About IoT security
Since the Internet of Things is still in the emerging phase, ensuring security and privacy is an important issue that must be addressed and resolved now.
The number of IoT and connected objects grows exponentially, so their security exploits will have more and more repercussions, making them very attractive for the hackers. Recent news and the growing IoT track at security conferences such as Blackhat, or Defcon perfectly illustrates this phenomenon.
About Bluetooth
In regards to Bluetooth, the SIG greatly enhanced the BLE security releasing at
the end of 2014 the Bluetooth Core Specification 4.2. This update introduces
LE Secure Connections pairing model with the numeric comparison method and
the Elliptical Curve Hellman-Diffie (ECDH) algorithm for the key exchange.
LE Secure Connections fixes BLE 4.0–1 exploits unveiled in 2012 by Mike
Ryan at TOORCON
(video, crackle
project).
Like LE Legacy pairing, LE Secure Connection defines several modes and levels of security (see section 5.2.4 Association Models of the Bluetooth Core Specification 4.2). Nonetheless, the available modes depend on the “IO Capabilities” — keyboard, display, button — that the pairing devices have.
The highest level of security, Numeric Comparison requires that both BLE devices have a keyboard and a display to confirm and compare a number displayed on both the peripheral and smartphone. An alternative and more convenient approach is using NFC. By placing a smartphone close to the BLE (and NFC) peripheral, NFC will automatically initiate the BLE pairing and keys exchange mechanisms to establish an authenticated and encrypted communication channel.
However, the highly limited bill of material (BOM) cost or the PCB size prevents placing a screen, an interactive input, or an NFC antenna on such
devices.
As a consequence, they provide a weak level of security whereas the
attacks targeting such smart objects are rising.
To overcome this issue, we propose a technological solution based on Visible Light Communication (VLC) solution to assist the pairing and the secure
connection setup between a BLE 4.2 peripheral and a smartphone.
This
solution targets low-cost and size-constrained IoT devices that need to setup
the Secure Connection with Numeric Comparison to provide a high level of security even on BLE devices that have neither input and display nor NFC.
Few words about Kiwink and VLC
Rtone has recently developed Kiwink,
a short range bi-directional Visible Light Communication system between an
unmodified smartphone and a basic and cheap LED.
Kiwink uses the camera and the flashlight of an Android or iOS smartphone and does
not need hardware modification in the IoT peripheral since it works with any
micro-controller.
In fact, bringing Kiwink and Visible Light Communication to your nRF52 BLE device just need a firmware update!
The communication range of such technology is tens of centimeters while the throughput is about 1kbps from the peripheral LED to the smartphone and 50bps from the smartphone to the peripheral LED.
Kiwink is a trademark and its technology patented.
Improving BLE security with Kiwink and VLC
To solve the problem described above, we propose to take advantage of this VLC-based technology and ubiquitous LEDs, to provide a safe side channel to acknowledge or display a confirmation code and establish a BLE Secure Connection. We can also envisage to transmit a larger key if another Secure Connection mechanism is used.
This out of band key exchange is thus safer than NFC against passive eavesdropper since the light signal is highly directive and easy to obfuscate.
In practice, the connection establishment should work as follow:
- The smartphone starts sending a BLE Secure Connection request to the peripheral
- The smartphone and the peripheral proceeds to the Secure Connection Establishment with Numeric Comparison according to the BLE 4.2 standard
- While the smartphone confirmation number appears on the smartphone screen, the peripheral LED starts lightning and transmits its number.
- By placing its smartphone above its screen, the application decodes the signal and displays the peripheral number on the smartphone screen.
- The user confirms that both codes are equal.
- The smartphone sends the acknowledgment to the peripheral using the flashlight.
- The peripheral decodes the acknowledgment signal and the secure connection establishment can proceed according to the BLE 4.2 standard.
Conclusion
We have shown that Kiwink and VLC offer the possibility to setup a Secure Connection with Numeric Comparison or Out-Off-Band authentication on low-cost and size-constrained IoT devices that have neither input and display nor NFC.
Our solution brings a high level of security on BLE devices that would have been completely unsafe otherwise. The costs of this major improvement are negligible since Kiwink only relies on a cheap LED and a piece of software.
Besides, many application fields and use cases of VLC exists like access control, device-to-device communication, or accurate indoor localization using ceiling LEDs (Kiwink website gives further information about VLC).
Finally, feel free to give your feedback about that. We are are waiting for your comments and suggestions!
