nRF Connect for VS Code
Change log
VS Code is a fast, cross-platform, and popular IDE. Nordic Semiconductor’s nRF Connect extension turns VS Code into a complete IDE for developing applications for nRF91, nRF53 and nRF52 Series devices on Windows, MacOS or Linux. This includes an interface to the compiler and linker, an RTOS-aware debugger, a seamless interface to the nRF Connect SDK, and a serial terminal.
Tutorial Videos
Setup basic configuration
Stay tuned as more features and video tutorials are under development and will be available to you soon. If you have any issues related to this bundle, contact us on DevZone.
ENJOY!
  • This is what I'm looking for. Tested on windows 10 and worked nicely.
    In MacOS I can create new project and build correctly but it can't detect nrf52832 development board.
    How to make it work?
  • Hmm. Do you even see the extension recognizing the nRF52832 DK under the CONNECTED DEVICES tab or not at all?
    Plugin the board, then there is a refresh button (a circular one) under the CONNECTED DEVICES tab. Hit that and see if it helps. Sometimes it takes a few seconds to get it up and running. Also, make sure to verify the correct HW settings on your dev kit.
    Note as this is still in development, so some things might be still glitchy.
  • I did it. Can't recognise the board anyway
    J-Link is shown at MacOS USB Device Tree.
    I can connect to board using J-Link tools and with nRF Connect v3.7.1.
    macOS High Sierra v.10.13.6
    Visual Studio Code
    Version: 1.60.0
    Commit: e7d7e9a9348e6a8cc8c03f877d39cb72e5dfb1ff
    Date: 2021-09-01T10:54:53.442Z
    Electron: 13.1.8
    Chrome: 91.0.4472.164
    Node.js: 14.16.0
    V8: 9.1.269.39-electron.0
    OS: Darwin x64 17.7.0
  • Is nrfjprog installed? This is part of nRF Command Line Tools.
Comment Children
