I'm using an nRF52832 with the S132v2 and SDK 11 and wanted to test the ble throughput. The nRF52832 should send as many as it can to an "normal" BLE-USB-Stick.
The strange thing is, that my windows application is receiving about 1000-1050 packets/s. 1000packets/s * 20Byte Data = 20kB/s
But in the datashet is the maximum 149,3kb/s -> 18,66kB/s and i think this value means 23 or 27 bytes per packet. (Who not all can be used)
Is 20kB/s possible or am i doing something wrong? Thank you.
Additional Info: The Connection Inteval is 7,5ms. On the nordic-site i'm using the NUS-Example and have modified the main like this:
if(m_conn_handle != BLE_CONN_HANDLE_INVALID) //Connection check
static uint8_t count = 0;
uint8_t p_string[20] = { count, 0xAA, 0x12, 0xAA, 0x32, 0xAA, 0x45, 0x34, 0xAA, 0x43, 0x22, 0x11, 0xff, 0xfb, 0xdA, 0xdb, 0x44, 0x22, 0x88, 0x87};
printf("\r\nble!\r\n");
if(ble_nus_string_send(&m_nus, p_string, 20) == NRF_SUCCESS)
count++;
printf("\r\nble\r\n");
On the Windows-Site i increment an int every time i get a package and every second i display this int * 20.
//Every received Packet
SpeedTest++;
//Every second
Label4->Caption = (float)SpeedTest*20;
SpeedTest = 0;
I don't see a mistake here.
