The nRF5x series Software Development Kits (SDK) come with Makefiles for use with the GNU ARM toolchain. This makes it possible to build example projects only using command line tools on your preferred platform (Windows, Linux or OS X). In this tutorial I will go through the necessary steps to integrate these examples with Eclipse in order to get common features associated with IDEs such as jump to declarations, code completion and debugger integration.
The scope of this tutorial will be limited to Makefile managed project in Eclipse to allow the existing SDK Makefiles to be used. A Makefile managed project is as the name implies, controlled by the Makefile and also built outside of the Eclipse environment using external tools, unlike other common IDE setups where the build recipe is a made based on project configurations. This means that the build will not be affected by project settings configured in Eclipse. I.e., adding source files, defines and include paths. So to actually manage your build you need to change the Makefile itself. We will later in the tutorial use the CDT output parser to parse the output of the Makefile to have the symbols and include paths added to the Eclipse project automatically in order to get some integration between the external build and project view in Eclipse as illustrated below.
The other alternative not covered in this tutorial is Eclipse Managed projects that automatically generates Makefiles based on your project settings and therefore giving a tighter integration between Eclipse and the build process. It is an option. However, main reason for not including it here is because it takes more time to set up, and the end result is about the same in terms of usability.
Before we start setting up Eclipse we need to install some software components required to build source code, and also software to load it to the target device. These components enables us to test the SDK examples from the command line in addition to Eclipse.
GNU toolchain for ARM Cortex-M
GNU toolchain including compiler and GDB debugger can be downloaded using the following link. Download and install the latest version. Then make sure to add the path to your toolchain to your OS PATH environment variable:
<path to install directory>/GNU Tools ARM Embedded/4.9 2015q3/bin
Adding the path makes it possible to run the toolchain executables from any directory using the terminal. To verify that the path is set correctly, type the following in your terminal:
arm-none-eabi-gcc --version
This will return the version of the C compiler if the executable is found in your path.
GNU make
Now with the toolchain installed we can build object files from source code, but to build projects based on makefiles, which can be seen as a recipes for the builds, we need to have GNU make installed on the system.
On windows it can be obtained by installing the GNU ARM Eclipse Windows Build Tools package from the GNU ARM Eclipse plug-in project. This package also adds support for shell commands such as rm and mkdir that are used by our Makefiles.
Linux and OS X already have the necessary shell commands, but GNU make may not be a part of the standard distro. Call "make -v" from the terminal to check whether it is installed or not. GNU make would need to be installed if it's not recognized as a command.
GNU make is bundled with Xcode tools if working on OS X.
On Linux it may be different ways to obtain GNU make depending on your distro, if not installed already. On Ubuntu you can get by entering this command:
sudo apt-get install build-essential checkinstall
Nordic nRF5x SDK
Download SDK 11.0.0 from http://developer.nordicsemi.com/, or SDK 10.0.0 if s110 is to be used on the nRF51.
To build an example in the SDK you first need to set the toolchain path in makefile.windows or makefile.posix depending on platform you are using. That is, the .posix should be edited if your are working on either Linux or OS X. These files are located in
<SDK>/components/toolchain/gcc
Open the file in a text editor, and make sure that the GNU_INSTALL_ROOT variable is pointing to your Gnu tools for ARM embedded Processors install directory.
Correct values for my current setup:
GNU_INSTALL_ROOT := $(PROGFILES)/GNU Tools ARM Embedded/4.9 2015q3 // Toolchain path GNU_VERSION := 4.9.3 GNU_PREFIX := arm-none-eabi
Now you can try to build one of the example projects. Will use the blinky example here to keep it simple:
Open terminal and change directory to
<SDK>/examples/peripheral/<board name>/blank/armgcc/
Alternatively, open the terminal in that directory. In windows, navigate to the directory in explorer, press 'Alt+D' and type 'cmd' in the address field followed by return.
Type 'make'. GNU Make should start the build using the Makefile and output the result in the _build directory. If everything works you should get the output shown in the screenshot below.
If you instead get an error saying something like "the sysem cannot find the files specified" it typically means that the GNU toolchain path is set incorrectly. Verify the path in makefile.windows/posix if you get this.
