Bootloader is not discoverable
I am trying to integrate bootloader to my firmware, But after integrating bootloader to my firmware it's not discoverable.
This is the debug terminal result when I try to debug but I can't see any device showing on nrf Connect app
Using nrf52832, SDK 16.00
Furthermore,
1)   Led 2 is blinking
 * @brief Function notifies certain events in DFU process.
static void dfu_observer(nrf_dfu_evt_type_t evt_type)
    switch (evt_type)
        case NRF_DFU_EVT_DFU_FAILED:
           bsp_board_led_on(BSP_BOARD_LED_0);
        case NRF_DFU_EVT_DFU_ABORTED:
           bsp_board_led_on(BSP_BOARD_LED_1);
        case NRF_DFU_EVT_DFU_INITIALIZED:
            bsp_board_led_on(BSP_BOARD_LED_2);
        case NRF_DFU_EVT_TRANSPORT_ACTIVATED:
            bsp_board_led_off(BSP_BOARD_LED_1);
        case NRF_DFU_EVT_DFU_STARTED:
2).. When I comment out the bootloader code but add its files to my firmware an error occurs as
app: ERROR 1 [NRF_ERROR_SVC_HANDLER_MISSING] PC at: 0x0002FF01
The error is being shown in ble_stack_init, but this function looks fine
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
Csan't figure out where to find the problematic part in code or any file that need to be added
  • yes device is working fine apart from not sending the sensor data in ,
    Sometimes when I upload the firmware directly, I can't update any firmware zip file on it
    However, I tested the same zip file by updating it on another firmware, There is no problem in zip file but there is problem in my firmware but I don't know where it is as everything seems pretty normal
    This is the code,
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * Peripheral: SAADC
     * Compatibility: nRF52832 rev 2/nRF52840 rev 1, SDK 15.2.0
     * Softdevice used: S132 v6.1.0/S140 v6.1.0
     * This SAADC example samples on 4 different input pins, and enables scan mode to do that. It is otherwise an
     * offsprint from the standard ble_app_uart example available in nRF5 SDK 15.2.0
     * Works together with softdevice S132 v6.1.0 on nRF52832 and S140 v6.1.0 on nRF52840
     * Transmits SAADC output to hardware UART and over BLE via Nordic UART Servive (NUS).
     * Info on NUS -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/ble_sdk_app_nus_eval.html?cp=4_0_0_4_1_2_17
     * Info on hardware UART settings -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/uart_example.html?cp=4_0_0_4_4_41
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_conn_params.h"
    #include "ble_srv_common.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_dfu_ble_svci_bond_sharing.h"
    #include "nrf_svci_async_function.h"
    #include "nrf_svci_async_handler.h"
    #include "ble_dfu.h"
    #include "nrf_power.h"
    #include "nrf_bootloader_info.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "DFU_TEST"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                        /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL      APP_TIMER_TICKS(2000)                   /**< Battery level measurement interval (ticks). */
    #define MIN_BATTERY_LEVEL                81                                      /**< Minimum simulated battery level. */
    #define MAX_BATTERY_LEVEL                100                                     /**< Maximum simulated 7battery level. */
    #define BATTERY_LEVEL_INCREMENT          1                                       /**< Increment between each simulated battery level measurement. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLES_IN_BUFFER         5
    #define SAADC_SAMPLE_RATE               250                                         /**< SAADC sample rate in ms. */
    #define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600                                     /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
    #define ADC_PRE_SCALING_COMPENSATION    6                                       /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
    #define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270                                     /**< Typical forward voltage drop of the diode . */
    #define ADC_RES_10BIT                   1024                                    /**< Maximum digital value for 10-bit ADC conversion. */
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 1                                          /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #define BLE_DFU_APP_SUPPORT
    /**@brief Macro to convert the result of ADC conversion in millivolts.
     * @param[in]  ADC_VALUE   ADC result.
     * @retval     Result converted to millivolts.
