I'm using SAADC on a NRF52832 DK to read a analog channel between 0-3.3V. I wanted to supply current with the board VDD but it's value is 2.8V and they're not event stable, so I used a LM1117 3.3V regulator between the board 5V and m module for it.
Regarding my measures, I'm configuring SAADC to use 10 bit with a 1KHz sampling frequency (10uS acquisition time, no oversampling). I wasn't getting a good value out of my module output (it's an ECG module) so I tried connecting GND, the digital output of the module I'm using and internal VCC (NRF_SAADC_INPUT_VDD
) with 1/6 GAIN and using internal reference.
Also I run nrf_drv_saadc_calibrate_offset()
at initialization time.
GND shows a weird wave between 0 and -5, not sure if that's normal I'm used to see it at stable 0 in every ADC I've used until now.
Internal VCC shows me similar noise problems, reading a value between 795 and 815.
Reading the module digital output and confirming with an oscilloscope that the signal is stable at both 0 and 3.3V.
Any ideas on what am I doing wrong? I'm using SDK 12.1.
UPDATE
Due to possible noise from USB I've powered it with a USB power bank and using a bluetooth to serial port bridge to transmit the ADC values. It gives me the same results
