Debugging nRF52 series devices using Trace
#Why use trace
#Overview
  1. Invasive debugging (i.e. program halt and stepping, HW breakpoints, etc...)
  2. Noninvasive debugging (i.e. memory access, trace, profiling)
  • Instruction trace: Generated by the Embedded Trace Macrocell (ETM).
  • Data trace: Generated by the Data Watchpoint and Trace (DWT) unit.
  • Debug message: Generated by ITM, provides message output such as printf in the debugger GUI.
Main benefits of ETM:
  • Trace and debug your system executing in real-time.
  • Collect vital timing on program execution for performance optimizations and ‘always-in-time’ code verification.
  • Capture program activity around the event you want to look at.
#Setting up and using ETM
  1. Connect debugger (with trace functionality) to target device, making sure trace pins are connected (see which GPIOs are trace pins here: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/pin.html#pin_assign). Note that we have a custom board to make this easy but you will have to figure something else out.
  1. Make sure you have up-to-date startup files and define ENABLE_TRACE in your project's preprocessor definitions. When this is defined trace functionality will be enabled in system_nrf52.c as seen in the screen shot below.
  1. Configure ETM in your Debug Settings as in the screen shot below. More info here: http://www.keil.com/support/man/docs/jlink/jlink_tracing.htm.
  1. Start the debugging session and open the Instruction Trace Window or the trace window of your choice. http://www.keil.com/support/man/docs/jlink/jLink_uvision_windows.htm.
