Hi, is someone of you aware of a portable (Win, Linux, OS/X) GATT client library, prefereable with C++ binding? The only one, that I've found so far is Qt. What do you use to write GATT Clients?
kind regards,
Torsten
kind regards,
Torsten
@Torsten: By "portable" do you mean cross platform ?
We provide the pc-ble-driver here. It's C++. The python binding and nodeJS binding can also be found at the same location.
Hi, yes, sorry I menat "cross platform". I'm looking for a library, that allows me to perform the ususal GATT Client procedures from a Windows PC, from a Mac and from a Linux PC. I though that this is a common requirement, but so far I found only Qt.
Python as interpreted language should work on different platforms. NodeJs should work also. We based on NodeJS to make our nRFConnect application which run on all 3 above platforms.
Yes, but the final application will be a C++ application and thus I'm looking for a C++ solution (or C)(I don't want to deploy a simple application with node). For small test clients I use noble / NodeJS too.
For C++ , I guess you can use the pc-ble-driver I linked above.
