ADC / PPI: SDK v11.0.0 works but v12.2.0 does not
I was building my own custom application that connects a nrf_drv_timer to an ADC start trigger using PPI on an nRF51822 and I could not get it to work. I asked a previous question about it here. This is a new question and a continuation of that exploration.
A strategy for figuring out how ADC / PPI should work
This is a continuation from that question. I decided that the best way to debug this issue would be to start with some working ADC scanning code that somebody has written previously for the nRF51822 and then modify it to work in the scenario that I need it to work in.
Proving that SDK 11.0.0 works (starting point)
The starting place that I picked was this repository: NordicSemiconductor/nrf51-ADC-examples
By updating the Makefile to point to the correct location for the SDK on my OSX machine I was able to get this compiling on my computer and working on my nRF51822. Importantly, it uses SDK 11.0.0. The differences that I made to the default repository are here and they are minimal. Using UART logging into minicom on my OSX machine I see this in the logs:
UART Start - with ADC !
  adc event counter: 1
ADC value channel 0: 173
ADC value channel 1: 187
ADC value channel 2: 174
ADC value channel 1: 182
  adc event counter: 2
ADC value channel 1: 181
  adc event counter: 3
ADC value channel 1: 180
<...snip...repeats endlessly...>
This is great. I am able to get a working version of ADC being read on my nRF51822 and being sent over the Bluetooth UART service to my android phone running the NRF toolkit. Awesome! It can work! I was pretty happy when this worked.
Getting the same code working on SDK 12.2.0
Now that I had a working example to start from I decided to try and migrate this code to v12.2.0 of the SDK. This version of the SDK has better internal logging for the modules and it has better utility functions avaliable. I would much prefer to be developing on v12.2.0 instead of v11.0.0.
To do that required a little bit of work but I managed to make the changes and get the code to compile.
You can view my modifications here.
However, the logs for this change look like this:
main.c:INFO:Connected...
main.c:INFO:Logging started.
PPI:INFO:Function: nrf_drv_ppi_init, error code: NRF_SUCCESS.
TIMER:INFO:Function: nrf_drv_timer_init, error code: NRF_SUCCESS.
TIMER:INFO:Timer id: 0, capture value set: 1536, channel: 0.
TIMER:INFO:Enabled instance: 0.
PPI:INFO:Allocated channel: 0.
PPI:INFO:Function: nrf_drv_ppi_channel_alloc, error code: NRF_SUCCESS.
PPI:INFO:Assigned channel: 0, event end point: 4000a140, task end point: 40007000.
PPI:INFO:Function: nrf_drv_ppi_channel_assign, error code: NRF_SUCCESS.
ADC:INFO:Function: nrf_drv_adc_init, error code: NRF_SUCCESS.
ADC:INFO:Enabled.
ADC:INFO:Enabled.
ADC:INFO:Enabled.
ADC:INFO:Number of samples requested to convert: 6.
ADC:INFO:Function: nrf_drv_adc_buffer_convert, error code: NRF_SUCCESS.
PPI:INFO:Function: nrf_drv_ppi_channel_enable, error code: NRF_SUCCESS.
<...nothing else is logged here except for connect / disconnect messages...no ADC logs messages...>
As you can see logging is started, the timer is instantiated, PPI is initialised: but no ADC readings are ever taken and logged. It is as though I have missed a step in the configuration of the PPI and caused those events to never be triggered.
This is where I need your help. I'm stuck at this point and can't get the ADC working or triggering. What am missing that is preventing this from working?
Concluding words and a question for you
At this point in time I have been pouring over the documentation and source code examples and am struggling to work out what I am doing wrong. My current thoughts are:
  • Maybe if I hook up GDB to this chip and keep scanning I'll be able to work out why the PPI is not triggering
  • Maybe v12.2.0 simply does not work with Timer 0 => PPI => ADC readings (unlikely, I'm sure that Nordic tests this stuff before releasing)
  • Maybe I should just add logging all over the SDK until I can figure out what is wrong.
  • Maybe I have configured something wrong in the "sdk_config.h" file
If anybody could help me work out what I am doing wrong that is preventing my 12.2.0 code from working then that would be much much appreciated.
