.634 50:d3:b9:81:11:84 LE 1M LE LL 12 2385\302\265s 0 SCAN_REQ 9041 18.634 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 9042 18.637 27:f1:d5:6a:d5:82 LE 1M LE LL 37 1970\302\265s 0 ADV_NONCONN_IND 9043 18.641 50:d3:b9:81:11:84 LE 1M LE LL 12 3595\302\265s 0 SCAN_REQ 9044 18.643 0d:62:2c:2a:24:88 LE 1M LE LL 37 1917\302\265s 0 ADV_NONCONN_IND 9045 18.643 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9046 18.645 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 1142\302\265s 0 ADV_NONCONN_IND 9047 18.649 31:ea:1b:25:0d:1f LE 1M LE LL 37 3527\302\265s 0 ADV_NONCONN_IND 9048 18.649 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9049 18.654 69:a9:48:2f:b7:16 LE 1M LE LL 37 4213\302\265s 0 ADV_NONCONN_IND 9050 18.655 69:c9:48:2f:b7:16 LE 1M LE LL 53 456\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 9051 18.658 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 2376\302\265s 0 ADV_IND 9052 18.658 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9053 18.658 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9054 18.663 50:d3:b9:81:11:84 LE 1M LE LL 12 4407\302\265s 0 SCAN_REQ 9055 18.667 c0:41:04:2e:be:9d LE 1M LE LL 36 3994\302\265s 0 ADV_IND 9056 18.668 71:c4:79:42:57:d8 LE 1M LE LL 37 394\302\265s 0 ADV_IND 9057 18.668 71:c9:89:02:1c:fb LE 1M LE LL 12 101\302\265s 0 SCAN_REQ 9058 18.67 07:69:22:f0:72:30 LE 1M LE LL 37 1904\302\265s 0 ADV_NONCONN_IND 9059 18.671 07:69:22:f0:72:30 LE 1M LE LL 37 185\302\265s 0 ADV_NONCONN_IND 9060 18.672 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 9061 18.675 74:d9:0b:7a:47:5a LE 1M LE LL 23 3013\302\265s 0 ADV_IND 9062 18.675 49:08:83:d3:3a:6c LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 9063 18.679 1e:28:49:84:c5:cd LE 1M LE LL 37 3029\302\265s 0 ADV_NONCONN_IND 9064 18.679 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9065 18.683 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3228\302\265s 0 ADV_NONCONN_IND 9066 18.683 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9067 18.684 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9068 18.688 43:bd:56:bd:74:f9 LE 1M LE LL 37 3973\302\265s 0 ADV_NONCONN_IND 9069 18.689 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9070 18.69 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9071 18.691 49:08:83:d3:3a:6c LE 1M LE LL 12 421\302\265s 0 SCAN_REQ 9072 18.694 5c:9e:d4:03:82:5b LE 1M LE LL 37 2970\302\265s 0 ADV_NONCONN_IND 9073 18.694 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 9074 18.696 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1286\302\265s 0 ADV_IND 9075 18.698 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1506\302\265s 0 ADV_NONCONN_IND 9076 18.698 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 9077 18.702 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2941\302\265s 0 ADV_NONCONN_IND 9078 18.702 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 9079 18.703 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 9080 18.708 fa:1f:24:e3:99:5d LE 1M LE LL 14 4815\302\265s 0 ADV_NONCONN_IND 9081 18.71 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1703\302\265s 0 ADV_NONCONN_IND 9082 18.711 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9083 18.714 50:d3:b9:81:11:84 LE 1M LE LL 12 3066\302\265s 0 SCAN_REQ 9084 18.718 11:fe:ef:ed:38:82 LE 1M LE LL 37 4103\302\265s 0 ADV_NONCONN_IND 9085 18.719 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9086 18.72 c2:f4:e6:80:5e:ae LE 1M LE LL 36 374\302\265s 0 ADV_IND 9087 18.72 50:d3:b9:81:11:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9088 18.721 c2:f4:e6:80:5e:ae LE 1M LE LL 36 415\302\265s 0 ADV_IND 9089 18.721 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9090 18.722 c2:f4:e6:80:5e:ae LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9091 18.722 c2:f4:e6:80:5e:ae LE 1M LE LL 36 138\302\265s 0 ADV_IND 9092 18.722 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9093 18.725 16:ed:93:0f:fa:b0 LE 1M LE LL 37 2888\302\265s 0 ADV_NONCONN_IND 9094 18.726 16:ed:93:0f:fa:b0 LE 1M LE LL 37 182\302\265s 0 ADV_NONCONN_IND 9095 18.727 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9096 18.734 50:d3:b9:81:11:84 LE 1M LE LL 12 6863\302\265s 0 SCAN_REQ 9097 18.734 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 9098 18.736 6f:54:d4:dd:c1:58 LE 1M LE LL 12 895\302\265s 0 SCAN_REQ 9099 18.741 27:f1:d5:6a:d5:82 LE 1M LE LL 37 5336\302\265s 0 ADV_NONCONN_IND 9100 18.742 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9101 18.743 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9102 18.746 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2775\302\265s 0 ADV_NONCONN_IND 9103 18.749 4d:dc:b7:a2:f3:be LE 1M LE LL 12 2550\302\265s 0 SCAN_REQ 9104 18.75 6f:54:d4:dd:c1:58 LE 1M LE LL 12 473\302\265s 0 SCAN_REQ 9105 18.75 d6:bc:97:6a:7c:4c LE 1M LE LL 36 434\302\265s 0 ADV_IND[Malformed Packet] 9106 18.751 d6:bf:76:0a:0b:dc LE 1M LE LL 36 740\302\265s 0 ADV_IND 9107 18.752 d6:bf:76:0a:0b:dc