nRF5 SDK v 16.0 : Flashing nRF52833 in Keil uVision
This page describes an easy workaround for the flashing error you get in Keil uVision when you are using nRF5 SDK v16 on nRF52833 chips.
The assumption is that you have installed the latest versions of nRF MDK and nRF-Command-Line-Tools before applying this workaround.
Option 1)
  1. Download NordicSemiconductor.nRF_DeviceFamilyPack.8.27.1.pack and install this pack OR using pack installer like below
    If you are familiar with Keil pack installer, then you can install this version 8.27.1 from the "Keil Pack Installer".
  2. After you install NordicSemiconductor.nRF_DeviceFamilyPack.8.27.1.pack using either of the options mentioned above, then you need to change the project dependency on this pack as shown below
    1. click pack configurator
    2. Select the version 8.27.1 for the nRF_DeviceFamilyPack as shown below and click OK
    3. Now you should not get any error while flashing to nRF52833 in this SDK version.
Option 2) You can also do a small configuration change in the flash tool to use nrfjprog command-line tool to be used instead of the native Keil flashing tool.
  1. .Go to Project-> "Options for Target nRF528xx_xxaa"
  2. Then click the "Utilities" tab and select the "Use External Tool for Flash Programming"
  3. In the Command space, enter the full path of nrfjprog.exe.
  4. In the Arguments space, enter "--program #H --sectorerase -f nrf52 -r" without the quotes as shown below
  5. Click OK and flash the device using the flash button   or Flash->Download. You will now see that nrfjprog is being used to flash to your nRF52833 based device.
Update
Happy coding.
    $comment.Body('Web')
