Purpose
This document will show how to automate the provisioning process for Nordic BLE Mesh nodes using Python scripting. When provisioning nodes using PyACI (Python Application Controller Interface), the Interactive Python shell is used to type in provisioning commands. However, this process can be automated by putting the commands in a script that is run automatically.
Modifications
In order to be able to automate this process, some modifications were required to the PyACI source code. In specific, the ConfigurationClient object in config.py was patched to provide blocking calls. In the original code, methods of this object are non-blocking which return immediately. A callback function is invoked once the results of the command are returned from the remote node over RF. For scripting purposes, this is problematic since a script should be monotonic with each command passing or failing. If a command fails, the script should abort or raise an exception to notify the user or appropriate error handling (such as retrying). The accompanying patch (attached) converts the non-blocking calls to blocking calls in [Mesh SDK 3.1.0]/scripts/interactive_pyaci/models/config.py.
Demonstration
The following Python script represents an example that can be extended to automate this process; save this to a file called command.txt:
from time import sleep
import sys
try:
db = MeshDB("database/example_database.json")
db.provisioners
p = Provisioner(device, db)
p.scan_start()
sleep(3)
p.scan_stop()
p.provision(name="Light bulb #1")
sleep(4)
cc = ConfigurationClient(db, True)
device.model_add(cc)
cc.publish_set(8, 0)
cc.composition_data_get()
except:
print("Unexpected error:", sys.exc_info()[0])
The try block has the sample provisioning commands; if any failure occurs the exception will be caught in the exception block. This script can be expanded to implement more intricate error handling and possible retries.
To run the above script, we will pass it to PyACI via the command line shown below:
python interactive_pyaci.py -d COM20 -l 3 < command.txt
The serial port will be changed accordingly to the local machine, of course. The “-l 3” command is to enable logging but is completely optional.
The above command redirects command.txt into the PyACI shell and it executes it within its environment. Full Python programming language is available to the user at their disposal to make the script as intricate as needed.
As an example, this is the output of running the above command as it runs to completion without errors:
python interactive_pyaci.py -d COM20 -l 3 < commands.txt
To control your device, use d[x], where x is the device index.
Devices are indexed based on the order of the COM ports specified by the -d option.
The first device, d[0], can also be accessed using device.
Type d[x]. and hit tab to see the available methods.
Python 3.7.1 (v3.7.1:260ec2c36a, Oct 20 2018, 14:57:15) [MSC v.1915 64 bit (AMD64)]
Type 'copyright', 'credits' or 'license' for more information
IPython 7.0.1 -- An enhanced Interactive Python. Type '?' for help.
In [1]:
In [2]:
In [3]:
In [3]: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: 2019-01-26 23:56:03,734 - INFO - COM20: Success
2019-01-26 23:56:03,749 - INFO - COM20: Success
2019-01-26 23:56:03,758 - INFO - COM20: SubnetAdd: {'subnet_handle': 0}
2019-01-26 23:56:03,763 - INFO - COM20: AppkeyAdd: {'appkey_handle': 0}
2019-01-26 23:56:03,767 - INFO - COM20: AppkeyAdd: {'appkey_handle': 1}
2019-01-26 23:56:03,774 - INFO - COM20: Success
2019-01-26 23:56:05,138 - INFO - COM20: Received UUID 5c8e16a4cdd378408297d12e7dd9ce68 with RSSI: -34 dB
