I`m trying to operate PWM and soft device at the same time. I have to make 4 Mhz using PWM block so I checked the PWM driver. There is no problem when using peripheral/pwmdriver.
However,when I applied pwm driver to ble_app_uart example, pwm driver code caused reboot. I can`t use app_timer because of clock frequency. How to overcome this problem?
Here is my pwm function.
WM
void EnableClock(void)
uint32_t err_code;
nrf_drv_pwm_config_t const config0 =
.output_pins =
SEOS_CLOCK_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 0 -> BSP_LED_0 | NRF_DRV_PWM_PIN_INVERTED,
.irq_priority = APP_IRQ_PRIORITY_LOW,
.base_clock = NRF_PWM_CLK_16MHz,
.count_mode = NRF_PWM_MODE_UP_AND_DOWN,
.top_value = 2,
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_TRIGGERED
err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);
m_used |= USED_PWM(0);
static nrf_pwm_values_individual_t /*const*/ seq_values[1] =
{ 1 },
nrf_pwm_sequence_t const seq =
.values.p_individual = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
