Error 116 Occurs after 12 hours of TLS socket connect()
Hello DevZone community,
I have been using the TLS socket in my application, which is executed whenever we need to call API or send logs.
However, I'm encountering an error after exactly 12 hours of operation. The error code returned is 116.
int mc_api_call(char* pReqMsg, int Msglen, char* pHost, int HostLen, char* pRcvBuf, int RcvBuflen)
	int err;
	int fd;
	int ret = -1;
	int sendbyte, recvbyte;
	size_t off;
	struct addrinfo *res;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM,
	k_sem_take(&mc_enable, K_FOREVER);
	err = getaddrinfo(pHost, NULL, &hints, &res);
	if (err) {
		MLOG_ERROR("getaddrinfo() failed, err %d", errno);
		k_sem_give(&mc_enable);
		return ret;
#if 0
	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
#else
	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTPS_PORT);
#if 0
	fd = socket(AF_INET, SOCK_STREAM, res->ai_protocol);
#else
	fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
	if (fd == -1) {
		// LOG_INF("Failed to open socket!");
		goto clean_up;
	err = tls_setup(fd, pHost, HostLen);
	if (err) {
		goto clean_up;
	MLOG_DEBUG("Connecting to %s", pHost);
	err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
	if (err) {
		MLOG_ERROR("connect() failed, err: %d", errno);
		goto clean_up;
	off = 0;
	do {
		sendbyte = send(fd, pReqMsg+off, Msglen - off, 0);
		if (sendbyte < 0) {
			MLOG_ERROR("send() failed, err %d", errno);
			goto clean_up;
		off += sendbyte;
	} while (off < sendbyte);
	MLOG_DEBUG("Send %d bytes", off);
	off = 0;
	memset(pRcvBuf, 0x00, RcvBuflen);
#if 0
	do{
		recvbyte = recv(fd, pRcvBuf+off, RcvBuflen - off, MSG_DONTWAIT);
		MLOG_DEBUG("Received %d bytes", recvbyte);
		if (recvbyte == 0) {
		cnt++;
		if(recvbyte < 0)
			if(cnt > 10)
				MLOG_WARNING("%s", "Receive time out");
				k_sleep(K_MSEC(1000));
				continue;
			cnt = 0;
		off += recvbyte;
	} while (recvbyte < RcvBuflen /* peer closed connection */);
#else
	do {
		recvbyte = recv(fd, pRcvBuf+off, RcvBuflen - off, 0);
		if (recvbyte < 0) {
		off += recvbyte;
	} while (recvbyte != 0 /* peer closed connection */);
	MLOG_DEBUG("Received end %d bytes", off);
	ret = off;
clean_up:
	freeaddrinfo(res);
	(void)close(fd);
	return ret;
My Environment
NCS - SDK 1.9.1
Device - nrf9160 customized one
Error log
[2023/05/17 23:42:44] [my_thread] [ERROR] connect() failed, err: 116
I'm seeking assistance in understanding the possible causes of this error and any recommended solutions or workarounds to resolve it.
Any insights or experiences shared would be greatly appreciated.
Thank you in advance for your help!
  • Do you have anything of what happens before you start to get errors?
    Hello Didrik,
    As we are unbale to get the modem trace (struggling from 3 months, there are other tickets raised for modem trace log).
    But I would like to inform you that we will get the connect() 116 error after this below error appears. This below error appears 12 hours after the device powered on. Within that 12 hours period everything works, like LTE connection, TCP socket connection. As soon as this error gets triggered, LTE connection will be there but TCP connection fails. Unable to make HTTPS API calls. I have also noticed that UDP connection works well.
    [2023/05/16 23:42:26] [lte_thread] [ERROR] lte_lc_conn_eval_params_get error 4
    Could you please check it and tell me what could be the problem.
    Kind Regards
    Praveen Deshmane
  • Which modem FW version are you using?
    Can you enable logs in the lte_lc library?
    CONFIG_LOG=y
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y
    And then send me the full log?
