Using the nRF9160 against Anritsu MT8821C In Signaling Callbox Mode
This is a guide showing how to use the Anritsu MT8821C tester against Nordic's nRF9160.
Please use at least Cat-M version 40.10#205, NB IoT version 40.00#013 and Platform SW v40.10S#205 or later versions to have all required MT8821C implementations available when testing against the nRF9160
Setting up
The RF attenuations between the nRF9160 and MT8821C can be modified from "External Loss"
Use Nordic proprietary AT commands for selecting LTE-M1 or NB-IoT mode.
For LTE-M: AT%XSYSTEMMODE=1,0,0,0
For NB-IoT: AT%XSYSTEMMODE=0,1,0,0
Before triggering an attach with AT+CFUN=1, you need to send AT+CFUN=4 for the detach procedure first.
The full list of AT commands supported by Nordic can be found here:https://infocenter.nordicsemi.com/index.jsp?topic=%2Fref_at_commands%2FREF%2Fat_commands%2Fintro.html.
Cat-M Common settings
Cat-M Call Processing settings
NB-IoT Call Processing settings
Use SIM model number P0035 when the default Anritsu SIM card is used in "Authentication / Integrity"
Use integrity protection other than "Null" as the "Null" algorithm might not be supported in all nRF9160 builds (also in "Authentication / Integrity" selection)
Always enable "Half Duplex" functionality where selectable in Cat-M1 testing (full duplex will not work properly against nRF9160)
To enable UE to go to RRC idle mode after registration, use "RRC Release During Registration" from "RMC". This needs to be selected before starting the attach procedure.
To enable UE to go to RRC idle mode after other connections, select "use RRC state transition" from selection "General->Packet"
The selection "Inactivity Timer" in "Call Processing->Packet" keeps NB-IoT RRC connection alive until timer expires (in case there is no any data exchange ongoing).
For signaling RF testing, RRC connected mode is required (for RF related testing, it is recommended to use RMC mode from "Common->Signal->Channel Coding->RMC")
For the RSRP and RSRQ measurements being reported by nRF9160 on the own cell, select "Common->General-Scenario type 6" and EventA1 from "General->Measurement report" and enable measurement reporting from the GUI.
You can also use periodic measurements by selecting "General->Measurement->Periodical"
For the IP data application (Using Iperf and Ping from MT8821C (internally, without Control PC) can be found from "IP data"):
Cat-M1 : Set following parameters as below :
"Common->General->Scenario->Type 6"
"Common->Signal->Channel Coding->Packet"
"Call Processing->RMC->Test Mode->Off"
NB IoT :
"Common->UL RMC->MCSIndex->"at least 4""
Options for Cat-M1 & NB IoT IP data testing :
- Cat-M1 & NB IoT IP Data Transfer SW options needed.
Taking logs
Select "menu" from UI : "Log->Save signaling log", saved *.lge log might be enough for debugging.
The *.lge file can be viewed with PA3 viewer and will help in debugging (along with the nRF9160 modem trace).
Recallable Anritsu MT8821C configuration files
- files are available on request for both M1 and NB IoT. For recalling use "Menu->Parameter Save/Recall->Recall" and select file to be recalled.
    And thanks again for the quick reply. The test laboratory has now contacted Anritsu and asked about the firmware in question. I'll let you know when we get to try it.
    Best regards
    -Iisko84-
    According to Anritsu this FW 40.105#206 (which contains all the fixes required for nRF9160) is not yet officially released, but Anritsu can provide this latest Cat-M1 FW to you. Can you please contact [email protected] as they are aware of this request?
    BR
    -Mike-
  • Hello again MikeS,
    The test lab employee just messaged me that they can't find that version (40.105#206 or 40.10#205 ) on Anritsu's website and that Anritsu's website claims that the FW version (40.10#076) they are using is the latest. Is that particular Anritsu FW version available somewhere else?
    He also told about those SIM model numbers that they are using the same in both mode.
    -Iisko84-
  • Hello again,
    I could recall *.prm file here successfully with MT8821C version 40.105#206. I had to zip configuration file as I couldn't attach it here without zipping.
    If DUT gets connected in NB IoT mode against MT8821C then could you check which SIM model number is used in NB IoT and try with same SIM model number in Cat-M?
    See 2nd and 3rd screenshots in the blog for detailed information where to find these fields.
    BR
    -Mike-
  • Hi MikeS,
    I was able to visit the test laboratory thanks to the cancellation of another customer.
    That Anritsu's configuration file (CatM1Data.zip) you shared didn't work. Anrtisu said "illegal file" when they tried to recall the file to the Anritsu. The test lab staff couldn't find any specific reason why it didn't work because files contents matched the working configuration files.
    I know the article mentions this: "Please use at least Cat-M version 40.10#205" , but the FW of the device we used was Cat-M version 40.10#076. So could this be a reason for a warning?
    Another thing we noticed was that if we used Anritsu's original configuration settings and NB-IoT mode, the DUT connected to Anritsu and everything worked, but if we tried to connect in LTE-M1 mode, the connection failed due to an authentication error.
    Iisko84
