Error Code 4 Returned by lte_lc_conn_eval_params_get() Function after 12 Hours
Hello DevZone community,
I have been using the lte_lc_conn_eval_params_get() function in my application, which is executed periodically.
However, I'm encountering an error after exactly 12 hours of operation. The error code returned is 4.
My Environment
NCS - SDK 1.9.1
Device - nrf9160 customized one
Error log
[2023/05/16 23:42:26] [lte_thread] [ERROR] lte_lc_conn_eval_params_get error 4
I'm seeking assistance in understanding the possible causes of this error and any recommended solutions or workarounds to resolve it.
Any insights or experiences shared would be greatly appreciated.
Thank you in advance for your help!
Best Regards
Praveen Deshmane
  • Hello Jonathan,
    Thank you for your time.
    I have followed the URL which you shared and configured my prf.conf to enable modem trace.
    CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    # General config
    CONFIG_REBOOT=y
    CONFIG_RING_BUFFER=y
    # LOGGNG
    CONFIG_LOG=n
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # Console
    CONFIG_PRINTK=y
    CONFIG_UART_CONSOLE=n
    CONFIG_SHELL=y
    CONFIG_KERNEL_SHELL=y
    CONFIG_DEVICE_SHELL=y
    CONFIG_POSIX_CLOCK=y
    CONFIG_DATE_SHELL=y
    CONFIG_SHELL_STACK_SIZE=1536
    CONFIG_SHELL_BACKEND_SERIAL=n
    CONFIG_THREAD_MONITOR=y
    CONFIG_INIT_STACKS=y
    CONFIG_BOOT_BANNER=n
    CONFIG_THREAD_NAME=y
    #enable RTT shell
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SHELL_BACKEND_RTT=y
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=32
    # UART
    CONFIG_UART_ASYNC_API=y
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_KEY_MGMT=y
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_NANO=n
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    CONFIG_LTE_LOCK_BANDS=y
    CONFIG_LTE_LOCK_BAND_MASK="0000000001000000000000000001"
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    # PDN library
    CONFIG_PDN=y
    CONFIG_PDN_SYS_INIT=n
    CONFIG_PDN_DEFAULTS_OVERRIDE=y
    CONFIG_PDN_DEFAULT_APN="iijmobile.biz"
    CONFIG_PDN_DEFAULT_FAM_IPV4=y
    CONFIG_PDN_DEFAULT_AUTH_CHAP=y
    CONFIG_PDN_DEFAULT_USERNAME="mobile@iij"
    CONFIG_PDN_DEFAULT_PASSWORD="iij"
    # Stacks and heaps
    CONFIG_HEAP_MEM_POOL_SIZE=33792
    # for debug
    CONFIG_DEBUG_THREAD_INFO=y
    CONFIG_OPENOCD_SUPPORT=y
    CONFIG_MAIN_STACK_SIZE=8192
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Flash
    CONFIG_SPI=y
    CONFIG_FLASH=y
    # I2C
    CONFIG_I2C_NRFX=y
    CONFIG_I2C=y
    #IMU
    CONFIG_SENSOR=y
    CONFIG_ICM42605=y
    CONFIG_ICM42605_TRIGGER_NONE=y
    # json
    CONFIG_JSON_LIBRARY=y
    # float
    # for Zmod library
    CONFIG_FPU=y
    CONFIG_FPU_SHARING=y
    CONFIG_FP_HARDABI=y
    CONFIG_CPU_LOAD=y
    CONFIG_DATE_TIME=y
    CONFIG_CJSON_LIB=y
    # appication fota update configuration
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_SOCKET_RETRIES=5
    CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
    #DFU
    CONFIG_DFU_TARGET=y
    # MCUBOOT
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # Image manager
    CONFIG_IMG_MANAGER=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # Download client
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2048
    CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
    CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=n
    CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG=n
    CONFIG_DOWNLOAD_CLIENT_LOG_HEADERS=n
    CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=600000
    # DFU Target
    CONFIG_DFU_TARGET_STREAM=y
    CONFIG_DFU_TARGET_FULL_MODEM=y
    # Full modem firmware from external flash support
    CONFIG_FMFU_FDEV=y
    CONFIG_CDDL_GEN=y
    #SPI NOR
    CONFIG_SPI_NOR=y
    #Stream flash
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_ERASE=y
    #libmodem
    CONFIG_NRF_MODEM_LIB_SYS_INIT=n
    #Prevalidation is not yet supported by the modem firmware, so skip it for now.