    #define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE) \
            ((((ADC_VALUE) *ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    BLE_BAS_DEF(m_bas);                                                 /**< Structure used to identify the battery service. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_battery_timer_id);                                  /**< Battery timer. */
    STATIC_ASSERT(IS_SRVC_CHANGED_CHARACT_PRESENT);  /** When having DFU Service support in application the Service Changed Characteristic should always be present. */
    //static dm_application_instance_t         m_app_handle;
    //static ble_dfu_t                         m_dfus;
    float dx=4.72; //12cm
    float dy=5.11; //13cm
    float x_0=7;   //17.78cm
    float y_0=4.47; //11.27
    float Ftot;
    float F21;
    float F21dy;
    float F13;
    float F13dx;
    float Fy;
    float Fx;
    float Xcopp;
    float Ycopp;
     uint8_t data[8];
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
         {BLE_UUID_BATTERY_SERVICE,              BLE_UUID_TYPE_BLE},
         {BLE_UUID_NUS_SERVICE,              NUS_SERVICE_UUID_TYPE}
    #define SAMPLES_IN_BUFFER 5
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
    static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       m_ppi_channel;
    static uint32_t                m_adc_evt_counter;
    uint8_t  battery_level;
    /**@brief Handler for shutdown preparation.
     * @details During shutdown procedures, this function will be called at a 1 second interval
     *          untill the function returns true. When the function returns true, it means that the
     *          app is ready to reset to DFU mode.
     * @param[in]   event   Power manager event.
     * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_DFU:
                NRF_LOG_INFO("Power management wants to reset to DFU mode.");
                // YOUR_JOB: Get ready to reset into DFU mode
                // If you aren't finished with any ongoing tasks, return "false" to
                // signal to the system that reset is impossible at this stage.
                // Here is an example using a variable to delay resetting the device.
                // if (!m_ready_for_reset)
                //      return false;
                // else
                //    // Device ready to enter
                //    uint32_t err_code;
                //    err_code = sd_softdevice_disable();
                //    APP_ERROR_CHECK(err_code);
                //    err_code = app_timer_stop_all();
                // YOUR_JOB: Implement any of the other events available from the power management module:
                //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
                //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
                //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
                return true;
        NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
        return true;
    //lint -esym(528, m_app_shutdown_handler)
    /**@brief Register application shutdown handler with priority 0.
    NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
    static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
        if (state == NRF_SDH_EVT_STATE_DISABLED)
            // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
            nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
            //Go to system off.
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    /* nrf_sdh state observer. */
    NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
        .handler = buttonless_dfu_sdh_state_observer,
    static void advertising_config_get(ble_adv_modes_config_t * p_config)
        memset(p_config, 0, sizeof(ble_adv_modes_config_t));
        p_config->ble_adv_fast_enabled  = true;
        p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
        p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
    static void disconnect(uint16_t conn_handle, void * p_context)
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
            NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
    // YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
    /**@brief Function for handling dfu events from the Buttonless Secure DFU service
     * @param[in]   event   Event from the Buttonless Secure DFU service.
    static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
                // Prevent device from advertising on disconnect.
                ble_adv_modes_config_t config;
                advertising_config_get(&config);
                config.ble_adv_on_disconnect_disabled = true;
                ble_advertising_modes_config_set(&m_advertising, &config);
                // Disconnect all other bonded devices that currently are connected.
                // This is required to receive a service changed indication
                // on bootup after a successful (or aborted) Device Firmware Update.
                uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
                NRF_LOG_INFO("Disconnected %d links.", conn_count);
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
                //           by delaying reset by reporting false in app_shutdown_handler
                NRF_LOG_INFO("Device will enter bootloader mode.");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
                // YOUR_JOB: Take corrective measures to resolve the issue
                //           like calling APP_ERROR_CHECK to reset the device.
            case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
                NRF_LOG_ERROR("Request to send a response to client failed.");
                APP_ERROR_CHECK(false);
                NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    ///**@brief Function for initializing the timer module.
    //static void timers_init(void)
    //    ret_code_t err_code = app_timer_init();
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
               //memcpy(data, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        ble_bas_init_t     bas_init;
        //ble_dfu_init_t   dfus_init;
        ble_dfu_buttonless_init_t dfus_init = {0};
        // Initialize DFU buttonless.
        dfus_init.evt_handler = ble_dfu_evt_handler;
        err_code =  ble_dfu_buttonless_init(&dfus_init);
        // Initialize NUS.
      // Initialize Battery Service.
          memset(&bas_init, 0, sizeof(bas_init));
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
         // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        err_code = ble_bas_init(&m_bas, &bas_init);
    /**@brief Function for initializing the sensor simulators.