Errors like "make: No rule to make target '_build/Nordic', needed by `nrf51422_xxac". Stop can also be an indication that build tools are unable to handle whitespaces in the path. E.g, c:/nordic semicondtor/SDK/... Workaround is to remove any whitespaces you may have with underscores.
nrfjprog - Programming Tool
nrfjprog bundled in the nRF5x-Command-Line-Tools is a command line tool for loading FW images to target via the debug interface (SWD). This tool has now been ported to all three platforms; Linux, Windows, and osx
Now you can try to load the FW image built in the previous step to your target.
nrfjprog:
/* Optional: erase target if not already blank */ <SDK>/examples/peripheral/<board name>/blank/armgcc/>nrfjprog --family <nRF51/52> -e /* Load FW image to target */ <SDK>/examples/peripheral/<board name>/blank/armgcc/>nrfjprog --family <nRF51/52> --program _build/<name>.hex /* Reset and run */ <SDK>/examples/peripheral/<board name>/blank/armgcc/>nrfjprog --family <nRF51/52> -r
Nrfjprog is tailored for the nRF5 series devices, but it is also possible to use Jlink commander for the same in case its needed:
/* Open Jlink Commander from terminal in _build directory */ JLinkExe (jlink on windows) -device <nRF51/nRF52> > erase // Optional: erase target if not already blank > loadfile <name>.hex // loads FW > r // Reset and halt > g // Run > q // Exit
You should see blinking LEDs on your kit once you have completed the steps above. Now we are ready for the next step which is to Download Eclipse and start configuring it.
Eclipse Neon IDE for C/C++ Developers
Download the latest Neon C/C++ developers package for your OS at https://www.eclipse.org/downloads/packages/release/Neon
The following steps shows the general settings configurations of Eclipse that are not project specific.
Install GNU ARM Eclipse plug-in
The GNU ARM Eclipse plug-in simplifies debugger integration in Eclipse significantly in addition to adding support for the GCC ARM compiler so paths to the standard toolchain libraries are set automatically.
Instruction on how to install it are provided on their website: http://gnuarmeclipse.github.io/plugins/install/
Required packages are:
The other packages are optional.
Install device family pack for the nRF5x series (optional)
The device family pack includes CMSIS System View Description, which is basically is a memory map of all peripheral registers on the device. Although it is not required to have installed it can be quite useful for debugging purposes; it allows you to easily read and write to particular peripherals through a built in peripheral viewer (part of GNU ARM Eclipse Plug-in) without having to look up the the addresses and register descriptions in the datasheet first.
Steps to install:
Configure environment
Here we will set the global Eclipse configurations for development on nRF5x. Note that these configurations are not specific for a particular project, and will only be done the first time Eclipse is installed.
First, click on the window item in the menubar and select preferences. Then go to C/C++->Build->Global Tools path. Check if the paths to your Build tools and Toolchain are set, otherwise add the paths where you installed these earlier. On this setup the following paths were used:
C:\Program Files\GNU ARM Eclipse\Build Tools\2.7-201610281058\bin C:\Program Files (x86)\GNU Tools ARM Embedded\5.2 2015q4\bin
On OS X or Linux the following shell command can be used to find the location of make:
$ which make
Then, enter Run/Debug, click on SEGGER J-link, and make sure that it is pointing to your latest version of the Segger software. In my case it was C:/Program Files (x86)/SEGGER/JLink_V502f. This is path will be needed later when debugging with the installed J-link debug plugin.
I have attached the ble_app_hrs and blinky example that can be used as a starting point, see the last section for a list of attachments. You may want to start with the blinky example first to keep it simple at first.
I guess some of you would prefer to start by integrating your own project right away instead as described in the next section. However, I would highly recommend trying one of these examples first in order to get something working first. Then if you experience problems with your project later on, you would have a working example compare against.
Download the project you wish to use from the attachment list, extract it, copy and replace with the content into the existing ARMGCC folder in the respective SDK project. E.g., \examples\peripheral\blinky"board name"\blank\armgcc for the blinky example. Note that the directory structure must be kept. Otherwise it will break the paths. Also make sure that your SDK copy has the same version number as the project.
Open Eclipse.
Enter file->import->General -> Existing Projects into Workspace.
Browse ARMGCC folder in your SDK
Make sure to select the project.
Click finish button.
The project should now be available in the project explorer including the linked sources.
Now you will see your imported project in the Project explorer window as shown in screenshot below. Notice the errors. We will get to that in the Enable auto discovery of symbols, include paths and compiler settings section
For now we just want to make sure that we can build the example as we did in the command line earlier. Right click on the project folder in project explorer, click properties, and click on the C/C++ item in the list. Then replace the default build command with make VERBOSE=1. Setting the VERBOSE variable to '1' makes the Makefile print command line options used in the build. In other words increase the verbosity level. This will later be used to parse compiler options to your Eclipse project.