    CONFIG_FMFU_FDEV_SKIP_PREVALIDATION=n
    CONFIG_NO_OPTIMIZATIONS=y
    CONFIG_EXTRA_EXCEPTION_INFO=y
    CONFIG_NCS_SAMPLES_DEFAULTS=n
    # Crypto
    CONFIG_OBERON_BACKEND=y
    CONFIG_NORDIC_SECURITY_BACKEND=y
    # Disable all non-used crypto
    CONFIG_NRF_SECURITY_RNG=n
    CONFIG_MBEDTLS_AES_C=n
    CONFIG_MBEDTLS_CHACHA20_C=n
    CONFIG_MBEDTLS_POLY1305_C=n
    CONFIG_MBEDTLS_ECP_C=n
    CONFIG_MBEDTLS_RSA_C=n
    CONFIG_MBEDTLS_DHM_C=n
    CONFIG_MBEDTLS_SHA1_C=n
    CONFIG_MBEDTLS_SHA384_C=n
    CONFIG_MBEDTLS_SHA512_C=n
    CONFIG_MBEDTLS_GCM_C=n
    # This is the one we need
    CONFIG_MBEDTLS_SHA256_C=y
    I am getting below issue when building my application.
    -- Generating done
    -- Build files have been written to: C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at C:/Users/ift_praveen/ncs/v1.9.1/nrf/modules/mcuboot/CMakeLists.txt:262 (message):
            --- WARNING: Using default MCUBoot key, it should not ---
            --- be used for production.                           ---
    CMake Warning at C:/Users/ift_praveen/ncs/v1.9.1/zephyr/CMakeLists.txt:764 (message):
      No SOURCES given to Zephyr library:
      ..__..__..__Desktop__IM-830__WORK2.5__dev_lpwa__im830__boards__arm__im830_nrf9160
      Excluding target from build.
      No SOURCES given to Zephyr library: subsys__net__pkt_filter
    -- Found partition manager static configuration: C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/pm_static.yml
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    Partition 'nrf_modem_lib_ctrl' is not included in the dynamic resolving since it is statically defined.
    Partition 'nrf_modem_lib_rx' is not included in the dynamic resolving since it is statically defined.
    Partition 'nrf_modem_lib_sram' is not included in the dynamic resolving since it is statically defined.
    Partition 'nrf_modem_lib_tx' is not included in the dynamic resolving since it is statically defined.
    Partition 'spm' is not included in the dynamic resolving since it is statically defined.
    Partition 'spm_sram' is not included in the dynamic resolving since it is statically defined.
    Partition 'sram_nonsecure' is not included in the dynamic resolving since it is statically defined.
    Partition 'sram_secure' is not included in the dynamic resolving since it is statically defined.
    Partition manager failed: End of last partition is after last valid address
    Failed to partition region sram_primary, size of region: 262144
    Partition Configuration:
    nrf_modem_lib_ctrl:
      placement:
        after:
        - spm_sram
        - start
    nrf_modem_lib_rx:
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
    nrf_modem_lib_trace:
      placement: {}
    nrf_modem_lib_tx:
      placement:
        after:
        - nrf_modem_lib_ctrl
    spm_sram:
      placement:
        after:
        - start
    sram_nonsecure:
    sram_primary:
    sram_secure:
    CMake Error at C:/Users/ift_praveen/ncs/v1.9.1/nrf/cmake/partition_manager.cmake:274 (message):
      Partition Manager failed, aborting.  Command:
      C:/Users/ift_praveen/ncs/v1.9.1/toolchain/opt/bin/python.exe;C:/Users/ift_praveen/ncs/v1.9.1/nrf/scripts/partition_manager.py;--input-files;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/spm/zephyr/include/generated/pm.yml;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/spm/modules/nrf/subsys/partition_manager/pm.yml.trustzone;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/mcuboot/zephyr/include/generated/pm.yml;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/zephyr/include/generated/pm.yml;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/modules/nrf/subsys/partition_manager/pm.yml.libmodem;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/modules/nrf/subsys/partition_manager/pm.yml.trustzone;--regions;sram_primary;otp;flash_primary;--output-partitions;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/partitions.yml;--output-regions;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/regions.yml;--static-config;C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/pm_static.yml;--sram_primary-size;0x40000;--sram_primary-base-address;0x20000000;--sram_primary-placement-strategy;complex;--sram_primary-dynamic-partition;sram_primary;--otp-size;756;--otp-base-address;0xff8108;--otp-placement-strategy;start_to_end;--flash_primary-size;0x100000;--flash_primary-base-address;0x0;--flash_primary-placement-strategy;complex;--flash_primary-device;NRF_FLASH_DRV_NAME
      C:/Users/ift_praveen/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake:678 (include)
      C:/Users/ift_praveen/ncs/v1.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      C:/Users/ift_praveen/ncs/v1.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
      CMakeLists.txt:5 (find_package)
    See also "C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/CMakeFiles/CMakeOutput.log".
    See also "C:/Users/ift_praveen/Desktop/IM-830/WORK2.5/dev_lpwa/im830/build/CMakeFiles/CMakeError.log".
    ninja: error: rebuilding 'build.ninja': subcommand failed
    FAILED: build.ninja
    could you please check and guide me to solve this issue.
    Thank You.
    Best Regards
    Praveen Deshmane
  • Hi Praveen, pardon the long response time but I am currently not working more then two days a week so responses can be far between. I see that you are getting follow up help from Didrik on you new ticket so you will likely be able to solve the issue there.
    Jonathan