LE 1M LE LL 36 742\302\265s 0 ADV_IND 9108 18.753 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9109 18.753 d6:bf:76:0a:0b:dc LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9110 18.758 69:a9:48:2f:b7:16 LE 1M LE LL 37 4165\302\265s 0 ADV_NONCONN_IND 9111 18.758 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9112 18.765 59:8c:7d:02:5f:c8 LE 1M LE LL 55 6676\302\265s 0 ADV_IND[Malformed Packet] 9113 18.767 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 1341\302\265s 0 ADV_NONCONN_IND 9114 18.768 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9115 18.768 0e:dc:ae:5f:ea:01 LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9116 18.77 cc:15:14:59:64:aa LE 1M LE LL 36 1646\302\265s 0 ADV_IND 9117 18.771 49:d0:47:a3:11:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9118 18.771 cc:15:14:59:64:aa LE 1M LE LL 36 412\302\265s 0 ADV_IND 9119 18.772 71:c9:89:02:1c:fb LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 9120 18.773 32:43:3c:28:8d:92 LE 1M LE LL 37 317\302\265s 0 ADV_NONCONN_IND 9121 18.773 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9122 18.774 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9123 18.776 e5:ea:46:16:3e:1e LE 1M LE LL 36 2040\302\265s 0 ADV_IND 9124 18.777 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9125 18.777 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9126 18.777 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 9127 18.779 71:c9:89:02:1c:fb LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 9128 18.782 cf:4f:81:f5:7d:55 LE 1M LE LL 36 3398\302\265s 0 ADV_IND 9129 18.783 50:d3:b8:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9130 18.783 cf:4f:81:f5:7d:55 LE 1M LE LL 36 415\302\265s 0 ADV_IND 9131 18.784 4d:dc:b7:a2:f3:be LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9132 18.784 cf:4f:81:f5:7d:55 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9133 18.784 cf:4f:81:f5:7d:55 LE 1M LE LL 36 138\302\265s 0 ADV_IND 9134 18.785 71:c9:89:02:1c:fb LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 9135 18.785 cf:4f:81:f5:7d:55 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9136 18.787 d5:80:ce:3a:df:84 LE 1M LE LL 36 1221\302\265s 0 ADV_IND 9137 18.787 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 9138 18.788 d5:80:ce:3a:df:84 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9139 18.788 d5:80:ce:3a:df:84 LE 1M LE LL 36 136\302\265s 0 ADV_IND 9140 18.79 43:bd:56:bd:74:f9 LE 1M LE LL 37 1642\302\265s 0 ADV_NONCONN_IND 9141 18.8 50:d3:b9:81:11:84 LE 1M LE LL 12 9343\302\265s 0 SCAN_REQ 9142 18.802 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1962\302\265s 0 ADV_NONCONN_IND 9143 18.802 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 9144 18.803 50:d3:b9:81:11:84 LE 1M LE LL 12 113\302\265s 0 SCAN_REQ 9145 18.803 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 9146 18.805 6f:54:d4:dd:c1:58 LE 1M LE LL 12 895\302\265s 0 SCAN_REQ 9147 18.807 LE 1M LE LL 36 1838\302\265s 0 Unknown 9148 18.811 0c:6e:66:d7:ed:03 LE 1M LE LL 37 3588\302\265s 0 ADV_NONCONN_IND 9149 18.811 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 9150 18.813 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1781\302\265s 0 ADV_NONCONN_IND 9151 18.814 24:c3:d0:ce:d4:37 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9152 18.814 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9153 18.82 5c:9e:d4:03:82:5b LE 1M LE LL 37 5489\302\265s 0 ADV_NONCONN_IND 9154 18.821 11:fe:ef:ed:38:82 LE 1M LE LL 37 228\302\265s 0 ADV_NONCONN_IND 9155 18.821 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9156 18.822 50:d3:b9:81:11:84 LE 1M LE LL 12 700\302\265s 0 SCAN_REQ 9157 18.827 16:ed:93:0f:fa:b0 LE 1M LE LL 37 3988\302\265s 0 ADV_NONCONN_IND 9158 18.827 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9159 18.831 c6:f1:43:db:57:1d LE 1M LE LL 36 3230\302\265s 0 ADV_IND 9160 18.837 71:c4:79:42:57:d8 LE 1M LE LL 37 5779\302\265s 0 ADV_IND 9161 18.841 45:9b:f4:8b:17:f9 LE 1M LE LL 37 3358\302\265s 0 SCAN_RSP[Malformed Packet] 9162 18.841 27:f1:d5:6a:d5:82 LE 1M LE LL 37 106\302\265s 0 ADV_NONCONN_IND 9163 18.842 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9164 18.843 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9165 18.844 0d:62:2c:2a:24:88 LE 1M LE LL 37 784\302\265s 0 ADV_NONCONN_IND 9166 18.845 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9167 18.845 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9168 18.847 7f:f8:8c:bb:a1:ac LE 1M LE LL 24 1450\302\265s 0 ADV_IND 9169 18.852 31:ea:1b:25:0d:1f LE 1M LE LL 37 5196\302\265s 0 ADV_NONCONN_IND 9170 18.853 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9171 18.854 64:0d:49:f9:4d:a4 LE 1M LE LL 12 215\302\265s 0 SCAN_REQ 9172 18.855 5e:93:36:dd:d3:09 LE 1M LE LL 10 980\302\265s 0 ADV_SCAN_IND 9173 18.86 74:d9:0b:7a:47:5a LE 1M LE LL 23 4878\302\265s 0 ADV_IND 9174 18.861 74:d9:0b:7a:47:5a LE 1M LE LL 23 513\302\265s 0 ADV_IND 9175 18.861 