I have followed instructions at the link below to setup a Raspberry Pi 3 as a 6lowPAN router, and am trying to run the dns
example from nRF5 IoT SDK 0.9.x on an nRF52-DK:
infocenter.nordicsemi.com/index.jsp
I think my Pi is setup correctly. I am able to detect and connect to the nRF52-DK, and ping it as well.
root@raspberrypi:/home/pi# hcitool lescan
LE Scan ...
00:4E:CC:9A:19:F2 DNS_Client
00:4E:CC:9A:19:F2 (unknown)
^C
root@raspberrypi:/home/pi# echo "connect 00:4E:CC:9A:19:F2 1" > /sys/kernel/debug/bluetooth/6lowpan_control
root@raspberrypi:/home/pi# hcitool con
Connections:
< Unknown 00:4E:CC:9A:19:F2 handle 64 state 1 lm MASTER
root@raspberrypi:/home/pi# echo 2 > /proc/sys/net/ipv6/conf/bt0/accept_ra
root@raspberrypi:/home/pi# sudo ifconfig bt0 add 2001:db8::1/64
root@raspberrypi:/home/pi# ifconfig bt0
bt0 Link encap:UNSPEC HWaddr B8-27-EB-FF-FE-57-53-C5-00-00-00-00-00-00-00-00
inet6 addr: 2001:db8::ba27:ebff:fe57:53c5/64 Scope:Global
inet6 addr: 2001:db8::1/64 Scope:Global
inet6 addr: fe80::ba27:ebff:fe57:53c5/64 Scope:Link
UP POINTOPOINT RUNNING MULTICAST MTU:1280 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:28 (28.0 B) TX bytes:813 (813.0 B)
root@raspberrypi:/home/pi# ping6 -I bt0 fe80::ba27:ebff:fe57:53c5
PING fe80::ba27:ebff:fe57:53c5(fe80::ba27:ebff:fe57:53c5) from fe80::ba27:ebff:fe57:53c5 bt0: 56 data bytes
64 bytes from fe80::ba27:ebff:fe57:53c5: icmp_seq=1 ttl=64 time=0.207 ms
64 bytes from fe80::ba27:ebff:fe57:53c5: icmp_seq=2 ttl=64 time=0.172 ms
64 bytes from fe80::ba27:ebff:fe57:53c5: icmp_seq=3 ttl=64 time=0.169 ms
^C
--- fe80::ba27:ebff:fe57:53c5 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.169/0.182/0.207/0.023 ms
Pinging the device (nRF52-DK) also works. (MAC addr is 00:4E:CC:9A:19:F2):
root@raspberrypi:/home/pi# ping6 2001:db8::24e:ccff:fe9a:19f2
PING 2001:db8::24e:ccff:fe9a:19f2(2001:db8::24e:ccff:fe9a:19f2) 56 data bytes
64 bytes from 2001:db8::24e:ccff:fe9a:19f2: icmp_seq=1 ttl=64 time=254 ms
64 bytes from 2001:db8::24e:ccff:fe9a:19f2: icmp_seq=2 ttl=64 time=266 ms
64 bytes from 2001:db8::24e:ccff:fe9a:19f2: icmp_seq=3 ttl=64 time=210 ms
64 bytes from 2001:db8::24e:ccff:fe9a:19f2: icmp_seq=4 ttl=64 time=358 ms
^C
--- 2001:db8::24e:ccff:fe9a:19f2 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3000ms
But the dns code on the nRF52-DK seems to be failing. LED2 remains lit after BLE connection, and pressing buttons 1/2 does nothing.
I think I am still missing something - maybe the 6LowPAN network is still not able to connect to the internet.
I'd appreciate any help in making this work. Thanks!
Update #3
I added a route and now I am able to ping DK externally.
sudo route -A inet6 add 2001:470:6d:3fd::/64 dev bt0
And low and behold, the DNS example works! :-)
Update #2
inet6 addr: 2001:470:6d:3fd:ba27:ebff:fe57:53c5/64 Scope:Global
inet6 addr: 2001:470:6d:3fd::2/64 Scope:Global
RX packets:17 errors:0 dropped:0 overruns:0 frame:0
TX packets:46 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1100 (1.0 KiB) TX bytes:3145 (3.0 KiB)
eth0 Link encap:Ethernet HWaddr b8:27:eb:fd:f9:6f
inet addr:192.168.3.94 Bcast:192.168.3.255 Mask:255.255.252.0
inet6 addr: 2001:470:6d:3fd::1/64 Scope:Global
inet6 addr: fe80::fa5c:d96c:8152:622b/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:83859 errors:0 dropped:28 overruns:0 frame:0
TX packets:81398 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:82505717 (78.6 MiB) TX bytes:83383851 (79.5 MiB)
he-ipv6 Link encap:IPv6-in-IPv4
inet6 addr: fe80::c0a8:35e/64 Scope:Link
inet6 addr: 2001:470:6c:3fd::2/64 Scope:Global
UP POINTOPOINT RUNNING NOARP MTU:1480 Metric:1
RX packets:59927 errors:0 dropped:0 overruns:0 frame:0
TX packets:19478 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:78821152 (75.1 MiB) TX bytes:2073148 (1.9 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:230 errors:0 dropped:0 overruns:0 frame:0
TX packets:230 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:19776 (19.3 KiB) TX bytes:19776 (19.3 KiB)
root@raspberrypi:/home/pi# ping6 -I bt0 ff02::1
PING ff02::1(ff02::1) from fe80::ba27:ebff:fe57:53c5 bt0: 56 data bytes
64 bytes from fe80::ba27:ebff:fe57:53c5: icmp_seq=1 ttl=64 time=0.149 ms
64 bytes from fe80::218:bbff:fe3c:1e76: icmp_seq=1 ttl=64 time=274 ms (DUP!)
^C
--- ff02::1 ping statistics ---
2 packets transmitted, 2 received, +2 duplicates, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 0.111/106.643/274.694/115.059 ms
root@raspberrypi:/home/pi# ping6 -I bt0 -c 4 2001:470:6d:3fd:218:bbff:fe3c:1e76
PING 2001:470:6d:3fd:218:bbff:fe3c:1e76(2001:470:6d:3fd:218:bbff:fe3c:1e76) from 2001:470:6d:3fd:ba27:ebff:fe57:53c5 bt0: 56 data bytes
64 bytes from 2001:470:6d:3fd:218:bbff:fe3c:1e76: icmp_seq=1 ttl=64 time=230 ms
64 bytes from 2001:470:6d:3fd:218:bbff:fe3c:1e76: icmp_seq=2 ttl=64 time=242 ms
64 bytes from 2001:470:6d:3fd:218:bbff:fe3c:1e76: icmp_seq=3 ttl=64 time=321 ms
64 bytes from 2001:470:6d:3fd:218:bbff:fe3c:1e76: icmp_seq=4 ttl=64 time=265 ms
--- 2001:470:6d:3fd:218:bbff:fe3c:1e76 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 230.845/264.887/321.060/34.698 ms
External ping of 2001:470:6d:3fd:ba27:ebff:fe57:53c5
(bt0) works.
External ping of 2001:470:6d:3fd:218:bbff:fe3c:1e76
(DK) does not work.
Update #1
I now have a Hurricane Electric tunnel setup and can ping6 ipv6.google.com. But unfortunately the example still does not work.
