pc-ble-driver: "Failed to open nRF BLE Driver. Error code: 0x0D"
Hi.
I'm getting an nRF Dongle (PCA10031) set up on a Windows machine to be the BLE central that we'll use for our production line testing. To that end, I've built the pc-ble-driver code following the instructions at github.com/.../pc-ble-driver. The connectivity hex file I've flashed is connectivity_1.1.0_1m_with_s130_2.0.1.hex. I've also tried with connectivity_1.1.0_115k2_with_s130_2.0.1.
However, if I build the heart rate monitor example and try to run it, this is the result:
c:\biketracker\pc-ble-driver\examples\heart_rate_monitor\build\Debug>hrm_v2.exe
COM4
Serial port used: COM4
Info: Successfully opened COM4. Baud rate: 115200. Flow control: none. Parity: n
one.
Status: 6, message: Target Reset performed
0x0D is a timeout:
#define NRF_ERROR_TIMEOUT                     (NRF_ERROR_BASE_NUM + 13) ///< Operation timed out
Any ideas?