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9176 18.861 74:d9:0b:7a:47:5a LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9177 18.872 c0:4e:43:7b:5f:2b LE 1M LE LL 14 10170\302\265s 0 ADV_IND 9178 18.873 4e:14:1a:cb:9e:d9 LE 1M LE LL 12 1342\302\265s 0 ADV_IND 9179 18.874 64:0d:49:f9:4d:a4 LE 1M LE LL 12 839\302\265s 0 SCAN_REQ 9180 18.876 SamsungE_07:d5:79 LE 1M LE LL 34 1750\302\265s 0 ADV_NONCONN_IND 9181 18.877 SamsungE_07:d5:79 LE 1M LE LL 34 586\302\265s 0 ADV_NONCONN_IND 9182 18.88 dd:b9:3b:45:59:8b LE 1M LE LL 24 2454\302\265s 0 ADV_IND 9183 18.88 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9184 18.881 dd:b9:3b:45:59:8b LE 1M LE LL 24 300\302\265s 0 ADV_IND 9185 18.881 76:e8:bb:73:ea:1b LE 1M LE LL 25 498\302\265s 0 ADV_IND[Malformed Packet] 9186 18.885 79:70:d9:25:16:e2 LE 1M LE LL 25 3594\302\265s 0 ADV_IND 9187 18.886 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9188 18.886 79:70:d9:25:16:e2 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9189 18.886 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 9190 18.887 6f:54:d4:dd:c1:58 LE 1M LE LL 12 799\302\265s 0 SCAN_REQ 9191 18.888 1e:28:49:84:c5:cd LE 1M LE LL 37 367\302\265s 0 ADV_NONCONN_IND 9192 18.889 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9193 18.889 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9194 18.891 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1978\302\265s 0 ADV_NONCONN_IND 9195 18.892 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9196 18.893 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9197 18.903 64:0d:49:f9:4d:a4 LE 1M LE LL 12 9957\302\265s 0 SCAN_REQ 9198 18.909 7d:c4:79:42:57:d8 LE 1M LE LL 37 6175\302\265s 0 ADV_IND 9199 18.91 71:c4:79:42:57:d8 LE 1M LE LL 37 368\302\265s 0 ADV_IND 9200 18.913 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2935\302\265s 0 ADV_NONCONN_IND 9201 18.914 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9202 18.914 24:c3:d0:ce:d4:37 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9203 18.918 64:0d:49:f9:4d:a4 LE 1M LE LL 12 3385\302\265s 0 SCAN_REQ 9204 18.92 5c:9e:d4:03:82:5b LE 1M LE LL 37 1673\302\265s 0 ADV_NONCONN_IND 9205 18.921 11:fe:ef:ed:38:82 LE 1M LE LL 37 1037\302\265s 0 ADV_NONCONN_IND 9206 18.926 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 3973\302\265s 0 ADV_IND 9207 18.926 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9208 18.927 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9209 18.927 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 137\302\265s 0 ADV_IND 9210 18.932 c1:c8:16:ae:fd:1d LE 1M LE LL 36 4548\302\265s 0 ADV_IND 9211 18.932 47:4e:9b:89:59:8e LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 9212 18.933 c1:c8:16:ae:fd:1d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9213 18.934 16:ed:93:0f:fa:b0 LE 1M LE LL 37 839\302\265s 0 ADV_NONCONN_IND 9214 18.934 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9215 18.935 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9216 18.938 e5:ea:46:16:3e:1e LE 1M LE LL 36 2512\302\265s 0 ADV_IND 9217 18.94 61:bc:87:78:a7:23 LE 1M LE LL 23 2266\302\265s 0 ADV_IND 9218 18.941 61:9c:87:78:87:2b LE 1M LE LL 23 514\302\265s 0 ADV_IND 9219 18.947 27:f1:d5:6a:d5:82 LE 1M LE LL 37 6149\302\265s 0 ADV_NONCONN_IND 9220 18.948 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9221 18.949 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9222 18.953 0d:62:2c:2a:24:88 LE 1M LE LL 37 3293\302\265s 0 ADV_NONCONN_IND 9223 18.953 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9224 18.954 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9225 18.954 31:ea:1b:25:0d:1f LE 1M LE LL 37 106\302\265s 0 ADV_NONCONN_IND 9226 18.955 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9227 18.955 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9228 18.957 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 792\302\265s 0 ADV_NONCONN_IND 9229 18.957 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9230 18.958 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9231 18.96 ef:6e:3d:68:42:19 LE 1M LE LL 36 1913\302\265s 0 ADV_IND 9232 18.961 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 9233 18.962 ef:6e:3d:68:42:19 LE 1M LE LL 36 415\302\265s 0 ADV_IND 9234 18.962 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9235 18.963 ef:6e:3d:68:42:19 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9236 18.968 08:ec:5e:66:cd:0d LE 1M LE LL 23 5458\302\265s 0 ADV_NONCONN_IND 9237 18.969 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9238 18.969 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9239 18.973 32:43:3c:28:8d:92 LE 1M LE LL 37 3478\302\265s 0 ADV_NONCONN_IND 9240 18.973 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9241 18.974 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9242 18.978 eb:db:35:2e:09:1b LE 1M LE LL 20 3974\302\265s 0 ADV_IND 9243 18.983 07:69:22:f0:72:30 LE 1M LE LL 37 4290\302\265s 0 ADV_NONCONN_IND 9244 18.983 