Communication nrf24LE1 and nrf24L01+
I'm trying to accomplish a communication from the nrf24LE1 to the nrf24L01+. The nrf24L01+ is hooked up to an Arduino UNO. The nrf24LE1 is flashed with the "enhanced_shockburst_ptx_nrf24le1.hex" from the nRFgo SDK V2.3.0.10040. On the Spectrum Analyzer I can see a peak on 2.402Ghz from the nrf24LE1.
The issue is that I can't receive the data packets from the nrf24LE1 on the nrf24L01+. I've written a simple sketch but it seems that it doesn't work. Anyone any Idea what I've missed? I always get 0x0E in the STATUS register of the nrf24L01+
#include <SPI.h>
#define CE  7
#define CSN 8
#define R_REGISTER 0b00000000
#define W_REGISTER 0b00100000
#define CONFIG 0x00
#define CONFIG_MASK_RX_DR 0x01<<6
#define CONFIG_MASK_TX_DS 0x01<<5
#define CONFIG_MASK_MAX_RT 0x01<<4
#define CONFIG_EN_CRC 0x01<<3
#define CONFIG_CRCO 0x01<<2
#define CONFIG_PWR_UP 0x01<<1
#define CONFIG_PRIM_RX 0x01<<0
#define STATUS 0x07
#define STATUS_RX_DR 0x01<<6
#define STATUS_TX_DS 0x01<<5
#define STATUS_MAX_RT 0x01<<4
#define STATUS_TX_FULL 0x01<<0
#define RX_PW_P0 0x11
void write_register(byte address, byte data) {
  digitalWrite(CSN, 0);
  SPI.transfer(W_REGISTER | address);
  SPI.transfer(data);
  digitalWrite(CSN, 1);
byte read_register(byte address) {
  byte reply;
  SPI.transfer(R_REGISTER | address);
  reply = SPI.transfer(0);
  return reply;
void setup() {
  pinMode(CE, OUTPUT);
  pinMode(CSN, OUTPUT);
  digitalWrite(CE, 0);
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  Serial.begin(115200);
  // Activate RX mode
  write_register(CONFIG, read_register(CONFIG) | CONFIG_PRIM_RX);
  // Set Payload to 3 Bytes
  write_register(RX_PW_P0, 3);
  // PWR_UP
  write_register(CONFIG, read_register(CONFIG) | CONFIG_PWR_UP);
  // Activate Receiver
  digitalWrite(CE, 1);
void loop() {
  if( read_register(0x07) & 0x40 ) {
    Serial.println("Received Data!!");
    write_register(0x07, read_register(0x07) | 0x40);
  } else {
    Serial.println("No data!");
    Serial.println("Status: ");
    Serial.println( read_register(0x07), HEX);
  delay(1000);
  • @berkutta: Which hardware board are you testing with ? Have you tried with 2 nRF24LE1, just to test if the transmitter works properly ? I don't see any problem with your sketch. Have you tried to use the RF24 library from Arduino ?
  • @hungbui I'm using those SMD modules i.ebayimg.com/.../s-l300.jpg, www.haoyuelectronics.com/.../Mini-NRF24L01-SMD-1.jpg. nrf24l01+ <-> nrf24l01+ together with RF24 Library are working together. nrf24l01+ Arduino Library <-> nrf24le1 with nrfGO hex isn't working. Do you have an example for the RF24 Library which should work with the "enhanced_shockburst_ptx_nrf24le1.hex"?
  • I'm afraid we don't have any example.
    Just want to let you know, you can use KEIL to compile the code for nRF24LE1 up to 4kB code size for free. You can test to compile our example in the SDK, maybe play with the prx project to receive data you send from the nRF24L01P, just for testing.
  • @berkutta, did you ever get this working? I'm trying the same, using the RF24 library on the arduino, but to no avail. Arduino code and nRF24L01+ config data below:
    #include <SPI.h>
    #include "RF24.h"
    #define CE_PIN 7
    #define CSN_PIN 8
    RF24 radio(CE_PIN, CSN_PIN);
    const uint64_t pipe = 0xA7A7A7A7A7A7LL;
    unsigned long payload[] = {0,0,0,0};
    // divert stdout to serial. from reza.net/.../
    int my_putc( char c, FILE *t) {
      Serial.write( c );
    // channel, pipe, address, data rate, crc?
    void setup() {
      Serial.begin(115200); // PC <--> Arduino serial communication
      fdevopen( &my_putc, 0); // route stdout to serial
      radio.begin(); // Start up the radio
      Serial.println("Power up status:");
      radio.printDetails(); // print verbose details of initial state of device.
      radio.setChannel(0x02); // 0x02 is the default channel for the nRF24LE1 (reset value) but 0x4c appears to be the default for the nRF24L01+ (see data dump).
      radio.setDataRate( RF24_1MBPS);
      radio.setCRCLength(RF24_CRC_8);
      bool pv = radio.isPVariant(); // if true, this is an nRF24L01+, not nRF24L01.
      radio.setAutoAck(1); // Ensure autoACK is enabled
      radio.setRetries(15,15); // Max delay between retries & max number of retries
      radio.setPayloadSize (3); // don't know if this is needed for the receiver.
      radio.openReadingPipe(1, address); // should we use pipe 0?
      Serial.println("After setup status:");
      radio.printDetails(); // print verbose details after setup.
      radio.startListening();
    void loop(void){
      if (radio.available()) {
        radio.read( &payload, sizeof(unsigned long) );
        if(payload != 0){
          Serial.print("Got Payload ");
      delay(10);
    The output, before setting values:
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	 = 0xe7e7e7e7e7 0xc2c2c2c2c2
    RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
    TX_ADDR		 = 0xe7e7e7e7e7
    RX_PW_P0-6	 = 0x00 0x00 0x00 0x00 0x00 0x00
    EN_AA		 = 0x3f
    EN_RXADDR	 = 0x03
    RF_CH		 = 0x4c
    RF_SETUP	 = 0x07
    CONFIG		 = 0x0e
    DYNPD/FEATURE	 = 0x00 0x00
    Data Rate	 = 1MBPS
    Model		 = nRF24L01+
    CRC Length	 = 16 bits
    PA Power	 = PA_MAX
    after setting values:
    RX_ADDR_P0-1	 = 0xe7e7e7e7e7 0xa7a7a7a7a7
    RX_PW_P0-6	 = 0x00 0x03 0x00 0x00 0x00 0x00
    EN_AA		 = 0x3f
    EN_RXADDR	 = 0x03
    RF_CH		 = 0x4c
    RF_SETUP	 = 0x07
    CONFIG		 = 0x0a
    Data Rate	 = 1MBPS
    Model		 = nRF24L01+
    CRC Length	 = 8 bits
    PA Power	 = PA_MAX