    //static void sensor_simulator_init(void)
    //    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    //    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    //    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    //    m_battery_sim_cfg.start_at_max = true;
    /**@brief Function for starting application timers.
    static void application_timers_start(void)
        // Start application timers.
        err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
              case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
         case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                     (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                            err_code = ble_nus_data_send(&m_nus,data_array, &length, m_conn_handle);
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        /* setup m_timer for compare event every _____ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 5000);
        nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
    float f1;
    float f2;
    float f3;
    float f4;
    float X;
    float Y;
    int samples=15;
    // check if the sampling is done and we are ready to take these samples for processing
        if(p_event -> type == NRFX_SAADC_EVT_DONE)
          ret_code_t err_code; //store errors code
          nrf_saadc_value_t adc_result; uint16_t batt_lvl_in_milli_volts; uint8_t percentage_batt_lvl;
    adc_result = p_event->data.done.p_buffer[4];
    // A function to take the samples (which are in the buffer in the form of 2's complement), and convert them to 16-bit interger values
          err_code = nrfx_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
          int i;
          printf("ADC Event Occurred!!\r\n");
    batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS (adc_result) + DIODE_FWD_VOLT_DROP_MILLIVOLTS;
    percentage_batt_lvl = battery_level_in_percent (batt_lvl_in_milli_volts);
    NRF_LOG_INFO("Battery in %03d%%", percentage_batt_lvl);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
          for(i = 0; i<SAMPLES_IN_BUFFER; i++)
           if(i==0){
          // read the variable and print it
            f1 = p_event->data.done.p_buffer[i];
            if (i==1){
            f2 = p_event->data.done.p_buffer[i];
            if (i==2){
            f3 = p_event->data.done.p_buffer[i];
            if(i==3){
            f4 = p_event->data.done.p_buffer[i];
        Xc=f1+f2;
       printf("Xc: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(Xc));
        Yc=y_f3+f4;
       printf("Yc: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(Yc));
      float sum=0.0;
    float sum1=0.0;
    for(int a=0; a<=samples; a++){
    sum= sum+Xc;
    sum1= sum1+Yc;
    Xcop=sum/samples;
       printf("Xc average: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(X));
    Ycop=sum1/samples;
      printf("Yc average: " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(Y));
    uint32_t err_code;
    uint16_t length ;
    uint8_t data[50];
    length = sprintf(data, "X = %f, Y = %f\r\n", X,Y);
    err_code = ble_nus_data_send(&m_nus, data, &length, m_conn_handle);
    if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
    return;
    void saadc_init(void)
    // Create structs to hold the default configurations which will be used to initialize the adc module.
      nrf_saadc_channel_config_t channel1_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
      nrf_saadc_channel_config_t channel2_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
      nrf_saadc_channel_config_t channel3_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
      nrf_saadc_channel_config_t channel4_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
      nrf_saadc_channel_config_t channel5_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
      err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    // allocate the channel along with the configurations
      err_code = nrfx_saadc_channel_init(0, &channel1_config);
      err_code = nrfx_saadc_channel_init(1, &channel2_config);
      err_code = nrfx_saadc_channel_init(2, &channel3_config);
      err_code = nrfx_saadc_channel_init(3, &channel4_config);
     err_code = nrfx_saadc_channel_init(4, &channel5_config);
    // allocate first buffer(array) where the values will be stored once sampled
      err_code = nrfx_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    // allocate second buffer where the values will be stored if overwritten on first before reading
      err_code = nrfx_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        saadc_init();
         err_code = nrf_drv_saadc_sample();
      printf("%s", __func__);
            // Create timers.
        err_code = app_timer_create(&m_battery_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    battery_level_meas_timeout_handler);
    /**@brief Application main function.
    {   ret_code_t err_code;
        bool erase_bonds;
     //// Initialize the async SVCI interface to bootloader before any interrupts are enabled.
     //   err_code = ble_dfu_buttonless_async_svci_init();
      //timers_init();
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_sampling_event_init();
        saadc_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • You should connect a debugger to see if there is any errors in your application, and read out the log from the device. It is very hard to give any suggestions on what is failing from your current description of the problem.