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 9245 18.987 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 3154\302\265s 0 ADV_IND 9246 18.994 1e:28:49:84:c5:cd LE 1M LE LL 37 6858\302\265s 0 ADV_NONCONN_IND 9247 18.995 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9248 18.997 SamsungE_07:d8:8f LE 1M LE LL 34 2072\302\265s 0 ADV_NONCONN_IND 9249 18.998 25:5f:bf:53:1f:d7 LE 1M LE LL 37 735\302\265s 0 ADV_NONCONN_IND 9250 18.999 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9251 19.005 c0:41:04:2e:be:9d LE 1M LE LL 36 5902\302\265s 0 ADV_IND 9252 19.006 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 9253 19.006 c0:41:04:2e:be:9d LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9254 19.006 c8:41:04:2e:be:9d LE 1M LE LL 36 136\302\265s 0 ADV_IND 9255 19.015 e7:70:80:c3:ad:91 LE 1M LE LL 36 8478\302\265s 0 ADV_IND 9256 19.023 0b:f9:be:c7:0f:fb LE 1M LE LL 23 7123\302\265s 0 ADV_NONCONN_IND 9257 19.023 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9258 19.023 0b:f9:be:c7:0f:fb LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9259 19.025 11:fe:ef:ed:38:82 LE 1M LE LL 37 1733\302\265s 0 ADV_NONCONN_IND 9260 19.026 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9261 19.026 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9262 19.03 d6:bf:03:c5:20:42 LE 1M LE LL 36 3275\302\265s 0 ADV_IND 9263 19.032 f1:ff:a7:1a:55:8d LE 1M LE LL 36 1301\302\265s 0 ADV_IND 9264 19.032 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9265 19.033 f1:ff:a7:1a:55:8d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9266 19.033 f1:ff:a7:1a:55:8d LE 1M LE LL 36 136\302\265s 0 ADV_IND 9267 19.033 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9268 19.034 f1:ff:a7:1a:55:8d LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9269 19.039 3a:d1:ca:1d:4d:de LE 1M LE LL 26 5598\302\265s 0 ADV_NONCONN_IND 9270 19.04 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 9271 19.041 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 9272 19.042 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1165\302\265s 0 ADV_NONCONN_IND 9273 19.043 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9274 19.043 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9275 19.05 74:d9:0b:7a:47:5a LE 1M LE LL 23 6111\302\265s 0 ADV_IND 9276 19.053 45:9b:f4:8b:97:f9 LE 1M LE LL 37 2593\302\265s 0 ADV_IND 9277 19.053 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9278 19.054 45:9b:f4:8b:97:f9 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9279 19.054 7f:e1:7b:e4:24:1c LE 1M LE LL 12 657\302\265s 0 SCAN_REQ 9280 19.055 0d:62:2c:2a:24:88 LE 1M LE LL 37 636\302\265s 0 ADV_NONCONN_IND 9281 19.056 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9282 19.056 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9283 19.057 27:f1:d5:6a:d5:82 LE 1M LE LL 37 677\302\265s 0 ADV_NONCONN_IND 9284 19.058 27:f1:d5:6a:d5:82 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9285 19.059 27:f1:d5:6a:d5:82 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9286 19.063 31:ea:1b:25:0d:1f LE 1M LE LL 37 3641\302\265s 0 ADV_NONCONN_IND 9287 19.064 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9288 19.064 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9289 19.075 32:43:3c:28:8d:92 LE 1M LE LL 37 10739\302\265s 0 ADV_NONCONN_IND 9290 19.076 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9291 19.076 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9292 19.08 69:a9:48:2f:b7:16 LE 1M LE LL 37 3219\302\265s 0 ADV_NONCONN_IND 9293 19.084 07:69:22:f0:72:30 LE 1M LE LL 37 3659\302\265s 0 ADV_NONCONN_IND 9294 19.085 07:69:22:f0:72:30 LE 1M LE LL 37 193\302\265s 0 ADV_NONCONN_IND 9295 19.086 d6:bf:76:0a:0b:dc LE 1M LE LL 36 1364\302\265s 0 ADV_IND 9296 19.089 71:c4:79:42:57:d8 LE 1M LE LL 37 2623\302\265s 0 ADV_IND 9297 19.09 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9298 19.09 71:c4:79:42:57:d8 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9299 19.095 43:bd:56:bd:74:f9 LE 1M LE LL 37 4450\302\265s 0 ADV_NONCONN_IND 9300 19.097 1e:28:49:84:c5:cd LE 1M LE LL 37 1537\302\265s 0 ADV_NONCONN_IND 9301 19.097 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9302 19.098 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9303 19.099 e5:ea:46:16:3e:1e LE 1M LE LL 36 642\302\265s 0 ADV_IND 9304 19.1 6c:c6:23:80:30:28 LE 1M LE LL 12 871\302\265s 0 SCAN_REQ 9305 19.101 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 9306 19.102 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1013\302\265s 0 ADV_NONCONN_IND 9307 19.103 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9308 19.103 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9309 19.111 cc:15:14:59:64:aa LE 1M LE LL 36 7654\302\265s 0 ADV_IND 9310 19.112 6c:c6:23:80:30:28 LE 1M LE LL 12 870\302\265s 0 SCAN_REQ 9311 19.113 cc:15:14:59:64:aa LE 1M LE LL 36 414\302\265s 0 ADV_IND 9312 19.118 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 4776\302\265s 0 ADV_IND 9313 