On an nRF51822 without the Soft Device, I use the app timers in a driver for a GPS module that uses the UART. Each time I start reading from the UART, I also start a timer with a timeout of 2 seconds. When the timer handler is called, I set a bool to indicate that the read has timed out and the driver continues.
This works just fine for 3 to 5 minutes, but then I notice that the timer is having its handler called immediately after app_timer_start() in every case. I have no idea why.
static app_timer_id_t m_gps_response_timeout_timer_id;
In my gps_init(), which is called once only, at the start:
err_code = app_timer_create(&m_gps_response_timeout_timer_id, APP_TIMER_MODE_SINGLE_SHOT, gps_response_timeout_handler);
Every time I read a sentence from the GPS:
err_code = app_timer_start(m_gps_response_timeout_timer_id, GPS_TIMEOUT, NULL);
...UART stuff, including checking for timeout, in a loop...
err_code = app_timer_stop(m_gps_response_timeout_timer_id);
Header macros:
#define GPS_TIMER_PRESCALER 0
#define GPS_TIMEOUT APP_TIMER_TICKS(2000, GPS_TIMER_PRESCALER)
Timeout handler:
void gps_response_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
m_gps_response_timed_out = true;
I've verified that the timeout handler function is really getting called. Why would this work for a few minutes then stop working? I do have other timers in the same code, but they all have their own timer IDs of course.
