SDK_ERROR observed
Hi Team,
I'm developing a custom app, based on the ble_app_uart.
I'm observing a error : SDK_ERROR (NRF_FAULT_ID_SDK_ERROR).
I'm unable to root cause it and also unable to get any information about this error.
I even though got the error details connecting the debugger.
Can you please share some insight about this crash/error. It will help to debug further the issue.
I understand the
Below are error details (taken from function app_error_save_and_stop()):-
  • Hi Vidar,
    Sorry to say but I couldn't upload the complete code base.
    Can you help me with some pointer on how to debug it or how you will debug it.
    Also how you got to know that its a corrupted/invalid stack pointer, as I least expect it because i have a simple application and the execution never comes the Application, it crashes even before it.
    I have reasons to say that its not occurring in or due Application as execution never reaches there.
    Also, yes I have also added the bootloader.
    And FYI, am uploading the binaries (bootloader / soft device / application) though JLINK !
    I first use the project dfu\secure_bootloader to write the bootloader (+soft device), then use my project to write the application + soft device. I hope its not an issue.
    Are you able to run the application if you only program the Softdevice and application without the bootloader?
    Because the stack pointer is well beyond the valid address range for RAM (which ranges from 0x20000000 to 0x20006000).
    It's not reaching main(), but is it reaching the application's reset handler?
    The bootloader will not be able to boot the application unless you also program a valid bootloader settings page along with it. See Combine application, bootloader and softdevice image - Bootloader setting.
  • Hi Vidar,
    Yes.
    ok
    Its not even reaching the application's reset handler, i tried by keeping a breakpoint in reset handler.
    Thanks for the information but i was expecting the project dfu\secure_bootloader will have the valid bootloader settings and while flashing the nordic device via JLink, it also writes the bootloader settings as well. If this is not the case, then
    1. can bootloader setting be written via JLink ?
    2. Is DFU Secure Bootloader MANDATORY to perform DFU via BLE ?
      1. As, i was trying to add bootloader to enable the DFU via BLE
    I guess the issue is with the bootloader setting, as i erased the complete flash via JLink and only flashed the Application + Soft Device via JLink, and i have it working.
    Then the problem isn't with the application, but with the bootloader. Please double check that the bootloader project you selected is configured to run on the nRF52810 and not some other nRF52 variant.
  • Hi Vidar,
    I'm using the project at location examples\dfu\secure_bootloader\pca10040e_s112_ble\ses.
    And even the flag DEVELOP_IN_NRF52832 is defined in the project.