19.12 d5:80:ce:3a:df:84 LE 1M LE LL 36 1413\302\265s 0 ADV_IND 9314 19.12 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9315 19.121 d5:80:ce:3a:df:84 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9316 19.124 LE 1M LE LL 125 2879\302\265s 0 Unknown 9317 19.128 5c:9e:d4:03:82:5b LE 1M LE LL 37 3337\302\265s 0 ADV_NONCONN_IND 9318 19.129 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 9319 19.129 5c:9e:d4:03:82:5b LE 1M LE LL 37 251\302\265s 0 ADV_NONCONN_IND 9320 19.135 d6:2c:05:d0:15:49 LE 1M LE LL 37 4748\302\265s 0 ADV_IND 9321 19.136 6c:c6:23:80:30:28 LE 1M LE LL 12 921\302\265s 0 SCAN_REQ 9322 19.137 d6:2c:05:d0:15:49 LE 1M LE LL 37 628\302\265s 0 ADV_IND 9323 19.143 d6:11:ee:07:97:9a LE 1M LE LL 36 5812\302\265s 0 ADV_IND 9324 19.144 d6:11:ee:07:97:9a LE 1M LE LL 36 353\302\265s 0 ADV_IND 9325 19.144 6c:c6:23:80:30:28 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9326 19.146 16:ed:93:0f:fa:b0 LE 1M LE LL 37 1759\302\265s 0 ADV_NONCONN_IND 9327 19.147 3a:d1:ca:1d:4d:de LE 1M LE LL 26 566\302\265s 0 ADV_NONCONN_IND 9328 19.148 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 9329 19.148 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 9330 19.154 6f:54:d4:dd:c1:58 LE 1M LE LL 12 5448\302\265s 0 SCAN_REQ 9331 19.155 6c:c6:23:80:30:28 LE 1M LE LL 12 567\302\265s 0 SCAN_REQ 9332 19.155 71:c4:79:42:57:d8 LE 1M LE LL 37 411\302\265s 0 ADV_IND 9333 19.157 79:70:d9:25:16:e2 LE 1M LE LL 25 797\302\265s 0 ADV_IND 9334 19.157 6f:54:d4:dd:c1:58 LE 1M LE LL 12 152\302\265s 0 SCAN_REQ 9335 19.158 7f:ab:0f:33:5d:32 LE 1M LE LL 12 840\302\265s 0 SCAN_REQ 9336 19.158 7e:e4:9e:1a:f2:00 LE 1M LE LL 148 98\302\265s 0 ADV_IND[Malformed Packet] 9337 19.161 c6:f1:43:db:57:1d LE 1M LE LL 36 1127\302\265s 0 ADV_IND 9338 19.165 31:ea:1b:25:0d:1f LE 1M LE LL 37 3793\302\265s 0 ADV_NONCONN_IND 9339 19.165 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9340 19.17 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 4548\302\265s 0 ADV_NONCONN_IND 9341 19.176 32:43:3c:28:8d:92 LE 1M LE LL 37 5123\302\265s 0 ADV_NONCONN_IND 9342 19.176 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9343 19.183 69:a9:48:2f:b7:16 LE 1M LE LL 37 5716\302\265s 0 ADV_NONCONN_IND 9344 19.183 69:a9:48:2f:b7:16 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9345 19.184 69:99:48:2f:87:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9346 19.186 ed:4e:4a:f5:08:6e LE 1M LE LL 14 1304\302\265s 0 ADV_NONCONN_IND 9347 19.186 ed:4e:4a:f5:08:6e LE 1M LE LL 14 132\302\265s 0 ADV_NONCONN_IND 9348 19.187 ed:4e:4a:f5:08:6e LE 1M LE LL 14 133\302\265s 0 ADV_NONCONN_IND 9349 19.192 07:69:22:f0:72:30 LE 1M LE LL 37 5538\302\265s 0 ADV_NONCONN_IND 9350 19.193 07:69:22:f0:72:30 LE 1M LE LL 37 190\302\265s 0 ADV_NONCONN_IND 9351 19.193 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 9352 19.198 1e:28:49:84:c5:cd LE 1M LE LL 37 4197\302\265s 0 ADV_NONCONN_IND 9353 19.199 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9354 19.199 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9355 19.203 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3855\302\265s 0 ADV_NONCONN_IND 9356 19.204 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9357 19.204 25:5f:bf:53:1f:d7 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9358 19.221 61:9c:87:78:87:2b LE 1M LE LL 23 15972\302\265s 0 ADV_IND 9359 19.225 2b:5e:0e:c8:62:4c LE 1M LE LL 35 3755\302\265s 0 ADV_NONCONN_IND 9360 19.225 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 9361 19.227 24:c3:d0:ce:d4:37 LE 1M LE LL 37 1345\302\265s 0 ADV_NONCONN_IND 9362 19.228 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9363 19.228 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9364 19.23 11:fe:ef:ed:38:8e LE 1M LE LL 37 1790\302\265s 0 ADV_NONCONN_IND 9365 19.231 11:fe:ef:ed:38:82 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9366 19.231 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9367 19.251 3a:d1:ca:1d:4d:de LE 1M LE LL 26 18865\302\265s 0 ADV_NONCONN_IND 9368 19.251 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 9369 19.252 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 9370 19.253 16:ed:93:0f:fa:b0 LE 1M LE LL 37 551\302\265s 0 ADV_NONCONN_IND 9371 19.254 16:ed:93:0f:fa:b0 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9372 19.254 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9373 19.26 e5:ea:46:16:3e:1e LE 1M LE LL 36 5618\302\265s 0 ADV_IND 9374 19.261 6f:54:d4:dd:c1:58 LE 1M LE LL 12 872\302\265s 0 SCAN_REQ 9375 19.262 e5:ea:46:16:3e:1e LE 1M LE LL 36 416\302\265s 0 ADV_IND 9376 19.263 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 956\302\265s 0 ADV_IND 9377 19.265 c3:e7:c0:d3:8a:f0 LE 1M LE LL 6 1197\302\265s 0 SCAN_RSP 9378 19.265 c3:e7:c0:d3:8a:f0 LE 1M LE LL 36 138\302\265s 0 ADV_IND 9379 19.266 c1:c8:16:ae:fd:1d LE 1M LE LL 36 776\302\265s 0 ADV_IND[Malformed Packet] 9380 19.267 31:ea:1b:25:0d:1f LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 