We have a custom board using the ISP130301 BLE module (containing a nRF51822, 16MHz xtal, 32kHz xtal). Our apps work fine (gcc, SDK6, S110v7) except for high system on idle power. We are measuring about 1.4mA in sleep using a variation of the system_on_wakeup_on_gpio (Keil5, SDK10, no softdevice) with peripherals disabled. We suspect that the board is still in debug mode but cannot get into a lower power mode.
We've read many threads regarding this but haven't been able to resolve it.
We use a Segger jlink connected to TC2030 pads on the board. We disconnect power, disconnect the TC2030 probe, and reapply power (which should put the board in normal mode), press the button (which turns off LED and CPU) and measure 1.4mA. We tied SWDCLK to GND and reapply power but no change in current measurements. We tried "nrfjprog --pinreset" with no change.
All other peripherals (memory, charger, regulator, switches, LEDs) are off or disabled. All other GPIO are floating. We've measured the enabled (mA) and disabled current (uA) of each individual peripheral on breadboards. Any ideas on how to get to low power in system on idle?
We use a Fluke 189 to measure mA and uA currents across the power leads which works fine on the pca10028. This can sample 250us events to capture both max current during connection events and min current during idle.
#include <stdbool.h>
#include <stdint.h>
#include "nrf_gpio.h"
#define CS 1
// pin 23 LED exists on pca10028 & LSLF1
nrf_gpio_cfg_output(23);
nrf_gpio_pin_clear(23); // LED on
#if CS
// U8 memory /CS
nrf_gpio_cfg_output(12);
nrf_gpio_pin_set(12); // memory disabled, expect 8uA
// Configure button
nrf_gpio_cfg_input(17, NRF_GPIO_PIN_PULLUP);
while (true)
if (nrf_gpio_pin_read(17) == 0) { // pressed?
nrf_gpio_pin_set(23); // LED off
// system on idle
__WFE(); __SEV(); __WFE();
