Thread aware debugging with nRF Connect SDK
With our nRF Connect SDK  we introduced the usage of a Real-Time Operating System. This system is called Zephyr and strives to be the best-in-class RTOS for connected resource-constrained devices, built to be secure and safe. It helps you develop your applications by abstracting away hardware- and scheduling complexity, allowing critical processes to finish in a deterministic fashion with limited developer interaction. A lot of developers are used to scheduling these tasks  by themselves and do all the bare-metal programming. What we need in order to get the same degree of insight in this way of programming is to see all threads while debugging. At a certain level of complexity it isn’t feasible anymore to spam our code with printf() and guess what the program is doing. When debugging a RTOS application it is very likely that by the time we halt the system the application will be in the idle task and we won’t be able to see much of what’s going on within the different threads or which would start next.
 We want to know which thread is active and which is waiting when we debug our application.  Multiple threads competing for the same semaphore might lead to some of them not executing at all just because they trigger at similar times. Seeing this, inspecting the call stack and the registers of any thread is key.
  • Nordic development kit
  • The text between the videos or the .txt file at the bottom of this post
  • The nRF Connect SDK with our Toolchain Manager
  • The Ozone Debugger (free for use with our development kits)
  • 5-10 minutes of your time (this does not include the happy dance you’ll do after seeing the actual threads in your debugger)
//Text for the .config file:
CONFIG_THREAD_ANALYZER=y
CONFIG_THREAD_NAME=y
  • SEGGER's Ozone debugger is a fairly common error when connecting and losing data synchronization, this fix is comprehensive and clear for most types of server devices. These pieces of code can create loops to avoid error stacking.
    venge io
    venge io
