Using Segger Embedded Studio 310i in Linux and SDK12.2.0, I imported the Beacon example project (ble_peripheral/ble_app_beacon) from Keil. Right now I'm trying to make it advertise rather than act as a beacon. I removed what I thought to be unnecessary for this. Here is main.c
now: bpaste.net/.../e839e61fa3ea
All the declarations of a variable a
are just so that I can set a breakpoint. My problem is that there is no advertising and the LED doesn't blink. When debugging, it clearly crashes in advertising_start
. In the breakpoint at line 101, I see that I have err_code = 0x12 = 18
#define NRF_ERROR_CONN_COUNT (NRF_ERROR_BASE_NUM + 18)
Maximum connection count exceeded.
I don't understand why I get this error, even before it starts advertising.
I also tried to set PERIPHERAL_LINK_COUNT
and CENTRAL_LINK_COUNT
both to 1. Is a link a connection? - Then the error does make sense.
However, it then crashes at the call to softdevice_enable_get_default_config
, it seems. In the comments (line 33
and 34
), it says that "When changing this number remember to adjust the RAM settings". But I'm not sure what is meant by that.