9381 19.267 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9382 19.271 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3299\302\265s 0 ADV_NONCONN_IND 9383 19.272 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9384 19.272 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9385 19.283 32:43:3c:28:8d:92 LE 1M LE LL 37 10330\302\265s 0 ADV_NONCONN_IND 9386 19.283 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9387 19.284 32:43:3c:38:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9388 19.288 69:a9:48:2f:b7:16 LE 1M LE LL 37 3215\302\265s 0 ADV_NONCONN_IND 9389 19.295 07:69:22:f0:72:30 LE 1M LE LL 37 6792\302\265s 0 ADV_NONCONN_IND 9390 19.295 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 9391 19.3 ef:6e:3d:68:42:19 LE 1M LE LL 36 4329\302\265s 0 ADV_IND 9392 19.301 ef:6e:3d:68:42:19 LE 1M LE LL 36 353\302\265s 0 ADV_IND 9393 19.303 1e:28:49:84:c5:cd LE 1M LE LL 37 1759\302\265s 0 ADV_NONCONN_IND 9394 19.304 43:bd:56:bd:74:f9 LE 1M LE LL 37 1220\302\265s 0 ADV_NONCONN_IND 9395 19.308 40:f0:08:9b:56:91 LE 1M LE LL 37 2702\302\265s 0 ADV_SCAN_IND 9396 19.308 85:9b:f4:8b:97:f9 LE 1M LE LL 37 277\302\265s 0 ADV_IND[Malformed Packet] 9397 19.309 45:9b:f4:8b:97:f9 LE 1M LE LL 37 368\302\265s 0 ADV_IND 9398 19.31 6f:54:d4:dd:c1:58 LE 1M LE LL 12 502\302\265s 0 SCAN_REQ 9399 19.313 25:5f:bf:53:1f:d7 LE 1M LE LL 37 2664\302\265s 0 ADV_NONCONN_IND 9400 19.313 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9401 19.321 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 7110\302\265s 0 ADV_IND 9402 19.321 6f:54:d4:dd:c1:58 LE 1M LE LL 12 152\302\265s 0 SCAN_REQ 9403 19.326 2b:5e:0e:c8:62:4c LE 1M LE LL 35 4687\302\265s 0 ADV_NONCONN_IND 9404 19.327 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 9405 19.329 0c:6e:66:d7:ed:03 LE 1M LE LL 37 2307\302\265s 0 ADV_NONCONN_IND 9406 19.33 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 9407 19.331 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 9408 19.334 fb:18:78:3b:10:36 LE 1M LE LL 28 2777\302\265s 0 ADV_IND 9409 19.335 6f:54:d4:dd:c1:58 LE 1M LE LL 12 901\302\265s 0 SCAN_REQ 9410 19.336 11:fe:ef:ed:38:82 LE 1M LE LL 37 1386\302\265s 0 ADV_NONCONN_IND 9411 19.344 5c:9e:d4:03:82:5b LE 1M LE LL 37 7586\302\265s 0 ADV_NONCONN_IND 9412 19.348 e7:70:80:c3:ad:91 LE 1M LE LL 36 2767\302\265s 0 ADV_IND 9413 19.348 6f:54:d4:dd:c1:58 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 9414 19.354 71:c4:79:42:57:d8 LE 1M LE LL 37 5358\302\265s 0 ADV_IND 9415 19.359 16:ed:93:0f:fa:b0 LE 1M LE LL 37 5286\302\265s 0 ADV_NONCONN_IND 9416 19.36 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9417 19.36 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9418 19.364 71:c9:89:02:1c:fb LE 1M LE LL 12 3186\302\265s 0 SCAN_REQ 9419 19.365 c8:de:06:91:ba:b3 LE 1M LE LL 36 415\302\265s 0 ADV_IND 9420 19.365 50:d3:b9:81:11:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 9421 19.366 f1:ff:a7:1a:55:8d LE 1M LE LL 36 405\302\265s 0 ADV_IND 9422 19.366 6f:54:d4:dd:c1:58 LE 1M LE LL 12 162\302\265s 0 SCAN_REQ 9423 19.372 20:1b:4a:69:0d:92 LE 1M LE LL 37 6102\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 9424 19.373 31:ea:1b:25:0d:1f LE 1M LE LL 37 254\302\265s 0 ADV_NONCONN_IND 9425 19.374 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9426 19.375 0d:62:2c:2a:24:88 LE 1M LE LL 37 672\302\265s 0 ADV_NONCONN_IND 9427 19.375 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9428 19.376 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9429 19.379 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 2388\302\265s 0 ADV_NONCONN_IND 9430 19.379 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9431 19.38 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9432 19.388 32:43:3c:28:8d:92 LE 1M LE LL 37 8454\302\265s 0 ADV_NONCONN_IND 9433 19.389 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9434 19.39 32:43:3c:28:8d:92 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9435 19.391 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 710\302\265s 0 ADV_IND 9436 19.391 7f:f8:8c:bb:a1:a8 LE 1M LE LL 24 368\302\265s 0 ADV_IND 9437 19.392 c2:f4:e6:80:5e:ae LE 1M LE LL 36 813\302\265s 0 ADV_IND 9438 19.401 ec:af:39:d1:f5:be LE 1M LE LL 14 7931\302\265s 0 ADV_NONCONN_IND 9439 19.403 07:69:22:f0:72:30 LE 1M LE LL 37 1950\302\265s 0 ADV_NONCONN_IND 9440 19.403 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 9441 19.411 1e:28:49:84:c5:cd LE 1M LE LL 37 7325\302\265s 0 ADV_NONCONN_IND 9442 19.412 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9443 19.412 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9444 19.414 43:bd:56:bd:74:f9 LE 1M LE LL 37 1842\302\265s 0 ADV_NONCONN_IND 9445 19.415 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9446 19.416 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9447 19.418 71:c9:89:02:1c:fb LE 1M LE LL 12 1658\302\265s 0 SCAN_REQ 9448 19.421 74:d9:0b:7a:47:5a LE 1M LE LL 23 2229\302\265s 0 ADV_IND 9449 19.424 