Hello I succeeded to configure QtCreator toolchain to compile and debug my NRF52 board. So I wanted to share.
I use my own Makefile to compile everything so I will focus here on how to run a debug session (with breakpoints and candies !) inside QtCreator (which is the best C++ IDE of course).
Even if you are not interested, can you try my tutorial and tell me where you have problems ? So I can detail my configuration. It will help other guys.
My computer
OS: Windows 8.1
Arch: x86-64 but I tried to install 32bits tools
Install QtCreator
Easy step, I have version Qt Creator 4.0.0, based on Qt 5.6.0 (MSVC 2013, 32 bit)
Install Python
- Because QtCreator uses Python inside gdb.
- Install version 2.7.11
- Add to environnement these variables:
- PYTHONHOME = C:\Python27
- PYTHONPATH = C:\Python27\Lib
Install GUN ARM toolchain
Here: https://launchpad.net/gcc-arm-embedded/+download
Version 5.3-2016-q1
Install GDB Server
Install SEGGER J-Link GDB Server V5.10u
Install Terminal
To receive/send message via UART. Install RealTerm: Serial Capture Program 2.0.0.70
Install Haroopad
Because it's cool to write documents with!
Configure QtCreator
New GDB Server
Open Help > About Plugins...
In Device Support section, enable BareMetal (v 4.0.0)
Retart QtCreator
Open Tools > Options
In left pane, click BareMetal
Click Add > OpenOCD (even if we don't use OpenOCD)
My config:
Name = JLink GDB Server
Startup mode = No Startup
Host = localhost ; 2331
Init cmds =
set remote hardware-breakpoint-limit 6
set remote hardware-watchpoint-limit 6 #(Not sure about limit)
monitor semihosting enable
load
monitor reset 0
Reset cmds = monitor reset 0
New Device
- In Options left pane, go to Devices
- Click Add, select Bare Metal Device and Start Wizard
- Name = nrf52 device
- GDB Server provider = JLink GDB Server (It's our previous config !)
Config GDB
- In Options left pane, goto Debugger
- Options I enabled (it works with them, maybe some of them are useless):
- General tab: Use tooltips ; Warn when debugging Release
- GDB tab: Adjust bp locations ; Use dynamic object type ; Load .gdbinit ; Load pretty printers
- GDB Extend: Use asynchronous mode to control the inferior (or QtCreator will crash when you pause execution or set breakpoints while it's running.) ; Use common location for debug information.
New Debugger
Options left pane, go to Build & Run
Go to Debugger tab
Add a new one
Name = arm-gdb-py
Path = C:\nrf\toolchain\gnu-arm\5.3-2016q1\bin\arm-none-eabi-gdb-py.exe (QtCreator needs python-enabled GDB)
Click Apply
New Kit
Go to Kits tab
Click Add
Name = NRF52
Device type = Bare Metal Device
Device = nrf52 device
Compiler = whatever, I use Makefile
Debugger = arm-gdb-py
Qt Version = None
Close and validate Options
Configure new project
- Create a new project, and import an existing project. It will allow you to use Makefile.
- In QtCreator left pane, click on Projects
- Add a Kit NRF52
- To Build (in Build tab), I use the command line
make -rRj VERBOSE=0 nrf52
- To Run (in Run tab), add a Run configuration Custom Executable (on GDB server or HW db). Actually, "run" means that QtCreator will load the firmware into the target via GDB.
- In Executable, enter path to the ".out" file. If you have never compiled, it is not existent yet.
Profit !
You should be able to set breakpoints and run in debug mode. QtCreator will connect as a GDB client to the JLink GDB server (that you have to launch manually only once). Then QtCreator will send the ".out" file to JLink which will load it into the board.
Any suggestions or improvements are welcome !
Sources: http://lists.qt-project.org/pipermail/qt-creator/2014-June/003748.html https://devzone.nordicsemi.com/blogs/702/debugging-using-qtcreator-on-mac/ http://morf.lv/modules.php?name=tutorials&lasit=37