Right click on project again and click on Build Project. Hopefully you will see the build output in the console window, same as when you built the example via the terminal. Note that actual build errors will be shown in the log at this point. The errors we see in Eclipse are due to the fact that Eclipse does not now what include paths to use nor symbols. E.g., -DBOARD_PCA10036 which is used to determine what board support file to include, but you can see that it is used in the build log.
This section is for those who wants to integrate an existing project into Eclipse, or just want to create a new one, but not use any of the attached examples as templates. These instructions assumes the Makefile configurations used in SDK 7.x.x. and later.
Start Eclipse, enter file -> new Makefile project with existing code in the menu bar. Name your project and browse the directory of your Makefile. Click finish once you are done.
Open and edit the SDK makefile to support debugging of your code. Locate the CFLAGS variables, and change ‘-O3’ to '-O0' for debugging to produce expected results (stack variables loaded directly to CPU registers,etc). Then add '-g3' to CFLAGS to include debug symbols in the .out file (GNU manual).
Configure the build settings and build the project, see the instructions from the Import existing Eclipse project to workspace section above and verify that there are no build errors before moving on to the next step.
Now you can start linking the source files into your project viewer, but you might want to add some virtual folders to obtain a more clear project view first.
Create virtual folders:
Repeat above steps until you have the folders you want. The naming of the folders should reflect the types of the source files you intend to link to. In the blinky it was sufficient to have Application, Device and nRF_Drivers, same as the Keil example for blinky, but, for larger projects with more source files you should add more folders. E.g., ble_app_hrs: Application, Board Support, Device, nRF_BLE, nRF_Drivers, nRF_Libraries and nRF_Softdevice.
Now you can start to link the source files to the respective folders. The source files to include are listed in your Makefile->C_SOURCE_FILES, and ASM_SOURCE_FILES. Source files are then linked to the folder by right clicking on any of the virtual folders and clicking on import, General->File System and browse the source files in the SDK. The path to each source file can be a good way to determine what folder to place the file in:
../../../../../../components/drivers_nrf/delay/nrf_delay.c can be classified as a driver. Thus placed in nRF_Driver, etc.
Note regarding SDK 12 9/30-16 - Makefile structure was changed in SDK 12.0.0; there are now two separate Makefiles for each example; the project makefile that defines the example dependencies/flags, and makefile.common to actually build the specified targets. It should only be necessary to modify the project makefile as before. However, apparently the CDT parser does not like that we added quoted toolchain strings. E.g., "C:/Program Files (x86)/GNU Tools ARM Embedded/4.9 2015q3/bin/arm-none-eabi-gcc".
Included a patched version of Makefile.common, see list of attachments at the end of this tutorial.
Good news is that the new makefiles support incremental builds rather than re-building every time. That is, make will only rebuild modified objects and link in those that weren't.
The following steps configure the CDT build output parser and CDT GCC Built-in Compiler Settings Cross ARM to automatically discover symbols, include paths and compiler settings based on the output produced by the Makefile. These steps also apply to imported projects as these configurations are not included in the project files.
The CDT build output parser works by parsing everything in the output string that has either a '-D' for defines and '-I' for include paths, and 'C:/Program Files (x86)/GNU Tools ARM Embedded/4.9 2015q3/bin/arm-none-eabi-gcc' will be recognized as the compiler command pattern with the settings above.
Example string when compiling main.c in the blinky example:
'C:/Program Files (x86)/GNU Tools ARM Embedded/4.9 2015q3/bin/arm-none-eabi-gcc' -DCONFIG_GPIO_AS_PINRESET -DBOARD_PCA10036 -DNRF52 -DBSP_DEFINES_ONLY -mcpu=cortex-m4 -mthumb -mabi=aapcs --std=gnu99 -Wall -Werror -O0 -g3 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -I../../../../../../components/toolchain/gcc -I../../../../../../components/toolchain -I../../.. -I../../../../../bsp -I../../../../../../components/device -I../../../../../../components/drivers_nrf/delay -I../../../../../../components/drivers_nrf/hal -c -o _build/main.o ../../../main.c
Rebuild your project to index the source files again with the CDT parser enabled. If it works you will notice a key symbol appears on the source files, and all errors should be resolved by now.
In case you want to see the paths and symbols added from the output, select one of the source files, click on properties, C/C++ item and preprocessor Include Paths you can see that the paths defines have been added based on the output:
Flash downloading and running a program on your device without debugging is possible by using flash targets included in the Makefiles.