c4:d3:3f:79:a7:16 LE 1M LE LL 36 3392\302\265s 0 ADV_IND[Malformed Packet] 9450 19.427 79:70:d9:25:16:e2 LE 1M LE LL 25 2149\302\265s 0 ADV_IND 9451 19.427 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9452 19.427 79:70:d9:25:16:e2 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9453 19.428 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 9454 19.428 50:d3:b9:81:11:84 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9455 19.428 79:70:d9:25:16:e2 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9456 19.429 79:70:d9:25:16:e2 LE 1M LE LL 25 132\302\265s 0 ADV_IND 9457 19.429 6f:54:d4:dd:c1:58 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9458 19.433 71:c9:89:02:1c:fb LE 1M LE LL 12 3877\302\265s 0 SCAN_REQ 9459 19.435 2b:5e:0e:c8:62:4c LE 1M LE LL 35 1403\302\265s 0 ADV_NONCONN_IND 9460 19.435 2b:5e:0e:c8:62:4c LE 1M LE LL 35 178\302\265s 0 ADV_NONCONN_IND 9461 19.437 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1057\302\265s 0 ADV_NONCONN_IND 9462 19.437 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 9463 19.438 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 9464 19.441 24:c3:d0:ce:d4:37 LE 1M LE LL 37 2412\302\265s 0 ADV_NONCONN_IND 9465 19.441 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9466 19.442 24:c3:d0:ce:d4:37 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9467 19.443 11:fe:ef:ed:38:82 LE 1M LE LL 37 1166\302\265s 0 ADV_NONCONN_IND 9468 19.444 11:fe:ef:ed:38:82 LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9469 19.445 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9470 19.45 71:c9:89:02:1c:fb LE 1M LE LL 12 4814\302\265s 0 SCAN_REQ 9471 19.451 64:0d:49:f9:4d:a4 LE 1M LE LL 12 933\302\265s 0 SCAN_REQ 9472 19.455 cc:15:14:59:64:aa LE 1M LE LL 36 3600\302\265s 0 ADV_IND 9473 19.456 LE 1M LE LL 34 902\302\265s 0 Unknown 9474 19.457 45:9b:f4:8b:97:f9 LE 1M LE LL 6 368\302\265s 0 SCAN_RSP 9475 19.457 45:9b:f4:8b:97:f9 LE 1M LE LL 37 132\302\265s 0 ADV_IND[Malformed Packet] 9476 19.458 d5:80:ce:3a:df:84 LE 1M LE LL 36 591\302\265s 0 ADV_IND 9477 19.459 60:01:49:79:c9:a4 LE 1M LE LL 12 1008\302\265s 0 SCAN_REQ 9478 19.46 cf:4f:81:f5:7d:55 LE 1M LE LL 36 562\302\265s 0 ADV_IND 9479 19.461 71:c4:79:42:57:d8 LE 1M LE LL 37 444\302\265s 0 ADV_IND 9480 19.466 3a:d1:ca:1d:4d:de LE 1M LE LL 26 4522\302\265s 0 ADV_NONCONN_IND 9481 19.466 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 9482 19.467 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 9483 19.473 cd:5c:f3:7d:98:0b LE 1M LE LL 36 6008\302\265s 0 ADV_IND 9484 19.474 cd:5c:f3:7d:98:0b LE 1M LE LL 36 353\302\265s 0 ADV_IND 9485 19.475 cd:5c:f3:7d:98:0b LE 1M LE LL 36 354\302\265s 0 ADV_IND 9486 19.477 31:ea:1b:25:0d:1f LE 1M LE LL 37 2228\302\265s 0 ADV_NONCONN_IND 9487 19.478 31:ea:1b:25:0d:1f LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9488 19.479 31:ea:1b:25:0d:1f LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9489 19.48 0d:62:2c:2a:24:88 LE 1M LE LL 37 677\302\265s 0 ADV_NONCONN_IND 9490 19.48 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9491 19.481 0d:62:2c:2a:24:88 LE 1M LE LL 37 181\302\265s 0 ADV_NONCONN_IND 9492 19.486 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 4519\302\265s 0 ADV_IND 9493 19.486 71:c9:89:02:1c:fb LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9494 19.487 c2:f4:8b:c3:ec:01 LE 1M LE LL 6 151\302\265s 0 SCAN_RSP 9495 19.487 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 136\302\265s 0 ADV_IND 9496 19.487 64:4d:49:f9:41:a4 LE 1M LE LL 12 151\302\265s 0 SCAN_REQ 9497 19.488 c2:f4:8b:c3:ec:01 LE 1M LE LL 36 164\302\265s 0 ADV_IND[Malformed Packet] 9498 19.49 69:a9:48:2f:b7:16 LE 1M LE LL 37 2047\302\265s 0 ADV_NONCONN_IND 9499 19.493 45:9b:f4:8b:97:f9 LE 1M LE LL 37 2906\302\265s 0 ADV_IND 9500 19.494 60:05:c9:f9:55:84 LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 9501 19.495 61:9c:87:78:87:2b LE 1M LE LL 23 990\302\265s 0 ADV_IND 9502 19.496 32:43:3c:28:8d:92 LE 1M LE LL 37 687\302\265s 0 ADV_NONCONN_IND 9503 19.497 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9504 19.497 32:43:3c:28:8d:92 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9505 19.504 07:69:22:f0:72:30 LE 1M LE LL 37 6686\302\265s 0 ADV_NONCONN_IND 9506 19.505 07:69:22:f0:72:30 LE 1M LE LL 37 195\302\265s 0 ADV_NONCONN_IND 9507 19.505 07:69:22:f0:72:30 LE 1M LE LL 37 194\302\265s 0 ADV_NONCONN_IND 9508 19.518 1e:28:49:84:c5:cd LE 1M LE LL 37 12319\302\265s 0 ADV_NONCONN_IND 9509 19.519 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9510 19.519 1e:28:49:84:c5:cd LE 1M LE LL 37 179\302\265s 0 ADV_NONCONN_IND 9511 19.523 43:bd:56:bd:74:f9 LE 1M LE LL 37 3702\302\265s 0 ADV_NONCONN_IND 9512 19.524 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9513 19.525 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9514 19.529 25:5f:bf:53:1f:d7 LE 1M LE LL 37 3741\302\265s 0 ADV_NONCONN_IND 9515 19.529 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9516 19.53 