I am trying to use PCA10000 dongle with the pb-ble-driver-py libraries with absolutely no success, as I get a "Failed to open. Error code: 13" error.
I am running Windows 10. I installed the library using pip.
- I installed the latest JLink software package (V614a) just to be sure.
- I tried having the library flash the dongle (that part worked) with no success, even after unplugging and replugging the dongle
- I tried flashing the connectivity_1.0.1_115k2_with_s130_2.0.1 firmware manually with nrfConnect, still a big nope.
Here is one of the test commands I tried and the resulting output:
C:\Python27\Lib\site-packages\pc_ble_driver_py\examples>py -2 heart_rate_collector.py NRF51 COM3
Serial port used: COM3
File "heart_rate_collector.py", line 187, in <module>
main(serial_port)
File "heart_rate_collector.py", line 149, in main
collector.open()
File "heart_rate_collector.py", line 67, in open
self.adapter.driver.open()
File "C:\Python27\lib\site-packages\wrapt\wrappers.py", line 561, in __call__
args, kwargs)
File "C:\Python27\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 126, in wrapper
raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 13
Note: my dongle is working fine with Master Control Panel 3.10.0.14, although I need to unplug-replug the dongle after flashing for it to respond.
Am I doing something wrong? Is anyone else encountering this issue?
