Hi. I have two nrf51 dongles that communicate with each other. When I set the transmission power to -30 dB, the range is almost like 15cm, but whe I set it to -20 dB, it has a range upto, say, 3 cubicals. Is there a way to set the TX power between -20 and -30 dB like say -25dB so that I can get a range according to me. I have read the nRF documentation that you can have the values like -40,-30,-20,0,+4 dB. But, is there a way to set the power in between these values ? Note: I am using Softdevice 130. Thanks :)