2019-01-26 23:56:06,736 - INFO - COM20: Success
2019-01-26 23:56:06,742 - INFO - COM20: Provision: {'context': 0}
2019-01-26 23:56:06,747 - INFO - COM20: Link established
2019-01-26 23:56:06,813 - INFO - COM20: Received capabilities
2019-01-26 23:56:06,816 - INFO - COM20: Number of elements: 1
2019-01-26 23:56:06,822 - INFO - COM20: OobUse: {'context': 0}
2019-01-26 23:56:09,059 - INFO - COM20: ECDH request received
2019-01-26 23:56:09,072 - INFO - COM20: EcdhSecret: {'context': 0}
2019-01-26 23:56:09,379 - INFO - COM20: Provisioning complete
2019-01-26 23:56:09,382 - INFO - COM20: Address(es): 0x36-0x36
2019-01-26 23:56:09,385 - INFO - COM20: Device key: bbd765a44c53f8ac7b09e72d45c37770
2019-01-26 23:56:09,387 - INFO - COM20: Network key: 18eed9c2a56add85049ffc3c59ad0e12
2019-01-26 23:56:09,390 - INFO - COM20: Adding device key to subnet 0
2019-01-26 23:56:09,393 - INFO - COM20: Adding publication address of root element
2019-01-26 23:56:09,423 - INFO - COM20: DevkeyAdd: {'devkey_handle': 8}
2019-01-26 23:56:09,442 - INFO - COM20: AddrPublicationAdd: {'address_handle': 0}
2019-01-26 23:56:09,472 - INFO - COM20: Provisioning link closed
2019-01-26 23:56:10,745 - INFO - COM20.ConfigurationClient: Sleeping 10
2019-01-26 23:56:10,750 - INFO - COM20: PacketSend: {'token': 1}
2019-01-26 23:56:10,754 - INFO - COM20: {event: MeshTxComplete, data: {'token': 1}}
2019-01-26 23:56:11,763 - INFO - COM20.ConfigurationClient: Sleeping 9
2019-01-26 23:56:12,768 - INFO - COM20.ConfigurationClient: Sleeping 8
2019-01-26 23:56:13,784 - INFO - COM20.ConfigurationClient: Sleeping 7
2019-01-26 23:56:14,797 - INFO - COM20.ConfigurationClient: Sleeping 6
2019-01-26 23:56:15,812 - INFO - COM20.ConfigurationClient: Sleeping 5
2019-01-26 23:56:16,826 - INFO - COM20.ConfigurationClient: Sleeping 4
2019-01-26 23:56:16,933 - INFO - COM20: Calling event handler
2019-01-26 23:56:16,970 - INFO - COM20.ConfigurationClient: Received composition data (page 0x00): {
"cid": "0059",
"pid": "0000",
"vid": "0000",
"crpl": 40,
"features": {
"relay": 0,
"proxy": 0,
"friend": 2,
"low_power": 2
"elements": [
"index": 0,
"location": "0000",
"models": [
"modelId": "0000"
"modelId": "0002"
"modelId": "1000"
2019-01-26 23:56:17,836 - INFO - COM20.ConfigurationClient: blocked = 0, timeout = 3
In [4]:
In [4]:
In [4]:
In [4]: Do you really want to exit ([y]/n)?
The cc.composition_data_get() command in the commands.txt script has been patched to be a blocking call. As is seen in the debug output above, it has a sleeping countdown that counts down to ten seconds while waiting for a response from the remote node. If a response is received within the allotted time, the command exits with no error. Otherwise, an exception is thrown.
Now let us see a degenerate case where there are errors:
In [1]:
In [2]:
In [3]:
In [3]: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: ...: 2019-01-26 23:57:16,204 - INFO - COM20: Success
2019-01-26 23:57:16,219 - ERROR - COM20: None: ERROR_REJECTED
2019-01-26 23:57:16,226 - ERROR - COM20: SubnetAdd: ERROR_INTERNAL
2019-01-26 23:57:16,232 - ERROR - COM20: AppkeyAdd: ERROR_INTERNAL
2019-01-26 23:57:16,237 - ERROR - COM20: AppkeyAdd: ERROR_INTERNAL
2019-01-26 23:57:16,242 - INFO - COM20: Success
Unexpected error: <class 'IndexError'>
In [4]:
2019-01-26 23:57:19,212 - INFO - COM20: SuccessIn [4]:
In [4]:
The Unexpected error: <class 'IndexError'> is from the exception block of the commands.txt script. This demonstrates the script handling an error in the execution of the script.
