app_timer_cnt_get returning zero on nrf52832
I am getting only two values on startup and the remaining values as zero when using app_timer_cnt_get. EDIT: updated entire main.c file
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "nrf_delay.h"
#include "MPU6050.h"
#include <stdlib.h>
#include "nrf_drv_gpiote.h"
#define PIN_IN 11
// MAX30100 functions
void PulseOximeter_begin();
void begin(void);
void setMode(enum Mode mode);
void setLedsPulseWidth(enum LEDPulseWidth ledPulseWidth);
void setSamplingRate(enum SamplingRate samplingRate);
void setLedsCurrent(enum LEDCurrent irLedCurrent, enum LEDCurrent redLedCurrent);
void setHighresModeEnabled(bool enabled);
void readMaxFIFO(void);
void SetMaxInterrupt(uint8_t interrupt_mode);
uint32_t millis(void);
static uint8_t sample_flag=0;
uint8_t readRegister(uint8_t device_Id,uint8_t address,uint8_t length);
void writeRegister(uint8_t device_Id,uint8_t address,uint8_t data);
float obj_temp=0.0;
float amb_temp =0.0;
uint8_t Obj_temp[10];
uint8_t Amb_temp[10];
uint8_t read_data[4];
nrf_drv_twi_t twi_instance = NRF_DRV_TWI_INSTANCE(0);
typedef struct
    uint8_t  x;
    uint8_t  y;
    uint8_t  z;
	  uint8_t w;
  //  uint8_t tilt;
} sample_t;
static sample_t  m_sample;
/*UART buffer size. */
float TemperatureFahrenheit(float celcius);
float receiveTemperature(sample_t *p_new_sample);
uint8_t device_address = 0; // Address used to temporarily store the current address being checked
bool device_found = false;
bool read_flag=false;
static volatile bool m_xfer_done =true;
uint8_t num_of_bytes_to_read=1;
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME                     "Waferchips"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    for (uint32_t i = 0; i < length; i++)
        while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    while(app_uart_put('\n') != NRF_SUCCESS);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
         //   sleep_mode_enter();
/**@brief Function for the application's SoftDevice event handler.
 * @param[in] p_ble_evt SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
        case BLE_GAP_EVT_CONNECTED:
            // Pairing not supported
            // No implementation needed.
/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
 *        event handler.
 * @details This function is called from the SoftDevice event interrupt handler after a
 *          SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
            err_code = ble_advertising_restart_without_whitelist();
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                err_code = ble_nus_string_send(&m_nus, data_array, index);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_ENABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud115200
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scanrsp;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
	uint8_t err_code,i;
    switch(p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            // If EVT_DONE (event done) is received a device is found and responding on that particular address
  //          printf("\r\n!****************************!\r\nDevice found at 7-bit address: %#x!\r\n!****************************!\r\n\r\n", device_address);
						if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX)
							  device_found = true;
                m_xfer_done=false;
                /* Read 4 bytes from the specified address. */
							if(read_flag==1){
                 nrf_drv_twi_rx(&twi_instance, 0x57, (uint8_t*)&m_sample, num_of_bytes_to_read );// sizeof(m_sample));
      //          printf("\r\n%d",m_sample.x);
		//					 printf(" %d ",m_sample.y);
			//				 printf(" %d\r\n ",m_sample.z);
						else{
			//				printf("m_xfer_true\r\n");
						//	obj_temp=receiveTemperature(&m_sample);
					//		sprintf(Obj_temp,"%.2f",obj_temp);
						//	device_found = true;
							m_xfer_done =true;
        case NRF_DRV_TWI_EVT_ADDRESS_NACK:
            printf("No address ACK on address: %#x!\r\n", device_address);
        case NRF_DRV_TWI_EVT_DATA_NACK:
            printf("No data ACK on address: %#x!\r\n", device_address);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
 * @brief UART initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = DEVICE_SCL_PIN,
       .sda                = DEVICE_SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH
    err_code = nrf_drv_twi_init(&twi_instance, &twi_config, twi_handler, NULL);
    nrf_drv_twi_enable(&twi_instance);
void start_clock(void)
    NRF_CLOCK->LFCLKSRC             = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->EVENTS_LFCLKSTARTED  = 0;
    NRF_CLOCK->TASKS_LFCLKSTART     = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
void timer_handler(void * p_context)
	uint8_t err_code,i;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
  //  nrf_drv_gpiote_out_toggle(25);
	  sample_flag = 1;
static void gpio_init(void)
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_IN, true);
/**@brief Application main function.
