Nordic nRF51822 ARM Cortex-M0 Development using emIDE
To avoid the hefty charges with commercial compilers I tried emIDE with some success; here are the settings I used for the EV Kit
Official emIDE website: http://www.emide.org/
Ev Kit: https://www.nordicsemi.com/eng/Products/Bluetooth-Smart-Bluetooth-low-energy/nRF51822-Evaluation-Kit
Exception Vectors
Any code compiled with a resident Soft Device has a vector table at the link address (eg, Soft Device 110 v7 requires user code to be at 0x16000, so the vector table will be at that address). The reset vector at 0x16004 will be the start address of the user code, but to debug the code must start at the reset vector in code location 0x00004, which is the Soft Device reset address. Ensure this happens by performing a device Reset before running code.
GDB Debugger
Breakpoints can be set and code single-stepped through the application startup assembler code, but currently 4.7.4 and 4.8.3 GDB crashes if setting a breakpoint in main.c. Note memory display works for both s100 Soft Device and application code and memory.
Link Files
Use the default gcc link files (eg gcc_nrf51_s110_xxaa.ld) located here: blahblah\nrf51822\Source\templates\gcc\
emIDE Default Version
gcc version 4.7.4 20130913 (release) [ARM/embedded-4_7-branch revision 202601] (GNU Tools for ARM Embedded Processors)
**Global Compiler Settings gcc - 4.7.4**
Settings->Compiler->Toolchain Executables:
C:\Program Files (x86)\emIDE\emIDE V2.20\arm
Settings->Compiler->Search Directories->Compiler:
C:\Program Files (x86)\emIDE\emIDE V2.20\arm\arm-none-eabi\include
**Global Compiler Settings - gcc 4.8.3**
C:\Program Files (x86)\GNU Tools ARM Embedded\4.8 2013q4
**Project-Specific Settings - Debug**
Project->Build Options->Debug->Policy:
Append target options to project options
Project->Build Options->Debug->Compiler Settings->Compiler Flags:
Produce debugging symbols [-g]
Project->Build Options->Debug->Compiler Settings->Other Options:
-std=c99
-mcpu=cortex-m0
Project->Build Options->Debug->Compiler Settings->#defines:
DEBUG=1
NRF51
DEBUG_NRF_USER
BLE_STACK_SUPPORT_REQD
BOARD_PCA10001
Project->Build Options->Debug->Linker Settings->Linker script:
.\Link\gcc_nrf51_s110_xxaa.ld
Project->Build Options->Debug->Linker Settings->Other linker options:
-mthumb
-Wl,--gc-sections
-n
-Wl,-cref
-mcpu=cortex-m0
-Wl,-Map
-Wl,${TARGET_OUTPUT_FILE}.map
Project->Build Options->Debug->Search Directories->Compiler:
.\Src
.\Src\nrf51822\Board
.\Src\nrf51822\Board\s110
.\Src\nrf51822\Board\s110\ble_app_YourApp
.\Src\nrf51822\Include
.\Src\nrf51822\Include\app_common
.\Src\nrf51822\Include\ble
.\Src\nrf51822\Include\ble\device_manager
.\Src\nrf51822\Include\ble\ble_services
.\Src\nrf51822\Include\gcc
.\Src\nrf51822\Include\s110
.\Src\nrf51822\Include\sd_common
.\Src\nrf51822\Include\sdk
.\Src\nrf51822\Lib
.\Src\nrf51822\Source
.\Src\nrf51822\SVD
Project->Build Options->Debug->Search Directories->Linker:
.\Link
Project->Properties->Debugger->GDB->GDB commands after connection:
Monitor reset
monitor flash device nRF51822_xxAA
load
Project->Properties->Debugger->J-Link GDB Server->Target Device:
nRF51822_xxAA
(Uncheck) Automatically close GDB Server after debugging
Project->Properties->Debugger->J-Link GDB Server->Interface Speed:
2000
Hugh