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9517 19.54 2b:5e:0e:c8:62:4c LE 1M LE LL 35 9455\302\265s 0 ADV_NONCONN_IND 9518 19.54 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 9519 19.541 2b:5e:0e:c8:62:4c LE 1M LE LL 35 179\302\265s 0 ADV_NONCONN_IND 9520 19.543 0c:6e:66:d7:ed:03 LE 1M LE LL 37 1679\302\265s 0 ADV_NONCONN_IND 9521 19.544 0c:6e:66:d7:ed:03 LE 1M LE LL 37 248\302\265s 0 ADV_NONCONN_IND 9522 19.544 0c:6e:66:d7:ed:03 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND 9523 19.545 11:fe:ef:ed:38:82 LE 1M LE LL 37 687\302\265s 0 ADV_NONCONN_IND 9524 19.546 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9525 19.546 11:fe:ef:ed:38:82 LE 1M LE LL 37 178\302\265s 0 ADV_NONCONN_IND 9526 19.561 16:ed:93:0f:fa:b0 LE 1M LE LL 37 14320\302\265s 0 ADV_NONCONN_IND 9527 19.562 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9528 19.562 16:ed:93:0f:fa:b0 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9529 19.569 3a:d1:ca:1d:4d:de LE 1M LE LL 26 6809\302\265s 0 ADV_NONCONN_IND 9530 19.57 3a:d1:ca:1d:4d:de LE 1M LE LL 26 456\302\265s 0 ADV_NONCONN_IND 9531 19.571 3a:d1:ca:1d:4d:de LE 1M LE LL 26 455\302\265s 0 ADV_NONCONN_IND 9532 19.575 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3754\302\265s 0 SCAN_REQ 9533 19.576 71:c4:79:42:57:d8 LE 1M LE LL 37 410\302\265s 0 ADV_IND 9534 19.576 64:0d:49:f9:4d:a4 LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9535 19.576 71:c4:79:42:57:d8 LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9536 19.579 31:ea:1b:25:0d:1f LE 1M LE LL 37 2716\302\265s 0 ADV_NONCONN_IND 9537 19.583 0d:62:2c:2a:24:88 LE 1M LE LL 37 3804\302\265s 0 ADV_NONCONN_IND 9538 19.584 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9539 19.585 0d:62:2c:2a:24:88 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9540 19.586 e5:ea:46:16:3e:1e LE 1M LE LL 36 1443\302\265s 0 ADV_IND 9541 19.587 7f:e1:7b:e4:24:1c LE 1M LE LL 12 150\302\265s 0 SCAN_REQ 9542 19.587 e5:ea:46:16:3e:1e LE 1M LE LL 6 150\302\265s 0 SCAN_RSP 9543 19.587 e5:ea:46:16:3e:1e LE 1M LE LL 36 136\302\265s 0 ADV_IND 9544 19.591 1c:2b:bf:5c:a9:12 LE 1M LE LL 37 3079\302\265s 0 ADV_NONCONN_IND 9545 19.592 7f:e1:7b:e4:24:1c LE 1M LE LL 12 929\302\265s 0 SCAN_REQ 9546 19.594 08:ec:5e:66:cd:0d LE 1M LE LL 23 1373\302\265s 0 ADV_NONCONN_IND 9547 19.594 08:ec:5e:66:cd:0d LE 1M LE LL 23 132\302\265s 0 ADV_NONCONN_IND 9548 19.598 69:a9:48:2f:b7:16 LE 1M LE LL 37 3139\302\265s 0 ADV_NONCONN_IND 9549 19.598 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9550 19.599 69:a9:48:2f:b7:16 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9551 19.602 7f:e1:7b:e4:24:1c LE 1M LE LL 12 2282\302\265s 0 SCAN_REQ 9552 19.605 c3:e5:c0:d9:88:70 LE 1M LE LL 36 3167\302\265s 0 ADV_IND[Malformed Packet] 9553 19.606 b6:4b:fc:28:8d:92 LE 1M LE LL 37 249\302\265s 0 ADV_NONCONN_IND[Malformed Packet] 9554 19.608 74:d9:0b:7a:47:5a LE 1M LE LL 23 2134\302\265s 0 ADV_IND 9555 19.609 7f:e1:7b:e4:24:1c LE 1M LE LL 12 149\302\265s 0 SCAN_REQ 9556 19.609 53:c4:c8:88:0b:c6 LE 1M LE LL 135 150\302\265s 0 SCAN_RSP[Malformed Packet] 9557 19.622 c5:65:68:79:19:c8 LE 1M LE LL 36 12238\302\265s 0 ADV_IND 9558 19.623 72:cb:d3:f2:71:8c LE 1M LE LL 23 255\302\265s 0 ADV_NONCONN_IND 9559 19.624 6f:54:d4:dd:c1:58 LE 1M LE LL 12 355\302\265s 0 SCAN_REQ 9560 19.631 43:bd:56:bd:74:f9 LE 1M LE LL 37 6744\302\265s 0 ADV_NONCONN_IND 9561 19.631 43:bd:56:bd:74:f9 LE 1M LE LL 37 456\302\265s 0 ADV_NONCONN_IND 9562 19.632 43:bd:56:bd:74:f9 LE 1M LE LL 37 455\302\265s 0 ADV_NONCONN_IND 9563 19.636 7f:e1:7b:e4:24:1c LE 1M LE LL 12 3249\302\265s 0 SCAN_REQ 9564 19.638 25:5f:bf:53:1f:d7 LE 1M LE LL 37 1526\302\265s 0 ADV_NONCONN_IND 9565 19.638 25:5f:bf:53:1f:d7 LE 1M LE LL 37 180\302\265s 0 ADV_NONCONN_IND 9566 19.639 7f:e1:7b:e4:24:1c LE 1M LE LL 12 735\302\265s 0 SCAN_REQ 9567 19.64 45:9b:f4:8b:97:f9 LE 1M LE LL 37 410\302\265s 0 ADV_IND 9568 19.641 f4:bb:6b:e4:ce:75 LE 1M LE LL 37 1193\302\265s 0 ADV_NONCONN_IND 9569 19.644 df:54:d4:5d:c1:59 LE 1M LE LL 10 1966\302\265s 0 SCAN_REQ[Malformed Packet]
Hi Gautam,
You would need to select the device d2:52:6a:67:61:fd in the dropdown list to be able to track it communication (connection).
You can take a look at this academy course on how to use the sniffer. Please take a look here.
Also when you capture the trace please save it as a file (.pcapng) and send us the file.
hello,
this is the pcapng file,
and when i try to run BLE-WIFI command then 1-2 times i get invalid argument and then i get time-out error.
if in case this file don't work:
Hi Gautam,
I'm sorry for the late response. It's holiday in Norway last week.
Your new trace still doesn't capture the communication between the two devices.
My suggestion is to follow our course on capturing sniffer trace here: https://academy.nordicsemi.com/lessons/lesson-6-bluetooth-le-sniffer/
What you need to look for when capturing the trace is to see the connection established and the communication before it's terminated.
