You have your choice of development tools for working with the Nordic nRF51x22 chips. If you want to use Eclipse + GCC for development, there are some app-notes and blog posts to help you on the way.
nAN-29 Development with GCC and Eclipse
This application note contains instructions from Nordic Semiconductor on using Eclipse and GCC for development. There are a few things to note, however.
- The instructions are specific to Windows, though with some imagination, you can adapt them to Linux and OS X.
- The instructions don't make use of GNU ARM Eclipse Plug-ins. Specifically, they don't use the SEGGER J-Link Eclipse plugin and they use a makefile instead of the managed build plugin.
- The application note hasn't been updated for version 7.1.0 of the SDK.
If you're using Eclipse on OS X, this is a list of tools that may be helpful.
Development with Eclipse and GCC
This blog post references the application note above, and is a little more up-to-date. One nice thing about this blog post over the application note is that it uses the SEGGER J-Link plugin.
- It also uses a makefile instead of a managed build.
- It hasn't been updated for version 7.1.0 of the SDK.
- It's specific to Windows--i.e.
make flashis not going to work out of the box on OS X.
Getting started with nRF51 development on Mac OS X
While not specific to Eclipse (in fact, Eclipse isn't used at all in this blog post), it has excellent information on using GCC and makefiles for development on the Mac.
- It's updated for version 7.0.0 of the SDK.
- It contains instructions for flashing firmware from the command line using the SEGGER J-Link tools on OS X.
Software Development with nRF51 Series Bluetooth Low Energy SoC
This blog is up-to-date. It's an excellent source for getting everything working at a low price-point:
- It uses the IMM-NRF51822 ($22.95) module instead of the nRF51-DK (~$70).
- It includes instructions for using OpenOCD with the IDAP-Link ($45) instead of SEGGER J-Link (though an external J-Link can also be used with the IMM-NRF51822).
- It includes instructions for using the third-party EHAL source tree (to facilitate portability between devices). If you don't want to use EHAL, just ignore the steps that mention it.
- This blog also includes a modification you need to make in the SDK in order to use C++.
