How to @Mention Names With Spaces
See: https://devzone.nordicsemi.com/f/nordic-q-a/37743/problem-with-fds-flash-read-write-delete-calling-that-function-using-android-phone/151618#151618
Although the forum allows names with spaces - eg, "" - the automatic lookup when you type the '@' to mention someone does not work with spaces!
  • It's worse than that!
    The forum allows two different users to have the same name - and the @ mention feature can't cope with that!
    See: https://devzone.nordicsemi.com/backstage/f/welcome-to-the-devzone/42608/forum-allows-multiple-users-with-the-same-name
  • Just found another one!
    User "" has a "display" name with a space - so that can't be @ Mentioned.
    But the "hidden" name is "nyp-nb_2d00_iot" - which also cannot be @ Mentioned because it has a hyphen in !!
  • This seems to be an inherent fault in the underlying forum software.
    ARM have just started using what appears to be exactly the same product for their Keil forum - and it has exactly the same issue!
    The problem is compounded by the fact that the list of suggestions seems to be just a random selection from all the names which contain the string in any position.
    Here's a Keil example:
    So the list would be a lot more useful if it prioritised:
    1. The search string at the beginning of the name;
    2. Names of contributors to the current thread.
    3. Where the string occurs as (the start of) a complete word - rather than any substring anywhere within any word.
    Again, this looks like an underlying flaw in the 3rd-party product - so, presumably, outside Nordic's control?
    But perhaps you could pass this on to the supplier?
    Cheers.
