I am trying to develop a BT Microphone that can pair directly with a BT speaker.
The Mic will act as a server for the speaker (client).
I have some nRF52 EVB.
Do you have a reference design to achieve this functionality?
Thanks, Paul
Thanks, Paul
Bluetooth speakers normally use Bluetooth classic, while the nRF52 only use Bluetooth Low Energy, so you cannot connect the nRF52 directly to the speaker. You need to have something in between.
@Ole
I think you should convert your comment to an answer, as basically the nRF52 does not do Classic Bluetooth which is what the OP needs
@Ole & @Roger. Thanks. If I can use nRF52. Can you suggest any Nordic solution for this application?
Check the products page
www.nordicsemi.com/.../Products
However I don't think any of them would be suitable for your application
