SDK 12 PWM Driver + Softdevice 132 + NRF52832
Hi Devzone.
I've taken the ble_app_hrs example, and then added the example code from the PWM Driver example.
The PWM module is mostly functional, however I have a fatal error that is prohibiting operation for more than a minute. This only occurs when I use a PWM handler, which leads me to believe I have a sync issue.
The overall architecture is -
  • begin using PWM0 with sequence A
  • when sequence A finishes, the PWM handler sets a flag for the task function to switch to sequence B
  • when sequence B finishes, the PWM handler sets a flag for the task function to switch to sequence A
  • I am using this approach because I am switching physical pins. Sequence A is on pin A, sequence B is on pin B.
I'm using simple playback with NRF_DRV_PWM_FLAG_STOP. I have added FreeRTOS Semaphores and task functions for synchronization. This is using nRF SDK12 with a nrf52832.
I am seeing a few failure modes, using both ARMGCC and Keil compilers.
  • The NRF_DRV_PWM_EVT_FINISHED event occurs but the NRF_DRV_PWM_EVT_STOPPED does not. This halts my PWM sequences.
  • The handler does not execute, leaving my task function without any flags to act upon.
  • The task function itself stops running
Here is my handler function (it has support for all 3 PWM modules, each with their own semaphore)
if( xSemaphoreTakeFromISR( *pwm_sem_ptr, NULL ) == pdTRUE )
    switch(event_type)
        case NRF_DRV_PWM_EVT_FINISHED: // using stopped vs finished
            printf("\t\tFINISHED %d\r\n", *pwm_state_ptr);
        case NRF_DRV_PWM_EVT_END_SEQ0: // not using complex playback
            printf("\t\tEND_SEQ0\r\n");
        case NRF_DRV_PWM_EVT_END_SEQ1: // not using complex playback
            printf("\t\tEND_SEQ1\r\n");
        case NRF_DRV_PWM_EVT_STOPPED:
            nrf_drv_pwm_uninit(pwm_instance_ptr);
            m_change |= CHANGE_PWM(pwm_instance_num);
            printf("\t\tSTOPPED %d\r\n", *pwm_state_ptr);
    xSemaphoreGiveFromISR( *pwm_sem_ptr, NULL );
Here is my task function for PWM0 (the rest are disabled while I figure this out)
vTaskDelay(50 / portTICK_PERIOD_MS);
if( xSemaphoreTake( xSemaphore0, 10 ) == pdTRUE )
    if (m_change & 0x01)
        m_change &= ~0x01;
        switch(m_state_pwm0)
            case PWM_IDLE:
            case PWM_SEQA:
                pwm_seqb(PWM0);
            case PWM_SEQB:
                pwm_seqa(PWM0);
    xSemaphoreGive( xSemaphore0 );
This is how the pwm sequences are initiated:
config.output_pins[0] = BSP_LED_2 | NRF_DRV_PWM_PIN_INVERTED;
err_code = nrf_drv_pwm_init(&m_pwm0, &config, handler0);
m_used |= USED_PWM(PWM0);
m_state_pwm0 = PWM_SEQA;
nrf_drv_pwm_simple_playback(&m_pwm0, &pwm_seq_a, 1,
                             NRF_DRV_PWM_FLAG_STOP );
I see some older versions of the SDK have a USE_WITH_SOFTDEVICE boolean, however I do not see that anywhere in SDK 12. Is there something obvious I missed in the docs/examples?
  • As a sanity check, I've disabled the PWM entirely, just to monitor the task function. Even the task function by itself does not survive much longer than a minute.
    It looks like I should probably hold off on the PWM until this works properly.
    The task function is currently logging and toggling a byte:
    void pwm_task_fxn( void *pvParameters )
        for (;;)
                vTaskDelay(100 / portTICK_PERIOD_MS);
                m_change ^= 0x01;
                printf("m_change: 0x%02x\r\n", m_change);
    I initialize the task like this
    BaseType_t xReturned = xTaskCreate(    /* Create the task, storing the handle. */
                    pwm_task_fxn,    /* Function that implements the task. */
                    "PWM",           /* Text name for the task. */
                    2*60,              /* Stack size in words, not bytes. */
                    ( void * ) 1,    /* Parameter passed into the task. */
                    tskIDLE_PRIORITY,/* Priority at which the task is created. */
                    &xHandle );      /* Used to pass out the created task's handle. */
    if( xReturned != pdPASS )
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
