I am getting no radio (as in not being able to pick up advertisements packets) from my custom nrf52832 board. The antenna design is a hack so I am not looking fo stellar performance, rather signs of life. It is a chip antenna (2450AT18A100) directly connected to the ANT output via a want to be 50 Ohm trace.
What I have done so far:
- Confirmed the design on the nrf52-DK board, works.
- Measured the crystal to 32 MHz and confirmed life from the software.
- Soldered a 60 mm copper wire to the chip antenna pad (with the antenna removed), still nothing (I have gotten away doing this before).
- Measured the air spectrum between 2402 and 2480 MHz to see if turning the circuit on and off makes a difference. Lets pretend that makes sense. Saw no difference in the very crowded range. I lack equipment to perform any proper measurements.
It is supererogatory to say that I do not know what I am doing. What I am looking for are hints on what to check, what I might have missed and if there is something that can be done in software to either help or troubleshoot. I will add a matching network on the next design. Before I bin the board I would like to know that I tried what I could.
Any ideas?