float MPU6050_Acc[3] = {0};
char PrintBuffer[100] = {0};
    uint32_t err_code;
    bool erase_bonds;
		uint16_t length = 0;
    // Initialize.
		nrf_gpio_cfg_output(25);
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    gpio_init();
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    printf("\r\nUART Start!\r\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
     twi_init();
// writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_MODE_CONFIGURATION,DEFAULT_MODE);  // configuring MAX30100_REG_MODE_CONFIGURATION TO DEFAULT MODE(0X02);
    uint8_t dummy_data[] = {1};
		uint32_t dummy_char =0x0000;
    uint32_t ticks1,ticks2,ti;
    uint8_t max_read_reg = 0;
    max_read_reg =MAX30100_REG_MODE_CONFIGURATION;
	float seconds_elapsed;
    // Enter main loop.
		max_read_reg=0;//MAX30100_REG_INTERRUPT_ENABLE;
    for (;;)
      //      app_timer_cnt_get(&ticks1);
            ticks1 =  millis();
            nrf_delay_ms(100);
       //        app_timer_cnt_get(&ticks2);
      			ticks2 = millis();
            app_timer_cnt_diff_compute(ticks2,ticks1,&ti);
		//	dummy_char=readRegister(MAX30100_DEVICE_ID,max_read_reg,1);
                sprintf(Amb_temp,"T=%d",ticks1);
                err_code = ble_nus_string_send(&m_nus, Amb_temp, 9);
                 nrf_delay_ms(900);
if(sample_flag==1){
	sample_flag=0;
   	readMaxFIFO();
    dummy_char = (m_sample.x << 8) | m_sample.y;
		sprintf(Obj_temp,"I=%d",dummy_char);
		err_code = ble_nus_string_send(&m_nus, Obj_temp, 8);
		nrf_delay_ms(150);
		dummy_char = (m_sample.z<<8)|m_sample.w;
		sprintf(Obj_temp,"R=%d",dummy_char);
		nrf_delay_ms(150);
//		APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
		max_read_reg =MAX30100_REG_SPO2_CONFIGURATION;
		sprintf(Obj_temp,"S=%d",dummy_char);
		err_code = ble_nus_string_send(&m_nus, Obj_temp, 5);
		nrf_delay_ms(1000);
 //       power_manage();
	 * Function Name: Temperature_calculation
	 * Description: receive and print out temperature in Celcius and fahrenheit
	 * Parameters: Temperature_type- choose ambient or object Temperature
	 * Return:  true for ok, false for failure
	float receiveTemperature(sample_t *p_new_sample) {
		uint8_t temp;
//		int dev = (DEVICE_ADDR << 1);                               // 5B is the device address
		uint8_t dataLow = 0;                              // initially setting data low as zero
	    uint8_t dataHigh = 0;                             // initially setting data high as zero
//		char pec = 0;
		float celcius = 0.0;
		// This combines high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
		double resolutionFactor = 0.02;                // resolution factor of the MLX90614
		double temperature = 0x0000;
		int frac;                                      // data past the decimal point
		dataHigh=p_new_sample->y;
		dataLow=p_new_sample->x;
		temperature = (double)(((dataHigh & 0x007F) << 8) | dataLow); // removes error bit of high byte by shifting and adds the low byte
		temperature= (temperature * resolutionFactor) ;//- 0.01;         // multiplying temperature value with resolutionFactor
    celcius = (float)(temperature)- 273.15;
	//printf("Temp= %f \r\n",TemperatureFahrenheit(celcius));
		return celcius;                                               // return the value of temperature in celcius
	* convert temperature in celsius to fahrenheit
	float TemperatureFahrenheit(float celcius){                       // convert celcius into fahrenheit