In order to execute the flash targets you first need to add a new target to the project. Here is an example with the blinky example. There are no flash softdevice target in this example as it runs independent of the softdevice. For the heart rate or other BLE examples you will need to flash the softdevice by executing the "flash_softdevice" target.
Then execute the flash target(s) to load the FW to target. You will see the commands invoked in the console window. Once you have done this your application will start running.
Note, makefiles from SDK 11.0.0 does not require the target name to be specified. so just 'flash'.
The GNU ARM Eclipse plugin we installed earlier has already integrated J-link debugging with Eclipse. We only need to set the debug configurations for our project before we can launch a debug session.
In the project explorer select your project in the project explorer window. Click on the Run tab in the menu bar and go to debug configurations. Right click on GDB SEGGER J-Link Debugging and select new. Project name and location of executable should be added automatically as long as you selected your project before opening debug configurations.
Enter the Debugger tab, and select the device name for the device you are targeting and make sure that the jlink variables are set correctly (must point to JLinkGDBServerCL executable). The 'nogui' option may be removed from other options field to get a device selection prompt if multiple J-link programmers are connected to the PC. Lastly, set the GDB client to arm-non-eabi-gdb to ensure that the correct client is used (may default to GDB client for host if not).
Then deselect SWO in startup tab unless you have configured it (not supported on the 51 series). Now you start the debug session by clicking on the Debug button. Eclipse will then show the debug view, and the application will break in main by default.
Now you can start debugging; set break points, single step, read registers, etc.
Using the peripheral viewer
Go to project properties and select C/C++ Build item. Enter settings and click on the Devices tab. Here you must select the chip you are using to enable the view. Start a debug session and open the peripheral viewer, and select the Peripheral you want to debug. If you select the GPIO module you can get an visual indications by controlling the board LEDs (P0 on nRF52 and GPIO on nRF51). Open the Memory view and click on PIN_CNF[24] or PIN_CNF[20] to control the LED 4 GPIO on your DK kit (PCA100028 or PCA10036/40). Changing the GPIO direction in PIN_CNF[x].DIR should toggle your board LED.
Below is a brief guide on how to troubleshoot some of the common problems related to GCC and Eclipse setup with the Nordic SDK.
Development with GCC and Eclipse.pdf
Please post a detailed description of the problem in the questions section if the guide does not help in solving a particular issue. Also feel free to provide feedback if you think something is missing/unclear or any other suggestions.
Tested with Eclipse Neon:
Patch for SDK 12 - implements required workaround for CDT build output parser. Replace makefile.common in in $(SDK_ROOT)/components/toolchain/gcc with one of the files below:
Hi Vidar, I was wondering if you had a New Years resolution for 2018? :O)
Given that this Tutorial is now well over 2 years old (3 years in April) I just wondered if there are any plans to update it…
.cproject(/attachment/7875011e0bc377ae64cad5c0b5a005b3)This tutorial was difficult for us so once we got it to work, we decided it would be nice to post our notes in case it helps others. We did not verify…
When I try to Project > Build All I get the following error
make all rm -rf _build process_begin: CreateProcess(NULL, rm -rf _build, ...) failed. make (e=2): The system cannot find the file specified…
I am getting these errors
make[1]: *** [Makefile:177: _build/app_button.o] Error 2make[1]: Leaving directory 'C:/Nrf_Env/nRF5_SDK_11.0.0_89a8197/examples/ble_peripheral/ble_app_beacon/pca10028/s130/armgcc'make: *** [Makefile:140: all] Error 2"make all" terminated with exit code 2. Build might be incomplete.
15:51:29 Build Failed. 2 errors, 0 warnings. (took 449ms)
Very useful tutorial. Appliable to the latest versions of CDT, ARM GCC & nRF5 SDK as TODAY, with slightly tinkering. Thanks!
did anyone had problem similiar to mine? Make works great but problem starts with debugging.
Regards
I using SDK 15.2 with 7.2.1 of GNU Tools ARM, this is my Makefile.windows:
GNU_INSTALL_ROOT := C:/Program Files (x86)/GNU Tools ARM Embedded/7 2017-q4-major/bin/GNU_VERSION := 7.2.1GNU_PREFIX := arm-none-eabi
Hope this help.
If I understand correctly, it is necessary to edit Makefile.common in order for the CDT output processor to work.Can someone post an edited Makefile.common for the "latest" SDK (I have 15.2.0) or - better - a list of instructions for editing the Makefile.Presumably this will break with every new SDK release. Would it be better to ensure that Makefile.common was kept up to date for Eclipse?