		return (celcius*1.8) + 32;                                    // returns fahrenheit = (celcius*1.8) + 32;
	void writeRegister(uint8_t device_id,uint8_t address,uint8_t data){
		uint8_t w2_dat[6], i;
	//configuring default mode
	w2_dat[0]= address; //0x06
	w2_dat[1] =data;   //0x02
	device_found=false;
	nrf_drv_twi_tx(&twi_instance, device_id, w2_dat, 2, false);
	while(device_found == false);
uint8_t readRegister(uint8_t device_Id,uint8_t address,uint8_t length){
	uint8_t err_code,High,Low,ret_data;
	num_of_bytes_to_read = length;
	m_xfer_done=false;
	double temp_data=0;
	read_flag=1;
		 err_code=nrf_drv_twi_tx(&twi_instance, device_Id, &address, sizeof(address), true);   // sending register
	//	printf("Error code=%d \r\n",err_code);
		do{
			__WFE();
		}while(m_xfer_done==false);
		read_flag=0;
	//	read_data[0] = m_sample.x;
	//	read_data[1] = m_sample.y;
	//	read_data[2] = m_sample.z;
	//	read_data[3] = m_sample.w;
		ret_data = m_sample.x;
		return ret_data;
void readMaxFIFO(void){
	uint8_t err_code,regAdd,Low;
	uint32_t ret_data;
	m_xfer_done=false;
	num_of_bytes_to_read=4;
		regAdd =0x05;
	double temp_data=0;
	read_flag=1;
		 err_code=nrf_drv_twi_tx(&twi_instance, MAX30100_DEVICE_ID, &regAdd, sizeof(regAdd), true);   // sending register
		do{
			__WFE();
		read_flag=0;
  //debuggingMode = debuggingMode_;						// ?
    begin();
    setMode(MAX30100_MODE_SPO2_HR);      //MAX30100_MODE_SPO2_HR  //MAX30100_MODE_HRONLY
    setLedsCurrent(IR_LED_CURRENT, RED_LED_CURRENT_START);    // (50mA,27.1mA)
//    irDCRemover = DCRemover(DC_REMOVER_ALPHA);				  // filter
//    redDCRemover = DCRemover(DC_REMOVER_ALPHA);				  // filter
//    state = PULSEOXIMETER_STATE_IDLE;                         // ???
	SetMaxInterrupt(MAX30100_IE_ENB_SPO2_RDY);
	SetMaxInterrupt(MAX30100_IE_ENB_HR_RDY);
	SetMaxInterrupt(MAX30100_IE_ENB_TEMP_RDY);
	SetMaxInterrupt(MAX30100_IE_ENB_A_FULL);
void begin(void)
    setMode(DEFAULT_MODE);                                     			//Default mode is MAX30100 as HR mode ONLY
    setLedsPulseWidth(DEFAULT_PULSE_WIDTH);					   			// 1600
    setSamplingRate(DEFAULT_SAMPLING_RATE);					   			// 100HZ
    setLedsCurrent(DEFAULT_IR_LED_CURRENT, DEFAULT_RED_LED_CURRENT);    // 50mA
    setHighresModeEnabled(true);
    writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_MODE_CONFIGURATION, mode);
    uint8_t previous = readRegister(MAX30100_DEVICE_ID,MAX30100_REG_SPO2_CONFIGURATION,1);
    writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_SPO2_CONFIGURATION, (previous & 0xFC) | ledPulseWidth);
    writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_SPO2_CONFIGURATION, (previous & 0xE3) | (samplingRate << 2));
    writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_LED_CONFIGURATION, redLedCurrent << 4 | irLedCurrent);
    if (enabled) {
        writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_SPO2_CONFIGURATION, previous | MAX30100_SPC_SPO2_HI_RES_EN);
    } else {
        writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_SPO2_CONFIGURATION, previous & ~MAX30100_SPC_SPO2_HI_RES_EN);
void SetMaxInterrupt(uint8_t interrupt_mode){
	uint8_t previous = readRegister(MAX30100_DEVICE_ID,MAX30100_REG_INTERRUPT_ENABLE,1);
  writeRegister(MAX30100_DEVICE_ID,MAX30100_REG_INTERRUPT_ENABLE, (previous & 0xFF) | interrupt_mode);
uint32_t millis(void){
	uint32_t count;
	count = NRF_RTC0->COUNTER;
	return (count/32);
please help.
